[U-Boot] [PATCH V3] kconfig: add config option for shell prompt
Add option to set shell prompt string from menuconfig and migrate boards globally.
The migration is done as follows: - Boards that explicitly and unconditionally set CONFIG_SYS_PROMPT had the entry moved to their defconfig files. - Boards that defined some kind of #ifdef logic which selects the CONFIG_SYS_PROMPT (for example qemu-mips) got an #undef CONFIG_SYS_PROMPT right before the #ifdef logic and were left alone. - This change forces CONFIG_SYS_PROMPT to be a per board decision, and thus CONFIG_SYS_PROMPT was removed from all <soc>_common.h and <arch>_common.h files. This results in a streamlined default value across platforms, and includes the following files: spear-common, sunxi-common, mv-common, ti_armv7_common, tegra-common, at91-sama5_common, and zynq-common. - Boards that relied on <arch/soc>_common.h values of CONFIG_SYS_PROMPT were not updated in their respective defconfig files under the assumption that since they did not explicitly define a value, they're fine with whatever the default is. - On the other hand, boards that relied on a value defined in some <boards>_common.h file such as woodburn_common, rpi-common, bur_am335x_common, ls2085a_common, siemens_am33x_common, and omap3_evm_common, had their values moved to the respective defconfig files. - The define V_PROMPT was removed, since it is not used anywhere except for assigning a value for CONFIG_SYS_PROMPT.
Cc: Tom Rini trini@konsulko.com Cc: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Stefano Babic sbabic@denx.de Cc: Igor Grinberg grinberg@compulab.co.il Signed-off-by: Nikita Kiryanov nikita@compulab.co.il --- Changes in V3: - Do not add CONFIG_SYS_PROMPT with default value to defconfig files - Rebased over current mainline and compile tested again with buildman on arm and powerpc
Changes in V2: - Migrate boards globally (compile tested with buildman on arm and powerpc) - Change default value to "=> " - V_PROMPT define removed as part of the migration
common/Kconfig | 7 +++++++ configs/M5208EVBE_defconfig | 1 + configs/M52277EVB_defconfig | 1 + configs/M5235EVB_defconfig | 1 + configs/M5272C3_defconfig | 1 + configs/M5275EVB_defconfig | 1 + configs/M5282EVB_defconfig | 1 + configs/M53017EVB_defconfig | 1 + configs/M5329AFEE_defconfig | 1 + configs/M5329BFEE_defconfig | 1 + configs/M5373EVB_defconfig | 1 + configs/M54418TWR_defconfig | 1 + configs/M54418TWR_nand_mii_defconfig | 1 + configs/M54418TWR_nand_rmii_defconfig | 1 + configs/M54418TWR_nand_rmii_lowfreq_defconfig | 1 + configs/M54418TWR_serial_mii_defconfig | 1 + configs/M54418TWR_serial_rmii_defconfig | 1 + configs/M54451EVB_defconfig | 1 + configs/M54455EVB_defconfig | 1 + configs/M5475AFE_defconfig | 1 + configs/M5475BFE_defconfig | 1 + configs/M5475CFE_defconfig | 1 + configs/M5475DFE_defconfig | 1 + configs/M5475EFE_defconfig | 1 + configs/M5475FFE_defconfig | 1 + configs/M5475GFE_defconfig | 1 + configs/M5485AFE_defconfig | 1 + configs/M5485BFE_defconfig | 1 + configs/M5485CFE_defconfig | 1 + configs/M5485DFE_defconfig | 1 + configs/M5485EFE_defconfig | 1 + configs/M5485FFE_defconfig | 1 + configs/M5485GFE_defconfig | 1 + configs/M5485HFE_defconfig | 1 + configs/MPC8349ITXGP_defconfig | 1 + configs/MPC8349ITX_LOWBOOT_defconfig | 1 + configs/MPC8349ITX_defconfig | 1 + configs/PATI_defconfig | 1 + configs/UCP1020_defconfig | 1 + configs/VCMA9_defconfig | 1 + configs/ac14xx_defconfig | 1 + configs/adp-ag101_defconfig | 1 + configs/adp-ag101p_defconfig | 1 + configs/adp-ag102_defconfig | 1 + configs/am3517_crane_defconfig | 1 + configs/am3517_evm_defconfig | 1 + configs/amcore_defconfig | 1 + configs/apalis_t30_defconfig | 1 + configs/apf27_defconfig | 1 + configs/arcangel4_defconfig | 1 + configs/arndale_defconfig | 1 + configs/astro_mcf5373l_defconfig | 1 + configs/at91rm9200ek_defconfig | 1 + configs/at91rm9200ek_ram_defconfig | 1 + configs/at91sam9260ek_dataflash_cs0_defconfig | 1 + configs/at91sam9260ek_dataflash_cs1_defconfig | 1 + configs/at91sam9260ek_nandflash_defconfig | 1 + configs/at91sam9261ek_dataflash_cs0_defconfig | 1 + configs/at91sam9261ek_dataflash_cs3_defconfig | 1 + configs/at91sam9261ek_nandflash_defconfig | 1 + configs/at91sam9263ek_dataflash_cs0_defconfig | 1 + configs/at91sam9263ek_dataflash_defconfig | 1 + configs/at91sam9263ek_nandflash_defconfig | 1 + configs/at91sam9263ek_norflash_boot_defconfig | 1 + configs/at91sam9263ek_norflash_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs0_defconfig | 1 + configs/at91sam9g10ek_dataflash_cs3_defconfig | 1 + configs/at91sam9g10ek_nandflash_defconfig | 1 + configs/at91sam9g20ek_2mmc_defconfig | 1 + configs/at91sam9g20ek_2mmc_nandflash_defconfig | 1 + configs/at91sam9g20ek_dataflash_cs0_defconfig | 1 + configs/at91sam9g20ek_dataflash_cs1_defconfig | 1 + configs/at91sam9g20ek_nandflash_defconfig | 1 + configs/at91sam9m10g45ek_mmc_defconfig | 1 + configs/at91sam9m10g45ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_mmc_defconfig | 1 + configs/at91sam9n12ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_spiflash_defconfig | 1 + configs/at91sam9rlek_dataflash_defconfig | 1 + configs/at91sam9rlek_mmc_defconfig | 1 + configs/at91sam9rlek_nandflash_defconfig | 1 + configs/at91sam9x5ek_dataflash_defconfig | 1 + configs/at91sam9x5ek_mmc_defconfig | 1 + configs/at91sam9x5ek_nandflash_defconfig | 1 + configs/at91sam9x5ek_spiflash_defconfig | 1 + configs/at91sam9xeek_dataflash_cs0_defconfig | 1 + configs/at91sam9xeek_dataflash_cs1_defconfig | 1 + configs/at91sam9xeek_nandflash_defconfig | 1 + configs/atngw100_defconfig | 1 + configs/atngw100mkii_defconfig | 1 + configs/atstk1002_defconfig | 1 + configs/axs101_defconfig | 1 + configs/beaver_defconfig | 1 + configs/bf537-minotaur_defconfig | 1 + configs/bf537-srv1_defconfig | 1 + configs/bf561-acvilon_defconfig | 1 + configs/br4_defconfig | 1 + configs/cairo_defconfig | 1 + configs/calimain_defconfig | 1 + configs/cam_enc_4xx_defconfig | 1 + configs/cardhu_defconfig | 1 + configs/cgtqmx6qeval_defconfig | 1 + configs/cm_fx6_defconfig | 1 + configs/cm_t335_defconfig | 1 + configs/cm_t3517_defconfig | 1 + configs/cm_t35_defconfig | 1 + configs/cm_t54_defconfig | 1 + configs/cobra5272_defconfig | 1 + configs/colibri_t20_defconfig | 1 + configs/colibri_t30_defconfig | 1 + configs/colibri_vf_defconfig | 1 + configs/colibri_vf_dtb_defconfig | 1 + configs/corvus_defconfig | 1 + configs/cpu9260_128M_defconfig | 1 + configs/cpu9260_defconfig | 1 + configs/cpu9260_nand_128M_defconfig | 1 + configs/cpu9260_nand_defconfig | 1 + configs/cpu9G20_128M_defconfig | 1 + configs/cpu9G20_defconfig | 1 + configs/cpu9G20_nand_128M_defconfig | 1 + configs/cpu9G20_nand_defconfig | 1 + configs/cpuat91_defconfig | 1 + configs/da830evm_defconfig | 1 + configs/da850evm_defconfig | 1 + configs/da850evm_direct_nor_defconfig | 1 + configs/dalmore_defconfig | 1 + configs/davinci_dm355evm_defconfig | 1 + configs/davinci_dm355leopard_defconfig | 1 + configs/davinci_dm365evm_defconfig | 1 + configs/davinci_dm6467evm_defconfig | 1 + configs/davinci_dvevm_defconfig | 1 + configs/davinci_schmoogie_defconfig | 1 + configs/davinci_sffsdr_defconfig | 1 + configs/davinci_sonata_defconfig | 1 + configs/dbau1000_defconfig | 1 + configs/dbau1100_defconfig | 1 + configs/dbau1500_defconfig | 1 + configs/dbau1550_defconfig | 1 + configs/dbau1550_el_defconfig | 1 + configs/dig297_defconfig | 1 + configs/dockstar_defconfig | 1 + configs/draco_defconfig | 1 + configs/duovero_defconfig | 1 + configs/ea20_defconfig | 1 + configs/eb_cpu5282_defconfig | 1 + configs/eb_cpux9k2_defconfig | 1 + configs/eco5pk_defconfig | 1 + configs/edminiv2_defconfig | 1 + configs/ethernut5_defconfig | 1 + configs/flea3_defconfig | 1 + configs/fx12mm_defconfig | 1 + configs/goflexhome_defconfig | 1 + configs/grasshopper_defconfig | 1 + configs/gwventana_defconfig | 1 + configs/h2200_defconfig | 1 + configs/harmony_defconfig | 1 + configs/ib62x0_defconfig | 1 + configs/iconnect_defconfig | 1 + configs/ima3-mx53_defconfig | 1 + configs/imx31_litekit_defconfig | 1 + configs/imx31_phycore_defconfig | 1 + configs/integratorap_cm720t_defconfig | 1 + configs/integratorap_cm920t_defconfig | 1 + configs/integratorap_cm926ejs_defconfig | 1 + configs/integratorap_cm946es_defconfig | 1 + configs/integratorcp_cm1136_defconfig | 1 + configs/integratorcp_cm920t_defconfig | 1 + configs/integratorcp_cm926ejs_defconfig | 1 + configs/integratorcp_cm946es_defconfig | 1 + configs/ipam390_defconfig | 1 + configs/jetson-tk1_defconfig | 1 + configs/jornada_defconfig | 1 + configs/k2e_evm_defconfig | 1 + configs/k2hk_evm_defconfig | 1 + configs/k2l_evm_defconfig | 1 + configs/kwb_defconfig | 1 + configs/kzm9g_defconfig | 1 + configs/mcx_defconfig | 1 + configs/medcom-wide_defconfig | 1 + configs/microblaze-generic_defconfig | 1 + configs/ml507_defconfig | 1 + configs/mt_ventoux_defconfig | 1 + configs/mx51_efikamx_defconfig | 1 + configs/nas220_defconfig | 1 + configs/nhk8815_defconfig | 1 + configs/nokia_rx51_defconfig | 1 + configs/nyan-big_defconfig | 1 + configs/odroid-xu3_defconfig | 1 + configs/odroid_defconfig | 1 + configs/omap3_evm_defconfig | 1 + configs/omap3_evm_quick_mmc_defconfig | 1 + configs/omap3_evm_quick_nand_defconfig | 1 + configs/omap3_logic_defconfig | 1 + configs/omap3_mvblx_defconfig | 1 + configs/omap3_overo_defconfig | 1 + configs/omap3_pandora_defconfig | 1 + configs/omap3_sdp3430_defconfig | 1 + configs/omapl138_lcdk_defconfig | 1 + configs/origen_defconfig | 1 + configs/palmld_defconfig | 1 + configs/palmtc_defconfig | 1 + configs/paz00_defconfig | 1 + configs/pb1000_defconfig | 1 + configs/pcm030_defconfig | 1 + configs/peach-pi_defconfig | 1 + configs/peach-pit_defconfig | 1 + configs/pepper_defconfig | 1 + configs/platinum_picon_defconfig | 1 + configs/platinum_titanium_defconfig | 1 + configs/plutux_defconfig | 1 + configs/pm9261_defconfig | 1 + configs/pm9263_defconfig | 1 + configs/pm9g45_defconfig | 1 + configs/pogo_e02_defconfig | 1 + configs/pr1_defconfig | 1 + configs/pxm2_defconfig | 1 + configs/rastaban_defconfig | 1 + configs/rpi_2_defconfig | 1 + configs/rpi_defconfig | 1 + configs/rut_defconfig | 1 + configs/s5p_goni_defconfig | 1 + configs/s5pc210_universal_defconfig | 1 + configs/scb9328_defconfig | 1 + configs/seaboard_defconfig | 1 + configs/secomx6quq7_defconfig | 1 + configs/smdk2410_defconfig | 1 + configs/smdk5250_defconfig | 1 + configs/smdk5420_defconfig | 1 + configs/smdkc100_defconfig | 1 + configs/smdkv310_defconfig | 1 + configs/snapper9260_defconfig | 1 + configs/snow_defconfig | 1 + configs/snowball_defconfig | 1 + configs/stamp9g20_defconfig | 1 + configs/stm32f429-discovery_defconfig | 1 + configs/stv0991_defconfig | 1 + configs/stxgp3_defconfig | 1 + configs/stxssa_defconfig | 1 + configs/tao3530_defconfig | 1 + configs/taurus_defconfig | 1 + configs/tb100_defconfig | 1 + configs/tbs2910_defconfig | 1 + configs/tec-ng_defconfig | 1 + configs/tec_defconfig | 1 + configs/thuban_defconfig | 1 + configs/ti814x_evm_defconfig | 1 + configs/ti816x_evm_defconfig | 1 + configs/titanium_defconfig | 1 + configs/trats2_defconfig | 1 + configs/trats_defconfig | 1 + configs/tricorder_defconfig | 1 + configs/trimslice_defconfig | 1 + configs/tseries_mmc_defconfig | 1 + configs/tseries_nand_defconfig | 1 + configs/tseries_spi_defconfig | 1 + configs/tt01_defconfig | 1 + configs/twister_defconfig | 1 + configs/u8500_href_defconfig | 1 + configs/usb_a9263_dataflash_defconfig | 1 + configs/v5fx30teval_defconfig | 1 + configs/vct_platinum_defconfig | 1 + configs/vct_platinum_onenand_defconfig | 1 + configs/vct_platinum_onenand_small_defconfig | 1 + configs/vct_platinum_small_defconfig | 1 + configs/vct_platinumavc_defconfig | 1 + configs/vct_platinumavc_onenand_defconfig | 1 + configs/vct_platinumavc_onenand_small_defconfig | 1 + configs/vct_platinumavc_small_defconfig | 1 + configs/vct_premium_defconfig | 1 + configs/vct_premium_onenand_defconfig | 1 + configs/vct_premium_onenand_small_defconfig | 1 + configs/vct_premium_small_defconfig | 1 + configs/venice2_defconfig | 1 + configs/ventana_defconfig | 1 + configs/vexpress_aemv8a_juno_defconfig | 1 + configs/vexpress_aemv8a_semi_defconfig | 1 + configs/vision2_defconfig | 1 + configs/vl_ma2sc_defconfig | 1 + configs/vpac270_nor_128_defconfig | 1 + configs/vpac270_nor_256_defconfig | 1 + configs/vpac270_ond_256_defconfig | 1 + configs/whistler_defconfig | 1 + configs/wireless_space_defconfig | 1 + configs/woodburn_defconfig | 1 + configs/woodburn_sd_defconfig | 1 + configs/x600_defconfig | 1 + configs/xilinx-ppc405-generic_defconfig | 1 + configs/xilinx-ppc440-generic_defconfig | 1 + configs/xilinx_zynqmp_ep_defconfig | 2 ++ configs/zipitz2_defconfig | 1 + configs/zmx25_defconfig | 1 + include/configs/M5208EVBE.h | 1 - include/configs/M52277EVB.h | 1 - include/configs/M5235EVB.h | 1 - include/configs/M5272C3.h | 1 - include/configs/M5275EVB.h | 1 - include/configs/M5282EVB.h | 1 - include/configs/M53017EVB.h | 1 - include/configs/M5329EVB.h | 1 - include/configs/M5373EVB.h | 1 - include/configs/M54418TWR.h | 1 - include/configs/M54451EVB.h | 1 - include/configs/M54455EVB.h | 1 - include/configs/M5475EVB.h | 1 - include/configs/M5485EVB.h | 1 - include/configs/MPC8349ITX.h | 6 ------ include/configs/PATI.h | 1 - include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/UCP1020.h | 1 - include/configs/VCMA9.h | 1 - include/configs/ac14xx.h | 1 - include/configs/adp-ag101.h | 1 - include/configs/adp-ag101p.h | 1 - include/configs/adp-ag102.h | 1 - include/configs/am3517_crane.h | 3 --- include/configs/am3517_evm.h | 3 --- include/configs/amcore.h | 1 - include/configs/apalis_t30.h | 1 - include/configs/apf27.h | 1 - include/configs/arcangel4.h | 1 - include/configs/arndale.h | 1 - include/configs/astro_mcf5373l.h | 2 -- include/configs/at91-sama5_common.h | 1 - include/configs/at91rm9200ek.h | 1 - include/configs/at91sam9260ek.h | 1 - include/configs/at91sam9261ek.h | 1 - include/configs/at91sam9263ek.h | 1 - include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 1 - include/configs/at91sam9rlek.h | 1 - include/configs/at91sam9x5ek.h | 1 - include/configs/atngw100.h | 1 - include/configs/atngw100mkii.h | 1 - include/configs/atstk1002.h | 1 - include/configs/axs101.h | 1 - include/configs/balloon3.h | 1 + include/configs/beaver.h | 1 - include/configs/bf537-minotaur.h | 1 - include/configs/bf537-srv1.h | 1 - include/configs/bf561-acvilon.h | 1 - include/configs/br4.h | 1 - include/configs/bur_am335x_common.h | 1 - include/configs/calimain.h | 1 - include/configs/cam_enc_4xx.h | 1 - include/configs/cardhu.h | 1 - include/configs/cm_fx6.h | 1 - include/configs/cm_t335.h | 3 --- include/configs/cm_t35.h | 1 - include/configs/cm_t3517.h | 1 - include/configs/cm_t54.h | 2 -- include/configs/cobra5272.h | 2 -- include/configs/colibri_pxa270.h | 1 + include/configs/colibri_t20.h | 1 - include/configs/colibri_t30.h | 1 - include/configs/colibri_vf.h | 1 - include/configs/corvus.h | 1 - include/configs/cpu9260.h | 5 ----- include/configs/cpuat91.h | 1 - include/configs/da830evm.h | 1 - include/configs/da850evm.h | 1 - include/configs/dalmore.h | 1 - include/configs/davinci_dm355evm.h | 1 - include/configs/davinci_dm355leopard.h | 1 - include/configs/davinci_dm365evm.h | 1 - include/configs/davinci_dm6467evm.h | 1 - include/configs/davinci_dvevm.h | 1 - include/configs/davinci_schmoogie.h | 1 - include/configs/davinci_sffsdr.h | 1 - include/configs/davinci_sonata.h | 1 - include/configs/dbau1x00.h | 2 -- include/configs/dig297.h | 1 - include/configs/dockstar.h | 3 --- include/configs/duovero.h | 3 --- include/configs/ea20.h | 1 - include/configs/eb_cpu5282.h | 1 - include/configs/eb_cpux9k2.h | 1 - include/configs/eco5pk.h | 6 ------ include/configs/edb93xx.h | 2 +- include/configs/edminiv2.h | 1 - include/configs/ethernut5.h | 1 - include/configs/flea3.h | 1 - include/configs/fx12mm.h | 1 - include/configs/goflexhome.h | 3 --- include/configs/grasshopper.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/h2200.h | 1 - include/configs/harmony.h | 1 - include/configs/hrcon.h | 1 - include/configs/ib62x0.h | 3 --- include/configs/iconnect.h | 3 --- include/configs/ima3-mx53.h | 1 - include/configs/imx31_litekit.h | 1 - include/configs/imx31_phycore.h | 1 - include/configs/integratorap.h | 5 ----- include/configs/integratorcp.h | 2 -- include/configs/ipam390.h | 1 - include/configs/jetson-tk1.h | 1 - include/configs/jornada.h | 1 - include/configs/kzm9g.h | 1 - include/configs/lp8x4x.h | 1 + include/configs/ls2085a_common.h | 1 - include/configs/lsxl.h | 1 - include/configs/malta.h | 1 + include/configs/mcx.h | 3 --- include/configs/medcom-wide.h | 1 - include/configs/microblaze-generic.h | 2 -- include/configs/ml507.h | 1 - include/configs/mt_ventoux.h | 6 ------ include/configs/mv-common.h | 1 - include/configs/mx51_efikamx.h | 1 - include/configs/mx6ul_14x14_evk.h | 1 - include/configs/nas220.h | 4 ---- include/configs/nhk8815.h | 1 - include/configs/nokia_rx51.h | 1 - include/configs/nyan-big.h | 1 - include/configs/odroid.h | 3 --- include/configs/odroid_xu3.h | 1 - include/configs/omap3_cairo.h | 4 ---- include/configs/omap3_evm_common.h | 1 - include/configs/omap3_logic.h | 1 - include/configs/omap3_mvblx.h | 1 - include/configs/omap3_overo.h | 6 ------ include/configs/omap3_pandora.h | 6 ------ include/configs/omap3_sdp3430.h | 1 - include/configs/omapl138_lcdk.h | 1 - include/configs/origen.h | 3 --- include/configs/palmld.h | 3 --- include/configs/palmtc.h | 3 --- include/configs/palmtreo680.h | 1 + include/configs/paz00.h | 1 - include/configs/pb1x00.h | 1 - include/configs/pcm030.h | 1 - include/configs/peach-pi.h | 1 - include/configs/peach-pit.h | 1 - include/configs/pepper.h | 3 --- include/configs/platinum_picon.h | 2 -- include/configs/platinum_titanium.h | 2 -- include/configs/plutux.h | 1 - include/configs/pm9261.h | 1 - include/configs/pm9263.h | 1 - include/configs/pm9g45.h | 1 - include/configs/pogo_e02.h | 4 ---- include/configs/pr1.h | 1 - include/configs/pxa255_idp.h | 1 + include/configs/qemu-mips.h | 1 + include/configs/qemu-mips64.h | 1 + include/configs/rpi-common.h | 1 - include/configs/s5p_goni.h | 1 - include/configs/s5pc210_universal.h | 3 --- include/configs/scb9328.h | 1 - include/configs/seaboard.h | 1 - include/configs/secomx6quq7.h | 3 --- include/configs/siemens-am33x-common.h | 1 - include/configs/smdk2410.h | 1 - include/configs/smdk5250.h | 1 - include/configs/smdk5420.h | 1 - include/configs/smdkc100.h | 1 - include/configs/smdkv310.h | 1 - include/configs/snapper9260.h | 1 - include/configs/snow.h | 1 - include/configs/snowball.h | 1 - include/configs/spear-common.h | 1 - include/configs/stamp9g20.h | 1 - include/configs/stm32f429-discovery.h | 1 - include/configs/stv0991.h | 1 - include/configs/stxgp3.h | 1 - include/configs/stxssa.h | 1 - include/configs/sunxi-common.h | 2 -- include/configs/tao3530.h | 1 - include/configs/taurus.h | 1 - include/configs/tb100.h | 1 - include/configs/tbs2910.h | 1 - include/configs/tec-ng.h | 1 - include/configs/tec.h | 1 - include/configs/tegra-common.h | 4 ---- include/configs/ti814x_evm.h | 1 - include/configs/ti816x_evm.h | 1 - include/configs/ti_armv7_common.h | 1 - include/configs/titanium.h | 3 --- include/configs/trats.h | 2 -- include/configs/trats2.h | 3 --- include/configs/tricorder.h | 1 - include/configs/trimslice.h | 1 - include/configs/trizepsiv.h | 1 + include/configs/tt01.h | 1 - include/configs/twister.h | 2 -- include/configs/u8500_href.h | 1 - include/configs/usb_a9263.h | 1 - include/configs/v5fx30teval.h | 1 - include/configs/vct.h | 1 - include/configs/venice2.h | 1 - include/configs/ventana.h | 1 - include/configs/versatile.h | 1 + include/configs/vexpress_aemv8a.h | 1 - include/configs/vexpress_common.h | 1 - include/configs/vision2.h | 1 - include/configs/vl_ma2sc.h | 1 - include/configs/vpac270.h | 1 - include/configs/whistler.h | 1 - include/configs/wireless_space.h | 2 -- include/configs/woodburn_common.h | 1 - include/configs/x600.h | 1 - include/configs/xaeniax.h | 2 +- include/configs/xilinx-ppc405-generic.h | 1 - include/configs/xilinx-ppc440-generic.h | 1 - include/configs/xilinx_zynqmp.h | 1 - include/configs/zipitz2.h | 3 --- include/configs/zmx25.h | 1 - include/configs/zynq-common.h | 1 - 510 files changed, 310 insertions(+), 304 deletions(-)
diff --git a/common/Kconfig b/common/Kconfig index 40cd69e..88dc016 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -17,6 +17,13 @@ config SYS_HUSH_PARSER help Backward compatibility.
+config SYS_PROMPT + string "Shell prompt" + default "=> " + help + This string is displayed in the command line to the left of the + cursor. + menu "Autoboot options"
config AUTOBOOT_KEYED diff --git a/configs/M5208EVBE_defconfig b/configs/M5208EVBE_defconfig index 58de96b..6a46194 100644 --- a/configs/M5208EVBE_defconfig +++ b/configs/M5208EVBE_defconfig @@ -1,3 +1,4 @@ CONFIG_M68K=y CONFIG_TARGET_M5208EVBE=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M52277EVB_defconfig b/configs/M52277EVB_defconfig index 6a2d175..608edc5 100644 --- a/configs/M52277EVB_defconfig +++ b/configs/M52277EVB_defconfig @@ -5,3 +5,4 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_SPANSION_BOOT,SYS_TEXT_BASE=0x00000000" # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M5235EVB_defconfig b/configs/M5235EVB_defconfig index 3292cff..e9c2b7c 100644 --- a/configs/M5235EVB_defconfig +++ b/configs/M5235EVB_defconfig @@ -4,3 +4,4 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0xFFE00000" # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M5272C3_defconfig b/configs/M5272C3_defconfig index 23d5468..6ad4e13 100644 --- a/configs/M5272C3_defconfig +++ b/configs/M5272C3_defconfig @@ -3,3 +3,4 @@ CONFIG_TARGET_M5272C3=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M5275EVB_defconfig b/configs/M5275EVB_defconfig index f051bf1..b29021b 100644 --- a/configs/M5275EVB_defconfig +++ b/configs/M5275EVB_defconfig @@ -3,3 +3,4 @@ CONFIG_TARGET_M5275EVB=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M5282EVB_defconfig b/configs/M5282EVB_defconfig index 6c130e8..322ee9a 100644 --- a/configs/M5282EVB_defconfig +++ b/configs/M5282EVB_defconfig @@ -3,3 +3,4 @@ CONFIG_TARGET_M5282EVB=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M53017EVB_defconfig b/configs/M53017EVB_defconfig index 1f5bc86..3e72290 100644 --- a/configs/M53017EVB_defconfig +++ b/configs/M53017EVB_defconfig @@ -1,3 +1,4 @@ CONFIG_M68K=y CONFIG_TARGET_M53017EVB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M5329AFEE_defconfig b/configs/M5329AFEE_defconfig index 02af3a4..1d2bb81 100644 --- a/configs/M5329AFEE_defconfig +++ b/configs/M5329AFEE_defconfig @@ -2,3 +2,4 @@ CONFIG_M68K=y CONFIG_TARGET_M5329EVB=y CONFIG_SYS_EXTRA_OPTIONS="NANDFLASH_SIZE=0" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M5329BFEE_defconfig b/configs/M5329BFEE_defconfig index f757a35..915734c 100644 --- a/configs/M5329BFEE_defconfig +++ b/configs/M5329BFEE_defconfig @@ -2,3 +2,4 @@ CONFIG_M68K=y CONFIG_TARGET_M5329EVB=y CONFIG_SYS_EXTRA_OPTIONS="NANDFLASH_SIZE=16" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M5373EVB_defconfig b/configs/M5373EVB_defconfig index 304ca48..eb7a96a 100644 --- a/configs/M5373EVB_defconfig +++ b/configs/M5373EVB_defconfig @@ -2,3 +2,4 @@ CONFIG_M68K=y CONFIG_TARGET_M5373EVB=y CONFIG_SYS_EXTRA_OPTIONS="NANDFLASH_SIZE=16" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M54418TWR_defconfig b/configs/M54418TWR_defconfig index 9a93b3b..a5c35d1 100644 --- a/configs/M54418TWR_defconfig +++ b/configs/M54418TWR_defconfig @@ -7,3 +7,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CF_SBF,SYS_SERIAL_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_IN # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M54418TWR_nand_mii_defconfig b/configs/M54418TWR_nand_mii_defconfig index c194ea7..20eadcf 100644 --- a/configs/M54418TWR_nand_mii_defconfig +++ b/configs/M54418TWR_nand_mii_defconfig @@ -7,3 +7,4 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_NAND_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSR # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M54418TWR_nand_rmii_defconfig b/configs/M54418TWR_nand_rmii_defconfig index 4ee35ff..d47127c 100644 --- a/configs/M54418TWR_nand_rmii_defconfig +++ b/configs/M54418TWR_nand_rmii_defconfig @@ -7,3 +7,4 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_NAND_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_INPUT_CLKSR # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M54418TWR_nand_rmii_lowfreq_defconfig b/configs/M54418TWR_nand_rmii_lowfreq_defconfig index 4c4b70a..700745d 100644 --- a/configs/M54418TWR_nand_rmii_lowfreq_defconfig +++ b/configs/M54418TWR_nand_rmii_lowfreq_defconfig @@ -7,3 +7,4 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_NAND_BOOT,LOW_MCFCLK,SYS_TEXT_BASE=0x47E00000,SYS_ # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M54418TWR_serial_mii_defconfig b/configs/M54418TWR_serial_mii_defconfig index 3be102c..4450084 100644 --- a/configs/M54418TWR_serial_mii_defconfig +++ b/configs/M54418TWR_serial_mii_defconfig @@ -7,3 +7,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CF_SBF,SYS_SERIAL_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_IN # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M54418TWR_serial_rmii_defconfig b/configs/M54418TWR_serial_rmii_defconfig index 9a93b3b..a5c35d1 100644 --- a/configs/M54418TWR_serial_rmii_defconfig +++ b/configs/M54418TWR_serial_rmii_defconfig @@ -7,3 +7,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CF_SBF,SYS_SERIAL_BOOT,SYS_TEXT_BASE=0x47E00000,SYS_IN # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M54451EVB_defconfig b/configs/M54451EVB_defconfig index b35bb81..0b446b8 100644 --- a/configs/M54451EVB_defconfig +++ b/configs/M54451EVB_defconfig @@ -5,3 +5,4 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x00000000,SYS_INPUT_CLKSRC=24000000" # CONFIG_CMD_LOADS is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M54455EVB_defconfig b/configs/M54455EVB_defconfig index cb56586..c7a0164 100644 --- a/configs/M54455EVB_defconfig +++ b/configs/M54455EVB_defconfig @@ -5,3 +5,4 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_ATMEL_BOOT,SYS_TEXT_BASE=0x04000000,SYS_INPUT_CLKS # CONFIG_CMD_LOADS is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M5475AFE_defconfig b/configs/M5475AFE_defconfig index 343f52f..b29d1a6 100644 --- a/configs/M5475AFE_defconfig +++ b/configs/M5475AFE_defconfig @@ -2,3 +2,4 @@ CONFIG_M68K=y CONFIG_TARGET_M5475EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M5475BFE_defconfig b/configs/M5475BFE_defconfig index c9667da..e62fbf6 100644 --- a/configs/M5475BFE_defconfig +++ b/configs/M5475BFE_defconfig @@ -2,3 +2,4 @@ CONFIG_M68K=y CONFIG_TARGET_M5475EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M5475CFE_defconfig b/configs/M5475CFE_defconfig index c1a9558..195b4e3 100644 --- a/configs/M5475CFE_defconfig +++ b/configs/M5475CFE_defconfig @@ -2,3 +2,4 @@ CONFIG_M68K=y CONFIG_TARGET_M5475EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16,SYS_VIDEO,SYS_USBCTRL" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M5475DFE_defconfig b/configs/M5475DFE_defconfig index d879894..314ced6 100644 --- a/configs/M5475DFE_defconfig +++ b/configs/M5475DFE_defconfig @@ -2,3 +2,4 @@ CONFIG_M68K=y CONFIG_TARGET_M5475EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_USBCTRL" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M5475EFE_defconfig b/configs/M5475EFE_defconfig index 9b677ee..279808f 100644 --- a/configs/M5475EFE_defconfig +++ b/configs/M5475EFE_defconfig @@ -2,3 +2,4 @@ CONFIG_M68K=y CONFIG_TARGET_M5475EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_VIDEO,SYS_USBCTRL" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M5475FFE_defconfig b/configs/M5475FFE_defconfig index 4989b00..a00100e 100644 --- a/configs/M5475FFE_defconfig +++ b/configs/M5475FFE_defconfig @@ -2,3 +2,4 @@ CONFIG_M68K=y CONFIG_TARGET_M5475EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=32,SYS_VIDEO,SYS_USBCTRL,SYS_DRAMSZ1=64" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M5475GFE_defconfig b/configs/M5475GFE_defconfig index 31df40e..1ea82a7 100644 --- a/configs/M5475GFE_defconfig +++ b/configs/M5475GFE_defconfig @@ -2,3 +2,4 @@ CONFIG_M68K=y CONFIG_TARGET_M5475EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=133333333,SYS_BOOTSZ=4,SYS_DRAMSZ=64" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M5485AFE_defconfig b/configs/M5485AFE_defconfig index 5381b74..70cfa8f 100644 --- a/configs/M5485AFE_defconfig +++ b/configs/M5485AFE_defconfig @@ -2,3 +2,4 @@ CONFIG_M68K=y CONFIG_TARGET_M5485EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M5485BFE_defconfig b/configs/M5485BFE_defconfig index 36dcccf..377b87f 100644 --- a/configs/M5485BFE_defconfig +++ b/configs/M5485BFE_defconfig @@ -2,3 +2,4 @@ CONFIG_M68K=y CONFIG_TARGET_M5485EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M5485CFE_defconfig b/configs/M5485CFE_defconfig index e5cc1e1..faa0196 100644 --- a/configs/M5485CFE_defconfig +++ b/configs/M5485CFE_defconfig @@ -2,3 +2,4 @@ CONFIG_M68K=y CONFIG_TARGET_M5485EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16,SYS_VIDEO,SYS_USBCTRL" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M5485DFE_defconfig b/configs/M5485DFE_defconfig index fdf667a..71a028f 100644 --- a/configs/M5485DFE_defconfig +++ b/configs/M5485DFE_defconfig @@ -2,3 +2,4 @@ CONFIG_M68K=y CONFIG_TARGET_M5485EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_USBCTRL" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M5485EFE_defconfig b/configs/M5485EFE_defconfig index a5933f2..784803e 100644 --- a/configs/M5485EFE_defconfig +++ b/configs/M5485EFE_defconfig @@ -2,3 +2,4 @@ CONFIG_M68K=y CONFIG_TARGET_M5485EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_VIDEO,SYS_USBCTRL" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M5485FFE_defconfig b/configs/M5485FFE_defconfig index 116c5cc..8a831e3 100644 --- a/configs/M5485FFE_defconfig +++ b/configs/M5485FFE_defconfig @@ -2,3 +2,4 @@ CONFIG_M68K=y CONFIG_TARGET_M5485EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=32,SYS_VIDEO,SYS_USBCTRL,SYS_DRAMSZ1=64" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M5485GFE_defconfig b/configs/M5485GFE_defconfig index fd5fc1a..00c7479 100644 --- a/configs/M5485GFE_defconfig +++ b/configs/M5485GFE_defconfig @@ -2,3 +2,4 @@ CONFIG_M68K=y CONFIG_TARGET_M5485EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=4,SYS_DRAMSZ=64" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/M5485HFE_defconfig b/configs/M5485HFE_defconfig index 6e2768c..887bd4d 100644 --- a/configs/M5485HFE_defconfig +++ b/configs/M5485HFE_defconfig @@ -2,3 +2,4 @@ CONFIG_M68K=y CONFIG_TARGET_M5485EVB=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16,SYS_VIDEO" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="-> " diff --git a/configs/MPC8349ITXGP_defconfig b/configs/MPC8349ITXGP_defconfig index 7a43fa0..4578b32 100644 --- a/configs/MPC8349ITXGP_defconfig +++ b/configs/MPC8349ITXGP_defconfig @@ -3,3 +3,4 @@ CONFIG_MPC83xx=y CONFIG_TARGET_MPC8349ITX=y CONFIG_SYS_EXTRA_OPTIONS="MPC8349ITXGP,SYS_TEXT_BASE=0xFE000000" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="MPC8349E-mITX-GP> " diff --git a/configs/MPC8349ITX_LOWBOOT_defconfig b/configs/MPC8349ITX_LOWBOOT_defconfig index f74d42c..c5fbeb9 100644 --- a/configs/MPC8349ITX_LOWBOOT_defconfig +++ b/configs/MPC8349ITX_LOWBOOT_defconfig @@ -3,3 +3,4 @@ CONFIG_MPC83xx=y CONFIG_TARGET_MPC8349ITX=y CONFIG_SYS_EXTRA_OPTIONS="MPC8349ITX,SYS_TEXT_BASE=0xFE000000" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="MPC8349E-mITX> " diff --git a/configs/MPC8349ITX_defconfig b/configs/MPC8349ITX_defconfig index 84c117c..a895c53 100644 --- a/configs/MPC8349ITX_defconfig +++ b/configs/MPC8349ITX_defconfig @@ -3,3 +3,4 @@ CONFIG_MPC83xx=y CONFIG_TARGET_MPC8349ITX=y CONFIG_SYS_EXTRA_OPTIONS="MPC8349ITX" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="MPC8349E-mITX> " diff --git a/configs/PATI_defconfig b/configs/PATI_defconfig index da8525e..6c1bf17 100644 --- a/configs/PATI_defconfig +++ b/configs/PATI_defconfig @@ -13,3 +13,4 @@ CONFIG_TARGET_PATI=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="pati=> " diff --git a/configs/UCP1020_defconfig b/configs/UCP1020_defconfig index 010b15f..cada7bb 100644 --- a/configs/UCP1020_defconfig +++ b/configs/UCP1020_defconfig @@ -5,3 +5,4 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc>" to stop\n" CONFIG_AUTOBOOT_STOP_STR="\x1b" CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="B$ " diff --git a/configs/VCMA9_defconfig b/configs/VCMA9_defconfig index 8885f1a..e9b28a8 100644 --- a/configs/VCMA9_defconfig +++ b/configs/VCMA9_defconfig @@ -1,3 +1,4 @@ CONFIG_ARM=y CONFIG_TARGET_VCMA9=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="VCMA9 # " diff --git a/configs/ac14xx_defconfig b/configs/ac14xx_defconfig index 37fb0e0..238630e 100644 --- a/configs/ac14xx_defconfig +++ b/configs/ac14xx_defconfig @@ -2,3 +2,4 @@ CONFIG_PPC=y CONFIG_MPC512X=y CONFIG_TARGET_AC14XX=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="ac14xx> " diff --git a/configs/adp-ag101_defconfig b/configs/adp-ag101_defconfig index e550f71..ac1dcaa 100644 --- a/configs/adp-ag101_defconfig +++ b/configs/adp-ag101_defconfig @@ -1,3 +1,4 @@ CONFIG_NDS32=y CONFIG_TARGET_ADP_AG101=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="NDS32 # " diff --git a/configs/adp-ag101p_defconfig b/configs/adp-ag101p_defconfig index 740cb57..92aa0be 100644 --- a/configs/adp-ag101p_defconfig +++ b/configs/adp-ag101p_defconfig @@ -1,3 +1,4 @@ CONFIG_NDS32=y CONFIG_TARGET_ADP_AG101P=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="NDS32 # " diff --git a/configs/adp-ag102_defconfig b/configs/adp-ag102_defconfig index 721f61d..1bef350 100644 --- a/configs/adp-ag102_defconfig +++ b/configs/adp-ag102_defconfig @@ -3,3 +3,4 @@ CONFIG_TARGET_ADP_AG102=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="NDS32 # " diff --git a/configs/am3517_crane_defconfig b/configs/am3517_crane_defconfig index a44ffe7..806dc3a 100644 --- a/configs/am3517_crane_defconfig +++ b/configs/am3517_crane_defconfig @@ -9,3 +9,4 @@ CONFIG_SPL=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="AM3517_CRANE # " diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index c72d29e..95b6754 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -8,3 +8,4 @@ CONFIG_FIT=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="AM3517_EVM # " diff --git a/configs/amcore_defconfig b/configs/amcore_defconfig index 47c4f3d..dc16d5b 100644 --- a/configs/amcore_defconfig +++ b/configs/amcore_defconfig @@ -6,3 +6,4 @@ CONFIG_TARGET_AMCORE=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="amcore $ " diff --git a/configs/apalis_t30_defconfig b/configs/apalis_t30_defconfig index fa9f365..c0bc3c5 100644 --- a/configs/apalis_t30_defconfig +++ b/configs/apalis_t30_defconfig @@ -12,3 +12,4 @@ CONFIG_SPL_DM=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="Apalis T30 # " diff --git a/configs/apf27_defconfig b/configs/apf27_defconfig index 854a2b7..4503235 100644 --- a/configs/apf27_defconfig +++ b/configs/apf27_defconfig @@ -3,3 +3,4 @@ CONFIG_TARGET_APF27=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_SYS_PROMPT="BIOS> " diff --git a/configs/arcangel4_defconfig b/configs/arcangel4_defconfig index 5683b81..cd9aafd 100644 --- a/configs/arcangel4_defconfig +++ b/configs/arcangel4_defconfig @@ -11,3 +11,4 @@ CONFIG_OF_EMBED=y CONFIG_DM=y CONFIG_DM_SERIAL=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="arcangel4# " diff --git a/configs/arndale_defconfig b/configs/arndale_defconfig index aa489cf..43c5527 100644 --- a/configs/arndale_defconfig +++ b/configs/arndale_defconfig @@ -13,3 +13,4 @@ CONFIG_SOUND_MAX98095=y CONFIG_SOUND_WM8994=y CONFIG_USB=y CONFIG_DM_USB=y +CONFIG_SYS_PROMPT="ARNDALE # " diff --git a/configs/astro_mcf5373l_defconfig b/configs/astro_mcf5373l_defconfig index f394f4d..8676120 100644 --- a/configs/astro_mcf5373l_defconfig +++ b/configs/astro_mcf5373l_defconfig @@ -3,3 +3,4 @@ CONFIG_TARGET_ASTRO_MCF5373L=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="URMEL > " diff --git a/configs/at91rm9200ek_defconfig b/configs/at91rm9200ek_defconfig index 74d4f3a..10df5f8 100644 --- a/configs/at91rm9200ek_defconfig +++ b/configs/at91rm9200ek_defconfig @@ -3,3 +3,4 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91RM9200EK=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91rm9200ek_ram_defconfig b/configs/at91rm9200ek_ram_defconfig index f499453..2765e9d 100644 --- a/configs/at91rm9200ek_ram_defconfig +++ b/configs/at91rm9200ek_ram_defconfig @@ -4,3 +4,4 @@ CONFIG_TARGET_AT91RM9200EK=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9260ek_dataflash_cs0_defconfig b/configs/at91sam9260ek_dataflash_cs0_defconfig index 96c5eee..9909bc8 100644 --- a/configs/at91sam9260ek_dataflash_cs0_defconfig +++ b/configs/at91sam9260ek_dataflash_cs0_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_DATAFLASH_CS0" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9260ek_dataflash_cs1_defconfig b/configs/at91sam9260ek_dataflash_cs1_defconfig index 6330c3e..8fdbd88 100644 --- a/configs/at91sam9260ek_dataflash_cs1_defconfig +++ b/configs/at91sam9260ek_dataflash_cs1_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_DATAFLASH_CS1" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9260ek_nandflash_defconfig b/configs/at91sam9260ek_nandflash_defconfig index ae2defd..e4fc8d7 100644 --- a/configs/at91sam9260ek_nandflash_defconfig +++ b/configs/at91sam9260ek_nandflash_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260,SYS_USE_NANDFLASH" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9261ek_dataflash_cs0_defconfig b/configs/at91sam9261ek_dataflash_cs0_defconfig index 838b235..e182f70 100644 --- a/configs/at91sam9261ek_dataflash_cs0_defconfig +++ b/configs/at91sam9261ek_dataflash_cs0_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261,SYS_USE_DATAFLASH_CS0" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9261ek_dataflash_cs3_defconfig b/configs/at91sam9261ek_dataflash_cs3_defconfig index 6104479..b3a35dd 100644 --- a/configs/at91sam9261ek_dataflash_cs3_defconfig +++ b/configs/at91sam9261ek_dataflash_cs3_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261,SYS_USE_DATAFLASH_CS3" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9261ek_nandflash_defconfig b/configs/at91sam9261ek_nandflash_defconfig index 4015c9f..58aa38f 100644 --- a/configs/at91sam9261ek_nandflash_defconfig +++ b/configs/at91sam9261ek_nandflash_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261,SYS_USE_NANDFLASH" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9263ek_dataflash_cs0_defconfig b/configs/at91sam9263ek_dataflash_cs0_defconfig index d9003ff..82e1b86 100644 --- a/configs/at91sam9263ek_dataflash_cs0_defconfig +++ b/configs/at91sam9263ek_dataflash_cs0_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9263ek_dataflash_defconfig b/configs/at91sam9263ek_dataflash_defconfig index d9003ff..82e1b86 100644 --- a/configs/at91sam9263ek_dataflash_defconfig +++ b/configs/at91sam9263ek_dataflash_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9263ek_nandflash_defconfig b/configs/at91sam9263ek_nandflash_defconfig index 600c5dd..bac882e 100644 --- a/configs/at91sam9263ek_nandflash_defconfig +++ b/configs/at91sam9263ek_nandflash_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_NANDFLASH" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9263ek_norflash_boot_defconfig b/configs/at91sam9263ek_norflash_boot_defconfig index 2e34b79..75f0ec6 100644 --- a/configs/at91sam9263ek_norflash_boot_defconfig +++ b/configs/at91sam9263ek_norflash_boot_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_BOOT_NORFLASH" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9263ek_norflash_defconfig b/configs/at91sam9263ek_norflash_defconfig index f72ed85..5bcdab0 100644 --- a/configs/at91sam9263ek_norflash_defconfig +++ b/configs/at91sam9263ek_norflash_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_NORFLASH" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9g10ek_dataflash_cs0_defconfig b/configs/at91sam9g10ek_dataflash_cs0_defconfig index 5f8d803..80e6a8a 100644 --- a/configs/at91sam9g10ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs0_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G10,SYS_USE_DATAFLASH_CS0" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9g10ek_dataflash_cs3_defconfig b/configs/at91sam9g10ek_dataflash_cs3_defconfig index 3ed763e..e6c9f61 100644 --- a/configs/at91sam9g10ek_dataflash_cs3_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs3_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G10,SYS_USE_DATAFLASH_CS3" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9g10ek_nandflash_defconfig b/configs/at91sam9g10ek_nandflash_defconfig index c27e39a..0adaf11 100644 --- a/configs/at91sam9g10ek_nandflash_defconfig +++ b/configs/at91sam9g10ek_nandflash_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G10,SYS_USE_NANDFLASH" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9g20ek_2mmc_defconfig b/configs/at91sam9g20ek_2mmc_defconfig index d58de8e..40cd6b1 100644 --- a/configs/at91sam9g20ek_2mmc_defconfig +++ b/configs/at91sam9g20ek_2mmc_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,AT91SAM9G20EK_2MMC,SYS_USE_MMC" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9g20ek_2mmc_nandflash_defconfig b/configs/at91sam9g20ek_2mmc_nandflash_defconfig index 4b28839..6f59305 100644 --- a/configs/at91sam9g20ek_2mmc_nandflash_defconfig +++ b/configs/at91sam9g20ek_2mmc_nandflash_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,AT91SAM9G20EK_2MMC,SYS_USE_NANDFLASH" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9g20ek_dataflash_cs0_defconfig b/configs/at91sam9g20ek_dataflash_cs0_defconfig index ee86dad..b63c6d6 100644 --- a/configs/at91sam9g20ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs0_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_DATAFLASH_CS0" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9g20ek_dataflash_cs1_defconfig b/configs/at91sam9g20ek_dataflash_cs1_defconfig index 39d4b09..aad9c1e 100644 --- a/configs/at91sam9g20ek_dataflash_cs1_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs1_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_DATAFLASH_CS1" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9g20ek_nandflash_defconfig b/configs/at91sam9g20ek_nandflash_defconfig index d636485..f247084 100644 --- a/configs/at91sam9g20ek_nandflash_defconfig +++ b/configs/at91sam9g20ek_nandflash_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,SYS_USE_NANDFLASH" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9m10g45ek_mmc_defconfig b/configs/at91sam9m10g45ek_mmc_defconfig index 1472d20..f88b48b 100644 --- a/configs/at91sam9m10g45ek_mmc_defconfig +++ b/configs/at91sam9m10g45ek_mmc_defconfig @@ -10,3 +10,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,SYS_USE_MMC" # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9m10g45ek_nandflash_defconfig b/configs/at91sam9m10g45ek_nandflash_defconfig index 526419c..7675f52 100644 --- a/configs/at91sam9m10g45ek_nandflash_defconfig +++ b/configs/at91sam9m10g45ek_nandflash_defconfig @@ -10,3 +10,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,SYS_USE_NANDFLASH" # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9n12ek_mmc_defconfig b/configs/at91sam9n12ek_mmc_defconfig index c549baf..1702a32 100644 --- a/configs/at91sam9n12ek_mmc_defconfig +++ b/configs/at91sam9n12ek_mmc_defconfig @@ -7,3 +7,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9N12,SYS_USE_MMC" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9n12ek_nandflash_defconfig b/configs/at91sam9n12ek_nandflash_defconfig index 756db2a..9f87469 100644 --- a/configs/at91sam9n12ek_nandflash_defconfig +++ b/configs/at91sam9n12ek_nandflash_defconfig @@ -8,3 +8,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9N12,SYS_USE_NANDFLASH" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9n12ek_spiflash_defconfig b/configs/at91sam9n12ek_spiflash_defconfig index 0430de9..a7d0581 100644 --- a/configs/at91sam9n12ek_spiflash_defconfig +++ b/configs/at91sam9n12ek_spiflash_defconfig @@ -8,3 +8,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9N12,SYS_USE_SPIFLASH" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9rlek_dataflash_defconfig b/configs/at91sam9rlek_dataflash_defconfig index c555caa..ed2f5d2 100644 --- a/configs/at91sam9rlek_dataflash_defconfig +++ b/configs/at91sam9rlek_dataflash_defconfig @@ -12,3 +12,4 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9rlek_mmc_defconfig b/configs/at91sam9rlek_mmc_defconfig index 5cb5655..760cf92 100644 --- a/configs/at91sam9rlek_mmc_defconfig +++ b/configs/at91sam9rlek_mmc_defconfig @@ -12,3 +12,4 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9rlek_nandflash_defconfig b/configs/at91sam9rlek_nandflash_defconfig index 3e3528e..191a261 100644 --- a/configs/at91sam9rlek_nandflash_defconfig +++ b/configs/at91sam9rlek_nandflash_defconfig @@ -12,3 +12,4 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index c757fc4..38607d0 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -8,3 +8,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_DATAFLASH" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index 82e67f3..8776627 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -8,3 +8,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_MMC" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index b45d8d0..cedc560 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_NANDFLASH" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index f33a2fd..3896300 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_SPIFLASH" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9xeek_dataflash_cs0_defconfig b/configs/at91sam9xeek_dataflash_cs0_defconfig index 585d564..fbdb564 100644 --- a/configs/at91sam9xeek_dataflash_cs0_defconfig +++ b/configs/at91sam9xeek_dataflash_cs0_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE,SYS_USE_DATAFLASH_CS0" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9xeek_dataflash_cs1_defconfig b/configs/at91sam9xeek_dataflash_cs1_defconfig index 1c38777..4f0cc11 100644 --- a/configs/at91sam9xeek_dataflash_cs1_defconfig +++ b/configs/at91sam9xeek_dataflash_cs1_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE,SYS_USE_DATAFLASH_CS1" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/at91sam9xeek_nandflash_defconfig b/configs/at91sam9xeek_nandflash_defconfig index 5e9a080..3dde55c 100644 --- a/configs/at91sam9xeek_nandflash_defconfig +++ b/configs/at91sam9xeek_nandflash_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE,SYS_USE_NANDFLASH" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/atngw100_defconfig b/configs/atngw100_defconfig index 0f5be56..51facf7 100644 --- a/configs/atngw100_defconfig +++ b/configs/atngw100_defconfig @@ -9,3 +9,4 @@ CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/atngw100mkii_defconfig b/configs/atngw100mkii_defconfig index b4d8d1c..b7099f5 100644 --- a/configs/atngw100mkii_defconfig +++ b/configs/atngw100mkii_defconfig @@ -8,3 +8,4 @@ CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/atstk1002_defconfig b/configs/atstk1002_defconfig index bb0406e..78e2256 100644 --- a/configs/atstk1002_defconfig +++ b/configs/atstk1002_defconfig @@ -8,3 +8,4 @@ CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/axs101_defconfig b/configs/axs101_defconfig index 04aec0b..9a6cef3 100644 --- a/configs/axs101_defconfig +++ b/configs/axs101_defconfig @@ -10,3 +10,4 @@ CONFIG_SYS_TEXT_BASE=0x81000000 CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="AXS# " diff --git a/configs/beaver_defconfig b/configs/beaver_defconfig index ad74b85..02e19d2 100644 --- a/configs/beaver_defconfig +++ b/configs/beaver_defconfig @@ -14,3 +14,4 @@ CONFIG_SPI_FLASH=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="Tegra30 (Beaver) # " diff --git a/configs/bf537-minotaur_defconfig b/configs/bf537-minotaur_defconfig index 57e9a24..212f2bb 100644 --- a/configs/bf537-minotaur_defconfig +++ b/configs/bf537-minotaur_defconfig @@ -5,3 +5,4 @@ CONFIG_TARGET_BF537_MINOTAUR=y # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="minotaur> " diff --git a/configs/bf537-srv1_defconfig b/configs/bf537-srv1_defconfig index 51022d8..52abf99 100644 --- a/configs/bf537-srv1_defconfig +++ b/configs/bf537-srv1_defconfig @@ -5,3 +5,4 @@ CONFIG_TARGET_BF537_SRV1=y # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="srv1> " diff --git a/configs/bf561-acvilon_defconfig b/configs/bf561-acvilon_defconfig index 897e44f..1409901 100644 --- a/configs/bf561-acvilon_defconfig +++ b/configs/bf561-acvilon_defconfig @@ -6,3 +6,4 @@ CONFIG_TARGET_BF561_ACVILON=y CONFIG_SPI_FLASH=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y CONFIG_LIB_RAND=y +CONFIG_SYS_PROMPT="Acvilon> " diff --git a/configs/br4_defconfig b/configs/br4_defconfig index b129899..540dbef 100644 --- a/configs/br4_defconfig +++ b/configs/br4_defconfig @@ -6,3 +6,4 @@ CONFIG_TARGET_BR4=y CONFIG_SPI_FLASH=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y CONFIG_LIB_RAND=y +CONFIG_SYS_PROMPT="br4>" diff --git a/configs/cairo_defconfig b/configs/cairo_defconfig index b837de3..756457c 100644 --- a/configs/cairo_defconfig +++ b/configs/cairo_defconfig @@ -7,3 +7,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_NET is not set +CONFIG_SYS_PROMPT="Cairo # " diff --git a/configs/calimain_defconfig b/configs/calimain_defconfig index 35f73e3..4d952cd 100644 --- a/configs/calimain_defconfig +++ b/configs/calimain_defconfig @@ -4,3 +4,4 @@ CONFIG_TARGET_CALIMAIN=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR="\x0b" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="Calimain > " diff --git a/configs/cam_enc_4xx_defconfig b/configs/cam_enc_4xx_defconfig index f7f6f12..a67bf0e 100644 --- a/configs/cam_enc_4xx_defconfig +++ b/configs/cam_enc_4xx_defconfig @@ -7,3 +7,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="cam_enc_4xx> " diff --git a/configs/cardhu_defconfig b/configs/cardhu_defconfig index c0e98a5..5c298d7 100644 --- a/configs/cardhu_defconfig +++ b/configs/cardhu_defconfig @@ -14,3 +14,4 @@ CONFIG_SPI_FLASH=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="Tegra30 (Cardhu) # " diff --git a/configs/cgtqmx6qeval_defconfig b/configs/cgtqmx6qeval_defconfig index 6fd29a0..af322bc 100644 --- a/configs/cgtqmx6qeval_defconfig +++ b/configs/cgtqmx6qeval_defconfig @@ -7,3 +7,4 @@ CONFIG_DM_THERMAL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="CGT-QMX6-Quad U-Boot > " diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index 2aba359..66fc382 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -30,3 +30,4 @@ CONFIG_USB_EHCI_MX6=y CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y +CONFIG_SYS_PROMPT="CM-FX6 # " diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index 9ebd327..4f4bd0b 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -4,3 +4,4 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="CM-T335 # " diff --git a/configs/cm_t3517_defconfig b/configs/cm_t3517_defconfig index 57b44ba..1eb4250 100644 --- a/configs/cm_t3517_defconfig +++ b/configs/cm_t3517_defconfig @@ -5,3 +5,4 @@ CONFIG_TARGET_CM_T3517=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="CM-T3517 # " diff --git a/configs/cm_t35_defconfig b/configs/cm_t35_defconfig index c8dc124..99dd2f4 100644 --- a/configs/cm_t35_defconfig +++ b/configs/cm_t35_defconfig @@ -6,3 +6,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="CM-T3x # " diff --git a/configs/cm_t54_defconfig b/configs/cm_t54_defconfig index af7c880..fc72ffa 100644 --- a/configs/cm_t54_defconfig +++ b/configs/cm_t54_defconfig @@ -6,3 +6,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="CM-T54 # " diff --git a/configs/cobra5272_defconfig b/configs/cobra5272_defconfig index 2ccb80c..77ad34d 100644 --- a/configs/cobra5272_defconfig +++ b/configs/cobra5272_defconfig @@ -3,3 +3,4 @@ CONFIG_TARGET_COBRA5272=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="COBRA > " diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index 4e1369b..0d28b06 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -12,3 +12,4 @@ CONFIG_SPL_DM=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="Colibri T20 # " diff --git a/configs/colibri_t30_defconfig b/configs/colibri_t30_defconfig index 45cf20a..d1ed09d 100644 --- a/configs/colibri_t30_defconfig +++ b/configs/colibri_t30_defconfig @@ -12,3 +12,4 @@ CONFIG_SPL_DM=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="Colibri T30 # " diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index ffb3b4f..74af563 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -6,3 +6,4 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/colibri_vf/imximage.cfg,ENV_I CONFIG_DM=y CONFIG_NAND_VF610_NFC=y CONFIG_SYS_NAND_VF610_NFC_60_ECC_BYTES=y +CONFIG_SYS_PROMPT="Colibri VFxx # " diff --git a/configs/colibri_vf_dtb_defconfig b/configs/colibri_vf_dtb_defconfig index 49f2105..54c3f2d 100644 --- a/configs/colibri_vf_dtb_defconfig +++ b/configs/colibri_vf_dtb_defconfig @@ -9,3 +9,4 @@ CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_NAND_VF610_NFC=y CONFIG_SYS_NAND_VF610_NFC_60_ECC_BYTES=y +CONFIG_SYS_PROMPT="Colibri VFxx # " diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index 13afb08..1fed14e 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,MACH_TYPE=2066,SYS_USE_NANDFLASH" # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/cpu9260_128M_defconfig b/configs/cpu9260_128M_defconfig index f423980..187fced 100644 --- a/configs/cpu9260_128M_defconfig +++ b/configs/cpu9260_128M_defconfig @@ -8,3 +8,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CPU9260,CPU9260_128M" # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="CPU9260=> " diff --git a/configs/cpu9260_defconfig b/configs/cpu9260_defconfig index 88afe9f..4b50505 100644 --- a/configs/cpu9260_defconfig +++ b/configs/cpu9260_defconfig @@ -8,3 +8,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CPU9260" # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="CPU9260=> " diff --git a/configs/cpu9260_nand_128M_defconfig b/configs/cpu9260_nand_128M_defconfig index f59b000..797fb85 100644 --- a/configs/cpu9260_nand_128M_defconfig +++ b/configs/cpu9260_nand_128M_defconfig @@ -8,3 +8,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CPU9260,CPU9260_128M,NANDBOOT" # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="CPU9260=> " diff --git a/configs/cpu9260_nand_defconfig b/configs/cpu9260_nand_defconfig index e914c2b..8d155d0 100644 --- a/configs/cpu9260_nand_defconfig +++ b/configs/cpu9260_nand_defconfig @@ -8,3 +8,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CPU9260,NANDBOOT" # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="CPU9260=> " diff --git a/configs/cpu9G20_128M_defconfig b/configs/cpu9G20_128M_defconfig index d215cc0..650c934 100644 --- a/configs/cpu9G20_128M_defconfig +++ b/configs/cpu9G20_128M_defconfig @@ -8,3 +8,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CPU9G20,CPU9G20_128M" # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="CPU9G20=> " diff --git a/configs/cpu9G20_defconfig b/configs/cpu9G20_defconfig index 51b19f0..997eec5 100644 --- a/configs/cpu9G20_defconfig +++ b/configs/cpu9G20_defconfig @@ -8,3 +8,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CPU9G20" # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="CPU9G20=> " diff --git a/configs/cpu9G20_nand_128M_defconfig b/configs/cpu9G20_nand_128M_defconfig index da4cbdd..6d62732 100644 --- a/configs/cpu9G20_nand_128M_defconfig +++ b/configs/cpu9G20_nand_128M_defconfig @@ -8,3 +8,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CPU9G20,CPU9G20_128M,NANDBOOT" # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="CPU9G20=> " diff --git a/configs/cpu9G20_nand_defconfig b/configs/cpu9G20_nand_defconfig index b9e4b3c..52f916f 100644 --- a/configs/cpu9G20_nand_defconfig +++ b/configs/cpu9G20_nand_defconfig @@ -8,3 +8,4 @@ CONFIG_SYS_EXTRA_OPTIONS="CPU9G20,NANDBOOT" # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="CPU9G20=> " diff --git a/configs/cpuat91_defconfig b/configs/cpuat91_defconfig index cfc62aa..10b8ad2 100644 --- a/configs/cpuat91_defconfig +++ b/configs/cpuat91_defconfig @@ -10,3 +10,4 @@ CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="CPUAT91=> " diff --git a/configs/da830evm_defconfig b/configs/da830evm_defconfig index e0c8e25..d37ede3 100644 --- a/configs/da830evm_defconfig +++ b/configs/da830evm_defconfig @@ -6,3 +6,4 @@ CONFIG_TARGET_DA830EVM=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="U-Boot > " diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index 41395e3..557c0d5 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -7,3 +7,4 @@ CONFIG_SYS_EXTRA_OPTIONS="MAC_ADDR_IN_SPIFLASH" # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="U-Boot > " diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index a1cba1a..79b877f 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -4,3 +4,4 @@ CONFIG_TARGET_DA850EVM=y CONFIG_SYS_EXTRA_OPTIONS="MAC_ADDR_IN_SPIFLASH,USE_NOR,DIRECT_NOR_BOOT" # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="U-Boot > " diff --git a/configs/dalmore_defconfig b/configs/dalmore_defconfig index e7443f8..e7688a6 100644 --- a/configs/dalmore_defconfig +++ b/configs/dalmore_defconfig @@ -14,3 +14,4 @@ CONFIG_SPI_FLASH=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="Tegra114 (Dalmore) # " diff --git a/configs/davinci_dm355evm_defconfig b/configs/davinci_dm355evm_defconfig index f10b643..4513ce4 100644 --- a/configs/davinci_dm355evm_defconfig +++ b/configs/davinci_dm355evm_defconfig @@ -6,3 +6,4 @@ CONFIG_TARGET_DAVINCI_DM355EVM=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="DM355 EVM # " diff --git a/configs/davinci_dm355leopard_defconfig b/configs/davinci_dm355leopard_defconfig index 7b33f6d..7945605 100644 --- a/configs/davinci_dm355leopard_defconfig +++ b/configs/davinci_dm355leopard_defconfig @@ -6,3 +6,4 @@ CONFIG_TARGET_DAVINCI_DM355LEOPARD=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="DM355 LEOPARD # " diff --git a/configs/davinci_dm365evm_defconfig b/configs/davinci_dm365evm_defconfig index f139b58..3550e75 100644 --- a/configs/davinci_dm365evm_defconfig +++ b/configs/davinci_dm365evm_defconfig @@ -6,3 +6,4 @@ CONFIG_TARGET_DAVINCI_DM365EVM=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="DM36x EVM # " diff --git a/configs/davinci_dm6467evm_defconfig b/configs/davinci_dm6467evm_defconfig index 2a5262a..b2021af 100644 --- a/configs/davinci_dm6467evm_defconfig +++ b/configs/davinci_dm6467evm_defconfig @@ -7,3 +7,4 @@ CONFIG_SYS_EXTRA_OPTIONS="REFCLK_FREQ=27000000" # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="DM6467 EVM > " diff --git a/configs/davinci_dvevm_defconfig b/configs/davinci_dvevm_defconfig index aa30d1b..7c6f03e 100644 --- a/configs/davinci_dvevm_defconfig +++ b/configs/davinci_dvevm_defconfig @@ -6,3 +6,4 @@ CONFIG_TARGET_DAVINCI_DVEVM=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot > " diff --git a/configs/davinci_schmoogie_defconfig b/configs/davinci_schmoogie_defconfig index 7c11c8c..2fb4d9f 100644 --- a/configs/davinci_schmoogie_defconfig +++ b/configs/davinci_schmoogie_defconfig @@ -6,3 +6,4 @@ CONFIG_TARGET_DAVINCI_SCHMOOGIE=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot > " diff --git a/configs/davinci_sffsdr_defconfig b/configs/davinci_sffsdr_defconfig index 7aca606..633b4a8 100644 --- a/configs/davinci_sffsdr_defconfig +++ b/configs/davinci_sffsdr_defconfig @@ -6,3 +6,4 @@ CONFIG_TARGET_DAVINCI_SFFSDR=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot > " diff --git a/configs/davinci_sonata_defconfig b/configs/davinci_sonata_defconfig index 6014eee..697ce06 100644 --- a/configs/davinci_sonata_defconfig +++ b/configs/davinci_sonata_defconfig @@ -4,3 +4,4 @@ CONFIG_TARGET_DAVINCI_SONATA=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot > " diff --git a/configs/dbau1000_defconfig b/configs/dbau1000_defconfig index 58da5b7..5dc12d2 100644 --- a/configs/dbau1000_defconfig +++ b/configs/dbau1000_defconfig @@ -10,3 +10,4 @@ CONFIG_SYS_EXTRA_OPTIONS="DBAU1000" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="DbAu1xx0 # " diff --git a/configs/dbau1100_defconfig b/configs/dbau1100_defconfig index 14aeb4c..522b9bc 100644 --- a/configs/dbau1100_defconfig +++ b/configs/dbau1100_defconfig @@ -10,3 +10,4 @@ CONFIG_DBAU1100=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="DbAu1xx0 # " diff --git a/configs/dbau1500_defconfig b/configs/dbau1500_defconfig index 699b968..2fdddc7 100644 --- a/configs/dbau1500_defconfig +++ b/configs/dbau1500_defconfig @@ -10,3 +10,4 @@ CONFIG_DBAU1500=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="DbAu1xx0 # " diff --git a/configs/dbau1550_defconfig b/configs/dbau1550_defconfig index 6b17da7..07be3f1 100644 --- a/configs/dbau1550_defconfig +++ b/configs/dbau1550_defconfig @@ -8,3 +8,4 @@ CONFIG_DBAU1550=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="DbAu1xx0 # " diff --git a/configs/dbau1550_el_defconfig b/configs/dbau1550_el_defconfig index 845bc87..7bd1e0c 100644 --- a/configs/dbau1550_el_defconfig +++ b/configs/dbau1550_el_defconfig @@ -9,3 +9,4 @@ CONFIG_SYS_LITTLE_ENDIAN=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="DbAu1xx0 # " diff --git a/configs/dig297_defconfig b/configs/dig297_defconfig index 483c20e..4c2c982 100644 --- a/configs/dig297_defconfig +++ b/configs/dig297_defconfig @@ -7,3 +7,4 @@ CONFIG_TARGET_DIG297=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="DIG297# " diff --git a/configs/dockstar_defconfig b/configs/dockstar_defconfig index 40f6e0f..e4da466 100644 --- a/configs/dockstar_defconfig +++ b/configs/dockstar_defconfig @@ -4,3 +4,4 @@ CONFIG_TARGET_DOCKSTAR=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="DockStar> " diff --git a/configs/draco_defconfig b/configs/draco_defconfig index 8b177b3..d2fc98d 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -8,3 +8,4 @@ CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="U-Boot# " diff --git a/configs/duovero_defconfig b/configs/duovero_defconfig index 57410d3..d3de28a 100644 --- a/configs/duovero_defconfig +++ b/configs/duovero_defconfig @@ -6,3 +6,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="duovero # " diff --git a/configs/ea20_defconfig b/configs/ea20_defconfig index 388dfec..1d7494f 100644 --- a/configs/ea20_defconfig +++ b/configs/ea20_defconfig @@ -5,3 +5,4 @@ CONFIG_TARGET_EA20=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="ea20 > " diff --git a/configs/eb_cpu5282_defconfig b/configs/eb_cpu5282_defconfig index 1e19d3a..0044de6 100644 --- a/configs/eb_cpu5282_defconfig +++ b/configs/eb_cpu5282_defconfig @@ -3,3 +3,4 @@ CONFIG_TARGET_EB_CPU5282=y CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0xFF000000,SYS_MONITOR_BASE=0xFF000400" # CONFIG_CMD_LOADB is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="\nEB+CPU5282> " diff --git a/configs/eb_cpux9k2_defconfig b/configs/eb_cpux9k2_defconfig index bff6595..6a6f3cd 100644 --- a/configs/eb_cpux9k2_defconfig +++ b/configs/eb_cpux9k2_defconfig @@ -2,3 +2,4 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_EB_CPUX9K2=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/eco5pk_defconfig b/configs/eco5pk_defconfig index c43603b..8b5874d 100644 --- a/configs/eco5pk_defconfig +++ b/configs/eco5pk_defconfig @@ -5,3 +5,4 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="ECO5-PK # " diff --git a/configs/edminiv2_defconfig b/configs/edminiv2_defconfig index 80ff33f..b2a2506 100644 --- a/configs/edminiv2_defconfig +++ b/configs/edminiv2_defconfig @@ -3,3 +3,4 @@ CONFIG_ORION5X=y CONFIG_TARGET_EDMINIV2=y CONFIG_SPL=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="EDMiniV2> " diff --git a/configs/ethernut5_defconfig b/configs/ethernut5_defconfig index d2379ec..d97008a 100644 --- a/configs/ethernut5_defconfig +++ b/configs/ethernut5_defconfig @@ -6,3 +6,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE" # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/flea3_defconfig b/configs/flea3_defconfig index 7ea5da2..c9e4a28 100644 --- a/configs/flea3_defconfig +++ b/configs/flea3_defconfig @@ -1,3 +1,4 @@ CONFIG_ARM=y CONFIG_TARGET_FLEA3=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="flea3 U-Boot > " diff --git a/configs/fx12mm_defconfig b/configs/fx12mm_defconfig index 1013b70..0213681 100644 --- a/configs/fx12mm_defconfig +++ b/configs/fx12mm_defconfig @@ -6,3 +6,4 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x041000 # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="FX12MM:/# " diff --git a/configs/goflexhome_defconfig b/configs/goflexhome_defconfig index d1b9ba1..059ce80 100644 --- a/configs/goflexhome_defconfig +++ b/configs/goflexhome_defconfig @@ -4,3 +4,4 @@ CONFIG_TARGET_GOFLEXHOME=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="GoFlexHome> " diff --git a/configs/grasshopper_defconfig b/configs/grasshopper_defconfig index 2d9c8ad..eefc5f2 100644 --- a/configs/grasshopper_defconfig +++ b/configs/grasshopper_defconfig @@ -6,3 +6,4 @@ CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/gwventana_defconfig b/configs/gwventana_defconfig index 401f77e..d81f941 100644 --- a/configs/gwventana_defconfig +++ b/configs/gwventana_defconfig @@ -8,3 +8,4 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" # CONFIG_CMD_FLASH is not set CONFIG_DM=y CONFIG_DM_SERIAL=y +CONFIG_SYS_PROMPT="Ventana > " diff --git a/configs/h2200_defconfig b/configs/h2200_defconfig index f90a4a6..07b1706 100644 --- a/configs/h2200_defconfig +++ b/configs/h2200_defconfig @@ -17,3 +17,4 @@ CONFIG_TARGET_H2200=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set +CONFIG_SYS_PROMPT="> " diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index d88a082..c9c0618 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -13,3 +13,4 @@ CONFIG_SPL_DM=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="Tegra20 (Harmony) # " diff --git a/configs/ib62x0_defconfig b/configs/ib62x0_defconfig index e418d8f..b3fa890 100644 --- a/configs/ib62x0_defconfig +++ b/configs/ib62x0_defconfig @@ -4,3 +4,4 @@ CONFIG_TARGET_IB62X0=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="ib62x0 => " diff --git a/configs/iconnect_defconfig b/configs/iconnect_defconfig index 49d4fa0..4c34290 100644 --- a/configs/iconnect_defconfig +++ b/configs/iconnect_defconfig @@ -4,3 +4,4 @@ CONFIG_TARGET_ICONNECT=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="iconnect => " diff --git a/configs/ima3-mx53_defconfig b/configs/ima3-mx53_defconfig index ef15127..1f5e3a6 100644 --- a/configs/ima3-mx53_defconfig +++ b/configs/ima3-mx53_defconfig @@ -3,3 +3,4 @@ CONFIG_TARGET_IMA3_MX53=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/esg/ima3-mx53/imximage.cfg" # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="IMA3 MX53 U-Boot > " diff --git a/configs/imx31_litekit_defconfig b/configs/imx31_litekit_defconfig index b197935..f10759b 100644 --- a/configs/imx31_litekit_defconfig +++ b/configs/imx31_litekit_defconfig @@ -1,3 +1,4 @@ CONFIG_ARM=y CONFIG_TARGET_IMX31_LITEKIT=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="uboot> " diff --git a/configs/imx31_phycore_defconfig b/configs/imx31_phycore_defconfig index 161a604..e801ee7 100644 --- a/configs/imx31_phycore_defconfig +++ b/configs/imx31_phycore_defconfig @@ -1,3 +1,4 @@ CONFIG_ARM=y CONFIG_TARGET_IMX31_PHYCORE=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="uboot> " diff --git a/configs/integratorap_cm720t_defconfig b/configs/integratorap_cm720t_defconfig index 369add7..50c6005 100644 --- a/configs/integratorap_cm720t_defconfig +++ b/configs/integratorap_cm720t_defconfig @@ -3,3 +3,4 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM720T=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="Integrator-AP # " diff --git a/configs/integratorap_cm920t_defconfig b/configs/integratorap_cm920t_defconfig index aa27cbd..ab0cdbd 100644 --- a/configs/integratorap_cm920t_defconfig +++ b/configs/integratorap_cm920t_defconfig @@ -3,3 +3,4 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM920T=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="Integrator-AP # " diff --git a/configs/integratorap_cm926ejs_defconfig b/configs/integratorap_cm926ejs_defconfig index 8155b67..317c6d8 100644 --- a/configs/integratorap_cm926ejs_defconfig +++ b/configs/integratorap_cm926ejs_defconfig @@ -3,3 +3,4 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM926EJ_S=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="Integrator-AP # " diff --git a/configs/integratorap_cm946es_defconfig b/configs/integratorap_cm946es_defconfig index b3b5edf..5ce1c00 100644 --- a/configs/integratorap_cm946es_defconfig +++ b/configs/integratorap_cm946es_defconfig @@ -3,3 +3,4 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM946ES=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="Integrator-AP # " diff --git a/configs/integratorcp_cm1136_defconfig b/configs/integratorcp_cm1136_defconfig index 5ab7c27..ddd2ce7 100644 --- a/configs/integratorcp_cm1136_defconfig +++ b/configs/integratorcp_cm1136_defconfig @@ -3,3 +3,4 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM1136=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="Integrator-CP # " diff --git a/configs/integratorcp_cm920t_defconfig b/configs/integratorcp_cm920t_defconfig index d0ed78d..036b32e 100644 --- a/configs/integratorcp_cm920t_defconfig +++ b/configs/integratorcp_cm920t_defconfig @@ -3,3 +3,4 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM920T=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="Integrator-CP # " diff --git a/configs/integratorcp_cm926ejs_defconfig b/configs/integratorcp_cm926ejs_defconfig index 9aa8602..6fc2a84 100644 --- a/configs/integratorcp_cm926ejs_defconfig +++ b/configs/integratorcp_cm926ejs_defconfig @@ -3,3 +3,4 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM926EJ_S=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="Integrator-CP # " diff --git a/configs/integratorcp_cm946es_defconfig b/configs/integratorcp_cm946es_defconfig index ef9d7d6..e077a5e 100644 --- a/configs/integratorcp_cm946es_defconfig +++ b/configs/integratorcp_cm946es_defconfig @@ -3,3 +3,4 @@ CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM946ES=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="Integrator-CP # " diff --git a/configs/ipam390_defconfig b/configs/ipam390_defconfig index c053b38..c416340 100644 --- a/configs/ipam390_defconfig +++ b/configs/ipam390_defconfig @@ -5,3 +5,4 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot > " diff --git a/configs/jetson-tk1_defconfig b/configs/jetson-tk1_defconfig index 7085469..14e1f05 100644 --- a/configs/jetson-tk1_defconfig +++ b/configs/jetson-tk1_defconfig @@ -14,3 +14,4 @@ CONFIG_SPI_FLASH=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="Tegra124 (Jetson TK1) # " diff --git a/configs/jornada_defconfig b/configs/jornada_defconfig index 735c75f..65cbc2a 100644 --- a/configs/jornada_defconfig +++ b/configs/jornada_defconfig @@ -6,3 +6,4 @@ CONFIG_TARGET_JORNADA=y # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set +CONFIG_SYS_PROMPT="HP Jornada# " diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index f422886..c4cbadd 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -6,3 +6,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="K2E EVM # " diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index 297183f..a604939 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -6,3 +6,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="K2HK EVM # " diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 7aa538d..a687e0c 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -6,3 +6,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="K2L EVM # " diff --git a/configs/kwb_defconfig b/configs/kwb_defconfig index 5bca811..928c4bf 100644 --- a/configs/kwb_defconfig +++ b/configs/kwb_defconfig @@ -14,3 +14,4 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="U-Boot (BuR V2.0)# " diff --git a/configs/kzm9g_defconfig b/configs/kzm9g_defconfig index 3df79d4..0669bbc 100644 --- a/configs/kzm9g_defconfig +++ b/configs/kzm9g_defconfig @@ -2,3 +2,4 @@ CONFIG_ARM=y CONFIG_RMOBILE=y CONFIG_TARGET_KZM9G=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="KZM-A9-GT# " diff --git a/configs/mcx_defconfig b/configs/mcx_defconfig index 1d3e978..1f38640 100644 --- a/configs/mcx_defconfig +++ b/configs/mcx_defconfig @@ -7,3 +7,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="mcx # " diff --git a/configs/medcom-wide_defconfig b/configs/medcom-wide_defconfig index bb33542..c0ba9d1 100644 --- a/configs/medcom-wide_defconfig +++ b/configs/medcom-wide_defconfig @@ -13,3 +13,4 @@ CONFIG_SPL_DM=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="Tegra20 (Medcom-Wide) # " diff --git a/configs/microblaze-generic_defconfig b/configs/microblaze-generic_defconfig index 8355c67..5de1bcd 100644 --- a/configs/microblaze-generic_defconfig +++ b/configs/microblaze-generic_defconfig @@ -6,3 +6,4 @@ CONFIG_SPL=y CONFIG_OF_CONTROL=y CONFIG_SPL_DISABLE_OF_CONTROL=y CONFIG_OF_EMBED=y +CONFIG_SYS_PROMPT="U-Boot-mONStR> " diff --git a/configs/ml507_defconfig b/configs/ml507_defconfig index 3f66c86..44b7c31 100644 --- a/configs/ml507_defconfig +++ b/configs/ml507_defconfig @@ -6,3 +6,4 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x041000 # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="ml507:/# " diff --git a/configs/mt_ventoux_defconfig b/configs/mt_ventoux_defconfig index 0a6b7d6..d5d26cf 100644 --- a/configs/mt_ventoux_defconfig +++ b/configs/mt_ventoux_defconfig @@ -5,3 +5,4 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="mt_ventoux => " diff --git a/configs/mx51_efikamx_defconfig b/configs/mx51_efikamx_defconfig index 9c0deb1..a88c223 100644 --- a/configs/mx51_efikamx_defconfig +++ b/configs/mx51_efikamx_defconfig @@ -4,3 +4,4 @@ CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_MX51_EFIKAMX,IMX_CONFIG=board/gene # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="Efika> " diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index 47e5911..257c305 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -4,3 +4,4 @@ CONFIG_TARGET_NAS220=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="nas220> " diff --git a/configs/nhk8815_defconfig b/configs/nhk8815_defconfig index f9fac6f..218d92a 100644 --- a/configs/nhk8815_defconfig +++ b/configs/nhk8815_defconfig @@ -4,3 +4,4 @@ CONFIG_NOMADIK_NHK8815=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="Nomadik> " diff --git a/configs/nokia_rx51_defconfig b/configs/nokia_rx51_defconfig index c40dadf..3dd24e0 100644 --- a/configs/nokia_rx51_defconfig +++ b/configs/nokia_rx51_defconfig @@ -10,3 +10,4 @@ CONFIG_AUTOBOOT_KEYED=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="Nokia RX-51 # " diff --git a/configs/nyan-big_defconfig b/configs/nyan-big_defconfig index 79b74a7..590596e 100644 --- a/configs/nyan-big_defconfig +++ b/configs/nyan-big_defconfig @@ -20,3 +20,4 @@ CONFIG_VIDEO_TEGRA124=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="Tegra124 (Nyan-big) # " diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index 2b960d5..ad9bb61 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -7,3 +7,4 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5422-odroidxu3" # CONFIG_CMD_SETEXPR is not set CONFIG_USB=y CONFIG_DM_USB=y +CONFIG_SYS_PROMPT="ODROID-XU3 # " diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index 3104f88..0a4f63b 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -21,3 +21,4 @@ CONFIG_DM_REGULATOR_MAX77686=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_ERRNO_STR=y +CONFIG_SYS_PROMPT="Odroid # " diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 65b6f6a..de8fbd9 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -7,3 +7,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="OMAP3_EVM # " diff --git a/configs/omap3_evm_quick_mmc_defconfig b/configs/omap3_evm_quick_mmc_defconfig index 527b465..7d15b16 100644 --- a/configs/omap3_evm_quick_mmc_defconfig +++ b/configs/omap3_evm_quick_mmc_defconfig @@ -23,3 +23,4 @@ CONFIG_SPL=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set +CONFIG_SYS_PROMPT="OMAP3_EVM # " diff --git a/configs/omap3_evm_quick_nand_defconfig b/configs/omap3_evm_quick_nand_defconfig index e3278b5..cd30134 100644 --- a/configs/omap3_evm_quick_nand_defconfig +++ b/configs/omap3_evm_quick_nand_defconfig @@ -23,3 +23,4 @@ CONFIG_SPL=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set +CONFIG_SYS_PROMPT="OMAP3_EVM # " diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index b11d2e4..5d0ac9e 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -5,3 +5,4 @@ CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_SYS_PROMPT="OMAP Logic # " diff --git a/configs/omap3_mvblx_defconfig b/configs/omap3_mvblx_defconfig index 415b02e..fb12a70 100644 --- a/configs/omap3_mvblx_defconfig +++ b/configs/omap3_mvblx_defconfig @@ -6,3 +6,4 @@ CONFIG_AUTOBOOT_STOP_STR="S" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="mvblx # " diff --git a/configs/omap3_overo_defconfig b/configs/omap3_overo_defconfig index 8d55590..5d03485 100644 --- a/configs/omap3_overo_defconfig +++ b/configs/omap3_overo_defconfig @@ -8,3 +8,4 @@ CONFIG_SPL=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="Overo # " diff --git a/configs/omap3_pandora_defconfig b/configs/omap3_pandora_defconfig index f18a520..4fb7899 100644 --- a/configs/omap3_pandora_defconfig +++ b/configs/omap3_pandora_defconfig @@ -8,3 +8,4 @@ CONFIG_TARGET_OMAP3_PANDORA=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="Pandora # " diff --git a/configs/omap3_sdp3430_defconfig b/configs/omap3_sdp3430_defconfig index df9e709..2e46091 100644 --- a/configs/omap3_sdp3430_defconfig +++ b/configs/omap3_sdp3430_defconfig @@ -4,3 +4,4 @@ CONFIG_TARGET_OMAP3_SDP3430=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="OMAP34XX SDP # " diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index a49be95..4cff178 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -6,3 +6,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="U-Boot > " diff --git a/configs/origen_defconfig b/configs/origen_defconfig index 6961978..d69d497 100644 --- a/configs/origen_defconfig +++ b/configs/origen_defconfig @@ -13,3 +13,4 @@ CONFIG_OF_CONTROL=y CONFIG_SPL_DISABLE_OF_CONTROL=y CONFIG_USB=y CONFIG_DM_USB=y +CONFIG_SYS_PROMPT="ORIGEN # " diff --git a/configs/palmld_defconfig b/configs/palmld_defconfig index 8bf6c53..354071a 100644 --- a/configs/palmld_defconfig +++ b/configs/palmld_defconfig @@ -4,3 +4,4 @@ CONFIG_TARGET_PALMLD=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="$ " diff --git a/configs/palmtc_defconfig b/configs/palmtc_defconfig index 4042466..de617e1 100644 --- a/configs/palmtc_defconfig +++ b/configs/palmtc_defconfig @@ -3,3 +3,4 @@ CONFIG_TARGET_PALMTC=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="$ " diff --git a/configs/paz00_defconfig b/configs/paz00_defconfig index 60fb2d6..5cba318 100644 --- a/configs/paz00_defconfig +++ b/configs/paz00_defconfig @@ -13,3 +13,4 @@ CONFIG_SPL_DM=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="Tegra20 (Paz00) MOD # " diff --git a/configs/pb1000_defconfig b/configs/pb1000_defconfig index 72756a7..c6221a3 100644 --- a/configs/pb1000_defconfig +++ b/configs/pb1000_defconfig @@ -10,3 +10,4 @@ CONFIG_SYS_EXTRA_OPTIONS="PB1000" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="Pb1x00 # " diff --git a/configs/pcm030_defconfig b/configs/pcm030_defconfig index df9309e..6305092 100644 --- a/configs/pcm030_defconfig +++ b/configs/pcm030_defconfig @@ -2,3 +2,4 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_PCM030=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="uboot> " diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index c17fc73..fa58d3e 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -12,3 +12,4 @@ CONFIG_CROS_EC_SPI=y CONFIG_CROS_EC_KEYB=y CONFIG_USB=y CONFIG_DM_USB=y +CONFIG_SYS_PROMPT="Peach-Pi # " diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index 8f21722..4dd58c9 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -12,3 +12,4 @@ CONFIG_CROS_EC_SPI=y CONFIG_CROS_EC_KEYB=y CONFIG_USB=y CONFIG_DM_USB=y +CONFIG_SYS_PROMPT="Peach-Pit # " diff --git a/configs/pepper_defconfig b/configs/pepper_defconfig index eb1b6cf..787c5f9 100644 --- a/configs/pepper_defconfig +++ b/configs/pepper_defconfig @@ -4,3 +4,4 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="pepper# " diff --git a/configs/platinum_picon_defconfig b/configs/platinum_picon_defconfig index 3484c46..64da7c4 100644 --- a/configs/platinum_picon_defconfig +++ b/configs/platinum_picon_defconfig @@ -5,3 +5,4 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6DL" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="picon > " diff --git a/configs/platinum_titanium_defconfig b/configs/platinum_titanium_defconfig index 6a2cacf..67957c3 100644 --- a/configs/platinum_titanium_defconfig +++ b/configs/platinum_titanium_defconfig @@ -5,3 +5,4 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="titanium > " diff --git a/configs/plutux_defconfig b/configs/plutux_defconfig index 8d96e33..07fa7f9 100644 --- a/configs/plutux_defconfig +++ b/configs/plutux_defconfig @@ -13,3 +13,4 @@ CONFIG_SPL_DM=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="Tegra20 (Plutux) # " diff --git a/configs/pm9261_defconfig b/configs/pm9261_defconfig index 2c842b4..0a7716e 100644 --- a/configs/pm9261_defconfig +++ b/configs/pm9261_defconfig @@ -8,3 +8,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9261" # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="pm9261> " diff --git a/configs/pm9263_defconfig b/configs/pm9263_defconfig index a065ce0..45e060b 100644 --- a/configs/pm9263_defconfig +++ b/configs/pm9263_defconfig @@ -8,3 +8,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263" # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="u-boot-pm9263> " diff --git a/configs/pm9g45_defconfig b/configs/pm9g45_defconfig index bbaeae8..3f34b3c 100644 --- a/configs/pm9g45_defconfig +++ b/configs/pm9g45_defconfig @@ -6,3 +6,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G45" # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/pogo_e02_defconfig b/configs/pogo_e02_defconfig index f21237f..50a058e 100644 --- a/configs/pogo_e02_defconfig +++ b/configs/pogo_e02_defconfig @@ -4,3 +4,4 @@ CONFIG_TARGET_POGO_E02=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="PogoE02> " diff --git a/configs/pr1_defconfig b/configs/pr1_defconfig index b06babc..583f132 100644 --- a/configs/pr1_defconfig +++ b/configs/pr1_defconfig @@ -6,3 +6,4 @@ CONFIG_TARGET_PR1=y CONFIG_SPI_FLASH=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y CONFIG_LIB_RAND=y +CONFIG_SYS_PROMPT="pr1>" diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 0bb42ff..41c2849 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -8,3 +8,4 @@ CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="U-Boot# " diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index 2b126ac..7a3ac70 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -8,3 +8,4 @@ CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="U-Boot# " diff --git a/configs/rpi_2_defconfig b/configs/rpi_2_defconfig index 139189d..4b92045 100644 --- a/configs/rpi_2_defconfig +++ b/configs/rpi_2_defconfig @@ -6,3 +6,4 @@ CONFIG_TARGET_RPI_2=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_PHYS_TO_BUS=y +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/rpi_defconfig b/configs/rpi_defconfig index db8da68..195ff99 100644 --- a/configs/rpi_defconfig +++ b/configs/rpi_defconfig @@ -6,3 +6,4 @@ CONFIG_TARGET_RPI=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set CONFIG_PHYS_TO_BUS=y +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/rut_defconfig b/configs/rut_defconfig index da9dfe3..774957c 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -8,3 +8,4 @@ CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="U-Boot# " diff --git a/configs/s5p_goni_defconfig b/configs/s5p_goni_defconfig index 7e03b9d..5c873f7 100644 --- a/configs/s5p_goni_defconfig +++ b/configs/s5p_goni_defconfig @@ -10,3 +10,4 @@ CONFIG_DEFAULT_DEVICE_TREE="s5pc1xx-goni" # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set +CONFIG_SYS_PROMPT="Goni # " diff --git a/configs/s5pc210_universal_defconfig b/configs/s5pc210_universal_defconfig index 21a4708..1a49978 100644 --- a/configs/s5pc210_universal_defconfig +++ b/configs/s5pc210_universal_defconfig @@ -12,3 +12,4 @@ CONFIG_OF_CONTROL=y CONFIG_SPL_DISABLE_OF_CONTROL=y CONFIG_USB=y CONFIG_DM_USB=y +CONFIG_SYS_PROMPT="Universal # " diff --git a/configs/scb9328_defconfig b/configs/scb9328_defconfig index 3104586..c9c5034 100644 --- a/configs/scb9328_defconfig +++ b/configs/scb9328_defconfig @@ -4,3 +4,4 @@ CONFIG_TARGET_SCB9328=y # CONFIG_CMD_LOADS is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="scb9328> " diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index 942f17e..54afbdb 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -13,3 +13,4 @@ CONFIG_SPL_DM=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="Tegra20 (SeaBoard) # " diff --git a/configs/secomx6quq7_defconfig b/configs/secomx6quq7_defconfig index 0095ceb..c97172d 100644 --- a/configs/secomx6quq7_defconfig +++ b/configs/secomx6quq7_defconfig @@ -7,3 +7,4 @@ CONFIG_SECOMX6_2GB=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_MMC" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_SYS_PROMPT="SECO MX6Q uQ7 U-Boot > " diff --git a/configs/smdk2410_defconfig b/configs/smdk2410_defconfig index 74bb9e3..51f348e 100644 --- a/configs/smdk2410_defconfig +++ b/configs/smdk2410_defconfig @@ -1,3 +1,4 @@ CONFIG_ARM=y CONFIG_TARGET_SMDK2410=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="SMDK2410 # " diff --git a/configs/smdk5250_defconfig b/configs/smdk5250_defconfig index 8412d6f..b8df6fb 100644 --- a/configs/smdk5250_defconfig +++ b/configs/smdk5250_defconfig @@ -14,3 +14,4 @@ CONFIG_SOUND_MAX98095=y CONFIG_SOUND_WM8994=y CONFIG_USB=y CONFIG_DM_USB=y +CONFIG_SYS_PROMPT="SMDK5250 # " diff --git a/configs/smdk5420_defconfig b/configs/smdk5420_defconfig index a96b368..d1d75e2 100644 --- a/configs/smdk5420_defconfig +++ b/configs/smdk5420_defconfig @@ -8,3 +8,4 @@ CONFIG_SPL=y CONFIG_SPI_FLASH=y CONFIG_USB=y CONFIG_DM_USB=y +CONFIG_SYS_PROMPT="SMDK5420 # " diff --git a/configs/smdkc100_defconfig b/configs/smdkc100_defconfig index 6c8359e..676781e 100644 --- a/configs/smdkc100_defconfig +++ b/configs/smdkc100_defconfig @@ -5,3 +5,4 @@ CONFIG_DEFAULT_DEVICE_TREE="s5pc1xx-smdkc100" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="SMDKC100 # " diff --git a/configs/smdkv310_defconfig b/configs/smdkv310_defconfig index 39dd5be..7833f62 100644 --- a/configs/smdkv310_defconfig +++ b/configs/smdkv310_defconfig @@ -10,3 +10,4 @@ CONFIG_SPL=y # CONFIG_CMD_MISC is not set CONFIG_USB=y CONFIG_DM_USB=y +CONFIG_SYS_PROMPT="SMDKV310 # " diff --git a/configs/snapper9260_defconfig b/configs/snapper9260_defconfig index d319a4f..31cc5a0 100644 --- a/configs/snapper9260_defconfig +++ b/configs/snapper9260_defconfig @@ -10,3 +10,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="Snapper> " diff --git a/configs/snow_defconfig b/configs/snow_defconfig index 93fbcae..54efe1a 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -18,3 +18,4 @@ CONFIG_SOUND_MAX98095=y CONFIG_SOUND_WM8994=y CONFIG_USB=y CONFIG_DM_USB=y +CONFIG_SYS_PROMPT="snow # " diff --git a/configs/snowball_defconfig b/configs/snowball_defconfig index 31aa583..e73bc48 100644 --- a/configs/snowball_defconfig +++ b/configs/snowball_defconfig @@ -10,3 +10,4 @@ CONFIG_TARGET_SNOWBALL=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="U8500 $ " diff --git a/configs/stamp9g20_defconfig b/configs/stamp9g20_defconfig index 78c4775..40d6232 100644 --- a/configs/stamp9g20_defconfig +++ b/configs/stamp9g20_defconfig @@ -8,3 +8,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20" # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/stm32f429-discovery_defconfig b/configs/stm32f429-discovery_defconfig index 188adc5..0c54d5b 100644 --- a/configs/stm32f429-discovery_defconfig +++ b/configs/stm32f429-discovery_defconfig @@ -1,3 +1,4 @@ CONFIG_ARM=y CONFIG_TARGET_STM32F429_DISCOVERY=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot > " diff --git a/configs/stv0991_defconfig b/configs/stv0991_defconfig index 3bdb1fc..f71206a 100644 --- a/configs/stv0991_defconfig +++ b/configs/stv0991_defconfig @@ -12,3 +12,4 @@ CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y CONFIG_OF_CONTROL=y +CONFIG_SYS_PROMPT="STV0991> " diff --git a/configs/stxgp3_defconfig b/configs/stxgp3_defconfig index 86afe88..816092d 100644 --- a/configs/stxgp3_defconfig +++ b/configs/stxgp3_defconfig @@ -2,3 +2,4 @@ CONFIG_PPC=y CONFIG_MPC85xx=y CONFIG_TARGET_STXGP3=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="GPPP=> " diff --git a/configs/stxssa_defconfig b/configs/stxssa_defconfig index c072417..ec812c1 100644 --- a/configs/stxssa_defconfig +++ b/configs/stxssa_defconfig @@ -2,3 +2,4 @@ CONFIG_PPC=y CONFIG_MPC85xx=y CONFIG_TARGET_STXSSA=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="SSA=> " diff --git a/configs/tao3530_defconfig b/configs/tao3530_defconfig index ae4b49b..779f400 100644 --- a/configs/tao3530_defconfig +++ b/configs/tao3530_defconfig @@ -7,3 +7,4 @@ CONFIG_SPL=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="TAO-3530 # " diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 3787493..838d0ed 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -11,3 +11,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,MACH_TYPE=2067,BOARD_TAURUS" # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/tb100_defconfig b/configs/tb100_defconfig index cc8f527..acd1f3a 100644 --- a/configs/tb100_defconfig +++ b/configs/tb100_defconfig @@ -14,3 +14,4 @@ CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y CONFIG_DM_SERIAL=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="[tb100]:~# " diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index f0e5106..745d32e 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -5,3 +5,4 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg, # CONFIG_CMD_FLASH is not set CONFIG_DM=y CONFIG_DM_THERMAL=y +CONFIG_SYS_PROMPT="Matrix U-Boot> " diff --git a/configs/tec-ng_defconfig b/configs/tec-ng_defconfig index e731205..4e8f5c6 100644 --- a/configs/tec-ng_defconfig +++ b/configs/tec-ng_defconfig @@ -14,3 +14,4 @@ CONFIG_SPI_FLASH=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="Tegra30 (TEC-NG) # " diff --git a/configs/tec_defconfig b/configs/tec_defconfig index 3f815fe..84fa0be 100644 --- a/configs/tec_defconfig +++ b/configs/tec_defconfig @@ -13,3 +13,4 @@ CONFIG_SPL_DM=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="Tegra20 (TEC) # " diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index 8192b28..e2a6b0c 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -8,3 +8,4 @@ CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="U-Boot# " diff --git a/configs/ti814x_evm_defconfig b/configs/ti814x_evm_defconfig index ade4ea2..f7d1e11 100644 --- a/configs/ti814x_evm_defconfig +++ b/configs/ti814x_evm_defconfig @@ -4,3 +4,4 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot# " diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index 67e5e60..1fd2719 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -4,3 +4,4 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="u-boot/ti816x# " diff --git a/configs/titanium_defconfig b/configs/titanium_defconfig index e892d3e..d286fd6 100644 --- a/configs/titanium_defconfig +++ b/configs/titanium_defconfig @@ -4,3 +4,4 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/barco/titanium/imximage.cfg" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="Titanium > " diff --git a/configs/trats2_defconfig b/configs/trats2_defconfig index f3cbe6d..f0dd2b9 100644 --- a/configs/trats2_defconfig +++ b/configs/trats2_defconfig @@ -13,3 +13,4 @@ CONFIG_OF_CONTROL=y CONFIG_SPL_DISABLE_OF_CONTROL=y CONFIG_USB=y CONFIG_DM_USB=y +CONFIG_SYS_PROMPT="Trats2 # " diff --git a/configs/trats_defconfig b/configs/trats_defconfig index 6553edb..6412f31 100644 --- a/configs/trats_defconfig +++ b/configs/trats_defconfig @@ -12,3 +12,4 @@ CONFIG_OF_CONTROL=y CONFIG_SPL_DISABLE_OF_CONTROL=y CONFIG_USB=y CONFIG_DM_USB=y +CONFIG_SYS_PROMPT="Trats # " diff --git a/configs/tricorder_defconfig b/configs/tricorder_defconfig index cbd4dd3..1da9e94 100644 --- a/configs/tricorder_defconfig +++ b/configs/tricorder_defconfig @@ -9,3 +9,4 @@ CONFIG_SPL=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="OMAP3 Tricorder # " diff --git a/configs/trimslice_defconfig b/configs/trimslice_defconfig index 9d2fb2d..a1bcb11 100644 --- a/configs/trimslice_defconfig +++ b/configs/trimslice_defconfig @@ -14,3 +14,4 @@ CONFIG_SPI_FLASH=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="Tegra20 (TrimSlice) # " diff --git a/configs/tseries_mmc_defconfig b/configs/tseries_mmc_defconfig index 9ed13b6..a083ee0 100644 --- a/configs/tseries_mmc_defconfig +++ b/configs/tseries_mmc_defconfig @@ -14,3 +14,4 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,EMMC_BOOT" # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="U-Boot (BuR V2.0)# " diff --git a/configs/tseries_nand_defconfig b/configs/tseries_nand_defconfig index 0b577edc..aa66a0e 100644 --- a/configs/tseries_nand_defconfig +++ b/configs/tseries_nand_defconfig @@ -14,3 +14,4 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND" # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="U-Boot (BuR V2.0)# " diff --git a/configs/tseries_spi_defconfig b/configs/tseries_spi_defconfig index 1602a43..1cb90d6 100644 --- a/configs/tseries_spi_defconfig +++ b/configs/tseries_spi_defconfig @@ -15,3 +15,4 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,SPI_BOOT,EMMC_BOOT" # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="U-Boot (BuR V2.0)# " diff --git a/configs/tt01_defconfig b/configs/tt01_defconfig index d23904d..08f9f7b 100644 --- a/configs/tt01_defconfig +++ b/configs/tt01_defconfig @@ -1,3 +1,4 @@ CONFIG_ARM=y CONFIG_TARGET_TT01=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="TT01> " diff --git a/configs/twister_defconfig b/configs/twister_defconfig index 7381665..c3edd34 100644 --- a/configs/twister_defconfig +++ b/configs/twister_defconfig @@ -5,3 +5,4 @@ CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="twister => " diff --git a/configs/u8500_href_defconfig b/configs/u8500_href_defconfig index 5a82ca8..0aebc78 100644 --- a/configs/u8500_href_defconfig +++ b/configs/u8500_href_defconfig @@ -10,3 +10,4 @@ CONFIG_TARGET_U8500_HREF=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="U8500 $ " diff --git a/configs/usb_a9263_dataflash_defconfig b/configs/usb_a9263_dataflash_defconfig index 5f3974e..8cf3c4c 100644 --- a/configs/usb_a9263_dataflash_defconfig +++ b/configs/usb_a9263_dataflash_defconfig @@ -10,3 +10,4 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/v5fx30teval_defconfig b/configs/v5fx30teval_defconfig index 8173f3e..e77dce9 100644 --- a/configs/v5fx30teval_defconfig +++ b/configs/v5fx30teval_defconfig @@ -6,3 +6,4 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x041000 # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="v5fx30t:/# " diff --git a/configs/vct_platinum_defconfig b/configs/vct_platinum_defconfig index 81cf280..9a46dcb 100644 --- a/configs/vct_platinum_defconfig +++ b/configs/vct_platinum_defconfig @@ -3,3 +3,4 @@ CONFIG_TARGET_VCT=y CONFIG_VCT_PLATINUM=y # CONFIG_CMD_SETEXPR is not set CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="$ " diff --git a/configs/vct_platinum_onenand_defconfig b/configs/vct_platinum_onenand_defconfig index 8d91aa5..8c8d69a 100644 --- a/configs/vct_platinum_onenand_defconfig +++ b/configs/vct_platinum_onenand_defconfig @@ -6,3 +6,4 @@ CONFIG_VCT_ONENAND=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="$ " diff --git a/configs/vct_platinum_onenand_small_defconfig b/configs/vct_platinum_onenand_small_defconfig index 6eaec0c..4e6cbc7 100644 --- a/configs/vct_platinum_onenand_small_defconfig +++ b/configs/vct_platinum_onenand_small_defconfig @@ -17,3 +17,4 @@ CONFIG_VCT_SMALL_IMAGE=y # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="$ " diff --git a/configs/vct_platinum_small_defconfig b/configs/vct_platinum_small_defconfig index 088ab7e..f896822 100644 --- a/configs/vct_platinum_small_defconfig +++ b/configs/vct_platinum_small_defconfig @@ -14,3 +14,4 @@ CONFIG_VCT_SMALL_IMAGE=y # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="$ " diff --git a/configs/vct_platinumavc_defconfig b/configs/vct_platinumavc_defconfig index faeb6a2..6e867b2 100644 --- a/configs/vct_platinumavc_defconfig +++ b/configs/vct_platinumavc_defconfig @@ -5,3 +5,4 @@ CONFIG_VCT_PLATINUMAVC=y # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="VCT# " diff --git a/configs/vct_platinumavc_onenand_defconfig b/configs/vct_platinumavc_onenand_defconfig index 900a626..55f8c91 100644 --- a/configs/vct_platinumavc_onenand_defconfig +++ b/configs/vct_platinumavc_onenand_defconfig @@ -8,3 +8,4 @@ CONFIG_VCT_ONENAND=y # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="$ " diff --git a/configs/vct_platinumavc_onenand_small_defconfig b/configs/vct_platinumavc_onenand_small_defconfig index e9928a0..343ab8f 100644 --- a/configs/vct_platinumavc_onenand_small_defconfig +++ b/configs/vct_platinumavc_onenand_small_defconfig @@ -17,3 +17,4 @@ CONFIG_VCT_SMALL_IMAGE=y # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="$ " diff --git a/configs/vct_platinumavc_small_defconfig b/configs/vct_platinumavc_small_defconfig index 719bd64..b4acc4a 100644 --- a/configs/vct_platinumavc_small_defconfig +++ b/configs/vct_platinumavc_small_defconfig @@ -14,3 +14,4 @@ CONFIG_VCT_SMALL_IMAGE=y # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="$ " diff --git a/configs/vct_premium_defconfig b/configs/vct_premium_defconfig index 7b04e7c..d71dd53 100644 --- a/configs/vct_premium_defconfig +++ b/configs/vct_premium_defconfig @@ -3,3 +3,4 @@ CONFIG_TARGET_VCT=y CONFIG_VCT_PREMIUM=y # CONFIG_CMD_SETEXPR is not set CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="$ " diff --git a/configs/vct_premium_onenand_defconfig b/configs/vct_premium_onenand_defconfig index 769f8bd..6923db8 100644 --- a/configs/vct_premium_onenand_defconfig +++ b/configs/vct_premium_onenand_defconfig @@ -6,3 +6,4 @@ CONFIG_VCT_ONENAND=y # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="$ " diff --git a/configs/vct_premium_onenand_small_defconfig b/configs/vct_premium_onenand_small_defconfig index c062a01..04a2855 100644 --- a/configs/vct_premium_onenand_small_defconfig +++ b/configs/vct_premium_onenand_small_defconfig @@ -17,3 +17,4 @@ CONFIG_VCT_SMALL_IMAGE=y # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="$ " diff --git a/configs/vct_premium_small_defconfig b/configs/vct_premium_small_defconfig index 4a5cdb0..265a6a5 100644 --- a/configs/vct_premium_small_defconfig +++ b/configs/vct_premium_small_defconfig @@ -14,3 +14,4 @@ CONFIG_VCT_SMALL_IMAGE=y # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="$ " diff --git a/configs/venice2_defconfig b/configs/venice2_defconfig index 9ccd739..0bab477 100644 --- a/configs/venice2_defconfig +++ b/configs/venice2_defconfig @@ -14,3 +14,4 @@ CONFIG_SPI_FLASH=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="Tegra124 (Venice2) # " diff --git a/configs/ventana_defconfig b/configs/ventana_defconfig index f728585..d347317 100644 --- a/configs/ventana_defconfig +++ b/configs/ventana_defconfig @@ -13,3 +13,4 @@ CONFIG_SPL_DM=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="Tegra20 (Ventana) # " diff --git a/configs/vexpress_aemv8a_juno_defconfig b/configs/vexpress_aemv8a_juno_defconfig index 0baaa91..3390f0e 100644 --- a/configs/vexpress_aemv8a_juno_defconfig +++ b/configs/vexpress_aemv8a_juno_defconfig @@ -15,3 +15,4 @@ CONFIG_DEFAULT_DEVICE_TREE="vexpress64" # CONFIG_CMD_MISC is not set CONFIG_DM=y CONFIG_DM_SERIAL=y +CONFIG_SYS_PROMPT="VExpress64# " diff --git a/configs/vexpress_aemv8a_semi_defconfig b/configs/vexpress_aemv8a_semi_defconfig index bf5576a..9890e64 100644 --- a/configs/vexpress_aemv8a_semi_defconfig +++ b/configs/vexpress_aemv8a_semi_defconfig @@ -16,3 +16,4 @@ CONFIG_DEFAULT_DEVICE_TREE="vexpress64" # CONFIG_CMD_MISC is not set CONFIG_DM=y CONFIG_DM_SERIAL=y +CONFIG_SYS_PROMPT="VExpress64# " diff --git a/configs/vision2_defconfig b/configs/vision2_defconfig index afe3b3c..962dc5b 100644 --- a/configs/vision2_defconfig +++ b/configs/vision2_defconfig @@ -4,3 +4,4 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/ttcontrol/vision2/imximage_hynix.cfg" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y +CONFIG_SYS_PROMPT="Vision II U-boot > " diff --git a/configs/vl_ma2sc_defconfig b/configs/vl_ma2sc_defconfig index 7a66783..c908c6e 100644 --- a/configs/vl_ma2sc_defconfig +++ b/configs/vl_ma2sc_defconfig @@ -6,3 +6,4 @@ CONFIG_TARGET_VL_MA2SC=y # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="U-Boot> " diff --git a/configs/vpac270_nor_128_defconfig b/configs/vpac270_nor_128_defconfig index bbc6e6a..1d11653 100644 --- a/configs/vpac270_nor_128_defconfig +++ b/configs/vpac270_nor_128_defconfig @@ -3,3 +3,4 @@ CONFIG_TARGET_VPAC270=y CONFIG_SYS_EXTRA_OPTIONS="NOR,RAM_128M" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="$ " diff --git a/configs/vpac270_nor_256_defconfig b/configs/vpac270_nor_256_defconfig index 3f1ae1e..bcd1006 100644 --- a/configs/vpac270_nor_256_defconfig +++ b/configs/vpac270_nor_256_defconfig @@ -3,3 +3,4 @@ CONFIG_TARGET_VPAC270=y CONFIG_SYS_EXTRA_OPTIONS="NOR,RAM_256M" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="$ " diff --git a/configs/vpac270_ond_256_defconfig b/configs/vpac270_ond_256_defconfig index 7500b7c..d989819 100644 --- a/configs/vpac270_ond_256_defconfig +++ b/configs/vpac270_ond_256_defconfig @@ -5,3 +5,4 @@ CONFIG_SYS_EXTRA_OPTIONS="ONENAND,RAM_256M" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="$ " diff --git a/configs/whistler_defconfig b/configs/whistler_defconfig index 43d725b..e3ce9fd 100644 --- a/configs/whistler_defconfig +++ b/configs/whistler_defconfig @@ -13,3 +13,4 @@ CONFIG_SPL_DM=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_SYS_PROMPT="Tegra20 (Whistler) # " diff --git a/configs/wireless_space_defconfig b/configs/wireless_space_defconfig index 5551d27..63013f6 100644 --- a/configs/wireless_space_defconfig +++ b/configs/wireless_space_defconfig @@ -4,3 +4,4 @@ CONFIG_TARGET_WIRELESS_SPACE=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +ONFIG_SYS_PROMPT="ws> " diff --git a/configs/woodburn_defconfig b/configs/woodburn_defconfig index 8dcf3e1..3b463c1 100644 --- a/configs/woodburn_defconfig +++ b/configs/woodburn_defconfig @@ -1,3 +1,4 @@ CONFIG_ARM=y CONFIG_TARGET_WOODBURN=y # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="woodburn U-Boot > " diff --git a/configs/woodburn_sd_defconfig b/configs/woodburn_sd_defconfig index 96a00b3..59f2ad0 100644 --- a/configs/woodburn_sd_defconfig +++ b/configs/woodburn_sd_defconfig @@ -3,3 +3,4 @@ CONFIG_TARGET_WOODBURN_SD=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/woodburn/imximage.cfg" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="woodburn U-Boot > " diff --git a/configs/x600_defconfig b/configs/x600_defconfig index fdd4d3b..6be6cc3 100644 --- a/configs/x600_defconfig +++ b/configs/x600_defconfig @@ -7,3 +7,4 @@ CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_SETEXPR is not set CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y +CONFIG_SYS_PROMPT="X600> " diff --git a/configs/xilinx-ppc405-generic_defconfig b/configs/xilinx-ppc405-generic_defconfig index 9dae755..98030d0 100644 --- a/configs/xilinx-ppc405-generic_defconfig +++ b/configs/xilinx-ppc405-generic_defconfig @@ -6,3 +6,4 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x041000 # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="xlx-ppc405:/# " diff --git a/configs/xilinx-ppc440-generic_defconfig b/configs/xilinx-ppc440-generic_defconfig index 398362b..de69773 100644 --- a/configs/xilinx-ppc440-generic_defconfig +++ b/configs/xilinx-ppc440-generic_defconfig @@ -6,3 +6,4 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x041000 # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="board:/# " diff --git a/configs/xilinx_zynqmp_ep_defconfig b/configs/xilinx_zynqmp_ep_defconfig index fda44ea..9c4d872 100644 --- a/configs/xilinx_zynqmp_ep_defconfig +++ b/configs/xilinx_zynqmp_ep_defconfig @@ -16,3 +16,5 @@ CONFIG_DEFAULT_DEVICE_TREE="zynqmp-ep" CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_SYS_TEXT_BASE=0x8000000 +CONFIG_SYS_PROMPT="ZynqMP> " + diff --git a/configs/zipitz2_defconfig b/configs/zipitz2_defconfig index 3591849..2977ccc 100644 --- a/configs/zipitz2_defconfig +++ b/configs/zipitz2_defconfig @@ -4,3 +4,4 @@ CONFIG_TARGET_ZIPITZ2=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_SYS_PROMPT="$ " diff --git a/configs/zmx25_defconfig b/configs/zmx25_defconfig index a34e827..c759cdf 100644 --- a/configs/zmx25_defconfig +++ b/configs/zmx25_defconfig @@ -5,3 +5,4 @@ CONFIG_AUTOBOOT_PROMPT="boot in %d s\n" CONFIG_AUTOBOOT_DELAY_STR="delaygs" CONFIG_AUTOBOOT_STOP_STR="stopgs" # CONFIG_CMD_SETEXPR is not set +CONFIG_SYS_PROMPT="zmx25> " diff --git a/include/configs/M5208EVBE.h b/include/configs/M5208EVBE.h index a2468c3..5e15dd9 100644 --- a/include/configs/M5208EVBE.h +++ b/include/configs/M5208EVBE.h @@ -88,7 +88,6 @@ ""
#define CONFIG_PRAM 512 /* 512 KB */ -#define CONFIG_SYS_PROMPT "-> " #define CONFIG_SYS_LONGHELP /* undef to save memory */
#ifdef CONFIG_CMD_KGDB diff --git a/include/configs/M52277EVB.h b/include/configs/M52277EVB.h index 2e86016..d1cadc0 100644 --- a/include/configs/M52277EVB.h +++ b/include/configs/M52277EVB.h @@ -150,7 +150,6 @@
#define CONFIG_PRAM 2048 /* 2048 KB */
#if defined(CONFIG_CMD_KGDB) diff --git a/include/configs/M5235EVB.h b/include/configs/M5235EVB.h index ae11e7d..1472672 100644 --- a/include/configs/M5235EVB.h +++ b/include/configs/M5235EVB.h @@ -106,7 +106,6 @@ ""
#if defined(CONFIG_KGDB) diff --git a/include/configs/M5272C3.h b/include/configs/M5272C3.h index d888c3e..006f2d8 100644 --- a/include/configs/M5272C3.h +++ b/include/configs/M5272C3.h @@ -105,7 +105,6 @@ "save\0" \ ""
#if defined(CONFIG_CMD_KGDB) diff --git a/include/configs/M5275EVB.h b/include/configs/M5275EVB.h index fa9b973..116e8e2 100644 --- a/include/configs/M5275EVB.h +++ b/include/configs/M5275EVB.h @@ -98,7 +98,6 @@ #define CONFIG_SYS_I2C_PINMUX_CLR (0xFFF0) #define CONFIG_SYS_I2C_PINMUX_SET (0x000F)
#if (CONFIG_CMD_KGDB) diff --git a/include/configs/M5282EVB.h b/include/configs/M5282EVB.h index 860abe7..eff0aa6 100644 --- a/include/configs/M5282EVB.h +++ b/include/configs/M5282EVB.h @@ -94,7 +94,6 @@ "save\0" \ ""
#if defined(CONFIG_CMD_KGDB) diff --git a/include/configs/M53017EVB.h b/include/configs/M53017EVB.h index 817b142..a48ae6b 100644 --- a/include/configs/M53017EVB.h +++ b/include/configs/M53017EVB.h @@ -108,7 +108,6 @@ ""
#ifdef CONFIG_CMD_KGDB diff --git a/include/configs/M5329EVB.h b/include/configs/M5329EVB.h index 4724a9c..e806b7a 100644 --- a/include/configs/M5329EVB.h +++ b/include/configs/M5329EVB.h @@ -102,7 +102,6 @@ ""
#ifdef CONFIG_CMD_KGDB diff --git a/include/configs/M5373EVB.h b/include/configs/M5373EVB.h index 32afa44..1df98f7 100644 --- a/include/configs/M5373EVB.h +++ b/include/configs/M5373EVB.h @@ -102,7 +102,6 @@ ""
#ifdef CONFIG_CMD_KGDB diff --git a/include/configs/M54418TWR.h b/include/configs/M54418TWR.h index 1f65918..db0ddcd 100644 --- a/include/configs/M54418TWR.h +++ b/include/configs/M54418TWR.h @@ -216,7 +216,6 @@ #define CONFIG_SYS_HUSH_PARSER 1 #define CONFIG_SYS_PROMPT_HUSH_PS2 "> "
#if defined(CONFIG_CMD_KGDB) diff --git a/include/configs/M54451EVB.h b/include/configs/M54451EVB.h index 2c08512..de747a4 100644 --- a/include/configs/M54451EVB.h +++ b/include/configs/M54451EVB.h @@ -160,7 +160,6 @@
#if defined(CONFIG_CMD_KGDB) diff --git a/include/configs/M54455EVB.h b/include/configs/M54455EVB.h index e82ba32..06da5f0 100644 --- a/include/configs/M54455EVB.h +++ b/include/configs/M54455EVB.h @@ -219,7 +219,6 @@
#if defined(CONFIG_CMD_KGDB) diff --git a/include/configs/M5475EVB.h b/include/configs/M5475EVB.h index 3c1bb90..e30b645 100644 --- a/include/configs/M5475EVB.h +++ b/include/configs/M5475EVB.h @@ -146,7 +146,6 @@ ""
#ifdef CONFIG_CMD_KGDB diff --git a/include/configs/M5485EVB.h b/include/configs/M5485EVB.h index 7e1b364..051c940 100644 --- a/include/configs/M5485EVB.h +++ b/include/configs/M5485EVB.h @@ -134,7 +134,6 @@ ""
#ifdef CONFIG_CMD_KGDB diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index 32cb007..834786d 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -544,12 +544,6 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ #define CONFIG_LOADADDR 800000 /* default location for tftp and bootm */
-#ifdef CONFIG_MPC8349ITX -#define CONFIG_SYS_PROMPT "MPC8349E-mITX> " /* Monitor Command Prompt */ -#else -#define CONFIG_SYS_PROMPT "MPC8349E-mITX-GP> " /* Monitor Command Prompt */ -#endif - #if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #else diff --git a/include/configs/PATI.h b/include/configs/PATI.h index dfc4fc0..5d0e422 100644 --- a/include/configs/PATI.h +++ b/include/configs/PATI.h @@ -71,7 +71,6 @@ #define CONFIG_PREBOOT
#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "pati=> " /* Monitor Command Prompt */ #if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #else diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index 0fa03cf..21a918a 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -871,7 +871,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_CMDLINE_EDITING /* Command-line editing */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ #define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ -#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ #ifdef CONFIG_CMD_KGDB #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #else diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index bde71fb..242c239 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -873,7 +873,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_CMDLINE_EDITING /* Command-line editing */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ #define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ -#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ #ifdef CONFIG_CMD_KGDB #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #else diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index bdedef5..76611b0 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -550,7 +550,6 @@ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_CMDLINE_EDITING /* Command-line editing */ #define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ -#define CONFIG_SYS_PROMPT "B$ " /* Monitor Command Prompt */ #if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #else diff --git a/include/configs/VCMA9.h b/include/configs/VCMA9.h index 60c2948..5b2e092 100644 --- a/include/configs/VCMA9.h +++ b/include/configs/VCMA9.h @@ -140,7 +140,6 @@
/* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "VCMA9 # " #define CONFIG_SYS_CBSIZE 256 /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) diff --git a/include/configs/ac14xx.h b/include/configs/ac14xx.h index 8a5d1e6..f05d9ec 100644 --- a/include/configs/ac14xx.h +++ b/include/configs/ac14xx.h @@ -421,7 +421,6 @@ */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ -#define CONFIG_SYS_PROMPT "ac14xx> " /* Monitor Command Prompt */
#ifdef CONFIG_CMD_KGDB # define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/adp-ag101.h b/include/configs/adp-ag101.h index 141fc99..0f256d8 100644 --- a/include/configs/adp-ag101.h +++ b/include/configs/adp-ag101.h @@ -117,7 +117,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "NDS32 # " /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */
/* Print Buffer Size */ diff --git a/include/configs/adp-ag101p.h b/include/configs/adp-ag101p.h index 4296c6b..94fcdbd 100644 --- a/include/configs/adp-ag101p.h +++ b/include/configs/adp-ag101p.h @@ -117,7 +117,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "NDS32 # " /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */
/* Print Buffer Size */ diff --git a/include/configs/adp-ag102.h b/include/configs/adp-ag102.h index 0c7573a..6f05d87 100644 --- a/include/configs/adp-ag102.h +++ b/include/configs/adp-ag102.h @@ -180,7 +180,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "NDS32 # " /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */
/* Print Buffer Size */ diff --git a/include/configs/am3517_crane.h b/include/configs/am3517_crane.h index 6a0240b..18a214f 100644 --- a/include/configs/am3517_crane.h +++ b/include/configs/am3517_crane.h @@ -207,11 +207,8 @@ /* * Miscellaneous configurable options */ -#define V_PROMPT "AM3517_CRANE # " - #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT V_PROMPT #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index e9808a7..fc75278 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -218,11 +218,8 @@ /* * Miscellaneous configurable options */ -#define V_PROMPT "AM3517_EVM # " - #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT V_PROMPT #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/amcore.h b/include/configs/amcore.h index 45fd265..bbab8b2 100644 --- a/include/configs/amcore.h +++ b/include/configs/amcore.h @@ -26,7 +26,6 @@ #define CONFIG_CMD_TIMER #define CONFIG_CMD_DIAG
-#define CONFIG_SYS_PROMPT "amcore $ " /* undef to save memory */ #undef CONFIG_SYS_LONGHELP
diff --git a/include/configs/apalis_t30.h b/include/configs/apalis_t30.h index aba9ba6..ed8ff52 100644 --- a/include/configs/apalis_t30.h +++ b/include/configs/apalis_t30.h @@ -12,7 +12,6 @@ #include "tegra30-common.h"
/* High-level configuration options */ -#define V_PROMPT "Apalis T30 # " #define CONFIG_TEGRA_BOARD_STRING "Toradex Apalis T30"
/* Board-specific serial config */ diff --git a/include/configs/apf27.h b/include/configs/apf27.h index a0a26bb..1f1b013 100644 --- a/include/configs/apf27.h +++ b/include/configs/apf27.h @@ -139,7 +139,6 @@ * U-Boot general configurations */ #define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_PROMPT "BIOS> " /* prompt string */ #define CONFIG_SYS_CBSIZE 2048 /* console I/O buffer */ #define CONFIG_SYS_PBSIZE \ (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) diff --git a/include/configs/arcangel4.h b/include/configs/arcangel4.h index 6636e0e..a342d7e 100644 --- a/include/configs/arcangel4.h +++ b/include/configs/arcangel4.h @@ -67,7 +67,6 @@ * Console configuration */ #define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_PROMPT "arcangel4# " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/arndale.h b/include/configs/arndale.h index 3ad4a9b..e590fa2 100644 --- a/include/configs/arndale.h +++ b/include/configs/arndale.h @@ -33,7 +33,6 @@ #define CONFIG_EXYNOS_SPL
/* Miscellaneous configurable options */ -#define CONFIG_SYS_PROMPT "ARNDALE # " #define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0"
#define CONFIG_NR_DRAM_BANKS 8 diff --git a/include/configs/astro_mcf5373l.h b/include/configs/astro_mcf5373l.h index c6e1f56..1c3a1c9 100644 --- a/include/configs/astro_mcf5373l.h +++ b/include/configs/astro_mcf5373l.h @@ -207,8 +207,6 @@ #define CONFIG_BOOTARGS " console=ttyS2,115200 rootfstype=romfs"\ " loaderversion=$loaderversion"
-#define CONFIG_SYS_PROMPT "URMEL > " - /* default RAM address for user programs */ #define CONFIG_SYS_LOAD_ADDR 0x20000
diff --git a/include/configs/at91-sama5_common.h b/include/configs/at91-sama5_common.h index c2621ff..2bded45 100644 --- a/include/configs/at91-sama5_common.h +++ b/include/configs/at91-sama5_common.h @@ -66,7 +66,6 @@
#define CONFIG_BAUDRATE 115200
-#define CONFIG_SYS_PROMPT "U-Boot> " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/at91rm9200ek.h b/include/configs/at91rm9200ek.h index 6f1f65f..7e026ef 100644 --- a/include/configs/at91rm9200ek.h +++ b/include/configs/at91rm9200ek.h @@ -194,7 +194,6 @@ #define CONFIG_SYS_LONGHELP #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT "U-Boot> " #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ /* Print Buffer Size */ diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index e98cf0c..459b8f9 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -254,7 +254,6 @@ "root=/dev/mmcblk0p2 rw rootfstype=ext4 rootwait" #endif
-#define CONFIG_SYS_PROMPT "U-Boot> " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 42461d2..9c595f2 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -201,7 +201,6 @@ "root=/dev/mtdblock7 rw rootfstype=jffs2" #endif
-#define CONFIG_SYS_PROMPT "U-Boot> " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 731c7f1..3eb0154 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -330,7 +330,6 @@ "root=/dev/mtdblock7 rw rootfstype=jffs2" #endif
-#define CONFIG_SYS_PROMPT "U-Boot> " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 09d8bec..4d90209 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -181,7 +181,6 @@
-#define CONFIG_SYS_PROMPT "U-Boot> " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index a19d4d9..ea0a94b 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -221,7 +221,6 @@
#endif
-#define CONFIG_SYS_PROMPT "U-Boot> " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) \ diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index e709f9c..f7a174e 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -184,7 +184,6 @@ "root=/dev/mmcblk0p2 rw rootwait" #endif
-#define CONFIG_SYS_PROMPT "U-Boot> " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index b9a7754..9f76786 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -223,7 +223,6 @@
-#define CONFIG_SYS_PROMPT "U-Boot> " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) \ diff --git a/include/configs/atngw100.h b/include/configs/atngw100.h index 1cab0a9..c436fef 100644 --- a/include/configs/atngw100.h +++ b/include/configs/atngw100.h @@ -135,7 +135,6 @@ #define CONFIG_SYS_BOOTPARAMS_LEN (16 * 1024)
/* Other configuration settings that shouldn't have to change all that often */ -#define CONFIG_SYS_PROMPT "U-Boot> " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) diff --git a/include/configs/atngw100mkii.h b/include/configs/atngw100mkii.h index 486d9ee..3935811 100644 --- a/include/configs/atngw100mkii.h +++ b/include/configs/atngw100mkii.h @@ -156,7 +156,6 @@ #define CONFIG_SYS_BOOTPARAMS_LEN (16 * 1024)
/* Other configuration settings that shouldn't have to change all that often */ -#define CONFIG_SYS_PROMPT "U-Boot> " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) diff --git a/include/configs/atstk1002.h b/include/configs/atstk1002.h index 1cd99e9..8cd7c35 100644 --- a/include/configs/atstk1002.h +++ b/include/configs/atstk1002.h @@ -151,7 +151,6 @@ #define CONFIG_SYS_BOOTPARAMS_LEN (16 * 1024)
/* Other configuration settings that shouldn't have to change all that often */ -#define CONFIG_SYS_PROMPT "U-Boot> " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) diff --git a/include/configs/axs101.h b/include/configs/axs101.h index 25116e5..7cb8853 100644 --- a/include/configs/axs101.h +++ b/include/configs/axs101.h @@ -155,7 +155,6 @@ * Console configuration */ #define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_PROMPT "AXS# " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/balloon3.h b/include/configs/balloon3.h index 12c5a6c..124a766 100644 --- a/include/configs/balloon3.h +++ b/include/configs/balloon3.h @@ -64,6 +64,7 @@ #define CONFIG_SYS_HUSH_PARSER 1
#define CONFIG_SYS_LONGHELP +#undef CONFIG_SYS_PROMPT #ifdef CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_PROMPT "$ " #else diff --git a/include/configs/beaver.h b/include/configs/beaver.h index c403729..348d9ef 100644 --- a/include/configs/beaver.h +++ b/include/configs/beaver.h @@ -25,7 +25,6 @@ #define CONFIG_TEGRA_VDD_CORE_TPS62366A_SET1
/* High-level configuration options */ -#define V_PROMPT "Tegra30 (Beaver) # " #define CONFIG_TEGRA_BOARD_STRING "NVIDIA Beaver"
/* Board-specific serial config */ diff --git a/include/configs/bf537-minotaur.h b/include/configs/bf537-minotaur.h index 7e52d17..6674d28 100644 --- a/include/configs/bf537-minotaur.h +++ b/include/configs/bf537-minotaur.h @@ -159,7 +159,6 @@
#define CONFIG_BOOTCOMMAND "run ramboot" #define CONFIG_BOOTARGS "root=/dev/mtdblock0 rw" -#define CONFIG_SYS_PROMPT "minotaur> "
#define BOOT_ENV_SETTINGS \ "update=tftpboot $(loadaddr) u-boot.ldr;" \ diff --git a/include/configs/bf537-srv1.h b/include/configs/bf537-srv1.h index d8a0cc6..15d912e 100644 --- a/include/configs/bf537-srv1.h +++ b/include/configs/bf537-srv1.h @@ -158,7 +158,6 @@
#define CONFIG_BOOTCOMMAND "run flashboot" #define CONFIG_BOOTARGS "root=/dev/mtdblock0 rw" -#define CONFIG_SYS_PROMPT "srv1> "
#define BOOT_ENV_SETTINGS \ "update=tftpboot $(loadaddr) u-boot.ldr;" \ diff --git a/include/configs/bf561-acvilon.h b/include/configs/bf561-acvilon.h index da28396..b3c6d29 100644 --- a/include/configs/bf561-acvilon.h +++ b/include/configs/bf561-acvilon.h @@ -153,7 +153,6 @@ */ #define CONFIG_UART_CONSOLE 0 #define CONFIG_BAUDRATE 57600 -#define CONFIG_SYS_PROMPT "Acvilon> "
/* * Pull in common ADI header for remaining command/environment setup diff --git a/include/configs/br4.h b/include/configs/br4.h index cbef809..959f9a9 100644 --- a/include/configs/br4.h +++ b/include/configs/br4.h @@ -127,7 +127,6 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_RTC_BFIN #define CONFIG_UART_CONSOLE 0 -#define CONFIG_SYS_PROMPT "br4>" #define CONFIG_BOOTCOMMAND "run nandboot" #define CONFIG_BOOTDELAY 2 #define CONFIG_LOADADDR 0x2000000 diff --git a/include/configs/bur_am335x_common.h b/include/configs/bur_am335x_common.h index 1521415..838ef1f 100644 --- a/include/configs/bur_am335x_common.h +++ b/include/configs/bur_am335x_common.h @@ -129,7 +129,6 @@ */ #define CONFIG_SYS_MALLOC_LEN (5120 << 10) #define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT "U-Boot (BuR V2.0)# " #define CONFIG_SYS_CONSOLE_INFO_QUIET #define CONFIG_ENV_OVERWRITE /* Overwrite ethaddr / serial# */ #define CONFIG_SYS_CONSOLE_IS_IN_ENV diff --git a/include/configs/calimain.h b/include/configs/calimain.h index 7d8bb47..c8b15fb 100644 --- a/include/configs/calimain.h +++ b/include/configs/calimain.h @@ -194,7 +194,6 @@ * U-Boot general configuration */ #define CONFIG_BOOTFILE "uImage" /* Boot file name */ -#define CONFIG_SYS_PROMPT "Calimain > " /* Command Prompt */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ diff --git a/include/configs/cam_enc_4xx.h b/include/configs/cam_enc_4xx.h index 21e3a0c..918bd43 100644 --- a/include/configs/cam_enc_4xx.h +++ b/include/configs/cam_enc_4xx.h @@ -124,7 +124,6 @@
/* U-Boot general configuration */ #define CONFIG_BOOTFILE "uImage" /* Boot file name */ -#define CONFIG_SYS_PROMPT "cam_enc_4xx> " /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE /* Print buffer size */ \ (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) diff --git a/include/configs/cardhu.h b/include/configs/cardhu.h index 96dfe07..a62680b 100644 --- a/include/configs/cardhu.h +++ b/include/configs/cardhu.h @@ -25,7 +25,6 @@ #define CONFIG_TEGRA_VDD_CORE_TPS62361B_SET3
/* High-level configuration options */ -#define V_PROMPT "Tegra30 (Cardhu) # " #define CONFIG_TEGRA_BOARD_STRING "NVIDIA Cardhu"
#define BOARD_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index bbd9f38..ddf6b5f 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -45,7 +45,6 @@ #define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200}
/* Shell */ -#define CONFIG_SYS_PROMPT "CM-FX6 # " #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16)
diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index 767ef3a..adf05b1 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -27,9 +27,6 @@ #undef CONFIG_MAX_RAM_BANK_SIZE #define CONFIG_MAX_RAM_BANK_SIZE (512 << 20) /* 512MB */
-#undef CONFIG_SYS_PROMPT -#define CONFIG_SYS_PROMPT "CM-T335 # " - #define CONFIG_OMAP_COMMON
#define MACH_TYPE_CM_T335 4586 /* Until the next sync */ diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index 41df106..a4590b3 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -222,7 +222,6 @@ #define CONFIG_SYS_AUTOLOAD "no" #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "CM-T3x # " #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/cm_t3517.h b/include/configs/cm_t3517.h index a8d0b97..b162762 100644 --- a/include/configs/cm_t3517.h +++ b/include/configs/cm_t3517.h @@ -227,7 +227,6 @@ #define CONFIG_SYS_AUTOLOAD "no" #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "CM-T3517 # " #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/cm_t54.h b/include/configs/cm_t54.h index 2a8b730..95a5a60 100644 --- a/include/configs/cm_t54.h +++ b/include/configs/cm_t54.h @@ -105,14 +105,12 @@ * Miscellaneous configurable options */ #undef CONFIG_SYS_AUTOLOAD -#undef CONFIG_SYS_PROMPT #undef CONFIG_EXTRA_ENV_SETTINGS #undef CONFIG_BOOTCOMMAND #undef CONFIG_BOOTDELAY
#define CONFIG_BOOTDELAY 3 #define CONFIG_SYS_AUTOLOAD "no" -#define CONFIG_SYS_PROMPT "CM-T54 # "
#define CONFIG_EXTRA_ENV_SETTINGS \ DEFAULT_LINUX_BOOT_ENV \ diff --git a/include/configs/cobra5272.h b/include/configs/cobra5272.h index 8a6106d..8e70d8c 100644 --- a/include/configs/cobra5272.h +++ b/include/configs/cobra5272.h @@ -178,8 +178,6 @@ considered during boot */
#endif
-#define CONFIG_SYS_PROMPT "COBRA > " /* Layout of u-boot prompt*/ - #define CONFIG_SYS_LOAD_ADDR 0x20000 /*Defines default RAM address from which user programs will be started */
diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h index e3f0ab0..a1b64c6 100644 --- a/include/configs/colibri_pxa270.h +++ b/include/configs/colibri_pxa270.h @@ -81,6 +81,7 @@ #define CONFIG_SYS_HUSH_PARSER 1
#undef CONFIG_SYS_LONGHELP /* Saves 10 KB */ +#undef CONFIG_SYS_PROMPT #ifdef CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_PROMPT "$ " #else diff --git a/include/configs/colibri_t20.h b/include/configs/colibri_t20.h index 8228e42..078c913 100644 --- a/include/configs/colibri_t20.h +++ b/include/configs/colibri_t20.h @@ -10,7 +10,6 @@ #include "tegra20-common.h"
/* High-level configuration options */ -#define V_PROMPT "Colibri T20 # " #define CONFIG_TEGRA_BOARD_STRING "Toradex Colibri T20"
/* Board-specific serial config */ diff --git a/include/configs/colibri_t30.h b/include/configs/colibri_t30.h index 4655668..40bccd2 100644 --- a/include/configs/colibri_t30.h +++ b/include/configs/colibri_t30.h @@ -12,7 +12,6 @@ #include "tegra30-common.h"
/* High-level configuration options */ -#define V_PROMPT "Colibri T30 # " #define CONFIG_TEGRA_BOARD_STRING "Toradex Colibri T30"
/* Board-specific serial config */ diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index ab8d293..f0da913 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -177,7 +177,6 @@ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " -#define CONFIG_SYS_PROMPT "Colibri VFxx # " #undef CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE \ diff --git a/include/configs/corvus.h b/include/configs/corvus.h index 3cfae21..2d2f3c1 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -133,7 +133,6 @@
-#define CONFIG_SYS_PROMPT "U-Boot> " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/cpu9260.h b/include/configs/cpu9260.h index d3c6f75..82f4fe7 100644 --- a/include/configs/cpu9260.h +++ b/include/configs/cpu9260.h @@ -464,11 +464,6 @@
-#if defined(CONFIG_CPU9G20) -#define CONFIG_SYS_PROMPT "CPU9G20=> " -#elif defined(CONFIG_CPU9260) -#define CONFIG_SYS_PROMPT "CPU9260=> " -#endif #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE \ diff --git a/include/configs/cpuat91.h b/include/configs/cpuat91.h index f990cf7..29cd842 100644 --- a/include/configs/cpuat91.h +++ b/include/configs/cpuat91.h @@ -173,7 +173,6 @@
-#define CONFIG_SYS_PROMPT "CPUAT91=> " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 32 #define CONFIG_SYS_PBSIZE \ diff --git a/include/configs/da830evm.h b/include/configs/da830evm.h index 729b6e7..5826a58 100644 --- a/include/configs/da830evm.h +++ b/include/configs/da830evm.h @@ -143,7 +143,6 @@ #undef CONFIG_MISC_INIT_R #undef CONFIG_BOOTDELAY #define CONFIG_BOOTFILE "uImage" /* Boot file name */ -#define CONFIG_SYS_PROMPT "U-Boot > " /* Command Prompt */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 3da9da4..1cd11c0 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -262,7 +262,6 @@ #define CONFIG_MISC_INIT_R #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOOTFILE "uImage" /* Boot file name */ -#define CONFIG_SYS_PROMPT "U-Boot > " /* Command Prompt */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ diff --git a/include/configs/dalmore.h b/include/configs/dalmore.h index 89b6f23..24e368a 100644 --- a/include/configs/dalmore.h +++ b/include/configs/dalmore.h @@ -22,7 +22,6 @@ #include "tegra114-common.h"
/* High-level configuration options */ -#define V_PROMPT "Tegra114 (Dalmore) # " #define CONFIG_TEGRA_BOARD_STRING "NVIDIA Dalmore"
/* Board-specific serial config */ diff --git a/include/configs/davinci_dm355evm.h b/include/configs/davinci_dm355evm.h index 847d788..7a9ce64 100644 --- a/include/configs/davinci_dm355evm.h +++ b/include/configs/davinci_dm355evm.h @@ -110,7 +110,6 @@
/* U-Boot general configuration */ #define CONFIG_BOOTFILE "uImage" /* Boot file name */ -#define CONFIG_SYS_PROMPT "DM355 EVM # " /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE /* Print buffer size */ \ (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) diff --git a/include/configs/davinci_dm355leopard.h b/include/configs/davinci_dm355leopard.h index d4b994a..e3ff943 100644 --- a/include/configs/davinci_dm355leopard.h +++ b/include/configs/davinci_dm355leopard.h @@ -78,7 +78,6 @@
/* U-Boot general configuration */ #define CONFIG_BOOTFILE "uImage" /* Boot file name */ -#define CONFIG_SYS_PROMPT "DM355 LEOPARD # " #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE /* Print buffer size */ \ (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) diff --git a/include/configs/davinci_dm365evm.h b/include/configs/davinci_dm365evm.h index 8b42c50..573c1b0 100644 --- a/include/configs/davinci_dm365evm.h +++ b/include/configs/davinci_dm365evm.h @@ -143,7 +143,6 @@
/* U-Boot general configuration */ #define CONFIG_BOOTFILE "uImage" /* Boot file name */ -#define CONFIG_SYS_PROMPT "DM36x EVM # " /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE /* Print buffer size */ \ (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) diff --git a/include/configs/davinci_dm6467evm.h b/include/configs/davinci_dm6467evm.h index 8571cbd..6346422 100644 --- a/include/configs/davinci_dm6467evm.h +++ b/include/configs/davinci_dm6467evm.h @@ -94,7 +94,6 @@ extern unsigned int davinci_arm_clk_get(void); /* U-Boot general configuration */ #define CONFIG_BOOTDELAY 3 #define CONFIG_BOOTFILE "uImage" /* Boot file name */ -#define CONFIG_SYS_PROMPT "DM6467 EVM > " /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE \ (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) diff --git a/include/configs/davinci_dvevm.h b/include/configs/davinci_dvevm.h index 6108736..6f73339 100644 --- a/include/configs/davinci_dvevm.h +++ b/include/configs/davinci_dvevm.h @@ -143,7 +143,6 @@ #define CONFIG_MISC_INIT_R #undef CONFIG_BOOTDELAY #define CONFIG_BOOTFILE "uImage" /* Boot file name */ -#define CONFIG_SYS_PROMPT "U-Boot > " /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print buffer sz */ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ diff --git a/include/configs/davinci_schmoogie.h b/include/configs/davinci_schmoogie.h index db636e4..bc5e1ca 100644 --- a/include/configs/davinci_schmoogie.h +++ b/include/configs/davinci_schmoogie.h @@ -87,7 +87,6 @@ #define CONFIG_MISC_INIT_R #undef CONFIG_BOOTDELAY #define CONFIG_BOOTFILE "uImage" /* Boot file name */ -#define CONFIG_SYS_PROMPT "U-Boot > " /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print buffer sz */ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ diff --git a/include/configs/davinci_sffsdr.h b/include/configs/davinci_sffsdr.h index 9ecf6ce..e719388 100644 --- a/include/configs/davinci_sffsdr.h +++ b/include/configs/davinci_sffsdr.h @@ -74,7 +74,6 @@ #define CONFIG_MISC_INIT_R #define CONFIG_BOOTDELAY 5 /* Autoboot after 5 seconds. */ #define CONFIG_BOOTFILE "uImage" /* Boot file name */ -#define CONFIG_SYS_PROMPT "U-Boot > " /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE \ (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) /* Print buffer size */ diff --git a/include/configs/davinci_sonata.h b/include/configs/davinci_sonata.h index 410cf68..b85c988 100644 --- a/include/configs/davinci_sonata.h +++ b/include/configs/davinci_sonata.h @@ -133,7 +133,6 @@ #define CONFIG_MISC_INIT_R #undef CONFIG_BOOTDELAY #define CONFIG_BOOTFILE "uImage" /* Boot file name */ -#define CONFIG_SYS_PROMPT "U-Boot > " /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print buffer sz */ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ diff --git a/include/configs/dbau1x00.h b/include/configs/dbau1x00.h index 0abab78..46e3a6c 100644 --- a/include/configs/dbau1x00.h +++ b/include/configs/dbau1x00.h @@ -98,8 +98,6 @@ */ #define CONFIG_SYS_LONGHELP /* undef to save memory */
-#define CONFIG_SYS_PROMPT "DbAu1xx0 # " /* Monitor Command Prompt */ - #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ #define CONFIG_SYS_MAXARGS 16 /* max number of command args*/ diff --git a/include/configs/dig297.h b/include/configs/dig297.h index f6d7ec4..fa24af7 100644 --- a/include/configs/dig297.h +++ b/include/configs/dig297.h @@ -208,7 +208,6 @@ */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "DIG297# " #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/dockstar.h b/include/configs/dockstar.h index b27b202..a62f4e3 100644 --- a/include/configs/dockstar.h +++ b/include/configs/dockstar.h @@ -43,9 +43,6 @@ */ #include "mv-common.h"
-#undef CONFIG_SYS_PROMPT /* previously defined in mv-common.h */ -#define CONFIG_SYS_PROMPT "DockStar> " /* Command Prompt */ - /* * Environment variables configurations */ diff --git a/include/configs/duovero.h b/include/configs/duovero.h index 6e53da5..28d12ad 100644 --- a/include/configs/duovero.h +++ b/include/configs/duovero.h @@ -27,9 +27,6 @@ #define CONFIG_SYS_AUTOMATIC_SDRAM_DETECTION #define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS
-#undef CONFIG_SYS_PROMPT -#define CONFIG_SYS_PROMPT "duovero # " - /* USB UHH support options */ #define CONFIG_CMD_USB #define CONFIG_USB_HOST diff --git a/include/configs/ea20.h b/include/configs/ea20.h index b9f28a3..9a70aae 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -122,7 +122,6 @@ * U-Boot general configuration */ #define CONFIG_BOOTFILE "uImage" /* Boot file name */ -#define CONFIG_SYS_PROMPT "ea20 > " /* Command Prompt */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ diff --git a/include/configs/eb_cpu5282.h b/include/configs/eb_cpu5282.h index 924362c..f9ec028 100644 --- a/include/configs/eb_cpu5282.h +++ b/include/configs/eb_cpu5282.h @@ -73,7 +73,6 @@ #define CONFIG_MCFTMR
#define CONFIG_BOOTDELAY 5 -#define CONFIG_SYS_PROMPT "\nEB+CPU5282> " #define CONFIG_SYS_LONGHELP 1
#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/eb_cpux9k2.h b/include/configs/eb_cpux9k2.h index 271e071..d27f7e0 100644 --- a/include/configs/eb_cpux9k2.h +++ b/include/configs/eb_cpux9k2.h @@ -44,7 +44,6 @@ #define CONFIG_BOOT_RETRY_TIME 30 #define CONFIG_CMDLINE_EDITING
-#define CONFIG_SYS_PROMPT "U-Boot> " /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ #define CONFIG_SYS_MAXARGS 32 /* max number of command args */ #define CONFIG_SYS_PBSIZE \ diff --git a/include/configs/eco5pk.h b/include/configs/eco5pk.h index 49c53e4..f23d383 100644 --- a/include/configs/eco5pk.h +++ b/include/configs/eco5pk.h @@ -37,12 +37,6 @@ #define CONFIG_AUTO_COMPLETE
/* - * Miscellaneous configurable options - */ -#define V_PROMPT "ECO5-PK # " -#define CONFIG_SYS_PROMPT V_PROMPT - -/* * Set its own mtdparts, different from common */ #undef MTDIDS_DEFAULT diff --git a/include/configs/edb93xx.h b/include/configs/edb93xx.h index 87b29f8..efe2a9d 100644 --- a/include/configs/edb93xx.h +++ b/include/configs/edb93xx.h @@ -39,7 +39,7 @@
#define CONFIG_SYS_LDSCRIPT "board/cirrus/edb93xx/u-boot.lds"
- +#undef CONFIG_SYS_PROMPT #ifdef CONFIG_EDB9301 #define CONFIG_EP9301 #define CONFIG_MACH_TYPE MACH_TYPE_EDB9301 diff --git a/include/configs/edminiv2.h b/include/configs/edminiv2.h index b5e8e0e..8b38d7e 100644 --- a/include/configs/edminiv2.h +++ b/include/configs/edminiv2.h @@ -130,7 +130,6 @@ #define CONFIG_INITRD_TAG 1 /* enable INITRD tag */ #define CONFIG_SETUP_MEMORY_TAGS 1 /* enable memory tag */
-#define CONFIG_SYS_PROMPT "EDMiniV2> " /* Command Prompt */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buff Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE \ +sizeof(CONFIG_SYS_PROMPT) + 16) /* Print Buff */ diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index c7b1e5c..b49b903 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -237,7 +237,6 @@ #endif
/* Misc. u-boot settings */ -#define CONFIG_SYS_PROMPT "U-Boot> " #define CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 diff --git a/include/configs/flea3.h b/include/configs/flea3.h index 5d66901..5b4b011 100644 --- a/include/configs/flea3.h +++ b/include/configs/flea3.h @@ -108,7 +108,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "flea3 U-Boot > " #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_HUSH_PARSER /* Use the HUSH parser */
diff --git a/include/configs/fx12mm.h b/include/configs/fx12mm.h index f1cbc8e..fa32a2e 100644 --- a/include/configs/fx12mm.h +++ b/include/configs/fx12mm.h @@ -37,7 +37,6 @@ #define CONFIG_ENV_OVERWRITE 1
/*Misc*/ -#define CONFIG_SYS_PROMPT "FX12MM:/# " /* Monitor Command Prompt */ #define CONFIG_PREBOOT "echo U-Boot is up and running;"
/*Flash*/ diff --git a/include/configs/goflexhome.h b/include/configs/goflexhome.h index 967a05a..2a42e7c 100644 --- a/include/configs/goflexhome.h +++ b/include/configs/goflexhome.h @@ -70,9 +70,6 @@ */ #include "mv-common.h"
-#undef CONFIG_SYS_PROMPT /* previously defined in mv-common.h */ -#define CONFIG_SYS_PROMPT "GoFlexHome> " /* Command Prompt */ - /* * Environment variables configurations */ diff --git a/include/configs/grasshopper.h b/include/configs/grasshopper.h index 231f25a..274175b 100644 --- a/include/configs/grasshopper.h +++ b/include/configs/grasshopper.h @@ -144,7 +144,6 @@ #define CONFIG_SYS_BOOTPARAMS_LEN (16 * 1024)
/* Other configuration settings that shouldn't have to change all that often */ -#define CONFIG_SYS_PROMPT "U-Boot> " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 7c90812..1c0d96e 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -226,7 +226,6 @@ #define CONFIG_IMX_VIDEO_SKIP
/* Miscellaneous configurable options */ -#define CONFIG_SYS_PROMPT "Ventana > " #define CONFIG_HWCONFIG
/* Print Buffer Size */ diff --git a/include/configs/h2200.h b/include/configs/h2200.h index 1d2d09a..e8dfa74 100644 --- a/include/configs/h2200.h +++ b/include/configs/h2200.h @@ -123,7 +123,6 @@ #define CONFIG_INITRD_TAG
/* Monitor Command Prompt */ -#define CONFIG_SYS_PROMPT "> " #define CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_PROMPT_HUSH_PS2 "$ "
diff --git a/include/configs/harmony.h b/include/configs/harmony.h index 99a63d6..e0bc7c0 100644 --- a/include/configs/harmony.h +++ b/include/configs/harmony.h @@ -12,7 +12,6 @@ #include "tegra20-common.h"
/* High-level configuration options */ -#define V_PROMPT "Tegra20 (Harmony) # " #define CONFIG_TEGRA_BOARD_STRING "NVIDIA Harmony"
/* Board-specific serial config */ diff --git a/include/configs/hrcon.h b/include/configs/hrcon.h index 08e2f42..558edfc 100644 --- a/include/configs/hrcon.h +++ b/include/configs/hrcon.h @@ -484,7 +484,6 @@ int fpga_gpio_get(unsigned int bus, int pin); */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ -#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ #define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */
#undef CONFIG_ZERO_BOOTDELAY_CHECK /* ignore keypress on bootdelay==0 */ diff --git a/include/configs/ib62x0.h b/include/configs/ib62x0.h index ee52452..6afe340 100644 --- a/include/configs/ib62x0.h +++ b/include/configs/ib62x0.h @@ -59,9 +59,6 @@ */ #include "mv-common.h"
-#undef CONFIG_SYS_PROMPT -#define CONFIG_SYS_PROMPT "ib62x0 => " - /* * Environment variables configuration */ diff --git a/include/configs/iconnect.h b/include/configs/iconnect.h index 1a5c93d..bce97dc 100644 --- a/include/configs/iconnect.h +++ b/include/configs/iconnect.h @@ -52,9 +52,6 @@ */ #include "mv-common.h"
-#undef CONFIG_SYS_PROMPT -#define CONFIG_SYS_PROMPT "iconnect => " - /* * Environment variables configuration */ diff --git a/include/configs/ima3-mx53.h b/include/configs/ima3-mx53.h index 5a02917..2fa6c3d 100644 --- a/include/configs/ima3-mx53.h +++ b/include/configs/ima3-mx53.h @@ -94,7 +94,6 @@ /* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "IMA3 MX53 U-Boot > " #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */
diff --git a/include/configs/imx31_litekit.h b/include/configs/imx31_litekit.h index c552e9f..23e3a6c 100644 --- a/include/configs/imx31_litekit.h +++ b/include/configs/imx31_litekit.h @@ -101,7 +101,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "uboot> " #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index 54e8121..86f327c 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -102,7 +102,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "uboot> " /* Console I/O Buffer Size */ #define CONFIG_SYS_CBSIZE 256 /* Print Buffer Size */ diff --git a/include/configs/integratorap.h b/include/configs/integratorap.h index c76ebcb..5e3ed8e 100644 --- a/include/configs/integratorap.h +++ b/include/configs/integratorap.h @@ -47,11 +47,6 @@ #define CONFIG_BOOTARGS "root=/dev/mtdblock0 console=ttyAM0 console=tty" #define CONFIG_BOOTCOMMAND ""
-/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_PROMPT "Integrator-AP # " /* Monitor Command Prompt */ - /* Flash settings */ #define CONFIG_SYS_FLASH_SIZE 0x02000000 /* 32 MiB */ #define CONFIG_SYS_MAX_FLASH_SECT 128 diff --git a/include/configs/integratorcp.h b/include/configs/integratorcp.h index d6f2602..5391ae6 100644 --- a/include/configs/integratorcp.h +++ b/include/configs/integratorcp.h @@ -50,8 +50,6 @@ /* * Miscellaneous configurable options */ -#define CONFIG_SYS_PROMPT "Integrator-CP # " /* Monitor Command Prompt */ - #define PHYS_FLASH_SIZE 0x01000000 /* 16MB */ #define CONFIG_SYS_MAX_FLASH_SECT 64 #define CONFIG_ENV_IS_IN_FLASH 1 diff --git a/include/configs/ipam390.h b/include/configs/ipam390.h index e68b661..b1cd7df 100644 --- a/include/configs/ipam390.h +++ b/include/configs/ipam390.h @@ -207,7 +207,6 @@ #define CONFIG_MISC_INIT_R #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOOTFILE "uImage" /* Boot file name */ -#define CONFIG_SYS_PROMPT "U-Boot > " /* Command Prompt */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ diff --git a/include/configs/jetson-tk1.h b/include/configs/jetson-tk1.h index 3bbff28..a16239b 100644 --- a/include/configs/jetson-tk1.h +++ b/include/configs/jetson-tk1.h @@ -16,7 +16,6 @@ #include "tegra124-common.h"
/* High-level configuration options */ -#define V_PROMPT "Tegra124 (Jetson TK1) # " #define CONFIG_TEGRA_BOARD_STRING "NVIDIA Jetson TK1"
/* Board-specific serial config */ diff --git a/include/configs/jornada.h b/include/configs/jornada.h index 71f2ee1..3090476 100644 --- a/include/configs/jornada.h +++ b/include/configs/jornada.h @@ -55,7 +55,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "HP Jornada# " #define CONFIG_SYS_CBSIZE 256 /* console buffsize */ #define CONFIG_SYS_PBSIZE (256+sizeof(CONFIG_SYS_PROMPT)+16) #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ diff --git a/include/configs/kzm9g.h b/include/configs/kzm9g.h index 93c2976..8a451ec 100644 --- a/include/configs/kzm9g.h +++ b/include/configs/kzm9g.h @@ -53,7 +53,6 @@
/* prompt */ #define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_PROMPT "KZM-A9-GT# " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_PBSIZE 256 #define CONFIG_SYS_MAXARGS 16 diff --git a/include/configs/lp8x4x.h b/include/configs/lp8x4x.h index e9ee3fb..10a7b05 100644 --- a/include/configs/lp8x4x.h +++ b/include/configs/lp8x4x.h @@ -97,6 +97,7 @@ #define CONFIG_SYS_HUSH_PARSER 1
#define CONFIG_SYS_LONGHELP +#undef CONFIG_SYS_PROMPT #ifdef CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_PROMPT "$ " #else diff --git a/include/configs/ls2085a_common.h b/include/configs/ls2085a_common.h index 5afee55..39fb464 100644 --- a/include/configs/ls2085a_common.h +++ b/include/configs/ls2085a_common.h @@ -260,7 +260,6 @@ unsigned long long get_qixis_addr(void);
/* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PROMPT "=> " #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_HUSH_PARSER diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index ddbf5ce..1837258 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -88,7 +88,6 @@ #define CONFIG_SF_DEFAULT_SPEED 25000000
-#undef CONFIG_SYS_PROMPT #define CONFIG_SYS_PROMPT_HUSH_PS2 "> "
/* diff --git a/include/configs/malta.h b/include/configs/malta.h index ab2335f..2f33f63 100644 --- a/include/configs/malta.h +++ b/include/configs/malta.h @@ -59,6 +59,7 @@ /* * Console configuration */ +#undef CONFIG_SYS_PROMPT #if defined(CONFIG_SYS_LITTLE_ENDIAN) #define CONFIG_SYS_PROMPT "maltael # " #else diff --git a/include/configs/mcx.h b/include/configs/mcx.h index 0a7b7cf..d5adfd6 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -267,11 +267,8 @@ /* * Miscellaneous configurable options */ -#define V_PROMPT "mcx # " - #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT V_PROMPT #define CONFIG_SYS_CBSIZE 1024/* Console I/O Buffer Size */ /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/medcom-wide.h b/include/configs/medcom-wide.h index b5d72e3..6dfd5e2 100644 --- a/include/configs/medcom-wide.h +++ b/include/configs/medcom-wide.h @@ -13,7 +13,6 @@ #include "tegra20-common.h"
/* High-level configuration options */ -#define V_PROMPT "Tegra20 (Medcom-Wide) # " #define CONFIG_TEGRA_BOARD_STRING "Avionic Design Medcom-Wide"
/* Board-specific serial config */ diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index e16965c..626fa44 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -316,8 +316,6 @@ "1m(cramfs),-(jffs2)" #endif
-/* Miscellaneous configurable options */ -#define CONFIG_SYS_PROMPT "U-Boot-mONStR> " /* size of console buffer */ #define CONFIG_SYS_CBSIZE 512 /* print buffer size */ diff --git a/include/configs/ml507.h b/include/configs/ml507.h index b9ecb09..89a7290 100644 --- a/include/configs/ml507.h +++ b/include/configs/ml507.h @@ -24,7 +24,6 @@ #define CONFIG_ENV_ADDR (XPAR_FLASH_MEM0_BASEADDR+CONFIG_ENV_OFFSET)
/*Misc*/ -#define CONFIG_SYS_PROMPT "ml507:/# " /* Monitor Command Prompt */ #define CONFIG_PREBOOT "echo U-Boot is up and runnining;"
/*Flash*/ diff --git a/include/configs/mt_ventoux.h b/include/configs/mt_ventoux.h index dd516ac..3073db9 100644 --- a/include/configs/mt_ventoux.h +++ b/include/configs/mt_ventoux.h @@ -30,12 +30,6 @@ #define CONFIG_HOSTNAME mt_ventoux
/* - * Miscellaneous configurable options - */ -#define V_PROMPT "mt_ventoux => " -#define CONFIG_SYS_PROMPT V_PROMPT - -/* * Set its own mtdparts, different from common */ #undef MTDIDS_DEFAULT diff --git a/include/configs/mv-common.h b/include/configs/mv-common.h index b90de14..92e5429 100644 --- a/include/configs/mv-common.h +++ b/include/configs/mv-common.h @@ -70,7 +70,6 @@ #define CONFIG_INITRD_TAG 1 /* enable INITRD tag */ #define CONFIG_SETUP_MEMORY_TAGS 1 /* enable memory tag */
-#define CONFIG_SYS_PROMPT "Marvell>> " /* Command Prompt */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buff Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE \ +sizeof(CONFIG_SYS_PROMPT) + 16) /* Print Buff */ diff --git a/include/configs/mx51_efikamx.h b/include/configs/mx51_efikamx.h index 22aec4f..373cfcb 100644 --- a/include/configs/mx51_efikamx.h +++ b/include/configs/mx51_efikamx.h @@ -205,7 +205,6 @@
#define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "Efika> " #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ /* Print Buffer Size */ diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index 436b022..6ae736f 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -151,7 +151,6 @@ "else run netboot; fi"
/* Miscellaneous configurable options */ -#define CONFIG_SYS_PROMPT "=> " /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16)
diff --git a/include/configs/nas220.h b/include/configs/nas220.h index 61af61f..ebf6750 100644 --- a/include/configs/nas220.h +++ b/include/configs/nas220.h @@ -64,10 +64,6 @@ */ #include "mv-common.h"
-/* Remove or override few declarations from mv-common.h */ -#undef CONFIG_SYS_PROMPT /* previously defined in mv-common.h */ -#define CONFIG_SYS_PROMPT "nas220> " - /* * Environment variables configurations */ diff --git a/include/configs/nhk8815.h b/include/configs/nhk8815.h index 8755be7..dd70adc 100644 --- a/include/configs/nhk8815.h +++ b/include/configs/nhk8815.h @@ -27,7 +27,6 @@ /* user interface */ #define CONFIG_SYS_LONGHELP #define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT "Nomadik> " #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE \ diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index 6e3ce4d..4f688c7 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -396,7 +396,6 @@ int rx51_kp_getc(struct stdio_dev *sdev); #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " -#define CONFIG_SYS_PROMPT "Nokia RX-51 # " #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/nyan-big.h b/include/configs/nyan-big.h index dd549aa..b198016 100644 --- a/include/configs/nyan-big.h +++ b/include/configs/nyan-big.h @@ -13,7 +13,6 @@ #include "tegra124-common.h"
/* High-level configuration options */ -#define V_PROMPT "Tegra124 (Nyan-big) # " #define CONFIG_TEGRA_BOARD_STRING "Google/NVIDIA Nyan-big"
/* Board-specific serial config */ diff --git a/include/configs/odroid.h b/include/configs/odroid.h index 69be496..1afe04a 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -14,9 +14,6 @@
#include <configs/exynos4-common.h>
-#define CONFIG_SYS_PROMPT "Odroid # " /* Monitor Command Prompt */ - - #define CONFIG_SYS_L2CACHE_OFF #ifndef CONFIG_SYS_L2CACHE_OFF #define CONFIG_SYS_L2_PL310 diff --git a/include/configs/odroid_xu3.h b/include/configs/odroid_xu3.h index 8d5c736..a86d4c1 100644 --- a/include/configs/odroid_xu3.h +++ b/include/configs/odroid_xu3.h @@ -10,7 +10,6 @@
#include "exynos5420-common.h"
-#define CONFIG_SYS_PROMPT "ODROID-XU3 # " #define CONFIG_IDENT_STRING " for ODROID-XU3"
#define CONFIG_BOARD_COMMON diff --git a/include/configs/omap3_cairo.h b/include/configs/omap3_cairo.h index 81d4b34..713df3c 100644 --- a/include/configs/omap3_cairo.h +++ b/include/configs/omap3_cairo.h @@ -241,10 +241,6 @@ #define CONFIG_SERIAL2 #endif
-/* Keep old prompt in case some existing script depends on it */ -#undef CONFIG_SYS_PROMPT -#define CONFIG_SYS_PROMPT "Cairo # " - /* Provide MACH_TYPE for compatibility with non-DT kernels */ #define MACH_TYPE_OMAP3_CAIRO 3063 #define CONFIG_MACH_TYPE MACH_TYPE_OMAP3_CAIRO diff --git a/include/configs/omap3_evm_common.h b/include/configs/omap3_evm_common.h index 370f21e..b0d1c93 100644 --- a/include/configs/omap3_evm_common.h +++ b/include/configs/omap3_evm_common.h @@ -179,7 +179,6 @@ * U-boot features * ---------------------------------------------------------------------------- */ -#define CONFIG_SYS_PROMPT "OMAP3_EVM # " #define CONFIG_SYS_MAXARGS 16 /* max args for a command */
#define CONFIG_MISC_INIT_R diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index af6ae73..7ff0b1a 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -235,7 +235,6 @@ */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "OMAP Logic # " #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/omap3_mvblx.h b/include/configs/omap3_mvblx.h index 4339b05..40f278a 100644 --- a/include/configs/omap3_mvblx.h +++ b/include/configs/omap3_mvblx.h @@ -205,7 +205,6 @@ */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "mvblx # " #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index a1a90ec..41a7481 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -186,12 +186,6 @@ "fi;" \ "run nanddtsboot; " \
-/* - * Miscellaneous configurable options - */ -#undef CONFIG_SYS_PROMPT -#define CONFIG_SYS_PROMPT "Overo # " - /* memtest works on */ #define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0) #define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + \ diff --git a/include/configs/omap3_pandora.h b/include/configs/omap3_pandora.h index 49467c9..93cb9a3 100644 --- a/include/configs/omap3_pandora.h +++ b/include/configs/omap3_pandora.h @@ -101,12 +101,6 @@ "ubi part boot && ubifsmount ubi:boot && " \ "ubifsload ${loadaddr} uImage && bootm ${loadaddr}"
-/* - * Miscellaneous configurable options - */ -#undef CONFIG_SYS_PROMPT -#define CONFIG_SYS_PROMPT "Pandora # " - /* memtest works on */ #define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0) #define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + \ diff --git a/include/configs/omap3_sdp3430.h b/include/configs/omap3_sdp3430.h index 16ceb91..f43e477 100644 --- a/include/configs/omap3_sdp3430.h +++ b/include/configs/omap3_sdp3430.h @@ -240,7 +240,6 @@
#define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "OMAP34XX SDP # " #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 6d0d020..d9a3aa4 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -199,7 +199,6 @@ #define CONFIG_MISC_INIT_R #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOOTFILE "uImage" /* Boot file name */ -#define CONFIG_SYS_PROMPT "U-Boot > " /* Command Prompt */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ diff --git a/include/configs/origen.h b/include/configs/origen.h index dae8fd5..21d8e7a 100644 --- a/include/configs/origen.h +++ b/include/configs/origen.h @@ -11,9 +11,6 @@
-#define CONFIG_SYS_PROMPT "ORIGEN # " - - /* High Level Configuration Options */ #define CONFIG_EXYNOS4210 1 /* which is a EXYNOS4210 SoC */ #define CONFIG_ORIGEN 1 /* working with ORIGEN*/ diff --git a/include/configs/palmld.h b/include/configs/palmld.h index a9f92fa..ec48c14 100644 --- a/include/configs/palmld.h +++ b/include/configs/palmld.h @@ -96,9 +96,6 @@ #define CONFIG_SYS_HUSH_PARSER 1
#define CONFIG_SYS_LONGHELP -#ifdef CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT "$ " -#endif #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_PBSIZE \ (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) diff --git a/include/configs/palmtc.h b/include/configs/palmtc.h index b68ad3b..81c3f02 100644 --- a/include/configs/palmtc.h +++ b/include/configs/palmtc.h @@ -99,9 +99,6 @@ #define CONFIG_SYS_HUSH_PARSER 1
#define CONFIG_SYS_LONGHELP -#ifdef CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT "$ " -#endif #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_PBSIZE \ (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) diff --git a/include/configs/palmtreo680.h b/include/configs/palmtreo680.h index 3946607..ffb0d1e 100644 --- a/include/configs/palmtreo680.h +++ b/include/configs/palmtreo680.h @@ -92,6 +92,7 @@ #define CONFIG_SYS_PROMPT_HUSH_PS2 "> "
#define CONFIG_SYS_LONGHELP +#undef CONFIG_SYS_PROMPT #ifdef CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_PROMPT "$ " #else diff --git a/include/configs/paz00.h b/include/configs/paz00.h index 0bdeccc..8eac81a 100644 --- a/include/configs/paz00.h +++ b/include/configs/paz00.h @@ -21,7 +21,6 @@ #include "tegra20-common.h"
/* High-level configuration options */ -#define V_PROMPT "Tegra20 (Paz00) MOD # " #define CONFIG_TEGRA_BOARD_STRING "Compal Paz00"
/* Board-specific serial config */ diff --git a/include/configs/pb1x00.h b/include/configs/pb1x00.h index af2654e..516d381 100644 --- a/include/configs/pb1x00.h +++ b/include/configs/pb1x00.h @@ -52,7 +52,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "Pb1x00 # " /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ #define CONFIG_SYS_MAXARGS 16 /* max number of command args*/ diff --git a/include/configs/pcm030.h b/include/configs/pcm030.h index 83c96a8..29feb7b 100644 --- a/include/configs/pcm030.h +++ b/include/configs/pcm030.h @@ -337,7 +337,6 @@ RTC configuration Miscellaneous configurable options -------------------------------------------------------------------------------*/ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "uboot> " /* Monitor Command Prompt */
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */
diff --git a/include/configs/peach-pi.h b/include/configs/peach-pi.h index 46699ff..5906171 100644 --- a/include/configs/peach-pi.h +++ b/include/configs/peach-pi.h @@ -36,7 +36,6 @@ #define CONFIG_SERIAL3 /* use SERIAL 3 */ #define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0"
-#define CONFIG_SYS_PROMPT "Peach-Pi # " #define CONFIG_IDENT_STRING " for Peach-Pi"
#define CONFIG_VIDEO_PARADE diff --git a/include/configs/peach-pit.h b/include/configs/peach-pit.h index c5c9e3a..3b92df8 100644 --- a/include/configs/peach-pit.h +++ b/include/configs/peach-pit.h @@ -36,7 +36,6 @@ #define CONFIG_SERIAL3 /* use SERIAL 3 */ #define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0"
-#define CONFIG_SYS_PROMPT "Peach-Pit # " #define CONFIG_IDENT_STRING " for Peach-Pit"
#define CONFIG_VIDEO_PARADE diff --git a/include/configs/pepper.h b/include/configs/pepper.h index 0bdcf22..1bc8c4b 100644 --- a/include/configs/pepper.h +++ b/include/configs/pepper.h @@ -17,9 +17,6 @@ #define V_OSCK 24000000 /* Clock output from T2 */ #define V_SCLK (V_OSCK)
-#undef CONFIG_SYS_PROMPT -#define CONFIG_SYS_PROMPT "pepper# " - #define CONFIG_SYS_I2C_EEPROM_ADDR 0x50
/* Mach type */ diff --git a/include/configs/platinum_picon.h b/include/configs/platinum_picon.h index f5b476f..3679530 100644 --- a/include/configs/platinum_picon.h +++ b/include/configs/platinum_picon.h @@ -19,8 +19,6 @@
#define CONFIG_HOSTNAME picon
-#define CONFIG_SYS_PROMPT "picon > " - #define CONFIG_PLATFORM_ENV_SETTINGS "\0"
#define CONFIG_EXTRA_ENV_SETTINGS CONFIG_COMMON_ENV_SETTINGS \ diff --git a/include/configs/platinum_titanium.h b/include/configs/platinum_titanium.h index 9bca10f..ccb6441 100644 --- a/include/configs/platinum_titanium.h +++ b/include/configs/platinum_titanium.h @@ -26,8 +26,6 @@
#define CONFIG_HOSTNAME titanium
-#define CONFIG_SYS_PROMPT "titanium > " - #define CONFIG_PLATFORM_ENV_SETTINGS "\0"
#define CONFIG_EXTRA_ENV_SETTINGS CONFIG_COMMON_ENV_SETTINGS \ diff --git a/include/configs/plutux.h b/include/configs/plutux.h index 7f7ea97..1d6df32 100644 --- a/include/configs/plutux.h +++ b/include/configs/plutux.h @@ -13,7 +13,6 @@ #include "tegra20-common.h"
/* High-level configuration options */ -#define V_PROMPT "Tegra20 (Plutux) # " #define CONFIG_TEGRA_BOARD_STRING "Avionic Design Plutux"
/* Board-specific serial config */ diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index f9a1d51..f4f96a7 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -336,7 +336,6 @@
-#define CONFIG_SYS_PROMPT "pm9261> " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE \ diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index 6c434f0..bd43577 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -370,7 +370,6 @@
-#define CONFIG_SYS_PROMPT "u-boot-pm9263> " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE \ diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index c793865..09f0744 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -149,7 +149,6 @@
-#define CONFIG_SYS_PROMPT "U-Boot> " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/pogo_e02.h b/include/configs/pogo_e02.h index 3a0992a..8cf3ad8 100644 --- a/include/configs/pogo_e02.h +++ b/include/configs/pogo_e02.h @@ -47,10 +47,6 @@ */ #include "mv-common.h"
-/* Remove or override few declarations from mv-common.h */ -#undef CONFIG_SYS_PROMPT /* previously defined in mv-common.h */ -#define CONFIG_SYS_PROMPT "PogoE02> " - /* * Environment variables configurations */ diff --git a/include/configs/pr1.h b/include/configs/pr1.h index 3e4aab4..f76e023 100644 --- a/include/configs/pr1.h +++ b/include/configs/pr1.h @@ -128,7 +128,6 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_RTC_BFIN #define CONFIG_UART_CONSOLE 0 -#define CONFIG_SYS_PROMPT "pr1>" #define CONFIG_BOOTCOMMAND "run nandboot" #define CONFIG_BOOTDELAY 2 #define CONFIG_LOADADDR 0x2000000 diff --git a/include/configs/pxa255_idp.h b/include/configs/pxa255_idp.h index 3edeb08..332d79f 100644 --- a/include/configs/pxa255_idp.h +++ b/include/configs/pxa255_idp.h @@ -205,6 +205,7 @@ #define CONFIG_SYS_HUSH_PARSER 1
#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#undef CONFIG_SYS_PROMPT #ifdef CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_PROMPT "$ " /* Monitor Command Prompt */ #else diff --git a/include/configs/qemu-mips.h b/include/configs/qemu-mips.h index b22637b..a7ec8f5 100644 --- a/include/configs/qemu-mips.h +++ b/include/configs/qemu-mips.h @@ -78,6 +78,7 @@ #define CONFIG_SYS_LONGHELP /* undef to save memory */
/* Monitor Command Prompt */ +#undef CONFIG_SYS_PROMPT #if defined(CONFIG_SYS_LITTLE_ENDIAN) #define CONFIG_SYS_PROMPT "qemu-mipsel # " #else diff --git a/include/configs/qemu-mips64.h b/include/configs/qemu-mips64.h index fae5b05..4de15bf 100644 --- a/include/configs/qemu-mips64.h +++ b/include/configs/qemu-mips64.h @@ -80,6 +80,7 @@ #define CONFIG_SYS_LONGHELP /* undef to save memory */
/* Monitor Command Prompt */ +#undef CONFIG_SYS_PROMPT #if defined(CONFIG_SYS_LITTLE_ENDIAN) #define CONFIG_SYS_PROMPT "qemu-mips64el # " #else diff --git a/include/configs/rpi-common.h b/include/configs/rpi-common.h index 1012cdd..25566d2 100644 --- a/include/configs/rpi-common.h +++ b/include/configs/rpi-common.h @@ -116,7 +116,6 @@
/* Shell */ #define CONFIG_SYS_MAXARGS 8 -#define CONFIG_SYS_PROMPT "U-Boot> " #define CONFIG_COMMAND_HISTORY
/* Commands */ diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index 235bba5..aff264b 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -197,7 +197,6 @@
#define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "Goni # " #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index e7bace4..35fef2b 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -12,9 +12,6 @@
-#define CONFIG_SYS_PROMPT "Universal # " /* Monitor Command Prompt */ - - #define CONFIG_TIZEN /* TIZEN lib */
/* Keep L2 Cache Disabled */ diff --git a/include/configs/scb9328.h b/include/configs/scb9328.h index f367d62..d4ffb46 100644 --- a/include/configs/scb9328.h +++ b/include/configs/scb9328.h @@ -51,7 +51,6 @@ * General options for u-boot. Modify to save memory foot print */ #define CONFIG_SYS_LONGHELP /* undef saves memory */ -#define CONFIG_SYS_PROMPT "scb9328> " /* prompt string */ #define CONFIG_SYS_CBSIZE 256 /* console I/O buffer */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* print buffer size */ #define CONFIG_SYS_MAXARGS 16 /* max command args */ diff --git a/include/configs/seaboard.h b/include/configs/seaboard.h index fdeffb5..3e90474 100644 --- a/include/configs/seaboard.h +++ b/include/configs/seaboard.h @@ -20,7 +20,6 @@ #include "tegra20-common.h"
/* High-level configuration options */ -#define V_PROMPT "Tegra20 (SeaBoard) # " #define CONFIG_TEGRA_BOARD_STRING "NVIDIA Seaboard"
/* Board-specific serial config */ diff --git a/include/configs/secomx6quq7.h b/include/configs/secomx6quq7.h index 114d1fd..703f4fc 100644 --- a/include/configs/secomx6quq7.h +++ b/include/configs/secomx6quq7.h @@ -74,9 +74,6 @@ "stderr=serial\0"
-/* Miscellaneous configurable options */ -#define CONFIG_SYS_PROMPT "SECO MX6Q uQ7 U-Boot > " - /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index f7bef70..6aeb96a 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -27,7 +27,6 @@ #define CONFIG_SYS_MALLOC_LEN (16 * 1024 * 1024) #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "U-Boot# " #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_BOARD_LATE_INIT #define CONFIG_SYS_NO_FLASH diff --git a/include/configs/smdk2410.h b/include/configs/smdk2410.h index 7b4b3b0..a6bfa76 100644 --- a/include/configs/smdk2410.h +++ b/include/configs/smdk2410.h @@ -106,7 +106,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "SMDK2410 # " #define CONFIG_SYS_CBSIZE 256 /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/smdk5250.h b/include/configs/smdk5250.h index e5655fc..8975316 100644 --- a/include/configs/smdk5250.h +++ b/include/configs/smdk5250.h @@ -25,7 +25,6 @@ #define CONFIG_USB_XHCI #define CONFIG_USB_XHCI_EXYNOS
-#define CONFIG_SYS_PROMPT "SMDK5250 # " #define CONFIG_IDENT_STRING " for SMDK5250"
/* Miscellaneous configurable options */ diff --git a/include/configs/smdk5420.h b/include/configs/smdk5420.h index 607877c..bbc75d8 100644 --- a/include/configs/smdk5420.h +++ b/include/configs/smdk5420.h @@ -29,7 +29,6 @@ #define CONFIG_SERIAL3 /* use SERIAL 3 */ #define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0"
-#define CONFIG_SYS_PROMPT "SMDK5420 # " #define CONFIG_IDENT_STRING " for SMDK5420" #define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0"
diff --git a/include/configs/smdkc100.h b/include/configs/smdkc100.h index 08a2e9f..4ec9c65 100644 --- a/include/configs/smdkc100.h +++ b/include/configs/smdkc100.h @@ -152,7 +152,6 @@ */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "SMDKC100 # " #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ diff --git a/include/configs/smdkv310.h b/include/configs/smdkv310.h index d26e5ec..dbba88b 100644 --- a/include/configs/smdkv310.h +++ b/include/configs/smdkv310.h @@ -55,7 +55,6 @@ #define CONFIG_BOOTCOMMAND "fatload mmc 0 40007000 uImage; bootm 40007000"
/* Miscellaneous configurable options */ -#define CONFIG_SYS_PROMPT "SMDKV310 # " #define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" /* memtest works on */ #define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE diff --git a/include/configs/snapper9260.h b/include/configs/snapper9260.h index 70ef939..7758b0f 100644 --- a/include/configs/snapper9260.h +++ b/include/configs/snapper9260.h @@ -89,7 +89,6 @@ #define CONFIG_USART_ID ATMEL_ID_SYS #endif #define CONFIG_BAUDRATE 115200 -#define CONFIG_SYS_PROMPT "Snapper> "
/* I2C - Bit-bashed */ #define CONFIG_SYS_I2C diff --git a/include/configs/snow.h b/include/configs/snow.h index 557f86c..8dba8f5 100644 --- a/include/configs/snow.h +++ b/include/configs/snow.h @@ -28,7 +28,6 @@ #define CONFIG_USB_XHCI_EXYNOS #define CONFIG_USB_EHCI_EXYNOS
-#define CONFIG_SYS_PROMPT "snow # " #define CONFIG_IDENT_STRING " for snow" #define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0"
diff --git a/include/configs/snowball.h b/include/configs/snowball.h index 91aaffa..de03e76 100644 --- a/include/configs/snowball.h +++ b/include/configs/snowball.h @@ -154,7 +154,6 @@ */
#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "U8500 $ " /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */
/* Print Buffer Size */ diff --git a/include/configs/spear-common.h b/include/configs/spear-common.h index f75c306..fb1bf66 100644 --- a/include/configs/spear-common.h +++ b/include/configs/spear-common.h @@ -201,7 +201,6 @@ #define CONFIG_SYS_MALLOC_LEN (1024*1024) #define CONFIG_IDENT_STRING "-SPEAr" #define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_PROMPT "u-boot> " #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/stamp9g20.h b/include/configs/stamp9g20.h index 086ebcf..87df70b 100644 --- a/include/configs/stamp9g20.h +++ b/include/configs/stamp9g20.h @@ -180,7 +180,6 @@ /* General Boot Parameter */ #define CONFIG_BOOTDELAY 3 #define CONFIG_BOOTCOMMAND "run flashboot" -#define CONFIG_SYS_PROMPT "U-Boot> " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE \ diff --git a/include/configs/stm32f429-discovery.h b/include/configs/stm32f429-discovery.h index 1ac3db6..19d9cf9 100644 --- a/include/configs/stm32f429-discovery.h +++ b/include/configs/stm32f429-discovery.h @@ -100,7 +100,6 @@ */ #define CONFIG_SYS_LONGHELP #define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT "U-Boot > " #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING
diff --git a/include/configs/stv0991.h b/include/configs/stv0991.h index 887f31a..b1b6919 100644 --- a/include/configs/stv0991.h +++ b/include/configs/stv0991.h @@ -36,7 +36,6 @@ #define CONFIG_PL01X_SERIAL
/* user interface */ -#define CONFIG_SYS_PROMPT "STV0991> " #define CONFIG_SYS_CBSIZE 1024 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE \ +sizeof(CONFIG_SYS_PROMPT) + 16) diff --git a/include/configs/stxgp3.h b/include/configs/stxgp3.h index 6676f37..25b7d5f 100644 --- a/include/configs/stxgp3.h +++ b/include/configs/stxgp3.h @@ -315,7 +315,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "GPPP=> " /* Monitor Command Prompt */ #if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #else diff --git a/include/configs/stxssa.h b/include/configs/stxssa.h index 5b1f3ab..ee16fea 100644 --- a/include/configs/stxssa.h +++ b/include/configs/stxssa.h @@ -349,7 +349,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "SSA=> " /* Monitor Command Prompt */ #if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #else diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 5adcc39..24919b7 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -50,8 +50,6 @@ */ #define CONFIG_DISPLAY_CPUINFO
-#define CONFIG_SYS_PROMPT "sunxi# " - /* Serial & console */ #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL diff --git a/include/configs/tao3530.h b/include/configs/tao3530.h index c8ec79b..a8928e5 100644 --- a/include/configs/tao3530.h +++ b/include/configs/tao3530.h @@ -196,7 +196,6 @@ */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT "TAO-3530 # " #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */
/* turn on command-line edit/hist/auto */ diff --git a/include/configs/taurus.h b/include/configs/taurus.h index d5b93eb..2c9f5da 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -165,7 +165,6 @@ "512k(dtb),6M(kernel)ro,-(rootfs) " \ "root=/dev/mtdblock7 rw rootfstype=jffs2"
-#define CONFIG_SYS_PROMPT "U-Boot> " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE \ diff --git a/include/configs/tb100.h b/include/configs/tb100.h index 42817ae..41c2c72 100644 --- a/include/configs/tb100.h +++ b/include/configs/tb100.h @@ -96,7 +96,6 @@ * Console configuration */ #define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_PROMPT "[tb100]:~# " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 14985f8..66cb274 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -18,7 +18,6 @@
-#define CONFIG_SYS_PROMPT "Matrix U-Boot> " #define CONFIG_SYS_HZ 1000
#define CONFIG_IMX6_THERMAL diff --git a/include/configs/tec-ng.h b/include/configs/tec-ng.h index fa651c1..4cf2823 100644 --- a/include/configs/tec-ng.h +++ b/include/configs/tec-ng.h @@ -11,7 +11,6 @@ #include "tegra30-common.h"
/* High-level configuration options */ -#define V_PROMPT "Tegra30 (TEC-NG) # " #define CONFIG_TEGRA_BOARD_STRING "Avionic Design Tamonten™ NG Evaluation Carrier"
/* Board-specific serial config */ diff --git a/include/configs/tec.h b/include/configs/tec.h index 3b543eb..4b8ca5e 100644 --- a/include/configs/tec.h +++ b/include/configs/tec.h @@ -13,7 +13,6 @@ #include "tegra20-common.h"
/* High-level configuration options */ -#define V_PROMPT "Tegra20 (TEC) # " #define CONFIG_TEGRA_BOARD_STRING "Avionic Design Tamonten Evaluation Carrier"
/* Board-specific serial config */ diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index ffe167e..145f635 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -88,10 +88,6 @@ #endif
/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_PROMPT V_PROMPT -/* * Increasing the size of the IO buffer as default nfsargs size is more * than 256 and so it is not possible to edit it */ diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index fcfb70e..7fa35a1 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -28,7 +28,6 @@ #define CONFIG_SYS_MALLOC_LEN (1024 << 10) #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER /* Use HUSH for command parsing */ -#define CONFIG_SYS_PROMPT "U-Boot# " #define CONFIG_SYS_NO_FLASH #define CONFIG_MACH_TYPE MACH_TYPE_TI8148EVM
diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index 8d52057..01d8233 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -24,7 +24,6 @@ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (32 * 1024)) #define CONFIG_SYS_LONGHELP /* undef save memory */ #define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT "u-boot/ti816x# " #define CONFIG_MACH_TYPE MACH_TYPE_TI8168EVM
#define CONFIG_OF_LIBFDT diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index 6dc5ebd..18fca02 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -115,7 +115,6 @@ #define CONFIG_SYS_MALLOC_LEN (16 << 20) #endif #define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT "U-Boot# " #define CONFIG_SYS_CONSOLE_INFO_QUIET #define CONFIG_BAUDRATE 115200 #define CONFIG_ENV_VARS_UBOOT_CONFIG /* Strongly encouraged */ diff --git a/include/configs/titanium.h b/include/configs/titanium.h index 49aa3c7..1b4ca29 100644 --- a/include/configs/titanium.h +++ b/include/configs/titanium.h @@ -141,9 +141,6 @@
#define CONFIG_BOOTCOMMAND "run nand_ubifs"
-/* Miscellaneous configurable options */ -#define CONFIG_SYS_PROMPT "Titanium > " - /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) diff --git a/include/configs/trats.h b/include/configs/trats.h index 6808e78..5fb991b 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -12,8 +12,6 @@
-#define CONFIG_SYS_PROMPT "Trats # " /* Monitor Command Prompt */ - #define CONFIG_TRATS
diff --git a/include/configs/trats2.h b/include/configs/trats2.h index 94c31fb..f12a952 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -13,9 +13,6 @@
-#define CONFIG_SYS_PROMPT "Trats2 # " /* Monitor Command Prompt */ - - #define CONFIG_TIZEN /* TIZEN lib */
#define CONFIG_SYS_L2CACHE_OFF diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index 23bf599..f04b572 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -284,7 +284,6 @@ #define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ #define CONFIG_CMDLINE_EDITING /* enable cmdline history */ #define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_PROMPT "OMAP3 Tricorder # " #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/trimslice.h b/include/configs/trimslice.h index 2db38e5..2ab5511 100644 --- a/include/configs/trimslice.h +++ b/include/configs/trimslice.h @@ -12,7 +12,6 @@ #include "tegra20-common.h"
/* High-level configuration options */ -#define V_PROMPT "Tegra20 (TrimSlice) # " #define CONFIG_TEGRA_BOARD_STRING "Compulab Trimslice"
/* Board-specific serial config */ diff --git a/include/configs/trizepsiv.h b/include/configs/trizepsiv.h index 8368931..40c8d71 100644 --- a/include/configs/trizepsiv.h +++ b/include/configs/trizepsiv.h @@ -130,6 +130,7 @@ #define CONFIG_SYS_HUSH_PARSER 1
#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#undef CONFIG_SYS_PROMPT #ifdef CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_PROMPT "$ " /* Monitor Command Prompt */ #else diff --git a/include/configs/tt01.h b/include/configs/tt01.h index 9501a83..ca1e2e2 100644 --- a/include/configs/tt01.h +++ b/include/configs/tt01.h @@ -224,7 +224,6 @@ #define CONFIG_SYS_HUSH_PARSER
#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "TT01> " #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/twister.h b/include/configs/twister.h index f24dc13..4f5560f 100644 --- a/include/configs/twister.h +++ b/include/configs/twister.h @@ -29,8 +29,6 @@ /* * Miscellaneous configurable options */ -#define CONFIG_SYS_PROMPT "twister => " - #define CONFIG_SMC911X #define CONFIG_SMC911X_16_BIT #define CONFIG_SMC911X_BASE 0x2C000000 diff --git a/include/configs/u8500_href.h b/include/configs/u8500_href.h index 6a22571..a8cc030 100644 --- a/include/configs/u8500_href.h +++ b/include/configs/u8500_href.h @@ -111,7 +111,6 @@ */
/* Print Buffer Size */ diff --git a/include/configs/usb_a9263.h b/include/configs/usb_a9263.h index 4774de5..10a1664 100644 --- a/include/configs/usb_a9263.h +++ b/include/configs/usb_a9263.h @@ -140,7 +140,6 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ "mtdparts=" MTDPARTS_DEFAULT "\0" \
-#define CONFIG_SYS_PROMPT "U-Boot> " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/v5fx30teval.h b/include/configs/v5fx30teval.h index f30a090..298fa3e 100644 --- a/include/configs/v5fx30teval.h +++ b/include/configs/v5fx30teval.h @@ -24,7 +24,6 @@ #define CONFIG_ENV_ADDR (XPAR_FLASH_MEM0_BASEADDR+CONFIG_ENV_OFFSET)
/*Misc*/ -#define CONFIG_SYS_PROMPT "v5fx30t:/# " /* Monitor Command Prompt */ #define CONFIG_PREBOOT "echo U-Boot is up and runnining;"
/*Flash*/ diff --git a/include/configs/vct.h b/include/configs/vct.h index b54519d..80f6a60 100644 --- a/include/configs/vct.h +++ b/include/configs/vct.h @@ -145,7 +145,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "VCT# " /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) diff --git a/include/configs/venice2.h b/include/configs/venice2.h index 1d9d053..4c2eb0d 100644 --- a/include/configs/venice2.h +++ b/include/configs/venice2.h @@ -13,7 +13,6 @@ #include "tegra124-common.h"
/* High-level configuration options */ -#define V_PROMPT "Tegra124 (Venice2) # " #define CONFIG_TEGRA_BOARD_STRING "NVIDIA Venice2"
/* Board-specific serial config */ diff --git a/include/configs/ventana.h b/include/configs/ventana.h index 3f1ebcd..e9c3500 100644 --- a/include/configs/ventana.h +++ b/include/configs/ventana.h @@ -12,7 +12,6 @@ #include "tegra20-common.h"
/* High-level configuration options */ -#define V_PROMPT "Tegra20 (Ventana) # " #define CONFIG_TEGRA_BOARD_STRING "NVIDIA Ventana"
/* Board-specific serial config */ diff --git a/include/configs/versatile.h b/include/configs/versatile.h index de23375..636ca43 100644 --- a/include/configs/versatile.h +++ b/include/configs/versatile.h @@ -108,6 +108,7 @@ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ /* Monitor Command Prompt */ +#undef CONFIG_SYS_PROMPT #ifdef CONFIG_ARCH_VERSATILE_AB # define CONFIG_SYS_PROMPT "VersatileAB # " #else diff --git a/include/configs/vexpress_aemv8a.h b/include/configs/vexpress_aemv8a.h index c36237f..6107c64 100644 --- a/include/configs/vexpress_aemv8a.h +++ b/include/configs/vexpress_aemv8a.h @@ -239,7 +239,6 @@
/* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PROMPT "VExpress64# " #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_HUSH_PARSER diff --git a/include/configs/vexpress_common.h b/include/configs/vexpress_common.h index 0c1da01..df2ac64 100644 --- a/include/configs/vexpress_common.h +++ b/include/configs/vexpress_common.h @@ -280,7 +280,6 @@
/* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PROMPT "VExpress# " #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_HUSH_PARSER diff --git a/include/configs/vision2.h b/include/configs/vision2.h index 93c7348..b43373f 100644 --- a/include/configs/vision2.h +++ b/include/configs/vision2.h @@ -137,7 +137,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_PROMPT "Vision II U-boot > " #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */
diff --git a/include/configs/vl_ma2sc.h b/include/configs/vl_ma2sc.h index e4958ce..3facd7f 100644 --- a/include/configs/vl_ma2sc.h +++ b/include/configs/vl_ma2sc.h @@ -340,7 +340,6 @@ #define CONFIG_SYS_BAUDRATE_TABLE {312500, 230400, 115200, 19200, \ 38400, 57600, 9600 }
-#define CONFIG_SYS_PROMPT "U-Boot> " #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ #define CONFIG_SYS_MAXARGS 32 /* max number of command args */ #define CONFIG_SYS_PBSIZE \ diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h index 95a69b3..976ba5d 100644 --- a/include/configs/vpac270.h +++ b/include/configs/vpac270.h @@ -126,7 +126,6 @@
#define CONFIG_SYS_LONGHELP #ifdef CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT "$ " #else #endif #define CONFIG_SYS_CBSIZE 256 diff --git a/include/configs/whistler.h b/include/configs/whistler.h index 13cc3d3..ff85964 100644 --- a/include/configs/whistler.h +++ b/include/configs/whistler.h @@ -12,7 +12,6 @@ #include "tegra20-common.h"
/* High-level configuration options */ -#define V_PROMPT "Tegra20 (Whistler) # " #define CONFIG_TEGRA_BOARD_STRING "NVIDIA Whistler"
/* Board-specific serial config */ diff --git a/include/configs/wireless_space.h b/include/configs/wireless_space.h index 7219034..191ac1b 100644 --- a/include/configs/wireless_space.h +++ b/include/configs/wireless_space.h @@ -64,8 +64,6 @@ #undef CONFIG_SYS_IDE_MAXDEVICE #define CONFIG_SYS_IDE_MAXBUS 1 #define CONFIG_SYS_IDE_MAXDEVICE 1 -#undef CONFIG_SYS_PROMPT -#define CONFIG_SYS_PROMPT "ws> "
/* * Ethernet Driver configuration diff --git a/include/configs/woodburn_common.h b/include/configs/woodburn_common.h index 52d392c..5d9f529 100644 --- a/include/configs/woodburn_common.h +++ b/include/configs/woodburn_common.h @@ -130,7 +130,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "woodburn U-Boot > " #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_HUSH_PARSER /* Use the HUSH parser */
diff --git a/include/configs/x600.h b/include/configs/x600.h index 1d4c1a9..edb16b1 100644 --- a/include/configs/x600.h +++ b/include/configs/x600.h @@ -151,7 +151,6 @@ #define CONFIG_SYS_MALLOC_LEN (1024 * 1024) #define CONFIG_IDENT_STRING "-SPEAr" #define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_PROMPT "X600> " #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/xaeniax.h b/include/configs/xaeniax.h index a072464..8d19bff 100644 --- a/include/configs/xaeniax.h +++ b/include/configs/xaeniax.h @@ -94,7 +94,7 @@ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_HUSH_PARSER 1
- +#undef CONFIG_SYS_PROMPT #ifdef CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_PROMPT "u-boot$ " /* Monitor Command Prompt */ #else diff --git a/include/configs/xilinx-ppc405-generic.h b/include/configs/xilinx-ppc405-generic.h index 75b119f..40fa087 100644 --- a/include/configs/xilinx-ppc405-generic.h +++ b/include/configs/xilinx-ppc405-generic.h @@ -26,7 +26,6 @@ #define CONFIG_ENV_OVERWRITE 1
/*Misc*/ -#define CONFIG_SYS_PROMPT "xlx-ppc405:/# " /* Monitor Command Prompt */ #define CONFIG_PREBOOT "echo U-Boot is up and runnining;"
/*Flash*/ diff --git a/include/configs/xilinx-ppc440-generic.h b/include/configs/xilinx-ppc440-generic.h index 8e68415..95b8834 100644 --- a/include/configs/xilinx-ppc440-generic.h +++ b/include/configs/xilinx-ppc440-generic.h @@ -24,7 +24,6 @@ #define CONFIG_ENV_ADDR (XPAR_FLASH_MEM0_BASEADDR+CONFIG_ENV_OFFSET)
/*Misc*/ -#define CONFIG_SYS_PROMPT "board:/# " /* Monitor Command Prompt */ #define CONFIG_PREBOOT "echo U-Boot is up and runnining;"
/*Flash*/ diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 68853b6..01b7993 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -131,7 +131,6 @@ /* Monitor Command Prompt */ /* Console I/O Buffer Size */ #define CONFIG_SYS_CBSIZE 2048 -#define CONFIG_SYS_PROMPT "ZynqMP> " #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_HUSH_PARSER diff --git a/include/configs/zipitz2.h b/include/configs/zipitz2.h index cff3ba8..0199190 100644 --- a/include/configs/zipitz2.h +++ b/include/configs/zipitz2.h @@ -119,9 +119,6 @@ unsigned char zipitz2_spi_read(void); #define CONFIG_SYS_HUSH_PARSER 1
#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#ifdef CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT "$ " /* Monitor Command Prompt */ -#endif #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ diff --git a/include/configs/zmx25.h b/include/configs/zmx25.h index af7cc49..81b9ce4 100644 --- a/include/configs/zmx25.h +++ b/include/configs/zmx25.h @@ -138,7 +138,6 @@ #define CONFIG_SYS_MEMTEST_START (PHYS_SDRAM + (512*1024)) #define CONFIG_SYS_MEMTEST_END (PHYS_SDRAM + PHYS_SDRAM_SIZE)
-#define CONFIG_SYS_PROMPT "zmx25> " #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 98bebd0..cc72c86 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -235,7 +235,6 @@ #define CONFIG_SYS_LOAD_ADDR 0 /* default? */
/* Miscellaneous configurable options */ -#define CONFIG_SYS_PROMPT "zynq-uboot> " #define CONFIG_SYS_HUSH_PARSER
On Mon, Aug 03, 2015 at 12:36:58PM +0300, Nikita Kiryanov wrote:
Add option to set shell prompt string from menuconfig and migrate boards globally.
The migration is done as follows:
- Boards that explicitly and unconditionally set CONFIG_SYS_PROMPT had the entry moved to their defconfig files.
- Boards that defined some kind of #ifdef logic which selects the CONFIG_SYS_PROMPT (for example qemu-mips) got an #undef CONFIG_SYS_PROMPT right before the #ifdef logic and were left alone.
- This change forces CONFIG_SYS_PROMPT to be a per board decision, and thus CONFIG_SYS_PROMPT was removed from all <soc>_common.h and <arch>_common.h files. This results in a streamlined default value across platforms, and includes the following files: spear-common, sunxi-common, mv-common, ti_armv7_common, tegra-common, at91-sama5_common, and zynq-common.
- Boards that relied on <arch/soc>_common.h values of CONFIG_SYS_PROMPT were not updated in their respective defconfig files under the assumption that since they did not explicitly define a value, they're fine with whatever the default is.
- On the other hand, boards that relied on a value defined in some <boards>_common.h file such as woodburn_common, rpi-common, bur_am335x_common, ls2085a_common, siemens_am33x_common, and omap3_evm_common, had their values moved to the respective defconfig files.
- The define V_PROMPT was removed, since it is not used anywhere except for assigning a value for CONFIG_SYS_PROMPT.
Cc: Tom Rini trini@konsulko.com Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Stefano Babic sbabic@denx.de Cc: Igor Grinberg grinberg@compulab.co.il Signed-off-by: Nikita Kiryanov nikita@compulab.co.il
Tom,
Looks like an extra file was committed during the merge
include/configs/odroid_xu3.h.rej
York
Tom,
Thanks, I'll push a delete with my next changes.
Tom,
Tom,
Yes, I had already posted a patch to delete it CCing you. I have not seen it on Patchwork though. I do not know why..
Masahiro
Nikita Kiryanov
York Sun
