[U-Boot-Users] [PATCH 1/2 (resubmit)] PPC4xx: Cosmetic changes
Signed-off-by: Larry Johnson lrj@acm.org ---
cpu/ppc4xx/miiphy.c | 58 +++++++--------------
diff --git a/cpu/ppc4xx/miiphy.c b/cpu/ppc4xx/miiphy.c index 6b98025..2fa1b57 100644 --- a/cpu/ppc4xx/miiphy.c +++ b/cpu/ppc4xx/miiphy.c @@ -27,19 +27,6 @@ | | Author: Mark Wisner | - | Change Activity- - | - | Date Description of Change BY - | --------- --------------------- --- - | 05-May-99 Created MKW - | 01-Jul-99 Changed clock setting of sta_reg from 66Mhz to 50Mhz to - | better match OPB speed. Also modified delay times. JWB - | 29-Jul-99 Added Full duplex support MKW - | 24-Aug-99 Removed printf from dp83843_duplex() JWB - | 19-Jul-00 Ported to esd cpci405 sr - | 23-Dec-03 Ported from miiphy.c to 440GX Travis Sawyer TBS - | travis.sawyer@sandburst.com - | +-----------------------------------------------------------------------------*/
#include <common.h> @@ -60,7 +47,6 @@ void miiphy_dump (char *devname, unsigned char addr) unsigned long i; unsigned short data;
- for (i = 0; i < 0x1A; i++) { if (miiphy_read (devname, addr, i, &data)) { printf ("read error for reg %lx\n", i); @@ -75,7 +61,6 @@ void miiphy_dump (char *devname, unsigned char addr) } /* end for loop */ } /* end dump */
- /***********************************************************/ /* (Re)start autonegotiation */ /***********************************************************/ @@ -102,7 +87,6 @@ int phy_setup_aneg (char *devname, unsigned char addr) return 0; }
- /***********************************************************/ /* read a phy reg and return the value with a rc */ /***********************************************************/ @@ -145,21 +129,20 @@ unsigned int miiphy_getemac_offset (void) #endif }
- -int emac4xx_miiphy_read (char *devname, unsigned char addr, - unsigned char reg, unsigned short *value) +int emac4xx_miiphy_read (char *devname, unsigned char addr, unsigned char reg, + unsigned short *value) { unsigned long sta_reg; /* STA scratch area */ unsigned long i; unsigned long emac_reg;
- emac_reg = miiphy_getemac_offset (); /* see if it is ready for 1000 nsec */ i = 0;
/* see if it is ready for sec */ - while ((in32 (EMAC_STACR + emac_reg) & EMAC_STACR_OC) == EMAC_STACR_OC_MASK) { + while ((in32 (EMAC_STACR + emac_reg) & EMAC_STACR_OC) == + EMAC_STACR_OC_MASK) { udelay (7); if (i > 5) { #ifdef ET_DEBUG @@ -175,10 +158,10 @@ int emac4xx_miiphy_read (char *devname, unsigned char addr, /* set clock (50Mhz) and read flags */ #if defined(CONFIG_440GX) || defined(CONFIG_440SPE) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) -#if defined(CONFIG_IBM_EMAC4_V4) /* EMAC4 V4 changed bit setting */ - sta_reg = (sta_reg & ~EMAC_STACR_OP_MASK) | EMAC_STACR_READ; +#if defined(CONFIG_IBM_EMAC4_V4) /* EMAC4 V4 changed bit setting */ + sta_reg = (sta_reg & ~EMAC_STACR_OP_MASK) | EMAC_STACR_READ; #else - sta_reg |= EMAC_STACR_READ; + sta_reg |= EMAC_STACR_READ; #endif #else sta_reg = (sta_reg | EMAC_STACR_READ) & ~EMAC_STACR_CLK_100MHZ; @@ -198,7 +181,7 @@ int emac4xx_miiphy_read (char *devname, unsigned char addr,
sta_reg = in32 (EMAC_STACR + emac_reg); #ifdef ET_DEBUG - printf ("a21: read : EMAC_STACR=0x%0x\n", sta_reg); /* test-only */ + printf ("a21: read : EMAC_STACR=0x%0x\n", sta_reg); /* test-only */ #endif i = 0; while ((sta_reg & EMAC_STACR_OC) == EMAC_STACR_OC_MASK) { @@ -216,19 +199,17 @@ int emac4xx_miiphy_read (char *devname, unsigned char addr, return -1; }
- *value = *(short *) (&sta_reg); + *value = *(short *)(&sta_reg); return 0;
- } /* phy_read */
- /***********************************************************/ /* write a phy reg and return the value with a rc */ /***********************************************************/
-int emac4xx_miiphy_write (char *devname, unsigned char addr, - unsigned char reg, unsigned short value) +int emac4xx_miiphy_write (char *devname, unsigned char addr, unsigned char reg, + unsigned short value) { unsigned long sta_reg; /* STA scratch area */ unsigned long i; @@ -238,7 +219,8 @@ int emac4xx_miiphy_write (char *devname, unsigned char addr, /* see if it is ready for 1000 nsec */ i = 0;
- while ((in32 (EMAC_STACR + emac_reg) & EMAC_STACR_OC) == EMAC_STACR_OC_MASK) { + while ((in32 (EMAC_STACR + emac_reg) & EMAC_STACR_OC) == + EMAC_STACR_OC_MASK) { if (i > 5) return -1; udelay (7); @@ -249,10 +231,10 @@ int emac4xx_miiphy_write (char *devname, unsigned char addr, /* set clock (50Mhz) and read flags */ #if defined(CONFIG_440GX) || defined(CONFIG_440SPE) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) -#if defined(CONFIG_IBM_EMAC4_V4) /* EMAC4 V4 changed bit setting */ - sta_reg = (sta_reg & ~EMAC_STACR_OP_MASK) | EMAC_STACR_WRITE; +#if defined(CONFIG_IBM_EMAC4_V4) /* EMAC4 V4 changed bit setting */ + sta_reg = (sta_reg & ~EMAC_STACR_OP_MASK) | EMAC_STACR_WRITE; #else - sta_reg |= EMAC_STACR_WRITE; + sta_reg |= EMAC_STACR_WRITE; #endif #else sta_reg = (sta_reg | EMAC_STACR_WRITE) & ~EMAC_STACR_CLK_100MHZ; @@ -263,8 +245,8 @@ int emac4xx_miiphy_write (char *devname, unsigned char addr, !defined(CONFIG_440EPX) && !defined(CONFIG_440GRX) sta_reg = sta_reg | CONFIG_PHY_CLK_FREQ; /* Set clock frequency (PLB freq. dependend) */ #endif - sta_reg = sta_reg | ((unsigned long) addr << 5);/* Phy address */ - sta_reg = sta_reg | EMAC_STACR_OC_MASK; /* new IBM emac v4 */ + sta_reg = sta_reg | ((unsigned long)addr << 5); /* Phy address */ + sta_reg = sta_reg | EMAC_STACR_OC_MASK; /* new IBM emac v4 */ memcpy (&sta_reg, &value, 2); /* put in data */
out32 (EMAC_STACR + emac_reg, sta_reg); @@ -273,7 +255,7 @@ int emac4xx_miiphy_write (char *devname, unsigned char addr, i = 0; sta_reg = in32 (EMAC_STACR + emac_reg); #ifdef ET_DEBUG - printf ("a31: read : EMAC_STACR=0x%0x\n", sta_reg); /* test-only */ + printf ("a31: read : EMAC_STACR=0x%0x\n", sta_reg); /* test-only */ #endif while ((sta_reg & EMAC_STACR_OC) == EMAC_STACR_OC_MASK) { udelay (7); @@ -290,4 +272,4 @@ int emac4xx_miiphy_write (char *devname, unsigned char addr, return -1; return 0;
-} /* phy_write */ +} /* phy_write */
Larry Johnson
