[PATCH] cmd: pxe_utils: Check fdtcontroladdr in label_boot
If using OF_CONTROL, fdtcontroladdr is set to the fdt used to configure U-Boot. When using PXE, if no fdt is defined in the menu file, and there is no fdt at fdt_addr, add fall back on fdtcontroladdr too.
We are developing board support for the Armv8r64 FVP using config_distro_bootcmd. We are also using OF_BOARD and would like the PXE boot option to default to the fdt provided by board_fdt_blob_setup.
Signed-off-by: Peter Hoyes Peter.Hoyes@arm.com --- cmd/pxe_utils.c | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/cmd/pxe_utils.c b/cmd/pxe_utils.c index 067c24e5ff..8f8e69ca97 100644 --- a/cmd/pxe_utils.c +++ b/cmd/pxe_utils.c @@ -556,7 +556,10 @@ static int label_boot(struct cmd_tbl *cmdtp, struct pxe_label *label) * Scenario 2: If there is an fdt_addr specified, pass it along to * bootm, and adjust argc appropriately. * - * Scenario 3: fdt blob is not available. + * Scenario 3: If there is an fdtcontroladdr specified, pass it along to + * bootm, and adjust argc appropriately. + * + * Scenario 4: fdt blob is not available. */ bootm_argv[3] = env_get("fdt_addr_r");
@@ -646,6 +649,9 @@ static int label_boot(struct cmd_tbl *cmdtp, struct pxe_label *label) if (!bootm_argv[3]) bootm_argv[3] = env_get("fdt_addr");
+ if (!bootm_argv[3]) + bootm_argv[3] = env_get("fdtcontroladdr"); + if (bootm_argv[3]) { if (!bootm_argv[2]) bootm_argv[2] = "-";
Hi Peter,
if (!bootm_argv[3])
-- 2.25.1
This is a bit strange as fdtcontroladdr is the control dtb that U-Boot uses. Can you not set fdt_addr to that, if you need to? Is it not already set to that?
Also, there is a clean-up series for this code outstanding. I will send v3 and copy you, if you are able to review it.
On Thu, 14 Oct 2021 12:24:45 -0600 Simon Glass sjg@chromium.org wrote:
Hi Simon,
if (!bootm_argv[3])
-- 2.25.1
Yes, that is the idea. This DTB should be as good as any, and this is the last check before giving up on DTs completely, so "U-Boot's DTB" (actually there is no such thing) is better than none at all. In fact EFI boot does the very same thing: https://source.denx.de/u-boot/u-boot/-/blob/master/include/config_distro_boo...
According to doc/README.distro, fdt_addr is reserved for DTBs residing at a (fixed?) ROM address. We don't really know yet where the DT comes from, the cleanest seems to be to be passed down from TF-A, in which case this would definitely not be ROM. board_fdt_blob_setup() knows this address, and this is what will be written to $fdtcontroladdr.
FWIW, this patch looks good to me.
Cheers, Andre
Hi Simon,
if (!bootm_argv[3])
-- 2.25.1
OK.
But note that OF_BOARD is going to become an option, not something that let's us leave out the DT. Board vendors must provide a DT in U-Boot. So long as that is understood:
Regards, Simom
Hi Simon,
if (!bootm_argv[3])
-- 2.25.1
OK.
Regards, Simom
applied to u-boot-net/next Thanks, Ramon.
Hi Simon,
if (!bootm_argv[3])
-- 2.25.1
OK.
Regards, Simom
Thanks for accepting this patch. I wondered if you could give an indication when it will reach u-boot/master?
Cheers,
Peter
IMPORTANT NOTICE: The contents of this email and any attachments are confidential and may also be privileged. If you are not the intended recipient, please notify the sender immediately and do not disclose the contents to any other person, use it for any purpose, or store or copy the information in any medium. Thank you.
Hi Simon,
if (!bootm_argv[3])
-- 2.25.1
OK.
Regards, Simom
Cheers,
Peter
Follow the pull request I sent to Tom.
*/ bootm_argv[3] = env_get("fdt_addr_r");* Scenario 4: fdt blob is not available.
- if (!bootm_argv[3])
- if (bootm_argv[3]) { if (!bootm_argv[2]) bootm_argv[2] = "-";
This change makes a regression when using a FIT image as kernel image within an extlinux.conf
Before this change, when a DT wasn't specified, the DT in the FIT image was selected, not the u-boot DT is selected.
While it should work because the U-Boot DT should work in Linux, it's not always the case.
Before: Found /extlinux/extlinux.conf Retrieving file: /extlinux/extlinux.conf 1: Yocto Retrieving file: /fitImage append: root=PARTUUID=fd26d57f-02 rootwait console=ttyAML0,115200 ## Loading kernel from FIT Image at 08080000 ... Using 'conf-amlogic_meson-gxl-s905x-libretech-cc.dtb' configuration Trying 'kernel-1' kernel subimage Description: Linux kernel Type: Kernel Image Compression: gzip compressed Data Start: 0x08080120 Data Size: 9926956 Bytes = 9.5 MiB Architecture: AArch64 OS: Linux Load Address: 0x01080000 Entry Point: 0x01080000 Hash algo: sha256 Hash value: 5181a76e4e7a728e24cd8569f8e48c543ac259bf4d66591a3dc5e166d709429e Verifying Hash Integrity ... sha256+ OK ## Loading fdt from FIT Image at 08080000 ... Using 'conf-amlogic_meson-gxl-s905x-libretech-cc.dtb' configuration Trying 'fdt-amlogic_meson-gxl-s905x-libretech-cc.dtb' fdt subimage Description: Flattened Device Tree blob Type: Flat Device Tree Compression: uncompressed Data Start: 0x089f7b78 Data Size: 29092 Bytes = 28.4 KiB Architecture: AArch64 Hash algo: sha256 Hash value: 72e5e4fcbb4aa59042377720e5636132ba790d85b6c3f6442446acc63f48cf67 Verifying Hash Integrity ... sha256+ OK Booting using the fdt blob at 0x89f7b78 Uncompressing Kernel Image Loading Device Tree to 000000007bf2f000, end 000000007bf391a3 ... OK
After: Found /extlinux/extlinux.conf Retrieving file: /extlinux/extlinux.conf 1: Yocto Retrieving file: /fitImage append: root=PARTUUID=fd26d57f-02 rootwait console=ttyAML0,115200 ## Loading kernel from FIT Image at 08080000 ... Using 'conf-amlogic_meson-gxl-s905x-libretech-cc.dtb' configuration Trying 'kernel-1' kernel subimage Description: Linux kernel Type: Kernel Image Compression: gzip compressed Data Start: 0x08080120 Data Size: 9926956 Bytes = 9.5 MiB Architecture: AArch64 OS: Linux Load Address: 0x01080000 Entry Point: 0x01080000 Hash algo: sha256 Hash value: 5181a76e4e7a728e24cd8569f8e48c543ac259bf4d66591a3dc5e166d709429e Verifying Hash Integrity ... sha256+ OK ## Flattened Device Tree blob at 7bf40210 Booting using the fdt blob at 0x7bf40210 Uncompressing Kernel Image Loading Device Tree to 000000007bf2c000, end 000000007bf38ba7 ... OK
Note this is the "best in town" boot method in Yocto/OE when using WIC, FIT Image and generating extlinux.conf from the WIC "bootimg-partition" plugin.
So this change will regress all platforms using this scheme.
In case we only want the FIT image and not DTB, the fdtdir is ommited at: https://github.com/openembedded/openembedded-core/blob/9015dec93233c7d45fd0c...
Neil
Well this is certainly tricky. Do we be "boring" and say that the built-in device tree should be used, or "boring" and say that the distro provided device tree should be used. I assume that in the OE case we're not always going to be booting U-Boot that was built, so updating the logic there to have the correct dtb isn't right either.
I'm not against this logic, it should definitely be aligned on EFI and permit using built-in DT, but the logic breaks fitImage loading via extlinux, because now we have no way to say "use the fitImage DT".
This change should have been elsewhere, like in the non-FIT bootm path when no DT was supplied and DT is mandatory for the platform.
Or by passing a keyword like fdt-built-in or ftdfile=builtin.
==><======================================================= diff --git a/boot/pxe_utils.c b/boot/pxe_utils.c index 0c24becae3..22040c2340 100644 --- a/boot/pxe_utils.c +++ b/boot/pxe_utils.c @@ -682,7 +682,7 @@ static int label_boot(struct pxe_context *ctx, struct pxe_label *label) fdtfile = fdtfilefree; }
- if (fdtfile) { + if (strcmp(fdtfile, "builtin") && fdtfile) { int err = get_relfile_envaddr(ctx, fdtfile, "fdt_addr_r", NULL);
@@ -724,7 +724,7 @@ static int label_boot(struct pxe_context *ctx, struct pxe_label *label) if (!bootm_argv[3]) bootm_argv[3] = env_get("fdt_addr");
- if (!bootm_argv[3]) + if (!strcmp(fdtfile, "builtin")) bootm_argv[3] = env_get("fdtcontroladdr");
if (bootm_argv[3]) { ==><=======================================================
Or by checking the image format before using fdtcontroladdr like:
==><======================================================= diff --git a/boot/pxe_utils.c b/boot/pxe_utils.c index 0c24becae3..f4f6369de6 100644 --- a/boot/pxe_utils.c +++ b/boot/pxe_utils.c @@ -724,7 +724,7 @@ static int label_boot(struct pxe_context *ctx, struct pxe_label *label) if (!bootm_argv[3]) bootm_argv[3] = env_get("fdt_addr");
- if (!bootm_argv[3]) + if (genimg_get_format(buf) != IMAGE_FORMAT_FIT && !bootm_argv[3]) bootm_argv[3] = env_get("fdtcontroladdr");
Neil
diff --git a/cmd/pxe_utils.c b/cmd/pxe_utils.c index 067c24e5ff..8f8e69ca97 100644 --- a/cmd/pxe_utils.c +++ b/cmd/pxe_utils.c @@ -556,7 +556,10 @@ static int label_boot(struct cmd_tbl *cmdtp, struct pxe_label *label) * Scenario 2: If there is an fdt_addr specified, pass it along to * bootm, and adjust argc appropriately. * - * Scenario 3: fdt blob is not available. + * Scenario 3: If there is an fdtcontroladdr specified, pass it along to + * bootm, and adjust argc appropriately. + * + * Scenario 4: fdt blob is not available. */ bootm_argv[3] = env_get("fdt_addr_r"); @@ -646,6 +649,9 @@ static int label_boot(struct cmd_tbl *cmdtp, struct pxe_label *label) if (!bootm_argv[3]) bootm_argv[3] = env_get("fdt_addr"); + if (!bootm_argv[3]) + bootm_argv[3] = env_get("fdtcontroladdr");
I agree the correct logic should be:
* Use the extlinux.conf fdt file, if defined * Use a FIT fdt, if available * Use fdtcontroladdr, as a last resort
, so FIT images was an oversight.
Neil
Your second diff above seems like the least invasive way of achieving this behavior.
I did wonder whether it would make sense to add a global 'fdtcontroladdr' fallback for bootm (i.e. in boot_get_fdt in image-fdt.c), so that:
bootm $kernel_addr_r
falls back to $fdtcontroladdr (if valid) as a last resort. Then we could remove the branch in pxe_utils, and the FIT logic would happen in the right order. It looks like bootefi already does something similar, but I guess modifying the bootm behavior would affect a lot of existing boards.
Peter
Neil
Probably, but I think getting back fit image working would be the priority.
Tom, should I send the last change ?
Neil
Peter
Neil
Yes please, thanks!
participants (7)
Andre Przywara
Neil Armstrong
Peter Hoyes
Peter Hoyes
Ramon Fried
