[PATCH v2] mx7ulp: add getting a board serial number
Get Unique ID of SoC iMX7ULP, using the logic described in Fusemap (IMX7ULPRMB2_Rev0_Fusemap) attached in the i.MX 7ULP APRM [1].
[1] https://www.nxp.com/docs/en/reference-manual/IMX7ULPRMB2.pdf
Signed-off-by: Ricardo Salveti ricardo@foundries.io Co-developed-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io ---
Changes in v2: - rebase the commit on top of the following series: https://patchwork.ozlabs.org/project/uboot/list/?series=260161
arch/arm/mach-imx/mx7ulp/soc.c | 23 +++++++++++++++++++++++ 1 file changed, 23 insertions(+)
diff --git a/arch/arm/mach-imx/mx7ulp/soc.c b/arch/arm/mach-imx/mx7ulp/soc.c index 320f24dd29..baf18cf8b7 100644 --- a/arch/arm/mach-imx/mx7ulp/soc.c +++ b/arch/arm/mach-imx/mx7ulp/soc.c @@ -13,6 +13,7 @@ #include <asm/arch/sys_proto.h> #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/hab.h> +#include <asm/setup.h> #include <linux/bitops.h>
#define PMC0_BASE_ADDR 0x410a1000 @@ -363,3 +364,25 @@ enum boot_device get_boot_device(void)
return boot_dev; } + +#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG +/* + * OCOTP_CFG (SJC CHALLENGE, Unique ID) + * i.MX 7ULP Applications Processor Reference Manual, Rev. 0, 09/2020 + * + * OCOTP_CFG0 offset 0x4B0: 15:0 -> 15:0 bits of Unique ID + * OCOTP_CFG1 offset 0x4C0: 15:0 -> 31:16 bits of Unique ID + * OCOTP_CFG2 offset 0x4D0: 15:0 -> 47:32 bits of Unique ID + * OCOTP_CFG3 offset 0x4E0: 15:0 -> 63:48 bits of Unique ID + */ +void get_board_serial(struct tag_serialnr *serialnr) +{ + struct ocotp_regs *ocotp = (struct ocotp_regs *)OCOTP_BASE_ADDR; + struct fuse_bank *bank = &ocotp->bank[1]; + struct fuse_bank1_regs *fuse = + (struct fuse_bank1_regs *)bank->fuse_regs; + + serialnr->low = (fuse->cfg0 & 0xFFFF) + ((fuse->cfg1 & 0xFFFF) << 16); + serialnr->high = (fuse->cfg2 & 0xFFFF) + ((fuse->cfg3 & 0xFFFF) << 16); +} +#endif /* CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG */
Hi Oleksandr,
On Tue, Aug 31, 2021 at 8:53 AM Oleksandr Suvorov oleksandr.suvorov@foundries.io wrote:
Reviewed-by: Fabio Estevam festevam@gmail.com
From: Ricardo Salveti ricardo@foundries.io Get Unique ID of SoC iMX7ULP, using the logic described in Fusemap (IMX7ULPRMB2_Rev0_Fusemap) attached in the i.MX 7ULP APRM [1]. [1] https://www.nxp.com/docs/en/reference-manual/IMX7ULPRMB2.pdf Signed-off-by: Ricardo Salveti ricardo@foundries.io Co-developed-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@foundries.io Reviewed-by: Fabio Estevam festevam@gmail.com
Best regards, Stefano Babic
Fabio Estevam
Oleksandr Suvorov
sbabic@denx.de
