[U-Boot] [PATCH 1/5 V2] PXA: Cleanup serial_pxa
* Cleanup register definitions by introducing new regs-uart.h, compliant with rest of U-Boot. * Remove old register definitions from pxa-regs.h * Convert serial_pxa to new regs-uart.h * Cleanup serial_pxa
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- arch/arm/include/asm/arch-pxa/pxa-regs.h | 111 ------- arch/arm/include/asm/arch-pxa/regs-uart.h | 109 +++++++ drivers/serial/serial_pxa.c | 464 ++++++++++++----------------- 3 files changed, 297 insertions(+), 387 deletions(-) create mode 100644 arch/arm/include/asm/arch-pxa/regs-uart.h
V2: Add missing regs-uart.h
diff --git a/arch/arm/include/asm/arch-pxa/pxa-regs.h b/arch/arm/include/asm/arch-pxa/pxa-regs.h index 109fdc0..52c79a9 100644 --- a/arch/arm/include/asm/arch-pxa/pxa-regs.h +++ b/arch/arm/include/asm/arch-pxa/pxa-regs.h @@ -315,117 +315,6 @@ typedef void (*ExcpHndlr) (void) ;
/******************************************************************************/ /* - * UARTs - */ -/* Full Function UART (FFUART) */ -#define FFUART FFRBR -#define FFRBR 0x40100000 /* Receive Buffer Register (read only) */ -#define FFTHR 0x40100000 /* Transmit Holding Register (write only) */ -#define FFIER 0x40100004 /* Interrupt Enable Register (read/write) */ -#define FFIIR 0x40100008 /* Interrupt ID Register (read only) */ -#define FFFCR 0x40100008 /* FIFO Control Register (write only) */ -#define FFLCR 0x4010000C /* Line Control Register (read/write) */ -#define FFMCR 0x40100010 /* Modem Control Register (read/write) */ -#define FFLSR 0x40100014 /* Line Status Register (read only) */ -#define FFMSR 0x40100018 /* Modem Status Register (read only) */ -#define FFSPR 0x4010001C /* Scratch Pad Register (read/write) */ -#define FFISR 0x40100020 /* Infrared Selection Register (read/write) */ -#define FFDLL 0x40100000 /* Divisor Latch Low Register (DLAB = 1) (read/write) */ -#define FFDLH 0x40100004 /* Divisor Latch High Register (DLAB = 1) (read/write) */ - -/* Bluetooth UART (BTUART) */ -#define BTUART BTRBR -#define BTRBR 0x40200000 /* Receive Buffer Register (read only) */ -#define BTTHR 0x40200000 /* Transmit Holding Register (write only) */ -#define BTIER 0x40200004 /* Interrupt Enable Register (read/write) */ -#define BTIIR 0x40200008 /* Interrupt ID Register (read only) */ -#define BTFCR 0x40200008 /* FIFO Control Register (write only) */ -#define BTLCR 0x4020000C /* Line Control Register (read/write) */ -#define BTMCR 0x40200010 /* Modem Control Register (read/write) */ -#define BTLSR 0x40200014 /* Line Status Register (read only) */ -#define BTMSR 0x40200018 /* Modem Status Register (read only) */ -#define BTSPR 0x4020001C /* Scratch Pad Register (read/write) */ -#define BTISR 0x40200020 /* Infrared Selection Register (read/write) */ -#define BTDLL 0x40200000 /* Divisor Latch Low Register (DLAB = 1) (read/write) */ -#define BTDLH 0x40200004 /* Divisor Latch High Register (DLAB = 1) (read/write) */ - -/* Standard UART (STUART) */ -#define STUART STRBR -#define STRBR 0x40700000 /* Receive Buffer Register (read only) */ -#define STTHR 0x40700000 /* Transmit Holding Register (write only) */ -#define STIER 0x40700004 /* Interrupt Enable Register (read/write) */ -#define STIIR 0x40700008 /* Interrupt ID Register (read only) */ -#define STFCR 0x40700008 /* FIFO Control Register (write only) */ -#define STLCR 0x4070000C /* Line Control Register (read/write) */ -#define STMCR 0x40700010 /* Modem Control Register (read/write) */ -#define STLSR 0x40700014 /* Line Status Register (read only) */ -#define STMSR 0x40700018 /* Reserved */ -#define STSPR 0x4070001C /* Scratch Pad Register (read/write) */ -#define STISR 0x40700020 /* Infrared Selection Register (read/write) */ -#define STDLL 0x40700000 /* Divisor Latch Low Register (DLAB = 1) (read/write) */ -#define STDLH 0x40700004 /* Divisor Latch High Register (DLAB = 1) (read/write) */ - -#define IER_DMAE (1 << 7) /* DMA Requests Enable */ -#define IER_UUE (1 << 6) /* UART Unit Enable */ -#define IER_NRZE (1 << 5) /* NRZ coding Enable */ -#define IER_RTIOE (1 << 4) /* Receiver Time Out Interrupt Enable */ -#define IER_MIE (1 << 3) /* Modem Interrupt Enable */ -#define IER_RLSE (1 << 2) /* Receiver Line Status Interrupt Enable */ -#define IER_TIE (1 << 1) /* Transmit Data request Interrupt Enable */ -#define IER_RAVIE (1 << 0) /* Receiver Data Available Interrupt Enable */ - -#define IIR_FIFOES1 (1 << 7) /* FIFO Mode Enable Status */ -#define IIR_FIFOES0 (1 << 6) /* FIFO Mode Enable Status */ -#define IIR_TOD (1 << 3) /* Time Out Detected */ -#define IIR_IID2 (1 << 2) /* Interrupt Source Encoded */ -#define IIR_IID1 (1 << 1) /* Interrupt Source Encoded */ -#define IIR_IP (1 << 0) /* Interrupt Pending (active low) */ - -#define FCR_ITL2 (1 << 7) /* Interrupt Trigger Level */ -#define FCR_ITL1 (1 << 6) /* Interrupt Trigger Level */ -#define FCR_RESETTF (1 << 2) /* Reset Transmitter FIFO */ -#define FCR_RESETRF (1 << 1) /* Reset Receiver FIFO */ -#define FCR_TRFIFOE (1 << 0) /* Transmit and Receive FIFO Enable */ -#define FCR_ITL_1 (0) -#define FCR_ITL_8 (FCR_ITL1) -#define FCR_ITL_16 (FCR_ITL2) -#define FCR_ITL_32 (FCR_ITL2|FCR_ITL1) - -#define LCR_DLAB (1 << 7) /* Divisor Latch Access Bit */ -#define LCR_SB (1 << 6) /* Set Break */ -#define LCR_STKYP (1 << 5) /* Sticky Parity */ -#define LCR_EPS (1 << 4) /* Even Parity Select */ -#define LCR_PEN (1 << 3) /* Parity Enable */ -#define LCR_STB (1 << 2) /* Stop Bit */ -#define LCR_WLS1 (1 << 1) /* Word Length Select */ -#define LCR_WLS0 (1 << 0) /* Word Length Select */ - -#define LSR_FIFOE (1 << 7) /* FIFO Error Status */ -#define LSR_TEMT (1 << 6) /* Transmitter Empty */ -#define LSR_TDRQ (1 << 5) /* Transmit Data Request */ -#define LSR_BI (1 << 4) /* Break Interrupt */ -#define LSR_FE (1 << 3) /* Framing Error */ -#define LSR_PE (1 << 2) /* Parity Error */ -#define LSR_OE (1 << 1) /* Overrun Error */ -#define LSR_DR (1 << 0) /* Data Ready */ - -#define MCR_LOOP (1 << 4) /* */ -#define MCR_OUT2 (1 << 3) /* force MSR_DCD in loopback mode */ -#define MCR_OUT1 (1 << 2) /* force MSR_RI in loopback mode */ -#define MCR_RTS (1 << 1) /* Request to Send */ -#define MCR_DTR (1 << 0) /* Data Terminal Ready */ - -#define MSR_DCD (1 << 7) /* Data Carrier Detect */ -#define MSR_RI (1 << 6) /* Ring Indicator */ -#define MSR_DSR (1 << 5) /* Data Set Ready */ -#define MSR_CTS (1 << 4) /* Clear To Send */ -#define MSR_DDCD (1 << 3) /* Delta Data Carrier Detect */ -#define MSR_TERI (1 << 2) /* Trailing Edge Ring Indicator */ -#define MSR_DDSR (1 << 1) /* Delta Data Set Ready */ -#define MSR_DCTS (1 << 0) /* Delta Clear To Send */ - -/******************************************************************************/ -/* * IrSR (Infrared Selection Register) */ #define IrSR_OFFSET 0x20 diff --git a/arch/arm/include/asm/arch-pxa/regs-uart.h b/arch/arm/include/asm/arch-pxa/regs-uart.h new file mode 100644 index 0000000..355e892 --- /dev/null +++ b/arch/arm/include/asm/arch-pxa/regs-uart.h @@ -0,0 +1,109 @@ +/* + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __REGS_UART_H__ +#define __REGS_UART_H__ + +#define FFUART_BASE 0x40100000 +#define BTUART_BASE 0x40200000 +#define STUART_BASE 0x40700000 +#define HWUART_BASE 0x41600000 + +struct pxa_uart_regs { + union { + uint32_t thr; + uint32_t rbr; + uint32_t dll; + }; + union { + uint32_t ier; + uint32_t dlh; + }; + union { + uint32_t fcr; + uint32_t iir; + }; + uint32_t lcr; + uint32_t mcr; + uint32_t lsr; + uint32_t msr; + uint32_t spr; + uint32_t isr; +}; + +#define IER_DMAE (1 << 7) +#define IER_UUE (1 << 6) +#define IER_NRZE (1 << 5) +#define IER_RTIOE (1 << 4) +#define IER_MIE (1 << 3) +#define IER_RLSE (1 << 2) +#define IER_TIE (1 << 1) +#define IER_RAVIE (1 << 0) + +#define IIR_FIFOES1 (1 << 7) +#define IIR_FIFOES0 (1 << 6) +#define IIR_TOD (1 << 3) +#define IIR_IID2 (1 << 2) +#define IIR_IID1 (1 << 1) +#define IIR_IP (1 << 0) + +#define FCR_ITL2 (1 << 7) +#define FCR_ITL1 (1 << 6) +#define FCR_RESETTF (1 << 2) +#define FCR_RESETRF (1 << 1) +#define FCR_TRFIFOE (1 << 0) +#define FCR_ITL_1 0 +#define FCR_ITL_8 (FCR_ITL1) +#define FCR_ITL_16 (FCR_ITL2) +#define FCR_ITL_32 (FCR_ITL2|FCR_ITL1) + +#define LCR_DLAB (1 << 7) +#define LCR_SB (1 << 6) +#define LCR_STKYP (1 << 5) +#define LCR_EPS (1 << 4) +#define LCR_PEN (1 << 3) +#define LCR_STB (1 << 2) +#define LCR_WLS1 (1 << 1) +#define LCR_WLS0 (1 << 0) + +#define LSR_FIFOE (1 << 7) +#define LSR_TEMT (1 << 6) +#define LSR_TDRQ (1 << 5) +#define LSR_BI (1 << 4) +#define LSR_FE (1 << 3) +#define LSR_PE (1 << 2) +#define LSR_OE (1 << 1) +#define LSR_DR (1 << 0) + +#define MCR_LOOP (1 << 4) +#define MCR_OUT2 (1 << 3) +#define MCR_OUT1 (1 << 2) +#define MCR_RTS (1 << 1) +#define MCR_DTR (1 << 0) + +#define MSR_DCD (1 << 7) +#define MSR_RI (1 << 6) +#define MSR_DSR (1 << 5) +#define MSR_CTS (1 << 4) +#define MSR_DDCD (1 << 3) +#define MSR_TERI (1 << 2) +#define MSR_DDSR (1 << 1) +#define MSR_DCTS (1 << 0) + +#endif /* __REGS_UART_H__ */ diff --git a/drivers/serial/serial_pxa.c b/drivers/serial/serial_pxa.c index 68469a4..84bb17c 100644 --- a/drivers/serial/serial_pxa.c +++ b/drivers/serial/serial_pxa.c @@ -1,4 +1,6 @@ /* + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * * (C) Copyright 2002 * Wolfgang Denk, DENX Software Engineering, wd@denx.de * @@ -32,148 +34,161 @@ #include <watchdog.h> #include <serial.h> #include <asm/arch/pxa-regs.h> +#include <asm/arch/regs-uart.h> #include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR;
-#define FFUART_INDEX 0 -#define BTUART_INDEX 1 -#define STUART_INDEX 2 +/* + * The numbering scheme differs here for PXA25x, PXA27x and PXA3xx so we can + * easily handle enabling of clock. + */ +#ifdef CONFIG_CPU_MONAHANS +#define UART_CLK_BASE CKENA_21_BTUART +#define UART_CLK_REG CKENA +#define BTUART_INDEX 0 +#define FFUART_INDEX 1 +#define STUART_INDEX 2 +#elif CONFIG_PXA250 +#define UART_CLK_BASE (1 << 4) /* HWUART */ +#define UART_CLK_REG CKEN +#define HWUART_INDEX 0 +#define STUART_INDEX 1 +#define FFUART_INDEX 2 +#define BTUART_INDEX 3 +#else /* PXA27x */ +#define UART_CLK_BASE CKEN5_STUART +#define UART_CLK_REG CKEN +#define STUART_INDEX 0 +#define FFUART_INDEX 1 +#define BTUART_INDEX 2 +#endif + +/* + * Only PXA250 has HWUART, to avoid poluting the code with more macros, + * artificially introduce this. + */ +#ifndef CONFIG_PXA250 +#define HWUART_INDEX 0xff +#endif
#ifndef CONFIG_SERIAL_MULTI -#if defined (CONFIG_FFUART) +#if defined(CONFIG_FFUART) #define UART_INDEX FFUART_INDEX -#elif defined (CONFIG_BTUART) +#elif defined(CONFIG_BTUART) #define UART_INDEX BTUART_INDEX -#elif defined (CONFIG_STUART) +#elif defined(CONFIG_STUART) #define UART_INDEX STUART_INDEX +#elif defined(CONFIG_HWUART) +#define UART_INDEX HWUART_INDEX #else -#error "Bad: you didn't configure serial ..." +#error "Please select CONFIG_(FF|BT|ST|HW)UART in board config file." #endif #endif
-void pxa_setbrg_dev (unsigned int uart_index) +uint32_t pxa_uart_get_baud_divider(void) { - unsigned int quot = 0; - if (gd->baudrate == 1200) - quot = 768; + return 768; else if (gd->baudrate == 9600) - quot = 96; + return 96; else if (gd->baudrate == 19200) - quot = 48; + return 48; else if (gd->baudrate == 38400) - quot = 24; + return 24; else if (gd->baudrate == 57600) - quot = 16; + return 16; else if (gd->baudrate == 115200) - quot = 8; - else - hang (); + return 8; + else /* Unsupported baudrate */ + return 0; +}
+struct pxa_uart_regs *pxa_uart_index_to_regs(uint32_t uart_index) +{ switch (uart_index) { - case FFUART_INDEX: -#ifdef CONFIG_CPU_MONAHANS - writel(readl(CKENA) | CKENA_22_FFUART, CKENA); -#else - writel(readl(CKEN) | CKEN6_FFUART, CKEN); -#endif /* CONFIG_CPU_MONAHANS */ - - writel(0, FFIER); /* Disable for now */ - writel(0, FFFCR); /* No fifos enabled */ + case FFUART_INDEX: return (struct pxa_uart_regs *)FFUART_BASE; + case BTUART_INDEX: return (struct pxa_uart_regs *)BTUART_BASE; + case STUART_INDEX: return (struct pxa_uart_regs *)STUART_BASE; + case HWUART_INDEX: return (struct pxa_uart_regs *)HWUART_BASE; + default: + return NULL; + } +}
- /* set baud rate */ - writel(LCR_WLS0 | LCR_WLS1 | LCR_DLAB, FFLCR); - writel(quot & 0xff, FFDLL); - writel(quot >> 8, FFDLH); - writel(LCR_WLS0 | LCR_WLS1, FFLCR); +void pxa_uart_toggle_clock(uint32_t uart_index, int enable) +{ + uint32_t clk_reg, clk_offset, reg;
- writel(IER_UUE, FFIER); /* Enable FFUART */ - break; + clk_reg = UART_CLK_REG; + clk_offset = UART_CLK_BASE << uart_index;
- case BTUART_INDEX: -#ifdef CONFIG_CPU_MONAHANS - writel(readl(CKENA) | CKENA_21_BTUART, CKENA); -#else - writel(readl(CKEN) | CKEN7_BTUART, CKEN); -#endif /* CONFIG_CPU_MONAHANS */ + reg = readl(clk_reg);
- writel(0, BTIER); - writel(0, BTFCR); + if (enable) + reg |= clk_offset; + else + reg &= ~clk_offset;
- /* set baud rate */ - writel(LCR_DLAB, BTLCR); - writel(quot & 0xff, BTDLL); - writel(quot >> 8, BTDLH); - writel(LCR_WLS0 | LCR_WLS1, BTLCR); + writel(reg, clk_reg); +}
- writel(IER_UUE, BTIER); /* Enable BFUART */ +/* + * Enable clock and set baud rate, parity etc. + */ +void pxa_setbrg_dev(uint32_t uart_index) +{ + uint32_t divider = 0; + struct pxa_uart_regs *uart_regs;
- break; + divider = pxa_uart_get_baud_divider(); + if (!divider) + hang();
- case STUART_INDEX: -#ifdef CONFIG_CPU_MONAHANS - writel(readl(CKENA) | CKENA_23_STUART, CKENA); -#else - writel(readl(CKEN) | CKEN5_STUART, CKEN); -#endif /* CONFIG_CPU_MONAHANS */ + uart_regs = pxa_uart_index_to_regs(uart_index); + if (!uart_regs) + hang();
- writel(0, STIER); - writel(0, STFCR); + pxa_uart_toggle_clock(uart_index, 1);
- /* set baud rate */ - writel(LCR_DLAB, STLCR); - writel(quot & 0xff, STDLL); - writel(quot >> 8, STDLH); - writel(LCR_WLS0 | LCR_WLS1, STLCR); + /* Disable interrupts and FIFOs */ + writel(0, &uart_regs->ier); + writel(0, &uart_regs->fcr);
- writel(IER_UUE, STIER); /* Enable STUART */ - break; + /* Set baud rate */ + writel(LCR_WLS0 | LCR_WLS1 | LCR_DLAB, &uart_regs->lcr); + writel(divider & 0xff, &uart_regs->dll); + writel(divider >> 8, &uart_regs->dlh); + writel(LCR_WLS0 | LCR_WLS1, &uart_regs->lcr);
- default: - hang(); - } + /* Enable UART */ + writel(IER_UUE, &uart_regs->ier); }
- /* * Initialise the serial port with the given baudrate. The settings * are always 8 data bits, no parity, 1 stop bit, no start bits. - * */ -int pxa_init_dev (unsigned int uart_index) +int pxa_init_dev(unsigned int uart_index) { pxa_setbrg_dev (uart_index); - - return (0); + return 0; }
- /* * Output a single byte to the serial port. */ -void pxa_putc_dev (unsigned int uart_index,const char c) +void pxa_putc_dev(unsigned int uart_index, const char c) { - switch (uart_index) { - case FFUART_INDEX: - /* wait for room in the tx FIFO on FFUART */ - while ((readl(FFLSR) & LSR_TEMT) == 0) - WATCHDOG_RESET (); /* Reset HW Watchdog, if needed */ - writel(c, FFTHR); - break; - - case BTUART_INDEX: - while ((readl(BTLSR) & LSR_TEMT) == 0) - WATCHDOG_RESET (); /* Reset HW Watchdog, if needed */ - writel(c, BTTHR); - break; - - case STUART_INDEX: - while ((readl(STLSR) & LSR_TEMT) == 0) - WATCHDOG_RESET (); /* Reset HW Watchdog, if needed */ - writel(c, STTHR); - break; - } + struct pxa_uart_regs *uart_regs; + + uart_regs = pxa_uart_index_to_regs(uart_index); + if (!uart_regs) + hang(); + + while (!(readl(&uart_regs->lsr) & LSR_TEMT)) + WATCHDOG_RESET(); + writel(c, &uart_regs->thr);
/* If \n, also do \r */ if (c == '\n') @@ -185,17 +200,15 @@ void pxa_putc_dev (unsigned int uart_index,const char c) * otherwise. When the function is succesfull, the character read is * written into its argument c. */ -int pxa_tstc_dev (unsigned int uart_index) +int pxa_tstc_dev(unsigned int uart_index) { - switch (uart_index) { - case FFUART_INDEX: - return readl(FFLSR) & LSR_DR; - case BTUART_INDEX: - return readl(BTLSR) & LSR_DR; - case STUART_INDEX: - return readl(STLSR) & LSR_DR; - } - return -1; + struct pxa_uart_regs *uart_regs; + + uart_regs = pxa_uart_index_to_regs(uart_index); + if (!uart_regs) + return -1; + + return readl(&uart_regs->lsr) & LSR_DR; }
/* @@ -203,187 +216,86 @@ int pxa_tstc_dev (unsigned int uart_index) * otherwise. When the function is succesfull, the character read is * written into its argument c. */ -int pxa_getc_dev (unsigned int uart_index) +int pxa_getc_dev(unsigned int uart_index) { - switch (uart_index) { - case FFUART_INDEX: - while (!(readl(FFLSR) & LSR_DR)) - /* Reset HW Watchdog, if needed */ - WATCHDOG_RESET(); - return (char) readl(FFRBR) & 0xff; - - case BTUART_INDEX: - while (!(readl(BTLSR) & LSR_DR)) - /* Reset HW Watchdog, if needed */ - WATCHDOG_RESET(); - return (char) readl(BTRBR) & 0xff; - case STUART_INDEX: - while (!(readl(STLSR) & LSR_DR)) - /* Reset HW Watchdog, if needed */ - WATCHDOG_RESET(); - return (char) readl(STRBR) & 0xff; - } - return -1; -} + struct pxa_uart_regs *uart_regs;
-void -pxa_puts_dev (unsigned int uart_index,const char *s) -{ - while (*s) { - pxa_putc_dev (uart_index,*s++); - } -} + uart_regs = pxa_uart_index_to_regs(uart_index); + if (!uart_regs) + return -1;
-#if defined (CONFIG_FFUART) -static int ffuart_init(void) -{ - return pxa_init_dev(FFUART_INDEX); + while (!(readl(&uart_regs->lsr) & LSR_DR)) + WATCHDOG_RESET(); + return readl(&uart_regs->rbr) & 0xff; }
-static void ffuart_setbrg(void) +void pxa_puts_dev(unsigned int uart_index, const char *s) { - return pxa_setbrg_dev(FFUART_INDEX); + while (*s) + pxa_putc_dev(uart_index, *s++); }
-static void ffuart_putc(const char c) -{ - return pxa_putc_dev(FFUART_INDEX,c); -} - -static void ffuart_puts(const char *s) -{ - return pxa_puts_dev(FFUART_INDEX,s); -} - -static int ffuart_getc(void) -{ - return pxa_getc_dev(FFUART_INDEX); -} - -static int ffuart_tstc(void) -{ - return pxa_tstc_dev(FFUART_INDEX); -} - -struct serial_device serial_ffuart_device = -{ - "serial_ffuart", - ffuart_init, - NULL, - ffuart_setbrg, - ffuart_getc, - ffuart_tstc, - ffuart_putc, - ffuart_puts, -}; +#define pxa_uart(uart, UART) \ + int uart##_init(void) \ + { \ + return pxa_init_dev(UART##_INDEX); \ + } \ + \ + void uart##_setbrg(void) \ + { \ + return pxa_setbrg_dev(UART##_INDEX); \ + } \ + \ + void uart##_putc(const char c) \ + { \ + return pxa_putc_dev(UART##_INDEX, c); \ + } \ + \ + void uart##_puts(const char *s) \ + { \ + return pxa_puts_dev(UART##_INDEX, s); \ + } \ + \ + int uart##_getc(void) \ + { \ + return pxa_getc_dev(UART##_INDEX); \ + } \ + \ + int uart##_tstc(void) \ + { \ + return pxa_tstc_dev(UART##_INDEX); \ + } \ + +#define pxa_uart_desc(uart) \ + struct serial_device serial_##uart##_device = \ + { \ + "serial_"#uart, \ + uart##_init, \ + NULL, \ + uart##_setbrg, \ + uart##_getc, \ + uart##_tstc, \ + uart##_putc, \ + uart##_puts, \ + }; + +#define pxa_uart_multi(uart, UART) \ + pxa_uart(uart, UART) \ + pxa_uart_desc(uart) + +#if defined(CONFIG_HWUART) + pxa_uart_multi(hwuart, HWUART) #endif - -#if defined (CONFIG_BTUART) -static int btuart_init(void) -{ - return pxa_init_dev(BTUART_INDEX); -} - -static void btuart_setbrg(void) -{ - return pxa_setbrg_dev(BTUART_INDEX); -} - -static void btuart_putc(const char c) -{ - return pxa_putc_dev(BTUART_INDEX,c); -} - -static void btuart_puts(const char *s) -{ - return pxa_puts_dev(BTUART_INDEX,s); -} - -static int btuart_getc(void) -{ - return pxa_getc_dev(BTUART_INDEX); -} - -static int btuart_tstc(void) -{ - return pxa_tstc_dev(BTUART_INDEX); -} - -struct serial_device serial_btuart_device = -{ - "serial_btuart", - btuart_init, - NULL, - btuart_setbrg, - btuart_getc, - btuart_tstc, - btuart_putc, - btuart_puts, -}; +#if defined(CONFIG_STUART) + pxa_uart_multi(stuart, STUART) #endif - -#if defined (CONFIG_STUART) -static int stuart_init(void) -{ - return pxa_init_dev(STUART_INDEX); -} - -static void stuart_setbrg(void) -{ - return pxa_setbrg_dev(STUART_INDEX); -} - -static void stuart_putc(const char c) -{ - return pxa_putc_dev(STUART_INDEX,c); -} - -static void stuart_puts(const char *s) -{ - return pxa_puts_dev(STUART_INDEX,s); -} - -static int stuart_getc(void) -{ - return pxa_getc_dev(STUART_INDEX); -} - -static int stuart_tstc(void) -{ - return pxa_tstc_dev(STUART_INDEX); -} - -struct serial_device serial_stuart_device = -{ - "serial_stuart", - stuart_init, - NULL, - stuart_setbrg, - stuart_getc, - stuart_tstc, - stuart_putc, - stuart_puts, -}; +#if defined(CONFIG_FFUART) + pxa_uart_multi(ffuart, FFUART) +#endif +#if defined(CONFIG_BTUART) + pxa_uart_multi(btuart, BTUART) #endif
- -#ifndef CONFIG_SERIAL_MULTI -inline int serial_init(void) { - return (pxa_init_dev(UART_INDEX)); -} -void serial_setbrg(void) { - pxa_setbrg_dev(UART_INDEX); -} -int serial_getc(void) { - return(pxa_getc_dev(UART_INDEX)); -} -int serial_tstc(void) { - return(pxa_tstc_dev(UART_INDEX)); -} -void serial_putc(const char c) { - pxa_putc_dev(UART_INDEX,c); -} -void serial_puts(const char *s) { - pxa_puts_dev(UART_INDEX,s); -} -#endif /* CONFIG_SERIAL_MULTI */ +#ifndef CONFIG_SERIAL_MULTI + pxa_uart(serial, UART) +#endif
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- arch/arm/include/asm/arch-pxa/regs-mmc.h | 155 +++++++++++ drivers/mmc/Makefile | 1 + drivers/mmc/pxa_mmc_gen.c | 442 ++++++++++++++++++++++++++++++ 3 files changed, 598 insertions(+), 0 deletions(-) create mode 100644 arch/arm/include/asm/arch-pxa/regs-mmc.h create mode 100644 drivers/mmc/pxa_mmc_gen.c
diff --git a/arch/arm/include/asm/arch-pxa/regs-mmc.h b/arch/arm/include/asm/arch-pxa/regs-mmc.h new file mode 100644 index 0000000..fd1eb1e --- /dev/null +++ b/arch/arm/include/asm/arch-pxa/regs-mmc.h @@ -0,0 +1,155 @@ +/* + * Copyright (C) 2011 Marek Vasut marek.vasut@gmail.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __REGS_MMC_H__ +#define __REGS_MMC_H__ + +#define MMC0_BASE 0x41100000 +#define MMC1_BASE 0x42000000 + +int pxa_mmc_register(int card_index); + +struct pxa_mmc_regs { + uint32_t strpcl; + uint32_t stat; + uint32_t clkrt; + uint32_t spi; + uint32_t cmdat; + uint32_t resto; + uint32_t rdto; + uint32_t blklen; + uint32_t nob; + uint32_t prtbuf; + uint32_t i_mask; + uint32_t i_reg; + uint32_t cmd; + uint32_t argh; + uint32_t argl; + uint32_t res; + uint32_t rxfifo; + uint32_t txfifo; +}; + +/* MMC_STRPCL */ +#define MMC_STRPCL_STOP_CLK (1 << 0) +#define MMC_STRPCL_START_CLK (1 << 1) + +/* MMC_STAT */ +#define MMC_STAT_END_CMD_RES (1 << 13) +#define MMC_STAT_PRG_DONE (1 << 12) +#define MMC_STAT_DATA_TRAN_DONE (1 << 11) +#define MMC_STAT_CLK_EN (1 << 8) +#define MMC_STAT_RECV_FIFO_FULL (1 << 7) +#define MMC_STAT_XMIT_FIFO_EMPTY (1 << 6) +#define MMC_STAT_RES_CRC_ERROR (1 << 5) +#define MMC_STAT_SPI_READ_ERROR_TOKEN (1 << 4) +#define MMC_STAT_CRC_READ_ERROR (1 << 3) +#define MMC_STAT_CRC_WRITE_ERROR (1 << 2) +#define MMC_STAT_TIME_OUT_RESPONSE (1 << 1) +#define MMC_STAT_READ_TIME_OUT (1 << 0) + +/* MMC_CLKRT */ +#define MMC_CLKRT_20MHZ 0 +#define MMC_CLKRT_10MHZ 1 +#define MMC_CLKRT_5MHZ 2 +#define MMC_CLKRT_2_5MHZ 3 +#define MMC_CLKRT_1_25MHZ 4 +#define MMC_CLKRT_0_625MHZ 5 +#define MMC_CLKRT_0_3125MHZ 6 + +/* MMC_SPI */ +#define MMC_SPI_EN (1 << 0) +#define MMC_SPI_CS_EN (1 << 2) +#define MMC_SPI_CS_ADDRESS (1 << 3) +#define MMC_SPI_CRC_ON (1 << 1) + +/* MMC_CMDAT */ +#define MMC_CMDAT_SD_4DAT (1 << 8) +#define MMC_CMDAT_MMC_DMA_EN (1 << 7) +#define MMC_CMDAT_INIT (1 << 6) +#define MMC_CMDAT_BUSY (1 << 5) +#define MMC_CMDAT_BCR (MMC_CMDAT_BUSY | MMC_CMDAT_INIT) +#define MMC_CMDAT_STREAM (1 << 4) +#define MMC_CMDAT_WRITE (1 << 3) +#define MMC_CMDAT_DATA_EN (1 << 2) +#define MMC_CMDAT_R0 0 +#define MMC_CMDAT_R1 1 +#define MMC_CMDAT_R2 2 +#define MMC_CMDAT_R3 3 + +/* MMC_RESTO */ +#define MMC_RES_TO_MAX_MASK 0x7f + +/* MMC_RDTO */ +#define MMC_READ_TO_MAX_MASK 0xffff + +/* MMC_BLKLEN */ +#define MMC_BLK_LEN_MAX_MASK 0x3ff + +/* MMC_PRTBUF */ +#define MMC_PRTBUF_BUF_PART_FULL (1 << 0) + +/* MMC_I_MASK */ +#define MMC_I_MASK_TXFIFO_WR_REQ (1 << 6) +#define MMC_I_MASK_RXFIFO_RD_REQ (1 << 5) +#define MMC_I_MASK_CLK_IS_OFF (1 << 4) +#define MMC_I_MASK_STOP_CMD (1 << 3) +#define MMC_I_MASK_END_CMD_RES (1 << 2) +#define MMC_I_MASK_PRG_DONE (1 << 1) +#define MMC_I_MASK_DATA_TRAN_DONE (1 << 0) +#define MMC_I_MASK_ALL 0x7f + + +/* MMC_I_REG */ +#define MMC_I_REG_TXFIFO_WR_REQ (1 << 6) +#define MMC_I_REG_RXFIFO_RD_REQ (1 << 5) +#define MMC_I_REG_CLK_IS_OFF (1 << 4) +#define MMC_I_REG_STOP_CMD (1 << 3) +#define MMC_I_REG_END_CMD_RES (1 << 2) +#define MMC_I_REG_PRG_DONE (1 << 1) +#define MMC_I_REG_DATA_TRAN_DONE (1 << 0) + +/* MMC_CMD */ +#define MMC_CMD_INDEX_MAX 0x6f +#define CMD(x) (x) + +#define MMC_R1_IDLE_STATE 0x01 +#define MMC_R1_ERASE_STATE 0x02 +#define MMC_R1_ILLEGAL_CMD 0x04 +#define MMC_R1_COM_CRC_ERR 0x08 +#define MMC_R1_ERASE_SEQ_ERR 0x01 +#define MMC_R1_ADDR_ERR 0x02 +#define MMC_R1_PARAM_ERR 0x04 + +#define MMC_R1B_WP_ERASE_SKIP 0x0002 +#define MMC_R1B_ERR 0x0004 +#define MMC_R1B_CC_ERR 0x0008 +#define MMC_R1B_CARD_ECC_ERR 0x0010 +#define MMC_R1B_WP_VIOLATION 0x0020 +#define MMC_R1B_ERASE_PARAM 0x0040 +#define MMC_R1B_OOR 0x0080 +#define MMC_R1B_IDLE_STATE 0x0100 +#define MMC_R1B_ERASE_RESET 0x0200 +#define MMC_R1B_ILLEGAL_CMD 0x0400 +#define MMC_R1B_COM_CRC_ERR 0x0800 +#define MMC_R1B_ERASE_SEQ_ERR 0x1000 +#define MMC_R1B_ADDR_ERR 0x2000 +#define MMC_R1B_PARAM_ERR 0x4000 + +#endif /* __REGS_MMC_H__ */ diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 3968c14..59bda49 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -38,6 +38,7 @@ COBJS-$(CONFIG_MXC_MMC) += mxcmmc.o COBJS-$(CONFIG_OMAP3_MMC) += omap3_mmc.o COBJS-$(CONFIG_OMAP_HSMMC) += omap_hsmmc.o COBJS-$(CONFIG_PXA_MMC) += pxa_mmc.o +COBJS-$(CONFIG_PXA_MMC_GENERIC) += pxa_mmc_gen.o COBJS-$(CONFIG_S5P_MMC) += s5p_mmc.o COBJS-$(CONFIG_SDHCI) += sdhci.o COBJS-$(CONFIG_SH_MMCIF) += sh_mmcif.o diff --git a/drivers/mmc/pxa_mmc_gen.c b/drivers/mmc/pxa_mmc_gen.c new file mode 100644 index 0000000..aa475e5 --- /dev/null +++ b/drivers/mmc/pxa_mmc_gen.c @@ -0,0 +1,442 @@ +/* + * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com + * + * Loosely based on the old code and Linux's PXA MMC driver + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <common.h> +#include <malloc.h> + +#include <mmc.h> +#include <asm/errno.h> +#include <asm/arch/hardware.h> +#include <asm/arch/regs-mmc.h> +#include <asm/io.h> + +/* PXAMMC Generic default config for various CPUs */ +#if defined(CONFIG_PXA250) +#define PXAMMC_FIFO_SIZE 1 +#define PXAMMC_MIN_SPEED 312500 +#define PXAMMC_MAX_SPEED 20000000 +#define PXAMMC_HOST_CAPS (0) +#elif defined(CONFIG_PXA27X) +#define PXAMMC_CRC_SKIP +#define PXAMMC_FIFO_SIZE 32 +#define PXAMMC_MIN_SPEED 304000 +#define PXAMMC_MAX_SPEED 19500000 +#define PXAMMC_HOST_CAPS (MMC_MODE_4BIT) +#elif defined(CONFIG_CPU_MONAHANS) +#define PXAMMC_FIFO_SIZE 32 +#define PXAMMC_MIN_SPEED 304000 +#define PXAMMC_MAX_SPEED 26000000 +#define PXAMMC_HOST_CAPS (MMC_MODE_4BIT | MMC_MODE_HS) +#else +#error "This CPU isn't supported by PXA MMC!" +#endif + +#define MMC_STAT_ERRORS \ + (MMC_STAT_RES_CRC_ERROR | MMC_STAT_SPI_READ_ERROR_TOKEN | \ + MMC_STAT_CRC_READ_ERROR | MMC_STAT_TIME_OUT_RESPONSE | \ + MMC_STAT_READ_TIME_OUT | MMC_STAT_CRC_WRITE_ERROR) + +/* 1 millisecond (in wait cycles below it's 100 x 10uS waits) */ +#define PXA_MMC_TIMEOUT 100 + +struct pxa_mmc_priv { + struct pxa_mmc_regs *regs; +}; + +/* Wait for bit to be set */ +static int pxa_mmc_wait(struct mmc *mmc, uint32_t mask) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + unsigned int timeout = PXA_MMC_TIMEOUT; + + /* Wait for bit to be set */ + while (--timeout) { + if (readl(®s->stat) & mask) + break; + udelay(10); + } + + if (!timeout) + return -ETIMEDOUT; + + return 0; +} + +static int pxa_mmc_stop_clock(struct mmc *mmc) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + unsigned int timeout = PXA_MMC_TIMEOUT; + + /* If the clock aren't running, exit */ + if (!(readl(®s->stat) & MMC_STAT_CLK_EN)) + return 0; + + /* Tell the controller to turn off the clock */ + writel(MMC_STRPCL_STOP_CLK, ®s->strpcl); + + /* Wait until the clock are off */ + while (--timeout) { + if (!(readl(®s->stat) & MMC_STAT_CLK_EN)) + break; + udelay(10); + } + + /* The clock refused to stop, scream and die a painful death */ + if (!timeout) + return -ETIMEDOUT; + + /* The clock stopped correctly */ + return 0; +} + +static int pxa_mmc_start_cmd(struct mmc *mmc, struct mmc_cmd *cmd, + uint32_t cmdat) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + int ret; + + /* The card can send a "busy" response */ + if (cmd->flags & MMC_RSP_BUSY) + cmdat |= MMC_CMDAT_BUSY; + + /* Inform the controller about response type */ + switch (cmd->resp_type) { + case MMC_RSP_R1: + case MMC_RSP_R1b: + cmdat |= MMC_CMDAT_R1; + break; + case MMC_RSP_R2: + cmdat |= MMC_CMDAT_R2; + break; + case MMC_RSP_R3: + cmdat |= MMC_CMDAT_R3; + break; + default: + break; + } + + /* Load command and it's arguments into the controller */ + writel(cmd->cmdidx, ®s->cmd); + writel(cmd->cmdarg >> 16, ®s->argh); + writel(cmd->cmdarg & 0xffff, ®s->argl); + writel(cmdat, ®s->cmdat); + + /* Start the controller clock and wait until they are started */ + writel(MMC_STRPCL_START_CLK, ®s->strpcl); + + ret = pxa_mmc_wait(mmc, MMC_STAT_CLK_EN); + if (ret) + return ret; + + /* Correct and happy end */ + return 0; +} + +static int pxa_mmc_cmd_done(struct mmc *mmc, struct mmc_cmd *cmd) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + uint32_t a, b, c; + int i; + int stat; + + /* Read the controller status */ + stat = readl(®s->stat); + + /* + * Linux says: + * Did I mention this is Sick. We always need to + * discard the upper 8 bits of the first 16-bit word. + */ + a = readl(®s->res) & 0xffff; + for (i = 0; i < 4; i++) { + b = readl(®s->res) & 0xffff; + c = readl(®s->res) & 0xffff; + cmd->response[i] = (a << 24) | (b << 8) | (c >> 8); + a = c; + } + + /* The command response didn't arrive */ + if (stat & MMC_STAT_TIME_OUT_RESPONSE) + return -ETIMEDOUT; + else if (stat & MMC_STAT_RES_CRC_ERROR && cmd->flags & MMC_RSP_CRC) { +#ifdef PXAMMC_CRC_SKIP + if (cmd->flags & MMC_RSP_136 && cmd->response[0] & (1 << 31)) + printf("Ignoring CRC, this may be dangerous!\n"); + else +#endif + return -EILSEQ; + } + + /* The command response was successfully read */ + return 0; +} + +static int pxa_mmc_do_read_xfer(struct mmc *mmc, struct mmc_data *data) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + uint32_t len; + uint32_t *buf = (uint32_t *)data->dest; + int size; + int ret; + + len = data->blocks * data->blocksize; + + while (len) { + /* The controller has data ready */ + if (readl(®s->i_reg) & MMC_I_REG_RXFIFO_RD_REQ) { + size = min(len, PXAMMC_FIFO_SIZE); + len -= size; + size /= 4; + + /* Read data into the buffer */ + while (size--) + *buf++ = readl(®s->rxfifo); + + } + + if (readl(®s->stat) & MMC_STAT_ERRORS) + return -EIO; + } + + /* Wait for the transmission-done interrupt */ + ret = pxa_mmc_wait(mmc, MMC_STAT_DATA_TRAN_DONE); + if (ret) + return ret; + + return 0; +} + +static int pxa_mmc_do_write_xfer(struct mmc *mmc, struct mmc_data *data) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + uint32_t len; + uint32_t *buf = (uint32_t *)data->src; + int size; + int ret; + + len = data->blocks * data->blocksize; + + while (len) { + /* The controller is ready to receive data */ + if (readl(®s->i_reg) & MMC_I_REG_TXFIFO_WR_REQ) { + size = min(len, PXAMMC_FIFO_SIZE); + len -= size; + size /= 4; + + while (size--) + writel(*buf++, ®s->txfifo); + + if (min(len, PXAMMC_FIFO_SIZE) < 32) + writel(MMC_PRTBUF_BUF_PART_FULL, ®s->prtbuf); + } + + if (readl(®s->stat) & MMC_STAT_ERRORS) + return -EIO; + } + + /* Wait for the transmission-done interrupt */ + ret = pxa_mmc_wait(mmc, MMC_STAT_DATA_TRAN_DONE); + if (ret) + return ret; + + /* Wait until the data are really written to the card */ + ret = pxa_mmc_wait(mmc, MMC_STAT_PRG_DONE); + if (ret) + return ret; + + return 0; +} + +static int pxa_mmc_request(struct mmc *mmc, struct mmc_cmd *cmd, + struct mmc_data *data) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + uint32_t cmdat = 0; + int ret; + + /* Stop the controller */ + ret = pxa_mmc_stop_clock(mmc); + if (ret) + return ret; + + /* If we're doing data transfer, configure the controller accordingly */ + if (data) { + writel(data->blocks, ®s->nob); + writel(data->blocksize, ®s->blklen); + /* This delay can be optimized, but stick with max value */ + writel(0xffff, ®s->rdto); + cmdat |= MMC_CMDAT_DATA_EN; + if (data->flags & MMC_DATA_WRITE) + cmdat |= MMC_CMDAT_WRITE; + } + + /* Run in 4bit mode if the card can do it */ + if (mmc->bus_width == 4) + cmdat |= MMC_CMDAT_SD_4DAT; + + /* Execute the command */ + ret = pxa_mmc_start_cmd(mmc, cmd, cmdat); + if (ret) + return ret; + + /* Wait until the command completes */ + ret = pxa_mmc_wait(mmc, MMC_STAT_END_CMD_RES); + if (ret) + return ret; + + /* Read back the result */ + ret = pxa_mmc_cmd_done(mmc, cmd); + if (ret) + return ret; + + /* In case there was a data transfer scheduled, do it */ + if (data) { + if (data->flags & MMC_DATA_WRITE) + pxa_mmc_do_write_xfer(mmc, data); + else + pxa_mmc_do_read_xfer(mmc, data); + } + + return 0; +} + +static void pxa_mmc_set_ios(struct mmc *mmc) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + uint32_t tmp; + uint32_t pxa_mmc_clock; + + if (!mmc->clock) { + pxa_mmc_stop_clock(mmc); + return; + } + + /* PXA3xx can do 26MHz with special settings. */ + if (mmc->clock == 26000000) { + writel(0x7, ®s->clkrt); + return; + } + + /* Set clock to the card the usual way. */ + pxa_mmc_clock = 0; + tmp = mmc->f_max / mmc->clock; + tmp += tmp % 2; + + while (tmp > 1) { + pxa_mmc_clock++; + tmp >>= 1; + } + + writel(pxa_mmc_clock, ®s->clkrt); +} + +static int pxa_mmc_init(struct mmc *mmc) +{ + struct pxa_mmc_priv *priv = (struct pxa_mmc_priv *)mmc->priv; + struct pxa_mmc_regs *regs = priv->regs; + + /* Make sure the clock are stopped */ + pxa_mmc_stop_clock(mmc); + + /* Turn off SPI mode */ + writel(0, ®s->spi); + + /* Set up maximum timeout to wait for command response */ + writel(MMC_RES_TO_MAX_MASK, ®s->resto); + + /* Mask all interrupts */ + writel(~(MMC_I_MASK_TXFIFO_WR_REQ | MMC_I_MASK_RXFIFO_RD_REQ), + ®s->i_mask); + return 0; +} + +int pxa_mmc_register(int card_index) +{ + struct mmc *mmc; + struct pxa_mmc_priv *priv; + uint32_t reg; + int ret = -ENOMEM; + + mmc = malloc(sizeof(struct mmc)); + if (!mmc) + goto err0; + + priv = malloc(sizeof(struct pxa_mmc_priv)); + if (!priv) + goto err1; + + switch (card_index) { + case 0: + priv->regs = (struct pxa_mmc_regs *)MMC0_BASE; + break; + case 1: + priv->regs = (struct pxa_mmc_regs *)MMC1_BASE; + break; + default: + printf("PXA MMC: Invalid MMC controller ID (card_index = %d)\n", + card_index); + goto err2; + } + + mmc->priv = priv; + + sprintf(mmc->name, "PXA MMC"); + mmc->send_cmd = pxa_mmc_request; + mmc->set_ios = pxa_mmc_set_ios; + mmc->init = pxa_mmc_init; + + mmc->voltages = MMC_VDD_32_33 | MMC_VDD_33_34; + mmc->f_max = PXAMMC_MAX_SPEED; + mmc->f_min = PXAMMC_MIN_SPEED; + mmc->host_caps = PXAMMC_HOST_CAPS; + + mmc->b_max = 0; + +#ifndef CONFIG_CPU_MONAHANS /* PXA2xx */ + reg = readl(CKEN); + reg |= CKEN12_MMC; + writel(reg, CKEN); +#else /* PXA3xx */ + reg = readl(CKENA); + reg |= CKENA_12_MMC0 | CKENA_13_MMC1; + writel(reg, CKENA); +#endif + + mmc_register(mmc); + + return 0; + +err2: + free(priv); +err1: + free(mmc); +err0: + return ret; +}
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- board/vpac270/vpac270.c | 8 ++++++++ include/configs/vpac270.h | 3 ++- 2 files changed, 10 insertions(+), 1 deletions(-)
diff --git a/board/vpac270/vpac270.c b/board/vpac270/vpac270.c index 43bbdff..d3f03c0 100644 --- a/board/vpac270/vpac270.c +++ b/board/vpac270/vpac270.c @@ -21,6 +21,7 @@
#include <common.h> #include <asm/arch/hardware.h> +#include <asm/arch/regs-mmc.h> #include <netdev.h> #include <serial.h> #include <asm/io.h> @@ -72,6 +73,13 @@ void dram_init_banksize(void) #endif }
+#ifdef CONFIG_CMD_MMC +int board_mmc_init(bd_t *bis) +{ + pxa_mmc_register(0); +} +#endif + #ifdef CONFIG_CMD_USB int usb_board_init(void) { diff --git a/include/configs/vpac270.h b/include/configs/vpac270.h index ea77971..9c3980d 100644 --- a/include/configs/vpac270.h +++ b/include/configs/vpac270.h @@ -108,7 +108,8 @@ */ #ifdef CONFIG_CMD_MMC #define CONFIG_MMC -#define CONFIG_PXA_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_PXA_MMC_GENERIC #define CONFIG_SYS_MMC_BASE 0xF0000000 #define CONFIG_CMD_FAT #define CONFIG_CMD_EXT2
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- drivers/usb/host/ohci-hcd.c | 69 +++++++++++++++++++++++------------------- 1 files changed, 38 insertions(+), 31 deletions(-)
diff --git a/drivers/usb/host/ohci-hcd.c b/drivers/usb/host/ohci-hcd.c index bc8bb20..653f97d 100644 --- a/drivers/usb/host/ohci-hcd.c +++ b/drivers/usb/host/ohci-hcd.c @@ -1263,12 +1263,19 @@ static int ohci_submit_rh_msg(struct usb_device *dev, unsigned long pipe, int len = 0; int stat = 0; __u32 datab[4]; - __u8 *data_buf = (__u8 *)datab; + union { + void *ptr; + __u8 *u8; + __u16 *u16; + __u32 *u32; + } databuf; __u16 bmRType_bReq; __u16 wValue; __u16 wIndex; __u16 wLength;
+ databuf.u32 = (__u32 *)datab; + #ifdef DEBUG pkt_print(NULL, dev, pipe, buffer, transfer_len, cmd, "SUB(rh)", usb_pipein(pipe)); @@ -1298,20 +1305,20 @@ pkt_print(NULL, dev, pipe, buffer, transfer_len, */
case RH_GET_STATUS: - *(__u16 *) data_buf = cpu_to_le16(1); + databuf.u16[0] = cpu_to_le16(1); OK(2); case RH_GET_STATUS | RH_INTERFACE: - *(__u16 *) data_buf = cpu_to_le16(0); + databuf.u16[0] = cpu_to_le16(0); OK(2); case RH_GET_STATUS | RH_ENDPOINT: - *(__u16 *) data_buf = cpu_to_le16(0); + databuf.u16[0] = cpu_to_le16(0); OK(2); case RH_GET_STATUS | RH_CLASS: - *(__u32 *) data_buf = cpu_to_le32( + databuf.u32[0] = cpu_to_le32( RD_RH_STAT & ~(RH_HS_CRWE | RH_HS_DRWE)); OK(4); case RH_GET_STATUS | RH_OTHER | RH_CLASS: - *(__u32 *) data_buf = cpu_to_le32(RD_RH_PORTSTAT); + databuf.u32[0] = cpu_to_le32(RD_RH_PORTSTAT); OK(4);
case RH_CLEAR_FEATURE | RH_ENDPOINT: @@ -1375,14 +1382,14 @@ pkt_print(NULL, dev, pipe, buffer, transfer_len, min_t(unsigned int, sizeof(root_hub_dev_des), wLength)); - data_buf = root_hub_dev_des; OK(len); + databuf.ptr = root_hub_dev_des; OK(len); case (0x02): /* configuration descriptor */ len = min_t(unsigned int, leni, min_t(unsigned int, sizeof(root_hub_config_des), wLength)); - data_buf = root_hub_config_des; OK(len); + databuf.ptr = root_hub_config_des; OK(len); case (0x03): /* string descriptors */ if (wValue == 0x0300) { len = min_t(unsigned int, @@ -1390,7 +1397,7 @@ pkt_print(NULL, dev, pipe, buffer, transfer_len, min_t(unsigned int, sizeof(root_hub_str_index0), wLength)); - data_buf = root_hub_str_index0; + databuf.ptr = root_hub_str_index0; OK(len); } if (wValue == 0x0301) { @@ -1399,7 +1406,7 @@ pkt_print(NULL, dev, pipe, buffer, transfer_len, min_t(unsigned int, sizeof(root_hub_str_index1), wLength)); - data_buf = root_hub_str_index1; + databuf.ptr = root_hub_str_index1; OK(len); } default: @@ -1411,39 +1418,39 @@ pkt_print(NULL, dev, pipe, buffer, transfer_len, { __u32 temp = roothub_a(&gohci);
- data_buf [0] = 9; /* min length; */ - data_buf [1] = 0x29; - data_buf [2] = temp & RH_A_NDP; + databuf.u8[0] = 9; /* min length; */ + databuf.u8[1] = 0x29; + databuf.u8[2] = temp & RH_A_NDP; #ifdef CONFIG_AT91C_PQFP_UHPBUG - data_buf [2] = (data_buf [2] == 2) ? 1:0; + databuf.u8[2] = (databuf.u8[2] == 2) ? 1:0; #endif - data_buf [3] = 0; + databuf.u8[3] = 0; if (temp & RH_A_PSM) /* per-port power switching? */ - data_buf [3] |= 0x1; + databuf.u8[3] |= 0x1; if (temp & RH_A_NOCP) /* no overcurrent reporting? */ - data_buf [3] |= 0x10; + databuf.u8[3] |= 0x10; else if (temp & RH_A_OCPM)/* per-port overcurrent reporting? */ - data_buf [3] |= 0x8; + databuf.u8[3] |= 0x8;
- /* corresponds to data_buf[4-7] */ - datab [1] = 0; - data_buf [5] = (temp & RH_A_POTPGT) >> 24; + /* corresponds to databuf.u8[4-7] */ + databuf.u8[1] = 0; + databuf.u8[5] = (temp & RH_A_POTPGT) >> 24; temp = roothub_b(&gohci); - data_buf [7] = temp & RH_B_DR; - if (data_buf [2] < 7) { - data_buf [8] = 0xff; + databuf.u8[7] = temp & RH_B_DR; + if (databuf.u8[2] < 7) { + databuf.u8[8] = 0xff; } else { - data_buf [0] += 2; - data_buf [8] = (temp & RH_B_DR) >> 8; - data_buf [10] = data_buf [9] = 0xff; + databuf.u8[0] += 2; + databuf.u8[8] = (temp & RH_B_DR) >> 8; + databuf.u8[10] = databuf.u8[9] = 0xff; }
len = min_t(unsigned int, leni, - min_t(unsigned int, data_buf [0], wLength)); + min_t(unsigned int, databuf.u8[0], wLength)); OK(len); }
- case RH_GET_CONFIGURATION: *(__u8 *) data_buf = 0x01; OK(1); + case RH_GET_CONFIGURATION: databuf.u8[0] = 0x01; OK(1);
case RH_SET_CONFIGURATION: WR_RH_STAT(0x10000); OK(0);
@@ -1459,8 +1466,8 @@ pkt_print(NULL, dev, pipe, buffer, transfer_len, #endif
len = min_t(int, len, leni); - if (data != data_buf) - memcpy(data, data_buf, len); + if (data != databuf.ptr) + memcpy(data, databuf.ptr, len); dev->act_len = len; dev->status = stat;
Signed-off-by: Marek Vasut marek.vasut@gmail.com --- common/cmd_ide.c | 51 +++++++++++++++++++++++++-------------------------- 1 files changed, 25 insertions(+), 26 deletions(-)
diff --git a/common/cmd_ide.c b/common/cmd_ide.c index 2e8c6e0..da5189c 100644 --- a/common/cmd_ide.c +++ b/common/cmd_ide.c @@ -985,9 +985,8 @@ input_data(int dev, ulong *sect_buf, int words) */ static void ide_ident (block_dev_desc_t *dev_desc) { - ulong iobuf[ATA_SECTORWORDS]; unsigned char c; - hd_driveid_t *iop = (hd_driveid_t *)iobuf; + hd_driveid_t iop;
#ifdef CONFIG_ATAPI int retries = 0; @@ -1073,11 +1072,11 @@ static void ide_ident (block_dev_desc_t *dev_desc) return; #endif
- input_swap_data (device, iobuf, ATA_SECTORWORDS); + input_swap_data (device, (ulong *)&iop, ATA_SECTORWORDS);
- ident_cpy ((unsigned char*)dev_desc->revision, iop->fw_rev, sizeof(dev_desc->revision)); - ident_cpy ((unsigned char*)dev_desc->vendor, iop->model, sizeof(dev_desc->vendor)); - ident_cpy ((unsigned char*)dev_desc->product, iop->serial_no, sizeof(dev_desc->product)); + ident_cpy ((unsigned char*)dev_desc->revision, iop.fw_rev, sizeof(dev_desc->revision)); + ident_cpy ((unsigned char*)dev_desc->vendor, iop.model, sizeof(dev_desc->vendor)); + ident_cpy ((unsigned char*)dev_desc->product, iop.serial_no, sizeof(dev_desc->product)); #ifdef __LITTLE_ENDIAN /* * firmware revision, model, and serial number have Big Endian Byte @@ -1092,14 +1091,14 @@ static void ide_ident (block_dev_desc_t *dev_desc) strswab (dev_desc->product); #endif /* __LITTLE_ENDIAN */
- if ((iop->config & 0x0080)==0x0080) + if ((iop.config & 0x0080) == 0x0080) dev_desc->removable = 1; else dev_desc->removable = 0;
#ifdef CONFIG_TUNE_PIO /* Mode 0 - 2 only, are directly determined by word 51. */ - pio_mode = iop->tPIO; + pio_mode = iop.tPIO; if (pio_mode > 2) { printf("WARNING: Invalid PIO (word 51 = %d).\n", pio_mode); pio_mode = 0; /* Force it to dead slow, and hope for the best... */ @@ -1109,18 +1108,18 @@ static void ide_ident (block_dev_desc_t *dev_desc) * shall set bit 1 of word 53 to one and support the fields contained * in words 64 through 70. */ - if (iop->field_valid & 0x02) { + if (iop.field_valid & 0x02) { /* Mode 3 and above are possible. Check in order from slow * to fast, so we wind up with the highest mode allowed. */ - if (iop->eide_pio_modes & 0x01) + if (iop.eide_pio_modes & 0x01) pio_mode = 3; - if (iop->eide_pio_modes & 0x02) + if (iop.eide_pio_modes & 0x02) pio_mode = 4; - if (ata_id_is_cfa((u16 *)iop)) { - if ((iop->cf_advanced_caps & 0x07) == 0x01) + if (ata_id_is_cfa((u16 *)&iop)) { + if ((iop.cf_advanced_caps & 0x07) == 0x01) pio_mode = 5; - if ((iop->cf_advanced_caps & 0x07) == 0x02) + if ((iop.cf_advanced_caps & 0x07) == 0x02) pio_mode = 6; } } @@ -1133,19 +1132,19 @@ static void ide_ident (block_dev_desc_t *dev_desc) /* * Drive PIO mode autoselection */ - mode = iop->tPIO; + mode = iop.tPIO;
printf ("tPIO = 0x%02x = %d\n",mode, mode); if (mode > 2) { /* 2 is maximum allowed tPIO value */ mode = 2; debug ("Override tPIO -> 2\n"); } - if (iop->field_valid & 2) { /* drive implements ATA2? */ + if (iop.field_valid & 2) { /* drive implements ATA2? */ debug ("Drive implements ATA2\n"); - if (iop->capability & 8) { /* drive supports use_iordy? */ - cycle_time = iop->eide_pio_iordy; + if (iop.capability & 8) { /* drive supports use_iordy? */ + cycle_time = iop.eide_pio_iordy; } else { - cycle_time = iop->eide_pio; + cycle_time = iop.eide_pio; } debug ("cycle time = %d\n", cycle_time); mode = 4; @@ -1166,7 +1165,7 @@ static void ide_ident (block_dev_desc_t *dev_desc)
#ifdef __BIG_ENDIAN /* swap shorts */ - dev_desc->lba = (iop->lba_capacity << 16) | (iop->lba_capacity >> 16); + dev_desc->lba = (iop.lba_capacity << 16) | (iop.lba_capacity >> 16); #else /* ! __BIG_ENDIAN */ /* * do not swap shorts on little endian @@ -1174,16 +1173,16 @@ static void ide_ident (block_dev_desc_t *dev_desc) * See CF+ and CompactFlash Specification Revision 2.0: * 6.2.1.6: Identfy Drive, Table 39, Word Address 57-58 for details. */ - dev_desc->lba = iop->lba_capacity; + dev_desc->lba = iop.lba_capacity; #endif /* __BIG_ENDIAN */
#ifdef CONFIG_LBA48 - if (iop->command_set_2 & 0x0400) { /* LBA 48 support */ + if (iop.command_set_2 & 0x0400) { /* LBA 48 support */ dev_desc->lba48 = 1; - dev_desc->lba = (unsigned long long)iop->lba48_capacity[0] | - ((unsigned long long)iop->lba48_capacity[1] << 16) | - ((unsigned long long)iop->lba48_capacity[2] << 32) | - ((unsigned long long)iop->lba48_capacity[3] << 48); + dev_desc->lba = (unsigned long long)iop.lba48_capacity[0] | + ((unsigned long long)iop.lba48_capacity[1] << 16) | + ((unsigned long long)iop.lba48_capacity[2] << 32) | + ((unsigned long long)iop.lba48_capacity[3] << 48); } else { dev_desc->lba48 = 0; }
Dear Marek Vasut,
In message 1314507088-1472-1-git-send-email-marek.vasut@gmail.com you wrote:
- Cleanup register definitions by introducing new regs-uart.h, compliant with rest of U-Boot.
- Remove old register definitions from pxa-regs.h
- Convert serial_pxa to new regs-uart.h
- Cleanup serial_pxa
Your patch stacks are a mess. It's impossible for mne to tell what you actually intend.
So we have now tow series:
1: [PATCH 1/6] PXA: Fix Lubbock, remove redundant parenthesis 1: [PATCH 2/6] PXA: Fix CSB226, fix monitor length 1: [PATCH 3/6] USB: Fix complaints about strict aliasing in OHCI-HCD 1: [PATCH 4/6] IDE: Fix complaints about strict aliasing in cmd_ide.c 1: [PATCH 5/6] PXA: Cleanup serial_pxa 1: [PATCH 6/6] PXA: vpac270: Remove re-defined CONFIG_SYS_TEXT_BASE
2: [PATCH 1/5 V2] PXA: Cleanup serial_pxa 2: [PATCH 3/5] PXA: vpac270: Enable the new generic MMC driver 2: [PATCH 2/5] PXA: Add MMC driver using the generic MMC framework 2: [PATCH 4/5 RESEND] USB: Fix complaints about strict aliasing in OHCI-HCD 2: [PATCH 5/5 RESEND] IDE: Fix complaints about strict aliasing in cmd_id
It appears as if "2: [PATCH 1/5 V2]" might be a replacement for "1: [PATCH 5/6]" - but then, it does not contain any of the required In-reply-to: and/or References: headers.
It appears as if "2: [PATCH 4/5 RESEND]" and "2: [PATCH 5/5 RESEND]" might be (unchanged ???) Repostings of ""1: [PATCH 3/6]" resp. "1: [PATCH 4/6]" - but then, why do you repost these at all? You are not supposed to resubmit patches without changes.
Also, it does not appears as if the whole 2nd series was a replacement / update for the first, as there are no equivalents for "1: [PATCH 1/6]" or "1: [PATCH 2/6]'.
All in all, this is a terrible mess, and in violation of patch submission rules.
Please consider both patch series NAKed.
Fix your code and clean up as needed, then repost but please with proper version information, proper change logs, and proper mail threading.
Thanks.
On Sunday, August 28, 2011 12:16:18 PM Wolfgang Denk wrote:
Dear Marek Vasut,
Yes, it didn't work out a bit here. I tried to split the stuff so Albert can pick up what's for him and then the rest for review.
Can you just review this series and scrap the other one please?
Thanks
Cheers
Thanks.
Dear Marek Vasut,
"This" being the second (5 parts), and "the other" being the first (6 parts)?
That means we also ignore your pull request, which refers to the first series?
I revommend you restart from a clean state. Split off independent patches that are not actually forming a series, and then send a new pull rq.
On Sunday, August 28, 2011 10:58:37 PM Wolfgang Denk wrote:
Dear Marek Vasut,
Yes
No, the pull request _IS_FINE_. I picked the patches that are good for Albert to pick (fixes). These would be good to have in 2011.09.
Then I submitted again the rest of the patches I have in stack ... 5 part series. I just want review on these, I don't intend to have them in 2011.09.
The 6 part series is wrong and should be scrapped.
The pull request is fine, so it's no use to resend it again. It can be pulled.
I'll resend the patches in a smaller chunks.
Cheers
