[PATCH] arm: socfpga: soc64: Remove PHY interface setup from misc arch init
'dwmac_socfpga' driver will setup the PHY interface during probe. PHY interface setup in arch_misc_init() is no longer needed.
Signed-off-by: Chee Hong Ang chee.hong.ang@intel.com --- arch/arm/mach-socfpga/misc_s10.c | 84 +------------------------------- 1 file changed, 1 insertion(+), 83 deletions(-)
diff --git a/arch/arm/mach-socfpga/misc_s10.c b/arch/arm/mach-socfpga/misc_s10.c index 670bfa1a31..77c2b7764e 100644 --- a/arch/arm/mach-socfpga/misc_s10.c +++ b/arch/arm/mach-socfpga/misc_s10.c @@ -8,20 +8,12 @@ #include <common.h> #include <env.h> #include <errno.h> -#include <fdtdec.h> #include <init.h> #include <log.h> -#include <miiphy.h> -#include <netdev.h> #include <asm/io.h> -#include <asm/arch/reset_manager.h> -#include <asm/arch/system_manager.h> #include <asm/arch/misc.h> -#include <asm/pl310.h> -#include <linux/libfdt.h> #include <asm/arch/mailbox_s10.h> - -#include <dt-bindings/reset/altr,rst-mgr-s10.h> +#include <asm/arch/reset_manager.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -45,79 +37,6 @@ static Altera_desc altera_fpga[] = { }, };
-/* - * DesignWare Ethernet initialization - */ -#ifdef CONFIG_ETH_DESIGNWARE - -static u32 socfpga_phymode_setup(u32 gmac_index, const char *phymode) -{ - u32 modereg; - - if (!phymode) - return -EINVAL; - - if (!strcmp(phymode, "mii") || !strcmp(phymode, "gmii") || - !strcmp(phymode, "sgmii")) - modereg = SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_GMII_MII; - else if (!strcmp(phymode, "rgmii")) - modereg = SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_RGMII; - else if (!strcmp(phymode, "rmii")) - modereg = SYSMGR_EMACGRP_CTRL_PHYSEL_ENUM_RMII; - else - return -EINVAL; - - clrsetbits_le32(socfpga_get_sysmgr_addr() + SYSMGR_SOC64_EMAC0 + - (gmac_index * sizeof(u32)), - SYSMGR_EMACGRP_CTRL_PHYSEL_MASK, modereg); - - return 0; -} - -static int socfpga_set_phymode(void) -{ - const void *fdt = gd->fdt_blob; - struct fdtdec_phandle_args args; - const char *phy_mode; - u32 gmac_index; - int nodes[3]; /* Max. 3 GMACs */ - int ret, count; - int i, node; - - count = fdtdec_find_aliases_for_id(fdt, "ethernet", - COMPAT_ALTERA_SOCFPGA_DWMAC, - nodes, ARRAY_SIZE(nodes)); - for (i = 0; i < count; i++) { - node = nodes[i]; - if (node <= 0) - continue; - - ret = fdtdec_parse_phandle_with_args(fdt, node, "resets", - "#reset-cells", 1, 0, - &args); - if (ret || args.args_count != 1) { - debug("GMAC%i: Failed to parse DT 'resets'!\n", i); - continue; - } - - gmac_index = args.args[0] - EMAC0_RESET; - - phy_mode = fdt_getprop(fdt, node, "phy-mode", NULL); - ret = socfpga_phymode_setup(gmac_index, phy_mode); - if (ret) { - debug("GMAC%i: Failed to parse DT 'phy-mode'!\n", i); - continue; - } - } - - return 0; -} -#else -static int socfpga_set_phymode(void) -{ - return 0; -}; -#endif
/* * Print CPU information @@ -139,7 +58,6 @@ int arch_misc_init(void) sprintf(qspi_string, "<0x%08x>", cm_get_qspi_controller_clk_hz()); env_set("qspi_clock", qspi_string);
- socfpga_set_phymode(); return 0; } #endif
-----Original Message----- From: Ang, Chee Hong chee.hong.ang@intel.com Sent: Friday, July 10, 2020 11:53 PM To: u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; See, Chin Liang chin.liang.see@intel.com; Tan, Ley Foon ley.foon.tan@intel.com; Ang, Chee Hong chee.hong.ang@intel.com Subject: [PATCH] arm: socfpga: soc64: Remove PHY interface setup from misc arch init
Reviewed-by: Ley Foon Tan ley.foon.tan@intel.com
Chee Hong Ang
Tan, Ley Foon
