[U-Boot] pata support in u-boot
I'm trying to add our ATA driver to u-boot.
But it seems that now u-boot only supports SATA.
ATA is mixed with ide in cmd_ide.c.
There is no ata common interface in include.
Is this suitable?
Yours Terry
Dear "Lv Terry-R65388",
In message 1AE74F652ECB1440B73DD7C2C20842D19A6462@zch01exm27.fsl.freescale.net you wrote:
Fine.
This is not correct. U-Boot also supports ATA/ATAPI, SCSI, USB, PCMCIA, Systemace, ...
Indeed.
Hm... so include/ata.h is not what you are looking for>
Is this suitable?
I'm afraid I don't understand what exactly your problem is.
drivers/block/mg_disk.c, drivers/block/pata_bfin.c or drivers/block/sil680.c seem to show that the current code actually can be used with ATA interfaces.
Hi Denk,
drivers/block/pata_bfin.c uses sata.h and can use commands in cmd_sata.c. drivers/block/mg_disk.c uses mg_disk.h and can use commands in cmd_mgdisk.c. drivers/block/sil680.c, hm.., I don't know what cmd it uses.
There's also ATAPI in cmd_ide.c, which uses code in Pcs440ep.c.
They are all ATAPI, But use different interface.
There is no ata common function definitions.
I just wonder if I should create a new interface, like cmd_pata.c and mxc_pata.h for my ata.
Actually, sata interface is ok for use in my ata. But it may make customer confused.
I don't want to add redundant code for ata, so I just ask if there is a better implementation for ata.
Thanks~~
Yours Terry
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: 2009年10月21日 17:37 To: Lv Terry-R65388 Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] pata support in u-boot
Fine.
Indeed.
Is this suitable?
Lv Terry-R65388
