[U-Boot] [PATCH] ppc4xx: Cleanup PPC4xx I2C infrastructure
This patch cleans up the PPC4xx I2C intrastructure:
- Use C struct to describe the I2C registers instead of defines - Coding style cleanup (braces, whitespace, comments, line length) - Extract common code from i2c_read() and i2c_write() - Remove unneeded IIC defines from ppc405.h & ppc440.h
Signed-off-by: Stefan Roese sr@denx.de --- cpu/ppc4xx/i2c.c | 199 ++++++++++++++++++++++++++--------------------------- include/4xx_i2c.h | 38 ++++++----- include/ppc405.h | 19 ----- include/ppc440.h | 19 ----- 4 files changed, 118 insertions(+), 157 deletions(-)
diff --git a/cpu/ppc4xx/i2c.c b/cpu/ppc4xx/i2c.c index e3e1bab..7976e75 100644 --- a/cpu/ppc4xx/i2c.c +++ b/cpu/ppc4xx/i2c.c @@ -1,5 +1,5 @@ /* - * (C) Copyright 2007 + * (C) Copyright 2007-2009 * Stefan Roese, DENX Software Engineering, sr@denx.de. * * based on work by Anne Sophie Harnois anne-sophie.harnois@nextream.fr @@ -37,7 +37,8 @@ DECLARE_GLOBAL_DATA_PTR;
#if defined(CONFIG_I2C_MULTI_BUS) -/* Initialize the bus pointer to whatever one the SPD EEPROM is on. +/* + * Initialize the bus pointer to whatever one the SPD EEPROM is on. * Default is bus 0. This is necessary because the DDR initialization * runs from ROM, and we can't switch buses because we can't modify * the global variables. @@ -45,59 +46,63 @@ DECLARE_GLOBAL_DATA_PTR; #ifndef CONFIG_SYS_SPD_BUS_NUM #define CONFIG_SYS_SPD_BUS_NUM 0 #endif -static unsigned int i2c_bus_num __attribute__ ((section (".data"))) = CONFIG_SYS_SPD_BUS_NUM; +static unsigned int i2c_bus_num __attribute__ ((section (".data"))) = + CONFIG_SYS_SPD_BUS_NUM; #endif /* CONFIG_I2C_MULTI_BUS */
static void _i2c_bus_reset(void) { + struct ppc4xx_i2c *i2c = (struct ppc4xx_i2c *)I2C_BASE_ADDR; int i; u8 dc;
/* Reset status register */ /* write 1 in SCMP and IRQA to clear these fields */ - out_8((u8 *)IIC_STS, 0x0A); + out_8(&i2c->sts, 0x0A);
/* write 1 in IRQP IRQD LA ICT XFRA to clear these fields */ - out_8((u8 *)IIC_EXTSTS, 0x8F); + out_8(&i2c->extsts, 0x8F);
/* Place chip in the reset state */ - out_8((u8 *)IIC_XTCNTLSS, IIC_XTCNTLSS_SRST); + out_8(&i2c->xtcntlss, IIC_XTCNTLSS_SRST);
/* Check if bus is free */ - dc = in_8((u8 *)IIC_DIRECTCNTL); + dc = in_8(&i2c->directcntl); if (!DIRCTNL_FREE(dc)){ /* Try to set bus free state */ - out_8((u8 *)IIC_DIRECTCNTL, IIC_DIRCNTL_SDAC | IIC_DIRCNTL_SCC); + out_8(&i2c->directcntl, IIC_DIRCNTL_SDAC | IIC_DIRCNTL_SCC);
/* Wait until we regain bus control */ for (i = 0; i < 100; ++i) { - dc = in_8((u8 *)IIC_DIRECTCNTL); + dc = in_8(&i2c->directcntl); if (DIRCTNL_FREE(dc)) break;
/* Toggle SCL line */ dc ^= IIC_DIRCNTL_SCC; - out_8((u8 *)IIC_DIRECTCNTL, dc); + out_8(&i2c->directcntl, dc); udelay(10); dc ^= IIC_DIRCNTL_SCC; - out_8((u8 *)IIC_DIRECTCNTL, dc); + out_8(&i2c->directcntl, dc); } }
/* Remove reset */ - out_8((u8 *)IIC_XTCNTLSS, 0); + out_8(&i2c->xtcntlss, 0); }
-void i2c_init(int speed, int slaveadd) +void i2c_init(int speed, int slaveaddr) { - unsigned long freqOPB; + struct ppc4xx_i2c *i2c = (struct ppc4xx_i2c *)I2C_BASE_ADDR; int val, divisor; int bus;
#ifdef CONFIG_SYS_I2C_INIT_BOARD - /* call board specific i2c bus reset routine before accessing the */ - /* environment, which might be in a chip on that bus. For details */ - /* about this problem see doc/I2C_Edge_Conditions. */ + /* + * Call board specific i2c bus reset routine before accessing the + * environment, which might be in a chip on that bus. For details + * about this problem see doc/I2C_Edge_Conditions. + */ i2c_init_board(); #endif
@@ -109,54 +114,52 @@ void i2c_init(int speed, int slaveadd) _i2c_bus_reset();
/* clear lo master address */ - out_8((u8 *)IIC_LMADR, 0); + out_8(&i2c->lmadr, 0);
/* clear hi master address */ - out_8((u8 *)IIC_HMADR, 0); + out_8(&i2c->hmadr, 0);
/* clear lo slave address */ - out_8((u8 *)IIC_LSADR, 0); + out_8(&i2c->lsadr, 0);
/* clear hi slave address */ - out_8((u8 *)IIC_HSADR, 0); + out_8(&i2c->hsadr, 0);
/* Clock divide Register */ - /* get OPB frequency */ - freqOPB = get_OPB_freq(); - /* set divisor according to freqOPB */ - divisor = (freqOPB - 1) / 10000000; + /* set divisor according to freq_opb */ + divisor = (get_OPB_freq() - 1) / 10000000; if (divisor == 0) divisor = 1; - out_8((u8 *)IIC_CLKDIV, divisor); + out_8(&i2c->clkdiv, divisor);
/* no interrupts */ - out_8((u8 *)IIC_INTRMSK, 0); + out_8(&i2c->intrmsk, 0);
/* clear transfer count */ - out_8((u8 *)IIC_XFRCNT, 0); + out_8(&i2c->xfrcnt, 0);
/* clear extended control & stat */ /* write 1 in SRC SRS SWC SWS to clear these fields */ - out_8((u8 *)IIC_XTCNTLSS, 0xF0); + out_8(&i2c->xtcntlss, 0xF0);
/* Mode Control Register Flush Slave/Master data buffer */ - out_8((u8 *)IIC_MDCNTL, IIC_MDCNTL_FSDB | IIC_MDCNTL_FMDB); + out_8(&i2c->mdcntl, IIC_MDCNTL_FSDB | IIC_MDCNTL_FMDB);
- val = in_8((u8 *)IIC_MDCNTL); + val = in_8(&i2c->mdcntl);
/* Ignore General Call, slave transfers are ignored, * disable interrupts, exit unknown bus state, enable hold * SCL 100kHz normaly or FastMode for 400kHz and above */
- val |= IIC_MDCNTL_EUBS|IIC_MDCNTL_HSCL; + val |= IIC_MDCNTL_EUBS | IIC_MDCNTL_HSCL; if (speed >= 400000) val |= IIC_MDCNTL_FSM; - out_8((u8 *)IIC_MDCNTL, val); + out_8(&i2c->mdcntl, val);
/* clear control reg */ - out_8((u8 *)IIC_CNTL, 0x00); + out_8(&i2c->cntl, 0x00); }
/* set to SPD bus as default bus upon powerup */ @@ -195,13 +198,14 @@ static int i2c_transfer(unsigned char cmd_type, unsigned char data[], unsigned short data_len) { - unsigned char* ptr; + struct ppc4xx_i2c *i2c = (struct ppc4xx_i2c *)I2C_BASE_ADDR; + u8 *ptr; int reading; - int tran,cnt; + int tran, cnt; int result; int status; int i; - uchar creg; + u8 creg;
if (data == 0 || data_len == 0) { /* Don't support data transfer of no length or to address 0 */ @@ -219,12 +223,13 @@ static int i2c_transfer(unsigned char cmd_type, }
/* Clear Stop Complete Bit */ - out_8((u8 *)IIC_STS, IIC_STS_SCMP); + out_8(&i2c->sts, IIC_STS_SCMP); + /* Check init */ i = 10; do { /* Get status */ - status = in_8((u8 *)IIC_STS); + status = in_8(&i2c->sts); i--; } while ((status & IIC_STS_PT) && (i > 0));
@@ -232,13 +237,16 @@ static int i2c_transfer(unsigned char cmd_type, result = IIC_NOK_TOUT; return(result); } + /* flush the Master/Slave Databuffers */ - out_8((u8 *)IIC_MDCNTL, ((in_8((u8 *)IIC_MDCNTL))|IIC_MDCNTL_FMDB|IIC_MDCNTL_FSDB)); + out_8(&i2c->mdcntl, in_8(&i2c->mdcntl) | + IIC_MDCNTL_FMDB | IIC_MDCNTL_FSDB); + /* need to wait 4 OPB clocks? code below should take that long */
/* 7-bit adressing */ - out_8((u8 *)IIC_HMADR, 0); - out_8((u8 *)IIC_LMADR, chip); + out_8(&i2c->hmadr, 0); + out_8(&i2c->lmadr, chip);
tran = 0; result = IIC_OK; @@ -247,9 +255,10 @@ static int i2c_transfer(unsigned char cmd_type, while (tran != cnt && (result == IIC_OK)) { int bc,j;
- /* Control register = - * Normal transfer, 7-bits adressing, Transfer up to bc bytes, Normal start, - * Transfer is a sequence of transfers + /* + * Control register = + * Normal transfer, 7-bits adressing, Transfer up to + * bc bytes, Normal start, Transfer is a sequence of transfers */ creg |= IIC_CNTL_PT;
@@ -259,32 +268,36 @@ static int i2c_transfer(unsigned char cmd_type, if ((!cmd_type && (ptr == addr)) || ((tran + bc) != cnt)) creg |= IIC_CNTL_CHT;
- if (reading) + if (reading) { creg |= IIC_CNTL_READ; - else - for(j=0; j < bc; j++) + } else { + for(j = 0; j < bc; j++) { /* Set buffer */ - out_8((u8 *)IIC_MDBUF, ptr[tran+j]); - out_8((u8 *)IIC_CNTL, creg); + out_8(&i2c->mdbuf, ptr[tran + j]); + } + } + out_8(&i2c->cntl, creg);
- /* Transfer is in progress + /* + * Transfer is in progress * we have to wait for upto 5 bytes of data * 1 byte chip address+r/w bit then bc bytes * of data. * udelay(10) is 1 bit time at 100khz * Doubled for slop. 20 is too small. */ - i = 2*5*8; + i = 2 * 5 * 8; do { /* Get status */ - status = in_8((u8 *)IIC_STS); + status = in_8(&i2c->sts); udelay(10); i--; - } while ((status & IIC_STS_PT) && !(status & IIC_STS_ERR) && (i > 0)); + } while ((status & IIC_STS_PT) && !(status & IIC_STS_ERR) && + (i > 0));
if (status & IIC_STS_ERR) { result = IIC_NOK; - status = in_8((u8 *)IIC_EXTSTS); + status = in_8(&i2c->extsts); /* Lost arbitration? */ if (status & IIC_EXTSTS_LA) result = IIC_NOK_LA; @@ -297,19 +310,21 @@ static int i2c_transfer(unsigned char cmd_type, } else if ( status & IIC_STS_PT) { result = IIC_NOK_TOUT; } + /* Command is reading => get buffer */ if ((reading) && (result == IIC_OK)) { /* Are there data in buffer */ if (status & IIC_STS_MDBS) { /* - * even if we have data we have to wait 4OPB clocks - * for it to hit the front of the FIFO, after that - * we can just read. We should check XFCNT here and - * if the FIFO is full there is no need to wait. + * even if we have data we have to wait 4OPB + * clocks for it to hit the front of the FIFO, + * after that we can just read. We should check + * XFCNT here and if the FIFO is full there is + * no need to wait. */ udelay(1); - for (j=0; j<bc; j++) - ptr[tran+j] = in_8((u8 *)IIC_MDBUF); + for (j = 0; j < bc; j++) + ptr[tran + j] = in_8(&i2c->mdbuf); } else result = IIC_NOK_DATA; } @@ -324,7 +339,7 @@ static int i2c_transfer(unsigned char cmd_type, creg = IIC_CNTL_RPST; } } - return (result); + return result; }
int i2c_probe(uchar chip) @@ -338,17 +353,17 @@ int i2c_probe(uchar chip) * address was <ACK>ed (i.e. there was a chip at that address which * drove the data line low). */ - return (i2c_transfer(1, chip << 1, 0,0, buf, 1) != 0); + return (i2c_transfer(1, chip << 1, 0, 0, buf, 1) != 0); }
- -int i2c_read(uchar chip, uint addr, int alen, uchar * buffer, int len) +static int ppc4xx_i2c_transfer(uchar chip, uint addr, int alen, uchar *buffer, + int len, int read) { uchar xaddr[4]; int ret;
if (alen > 4) { - printf ("I2C read: addr len %d not supported\n", alen); + printf("I2C: addr len %d not supported\n", alen); return 1; }
@@ -373,50 +388,30 @@ int i2c_read(uchar chip, uint addr, int alen, uchar * buffer, int len) * hidden in the chip address. */ if (alen > 0) - chip |= ((addr >> (alen * 8)) & CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW); + chip |= ((addr >> (alen * 8)) & + CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW); #endif - if ((ret = i2c_transfer(1, chip<<1, &xaddr[4-alen], alen, buffer, len)) != 0) { - if (gd->have_console) - printf( "I2c read: failed %d\n", ret); + if ((ret = i2c_transfer(read, chip << 1, &xaddr[4 - alen], alen, + buffer, len)) != 0) { + if (gd->have_console) { + printf("I2C %s: failed %d\n", + read ? "read" : "write", ret); + } + return 1; } + return 0; }
-int i2c_write(uchar chip, uint addr, int alen, uchar * buffer, int len) +int i2c_read(uchar chip, uint addr, int alen, uchar * buffer, int len) { - uchar xaddr[4]; - - if (alen > 4) { - printf ("I2C write: addr len %d not supported\n", alen); - return 1; - - } - - if (alen > 0) { - xaddr[0] = (addr >> 24) & 0xFF; - xaddr[1] = (addr >> 16) & 0xFF; - xaddr[2] = (addr >> 8) & 0xFF; - xaddr[3] = addr & 0xFF; - } - -#ifdef CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW - /* - * EEPROM chips that implement "address overflow" are ones - * like Catalyst 24WC04/08/16 which has 9/10/11 bits of - * address and the extra bits end up in the "chip address" - * bit slots. This makes a 24WC08 (1Kbyte) chip look like - * four 256 byte chips. - * - * Note that we consider the length of the address field to - * still be one byte because the extra address bits are - * hidden in the chip address. - */ - if (alen > 0) - chip |= ((addr >> (alen * 8)) & CONFIG_SYS_I2C_EEPROM_ADDR_OVERFLOW); -#endif + return ppc4xx_i2c_transfer(chip, addr, alen, buffer, len, 1); +}
- return (i2c_transfer(0, chip<<1, &xaddr[4-alen], alen, buffer, len ) != 0); +int i2c_write(uchar chip, uint addr, int alen, uchar * buffer, int len) +{ + return ppc4xx_i2c_transfer(chip, addr, alen, buffer, len, 0); }
#if defined(CONFIG_I2C_MULTI_BUS) diff --git a/include/4xx_i2c.h b/include/4xx_i2c.h index 070657f..0c6c926 100644 --- a/include/4xx_i2c.h +++ b/include/4xx_i2c.h @@ -1,5 +1,5 @@ /* - * (C) Copyright 2007 + * (C) Copyright 2007-2009 * Stefan Roese, DENX Software Engineering, sr@denx.de. * * See file CREDITS for list of people who contributed to this @@ -52,22 +52,26 @@ #define I2C_BASE_ADDR (0xEF600500 + I2C_BUS_OFFS) #endif
-#define I2C_REGISTERS_BASE_ADDRESS I2C_BASE_ADDR -#define IIC_MDBUF (I2C_REGISTERS_BASE_ADDRESS+IICMDBUF) -#define IIC_SDBUF (I2C_REGISTERS_BASE_ADDRESS+IICSDBUF) -#define IIC_LMADR (I2C_REGISTERS_BASE_ADDRESS+IICLMADR) -#define IIC_HMADR (I2C_REGISTERS_BASE_ADDRESS+IICHMADR) -#define IIC_CNTL (I2C_REGISTERS_BASE_ADDRESS+IICCNTL) -#define IIC_MDCNTL (I2C_REGISTERS_BASE_ADDRESS+IICMDCNTL) -#define IIC_STS (I2C_REGISTERS_BASE_ADDRESS+IICSTS) -#define IIC_EXTSTS (I2C_REGISTERS_BASE_ADDRESS+IICEXTSTS) -#define IIC_LSADR (I2C_REGISTERS_BASE_ADDRESS+IICLSADR) -#define IIC_HSADR (I2C_REGISTERS_BASE_ADDRESS+IICHSADR) -#define IIC_CLKDIV (I2C_REGISTERS_BASE_ADDRESS+IIC0_CLKDIV) -#define IIC_INTRMSK (I2C_REGISTERS_BASE_ADDRESS+IICINTRMSK) -#define IIC_XFRCNT (I2C_REGISTERS_BASE_ADDRESS+IICXFRCNT) -#define IIC_XTCNTLSS (I2C_REGISTERS_BASE_ADDRESS+IICXTCNTLSS) -#define IIC_DIRECTCNTL (I2C_REGISTERS_BASE_ADDRESS+IICDIRECTCNTL) +struct ppc4xx_i2c { + u8 mdbuf; + u8 res1; + u8 sdbuf; + u8 res2; + u8 lmadr; + u8 hmadr; + u8 cntl; + u8 mdcntl; + u8 sts; + u8 extsts; + u8 lsadr; + u8 hsadr; + u8 clkdiv; + u8 intrmsk; + u8 xfrcnt; + u8 xtcntlss; + u8 directcntl; + u8 intr; +};
/* MDCNTL Register Bit definition */ #define IIC_MDCNTL_HSCL 0x01 diff --git a/include/ppc405.h b/include/ppc405.h index 508c77b..bc2d051 100644 --- a/include/ppc405.h +++ b/include/ppc405.h @@ -566,25 +566,6 @@ #define MAL0_RCBS24 (MAL_DCR_BASE + 0x78) /* RX 24 Channel buffer size */
/*----------------------------------------------------------------------------- -| IIC Register Offsets -'----------------------------------------------------------------------------*/ -#define IICMDBUF 0x00 -#define IICSDBUF 0x02 -#define IICLMADR 0x04 -#define IICHMADR 0x05 -#define IICCNTL 0x06 -#define IICMDCNTL 0x07 -#define IICSTS 0x08 -#define IICEXTSTS 0x09 -#define IICLSADR 0x0A -#define IICHSADR 0x0B -#define IIC0_CLKDIV 0x0C -#define IICINTRMSK 0x0D -#define IICXFRCNT 0x0E -#define IICXTCNTLSS 0x0F -#define IICDIRECTCNTL 0x10 - -/*----------------------------------------------------------------------------- | UART Register Offsets '----------------------------------------------------------------------------*/ #define DATA_REG 0x00 diff --git a/include/ppc440.h b/include/ppc440.h index a050ffd..e60fa13 100644 --- a/include/ppc440.h +++ b/include/ppc440.h @@ -1714,25 +1714,6 @@ #endif
/*----------------------------------------------------------------------------- -| IIC Register Offsets -'----------------------------------------------------------------------------*/ -#define IICMDBUF 0x00 -#define IICSDBUF 0x02 -#define IICLMADR 0x04 -#define IICHMADR 0x05 -#define IICCNTL 0x06 -#define IICMDCNTL 0x07 -#define IICSTS 0x08 -#define IICEXTSTS 0x09 -#define IICLSADR 0x0A -#define IICHSADR 0x0B -#define IIC0_CLKDIV 0x0C -#define IICINTRMSK 0x0D -#define IICXFRCNT 0x0E -#define IICXTCNTLSS 0x0F -#define IICDIRECTCNTL 0x10 - -/*----------------------------------------------------------------------------- | PCI Internal Registers et. al. (accessed via plb) +----------------------------------------------------------------------------*/ #define PCIL0_CFGADR (CONFIG_SYS_PCI_BASE + 0x0ec00000)
Applied to u-boot-ppc4xx/next. Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Stefan Roese
