[U-Boot] Please pull u-boot-ti/master
Hello,
The following changes since commit 39826f09978a0a7070999acc15babf88f03e4051:
arm: fdt: Relocate fdt along with other data (2012-10-19 21:38:27 +0200)
git://git.denx.de/u-boot-ti.git master
for you to fetch changes up to c7d35bef255dedb3ec3856982f042dde514676b0:
am33xx/ddr_defs.h: rename DDR2/DDR3 defines to their actual part numbers (2012-10-25 11:31:38 -0700)
---------------------------------------------------------------- Andrew Bradford (1): configs: Fix usage of mmc rescan
Igor Grinberg (1): cm-t35: clean unused defines from config
Joel A Fernandes (1): am33xx: Enable DDR3 for DDR3 version of beaglebone
Pankaj Bharadiya (1): USB: musb_udc: Make musb_peri_rx_ep check for MUSB_RXCSR_RXPKTRDY
Peter Korsgaard (7): omap3_spi: introduce CONFIG_OMAP3_SPI_D0_D1_SWAPPED am33xx/board.c: make wdtimer/uart_base static am33xx: move ti i2c baseboard header handling to board/ti/am335x/ am33xx/board: use cpu_mmc_init() for default mmc initialization am33xx: move generic parts of pinmux handling out from board/ti/am335x am33xx: support board specific ddr settings am33xx/ddr_defs.h: rename DDR2/DDR3 defines to their actual part numbers
Stefano Babic (5): OMAP3: mt_ventoux: power on USB at startup OMAP3: updated pinmux and environment for new revision of mcx board OMAP3: mcx: updated to new hardware revision VIDEO: add macro to set LCD size for DSS driver OMAP3: add video support to the mcx board
Tom Rini (2): omapimage: Add support for byteswapped SPI images am33xx: Add SPI SPL as an option
Vaibhav Hiremath (1): am335x: Enable RTC 32K OSC clock
arch/arm/cpu/armv7/am33xx/Makefile | 1 + arch/arm/cpu/armv7/am33xx/board.c | 239 +--------------- arch/arm/cpu/armv7/am33xx/clock.c | 6 + arch/arm/cpu/armv7/am33xx/config.mk | 1 + arch/arm/cpu/armv7/am33xx/emif4.c | 114 +------- arch/arm/cpu/armv7/am33xx/mux.c | 33 +++ arch/arm/include/asm/arch-am33xx/cpu.h | 15 + arch/arm/include/asm/arch-am33xx/ddr_defs.h | 69 ++--- arch/arm/include/asm/arch-am33xx/hardware.h | 4 + arch/arm/include/asm/arch-am33xx/mux.h | 261 ++++++++++++++++++ arch/arm/include/asm/arch-am33xx/spl.h | 1 + arch/arm/include/asm/arch-am33xx/sys_proto.h | 27 -- arch/arm/include/asm/arch-omap3/dss.h | 1 + board/htkw/mcx/mcx.c | 48 +++- board/htkw/mcx/mcx.h | 30 +- board/teejet/mt_ventoux/mt_ventoux.c | 8 + board/ti/am335x/Makefile | 1 + board/ti/am335x/board.c | 376 ++++++++++++++++++++++++++ board/ti/am335x/board.h | 49 ++++ board/ti/am335x/mux.c | 250 +---------------- drivers/spi/omap3_spi.c | 11 +- drivers/usb/musb/musb_udc.c | 11 +- include/configs/am335x_evm.h | 9 +- include/configs/am3517_crane.h | 2 +- include/configs/am3517_evm.h | 2 +- include/configs/cm_t35.h | 14 +- include/configs/devkit8000.h | 2 +- include/configs/igep00x0.h | 2 +- include/configs/mcx.h | 31 ++- include/configs/mx28evk.h | 2 +- include/configs/mx51evk.h | 2 +- include/configs/mx53ard.h | 2 +- include/configs/mx53evk.h | 2 +- include/configs/mx53loco.h | 2 +- include/configs/mx53smd.h | 2 +- include/configs/mx6qarm2.h | 2 +- include/configs/mx6qsabrelite.h | 2 +- include/configs/omap3_beagle.h | 2 +- include/configs/omap3_evm.h | 2 +- include/configs/omap3_logic.h | 2 +- include/configs/omap3_overo.h | 2 +- include/configs/omap3_zoom1.h | 2 +- include/configs/omap4_common.h | 2 +- include/configs/omap5_evm.h | 2 +- include/configs/tricorder.h | 2 +- spl/Makefile | 9 +- tools/omapimage.c | 83 ++++-- 47 files changed, 998 insertions(+), 744 deletions(-) create mode 100644 arch/arm/cpu/armv7/am33xx/mux.c create mode 100644 arch/arm/include/asm/arch-am33xx/mux.h create mode 100644 board/ti/am335x/board.c create mode 100644 board/ti/am335x/board.h
Thanks!
Hi Tom,
On Thu, 25 Oct 2012 11:49:22 -0700, Tom Rini trini@ti.com wrote:
Hello,
Thanks!
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
