[U-Boot] [PATCH] ARM: at91sam9x5: Using CPU string directly
As the CPU name is not configurable, using CPU string directly
Signed-off-by: Bo Shen voice.shen@atmel.com --- arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c | 14 +++++++------- arch/arm/include/asm/arch-at91/at91sam9x5.h | 6 ------ 2 files changed, 7 insertions(+), 13 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c b/arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c index 0448c0b..29e8aa4 100644 --- a/arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c +++ b/arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c @@ -61,20 +61,20 @@ char *get_cpu_name() if (cpu_is_at91sam9x5()) { switch (extension_id) { case ARCH_EXID_AT91SAM9G15: - return CONFIG_SYS_AT91_G15_CPU_NAME; + return "AT91SAM9G15"; case ARCH_EXID_AT91SAM9G25: - return CONFIG_SYS_AT91_G25_CPU_NAME; + return "AT91SAM9G25"; case ARCH_EXID_AT91SAM9G35: - return CONFIG_SYS_AT91_G35_CPU_NAME; + return "AT91SAM9G35"; case ARCH_EXID_AT91SAM9X25: - return CONFIG_SYS_AT91_X25_CPU_NAME; + return "AT91SAM9X25"; case ARCH_EXID_AT91SAM9X35: - return CONFIG_SYS_AT91_X35_CPU_NAME; + return "AT91SAM9X35"; default: - return CONFIG_SYS_AT91_UNKNOWN_CPU; + return "Unknown CPU type"; } } else { - return CONFIG_SYS_AT91_UNKNOWN_CPU; + return "Unknown CPU type"; } }
diff --git a/arch/arm/include/asm/arch-at91/at91sam9x5.h b/arch/arm/include/asm/arch-at91/at91sam9x5.h index de0f1b1..b7d1932 100644 --- a/arch/arm/include/asm/arch-at91/at91sam9x5.h +++ b/arch/arm/include/asm/arch-at91/at91sam9x5.h @@ -140,12 +140,6 @@ /* * Cpu Name */ -#define CONFIG_SYS_AT91_G15_CPU_NAME "AT91SAM9G15" -#define CONFIG_SYS_AT91_G25_CPU_NAME "AT91SAM9G25" -#define CONFIG_SYS_AT91_G35_CPU_NAME "AT91SAM9G35" -#define CONFIG_SYS_AT91_X25_CPU_NAME "AT91SAM9X25" -#define CONFIG_SYS_AT91_X35_CPU_NAME "AT91SAM9X35" -#define CONFIG_SYS_AT91_UNKNOWN_CPU "Unknown CPU type" #define ATMEL_CPU_NAME get_cpu_name()
Dear Bo Shen,
Bo Shen voice.shen@atmel.com writes:
applied to u-boot-atmel/master, thanks!
Best regards, Andreas Bießmann
andreas.devel@googlemail.com
Bo Shen
