[PATCH 1/2] udoo_neo: Move to DM for REGUALTOR/PMIC/I2C drivers
This moves over the PMIC power init to DM and the associated i2c and regulator bits.
Signed-off-by: Peter Robinson pbrobinson@gmail.com ---
Rebase this and I think I've fixed the previous build error reported by Stefano.
board/udoo/neo/neo.c | 139 +++---------------------------------- configs/udoo_neo_defconfig | 10 +-- include/configs/udoo_neo.h | 5 -- 3 files changed, 15 insertions(+), 139 deletions(-)
diff --git a/board/udoo/neo/neo.c b/board/udoo/neo/neo.c index 5e40583ab43..9e2a66996c4 100644 --- a/board/udoo/neo/neo.c +++ b/board/udoo/neo/neo.c @@ -51,11 +51,6 @@ enum { PAD_CTL_PUS_22K_UP | PAD_CTL_SPEED_LOW | \ PAD_CTL_DSE_80ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
-#define I2C_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ - PAD_CTL_ODE) - #define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | PAD_CTL_PUE | \ PAD_CTL_SPEED_MED | \ PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) @@ -83,135 +78,25 @@ int dram_init(void) return 0; }
-#ifdef CONFIG_SYS_I2C_MXC -#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) -/* I2C1 for PMIC */ -static struct i2c_pads_info i2c_pad_info1 = { - .scl = { - .i2c_mode = MX6_PAD_GPIO1_IO00__I2C1_SCL | PC, - .gpio_mode = MX6_PAD_GPIO1_IO00__GPIO1_IO_0 | PC, - .gp = IMX_GPIO_NR(1, 0), - }, - .sda = { - .i2c_mode = MX6_PAD_GPIO1_IO01__I2C1_SDA | PC, - .gpio_mode = MX6_PAD_GPIO1_IO01__GPIO1_IO_1 | PC, - .gp = IMX_GPIO_NR(1, 1), - }, -}; -#endif - -#if CONFIG_IS_ENABLED(POWER_LEGACY) int power_init_board(void) { - struct pmic *p; - int ret; - unsigned int reg, rev_id; - - ret = power_pfuze3000_init(PFUZE3000_I2C_BUS); - if (ret) - return ret; - - p = pmic_get("PFUZE3000"); - ret = pmic_probe(p); - if (ret) - return ret; + struct udevice *dev; + int ret, dev_id, rev_id;
- pmic_reg_read(p, PFUZE3000_DEVICEID, ®); - pmic_reg_read(p, PFUZE3000_REVID, &rev_id); - printf("PMIC: PFUZE3000 DEV_ID=0x%x REV_ID=0x%x\n", reg, rev_id); - - /* disable Low Power Mode during standby mode */ - pmic_reg_read(p, PFUZE3000_LDOGCTL, ®); - reg |= 0x1; - ret = pmic_reg_write(p, PFUZE3000_LDOGCTL, reg); - if (ret) + ret = pmic_get("pfuze3000@8", &dev); + if (ret == -ENODEV) + return 0; + if (ret != 0) return ret;
- ret = pmic_reg_write(p, PFUZE3000_SW1AMODE, 0xc); - if (ret) - return ret; + dev_id = pmic_reg_read(dev, PFUZE3000_DEVICEID); + rev_id = pmic_reg_read(dev, PFUZE3000_REVID); + printf("PMIC: PFUZE3000 DEV_ID=0x%x REV_ID=0x%x\n", dev_id, rev_id);
- ret = pmic_reg_write(p, PFUZE3000_SW1BMODE, 0xc); - if (ret) - return ret; - - ret = pmic_reg_write(p, PFUZE3000_SW2MODE, 0xc); - if (ret) - return ret; - - ret = pmic_reg_write(p, PFUZE3000_SW3MODE, 0xc); - if (ret) - return ret; - - /* set SW1A standby voltage 0.975V */ - pmic_reg_read(p, PFUZE3000_SW1ASTBY, ®); - reg &= ~0x3f; - reg |= PFUZE3000_SW1AB_SETP(9750); - ret = pmic_reg_write(p, PFUZE3000_SW1ASTBY, reg); - if (ret) - return ret; - - /* set SW1B standby voltage 0.975V */ - pmic_reg_read(p, PFUZE3000_SW1BSTBY, ®); - reg &= ~0x3f; - reg |= PFUZE3000_SW1AB_SETP(9750); - ret = pmic_reg_write(p, PFUZE3000_SW1BSTBY, reg); - if (ret) - return ret; - - /* set SW1A/VDD_ARM_IN step ramp up time from 16us to 4us/25mV */ - pmic_reg_read(p, PFUZE3000_SW1ACONF, ®); - reg &= ~0xc0; - reg |= 0x40; - ret = pmic_reg_write(p, PFUZE3000_SW1ACONF, reg); - if (ret) - return ret; - - /* set SW1B/VDD_SOC_IN step ramp up time from 16us to 4us/25mV */ - pmic_reg_read(p, PFUZE3000_SW1BCONF, ®); - reg &= ~0xc0; - reg |= 0x40; - ret = pmic_reg_write(p, PFUZE3000_SW1BCONF, reg); - if (ret) - return ret; - - /* set VDD_ARM_IN to 1.350V */ - pmic_reg_read(p, PFUZE3000_SW1AVOLT, ®); - reg &= ~0x3f; - reg |= PFUZE3000_SW1AB_SETP(13500); - ret = pmic_reg_write(p, PFUZE3000_SW1AVOLT, reg); - if (ret) - return ret; - - /* set VDD_SOC_IN to 1.350V */ - pmic_reg_read(p, PFUZE3000_SW1BVOLT, ®); - reg &= ~0x3f; - reg |= PFUZE3000_SW1AB_SETP(13500); - ret = pmic_reg_write(p, PFUZE3000_SW1BVOLT, reg); - if (ret) - return ret; - - /* set DDR_1_5V to 1.350V */ - pmic_reg_read(p, PFUZE3000_SW3VOLT, ®); - reg &= ~0x0f; - reg |= PFUZE3000_SW3_SETP(13500); - ret = pmic_reg_write(p, PFUZE3000_SW3VOLT, reg); - if (ret) - return ret; - - /* set VGEN2_1V5 to 1.5V */ - pmic_reg_read(p, PFUZE3000_VLDO2CTL, ®); - reg &= ~0x0f; - reg |= PFUZE3000_VLDO_SETP(15000); - /* enable */ - reg |= 0x10; - ret = pmic_reg_write(p, PFUZE3000_VLDO2CTL, reg); - if (ret) - return ret; + pmic_clrsetbits(dev, PFUZE3000_LDOGCTL, 0, 1);
return 0; } -#endif
static iomux_v3_cfg_t const uart1_pads[] = { MX6_PAD_GPIO1_IO04__UART1_TX | MUX_PAD_CTRL(UART_PAD_CTRL), @@ -294,10 +179,6 @@ int board_init(void) gpio_request(IMX_GPIO_NR(4, 16), "ncp692"); gpio_direction_output(IMX_GPIO_NR(4, 16) , 1);
-#ifdef CONFIG_SYS_I2C_MXC - setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); -#endif - setup_fec();
return 0; diff --git a/configs/udoo_neo_defconfig b/configs/udoo_neo_defconfig index 8ae9fa57f03..6c29f8fd251 100644 --- a/configs/udoo_neo_defconfig +++ b/configs/udoo_neo_defconfig @@ -10,8 +10,9 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x80000 CONFIG_MX6SX=y CONFIG_TARGET_UDOO_NEO=y -CONFIG_SYS_I2C_MXC_I2C1=y +CONFIG_DM_I2C=y CONFIG_DM_GPIO=y +CONFIG_DM_MMC=y CONFIG_DEFAULT_DEVICE_TREE="imx6sx-udoo-neo-basic" CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_SPL_MMC=y @@ -43,8 +44,6 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_DEV=1 CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_BOUNCE_BUFFER=y -CONFIG_SYS_I2C_LEGACY=y -CONFIG_SPL_SYS_I2C_LEGACY=y CONFIG_SYS_I2C_MXC=y CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y @@ -55,11 +54,12 @@ CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y -CONFIG_POWER_LEGACY=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PFUZE100=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_ANATOP=y -CONFIG_POWER_I2C=y +CONFIG_DM_REGULATOR_PFUZE100=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y diff --git a/include/configs/udoo_neo.h b/include/configs/udoo_neo.h index e30b6cc82d8..9ab64a6b0f3 100644 --- a/include/configs/udoo_neo.h +++ b/include/configs/udoo_neo.h @@ -63,9 +63,4 @@ #define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR #define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE
-/* PMIC */ -#define CONFIG_POWER_PFUZE3000 -#define CONFIG_POWER_PFUZE3000_I2C_ADDR 0x08 -#define PFUZE3000_I2C_BUS 0 - #endif /* __CONFIG_H */
The conversion to DM_SERIAL is mandatory, so select this option.
Signed-off-by: Peter Robinson pbrobinson@gmail.com --- configs/udoo_neo_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/udoo_neo_defconfig b/configs/udoo_neo_defconfig index 6c29f8fd251..0c60e4a6f4a 100644 --- a/configs/udoo_neo_defconfig +++ b/configs/udoo_neo_defconfig @@ -60,6 +60,7 @@ CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_ANATOP=y CONFIG_DM_REGULATOR_PFUZE100=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y
After converting it to DM_SERIAL, the setup_iomux_uart() could be removed.
With that removed:
Reviewed-by: Fabio Estevam festevam@denx.de
With that removed:
Yes, I realised that, I was going to do a follow up patch like some of the other conversions I'd seen, but I'm reviewing a few other bits while I'm at it.
It is OK to do that on incremental patches, thanks.
Hi Peter,
There is a typo in the Subject line: s/REGUALTOR/REGULATOR
CONFIG_DM_MMC is selected by default. No need to have it in the defconfig.
On Mon, 14 Nov 2022 at 10:32, Fabio Estevam festevam@gmail.com wrote:
Hi Peter,
Would be good to fix REGUALTOR when applying
Hi Peter,
Was fixed in a v2 with other bits.
Fabio Estevam
Peter Robinson
