[U-Boot] [GIT PULL] Pull request: u-boot-imx
Hi Wolfgang,
please pull from u-boot-imx.
The following changes since commit 2e6e1772c0e34871769be4aef79748fe3e47d953: Wolfgang Denk (1): Merge branch 'next' of /home/wd/git/u-boot/next
git://git.denx.de/u-boot-imx master
Stefano Babic (10): Use common function to set GPIOs for MX3 and MX5 ARM: Use syslib functions for all CORTEXA8 MX51: Added pins definition to set up pads MX51: add structure to access System Reset Controller MXC: Add watchdog support to serial driver MX51: Drop unused header file for mx51evk MXC: Correct SPI_CPOL setting in SPI driver MXC: Fix byte-ordering in SPI driver for i.MX31/i.MX51 MX51: Register definitions cannot be included in board config file MX51: Support for TTECH vision2 board
MAINTAINERS | 1 + arch/arm/cpu/armv7/Makefile | 3 +- arch/arm/cpu/armv7/omap-common/Makefile | 1 - arch/arm/cpu/armv7/{omap-common => }/syslib.c | 0 arch/arm/include/asm/arch-mx31/mx31-regs.h | 14 +- arch/arm/include/asm/arch-mx31/mx31.h | 25 - arch/arm/include/asm/arch-mx51/imx-regs.h | 26 +- arch/arm/include/asm/arch-mx51/mx51_pins.h | 44 ++ arch/arm/include/asm/arch-mx51/sys_proto.h | 1 + board/davedenx/qong/qong.c | 29 +- board/freescale/mx51evk/mx51evk.c | 2 - board/ttcontrol/vision2/Makefile | 48 ++ board/ttcontrol/vision2/config.mk | 25 + board/ttcontrol/vision2/imximage_hynix.cfg | 209 ++++++ board/ttcontrol/vision2/vision2.c | 711 ++++++++++++++++++++ boards.cfg | 1 + drivers/gpio/Makefile | 2 +- drivers/gpio/{mx31_gpio.c => mxc_gpio.c} | 47 +- drivers/misc/fsl_pmic.c | 10 +- drivers/serial/serial_mxc.c | 7 +- drivers/spi/mxc_spi.c | 168 ++++-- include/configs/imx31_litekit.h | 4 +- include/configs/imx31_phycore.h | 2 +- include/configs/mx31ads.h | 4 +- include/configs/mx31pdk.h | 4 +- include/configs/mx51evk.h | 2 +- include/configs/qong.h | 6 +- include/configs/vision2.h | 214 ++++++ include/mc13892.h | 3 + .../mx51evk/mx51evk.h => include/mxc_gpio.h | 50 +- 30 files changed, 1510 insertions(+), 153 deletions(-) rename arch/arm/cpu/armv7/{omap-common => }/syslib.c (100%) create mode 100644 board/ttcontrol/vision2/Makefile create mode 100644 board/ttcontrol/vision2/config.mk create mode 100644 board/ttcontrol/vision2/imximage_hynix.cfg create mode 100644 board/ttcontrol/vision2/vision2.c rename drivers/gpio/{mx31_gpio.c => mxc_gpio.c} (63%) create mode 100644 include/configs/vision2.h rename board/freescale/mx51evk/mx51evk.h => include/mxc_gpio.h (54%)
Dear Stefano Babic,
In message 4CAD8492.3000702@denx.de you wrote:
Hi Wolfgang,
Applied, thanks.
Stefano Babic
