[U-Boot] TCP & Overrrun
I'm gettin overrun on the raspberry pi.
Which ethernet drived does it use? I need to determine if it uses CONFIG_SYS_RX_ETH_BUFFER" from net.h and the "net_rx_packets" buffer pool defined in net/net.c
grep suggests it is not using net_rx_packets.
Here's a list of a grep of the u-boot source directory
rch/mips/mach-au1x00/au1x00_eth.c arch/powerpc/cpu/mpc85xx/ether_fcc.c net/net.c drivers/usb/gadget/ether.c drivers/net/ep93xx_eth.c drivers/net/cs8900.c drivers/net/ftgmac100.c drivers/net/ks8851_mll.c drivers/net/dc2114x.c drivers/net/dm9000x.c drivers/net/xilinx_ll_temac_fifo.c drivers/net/ax88180.c drivers/net/tsec.c drivers/net/mcffec.c drivers/net/dnet.c drivers/net/ftmac100.c drivers/net/xilinx_ll_temac_sdma.c drivers/net/sandbox-raw.c drivers/net/cpsw.c drivers/net/sandbox.c drivers/net/smc911x.c drivers/net/lan91c96.c drivers/net/uli526x.c drivers/net/tsi108_eth.c drivers/net/mpc8xx_fec.c drivers/net/at91_emac.c drivers/net/ethoc.c drivers/net/fsl_mcdmafec.c drivers/net/bcm-sf2-eth.c drivers/net/enc28j60.c drivers/net/smc91111.c drivers/net/macb.c drivers/net/pic32_eth.c
Thanks
Duncan Hare
Hi Duncan,
You didn't specify which one you are talking about, but here's how to find out...
Assuming rpi3, find the config first...
configs/rpi_3_defconfig says: CONFIG_DEFAULT_DEVICE_TREE="bcm2837-rpi-3-b" arch/arm/dts/bcm2837-rpi-3-b.dts says: #include "bcm283x-rpi-smsc9514.dtsi" arch/arm/dts/bcm283x-rpi-smsc9514.dtsi says: ethernet: usbether@1 { compatible = "usb424,ec00"; grep -rn ec00 drivers/ says: drivers/usb/eth/smsc95xx.c
Cheers, -Joe
Thanks
Duncan Hare _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Duncan Hare
Joe Hershberger
