imx8mm-evk does not boot kernel 5.16
I am able to boot Linux 5.15.14 on an imx8mm-evk running U-Boot 2022.01 just fine.
However, if I try to boot a 5.16 kernel, the boot fails in most of the attempts (like in 80% of the boots. It does boot completely in some of the attempts).
Starting kernel ... (hangs here)
Using earlycon I see that it hangs around the imx-sdma driver load: [ 0.681930] imx-sdma 302c0000.dma-controller: Direct firmware load for imx/sdma/sdma-imx7d.bin failed with error -2 [ 0.689628] imx-sdma 302c0000.dma-controller: external firmware not found, using ROM firmware [ 0.689635] imx-sdma 302b0000.dma-controller: external firmware not found, using ROM firmware
Tried to disable the imx-sdma driver and the hang also happens, so it is something else that causes the hang.
If I use U-Boot from NXP the problem does not happen.
I tried to select the imx8m power domain options:
--- a/configs/imx8mm_evk_defconfig +++ b/configs/imx8mm_evk_defconfig @@ -72,6 +72,8 @@ CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_IMX8M=y +CONFIG_POWER_DOMAIN=y +CONFIG_IMX8M_POWER_DOMAIN=y CONFIG_DM_PMIC=y CONFIG_SPL_DM_PMIC_PCA9450=y CONFIG_DM_REGULATOR=y
but it did not help.
The same behavior is seen with the top of tree U-Boot.
Does anyone have any ideas as to what is missing?
Thanks,
Fabio Estevam
Hi Fabio
Strange, remember, I am working on Verdin iMX8M Mini support [1] and run that stuff more or less daily. However, as you can see in that patch series, I build the imx-sdma driver now as a module just like already merged for imx_v6_v7_defconfig. As I also do have an imx8mm-evk laying around somewhere I can give that a try as well. I keep you posted...
[1] https://lore.kernel.org/lkml/20220114141507.395271-1-marcel@ziswiler.com/
Thanks,
Fabio Estevam
Cheers
Marcel
Hi Marcel,
On Fri, Jan 14, 2022 at 3:10 PM Marcel Ziswiler marcel.ziswiler@toradex.com wrote:
Just noticed that when using the TF-A from NXP: imx-atf branch: imx_5.4.47_2.2.0 the 5.16 kernel boots fine.
When using the mainline TF-A (v2.5 or v2.6) the board hangs with 5.16
Thanks
Hi Fabio
On Fri, 2022-01-14 at 16:44 -0300, Fabio Estevam wrote:
Hi Marcel,
I am always using imx_5.4.47_2.3.0 resp. for our board our fork thereof which defaults to a different UART.
I have to admit that I never tried mainline TF-A so far.
Thanks
Thank you.
Cheers
Marcel
On 14.01.22 20:44, Fabio Estevam wrote:
Hi Marcel,
I remember having lockup issues with the mainline TF-A and i.MX8MM when it came to power domain handling (with older kernels and preliminary power domain support). I never tracked this down, but switched to the NXP TF-A for the time being.
IIRC the mainline TF-A doesn't enable the USB power domains per default, while the NXP TF-A does and there are probably other differences. With the latest GPCv2 and BLK-CTRL code in the kernel it should work either way, but there still might be some unresolved problems.
On Fri, Jan 14, 2022 at 11:44 AM Fabio Estevam festevam@gmail.com wrote:
Hi Marcel,
Interesting. Can you give us a breakdown of pros and cons of using mainline TF-A vs NXP's? I'm not clear if NXP has been actively pushing their changes up or not and haven't had time to follow the commits for either project.
Tim
Hi Tim,
I am not following TF-A i.MX development in upstream, so I cannot comment myself.
Added Jacky on Cc, who is involved with i.MX TF-A development and could probably explain.
Subject: Re: imx8mm-evk does not boot kernel 5.16
Hi Tim,
I will check what's wrong, the mainline TF-A should work before. Although there's some code gap between downstream vs upstream, the basic function should be ok before, and some community guys have used it for their project for a while.
BR Jacky Bai
participants (5)
Fabio Estevam
Frieder Schrempf
Jacky Bai
Marcel Ziswiler
Tim Harvey
