[U-Boot] [v5, 0/5] Split fsl_esdhc driver for i.MX
The fsl_esdhc driver was for Freescale eSDHC on MPC83XX/MPC85XX initially. The later QoriQ series PowerPC processors (which were evolutions of MPC83XX/MPC85XX), QorIQ series ARM processors, and i.MX series processors were using this driver for their eSDHCs too.
For the two series processors, the eSDHCs are becoming more and more different. We should have split it into two drivers, like them (sdhci-of-esdhc.c/sdhci-esdhc-imx.c) in linux kernel.
It's ideal to keep common part for reusing. However, it's hard to find out a little which could be reused. The truth is there will be more and more different registers, bits and operatiing processes. Even some code is common now, it may have to be split in the future. So let's just split is as two drivers.
Patch #2 just created a fsl_esdhc_imx driver which was a copy of fsl_esdhc driver for i.MX processors. Patch #3 converted i.MX platforms to use fsl_esdhc_imx. Patch #4 and #5 just dropped useless code for the two driver. There are still many cleaning up works needed to be done in the future, because the eSDHC driver is mess for a long time. Since I'm only owner for QorIQ eSDHC driver, I dropped only a little things which I'm sure for fsl_esdhc_imx. Let i.MX eSDHC owner do futhur cleaning up.
Yangbo Lu (5): Move CONFIG_FSL_ESDHC to defconfig mmc: split fsl_esdhc driver for i.MX Convert to use fsl_esdhc_imx for i.MX platforms mmc: fsl_esdhc: drop i.MX code mmc: fsl_esdhc_imx: drop useless code
arch/arm/cpu/arm1136/mx35/generic.c | 10 +- arch/arm/cpu/arm926ejs/mx25/generic.c | 8 +- arch/arm/cpu/armv7/vf610/generic.c | 10 +- arch/arm/cpu/armv8/s32v234/generic.c | 2 +- arch/arm/include/asm/global_data.h | 2 +- arch/arm/mach-imx/cpu.c | 6 +- arch/arm/mach-imx/mx6/litesom.c | 4 +- arch/arm/mach-imx/mx7/clock.c | 4 +- arch/arm/mach-imx/mx7ulp/clock.c | 2 +- arch/arm/mach-imx/speed.c | 4 +- arch/m68k/cpu/mcf5445x/cpu_init.c | 2 +- board/advantech/dms-ba16/dms-ba16.c | 4 +- board/aristainetos/aristainetos-v1.c | 2 +- board/aristainetos/aristainetos-v2.c | 2 +- board/aristainetos/aristainetos.c | 4 +- board/bachmann/ot1200/ot1200.c | 2 +- board/barco/platinum/platinum.c | 2 +- board/barco/titanium/titanium.c | 4 +- board/boundary/nitrogen6x/nitrogen6x.c | 4 +- board/ccv/xpress/xpress.c | 2 +- board/compulab/cl-som-imx7/cl-som-imx7.c | 6 +- board/compulab/cl-som-imx7/common.c | 6 +- board/compulab/cl-som-imx7/common.h | 8 +- board/compulab/cl-som-imx7/mux.c | 8 +- board/compulab/cl-som-imx7/spl.c | 6 +- board/compulab/cm_fx6/cm_fx6.c | 4 +- board/compulab/cm_fx6/common.c | 4 +- board/compulab/cm_fx6/spl.c | 2 +- board/congatec/cgtqmx6eval/cgtqmx6eval.c | 4 +- board/dhelectronics/dh_imx6/dh_imx6.c | 4 +- board/dhelectronics/dh_imx6/dh_imx6_spl.c | 2 +- board/el/el6x/el6x.c | 4 +- board/embest/mx6boards/mx6boards.c | 4 +- board/freescale/imx8mq_evk/imx8mq_evk.c | 2 +- board/freescale/imx8mq_evk/spl.c | 2 +- board/freescale/imx8qxp_mek/imx8qxp_mek.c | 2 +- board/freescale/m54418twr/m54418twr.c | 2 +- board/freescale/mx25pdk/mx25pdk.c | 6 +- board/freescale/mx35pdk/mx35pdk.c | 4 +- board/freescale/mx51evk/mx51evk.c | 6 +- board/freescale/mx53ard/mx53ard.c | 4 +- board/freescale/mx53evk/mx53evk.c | 4 +- board/freescale/mx53loco/mx53loco.c | 4 +- board/freescale/mx53smd/mx53smd.c | 4 +- board/freescale/mx6qarm2/mx6qarm2.c | 4 +- board/freescale/mx6sabreauto/mx6sabreauto.c | 4 +- board/freescale/mx6sabresd/mx6sabresd.c | 4 +- board/freescale/mx6slevk/mx6slevk.c | 2 +- board/freescale/mx6sxsabreauto/mx6sxsabreauto.c | 2 +- board/freescale/mx6sxsabresd/mx6sxsabresd.c | 2 +- board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c | 4 +- board/freescale/mx6ullevk/mx6ullevk.c | 2 +- board/freescale/mx7dsabresd/mx7dsabresd.c | 2 +- board/freescale/s32v234evb/s32v234evb.c | 4 +- board/freescale/vf610twr/vf610twr.c | 4 +- board/gateworks/gw_ventana/common.c | 6 +- board/gateworks/gw_ventana/gw_ventana.c | 2 +- board/ge/bx50v3/bx50v3.c | 2 +- board/ge/mx53ppd/mx53ppd.c | 2 +- board/grinn/liteboard/board.c | 4 +- board/inversepath/usbarmory/usbarmory.c | 2 +- board/k+p/kp_imx6q_tpc/kp_imx6q_tpc.c | 4 +- board/k+p/kp_imx6q_tpc/kp_imx6q_tpc_spl.c | 2 +- board/kosagi/novena/novena.c | 4 +- board/kosagi/novena/novena_spl.c | 6 +- board/liebherr/display5/common.c | 2 +- board/liebherr/display5/display5.c | 6 +- board/liebherr/display5/spl.c | 2 +- board/liebherr/mccmon6/mccmon6.c | 2 +- board/liebherr/mccmon6/spl.c | 2 +- board/logicpd/imx6/imx6logic.c | 4 +- board/menlo/m53menlo/m53menlo.c | 4 +- board/phytec/pcl063/pcl063.c | 2 +- board/phytec/pcl063/spl.c | 6 +- board/phytec/pcm058/pcm058.c | 2 +- board/phytec/pfla02/pfla02.c | 2 +- board/samtec/vining_2000/vining_2000.c | 2 +- board/seco/common/mx6.c | 2 +- board/seco/mx6quq7/mx6quq7.c | 2 +- board/sks-kinkel/sksimx6/sksimx6.c | 2 +- board/solidrun/mx6cuboxi/mx6cuboxi.c | 2 +- board/tbs/tbs2910/tbs2910.c | 6 +- board/technexion/pico-imx6ul/spl.c | 2 +- board/technexion/pico-imx7d/spl.c | 2 +- board/technologic/ts4800/ts4800.c | 6 +- board/toradex/apalis_imx6/apalis_imx6.c | 6 +- board/toradex/colibri_imx6/colibri_imx6.c | 6 +- board/toradex/colibri_imx7/colibri_imx7.c | 2 +- board/tqc/tqma6/tqma6.c | 2 +- board/tqc/tqma6/tqma6_mba6.c | 2 +- board/tqc/tqma6/tqma6_wru4.c | 2 +- board/udoo/neo/neo.c | 2 +- board/udoo/udoo.c | 2 +- board/udoo/udoo_spl.c | 2 +- board/variscite/dart_6ul/dart_6ul.c | 2 +- board/variscite/dart_6ul/spl.c | 2 +- board/wandboard/spl.c | 2 +- board/warp/warp.c | 2 +- board/woodburn/woodburn.c | 4 +- configs/apalis_imx6_defconfig | 2 +- configs/aristainetos2_defconfig | 2 +- configs/aristainetos2b_defconfig | 2 +- configs/aristainetos_defconfig | 2 +- configs/bk4r1_defconfig | 2 +- configs/cgtqmx6eval_defconfig | 2 +- configs/cl-som-imx7_defconfig | 2 +- configs/cm_fx6_defconfig | 2 +- configs/colibri-imx6ull_defconfig | 2 +- configs/colibri_imx6_defconfig | 2 +- configs/colibri_imx7_defconfig | 2 +- configs/colibri_imx7_emmc_defconfig | 2 +- configs/colibri_vf_defconfig | 2 +- configs/dh_imx6_defconfig | 2 +- configs/display5_defconfig | 2 +- configs/display5_factory_defconfig | 2 +- configs/dms-ba16-1g_defconfig | 2 +- configs/dms-ba16_defconfig | 2 +- configs/ge_bx50v3_defconfig | 2 +- configs/gwventana_emmc_defconfig | 2 +- configs/gwventana_gw5904_defconfig | 2 +- configs/gwventana_nand_defconfig | 2 +- configs/imx6dl_icore_nand_defconfig | 2 +- configs/imx6dl_mamoj_defconfig | 2 +- configs/imx6q_icore_nand_defconfig | 2 +- configs/imx6q_logic_defconfig | 2 +- configs/imx6qdl_icore_mipi_defconfig | 2 +- configs/imx6qdl_icore_mmc_defconfig | 2 +- configs/imx6qdl_icore_nand_defconfig | 2 +- configs/imx6qdl_icore_rqs_defconfig | 2 +- configs/imx6ul_geam_mmc_defconfig | 2 +- configs/imx6ul_geam_nand_defconfig | 2 +- configs/imx6ul_isiot_emmc_defconfig | 2 +- configs/imx6ul_isiot_nand_defconfig | 2 +- configs/imx8mq_evk_defconfig | 1 + configs/imx8qm_mek_defconfig | 1 + configs/imx8qxp_mek_defconfig | 1 + configs/kp_imx53_defconfig | 2 +- configs/kp_imx6q_tpc_defconfig | 1 + configs/liteboard_defconfig | 2 +- configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1012afrwy_qspi_defconfig | 1 + configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1012afrwy_tfa_defconfig | 1 + configs/m53menlo_defconfig | 2 +- configs/marsboard_defconfig | 2 +- configs/mccmon6_nor_defconfig | 2 +- configs/mccmon6_sd_defconfig | 2 +- configs/mx25pdk_defconfig | 2 +- configs/mx35pdk_defconfig | 2 +- configs/mx51evk_defconfig | 2 +- configs/mx53ard_defconfig | 2 +- configs/mx53cx9020_defconfig | 2 +- configs/mx53evk_defconfig | 2 +- configs/mx53loco_defconfig | 2 +- configs/mx53ppd_defconfig | 2 +- configs/mx53smd_defconfig | 2 +- configs/mx6cuboxi_defconfig | 2 +- configs/mx6dlarm2_defconfig | 2 +- configs/mx6dlarm2_lpddr2_defconfig | 2 +- configs/mx6qarm2_defconfig | 2 +- configs/mx6qarm2_lpddr2_defconfig | 2 +- configs/mx6qsabrelite_defconfig | 2 +- configs/mx6sabreauto_defconfig | 2 +- configs/mx6sabresd_defconfig | 2 +- configs/mx6slevk_defconfig | 2 +- configs/mx6slevk_spinor_defconfig | 2 +- configs/mx6slevk_spl_defconfig | 2 +- configs/mx6sllevk_defconfig | 2 +- configs/mx6sllevk_plugin_defconfig | 2 +- configs/mx6sxsabreauto_defconfig | 2 +- configs/mx6sxsabresd_defconfig | 2 +- configs/mx6sxsabresd_spl_defconfig | 2 +- configs/mx6ul_14x14_evk_defconfig | 2 +- configs/mx6ul_9x9_evk_defconfig | 2 +- configs/mx6ull_14x14_evk_defconfig | 2 +- configs/mx6ull_14x14_evk_plugin_defconfig | 2 +- configs/mx7dsabresd_defconfig | 2 +- configs/mx7dsabresd_qspi_defconfig | 2 +- configs/mx7ulp_evk_defconfig | 2 +- configs/mx7ulp_evk_plugin_defconfig | 2 +- configs/nitrogen6dl2g_defconfig | 2 +- configs/nitrogen6dl_defconfig | 2 +- configs/nitrogen6q2g_defconfig | 2 +- configs/nitrogen6q_defconfig | 2 +- configs/nitrogen6s1g_defconfig | 2 +- configs/nitrogen6s_defconfig | 2 +- configs/novena_defconfig | 2 +- configs/opos6uldev_defconfig | 2 +- configs/ot1200_defconfig | 2 +- configs/ot1200_spl_defconfig | 2 +- configs/pcm052_defconfig | 2 +- configs/pcm058_defconfig | 2 +- configs/pfla02_defconfig | 2 +- configs/phycore_pcl063_defconfig | 2 +- configs/pico-hobbit-imx6ul_defconfig | 2 +- configs/pico-hobbit-imx7d_defconfig | 2 +- configs/pico-imx6ul_defconfig | 2 +- configs/pico-imx7d_defconfig | 2 +- configs/pico-pi-imx6ul_defconfig | 2 +- configs/pico-pi-imx7d_defconfig | 2 +- configs/platinum_picon_defconfig | 2 +- configs/platinum_titanium_defconfig | 2 +- configs/riotboard_defconfig | 2 +- configs/riotboard_spl_defconfig | 2 +- configs/s32v234evb_defconfig | 2 +- configs/secomx6quq7_defconfig | 2 +- configs/sksimx6_defconfig | 2 +- configs/tbs2910_defconfig | 2 +- configs/titanium_defconfig | 2 +- configs/tqma6dl_mba6_mmc_defconfig | 2 +- configs/tqma6dl_mba6_spi_defconfig | 2 +- configs/tqma6q_mba6_mmc_defconfig | 2 +- configs/tqma6q_mba6_spi_defconfig | 2 +- configs/tqma6s_mba6_mmc_defconfig | 2 +- configs/tqma6s_mba6_spi_defconfig | 2 +- configs/tqma6s_wru4_mmc_defconfig | 2 +- configs/ts4800_defconfig | 2 +- configs/udoo_defconfig | 2 +- configs/udoo_neo_defconfig | 2 +- configs/usbarmory_defconfig | 2 +- configs/variscite_dart6ul_defconfig | 2 +- configs/vf610twr_defconfig | 2 +- configs/vf610twr_nand_defconfig | 2 +- configs/vining_2000_defconfig | 2 +- configs/wandboard_defconfig | 2 +- configs/warp7_bl33_defconfig | 2 +- configs/warp7_defconfig | 2 +- configs/warp_defconfig | 2 +- configs/woodburn_defconfig | 2 +- configs/woodburn_sd_defconfig | 2 +- configs/xpress_defconfig | 2 +- configs/xpress_spl_defconfig | 2 +- configs/zc5202_defconfig | 2 +- configs/zc5601_defconfig | 2 +- drivers/mmc/Kconfig | 10 +- drivers/mmc/Makefile | 1 + drivers/mmc/fsl_esdhc.c | 626 +--------------------- drivers/mmc/{fsl_esdhc.c => fsl_esdhc_imx.c} | 72 +-- include/configs/imx8mq_evk.h | 1 - include/configs/imx8qm_mek.h | 1 - include/configs/imx8qxp_mek.h | 1 - include/configs/kp_imx6q_tpc.h | 1 - include/configs/ls1012afrwy.h | 1 - include/fsl_esdhc.h | 57 -- include/{fsl_esdhc.h => fsl_esdhc_imx.h} | 17 +- 245 files changed, 351 insertions(+), 1047 deletions(-) copy drivers/mmc/{fsl_esdhc.c => fsl_esdhc_imx.c} (95%) copy include/{fsl_esdhc.h => fsl_esdhc_imx.h} (97%)
Moved CONFIG_FSL_ESDHC from header files to defconfig files.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com Tested-by: Steffen Dirkwinkel s.dirkwinkel@beckhoff.com Reviewed-by: Peng Fan peng.fan@nxp.com Reviewed-by: Lukasz Majewski lukma@denx.de Acked-by: Jason Liu Jason.hui.liu@nxp.com --- Changes for v2: - Rebased. Changes for v3: - Rebased. Changes for v4: - Added Tested-by/Reviewed-by/Acked-by. Changes for v5: - None. --- configs/imx8mq_evk_defconfig | 1 + configs/imx8qm_mek_defconfig | 1 + configs/imx8qxp_mek_defconfig | 1 + configs/kp_imx6q_tpc_defconfig | 1 + configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1012afrwy_qspi_defconfig | 1 + configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1012afrwy_tfa_defconfig | 1 + include/configs/imx8mq_evk.h | 1 - include/configs/imx8qm_mek.h | 1 - include/configs/imx8qxp_mek.h | 1 - include/configs/kp_imx6q_tpc.h | 1 - include/configs/ls1012afrwy.h | 1 - 13 files changed, 8 insertions(+), 5 deletions(-)
diff --git a/configs/imx8mq_evk_defconfig b/configs/imx8mq_evk_defconfig index bc84a66..1c857bc 100644 --- a/configs/imx8mq_evk_defconfig +++ b/configs/imx8mq_evk_defconfig @@ -31,6 +31,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MXC=y CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_DM_ETH=y CONFIG_PINCTRL=y diff --git a/configs/imx8qm_mek_defconfig b/configs/imx8qm_mek_defconfig index 1c67b98..f1155d6 100644 --- a/configs/imx8qm_mek_defconfig +++ b/configs/imx8qm_mek_defconfig @@ -52,6 +52,7 @@ CONFIG_I2C_MUX=y CONFIG_I2C_MUX_PCA954x=y CONFIG_MISC=y CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y CONFIG_PHY_ATHEROS=y diff --git a/configs/imx8qxp_mek_defconfig b/configs/imx8qxp_mek_defconfig index d735d34..1ce175e 100644 --- a/configs/imx8qxp_mek_defconfig +++ b/configs/imx8qxp_mek_defconfig @@ -55,6 +55,7 @@ CONFIG_I2C_MUX=y CONFIG_I2C_MUX_PCA954x=y CONFIG_MISC=y CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y diff --git a/configs/kp_imx6q_tpc_defconfig b/configs/kp_imx6q_tpc_defconfig index 0ca83cb..9b6ff4a 100644 --- a/configs/kp_imx6q_tpc_defconfig +++ b/configs/kp_imx6q_tpc_defconfig @@ -34,6 +34,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_ISO_PARTITION is not set # CONFIG_EFI_PARTITION is not set CONFIG_ENV_IS_IN_MMC=y +CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_PHY_ATHEROS=y CONFIG_FEC_MXC=y diff --git a/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig b/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig index bf98466..0360d9d 100644 --- a/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig @@ -31,6 +31,7 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/ls1012afrwy_qspi_defconfig b/configs/ls1012afrwy_qspi_defconfig index aa3256f..08eedec 100644 --- a/configs/ls1012afrwy_qspi_defconfig +++ b/configs/ls1012afrwy_qspi_defconfig @@ -32,6 +32,7 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig b/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig index b0fdad6..2c3d893 100644 --- a/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig @@ -31,6 +31,7 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/ls1012afrwy_tfa_defconfig b/configs/ls1012afrwy_tfa_defconfig index 6a70f58..19aae5a 100644 --- a/configs/ls1012afrwy_tfa_defconfig +++ b/configs/ls1012afrwy_tfa_defconfig @@ -32,6 +32,7 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y CONFIG_SATA_CEVA=y CONFIG_DM_MMC=y +CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/include/configs/imx8mq_evk.h b/include/configs/imx8mq_evk.h index e4fa2df..16e4136 100644 --- a/include/configs/imx8mq_evk.h +++ b/include/configs/imx8mq_evk.h @@ -216,7 +216,6 @@ #define CONFIG_IMX_BOOTAUX
#define CONFIG_CMD_MMC -#define CONFIG_FSL_ESDHC #define CONFIG_FSL_USDHC
#define CONFIG_SYS_FSL_USDHC_NUM 2 diff --git a/include/configs/imx8qm_mek.h b/include/configs/imx8qm_mek.h index 2bdf3be..3679b48 100644 --- a/include/configs/imx8qm_mek.h +++ b/include/configs/imx8qm_mek.h @@ -47,7 +47,6 @@ #undef CONFIG_CMD_CRC32 #undef CONFIG_BOOTM_NETBSD
-#define CONFIG_FSL_ESDHC #define CONFIG_FSL_USDHC #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define USDHC1_BASE_ADDR 0x5B010000 diff --git a/include/configs/imx8qxp_mek.h b/include/configs/imx8qxp_mek.h index 261661a..18cc930 100644 --- a/include/configs/imx8qxp_mek.h +++ b/include/configs/imx8qxp_mek.h @@ -46,7 +46,6 @@ #undef CONFIG_CMD_CRC32 #undef CONFIG_BOOTM_NETBSD
-#define CONFIG_FSL_ESDHC #define CONFIG_FSL_USDHC #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define USDHC1_BASE_ADDR 0x5B010000 diff --git a/include/configs/kp_imx6q_tpc.h b/include/configs/kp_imx6q_tpc.h index d2ebf92..dbae276 100644 --- a/include/configs/kp_imx6q_tpc.h +++ b/include/configs/kp_imx6q_tpc.h @@ -39,7 +39,6 @@ #define CONFIG_SYS_I2C_SPEED 100000
/* MMC Configs */ -#define CONFIG_FSL_ESDHC #define CONFIG_FSL_USDHC #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define CONFIG_SYS_FSL_USDHC_NUM 2 diff --git a/include/configs/ls1012afrwy.h b/include/configs/ls1012afrwy.h index 12e6437..77aa22b 100644 --- a/include/configs/ls1012afrwy.h +++ b/include/configs/ls1012afrwy.h @@ -41,7 +41,6 @@
/* MMC */ #ifdef CONFIG_MMC -#define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 #endif
This patch is just to create a fsl_esdhc_imx driver which is a copy of fsl_esdhc driver for i.MX processors. We will convert i.MX processors to use fsl_esdhc_imx, and clean up the two drivers separately in the future patches.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com Tested-by: Steffen Dirkwinkel s.dirkwinkel@beckhoff.com Reviewed-by: Peng Fan peng.fan@nxp.com --- Changes for v2: - None. Changes for v3: - None. Changes for v4: - Used "Enhanced Secure Digital Host" in Kconfig help. - Moved copyright to top line and added my info. - Added Tested-by/Reviewed-by. Changes for v5: - None. --- drivers/mmc/Kconfig | 10 ++++++++-- drivers/mmc/Makefile | 1 + drivers/mmc/{fsl_esdhc.c => fsl_esdhc_imx.c} | 7 +++++-- include/{fsl_esdhc.h => fsl_esdhc_imx.h} | 13 ++++++++----- 4 files changed, 22 insertions(+), 9 deletions(-) copy drivers/mmc/{fsl_esdhc.c => fsl_esdhc_imx.c} (99%) copy include/{fsl_esdhc.h => fsl_esdhc_imx.h} (97%)
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index c23299e..9358872 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -668,8 +668,14 @@ config TEGRA124_MMC_DISABLE_EXT_LOOPBACK config FSL_ESDHC bool "Freescale/NXP eSDHC controller support" help - This selects support for the eSDHC (enhanced secure digital host - controller) found on numerous Freescale/NXP SoCs. + This selects support for the eSDHC (Enhanced Secure Digital Host + Controller) found on numerous Freescale/NXP SoCs. + +config FSL_ESDHC_IMX + bool "Freescale/NXP i.MX eSDHC controller support" + help + This selects support for the i.MX eSDHC (Enhanced Secure Digital Host + Controller) found on numerous Freescale/NXP SoCs.
endmenu
diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 0076fc3..3c8c53a 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -26,6 +26,7 @@ obj-$(CONFIG_MMC_DW_ROCKCHIP) += rockchip_dw_mmc.o obj-$(CONFIG_MMC_DW_SOCFPGA) += socfpga_dw_mmc.o obj-$(CONFIG_MMC_DW_SNPS) += snps_dw_mmc.o obj-$(CONFIG_FSL_ESDHC) += fsl_esdhc.o +obj-$(CONFIG_FSL_ESDHC_IMX) += fsl_esdhc_imx.o obj-$(CONFIG_FTSDC010) += ftsdc010_mci.o obj-$(CONFIG_GENERIC_ATMEL_MCI) += gen_atmel_mci.o obj-$(CONFIG_MMC_MESON_GX) += meson_gx_mmc.o diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc_imx.c similarity index 99% copy from drivers/mmc/fsl_esdhc.c copy to drivers/mmc/fsl_esdhc_imx.c index 672691f..1474e2c 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -1,5 +1,8 @@ // SPDX-License-Identifier: GPL-2.0+ /* + * Copyright 2019 NXP + * Yangbo Lu yangbo.lu@nxp.com + * * Copyright 2007, 2010-2011 Freescale Semiconductor, Inc * Andy Fleming * @@ -18,7 +21,7 @@ #include <part.h> #include <power/regulator.h> #include <malloc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <fdt_support.h> #include <asm/io.h> #include <dm.h> @@ -110,7 +113,7 @@ struct esdhc_soc_data { * @non_removable: 0: removable; 1: non-removable * @wp_enable: 1: enable checking wp; 0: no check * @vs18_enable: 1: use 1.8V voltage; 0: use 3.3V - * @flags: ESDHC_FLAG_xx in include/fsl_esdhc.h + * @flags: ESDHC_FLAG_xx in include/fsl_esdhc_imx.h * @caps: controller capabilities * @tuning_step: tuning step setting in tuning_ctrl register * @start_tuning_tap: the start point for tuning in tuning_ctrl register diff --git a/include/fsl_esdhc.h b/include/fsl_esdhc_imx.h similarity index 97% copy from include/fsl_esdhc.h copy to include/fsl_esdhc_imx.h index 8dbd524..67fd289 100644 --- a/include/fsl_esdhc.h +++ b/include/fsl_esdhc_imx.h @@ -3,11 +3,14 @@ * FSL SD/MMC Defines *------------------------------------------------------------------- * + * Copyright 2019 NXP + * Yangbo Lu yangbo.lu@nxp.com + * * Copyright 2007-2008,2010-2011 Freescale Semiconductor, Inc */
-#ifndef __FSL_ESDHC_H__ -#define __FSL_ESDHC_H__ +#ifndef __FSL_ESDHC_IMX_H__ +#define __FSL_ESDHC_IMX_H__
#include <linux/bitops.h> #include <linux/errno.h> @@ -258,15 +261,15 @@ struct fsl_esdhc_cfg { #error "Endianess is not defined: please fix to continue" #endif
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX int fsl_esdhc_mmc_init(bd_t *bis); int fsl_esdhc_initialize(bd_t *bis, struct fsl_esdhc_cfg *cfg); void fdt_fixup_esdhc(void *blob, bd_t *bd); #else static inline int fsl_esdhc_mmc_init(bd_t *bis) { return -ENOSYS; } static inline void fdt_fixup_esdhc(void *blob, bd_t *bd) {} -#endif /* CONFIG_FSL_ESDHC */ +#endif /* CONFIG_FSL_ESDHC_IMX */ void __noreturn mmc_boot(void); void mmc_spl_load_image(uint32_t offs, unsigned int size, void *vdst);
-#endif /* __FSL_ESDHC_H__ */ +#endif /* __FSL_ESDHC_IMX_H__ */
Converted to use fsl_esdhc_imx for i.MX platforms.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com Tested-by: Steffen Dirkwinkel s.dirkwinkel@beckhoff.com Reviewed-by: Peng Fan peng.fan@nxp.com Reviewed-by: Lukasz Majewski lukma@denx.de Acked-by: Jason Liu Jason.hui.liu@nxp.com --- Changes for v2: - Rebased. Changes for v3: - Rebased. Changes for v4: - Rebased. - Added Tested-by/Reviewed-by/Acked-by. Changes for v5: - Applied to MCF544x platforms. --- arch/arm/cpu/arm1136/mx35/generic.c | 10 +++++----- arch/arm/cpu/arm926ejs/mx25/generic.c | 8 ++++---- arch/arm/cpu/armv7/vf610/generic.c | 10 +++++----- arch/arm/cpu/armv8/s32v234/generic.c | 2 +- arch/arm/include/asm/global_data.h | 2 +- arch/arm/mach-imx/cpu.c | 6 +++--- arch/arm/mach-imx/mx6/litesom.c | 4 ++-- arch/arm/mach-imx/mx7/clock.c | 4 ++-- arch/arm/mach-imx/mx7ulp/clock.c | 2 +- arch/arm/mach-imx/speed.c | 4 ++-- arch/m68k/cpu/mcf5445x/cpu_init.c | 2 +- board/advantech/dms-ba16/dms-ba16.c | 4 ++-- board/aristainetos/aristainetos-v1.c | 2 +- board/aristainetos/aristainetos-v2.c | 2 +- board/aristainetos/aristainetos.c | 4 ++-- board/bachmann/ot1200/ot1200.c | 2 +- board/barco/platinum/platinum.c | 2 +- board/barco/titanium/titanium.c | 4 ++-- board/boundary/nitrogen6x/nitrogen6x.c | 4 ++-- board/ccv/xpress/xpress.c | 2 +- board/compulab/cl-som-imx7/cl-som-imx7.c | 6 +++--- board/compulab/cl-som-imx7/common.c | 6 +++--- board/compulab/cl-som-imx7/common.h | 8 ++++---- board/compulab/cl-som-imx7/mux.c | 8 ++++---- board/compulab/cl-som-imx7/spl.c | 6 +++--- board/compulab/cm_fx6/cm_fx6.c | 4 ++-- board/compulab/cm_fx6/common.c | 4 ++-- board/compulab/cm_fx6/spl.c | 2 +- board/congatec/cgtqmx6eval/cgtqmx6eval.c | 4 ++-- board/dhelectronics/dh_imx6/dh_imx6.c | 4 ++-- board/dhelectronics/dh_imx6/dh_imx6_spl.c | 2 +- board/el/el6x/el6x.c | 4 ++-- board/embest/mx6boards/mx6boards.c | 4 ++-- board/freescale/imx8mq_evk/imx8mq_evk.c | 2 +- board/freescale/imx8mq_evk/spl.c | 2 +- board/freescale/imx8qxp_mek/imx8qxp_mek.c | 2 +- board/freescale/m54418twr/m54418twr.c | 2 +- board/freescale/mx25pdk/mx25pdk.c | 6 +++--- board/freescale/mx35pdk/mx35pdk.c | 4 ++-- board/freescale/mx51evk/mx51evk.c | 6 +++--- board/freescale/mx53ard/mx53ard.c | 4 ++-- board/freescale/mx53evk/mx53evk.c | 4 ++-- board/freescale/mx53loco/mx53loco.c | 4 ++-- board/freescale/mx53smd/mx53smd.c | 4 ++-- board/freescale/mx6qarm2/mx6qarm2.c | 4 ++-- board/freescale/mx6sabreauto/mx6sabreauto.c | 4 ++-- board/freescale/mx6sabresd/mx6sabresd.c | 4 ++-- board/freescale/mx6slevk/mx6slevk.c | 2 +- board/freescale/mx6sxsabreauto/mx6sxsabreauto.c | 2 +- board/freescale/mx6sxsabresd/mx6sxsabresd.c | 2 +- board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c | 4 ++-- board/freescale/mx6ullevk/mx6ullevk.c | 2 +- board/freescale/mx7dsabresd/mx7dsabresd.c | 2 +- board/freescale/s32v234evb/s32v234evb.c | 4 ++-- board/freescale/vf610twr/vf610twr.c | 4 ++-- board/gateworks/gw_ventana/common.c | 6 +++--- board/gateworks/gw_ventana/gw_ventana.c | 2 +- board/ge/bx50v3/bx50v3.c | 2 +- board/ge/mx53ppd/mx53ppd.c | 2 +- board/grinn/liteboard/board.c | 4 ++-- board/inversepath/usbarmory/usbarmory.c | 2 +- board/k+p/kp_imx6q_tpc/kp_imx6q_tpc.c | 4 ++-- board/k+p/kp_imx6q_tpc/kp_imx6q_tpc_spl.c | 2 +- board/kosagi/novena/novena.c | 4 ++-- board/kosagi/novena/novena_spl.c | 6 +++--- board/liebherr/display5/common.c | 2 +- board/liebherr/display5/display5.c | 6 +++--- board/liebherr/display5/spl.c | 2 +- board/liebherr/mccmon6/mccmon6.c | 2 +- board/liebherr/mccmon6/spl.c | 2 +- board/logicpd/imx6/imx6logic.c | 4 ++-- board/menlo/m53menlo/m53menlo.c | 4 ++-- board/phytec/pcl063/pcl063.c | 2 +- board/phytec/pcl063/spl.c | 6 +++--- board/phytec/pcm058/pcm058.c | 2 +- board/phytec/pfla02/pfla02.c | 2 +- board/samtec/vining_2000/vining_2000.c | 2 +- board/seco/common/mx6.c | 2 +- board/seco/mx6quq7/mx6quq7.c | 2 +- board/sks-kinkel/sksimx6/sksimx6.c | 2 +- board/solidrun/mx6cuboxi/mx6cuboxi.c | 2 +- board/tbs/tbs2910/tbs2910.c | 6 +++--- board/technexion/pico-imx6ul/spl.c | 2 +- board/technexion/pico-imx7d/spl.c | 2 +- board/technologic/ts4800/ts4800.c | 6 +++--- board/toradex/apalis_imx6/apalis_imx6.c | 6 +++--- board/toradex/colibri_imx6/colibri_imx6.c | 6 +++--- board/toradex/colibri_imx7/colibri_imx7.c | 2 +- board/tqc/tqma6/tqma6.c | 2 +- board/tqc/tqma6/tqma6_mba6.c | 2 +- board/tqc/tqma6/tqma6_wru4.c | 2 +- board/udoo/neo/neo.c | 2 +- board/udoo/udoo.c | 2 +- board/udoo/udoo_spl.c | 2 +- board/variscite/dart_6ul/dart_6ul.c | 2 +- board/variscite/dart_6ul/spl.c | 2 +- board/wandboard/spl.c | 2 +- board/warp/warp.c | 2 +- board/woodburn/woodburn.c | 4 ++-- configs/apalis_imx6_defconfig | 2 +- configs/aristainetos2_defconfig | 2 +- configs/aristainetos2b_defconfig | 2 +- configs/aristainetos_defconfig | 2 +- configs/bk4r1_defconfig | 2 +- configs/cgtqmx6eval_defconfig | 2 +- configs/cl-som-imx7_defconfig | 2 +- configs/cm_fx6_defconfig | 2 +- configs/colibri-imx6ull_defconfig | 2 +- configs/colibri_imx6_defconfig | 2 +- configs/colibri_imx7_defconfig | 2 +- configs/colibri_imx7_emmc_defconfig | 2 +- configs/colibri_vf_defconfig | 2 +- configs/dh_imx6_defconfig | 2 +- configs/display5_defconfig | 2 +- configs/display5_factory_defconfig | 2 +- configs/dms-ba16-1g_defconfig | 2 +- configs/dms-ba16_defconfig | 2 +- configs/ge_bx50v3_defconfig | 2 +- configs/gwventana_emmc_defconfig | 2 +- configs/gwventana_gw5904_defconfig | 2 +- configs/gwventana_nand_defconfig | 2 +- configs/imx6dl_icore_nand_defconfig | 2 +- configs/imx6dl_mamoj_defconfig | 2 +- configs/imx6q_icore_nand_defconfig | 2 +- configs/imx6q_logic_defconfig | 2 +- configs/imx6qdl_icore_mipi_defconfig | 2 +- configs/imx6qdl_icore_mmc_defconfig | 2 +- configs/imx6qdl_icore_nand_defconfig | 2 +- configs/imx6qdl_icore_rqs_defconfig | 2 +- configs/imx6ul_geam_mmc_defconfig | 2 +- configs/imx6ul_geam_nand_defconfig | 2 +- configs/imx6ul_isiot_emmc_defconfig | 2 +- configs/imx6ul_isiot_nand_defconfig | 2 +- configs/imx8mq_evk_defconfig | 2 +- configs/imx8qm_mek_defconfig | 2 +- configs/imx8qxp_mek_defconfig | 2 +- configs/kp_imx53_defconfig | 2 +- configs/kp_imx6q_tpc_defconfig | 2 +- configs/liteboard_defconfig | 2 +- configs/m53menlo_defconfig | 2 +- configs/marsboard_defconfig | 2 +- configs/mccmon6_nor_defconfig | 2 +- configs/mccmon6_sd_defconfig | 2 +- configs/mx25pdk_defconfig | 2 +- configs/mx35pdk_defconfig | 2 +- configs/mx51evk_defconfig | 2 +- configs/mx53ard_defconfig | 2 +- configs/mx53cx9020_defconfig | 2 +- configs/mx53evk_defconfig | 2 +- configs/mx53loco_defconfig | 2 +- configs/mx53ppd_defconfig | 2 +- configs/mx53smd_defconfig | 2 +- configs/mx6cuboxi_defconfig | 2 +- configs/mx6dlarm2_defconfig | 2 +- configs/mx6dlarm2_lpddr2_defconfig | 2 +- configs/mx6qarm2_defconfig | 2 +- configs/mx6qarm2_lpddr2_defconfig | 2 +- configs/mx6qsabrelite_defconfig | 2 +- configs/mx6sabreauto_defconfig | 2 +- configs/mx6sabresd_defconfig | 2 +- configs/mx6slevk_defconfig | 2 +- configs/mx6slevk_spinor_defconfig | 2 +- configs/mx6slevk_spl_defconfig | 2 +- configs/mx6sllevk_defconfig | 2 +- configs/mx6sllevk_plugin_defconfig | 2 +- configs/mx6sxsabreauto_defconfig | 2 +- configs/mx6sxsabresd_defconfig | 2 +- configs/mx6sxsabresd_spl_defconfig | 2 +- configs/mx6ul_14x14_evk_defconfig | 2 +- configs/mx6ul_9x9_evk_defconfig | 2 +- configs/mx6ull_14x14_evk_defconfig | 2 +- configs/mx6ull_14x14_evk_plugin_defconfig | 2 +- configs/mx7dsabresd_defconfig | 2 +- configs/mx7dsabresd_qspi_defconfig | 2 +- configs/mx7ulp_evk_defconfig | 2 +- configs/mx7ulp_evk_plugin_defconfig | 2 +- configs/nitrogen6dl2g_defconfig | 2 +- configs/nitrogen6dl_defconfig | 2 +- configs/nitrogen6q2g_defconfig | 2 +- configs/nitrogen6q_defconfig | 2 +- configs/nitrogen6s1g_defconfig | 2 +- configs/nitrogen6s_defconfig | 2 +- configs/novena_defconfig | 2 +- configs/opos6uldev_defconfig | 2 +- configs/ot1200_defconfig | 2 +- configs/ot1200_spl_defconfig | 2 +- configs/pcm052_defconfig | 2 +- configs/pcm058_defconfig | 2 +- configs/pfla02_defconfig | 2 +- configs/phycore_pcl063_defconfig | 2 +- configs/pico-hobbit-imx6ul_defconfig | 2 +- configs/pico-hobbit-imx7d_defconfig | 2 +- configs/pico-imx6ul_defconfig | 2 +- configs/pico-imx7d_defconfig | 2 +- configs/pico-pi-imx6ul_defconfig | 2 +- configs/pico-pi-imx7d_defconfig | 2 +- configs/platinum_picon_defconfig | 2 +- configs/platinum_titanium_defconfig | 2 +- configs/riotboard_defconfig | 2 +- configs/riotboard_spl_defconfig | 2 +- configs/s32v234evb_defconfig | 2 +- configs/secomx6quq7_defconfig | 2 +- configs/sksimx6_defconfig | 2 +- configs/tbs2910_defconfig | 2 +- configs/titanium_defconfig | 2 +- configs/tqma6dl_mba6_mmc_defconfig | 2 +- configs/tqma6dl_mba6_spi_defconfig | 2 +- configs/tqma6q_mba6_mmc_defconfig | 2 +- configs/tqma6q_mba6_spi_defconfig | 2 +- configs/tqma6s_mba6_mmc_defconfig | 2 +- configs/tqma6s_mba6_spi_defconfig | 2 +- configs/tqma6s_wru4_mmc_defconfig | 2 +- configs/ts4800_defconfig | 2 +- configs/udoo_defconfig | 2 +- configs/udoo_neo_defconfig | 2 +- configs/usbarmory_defconfig | 2 +- configs/variscite_dart6ul_defconfig | 2 +- configs/vf610twr_defconfig | 2 +- configs/vf610twr_nand_defconfig | 2 +- configs/vining_2000_defconfig | 2 +- configs/wandboard_defconfig | 2 +- configs/warp7_bl33_defconfig | 2 +- configs/warp7_defconfig | 2 +- configs/warp_defconfig | 2 +- configs/woodburn_defconfig | 2 +- configs/woodburn_sd_defconfig | 2 +- configs/xpress_defconfig | 2 +- configs/xpress_spl_defconfig | 2 +- configs/zc5202_defconfig | 2 +- configs/zc5601_defconfig | 2 +- 230 files changed, 305 insertions(+), 305 deletions(-)
diff --git a/arch/arm/cpu/arm1136/mx35/generic.c b/arch/arm/cpu/arm1136/mx35/generic.c index cbc4364..a651b8c 100644 --- a/arch/arm/cpu/arm1136/mx35/generic.c +++ b/arch/arm/cpu/arm1136/mx35/generic.c @@ -14,8 +14,8 @@ #include <asm/arch/crm_regs.h> #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> -#ifdef CONFIG_FSL_ESDHC -#include <fsl_esdhc.h> +#ifdef CONFIG_FSL_ESDHC_IMX +#include <fsl_esdhc_imx.h> #endif #include <netdev.h> #include <spl.h> @@ -27,7 +27,7 @@
#define CCM_GET_DIVIDER(x, m, o) (((x) & (m)) >> (o))
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX DECLARE_GLOBAL_DATA_PTR; #endif
@@ -446,7 +446,7 @@ int cpu_eth_init(bd_t *bis) return rc; }
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX /* * Initializes on-chip MMC controllers. * to override, implement board_mmc_init() @@ -459,7 +459,7 @@ int cpu_mmc_init(bd_t *bis)
int get_clocks(void) { -#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX #if CONFIG_SYS_FSL_ESDHC_ADDR == MMC_SDHC2_BASE_ADDR gd->arch.sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); #elif CONFIG_SYS_FSL_ESDHC_ADDR == MMC_SDHC3_BASE_ADDR diff --git a/arch/arm/cpu/arm926ejs/mx25/generic.c b/arch/arm/cpu/arm926ejs/mx25/generic.c index 2795a5f..5fcf06a 100644 --- a/arch/arm/cpu/arm926ejs/mx25/generic.c +++ b/arch/arm/cpu/arm926ejs/mx25/generic.c @@ -16,8 +16,8 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h>
DECLARE_GLOBAL_DATA_PTR; #endif @@ -233,7 +233,7 @@ int cpu_eth_init(bd_t *bis)
int get_clocks(void) { -#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX #if CONFIG_SYS_FSL_ESDHC_ADDR == IMX_MMC_SDHC2_BASE gd->arch.sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); #else @@ -243,7 +243,7 @@ int get_clocks(void) return 0; }
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX /* * Initializes on-chip MMC controllers. * to override, implement board_mmc_init() diff --git a/arch/arm/cpu/armv7/vf610/generic.c b/arch/arm/cpu/armv7/vf610/generic.c index f962903..337f4af 100644 --- a/arch/arm/cpu/armv7/vf610/generic.c +++ b/arch/arm/cpu/armv7/vf610/generic.c @@ -10,11 +10,11 @@ #include <asm/arch/crm_regs.h> #include <asm/mach-imx/sys_proto.h> #include <netdev.h> -#ifdef CONFIG_FSL_ESDHC -#include <fsl_esdhc.h> +#ifdef CONFIG_FSL_ESDHC_IMX +#include <fsl_esdhc_imx.h> #endif
@@ -345,7 +345,7 @@ int cpu_eth_init(bd_t *bis) return rc; }
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX int cpu_mmc_init(bd_t *bis) { return fsl_esdhc_mmc_init(bis); @@ -354,7 +354,7 @@ int cpu_mmc_init(bd_t *bis)
int get_clocks(void) { -#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX gd->arch.sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); #endif return 0; diff --git a/arch/arm/cpu/armv8/s32v234/generic.c b/arch/arm/cpu/armv8/s32v234/generic.c index 273b88e..2c4ea36 100644 --- a/arch/arm/cpu/armv8/s32v234/generic.c +++ b/arch/arm/cpu/armv8/s32v234/generic.c @@ -342,7 +342,7 @@ int cpu_eth_init(bd_t * bis)
int get_clocks(void) { -#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX gd->arch.sdhc_clk = mxc_get_clock(MXC_USDHC_CLK); #endif return 0; diff --git a/arch/arm/include/asm/global_data.h b/arch/arm/include/asm/global_data.h index a81b106..1774014 100644 --- a/arch/arm/include/asm/global_data.h +++ b/arch/arm/include/asm/global_data.h @@ -9,7 +9,7 @@
/* Architecture-specific global data */ struct arch_global_data { -#if defined(CONFIG_FSL_ESDHC) +#if defined(CONFIG_FSL_ESDHC) || defined(CONFIG_FSL_ESDHC_IMX) u32 sdhc_clk; #endif
diff --git a/arch/arm/mach-imx/cpu.c b/arch/arm/mach-imx/cpu.c index 6b83f92..8f5a01b 100644 --- a/arch/arm/mach-imx/cpu.c +++ b/arch/arm/mach-imx/cpu.c @@ -21,8 +21,8 @@ #include <thermal.h> #include <sata.h>
static u32 reset_cause = -1; @@ -258,7 +258,7 @@ int cpu_eth_init(bd_t *bis) return rc; }
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX /* * Initializes on-chip MMC controllers. * to override, implement board_mmc_init() diff --git a/arch/arm/mach-imx/mx6/litesom.c b/arch/arm/mach-imx/mx6/litesom.c index c332d68..4f4df74 100644 --- a/arch/arm/mach-imx/mx6/litesom.c +++ b/arch/arm/mach-imx/mx6/litesom.c @@ -16,7 +16,7 @@ #include <asm/mach-imx/boot_mode.h> #include <asm/io.h> #include <common.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <linux/sizes.h> #include <mmc.h>
@@ -49,7 +49,7 @@ static iomux_v3_cfg_t const emmc_pads[] = { MX6_PAD_NAND_ALE__GPIO4_IO10 | MUX_PAD_CTRL(NO_PAD_CTRL), };
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX static struct fsl_esdhc_cfg emmc_cfg = {USDHC2_BASE_ADDR, 0, 8};
#define EMMC_PWR_GPIO IMX_GPIO_NR(4, 10) diff --git a/arch/arm/mach-imx/mx7/clock.c b/arch/arm/mach-imx/mx7/clock.c index 8cda71c..a98ae37 100644 --- a/arch/arm/mach-imx/mx7/clock.c +++ b/arch/arm/mach-imx/mx7/clock.c @@ -19,13 +19,13 @@ struct mxc_ccm_anatop_reg *ccm_anatop = (struct mxc_ccm_anatop_reg *) ANATOP_BASE_ADDR; struct mxc_ccm_reg *ccm_reg = (struct mxc_ccm_reg *)CCM_BASE_ADDR;
int get_clocks(void) { -#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX #if CONFIG_SYS_FSL_ESDHC_ADDR == USDHC2_BASE_ADDR gd->arch.sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); #elif CONFIG_SYS_FSL_ESDHC_ADDR == USDHC3_BASE_ADDR diff --git a/arch/arm/mach-imx/mx7ulp/clock.c b/arch/arm/mach-imx/mx7ulp/clock.c index fac9011..dc317fe 100644 --- a/arch/arm/mach-imx/mx7ulp/clock.c +++ b/arch/arm/mach-imx/mx7ulp/clock.c @@ -14,7 +14,7 @@ DECLARE_GLOBAL_DATA_PTR;
int get_clocks(void) { -#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX #if CONFIG_SYS_FSL_ESDHC_ADDR == USDHC0_RBASE gd->arch.sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); #elif CONFIG_SYS_FSL_ESDHC_ADDR == USDHC1_RBASE diff --git a/arch/arm/mach-imx/speed.c b/arch/arm/mach-imx/speed.c index ab134d0..f9e486c 100644 --- a/arch/arm/mach-imx/speed.c +++ b/arch/arm/mach-imx/speed.c @@ -11,13 +11,13 @@ #include <asm/arch/imx-regs.h> #include <asm/arch/clock.h>
int get_clocks(void) { -#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX #ifdef CONFIG_FSL_USDHC #if CONFIG_SYS_FSL_ESDHC_ADDR == USDHC2_BASE_ADDR gd->arch.sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); diff --git a/arch/m68k/cpu/mcf5445x/cpu_init.c b/arch/m68k/cpu/mcf5445x/cpu_init.c index 8f4991c..134510b 100644 --- a/arch/m68k/cpu/mcf5445x/cpu_init.c +++ b/arch/m68k/cpu/mcf5445x/cpu_init.c @@ -200,7 +200,7 @@ void cpu_init_f(void) /* Lowest slew rate for UART0,1,2 */ out_8(&gpio->srcr_uart, 0x00);
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX /* eSDHC pin as faster speed */ out_8(&gpio->srcr_sdhc, 0x03);
diff --git a/board/advantech/dms-ba16/dms-ba16.c b/board/advantech/dms-ba16/dms-ba16.c index 0962043..2eccc05 100644 --- a/board/advantech/dms-ba16/dms-ba16.c +++ b/board/advantech/dms-ba16/dms-ba16.c @@ -16,7 +16,7 @@ #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/video.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <miiphy.h> #include <netdev.h> #include <asm/arch/mxc_hdmi.h> @@ -221,7 +221,7 @@ static void setup_iomux_uart(void) imx_iomux_v3_setup_multiple_pads(uart4_pads, ARRAY_SIZE(uart4_pads)); }
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX struct fsl_esdhc_cfg usdhc_cfg[3] = { {USDHC2_BASE_ADDR}, {USDHC3_BASE_ADDR}, diff --git a/board/aristainetos/aristainetos-v1.c b/board/aristainetos/aristainetos-v1.c index 5231c2e..de1a018 100644 --- a/board/aristainetos/aristainetos-v1.c +++ b/board/aristainetos/aristainetos-v1.c @@ -20,7 +20,7 @@ #include <asm/mach-imx/mxc_i2c.h> #include <asm/mach-imx/video.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <miiphy.h> #include <netdev.h> #include <asm/arch/mxc_hdmi.h> diff --git a/board/aristainetos/aristainetos-v2.c b/board/aristainetos/aristainetos-v2.c index 63b1057..c81c441 100644 --- a/board/aristainetos/aristainetos-v2.c +++ b/board/aristainetos/aristainetos-v2.c @@ -20,7 +20,7 @@ #include <asm/mach-imx/mxc_i2c.h> #include <asm/mach-imx/video.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <miiphy.h> #include <netdev.h> #include <asm/arch/mxc_hdmi.h> diff --git a/board/aristainetos/aristainetos.c b/board/aristainetos/aristainetos.c index c88b9fc..9f744b3 100644 --- a/board/aristainetos/aristainetos.c +++ b/board/aristainetos/aristainetos.c @@ -20,7 +20,7 @@ #include <asm/mach-imx/mxc_i2c.h> #include <asm/mach-imx/video.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <miiphy.h> #include <netdev.h> #include <asm/arch/mxc_hdmi.h> @@ -107,7 +107,7 @@ int dram_init(void) return 0; }
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX struct fsl_esdhc_cfg usdhc_cfg[2] = { {USDHC1_BASE_ADDR}, {USDHC2_BASE_ADDR}, diff --git a/board/bachmann/ot1200/ot1200.c b/board/bachmann/ot1200/ot1200.c index 2d73441..067a970 100644 --- a/board/bachmann/ot1200/ot1200.c +++ b/board/bachmann/ot1200/ot1200.c @@ -18,7 +18,7 @@ #include <asm/arch/crm_regs.h> #include <asm/arch/sys_proto.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <netdev.h> #include <i2c.h> #include <pca953x.h> diff --git a/board/barco/platinum/platinum.c b/board/barco/platinum/platinum.c index b484ec2..1c6514a 100644 --- a/board/barco/platinum/platinum.c +++ b/board/barco/platinum/platinum.c @@ -6,7 +6,7 @@
#include <common.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <miiphy.h> #include <netdev.h> #include <asm/io.h> diff --git a/board/barco/titanium/titanium.c b/board/barco/titanium/titanium.c index e9955c8..407bfe9 100644 --- a/board/barco/titanium/titanium.c +++ b/board/barco/titanium/titanium.c @@ -16,7 +16,7 @@ #include <asm/mach-imx/mxc_i2c.h> #include <asm/mach-imx/boot_mode.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <micrel.h> #include <miiphy.h> #include <netdev.h> @@ -215,7 +215,7 @@ int board_ehci_hcd_init(int port)
#endif
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX struct fsl_esdhc_cfg usdhc_cfg[1] = { { USDHC3_BASE_ADDR }, }; diff --git a/board/boundary/nitrogen6x/nitrogen6x.c b/board/boundary/nitrogen6x/nitrogen6x.c index 84d7cee..867eade 100644 --- a/board/boundary/nitrogen6x/nitrogen6x.c +++ b/board/boundary/nitrogen6x/nitrogen6x.c @@ -21,7 +21,7 @@ #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/video.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <micrel.h> #include <miiphy.h> #include <netdev.h> @@ -283,7 +283,7 @@ int board_ehci_power(int port, int on)
#endif
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX static struct fsl_esdhc_cfg usdhc_cfg[2] = { {USDHC3_BASE_ADDR}, {USDHC4_BASE_ADDR}, diff --git a/board/ccv/xpress/xpress.c b/board/ccv/xpress/xpress.c index dcf5e144..35e1c55 100644 --- a/board/ccv/xpress/xpress.c +++ b/board/ccv/xpress/xpress.c @@ -16,7 +16,7 @@ #include <asm/mach-imx/mxc_i2c.h> #include <asm/io.h> #include <common.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <i2c.h> #include <miiphy.h> #include <mmc.h> diff --git a/board/compulab/cl-som-imx7/cl-som-imx7.c b/board/compulab/cl-som-imx7/cl-som-imx7.c index 1bc33b0..94e7bf1 100644 --- a/board/compulab/cl-som-imx7/cl-som-imx7.c +++ b/board/compulab/cl-som-imx7/cl-som-imx7.c @@ -12,7 +12,7 @@ #include <mmc.h> #include <phy.h> #include <netdev.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <power/pmic.h> #include <power/pfuze3000_pmic.h> #include <asm/mach-imx/mxc_i2c.h> @@ -68,7 +68,7 @@ int dram_init(void) return 0; }
#define CL_SOM_IMX7_GPIO_USDHC3_PWR IMX_GPIO_NR(6, 11)
@@ -116,7 +116,7 @@ int board_mmc_init(bd_t *bis)
return 0; } -#endif /* CONFIG_FSL_ESDHC */ +#endif /* CONFIG_FSL_ESDHC_IMX */
#ifdef CONFIG_FEC_MXC
diff --git a/board/compulab/cl-som-imx7/common.c b/board/compulab/cl-som-imx7/common.c index e0f90fd..40ba0f7 100644 --- a/board/compulab/cl-som-imx7/common.c +++ b/board/compulab/cl-som-imx7/common.c @@ -8,7 +8,7 @@ */
#include <common.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <asm-generic/gpio.h> #include "common.h"
@@ -23,7 +23,7 @@ int board_spi_cs_gpio(unsigned int bus, unsigned int cs)
#endif /* CONFIG_SPI */
int board_mmc_getcd(struct mmc *mmc) { @@ -42,4 +42,4 @@ int board_mmc_getcd(struct mmc *mmc) return ret; }
-#endif /* CONFIG_FSL_ESDHC */ +#endif /* CONFIG_FSL_ESDHC_IMX */ diff --git a/board/compulab/cl-som-imx7/common.h b/board/compulab/cl-som-imx7/common.h index 8b15a59..bc19867 100644 --- a/board/compulab/cl-som-imx7/common.h +++ b/board/compulab/cl-som-imx7/common.h @@ -9,19 +9,19 @@
#define PADS_SET_PROT(pads_array) void cl_som_imx7_##pads_array##_set(void)
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX #define CL_SOM_IMX7_GPIO_USDHC1_CD IMX_GPIO_NR(5, 0) PADS_SET_PROT(usdhc1_pads); -#endif /* CONFIG_FSL_ESDHC */ +#endif /* CONFIG_FSL_ESDHC_IMX */ PADS_SET_PROT(uart1_pads); #ifdef CONFIG_SPI PADS_SET_PROT(espi1_pads); #endif /* CONFIG_SPI */
#ifndef CONFIG_SPL_BUILD -#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX PADS_SET_PROT(usdhc3_emmc_pads); -#endif /* CONFIG_FSL_ESDHC */ +#endif /* CONFIG_FSL_ESDHC_IMX */ #ifdef CONFIG_FEC_MXC PADS_SET_PROT(phy1_rst_pads); PADS_SET_PROT(fec1_pads); diff --git a/board/compulab/cl-som-imx7/mux.c b/board/compulab/cl-som-imx7/mux.c index e29d2de..18f16a4 100644 --- a/board/compulab/cl-som-imx7/mux.c +++ b/board/compulab/cl-som-imx7/mux.c @@ -17,7 +17,7 @@ void cl_som_imx7_##pads_array##_set(void) \ imx_iomux_v3_setup_multiple_pads(pads_array, ARRAY_SIZE(pads_array)); \ }
#define USDHC_PAD_CTRL (PAD_CTL_DSE_3P3V_32OHM | PAD_CTL_SRE_SLOW | \ PAD_CTL_HYS | PAD_CTL_PUE | \ @@ -36,7 +36,7 @@ static iomux_v3_cfg_t const usdhc1_pads[] = {
PADS_SET(usdhc1_pads)
#define UART_PAD_CTRL (PAD_CTL_DSE_3P3V_49OHM | \ PAD_CTL_PUS_PU100KOHM | PAD_CTL_HYS) @@ -69,7 +69,7 @@ PADS_SET(espi1_pads)
static iomux_v3_cfg_t const usdhc3_emmc_pads[] = { MX7D_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), @@ -89,7 +89,7 @@ static iomux_v3_cfg_t const usdhc3_emmc_pads[] = {
PADS_SET(usdhc3_emmc_pads)
diff --git a/board/compulab/cl-som-imx7/spl.c b/board/compulab/cl-som-imx7/spl.c index 76a4c8b..f9a19f0 100644 --- a/board/compulab/cl-som-imx7/spl.c +++ b/board/compulab/cl-som-imx7/spl.c @@ -9,14 +9,14 @@
#include <common.h> #include <spl.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/arch-mx7/mx7-pins.h> #include <asm/arch-mx7/clock.h> #include <asm/arch-mx7/mx7-ddr.h> #include "common.h"
static struct fsl_esdhc_cfg cl_som_imx7_spl_usdhc_cfg = { USDHC1_BASE_ADDR, 0, 4}; @@ -27,7 +27,7 @@ int board_mmc_init(bd_t *bis) cl_som_imx7_spl_usdhc_cfg.sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); return fsl_esdhc_initialize(bis, &cl_som_imx7_spl_usdhc_cfg); } -#endif /* CONFIG_FSL_ESDHC */ +#endif /* CONFIG_FSL_ESDHC_IMX */
static iomux_v3_cfg_t const led_pads[] = { MX7D_PAD_SAI1_TX_SYNC__GPIO6_IO14 | MUX_PAD_CTRL(PAD_CTL_PUS_PU5KOHM | diff --git a/board/compulab/cm_fx6/cm_fx6.c b/board/compulab/cm_fx6/cm_fx6.c index d42f57d..e9262c6 100644 --- a/board/compulab/cm_fx6/cm_fx6.c +++ b/board/compulab/cm_fx6/cm_fx6.c @@ -12,7 +12,7 @@ #include <dm.h> #include <dwc_ahsata.h> #include <environment.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <miiphy.h> #include <mtd_node.h> #include <netdev.h> @@ -608,7 +608,7 @@ int board_init(void) cm_fx6_setup_display();
/* This should be done in the MMC driver when MX6 has a clock driver */ -#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX if (IS_ENABLED(CONFIG_BLK)) { int i;
diff --git a/board/compulab/cm_fx6/common.c b/board/compulab/cm_fx6/common.c index e1e4a67..ed8c7a3 100644 --- a/board/compulab/cm_fx6/common.c +++ b/board/compulab/cm_fx6/common.c @@ -11,10 +11,10 @@ #include <asm/arch/sys_proto.h> #include <asm/gpio.h> #include <asm/mach-imx/spi.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include "common.h"
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX #define USDHC_PAD_CTRL (PAD_CTL_PUS_47K_UP | \ PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \ PAD_CTL_SRE_FAST | PAD_CTL_HYS) diff --git a/board/compulab/cm_fx6/spl.c b/board/compulab/cm_fx6/spl.c index acbb2ad..66186ec 100644 --- a/board/compulab/cm_fx6/spl.c +++ b/board/compulab/cm_fx6/spl.c @@ -16,7 +16,7 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/crm_regs.h> #include <asm/mach-imx/iomux-v3.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include "common.h"
enum ddr_config { diff --git a/board/congatec/cgtqmx6eval/cgtqmx6eval.c b/board/congatec/cgtqmx6eval/cgtqmx6eval.c index 50124f8..7c767fb 100644 --- a/board/congatec/cgtqmx6eval/cgtqmx6eval.c +++ b/board/congatec/cgtqmx6eval/cgtqmx6eval.c @@ -21,7 +21,7 @@ #include <asm/arch/mxc_hdmi.h> #include <asm/arch/crm_regs.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <i2c.h> #include <input.h> #include <power/pmic.h> @@ -411,7 +411,7 @@ static void setup_spi(void) } #endif
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX static struct fsl_esdhc_cfg usdhc_cfg[] = { {USDHC2_BASE_ADDR}, {USDHC3_BASE_ADDR}, diff --git a/board/dhelectronics/dh_imx6/dh_imx6.c b/board/dhelectronics/dh_imx6/dh_imx6.c index f9ac5c1..fb2f24f 100644 --- a/board/dhelectronics/dh_imx6/dh_imx6.c +++ b/board/dhelectronics/dh_imx6/dh_imx6.c @@ -20,7 +20,7 @@ #include <asm/mach-imx/sata.h> #include <environment.h> #include <errno.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <fuse.h> #include <i2c.h> #include <miiphy.h> @@ -186,7 +186,7 @@ int board_eth_init(bd_t *bis) } #endif
#define USDHC2_CD_GPIO IMX_GPIO_NR(6, 16) #define USDHC3_CD_GPIO IMX_GPIO_NR(7, 8) diff --git a/board/dhelectronics/dh_imx6/dh_imx6_spl.c b/board/dhelectronics/dh_imx6/dh_imx6_spl.c index 2939389..b492961 100644 --- a/board/dhelectronics/dh_imx6/dh_imx6_spl.c +++ b/board/dhelectronics/dh_imx6/dh_imx6_spl.c @@ -20,7 +20,7 @@ #include <asm/io.h> #include <errno.h> #include <fuse.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <i2c.h> #include <mmc.h> #include <spl.h> diff --git a/board/el/el6x/el6x.c b/board/el/el6x/el6x.c index dd0c112..55db26a 100644 --- a/board/el/el6x/el6x.c +++ b/board/el/el6x/el6x.c @@ -16,7 +16,7 @@ #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/video.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <miiphy.h> #include <netdev.h> #include <asm/arch/mxc_hdmi.h> @@ -255,7 +255,7 @@ iomux_v3_cfg_t const usdhc4_pads[] = { MX6_PAD_SD4_DAT7__SD4_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), };
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX struct fsl_esdhc_cfg usdhc_cfg[2] = { {USDHC2_BASE_ADDR}, {USDHC4_BASE_ADDR}, diff --git a/board/embest/mx6boards/mx6boards.c b/board/embest/mx6boards/mx6boards.c index fed92aa..bcfe125 100644 --- a/board/embest/mx6boards/mx6boards.c +++ b/board/embest/mx6boards/mx6boards.c @@ -27,7 +27,7 @@ #include <i2c.h> #include <input.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <miiphy.h> #include <netdev.h> #include <asm/arch/mxc_hdmi.h> @@ -181,7 +181,7 @@ iomux_v3_cfg_t const usdhc4_pads[] = { MX6_PAD_NANDF_ALE__GPIO6_IO08 | MUX_PAD_CTRL(NO_PAD_CTRL), };
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX struct fsl_esdhc_cfg usdhc_cfg[3] = { {USDHC2_BASE_ADDR}, {USDHC3_BASE_ADDR}, diff --git a/board/freescale/imx8mq_evk/imx8mq_evk.c b/board/freescale/imx8mq_evk/imx8mq_evk.c index 54e0c38..322713c 100644 --- a/board/freescale/imx8mq_evk/imx8mq_evk.c +++ b/board/freescale/imx8mq_evk/imx8mq_evk.c @@ -11,7 +11,7 @@ #include <netdev.h> #include <asm/mach-imx/iomux-v3.h> #include <asm-generic/gpio.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <mmc.h> #include <asm/arch/imx8mq_pins.h> #include <asm/arch/sys_proto.h> diff --git a/board/freescale/imx8mq_evk/spl.c b/board/freescale/imx8mq_evk/spl.c index e6cbc34..f5681ff 100644 --- a/board/freescale/imx8mq_evk/spl.c +++ b/board/freescale/imx8mq_evk/spl.c @@ -16,7 +16,7 @@ #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/gpio.h> #include <asm/mach-imx/mxc_i2c.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <mmc.h> #include <power/pmic.h> #include <power/pfuze100_pmic.h> diff --git a/board/freescale/imx8qxp_mek/imx8qxp_mek.c b/board/freescale/imx8qxp_mek/imx8qxp_mek.c index 63cd605..1207314 100644 --- a/board/freescale/imx8qxp_mek/imx8qxp_mek.c +++ b/board/freescale/imx8qxp_mek/imx8qxp_mek.c @@ -7,7 +7,7 @@ #include <errno.h> #include <linux/libfdt.h> #include <environment.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <asm/io.h> #include <asm/gpio.h> #include <asm/arch/clock.h> diff --git a/board/freescale/m54418twr/m54418twr.c b/board/freescale/m54418twr/m54418twr.c index aa6f0e6..a4943e7 100644 --- a/board/freescale/m54418twr/m54418twr.c +++ b/board/freescale/m54418twr/m54418twr.c @@ -9,7 +9,7 @@ #include <asm/io.h> #include <asm/immap.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h>
diff --git a/board/freescale/mx25pdk/mx25pdk.c b/board/freescale/mx25pdk/mx25pdk.c index 18922d8..c59f0fb 100644 --- a/board/freescale/mx25pdk/mx25pdk.c +++ b/board/freescale/mx25pdk/mx25pdk.c @@ -12,7 +12,7 @@ #include <asm/arch/iomux-mx25.h> #include <asm/arch/clock.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <i2c.h> #include <power/pmic.h> #include <fsl_pmic.h> @@ -24,7 +24,7 @@
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX struct fsl_esdhc_cfg esdhc_cfg[1] = { {IMX_MMC_SDHC1_BASE}, }; @@ -151,7 +151,7 @@ int board_late_init(void) return 0; }
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX int board_mmc_getcd(struct mmc *mmc) { /* Set up the Card Detect pin. */ diff --git a/board/freescale/mx35pdk/mx35pdk.c b/board/freescale/mx35pdk/mx35pdk.c index fa67230..aba17a6 100644 --- a/board/freescale/mx35pdk/mx35pdk.c +++ b/board/freescale/mx35pdk/mx35pdk.c @@ -16,7 +16,7 @@ #include <power/pmic.h> #include <fsl_pmic.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <mc9sdz60.h> #include <mc13892.h> #include <linux/types.h> @@ -261,7 +261,7 @@ int board_eth_init(bd_t *bis) return cpu_eth_init(bis); }
-#if defined(CONFIG_FSL_ESDHC) +#if defined(CONFIG_FSL_ESDHC_IMX)
struct fsl_esdhc_cfg esdhc_cfg = {MMC_SDHC1_BASE_ADDR};
diff --git a/board/freescale/mx51evk/mx51evk.c b/board/freescale/mx51evk/mx51evk.c index 68a9c77..d1bb852 100644 --- a/board/freescale/mx51evk/mx51evk.c +++ b/board/freescale/mx51evk/mx51evk.c @@ -16,7 +16,7 @@ #include <i2c.h> #include <input.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <power/pmic.h> #include <fsl_pmic.h> #include <mc13892.h> @@ -24,7 +24,7 @@
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX struct fsl_esdhc_cfg esdhc_cfg[2] = { {MMC_SDHC1_BASE_ADDR}, {MMC_SDHC2_BASE_ADDR}, @@ -262,7 +262,7 @@ static void power_init(void) gpio_set_value(IMX_GPIO_NR(2, 14), 1); }
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX int board_mmc_getcd(struct mmc *mmc) { struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; diff --git a/board/freescale/mx53ard/mx53ard.c b/board/freescale/mx53ard/mx53ard.c index 9ed4668..e8fcccc 100644 --- a/board/freescale/mx53ard/mx53ard.c +++ b/board/freescale/mx53ard/mx53ard.c @@ -13,7 +13,7 @@ #include <linux/errno.h> #include <netdev.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <asm/gpio.h>
#define ETHERNET_INT IMX_GPIO_NR(2, 31) @@ -112,7 +112,7 @@ static void setup_iomux_uart(void) imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); }
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX struct fsl_esdhc_cfg esdhc_cfg[2] = { {MMC_SDHC1_BASE_ADDR}, {MMC_SDHC2_BASE_ADDR}, diff --git a/board/freescale/mx53evk/mx53evk.c b/board/freescale/mx53evk/mx53evk.c index 5603658..56985c6 100644 --- a/board/freescale/mx53evk/mx53evk.c +++ b/board/freescale/mx53evk/mx53evk.c @@ -15,7 +15,7 @@ #include <netdev.h> #include <i2c.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <power/pmic.h> #include <fsl_pmic.h> #include <asm/gpio.h> @@ -137,7 +137,7 @@ static void setup_iomux_fec(void) imx_iomux_v3_setup_multiple_pads(fec_pads, ARRAY_SIZE(fec_pads)); }
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX struct fsl_esdhc_cfg esdhc_cfg[2] = { {MMC_SDHC1_BASE_ADDR}, {MMC_SDHC3_BASE_ADDR}, diff --git a/board/freescale/mx53loco/mx53loco.c b/board/freescale/mx53loco/mx53loco.c index b66cdcd..d023ce6 100644 --- a/board/freescale/mx53loco/mx53loco.c +++ b/board/freescale/mx53loco/mx53loco.c @@ -18,7 +18,7 @@ #include <i2c.h> #include <input.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <asm/gpio.h> #include <power/pmic.h> #include <dialog_pmic.h> @@ -92,7 +92,7 @@ static void setup_iomux_fec(void) imx_iomux_v3_setup_multiple_pads(fec_pads, ARRAY_SIZE(fec_pads)); }
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX struct fsl_esdhc_cfg esdhc_cfg[2] = { {MMC_SDHC1_BASE_ADDR}, {MMC_SDHC3_BASE_ADDR}, diff --git a/board/freescale/mx53smd/mx53smd.c b/board/freescale/mx53smd/mx53smd.c index 1a1a039..cab0e79 100644 --- a/board/freescale/mx53smd/mx53smd.c +++ b/board/freescale/mx53smd/mx53smd.c @@ -13,7 +13,7 @@ #include <linux/errno.h> #include <netdev.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <asm/gpio.h>
DECLARE_GLOBAL_DATA_PTR; @@ -77,7 +77,7 @@ static void setup_iomux_fec(void) imx_iomux_v3_setup_multiple_pads(fec_pads, ARRAY_SIZE(fec_pads)); }
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX struct fsl_esdhc_cfg esdhc_cfg[1] = { {MMC_SDHC1_BASE_ADDR}, }; diff --git a/board/freescale/mx6qarm2/mx6qarm2.c b/board/freescale/mx6qarm2/mx6qarm2.c index f445f4b..3957c09 100644 --- a/board/freescale/mx6qarm2/mx6qarm2.c +++ b/board/freescale/mx6qarm2/mx6qarm2.c @@ -12,7 +12,7 @@ #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <miiphy.h> #include <netdev.h> #include <usb.h> @@ -103,7 +103,7 @@ static void setup_iomux_enet(void) imx_iomux_v3_setup_multiple_pads(enet_pads, ARRAY_SIZE(enet_pads)); }
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX struct fsl_esdhc_cfg usdhc_cfg[2] = { {USDHC3_BASE_ADDR}, {USDHC4_BASE_ADDR}, diff --git a/board/freescale/mx6sabreauto/mx6sabreauto.c b/board/freescale/mx6sabreauto/mx6sabreauto.c index dd72de9..e1a3b47 100644 --- a/board/freescale/mx6sabreauto/mx6sabreauto.c +++ b/board/freescale/mx6sabreauto/mx6sabreauto.c @@ -18,7 +18,7 @@ #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/spi.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <miiphy.h> #include <netdev.h> #include <asm/arch/sys_proto.h> @@ -282,7 +282,7 @@ static void setup_iomux_uart(void) SETUP_IOMUX_PADS(uart4_pads); }
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX static struct fsl_esdhc_cfg usdhc_cfg[1] = { {USDHC3_BASE_ADDR}, }; diff --git a/board/freescale/mx6sabresd/mx6sabresd.c b/board/freescale/mx6sabresd/mx6sabresd.c index 385a18e..6dd0977 100644 --- a/board/freescale/mx6sabresd/mx6sabresd.c +++ b/board/freescale/mx6sabresd/mx6sabresd.c @@ -17,7 +17,7 @@ #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/video.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <miiphy.h> #include <netdev.h> #include <asm/arch/mxc_hdmi.h> @@ -250,7 +250,7 @@ static void setup_iomux_uart(void) SETUP_IOMUX_PADS(uart1_pads); }
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX struct fsl_esdhc_cfg usdhc_cfg[3] = { {USDHC2_BASE_ADDR}, {USDHC3_BASE_ADDR}, diff --git a/board/freescale/mx6slevk/mx6slevk.c b/board/freescale/mx6slevk/mx6slevk.c index e05aea6..4c48679 100644 --- a/board/freescale/mx6slevk/mx6slevk.c +++ b/board/freescale/mx6slevk/mx6slevk.c @@ -19,7 +19,7 @@ #include <asm/io.h> #include <linux/sizes.h> #include <common.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <i2c.h> #include <mmc.h> #include <netdev.h> diff --git a/board/freescale/mx6sxsabreauto/mx6sxsabreauto.c b/board/freescale/mx6sxsabreauto/mx6sxsabreauto.c index 6e606da..15e921a 100644 --- a/board/freescale/mx6sxsabreauto/mx6sxsabreauto.c +++ b/board/freescale/mx6sxsabreauto/mx6sxsabreauto.c @@ -17,7 +17,7 @@ #include <asm/io.h> #include <linux/sizes.h> #include <common.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <miiphy.h> #include <netdev.h> #include <power/pmic.h> diff --git a/board/freescale/mx6sxsabresd/mx6sxsabresd.c b/board/freescale/mx6sxsabresd/mx6sxsabresd.c index 3e10c7f..8ee85cc 100644 --- a/board/freescale/mx6sxsabresd/mx6sxsabresd.c +++ b/board/freescale/mx6sxsabresd/mx6sxsabresd.c @@ -17,7 +17,7 @@ #include <asm/mach-imx/mxc_i2c.h> #include <linux/sizes.h> #include <common.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <mmc.h> #include <i2c.h> #include <miiphy.h> diff --git a/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c index 636c008..785247f 100644 --- a/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c +++ b/board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c @@ -16,7 +16,7 @@ #include <asm/mach-imx/mxc_i2c.h> #include <asm/io.h> #include <common.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <i2c.h> #include <miiphy.h> #include <linux/sizes.h> @@ -189,7 +189,7 @@ static int board_qspi_init(void) } #endif
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX static struct fsl_esdhc_cfg usdhc_cfg[2] = { {USDHC1_BASE_ADDR, 0, 4}, #if defined(CONFIG_MX6UL_14X14_EVK_EMMC_REWORK) diff --git a/board/freescale/mx6ullevk/mx6ullevk.c b/board/freescale/mx6ullevk/mx6ullevk.c index ad83f36..1f0f70e 100644 --- a/board/freescale/mx6ullevk/mx6ullevk.c +++ b/board/freescale/mx6ullevk/mx6ullevk.c @@ -14,7 +14,7 @@ #include <asm/mach-imx/boot_mode.h> #include <asm/io.h> #include <common.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <linux/sizes.h> #include <mmc.h>
diff --git a/board/freescale/mx7dsabresd/mx7dsabresd.c b/board/freescale/mx7dsabresd/mx7dsabresd.c index 191b59a..86bf030 100644 --- a/board/freescale/mx7dsabresd/mx7dsabresd.c +++ b/board/freescale/mx7dsabresd/mx7dsabresd.c @@ -12,7 +12,7 @@ #include <asm/io.h> #include <linux/sizes.h> #include <common.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <mmc.h> #include <miiphy.h> #include <netdev.h> diff --git a/board/freescale/s32v234evb/s32v234evb.c b/board/freescale/s32v234evb/s32v234evb.c index 464be2b..9bc9ddf 100644 --- a/board/freescale/s32v234evb/s32v234evb.c +++ b/board/freescale/s32v234evb/s32v234evb.c @@ -10,7 +10,7 @@ #include <asm/arch/lpddr2.h> #include <asm/arch/clock.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <miiphy.h> #include <netdev.h> #include <i2c.h> @@ -74,7 +74,7 @@ void setup_iomux_nfc(void) } #endif
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX struct fsl_esdhc_cfg esdhc_cfg[1] = { {USDHC_BASE_ADDR}, }; diff --git a/board/freescale/vf610twr/vf610twr.c b/board/freescale/vf610twr/vf610twr.c index 63be3bd..f6cd7a4 100644 --- a/board/freescale/vf610twr/vf610twr.c +++ b/board/freescale/vf610twr/vf610twr.c @@ -11,7 +11,7 @@ #include <asm/arch/crm_regs.h> #include <asm/arch/clock.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <miiphy.h> #include <netdev.h> #include <i2c.h> @@ -234,7 +234,7 @@ static void setup_iomux_qspi(void) imx_iomux_v3_setup_multiple_pads(qspi0_pads, ARRAY_SIZE(qspi0_pads)); }
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX struct fsl_esdhc_cfg esdhc_cfg[1] = { {ESDHC1_BASE_ADDR}, }; diff --git a/board/gateworks/gw_ventana/common.c b/board/gateworks/gw_ventana/common.c index 8786a12..a543916 100644 --- a/board/gateworks/gw_ventana/common.c +++ b/board/gateworks/gw_ventana/common.c @@ -10,7 +10,7 @@ #include <asm/arch/sys_proto.h> #include <asm/gpio.h> #include <asm/mach-imx/mxc_i2c.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <hwconfig.h> #include <power/pmic.h> #include <power/ltc3676_pmic.h> @@ -1656,7 +1656,7 @@ void setup_pmic(void) } }
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX static struct fsl_esdhc_cfg usdhc_cfg[2];
int board_mmc_init(bd_t *bis) @@ -1753,4 +1753,4 @@ int board_mmc_getcd(struct mmc *mmc) return -1; }
-#endif /* CONFIG_FSL_ESDHC */ +#endif /* CONFIG_FSL_ESDHC_IMX */ diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c index c63fb41..92edc10 100644 --- a/board/gateworks/gw_ventana/gw_ventana.c +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -25,7 +25,7 @@ #include <hwconfig.h> #include <i2c.h> #include <fdt_support.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <jffs2/load_kernel.h> #include <linux/ctype.h> #include <miiphy.h> diff --git a/board/ge/bx50v3/bx50v3.c b/board/ge/bx50v3/bx50v3.c index f42d2ce..8065252 100644 --- a/board/ge/bx50v3/bx50v3.c +++ b/board/ge/bx50v3/bx50v3.c @@ -17,7 +17,7 @@ #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/video.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <miiphy.h> #include <net.h> #include <netdev.h> diff --git a/board/ge/mx53ppd/mx53ppd.c b/board/ge/mx53ppd/mx53ppd.c index 5411e42..bf75bd2 100644 --- a/board/ge/mx53ppd/mx53ppd.c +++ b/board/ge/mx53ppd/mx53ppd.c @@ -24,7 +24,7 @@ #include <netdev.h> #include <i2c.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <asm/gpio.h> #include <power/pmic.h> #include <dialog_pmic.h> diff --git a/board/grinn/liteboard/board.c b/board/grinn/liteboard/board.c index 80910e4..1491b8c 100644 --- a/board/grinn/liteboard/board.c +++ b/board/grinn/liteboard/board.c @@ -17,7 +17,7 @@ #include <asm/mach-imx/boot_mode.h> #include <asm/io.h> #include <common.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <linux/sizes.h> #include <linux/fb.h> #include <miiphy.h> @@ -66,7 +66,7 @@ static void setup_iomux_uart(void) imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); }
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX static struct fsl_esdhc_cfg sd_cfg = {USDHC1_BASE_ADDR, 0, 4};
#define SD_CD_GPIO IMX_GPIO_NR(1, 19) diff --git a/board/inversepath/usbarmory/usbarmory.c b/board/inversepath/usbarmory/usbarmory.c index a490aa8..de4ad83 100644 --- a/board/inversepath/usbarmory/usbarmory.c +++ b/board/inversepath/usbarmory/usbarmory.c @@ -17,7 +17,7 @@ #include <linux/errno.h> #include <i2c.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <asm/gpio.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc.c b/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc.c index ace986f..7bdc64b 100644 --- a/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc.c +++ b/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc.c @@ -18,7 +18,7 @@ #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/mxc_i2c.h> #include <errno.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <fuse.h> #include <i2c.h> #include <miiphy.h> @@ -166,7 +166,7 @@ int board_phy_config(struct phy_device *phydev) } #endif
#define USDHC2_CD_GPIO IMX_GPIO_NR(1, 4) static struct fsl_esdhc_cfg usdhc_cfg[] = { diff --git a/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc_spl.c b/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc_spl.c index d89e112..e284d5e 100644 --- a/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc_spl.c +++ b/board/k+p/kp_imx6q_tpc/kp_imx6q_tpc_spl.c @@ -20,7 +20,7 @@ #include <asm/io.h> #include <errno.h> #include <fuse.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <i2c.h> #include <mmc.h> #include <spl.h> diff --git a/board/kosagi/novena/novena.c b/board/kosagi/novena/novena.c index 9f25865..54d10a4 100644 --- a/board/kosagi/novena/novena.c +++ b/board/kosagi/novena/novena.c @@ -21,7 +21,7 @@ #include <asm/mach-imx/sata.h> #include <asm/mach-imx/video.h> #include <environment.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <i2c.h> #include <input.h> #include <ipu_pixfmt.h> @@ -102,7 +102,7 @@ int drv_keyboard_init(void) /* * SDHC */ -#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX static struct fsl_esdhc_cfg usdhc_cfg[] = { { USDHC3_BASE_ADDR, 0, 4 }, /* Micro SD */ { USDHC2_BASE_ADDR, 0, 4 }, /* Big SD */ diff --git a/board/kosagi/novena/novena_spl.c b/board/kosagi/novena/novena_spl.c index b2d670e..00210ab 100644 --- a/board/kosagi/novena/novena_spl.c +++ b/board/kosagi/novena/novena_spl.c @@ -19,7 +19,7 @@ #include <asm/arch/crm_regs.h> #include <i2c.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <spl.h>
#include <asm/arch/mx6-ddr.h> @@ -404,7 +404,7 @@ static inline void novena_spl_setup_iomux_video(void) {} /* * SPL boots from uSDHC card */ -#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX static struct fsl_esdhc_cfg usdhc_cfg = { USDHC3_BASE_ADDR, 0, 4 }; @@ -566,7 +566,7 @@ void board_init_f(ulong dummy) #ifdef CONFIG_BOARD_POSTCLK_INIT board_postclk_init(); #endif -#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX get_clocks(); #endif
diff --git a/board/liebherr/display5/common.c b/board/liebherr/display5/common.c index 4eb86d8..7b89d16 100644 --- a/board/liebherr/display5/common.c +++ b/board/liebherr/display5/common.c @@ -89,7 +89,7 @@ void displ5_set_iomux_ecspi_spl(void) {} void displ5_set_iomux_ecspi(void) {} #endif
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX iomux_v3_cfg_t const usdhc4_pads[] = { MX6_PAD_SD4_CLK__SD4_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), MX6_PAD_SD4_CMD__SD4_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), diff --git a/board/liebherr/display5/display5.c b/board/liebherr/display5/display5.c index d838317..6b7ff0a 100644 --- a/board/liebherr/display5/display5.c +++ b/board/liebherr/display5/display5.c @@ -21,7 +21,7 @@ #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/spi.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <miiphy.h> #include <netdev.h> #include <i2c.h> @@ -186,7 +186,7 @@ iomux_v3_cfg_t const misc_pads[] = { MX6_PAD_EIM_D29__GPIO3_IO29 | MUX_PAD_CTRL(NO_PAD_CTRL), };
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX struct fsl_esdhc_cfg usdhc_cfg[1] = { { USDHC4_BASE_ADDR, 0, 8, }, }; @@ -204,7 +204,7 @@ int board_mmc_init(bd_t *bis)
return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); } -#endif /* CONFIG_FSL_ESDHC */ +#endif /* CONFIG_FSL_ESDHC_IMX */
static void displ5_setup_ecspi(void) { diff --git a/board/liebherr/display5/spl.c b/board/liebherr/display5/spl.c index 0c0172e..27f843e 100644 --- a/board/liebherr/display5/spl.c +++ b/board/liebherr/display5/spl.c @@ -18,7 +18,7 @@ #include <asm/mach-imx/iomux-v3.h> #include <asm/gpio.h> #include <environment.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <netdev.h> #include <bootcount.h> #include <watchdog.h> diff --git a/board/liebherr/mccmon6/mccmon6.c b/board/liebherr/mccmon6/mccmon6.c index 946b91f..0e069a7 100644 --- a/board/liebherr/mccmon6/mccmon6.c +++ b/board/liebherr/mccmon6/mccmon6.c @@ -16,7 +16,7 @@ #include <asm/mach-imx/spi.h> #include <asm/mach-imx/boot_mode.h> #include <asm/io.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <mmc.h> #include <netdev.h> #include <micrel.h> diff --git a/board/liebherr/mccmon6/spl.c b/board/liebherr/mccmon6/spl.c index acfc490..f0ed78c 100644 --- a/board/liebherr/mccmon6/spl.c +++ b/board/liebherr/mccmon6/spl.c @@ -14,7 +14,7 @@ #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/video.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <asm/arch/crm_regs.h> #include <asm/io.h> #include <asm/arch/sys_proto.h> diff --git a/board/logicpd/imx6/imx6logic.c b/board/logicpd/imx6/imx6logic.c index b17a3b1..1bca1c4 100644 --- a/board/logicpd/imx6/imx6logic.c +++ b/board/logicpd/imx6/imx6logic.c @@ -12,7 +12,7 @@ #include <miiphy.h> #include <input.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <asm/io.h> #include <asm/gpio.h> #include <linux/sizes.h> @@ -199,7 +199,7 @@ static iomux_v3_cfg_t const usdhc2_pads[] = { MX6_PAD_GPIO_4__GPIO1_IO04 | MUX_PAD_CTRL(NO_PAD_CTRL), /* CD */ };
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX struct fsl_esdhc_cfg usdhc_cfg[] = { {USDHC1_BASE_ADDR}, /* SOM */ {USDHC2_BASE_ADDR} /* Baseboard */ diff --git a/board/menlo/m53menlo/m53menlo.c b/board/menlo/m53menlo/m53menlo.c index 6bdd6d5..35e9b02 100644 --- a/board/menlo/m53menlo/m53menlo.c +++ b/board/menlo/m53menlo/m53menlo.c @@ -18,7 +18,7 @@ #include <asm/gpio.h> #include <asm/spl.h> #include <fdt_support.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <i2c.h> #include <ipu_pixfmt.h> #include <linux/errno.h> @@ -150,7 +150,7 @@ static void setup_iomux_fec(void) imx_iomux_v3_setup_multiple_pads(fec_pads, ARRAY_SIZE(fec_pads)); }
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX struct fsl_esdhc_cfg esdhc_cfg = { MMC_SDHC1_BASE_ADDR, }; diff --git a/board/phytec/pcl063/pcl063.c b/board/phytec/pcl063/pcl063.c index 38b233d..b99fa6a 100644 --- a/board/phytec/pcl063/pcl063.c +++ b/board/phytec/pcl063/pcl063.c @@ -12,7 +12,7 @@ #include <asm/arch/sys_proto.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/mxc_i2c.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <linux/bitops.h> #include <miiphy.h> #include <netdev.h> diff --git a/board/phytec/pcl063/spl.c b/board/phytec/pcl063/spl.c index b93cd49..fc4a9cc 100644 --- a/board/phytec/pcl063/spl.c +++ b/board/phytec/pcl063/spl.c @@ -13,7 +13,7 @@ #include <asm/arch/mx6-ddr.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/crm_regs.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h>
/* Configuration for Micron MT41K256M16TW-107 IT:P, 32M x 16 x 8 -> 256MiB */
@@ -100,7 +100,7 @@ static void spl_dram_init(void) mx6_dram_cfg(&ddr_sysinfo, &mx6_mmcd_calib, &mem_ddr); }
#define USDHC_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ PAD_CTL_PUS_22K_UP | PAD_CTL_SPEED_LOW | \ @@ -137,7 +137,7 @@ int board_mmc_init(bd_t *bis) return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); }
void board_init_f(ulong dummy) { diff --git a/board/phytec/pcm058/pcm058.c b/board/phytec/pcm058/pcm058.c index 5ecaf00..ac5e3a2 100644 --- a/board/phytec/pcm058/pcm058.c +++ b/board/phytec/pcm058/pcm058.c @@ -25,7 +25,7 @@ #include <asm/gpio.h> #include <mmc.h> #include <i2c.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <nand.h> #include <miiphy.h> #include <netdev.h> diff --git a/board/phytec/pfla02/pfla02.c b/board/phytec/pfla02/pfla02.c index aae23a3..753cf2b 100644 --- a/board/phytec/pfla02/pfla02.c +++ b/board/phytec/pfla02/pfla02.c @@ -19,7 +19,7 @@ #include <asm/gpio.h> #include <mmc.h> #include <i2c.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <nand.h> #include <miiphy.h> #include <netdev.h> diff --git a/board/samtec/vining_2000/vining_2000.c b/board/samtec/vining_2000/vining_2000.c index f37365c..8f6b026 100644 --- a/board/samtec/vining_2000/vining_2000.c +++ b/board/samtec/vining_2000/vining_2000.c @@ -18,7 +18,7 @@ #include <linux/sizes.h> #include <common.h> #include <environment.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <mmc.h> #include <i2c.h> #include <miiphy.h> diff --git a/board/seco/common/mx6.c b/board/seco/common/mx6.c index fd7008a..51832b9 100644 --- a/board/seco/common/mx6.c +++ b/board/seco/common/mx6.c @@ -16,7 +16,7 @@ #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/boot_mode.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <miiphy.h> #include <netdev.h> #include <asm/arch/mxc_hdmi.h> diff --git a/board/seco/mx6quq7/mx6quq7.c b/board/seco/mx6quq7/mx6quq7.c index 094a210..c1e36b6 100644 --- a/board/seco/mx6quq7/mx6quq7.c +++ b/board/seco/mx6quq7/mx6quq7.c @@ -17,7 +17,7 @@ #include <asm/mach-imx/boot_mode.h> #include <malloc.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <miiphy.h> #include <netdev.h> #include <asm/arch/mxc_hdmi.h> diff --git a/board/sks-kinkel/sksimx6/sksimx6.c b/board/sks-kinkel/sksimx6/sksimx6.c index f6e3d4d..59a07a9 100644 --- a/board/sks-kinkel/sksimx6/sksimx6.c +++ b/board/sks-kinkel/sksimx6/sksimx6.c @@ -12,7 +12,7 @@ #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/video.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <asm/arch/crm_regs.h> #include <asm/io.h> #include <asm/arch/sys_proto.h> diff --git a/board/solidrun/mx6cuboxi/mx6cuboxi.c b/board/solidrun/mx6cuboxi/mx6cuboxi.c index cf63427..d333ccc 100644 --- a/board/solidrun/mx6cuboxi/mx6cuboxi.c +++ b/board/solidrun/mx6cuboxi/mx6cuboxi.c @@ -24,7 +24,7 @@ #include <asm/mach-imx/sata.h> #include <asm/mach-imx/video.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <malloc.h> #include <miiphy.h> #include <netdev.h> diff --git a/board/tbs/tbs2910/tbs2910.c b/board/tbs/tbs2910/tbs2910.c index fb0e773..d8db7a8 100644 --- a/board/tbs/tbs2910/tbs2910.c +++ b/board/tbs/tbs2910/tbs2910.c @@ -13,7 +13,7 @@ #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/video.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <miiphy.h> #include <netdev.h> #include <asm/arch/mxc_hdmi.h> @@ -98,7 +98,7 @@ static void setup_iomux_uart(void) imx_iomux_v3_setup_multiple_pads(uart2_pads, ARRAY_SIZE(uart2_pads)); }
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX /* set environment device to boot device when booting from SD */ int board_mmc_get_env_dev(int devno) { @@ -109,7 +109,7 @@ int board_mmc_get_env_part(int devno) { return (devno == 3) ? 1 : 0; /* part 0 for SD2 / SD3, part 1 for eMMC */ } -#endif /* CONFIG_FSL_ESDHC */ +#endif /* CONFIG_FSL_ESDHC_IMX */
#ifdef CONFIG_VIDEO_IPUV3 static void do_enable_hdmi(struct display_info_t const *dev) diff --git a/board/technexion/pico-imx6ul/spl.c b/board/technexion/pico-imx6ul/spl.c index f972cc9..284aa40 100644 --- a/board/technexion/pico-imx6ul/spl.c +++ b/board/technexion/pico-imx6ul/spl.c @@ -10,7 +10,7 @@ #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/boot_mode.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <linux/libfdt.h> #include <spl.h>
diff --git a/board/technexion/pico-imx7d/spl.c b/board/technexion/pico-imx7d/spl.c index 92a4646..c55a35d 100644 --- a/board/technexion/pico-imx7d/spl.c +++ b/board/technexion/pico-imx7d/spl.c @@ -13,7 +13,7 @@ #include <asm/arch-mx7/mx7-ddr.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/gpio.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <spl.h>
#if defined(CONFIG_SPL_BUILD) diff --git a/board/technologic/ts4800/ts4800.c b/board/technologic/ts4800/ts4800.c index a0e021e..927a19d 100644 --- a/board/technologic/ts4800/ts4800.c +++ b/board/technologic/ts4800/ts4800.c @@ -19,7 +19,7 @@ #include <environment.h> #include <mmc.h> #include <input.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <mc13892.h>
#include <malloc.h> @@ -29,7 +29,7 @@
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX struct fsl_esdhc_cfg esdhc_cfg[2] = { {MMC_SDHC1_BASE_ADDR}, {MMC_SDHC2_BASE_ADDR}, @@ -96,7 +96,7 @@ static void setup_iomux_fec(void) imx_iomux_v3_setup_multiple_pads(fec_pads, ARRAY_SIZE(fec_pads)); }
-#ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_IMX int board_mmc_getcd(struct mmc *mmc) { struct fsl_esdhc_cfg *cfg = (struct fsl_esdhc_cfg *)mmc->priv; diff --git a/board/toradex/apalis_imx6/apalis_imx6.c b/board/toradex/apalis_imx6/apalis_imx6.c index 3e59185..4d05c81 100644 --- a/board/toradex/apalis_imx6/apalis_imx6.c +++ b/board/toradex/apalis_imx6/apalis_imx6.c @@ -27,7 +27,7 @@ #include <dm/platform_data/serial_mxc.h> #include <dwc_ahsata.h> #include <environment.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <imx_thermal.h> #include <micrel.h> #include <miiphy.h> @@ -131,7 +131,7 @@ iomux_v3_cfg_t const usdhc3_pads[] = { MX6_PAD_SD3_DAT7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), MX6_PAD_SD3_RST__GPIO7_IO08 | MUX_PAD_CTRL(WEAK_PULLUP) | MUX_MODE_SION, }; -#endif /* CONFIG_FSL_ESDHC & CONFIG_SPL_BUILD */ +#endif /* CONFIG_FSL_ESDHC_IMX & CONFIG_SPL_BUILD */
int mx6_rgmii_rework(struct phy_device *phydev) { @@ -355,7 +355,7 @@ int board_mmc_init(bd_t *bis)
return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); } -#endif /* CONFIG_FSL_ESDHC & CONFIG_SPL_BUILD */ +#endif /* CONFIG_FSL_ESDHC_IMX & CONFIG_SPL_BUILD */
int board_phy_config(struct phy_device *phydev) { diff --git a/board/toradex/colibri_imx6/colibri_imx6.c b/board/toradex/colibri_imx6/colibri_imx6.c index c634e32..6417ba4 100644 --- a/board/toradex/colibri_imx6/colibri_imx6.c +++ b/board/toradex/colibri_imx6/colibri_imx6.c @@ -25,7 +25,7 @@ #include <cpu.h> #include <dm/platform_data/serial_mxc.h> #include <environment.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <imx_thermal.h> #include <micrel.h> #include <miiphy.h> @@ -110,7 +110,7 @@ iomux_v3_cfg_t const usdhc3_pads[] = { MX6_PAD_SD3_DAT7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), MX6_PAD_SD3_RST__SD3_RESET | MUX_PAD_CTRL(USDHC_PAD_CTRL), }; -#endif /* CONFIG_FSL_ESDHC & CONFIG_SPL_BUILD */ +#endif /* CONFIG_FSL_ESDHC_IMX & CONFIG_SPL_BUILD */
iomux_v3_cfg_t const enet_pads[] = { MX6_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), @@ -361,7 +361,7 @@ int board_mmc_init(bd_t *bis)
int board_phy_config(struct phy_device *phydev) { diff --git a/board/toradex/colibri_imx7/colibri_imx7.c b/board/toradex/colibri_imx7/colibri_imx7.c index 61bf8bf..0eb8347 100644 --- a/board/toradex/colibri_imx7/colibri_imx7.c +++ b/board/toradex/colibri_imx7/colibri_imx7.c @@ -15,7 +15,7 @@ #include <dm.h> #include <dm/platform_data/serial_mxc.h> #include <fdt_support.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <jffs2/load_kernel.h> #include <linux/sizes.h> #include <mmc.h> diff --git a/board/tqc/tqma6/tqma6.c b/board/tqc/tqma6/tqma6.c index 372a17c..5f0c7aa 100644 --- a/board/tqc/tqma6/tqma6.c +++ b/board/tqc/tqma6/tqma6.c @@ -18,7 +18,7 @@ #include <asm/mach-imx/mxc_i2c.h> #include <asm/mach-imx/spi.h> #include <common.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <linux/libfdt.h> #include <i2c.h> #include <mmc.h> diff --git a/board/tqc/tqma6/tqma6_mba6.c b/board/tqc/tqma6/tqma6_mba6.c index f7072b8..8a2431e 100644 --- a/board/tqc/tqma6/tqma6_mba6.c +++ b/board/tqc/tqma6/tqma6_mba6.c @@ -18,7 +18,7 @@ #include <asm/mach-imx/mxc_i2c.h>
#include <common.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <linux/libfdt.h> #include <malloc.h> #include <i2c.h> diff --git a/board/tqc/tqma6/tqma6_wru4.c b/board/tqc/tqma6/tqma6_wru4.c index aaee9bf..99196ad 100644 --- a/board/tqc/tqma6/tqma6_wru4.c +++ b/board/tqc/tqma6/tqma6_wru4.c @@ -21,7 +21,7 @@ #include <asm/mach-imx/mxc_i2c.h>
#include <common.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <linux/libfdt.h> #include <malloc.h> #include <i2c.h> diff --git a/board/udoo/neo/neo.c b/board/udoo/neo/neo.c index 8281613..d51f648 100644 --- a/board/udoo/neo/neo.c +++ b/board/udoo/neo/neo.c @@ -16,7 +16,7 @@ #include <asm/gpio.h> #include <asm/mach-imx/iomux-v3.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <asm/arch/crm_regs.h> #include <asm/io.h> #include <asm/mach-imx/mxc_i2c.h> diff --git a/board/udoo/udoo.c b/board/udoo/udoo.c index 491e9be..c34a5a6 100644 --- a/board/udoo/udoo.c +++ b/board/udoo/udoo.c @@ -15,7 +15,7 @@ #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/sata.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <asm/arch/crm_regs.h> #include <asm/io.h> #include <asm/arch/sys_proto.h> diff --git a/board/udoo/udoo_spl.c b/board/udoo/udoo_spl.c index 30663e2..b287fbf 100644 --- a/board/udoo/udoo_spl.c +++ b/board/udoo/udoo_spl.c @@ -15,7 +15,7 @@ #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/video.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <asm/arch/crm_regs.h> #include <asm/io.h> #include <asm/arch/sys_proto.h> diff --git a/board/variscite/dart_6ul/dart_6ul.c b/board/variscite/dart_6ul/dart_6ul.c index 4765595..2d0b760 100644 --- a/board/variscite/dart_6ul/dart_6ul.c +++ b/board/variscite/dart_6ul/dart_6ul.c @@ -10,7 +10,7 @@ #include <asm/arch/sys_proto.h> #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/mxc_i2c.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <linux/bitops.h> #include <miiphy.h> #include <netdev.h> diff --git a/board/variscite/dart_6ul/spl.c b/board/variscite/dart_6ul/spl.c index f7e6ab6..798523d 100644 --- a/board/variscite/dart_6ul/spl.c +++ b/board/variscite/dart_6ul/spl.c @@ -11,7 +11,7 @@ #include <asm/arch/mx6-ddr.h> #include <asm/arch/mx6-pins.h> #include <asm/arch/crm_regs.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h>
#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ diff --git a/board/wandboard/spl.c b/board/wandboard/spl.c index 000cb10..75f6980 100644 --- a/board/wandboard/spl.c +++ b/board/wandboard/spl.c @@ -14,7 +14,7 @@ #include <asm/mach-imx/iomux-v3.h> #include <asm/mach-imx/video.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <asm/arch/crm_regs.h> #include <asm/io.h> #include <asm/arch/sys_proto.h> diff --git a/board/warp/warp.c b/board/warp/warp.c index f346b92..a44a578 100644 --- a/board/warp/warp.c +++ b/board/warp/warp.c @@ -19,7 +19,7 @@ #include <linux/sizes.h> #include <common.h> #include <watchdog.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <i2c.h> #include <mmc.h> #include <usb.h> diff --git a/board/woodburn/woodburn.c b/board/woodburn/woodburn.c index 42633ed..5cab3f4 100644 --- a/board/woodburn/woodburn.c +++ b/board/woodburn/woodburn.c @@ -17,7 +17,7 @@ #include <fsl_pmic.h> #include <mc13892.h> #include <mmc.h> -#include <fsl_esdhc.h> +#include <fsl_esdhc_imx.h> #include <linux/types.h> #include <asm/gpio.h> #include <asm/arch/sys_proto.h> @@ -206,7 +206,7 @@ int board_init(void) return 0; }
-#if defined(CONFIG_FSL_ESDHC) +#if defined(CONFIG_FSL_ESDHC_IMX) struct fsl_esdhc_cfg esdhc_cfg = {MMC_SDHC1_BASE_ADDR};
int board_mmc_init(bd_t *bis) diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 3292d64..0f20f2e 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -59,7 +59,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index 87a8678..49dd9bb 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -35,7 +35,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index 256d722..06c05f7 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -35,7 +35,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index 44b30e3..e645055 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -35,7 +35,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y diff --git a/configs/bk4r1_defconfig b/configs/bk4r1_defconfig index 7c455d2..d9e337a 100644 --- a/configs/bk4r1_defconfig +++ b/configs/bk4r1_defconfig @@ -52,7 +52,7 @@ CONFIG_SYS_EEPROM_SIZE=32768 CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=6 CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD=y CONFIG_NAND_VF610_NFC=y CONFIG_NAND_VF610_NFC_DT=y diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index 0a6ff20..ec042d7 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -55,7 +55,7 @@ CONFIG_DFU_MMC=y CONFIG_DFU_SF=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/configs/cl-som-imx7_defconfig b/configs/cl-som-imx7_defconfig index 73c78e2..cad8f4b 100644 --- a/configs/cl-som-imx7_defconfig +++ b/configs/cl-som-imx7_defconfig @@ -51,7 +51,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx7d-sdb" CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index ce3f9de..002db24 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -55,7 +55,7 @@ CONFIG_DWC_AHSATA=y # CONFIG_DWC_AHSATA_AHCI is not set CONFIG_DM_KEYBOARD=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_SPI_FLASH=y diff --git a/configs/colibri-imx6ull_defconfig b/configs/colibri-imx6ull_defconfig index 3dbb4d9..fbd1c94 100644 --- a/configs/colibri-imx6ull_defconfig +++ b/configs/colibri-imx6ull_defconfig @@ -51,7 +51,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MXC=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD=y CONFIG_NAND=y CONFIG_NAND_MXS=y diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 72e9128..333268a 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -58,7 +58,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index bfb84ec..9ccbd60 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -50,7 +50,7 @@ CONFIG_DFU_NAND=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD=y CONFIG_NAND=y CONFIG_NAND_MXS_DT=y diff --git a/configs/colibri_imx7_emmc_defconfig b/configs/colibri_imx7_emmc_defconfig index af3cf93..265402b 100644 --- a/configs/colibri_imx7_emmc_defconfig +++ b/configs/colibri_imx7_emmc_defconfig @@ -46,7 +46,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index 7334002..268eee9 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -58,7 +58,7 @@ CONFIG_DM_GPIO=y CONFIG_VYBRID_GPIO=y CONFIG_DM_MMC=y # CONFIG_MMC_HW_PARTITIONING is not set -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD=y CONFIG_NAND_VF610_NFC=y CONFIG_NAND_VF610_NFC_DT=y diff --git a/configs/dh_imx6_defconfig b/configs/dh_imx6_defconfig index d9ec5c7..a71a658 100644 --- a/configs/dh_imx6_defconfig +++ b/configs/dh_imx6_defconfig @@ -40,7 +40,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DWC_AHSATA=y CONFIG_BOOTCOUNT_LIMIT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=25000000 diff --git a/configs/display5_defconfig b/configs/display5_defconfig index 3b793f4..938414c 100644 --- a/configs/display5_defconfig +++ b/configs/display5_defconfig @@ -64,7 +64,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD_DEVICE=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=1 diff --git a/configs/display5_factory_defconfig b/configs/display5_factory_defconfig index 0d9eed3..40df91a 100644 --- a/configs/display5_factory_defconfig +++ b/configs/display5_factory_defconfig @@ -65,7 +65,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DFU_MMC=y CONFIG_DFU_SF=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD_DEVICE=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=1 diff --git a/configs/dms-ba16-1g_defconfig b/configs/dms-ba16-1g_defconfig index 980f7b4..4231adb 100644 --- a/configs/dms-ba16-1g_defconfig +++ b/configs/dms-ba16-1g_defconfig @@ -33,7 +33,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DWC_AHSATA=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/configs/dms-ba16_defconfig b/configs/dms-ba16_defconfig index bea75b5..f98088d 100644 --- a/configs/dms-ba16_defconfig +++ b/configs/dms-ba16_defconfig @@ -32,7 +32,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DWC_AHSATA=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/configs/ge_bx50v3_defconfig b/configs/ge_bx50v3_defconfig index 8be881b..60bdcd6 100644 --- a/configs/ge_bx50v3_defconfig +++ b/configs/ge_bx50v3_defconfig @@ -43,7 +43,7 @@ CONFIG_SYS_BOOTCOUNT_EXT_DEVPART="1:5" CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index f9857d1..19aa73f 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -63,7 +63,7 @@ CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_SUPPORT_EMMC_RPMB=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD_DEVICE=y CONFIG_PHYLIB=y CONFIG_E1000=y diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index 27ef264..1461cb1 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -63,7 +63,7 @@ CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_SUPPORT_EMMC_RPMB=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD_DEVICE=y CONFIG_PHYLIB=y CONFIG_MV88E61XX_SWITCH=y diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index 25af087..f440363 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -65,7 +65,7 @@ CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_SUPPORT_EMMC_RPMB=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx6dl_icore_nand_defconfig b/configs/imx6dl_icore_nand_defconfig index f282064..eb9d456 100644 --- a/configs/imx6dl_icore_nand_defconfig +++ b/configs/imx6dl_icore_nand_defconfig @@ -40,7 +40,7 @@ CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="imx6dl-icore" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx6dl_mamoj_defconfig b/configs/imx6dl_mamoj_defconfig index 5ad49b3..579c2c4 100644 --- a/configs/imx6dl_mamoj_defconfig +++ b/configs/imx6dl_mamoj_defconfig @@ -33,7 +33,7 @@ CONFIG_FASTBOOT_FLASH=y CONFIG_FASTBOOT_FLASH_MMC_DEV=2 CONFIG_SYS_I2C_MXC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y diff --git a/configs/imx6q_icore_nand_defconfig b/configs/imx6q_icore_nand_defconfig index d39fd95..2ee3099 100644 --- a/configs/imx6q_icore_nand_defconfig +++ b/configs/imx6q_icore_nand_defconfig @@ -41,7 +41,7 @@ CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index 0bb2fc6..cf6964b 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -63,7 +63,7 @@ CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_PCF8575_GPIO=y CONFIG_LED=y CONFIG_LED_GPIO=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD=y CONFIG_NAND=y CONFIG_NAND_MXS=y diff --git a/configs/imx6qdl_icore_mipi_defconfig b/configs/imx6qdl_icore_mipi_defconfig index 8704006..5537aa0 100644 --- a/configs/imx6qdl_icore_mipi_defconfig +++ b/configs/imx6qdl_icore_mipi_defconfig @@ -45,7 +45,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore-mipi" CONFIG_OF_LIST="imx6q-icore-mipi imx6dl-icore-mipi" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y CONFIG_FEC_MXC=y diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index b659799..aa11f61 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -55,7 +55,7 @@ CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_SYS_BOOTCOUNT_MAGIC=0x0B01C041 CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6qdl_icore_nand_defconfig index ad4b930..1657298 100644 --- a/configs/imx6qdl_icore_nand_defconfig +++ b/configs/imx6qdl_icore_nand_defconfig @@ -40,7 +40,7 @@ CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx6qdl_icore_rqs_defconfig b/configs/imx6qdl_icore_rqs_defconfig index 83b926b..2e1e3d1 100644 --- a/configs/imx6qdl_icore_rqs_defconfig +++ b/configs/imx6qdl_icore_rqs_defconfig @@ -42,7 +42,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx6q-icore-rqs" CONFIG_OF_LIST="imx6q-icore-rqs imx6dl-icore-rqs" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y diff --git a/configs/imx6ul_geam_mmc_defconfig b/configs/imx6ul_geam_mmc_defconfig index 318628b..39a121f 100644 --- a/configs/imx6ul_geam_mmc_defconfig +++ b/configs/imx6ul_geam_mmc_defconfig @@ -39,7 +39,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-geam" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y CONFIG_FEC_MXC=y diff --git a/configs/imx6ul_geam_nand_defconfig b/configs/imx6ul_geam_nand_defconfig index ea4d7ad..68e16bb 100644 --- a/configs/imx6ul_geam_nand_defconfig +++ b/configs/imx6ul_geam_nand_defconfig @@ -41,7 +41,7 @@ CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-geam" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx6ul_isiot_emmc_defconfig b/configs/imx6ul_isiot_emmc_defconfig index 00c9bbd..c7c1d34 100644 --- a/configs/imx6ul_isiot_emmc_defconfig +++ b/configs/imx6ul_isiot_emmc_defconfig @@ -39,7 +39,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-isiot-emmc" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y CONFIG_FEC_MXC=y diff --git a/configs/imx6ul_isiot_nand_defconfig b/configs/imx6ul_isiot_nand_defconfig index c60bde7..8ed5ea4 100644 --- a/configs/imx6ul_isiot_nand_defconfig +++ b/configs/imx6ul_isiot_nand_defconfig @@ -41,7 +41,7 @@ CONFIG_CMD_UBI=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-isiot-nand" CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/imx8mq_evk_defconfig b/configs/imx8mq_evk_defconfig index 1c857bc..531f453 100644 --- a/configs/imx8mq_evk_defconfig +++ b/configs/imx8mq_evk_defconfig @@ -31,7 +31,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MXC=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_DM_ETH=y CONFIG_PINCTRL=y diff --git a/configs/imx8qm_mek_defconfig b/configs/imx8qm_mek_defconfig index f1155d6..a78937f 100644 --- a/configs/imx8qm_mek_defconfig +++ b/configs/imx8qm_mek_defconfig @@ -52,7 +52,7 @@ CONFIG_I2C_MUX=y CONFIG_I2C_MUX_PCA954x=y CONFIG_MISC=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y CONFIG_PHY_ATHEROS=y diff --git a/configs/imx8qxp_mek_defconfig b/configs/imx8qxp_mek_defconfig index 1ce175e..39e5f5e 100644 --- a/configs/imx8qxp_mek_defconfig +++ b/configs/imx8qxp_mek_defconfig @@ -55,7 +55,7 @@ CONFIG_I2C_MUX=y CONFIG_I2C_MUX_PCA954x=y CONFIG_MISC=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_PHYLIB=y CONFIG_PHY_ADDR_ENABLE=y diff --git a/configs/kp_imx53_defconfig b/configs/kp_imx53_defconfig index a6a727b..86d6727 100644 --- a/configs/kp_imx53_defconfig +++ b/configs/kp_imx53_defconfig @@ -31,7 +31,7 @@ CONFIG_DEFAULT_DEVICE_TREE="imx53-kp" CONFIG_ENV_IS_IN_MMC=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y CONFIG_I2C_DEFAULT_BUS_NUMBER=0x1 -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_PHY_SMSC=y CONFIG_FEC_MXC=y diff --git a/configs/kp_imx6q_tpc_defconfig b/configs/kp_imx6q_tpc_defconfig index 9b6ff4a..87b25e6 100644 --- a/configs/kp_imx6q_tpc_defconfig +++ b/configs/kp_imx6q_tpc_defconfig @@ -34,7 +34,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_ISO_PARTITION is not set # CONFIG_EFI_PARTITION is not set CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_PHY_ATHEROS=y CONFIG_FEC_MXC=y diff --git a/configs/liteboard_defconfig b/configs/liteboard_defconfig index a439631..456f1e3 100644 --- a/configs/liteboard_defconfig +++ b/configs/liteboard_defconfig @@ -39,7 +39,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_DM_ETH=y CONFIG_MII=y diff --git a/configs/m53menlo_defconfig b/configs/m53menlo_defconfig index 0e5fa01..9622cb7 100644 --- a/configs/m53menlo_defconfig +++ b/configs/m53menlo_defconfig @@ -52,7 +52,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_SYS_BOOTCOUNT_MAGIC=0x0B01C041 -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_NAND=y CONFIG_NAND_MXC=y CONFIG_PHYLIB=y diff --git a/configs/marsboard_defconfig b/configs/marsboard_defconfig index 8607760..f6e351f 100644 --- a/configs/marsboard_defconfig +++ b/configs/marsboard_defconfig @@ -21,7 +21,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/configs/mccmon6_nor_defconfig b/configs/mccmon6_nor_defconfig index af2a106..7816200 100644 --- a/configs/mccmon6_nor_defconfig +++ b/configs/mccmon6_nor_defconfig @@ -29,7 +29,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=8000000.nor:32m@0x0(mccmon6-image.nor),256k@0x CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_MTD_DEVICE=y diff --git a/configs/mccmon6_sd_defconfig b/configs/mccmon6_sd_defconfig index aac433c..522207a 100644 --- a/configs/mccmon6_sd_defconfig +++ b/configs/mccmon6_sd_defconfig @@ -30,7 +30,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=8000000.nor:32m@0x0(mccmon6-image.nor),256k@0x CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y CONFIG_MTD_DEVICE=y diff --git a/configs/mx25pdk_defconfig b/configs/mx25pdk_defconfig index c024d79..a6ee105 100644 --- a/configs/mx25pdk_defconfig +++ b/configs/mx25pdk_defconfig @@ -19,7 +19,7 @@ CONFIG_CMD_DATE=y CONFIG_CMD_FS_GENERIC=y CONFIG_DOS_PARTITION=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MII=y CONFIG_FS_EXT4=y CONFIG_FS_FAT=y diff --git a/configs/mx35pdk_defconfig b/configs/mx35pdk_defconfig index 7fec4b6..3d36045 100644 --- a/configs/mx35pdk_defconfig +++ b/configs/mx35pdk_defconfig @@ -26,7 +26,7 @@ CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set CONFIG_ENV_IS_IN_FLASH=y CONFIG_MXC_GPIO=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/mx51evk_defconfig b/configs/mx51evk_defconfig index ffb821e..42b37af 100644 --- a/configs/mx51evk_defconfig +++ b/configs/mx51evk_defconfig @@ -21,7 +21,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MII=y CONFIG_SPI=y CONFIG_MXC_SPI=y diff --git a/configs/mx53ard_defconfig b/configs/mx53ard_defconfig index ea1d3f6..cf85c42 100644 --- a/configs/mx53ard_defconfig +++ b/configs/mx53ard_defconfig @@ -15,7 +15,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_NAND=y CONFIG_NAND_MXC=y CONFIG_MII=y diff --git a/configs/mx53cx9020_defconfig b/configs/mx53cx9020_defconfig index bf48966..e57d0df 100644 --- a/configs/mx53cx9020_defconfig +++ b/configs/mx53cx9020_defconfig @@ -26,7 +26,7 @@ CONFIG_FPGA_ALTERA=y CONFIG_FPGA_CYCLON2=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y diff --git a/configs/mx53evk_defconfig b/configs/mx53evk_defconfig index 67582b5..ab9e485 100644 --- a/configs/mx53evk_defconfig +++ b/configs/mx53evk_defconfig @@ -14,6 +14,6 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MII=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx53loco_defconfig b/configs/mx53loco_defconfig index a7adeff..2c76b83 100644 --- a/configs/mx53loco_defconfig +++ b/configs/mx53loco_defconfig @@ -23,7 +23,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y CONFIG_DWC_AHSATA=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MII=y CONFIG_USB=y CONFIG_USB_EHCI_MX5=y diff --git a/configs/mx53ppd_defconfig b/configs/mx53ppd_defconfig index 19ebab7..a88af15 100644 --- a/configs/mx53ppd_defconfig +++ b/configs/mx53ppd_defconfig @@ -39,7 +39,7 @@ CONFIG_BOOTCOUNT_EXT=y CONFIG_BOOTCOUNT_BOOTLIMIT=10 CONFIG_SYS_BOOTCOUNT_EXT_DEVPART="0:5" CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX5=y diff --git a/configs/mx53smd_defconfig b/configs/mx53smd_defconfig index 8c3e40f..2454956 100644 --- a/configs/mx53smd_defconfig +++ b/configs/mx53smd_defconfig @@ -14,6 +14,6 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MII=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index f13e688..cc2ed9a 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -33,7 +33,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_DWC_AHSATA=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_DM_THERMAL=y diff --git a/configs/mx6dlarm2_defconfig b/configs/mx6dlarm2_defconfig index 35f8183..866e0b5 100644 --- a/configs/mx6dlarm2_defconfig +++ b/configs/mx6dlarm2_defconfig @@ -26,7 +26,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MII=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/mx6dlarm2_lpddr2_defconfig b/configs/mx6dlarm2_lpddr2_defconfig index 0e68df0..98ae70e 100644 --- a/configs/mx6dlarm2_lpddr2_defconfig +++ b/configs/mx6dlarm2_lpddr2_defconfig @@ -26,7 +26,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MII=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/mx6qarm2_defconfig b/configs/mx6qarm2_defconfig index 304d1dc..8056e53 100644 --- a/configs/mx6qarm2_defconfig +++ b/configs/mx6qarm2_defconfig @@ -26,7 +26,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MII=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/mx6qarm2_lpddr2_defconfig b/configs/mx6qarm2_lpddr2_defconfig index bbdc771..27c215f 100644 --- a/configs/mx6qarm2_lpddr2_defconfig +++ b/configs/mx6qarm2_lpddr2_defconfig @@ -26,7 +26,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MII=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index 03bddda..0d402f2 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -34,7 +34,7 @@ CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=25000000 diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index d0f302e..ae3e4b5 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -60,7 +60,7 @@ CONFIG_DFU_MMC=y CONFIG_DFU_SF=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index 0fda6fc..3ce149a 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -75,7 +75,7 @@ CONFIG_FASTBOOT_FLASH_MMC_DEV=2 CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/mx6slevk_defconfig b/configs/mx6slevk_defconfig index 50cc225..643cad4 100644 --- a/configs/mx6slevk_defconfig +++ b/configs/mx6slevk_defconfig @@ -34,7 +34,7 @@ CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/configs/mx6slevk_spinor_defconfig b/configs/mx6slevk_spinor_defconfig index d2be52f..3dada99 100644 --- a/configs/mx6slevk_spinor_defconfig +++ b/configs/mx6slevk_spinor_defconfig @@ -34,7 +34,7 @@ CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/configs/mx6slevk_spl_defconfig b/configs/mx6slevk_spl_defconfig index 4841dc6..63a7a74 100644 --- a/configs/mx6slevk_spl_defconfig +++ b/configs/mx6slevk_spl_defconfig @@ -43,7 +43,7 @@ CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/configs/mx6sllevk_defconfig b/configs/mx6sllevk_defconfig index 4dcac21..81f5fa5 100644 --- a/configs/mx6sllevk_defconfig +++ b/configs/mx6sllevk_defconfig @@ -30,7 +30,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_DM_PMIC=y diff --git a/configs/mx6sllevk_plugin_defconfig b/configs/mx6sllevk_plugin_defconfig index 090ab06..565dc89 100644 --- a/configs/mx6sllevk_plugin_defconfig +++ b/configs/mx6sllevk_plugin_defconfig @@ -31,7 +31,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_DM_PMIC=y diff --git a/configs/mx6sxsabreauto_defconfig b/configs/mx6sxsabreauto_defconfig index f7ae29e..11c2a82 100644 --- a/configs/mx6sxsabreauto_defconfig +++ b/configs/mx6sxsabreauto_defconfig @@ -34,7 +34,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_PCA953X=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_DM_SPI_FLASH=y diff --git a/configs/mx6sxsabresd_defconfig b/configs/mx6sxsabresd_defconfig index 4e516c5..135961a 100644 --- a/configs/mx6sxsabresd_defconfig +++ b/configs/mx6sxsabresd_defconfig @@ -38,7 +38,7 @@ CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=1 diff --git a/configs/mx6sxsabresd_spl_defconfig b/configs/mx6sxsabresd_spl_defconfig index 159f079..21c9366 100644 --- a/configs/mx6sxsabresd_spl_defconfig +++ b/configs/mx6sxsabresd_spl_defconfig @@ -47,7 +47,7 @@ CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_PCI=y diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index 2fc7119..1d777b5 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -44,7 +44,7 @@ CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index 8816f6a..1014bd8 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -44,7 +44,7 @@ CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/mx6ull_14x14_evk_defconfig b/configs/mx6ull_14x14_evk_defconfig index 7902465..f4681a6 100644 --- a/configs/mx6ull_14x14_evk_defconfig +++ b/configs/mx6ull_14x14_evk_defconfig @@ -30,7 +30,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_74X164=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/mx6ull_14x14_evk_plugin_defconfig b/configs/mx6ull_14x14_evk_plugin_defconfig index c52de80..6fb30ce 100644 --- a/configs/mx6ull_14x14_evk_plugin_defconfig +++ b/configs/mx6ull_14x14_evk_plugin_defconfig @@ -31,7 +31,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_74X164=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/mx7dsabresd_defconfig b/configs/mx7dsabresd_defconfig index b2ca4f9..45901f0 100644 --- a/configs/mx7dsabresd_defconfig +++ b/configs/mx7dsabresd_defconfig @@ -48,7 +48,7 @@ CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS200_SUPPORT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_PHYLIB=y diff --git a/configs/mx7dsabresd_qspi_defconfig b/configs/mx7dsabresd_qspi_defconfig index 27a8387..2f56698 100644 --- a/configs/mx7dsabresd_qspi_defconfig +++ b/configs/mx7dsabresd_qspi_defconfig @@ -48,7 +48,7 @@ CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_MMC_IO_VOLTAGE=y CONFIG_MMC_UHS_SUPPORT=y CONFIG_MMC_HS200_SUPPORT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/mx7ulp_evk_defconfig b/configs/mx7ulp_evk_defconfig index d125ccc..d4eba65 100644 --- a/configs/mx7ulp_evk_defconfig +++ b/configs/mx7ulp_evk_defconfig @@ -22,7 +22,7 @@ CONFIG_IMX_RGPIO2P=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7ULP=y CONFIG_DM_REGULATOR=y diff --git a/configs/mx7ulp_evk_plugin_defconfig b/configs/mx7ulp_evk_plugin_defconfig index fcead94..ae8d4b4 100644 --- a/configs/mx7ulp_evk_plugin_defconfig +++ b/configs/mx7ulp_evk_plugin_defconfig @@ -21,7 +21,7 @@ CONFIG_IMX_RGPIO2P=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7ULP=y CONFIG_DM_REGULATOR=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index dff3770..015675b 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -36,7 +36,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=25000000 diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index 95fdb4a..ee353f2 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -36,7 +36,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=25000000 diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index 05f0a21..ebd9bf8 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -38,7 +38,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DWC_AHSATA=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=25000000 diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index 5ac4a33..d324282 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -38,7 +38,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DWC_AHSATA=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=25000000 diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 69cd12d..b26bce4 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -36,7 +36,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=25000000 diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index 2e3d62f..a2fb07f 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -36,7 +36,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_USB_FUNCTION_FASTBOOT=y CONFIG_FASTBOOT_BUF_ADDR=0x12000000 -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=25000000 diff --git a/configs/novena_defconfig b/configs/novena_defconfig index 340e1cd..42272ef 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -42,7 +42,7 @@ CONFIG_CMD_EXT4_WRITE=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_ENV_IS_IN_MMC=y CONFIG_DWC_AHSATA=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/configs/opos6uldev_defconfig b/configs/opos6uldev_defconfig index badc4b0..2d6a664 100644 --- a/configs/opos6uldev_defconfig +++ b/configs/opos6uldev_defconfig @@ -69,7 +69,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_MXC=y CONFIG_PWRSEQ=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y diff --git a/configs/ot1200_defconfig b/configs/ot1200_defconfig index f0fe375..02c6d71 100644 --- a/configs/ot1200_defconfig +++ b/configs/ot1200_defconfig @@ -31,7 +31,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_CMD_PCA953X=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=2 CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/ot1200_spl_defconfig b/configs/ot1200_spl_defconfig index 9bc22fe..dd74591 100644 --- a/configs/ot1200_spl_defconfig +++ b/configs/ot1200_spl_defconfig @@ -41,7 +41,7 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y CONFIG_DWC_AHSATA=y CONFIG_CMD_PCA953X=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=2 CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/pcm052_defconfig b/configs/pcm052_defconfig index 171341b..b7e3d04 100644 --- a/configs/pcm052_defconfig +++ b/configs/pcm052_defconfig @@ -39,7 +39,7 @@ CONFIG_SYS_EEPROM_SIZE=32768 CONFIG_SYS_EEPROM_PAGE_WRITE_BITS=6 CONFIG_SYS_I2C_EEPROM_ADDR_LEN=2 CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD=y CONFIG_NAND_VF610_NFC=y CONFIG_NAND_VF610_NFC_DT=y diff --git a/configs/pcm058_defconfig b/configs/pcm058_defconfig index c461459..f7e5faa 100644 --- a/configs/pcm058_defconfig +++ b/configs/pcm058_defconfig @@ -43,7 +43,7 @@ CONFIG_CMD_UBI=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DM=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD=y CONFIG_NAND=y CONFIG_NAND_MXS=y diff --git a/configs/pfla02_defconfig b/configs/pfla02_defconfig index aeab883..f710d0d 100644 --- a/configs/pfla02_defconfig +++ b/configs/pfla02_defconfig @@ -42,7 +42,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:-(nand);spi2.0:1024k(bootloader),64k CONFIG_CMD_UBI=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_DM=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD=y CONFIG_NAND=y CONFIG_NAND_MXS=y diff --git a/configs/phycore_pcl063_defconfig b/configs/phycore_pcl063_defconfig index a051a8d..cf43b43 100644 --- a/configs/phycore_pcl063_defconfig +++ b/configs/phycore_pcl063_defconfig @@ -35,7 +35,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-phycore-segin" CONFIG_DM_I2C_GPIO=y CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD=y CONFIG_NAND=y CONFIG_NAND_MXS=y diff --git a/configs/pico-hobbit-imx6ul_defconfig b/configs/pico-hobbit-imx6ul_defconfig index bb6a9e4..55f25d5 100644 --- a/configs/pico-hobbit-imx6ul_defconfig +++ b/configs/pico-hobbit-imx6ul_defconfig @@ -46,7 +46,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y diff --git a/configs/pico-hobbit-imx7d_defconfig b/configs/pico-hobbit-imx7d_defconfig index 9545d6b..bc34e99 100644 --- a/configs/pico-hobbit-imx7d_defconfig +++ b/configs/pico-hobbit-imx7d_defconfig @@ -52,7 +52,7 @@ CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_PINCTRL=y diff --git a/configs/pico-imx6ul_defconfig b/configs/pico-imx6ul_defconfig index 3284680..0345263 100644 --- a/configs/pico-imx6ul_defconfig +++ b/configs/pico-imx6ul_defconfig @@ -48,7 +48,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y diff --git a/configs/pico-imx7d_defconfig b/configs/pico-imx7d_defconfig index 92ab9c5..f23bbf7 100644 --- a/configs/pico-imx7d_defconfig +++ b/configs/pico-imx7d_defconfig @@ -52,7 +52,7 @@ CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_PINCTRL=y diff --git a/configs/pico-pi-imx6ul_defconfig b/configs/pico-pi-imx6ul_defconfig index d52c09e..2e23c7b 100644 --- a/configs/pico-pi-imx6ul_defconfig +++ b/configs/pico-pi-imx6ul_defconfig @@ -46,7 +46,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y diff --git a/configs/pico-pi-imx7d_defconfig b/configs/pico-pi-imx7d_defconfig index 042affe..14c0817 100644 --- a/configs/pico-pi-imx7d_defconfig +++ b/configs/pico-pi-imx7d_defconfig @@ -52,7 +52,7 @@ CONFIG_FASTBOOT_CMD_OEM_FORMAT=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_PINCTRL=y diff --git a/configs/platinum_picon_defconfig b/configs/platinum_picon_defconfig index 786f6a4..130d8ac 100644 --- a/configs/platinum_picon_defconfig +++ b/configs/platinum_picon_defconfig @@ -47,7 +47,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:14M(spl),2M(uboot),512k(env1),512k(env2),495M(ubi0),14M(res0),2M(res1),512k(res2),512k(res3),-(ubi1)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/platinum_titanium_defconfig b/configs/platinum_titanium_defconfig index c45abb0..71914ad 100644 --- a/configs/platinum_titanium_defconfig +++ b/configs/platinum_titanium_defconfig @@ -47,7 +47,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:14M(spl),2M(uboot),512k(env1),512k(env2),-(ubi)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/riotboard_defconfig b/configs/riotboard_defconfig index 6b0d7e5..0b6304e 100644 --- a/configs/riotboard_defconfig +++ b/configs/riotboard_defconfig @@ -22,7 +22,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/configs/riotboard_spl_defconfig b/configs/riotboard_spl_defconfig index 1b61232..427bd9d 100644 --- a/configs/riotboard_spl_defconfig +++ b/configs/riotboard_spl_defconfig @@ -32,7 +32,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=20000000 diff --git a/configs/s32v234evb_defconfig b/configs/s32v234evb_defconfig index deb8c04..9eaa894 100644 --- a/configs/s32v234evb_defconfig +++ b/configs/s32v234evb_defconfig @@ -11,7 +11,7 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_MEMTEST=y CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_DM_SERIAL=y CONFIG_FSL_LINFLEXUART=y CONFIG_OF_LIBFDT=y diff --git a/configs/secomx6quq7_defconfig b/configs/secomx6quq7_defconfig index 8526f05..40ca954 100644 --- a/configs/secomx6quq7_defconfig +++ b/configs/secomx6quq7_defconfig @@ -26,7 +26,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/configs/sksimx6_defconfig b/configs/sksimx6_defconfig index 164614d..748b13e 100644 --- a/configs/sksimx6_defconfig +++ b/configs/sksimx6_defconfig @@ -33,7 +33,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index ba42603..17c90a7 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -48,7 +48,7 @@ CONFIG_DM_I2C=y CONFIG_SYS_I2C_MXC=y CONFIG_DM_KEYBOARD=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_PCI=y diff --git a/configs/titanium_defconfig b/configs/titanium_defconfig index 1e19240..2816f66 100644 --- a/configs/titanium_defconfig +++ b/configs/titanium_defconfig @@ -34,7 +34,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=gpmi-nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=gpmi-nand:16M(uboot),512k(env1),512k(env2),-(ubi)" CONFIG_CMD_UBI=y CONFIG_ENV_IS_IN_NAND=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_NAND=y CONFIG_NAND_MXS=y CONFIG_PHYLIB=y diff --git a/configs/tqma6dl_mba6_mmc_defconfig b/configs/tqma6dl_mba6_mmc_defconfig index bc54005..887f938 100644 --- a/configs/tqma6dl_mba6_mmc_defconfig +++ b/configs/tqma6dl_mba6_mmc_defconfig @@ -32,7 +32,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=50000000 diff --git a/configs/tqma6dl_mba6_spi_defconfig b/configs/tqma6dl_mba6_spi_defconfig index 58d08bf..6abefa3 100644 --- a/configs/tqma6dl_mba6_spi_defconfig +++ b/configs/tqma6dl_mba6_spi_defconfig @@ -33,7 +33,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=50000000 diff --git a/configs/tqma6q_mba6_mmc_defconfig b/configs/tqma6q_mba6_mmc_defconfig index b57cb81..67aae05 100644 --- a/configs/tqma6q_mba6_mmc_defconfig +++ b/configs/tqma6q_mba6_mmc_defconfig @@ -31,7 +31,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=50000000 diff --git a/configs/tqma6q_mba6_spi_defconfig b/configs/tqma6q_mba6_spi_defconfig index c713fac..6ecba56 100644 --- a/configs/tqma6q_mba6_spi_defconfig +++ b/configs/tqma6q_mba6_spi_defconfig @@ -32,7 +32,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=50000000 diff --git a/configs/tqma6s_mba6_mmc_defconfig b/configs/tqma6s_mba6_mmc_defconfig index d9d3ce9..d291d0f 100644 --- a/configs/tqma6s_mba6_mmc_defconfig +++ b/configs/tqma6s_mba6_mmc_defconfig @@ -32,7 +32,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=50000000 diff --git a/configs/tqma6s_mba6_spi_defconfig b/configs/tqma6s_mba6_spi_defconfig index f793658..b5acd0e 100644 --- a/configs/tqma6s_mba6_spi_defconfig +++ b/configs/tqma6s_mba6_spi_defconfig @@ -33,7 +33,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=50000000 diff --git a/configs/tqma6s_wru4_mmc_defconfig b/configs/tqma6s_wru4_mmc_defconfig index 57f2221..f2a8376 100644 --- a/configs/tqma6s_wru4_mmc_defconfig +++ b/configs/tqma6s_wru4_mmc_defconfig @@ -59,7 +59,7 @@ CONFIG_LED_STATUS_BIT5=5 CONFIG_LED_STATUS_STATE5=2 CONFIG_LED_STATUS_CMD=y CONFIG_PCA9551_LED=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_USB=y diff --git a/configs/ts4800_defconfig b/configs/ts4800_defconfig index 68404e3..208366e 100644 --- a/configs/ts4800_defconfig +++ b/configs/ts4800_defconfig @@ -15,7 +15,7 @@ CONFIG_CMD_MII=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_SPI=y diff --git a/configs/udoo_defconfig b/configs/udoo_defconfig index 317592b..259ffee 100644 --- a/configs/udoo_defconfig +++ b/configs/udoo_defconfig @@ -29,7 +29,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DM=y CONFIG_DWC_AHSATA=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y diff --git a/configs/udoo_neo_defconfig b/configs/udoo_neo_defconfig index e8df11d..4f00e48 100644 --- a/configs/udoo_neo_defconfig +++ b/configs/udoo_neo_defconfig @@ -28,7 +28,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ8XXX=y diff --git a/configs/usbarmory_defconfig b/configs/usbarmory_defconfig index 3c1eaf6..77a3a23 100644 --- a/configs/usbarmory_defconfig +++ b/configs/usbarmory_defconfig @@ -13,7 +13,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_ENV_IS_IN_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_USB=y CONFIG_USB_EHCI_MX5=y CONFIG_OF_LIBFDT=y diff --git a/configs/variscite_dart6ul_defconfig b/configs/variscite_dart6ul_defconfig index f55c386..55f4ff5 100644 --- a/configs/variscite_dart6ul_defconfig +++ b/configs/variscite_dart6ul_defconfig @@ -30,7 +30,7 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6ull-dart-6ul" CONFIG_DM_I2C_GPIO=y CONFIG_SYS_I2C_MXC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_FEC_MXC=y diff --git a/configs/vf610twr_defconfig b/configs/vf610twr_defconfig index dc67ddc..3ad60e6 100644 --- a/configs/vf610twr_defconfig +++ b/configs/vf610twr_defconfig @@ -32,7 +32,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_VYBRID_GPIO=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_NAND_VF610_NFC=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_PHYLIB=y diff --git a/configs/vf610twr_nand_defconfig b/configs/vf610twr_nand_defconfig index 7fcb630..d7598c4 100644 --- a/configs/vf610twr_nand_defconfig +++ b/configs/vf610twr_nand_defconfig @@ -32,7 +32,7 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_VYBRID_GPIO=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_NAND_VF610_NFC=y CONFIG_SYS_NAND_BUSWIDTH_16BIT=y CONFIG_PHYLIB=y diff --git a/configs/vining_2000_defconfig b/configs/vining_2000_defconfig index 073ff48..648ccf2 100644 --- a/configs/vining_2000_defconfig +++ b/configs/vining_2000_defconfig @@ -34,7 +34,7 @@ CONFIG_EFI_PARTITION=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_SUPPORT_EMMC_RPMB=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_PCI=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index ee81e1a..3025c0d 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -47,7 +47,7 @@ CONFIG_SYS_I2C_MXC_I2C1=y CONFIG_SYS_I2C_MXC_I2C2=y CONFIG_SYS_I2C_MXC_I2C3=y CONFIG_DM_MMC=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_PINCTRL=y diff --git a/configs/warp7_bl33_defconfig b/configs/warp7_bl33_defconfig index a79f670..8a4e294 100644 --- a/configs/warp7_bl33_defconfig +++ b/configs/warp7_bl33_defconfig @@ -30,7 +30,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7=y CONFIG_DM_PMIC=y diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index 5b35113..11f16cf 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -39,7 +39,7 @@ CONFIG_DM_GPIO=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7=y CONFIG_DM_PMIC=y diff --git a/configs/warp_defconfig b/configs/warp_defconfig index a37d769..0f911a9 100644 --- a/configs/warp_defconfig +++ b/configs/warp_defconfig @@ -30,7 +30,7 @@ CONFIG_ENV_IS_IN_MMC=y # CONFIG_NET is not set CONFIG_DFU_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/woodburn_defconfig b/configs/woodburn_defconfig index ebc12ab..73b76aa 100644 --- a/configs/woodburn_defconfig +++ b/configs/woodburn_defconfig @@ -28,7 +28,7 @@ CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set CONFIG_ENV_IS_IN_FLASH=y CONFIG_MXC_GPIO=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/woodburn_sd_defconfig b/configs/woodburn_sd_defconfig index 7182aff..72e6ab4 100644 --- a/configs/woodburn_sd_defconfig +++ b/configs/woodburn_sd_defconfig @@ -40,7 +40,7 @@ CONFIG_EFI_PARTITION=y # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_ENV_IS_IN_FLASH=y CONFIG_MXC_GPIO=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_MTD_NOR_FLASH=y CONFIG_FLASH_CFI_DRIVER=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y diff --git a/configs/xpress_defconfig b/configs/xpress_defconfig index 709a7ef..64fed1d 100644 --- a/configs/xpress_defconfig +++ b/configs/xpress_defconfig @@ -26,7 +26,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_USB=y diff --git a/configs/xpress_spl_defconfig b/configs/xpress_spl_defconfig index e79a038..c203353 100644 --- a/configs/xpress_spl_defconfig +++ b/configs/xpress_spl_defconfig @@ -37,7 +37,7 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_PHYLIB=y CONFIG_MII=y CONFIG_USB=y diff --git a/configs/zc5202_defconfig b/configs/zc5202_defconfig index ae3a6b3..1aee743 100644 --- a/configs/zc5202_defconfig +++ b/configs/zc5202_defconfig @@ -35,7 +35,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=3 CONFIG_SF_DEFAULT_MODE=0 diff --git a/configs/zc5601_defconfig b/configs/zc5601_defconfig index 65a1915..f361ad9 100644 --- a/configs/zc5601_defconfig +++ b/configs/zc5601_defconfig @@ -34,7 +34,7 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_ESDHC=y +CONFIG_FSL_ESDHC_IMX=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=3 CONFIG_SF_DEFAULT_MODE=0
Dropped i.MX code which couldn't be reused.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com Tested-by: Steffen Dirkwinkel s.dirkwinkel@beckhoff.com Acked-by: Peng Fan peng.fan@nxp.com --- Changes for v2: - Added this patch. Changes for v3: - Rebased. Changes for v4: - Rebased. - Added Tested-by/Acked-by. Changes for v5: - Dropped MCF5441x code. --- drivers/mmc/fsl_esdhc.c | 626 ++---------------------------------------------- include/fsl_esdhc.h | 57 ----- 2 files changed, 16 insertions(+), 667 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 672691f..65fc849 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -16,14 +16,11 @@ #include <hwconfig.h> #include <mmc.h> #include <part.h> -#include <power/regulator.h> #include <malloc.h> #include <fsl_esdhc.h> #include <fdt_support.h> #include <asm/io.h> #include <dm.h> -#include <asm-generic/gpio.h> -#include <dm/pinctrl.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -33,8 +30,6 @@ DECLARE_GLOBAL_DATA_PTR; IRQSTATEN_CIE | IRQSTATEN_DTOE | IRQSTATEN_DCE | \ IRQSTATEN_DEBE | IRQSTATEN_BRR | IRQSTATEN_BWR | \ IRQSTATEN_DINT) -#define MAX_TUNING_LOOP 40 - struct fsl_esdhc { uint dsaddr; /* SDMA system address register */ uint blkattr; /* Block attributes register */ @@ -54,37 +49,20 @@ struct fsl_esdhc { uint autoc12err; /* Auto CMD error status register */ uint hostcapblt; /* Host controller capabilities register */ uint wml; /* Watermark level register */ - uint mixctrl; /* For USDHC */ - char reserved1[4]; /* reserved */ + char reserved1[8]; /* reserved */ uint fevt; /* Force event register */ uint admaes; /* ADMA error status register */ uint adsaddr; /* ADMA system address register */ - char reserved2[4]; - uint dllctrl; - uint dllstat; - uint clktunectrlstatus; - char reserved3[4]; - uint strobe_dllctrl; - uint strobe_dllstat; - char reserved4[72]; - uint vendorspec; - uint mmcboot; - uint vendorspec2; - uint tuning_ctrl; /* on i.MX6/7/8 */ - char reserved5[44]; + char reserved2[160]; uint hostver; /* Host controller version register */ - char reserved6[4]; /* reserved */ + char reserved3[4]; /* reserved */ uint dmaerraddr; /* DMA error address register */ - char reserved7[4]; /* reserved */ + char reserved4[4]; /* reserved */ uint dmaerrattr; /* DMA error attribute register */ - char reserved8[4]; /* reserved */ + char reserved5[4]; /* reserved */ uint hostcapblt2; /* Host controller capabilities register 2 */ - char reserved9[8]; /* reserved */ - uint tcr; /* Tuning control register */ - char reserved10[28]; /* reserved */ - uint sddirctl; /* SD direction control register */ - char reserved11[712];/* reserved */ - uint scr; /* eSDHC control register */ + char reserved6[756]; /* reserved */ + uint esdhcctl; /* eSDHC control register */ };
struct fsl_esdhc_plat { @@ -92,11 +70,6 @@ struct fsl_esdhc_plat { struct mmc mmc; };
-struct esdhc_soc_data { - u32 flags; - u32 caps; -}; - /** * struct fsl_esdhc_priv * @@ -109,13 +82,6 @@ struct esdhc_soc_data { * @dev: pointer for the device * @non_removable: 0: removable; 1: non-removable * @wp_enable: 1: enable checking wp; 0: no check - * @vs18_enable: 1: use 1.8V voltage; 0: use 3.3V - * @flags: ESDHC_FLAG_xx in include/fsl_esdhc.h - * @caps: controller capabilities - * @tuning_step: tuning step setting in tuning_ctrl register - * @start_tuning_tap: the start point for tuning in tuning_ctrl register - * @strobe_dll_delay_target: settings in strobe_dllctrl - * @signal_voltage: indicating the current voltage * @cd_gpio: gpio for card detection * @wp_gpio: gpio for write protection */ @@ -124,7 +90,6 @@ struct fsl_esdhc_priv { unsigned int sdhc_clk; struct clk per_clk; unsigned int clock; - unsigned int mode; unsigned int bus_width; #if !CONFIG_IS_ENABLED(BLK) struct mmc *mmc; @@ -132,21 +97,6 @@ struct fsl_esdhc_priv { struct udevice *dev; int non_removable; int wp_enable; - int vs18_enable; - u32 flags; - u32 caps; - u32 tuning_step; - u32 tuning_start_tap; - u32 strobe_dll_delay_target; - u32 signal_voltage; -#if IS_ENABLED(CONFIG_DM_REGULATOR) - struct udevice *vqmmc_dev; - struct udevice *vmmc_dev; -#endif -#ifdef CONFIG_DM_GPIO - struct gpio_desc cd_gpio; - struct gpio_desc wp_gpio; -#endif };
/* Return the XFERTYP flags for a given command and data packet */ @@ -258,8 +208,7 @@ static int esdhc_setup_data(struct fsl_esdhc_priv *priv, struct mmc *mmc, { int timeout; struct fsl_esdhc *regs = priv->esdhc_regs; -#if defined(CONFIG_FSL_LAYERSCAPE) || defined(CONFIG_S32V234) || \ - defined(CONFIG_IMX8) || defined(CONFIG_IMX8M) +#if defined(CONFIG_FSL_LAYERSCAPE) dma_addr_t addr; #endif uint wml_value; @@ -272,8 +221,7 @@ static int esdhc_setup_data(struct fsl_esdhc_priv *priv, struct mmc *mmc,
esdhc_clrsetbits32(®s->wml, WML_RD_WML_MASK, wml_value); #ifndef CONFIG_SYS_FSL_ESDHC_USE_PIO -#if defined(CONFIG_FSL_LAYERSCAPE) || defined(CONFIG_S32V234) || \ - defined(CONFIG_IMX8) || defined(CONFIG_IMX8M) +#if defined(CONFIG_FSL_LAYERSCAPE) addr = virt_to_phys((void *)(data->dest)); if (upper_32_bits(addr)) printf("Error found for upper 32 bits\n"); @@ -297,20 +245,12 @@ static int esdhc_setup_data(struct fsl_esdhc_priv *priv, struct mmc *mmc, printf("\nThe SD card is locked. Can not write to a locked card.\n\n"); return -ETIMEDOUT; } - } else { -#ifdef CONFIG_DM_GPIO - if (dm_gpio_is_valid(&priv->wp_gpio) && dm_gpio_get_value(&priv->wp_gpio)) { - printf("\nThe SD card is locked. Can not write to a locked card.\n\n"); - return -ETIMEDOUT; - } -#endif }
esdhc_clrsetbits32(®s->wml, WML_WR_WML_MASK, wml_value << 16); #ifndef CONFIG_SYS_FSL_ESDHC_USE_PIO -#if defined(CONFIG_FSL_LAYERSCAPE) || defined(CONFIG_S32V234) || \ - defined(CONFIG_IMX8) || defined(CONFIG_IMX8M) +#if defined(CONFIG_FSL_LAYERSCAPE) addr = virt_to_phys((void *)(data->src)); if (upper_32_bits(addr)) printf("Error found for upper 32 bits\n"); @@ -375,8 +315,7 @@ static void check_and_invalidate_dcache_range unsigned end = 0; unsigned size = roundup(ARCH_DMA_MINALIGN, data->blocks*data->blocksize); -#if defined(CONFIG_FSL_LAYERSCAPE) || defined(CONFIG_S32V234) || \ - defined(CONFIG_IMX8) || defined(CONFIG_IMX8M) +#if defined(CONFIG_FSL_LAYERSCAPE) dma_addr_t addr;
addr = virt_to_phys((void *)(data->dest)); @@ -391,25 +330,6 @@ static void check_and_invalidate_dcache_range invalidate_dcache_range(start, end); }
-#ifdef CONFIG_MCF5441x -/* - * Swaps 32-bit words to little-endian byte order. - */ -static inline void sd_swap_dma_buff(struct mmc_data *data) -{ - int i, size = data->blocksize >> 2; - u32 *buffer = (u32 *)data->dest; - u32 sw; - - while (data->blocks--) { - for (i = 0; i < size; i++) { - sw = __sw32(*buffer); - *buffer++ = sw; - } - } -} -#endif - /* * Sends a command out on the bus. Takes the mmc pointer, * a command pointer, and an optional data pointer. @@ -466,14 +386,7 @@ static int esdhc_send_cmd_common(struct fsl_esdhc_priv *priv, struct mmc *mmc,
/* Send the command */ esdhc_write32(®s->cmdarg, cmd->cmdarg); -#if defined(CONFIG_FSL_USDHC) - esdhc_write32(®s->mixctrl, - (esdhc_read32(®s->mixctrl) & 0xFFFFFF80) | (xfertyp & 0x7F) - | (mmc->ddr_mode ? XFERTYP_DDREN : 0)); - esdhc_write32(®s->xfertyp, xfertyp & 0xFFFF0000); -#else esdhc_write32(®s->xfertyp, xfertyp); -#endif
if ((cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK) || (cmd->cmdidx == MMC_CMD_SEND_TUNING_BLOCK_HS200)) @@ -500,15 +413,6 @@ static int esdhc_send_cmd_common(struct fsl_esdhc_priv *priv, struct mmc *mmc, goto out; }
- /* Switch voltage to 1.8V if CMD11 succeeded */ - if (cmd->cmdidx == SD_CMD_SWITCH_UHS18V) { - esdhc_setbits32(®s->vendorspec, ESDHC_VENDORSPEC_VSELECT); - - printf("Run CMD11 1.8V switch\n"); - /* Sleep for 5 ms - max time for card to switch to 1.8V */ - udelay(5000); - } - /* Workaround for ESDHC errata ENGcm03648 */ if (!data && (cmd->resp_type & MMC_RSP_BUSY)) { int timeout = 6000; @@ -574,9 +478,6 @@ static int esdhc_send_cmd_common(struct fsl_esdhc_priv *priv, struct mmc *mmc, */ if (data->flags & MMC_DATA_READ) { check_and_invalidate_dcache_range(cmd, data); -#ifdef CONFIG_MCF5441x - sd_swap_dma_buff(data); -#endif } #endif } @@ -596,10 +497,6 @@ out: while ((esdhc_read32(®s->sysctl) & SYSCTL_RSTD)) ; } - - /* If this was CMD11, then notify that power cycle is needed */ - if (cmd->cmdidx == SD_CMD_SWITCH_UHS18V) - printf("CMD11 to switch to 1.8V mode failed, card requires power cycle.\n"); }
esdhc_write32(®s->irqstat, -1); @@ -611,16 +508,7 @@ static void set_sysctl(struct fsl_esdhc_priv *priv, struct mmc *mmc, uint clock) { struct fsl_esdhc *regs = priv->esdhc_regs; int div = 1; -#ifdef ARCH_MXC -#ifdef CONFIG_MX53 - /* For i.MX53 eSDHCv3, SYSCTL.SDCLKFS may not be set to 0. */ - int pre_div = (regs == (struct fsl_esdhc *)MMC_SDHC3_BASE_ADDR) ? 2 : 1; -#else - int pre_div = 1; -#endif -#else int pre_div = 2; -#endif int ddr_pre_div = mmc->ddr_mode ? 2 : 1; int sdhc_clk = priv->sdhc_clk; uint clk; @@ -639,21 +527,13 @@ static void set_sysctl(struct fsl_esdhc_priv *priv, struct mmc *mmc, uint clock)
clk = (pre_div << 8) | (div << 4);
-#ifdef CONFIG_FSL_USDHC - esdhc_clrbits32(®s->vendorspec, VENDORSPEC_CKEN); -#else esdhc_clrbits32(®s->sysctl, SYSCTL_CKEN); -#endif
esdhc_clrsetbits32(®s->sysctl, SYSCTL_CLOCK_MASK, clk);
udelay(10000);
-#ifdef CONFIG_FSL_USDHC - esdhc_setbits32(®s->vendorspec, VENDORSPEC_PEREN | VENDORSPEC_CKEN); -#else esdhc_setbits32(®s->sysctl, SYSCTL_PEREN | SYSCTL_CKEN); -#endif
priv->clock = clock; } @@ -687,317 +567,20 @@ static void esdhc_clock_control(struct fsl_esdhc_priv *priv, bool enable) } #endif
-#ifdef MMC_SUPPORTS_TUNING -static int esdhc_change_pinstate(struct udevice *dev) -{ - struct fsl_esdhc_priv *priv = dev_get_priv(dev); - int ret; - - switch (priv->mode) { - case UHS_SDR50: - case UHS_DDR50: - ret = pinctrl_select_state(dev, "state_100mhz"); - break; - case UHS_SDR104: - case MMC_HS_200: - case MMC_HS_400: - ret = pinctrl_select_state(dev, "state_200mhz"); - break; - default: - ret = pinctrl_select_state(dev, "default"); - break; - } - - if (ret) - printf("%s %d error\n", __func__, priv->mode); - - return ret; -} - -static void esdhc_reset_tuning(struct mmc *mmc) -{ - struct fsl_esdhc_priv *priv = dev_get_priv(mmc->dev); - struct fsl_esdhc *regs = priv->esdhc_regs; - - if (priv->flags & ESDHC_FLAG_USDHC) { - if (priv->flags & ESDHC_FLAG_STD_TUNING) { - esdhc_clrbits32(®s->autoc12err, - MIX_CTRL_SMPCLK_SEL | - MIX_CTRL_EXE_TUNE); - } - } -} - -static void esdhc_set_strobe_dll(struct mmc *mmc) -{ - struct fsl_esdhc_priv *priv = dev_get_priv(mmc->dev); - struct fsl_esdhc *regs = priv->esdhc_regs; - u32 val; - - if (priv->clock > ESDHC_STROBE_DLL_CLK_FREQ) { - writel(ESDHC_STROBE_DLL_CTRL_RESET, ®s->strobe_dllctrl); - - /* - * enable strobe dll ctrl and adjust the delay target - * for the uSDHC loopback read clock - */ - val = ESDHC_STROBE_DLL_CTRL_ENABLE | - (priv->strobe_dll_delay_target << - ESDHC_STROBE_DLL_CTRL_SLV_DLY_TARGET_SHIFT); - writel(val, ®s->strobe_dllctrl); - /* wait 1us to make sure strobe dll status register stable */ - mdelay(1); - val = readl(®s->strobe_dllstat); - if (!(val & ESDHC_STROBE_DLL_STS_REF_LOCK)) - pr_warn("HS400 strobe DLL status REF not lock!\n"); - if (!(val & ESDHC_STROBE_DLL_STS_SLV_LOCK)) - pr_warn("HS400 strobe DLL status SLV not lock!\n"); - } -} - -static int esdhc_set_timing(struct mmc *mmc) -{ - struct fsl_esdhc_priv *priv = dev_get_priv(mmc->dev); - struct fsl_esdhc *regs = priv->esdhc_regs; - u32 mixctrl; - - mixctrl = readl(®s->mixctrl); - mixctrl &= ~(MIX_CTRL_DDREN | MIX_CTRL_HS400_EN); - - switch (mmc->selected_mode) { - case MMC_LEGACY: - case SD_LEGACY: - esdhc_reset_tuning(mmc); - writel(mixctrl, ®s->mixctrl); - break; - case MMC_HS_400: - mixctrl |= MIX_CTRL_DDREN | MIX_CTRL_HS400_EN; - writel(mixctrl, ®s->mixctrl); - esdhc_set_strobe_dll(mmc); - break; - case MMC_HS: - case MMC_HS_52: - case MMC_HS_200: - case SD_HS: - case UHS_SDR12: - case UHS_SDR25: - case UHS_SDR50: - case UHS_SDR104: - writel(mixctrl, ®s->mixctrl); - break; - case UHS_DDR50: - case MMC_DDR_52: - mixctrl |= MIX_CTRL_DDREN; - writel(mixctrl, ®s->mixctrl); - break; - default: - printf("Not supported %d\n", mmc->selected_mode); - return -EINVAL; - } - - priv->mode = mmc->selected_mode; - - return esdhc_change_pinstate(mmc->dev); -} - -static int esdhc_set_voltage(struct mmc *mmc) -{ - struct fsl_esdhc_priv *priv = dev_get_priv(mmc->dev); - struct fsl_esdhc *regs = priv->esdhc_regs; - int ret; - - priv->signal_voltage = mmc->signal_voltage; - switch (mmc->signal_voltage) { - case MMC_SIGNAL_VOLTAGE_330: - if (priv->vs18_enable) - return -EIO; -#if CONFIG_IS_ENABLED(DM_REGULATOR) - if (!IS_ERR_OR_NULL(priv->vqmmc_dev)) { - ret = regulator_set_value(priv->vqmmc_dev, 3300000); - if (ret) { - printf("Setting to 3.3V error"); - return -EIO; - } - /* Wait for 5ms */ - mdelay(5); - } -#endif - - esdhc_clrbits32(®s->vendorspec, ESDHC_VENDORSPEC_VSELECT); - if (!(esdhc_read32(®s->vendorspec) & - ESDHC_VENDORSPEC_VSELECT)) - return 0; - - return -EAGAIN; - case MMC_SIGNAL_VOLTAGE_180: -#if CONFIG_IS_ENABLED(DM_REGULATOR) - if (!IS_ERR_OR_NULL(priv->vqmmc_dev)) { - ret = regulator_set_value(priv->vqmmc_dev, 1800000); - if (ret) { - printf("Setting to 1.8V error"); - return -EIO; - } - } -#endif - esdhc_setbits32(®s->vendorspec, ESDHC_VENDORSPEC_VSELECT); - if (esdhc_read32(®s->vendorspec) & ESDHC_VENDORSPEC_VSELECT) - return 0; - - return -EAGAIN; - case MMC_SIGNAL_VOLTAGE_120: - return -ENOTSUPP; - default: - return 0; - } -} - -static void esdhc_stop_tuning(struct mmc *mmc) -{ - struct mmc_cmd cmd; - - cmd.cmdidx = MMC_CMD_STOP_TRANSMISSION; - cmd.cmdarg = 0; - cmd.resp_type = MMC_RSP_R1b; - - dm_mmc_send_cmd(mmc->dev, &cmd, NULL); -} - -static int fsl_esdhc_execute_tuning(struct udevice *dev, uint32_t opcode) -{ - struct fsl_esdhc_plat *plat = dev_get_platdata(dev); - struct fsl_esdhc_priv *priv = dev_get_priv(dev); - struct fsl_esdhc *regs = priv->esdhc_regs; - struct mmc *mmc = &plat->mmc; - u32 irqstaten = readl(®s->irqstaten); - u32 irqsigen = readl(®s->irqsigen); - int i, ret = -ETIMEDOUT; - u32 val, mixctrl; - - /* clock tuning is not needed for upto 52MHz */ - if (mmc->clock <= 52000000) - return 0; - - /* This is readw/writew SDHCI_HOST_CONTROL2 when tuning */ - if (priv->flags & ESDHC_FLAG_STD_TUNING) { - val = readl(®s->autoc12err); - mixctrl = readl(®s->mixctrl); - val &= ~MIX_CTRL_SMPCLK_SEL; - mixctrl &= ~(MIX_CTRL_FBCLK_SEL | MIX_CTRL_AUTO_TUNE_EN); - - val |= MIX_CTRL_EXE_TUNE; - mixctrl |= MIX_CTRL_FBCLK_SEL | MIX_CTRL_AUTO_TUNE_EN; - - writel(val, ®s->autoc12err); - writel(mixctrl, ®s->mixctrl); - } - - /* sdhci_writew(host, SDHCI_TRNS_READ, SDHCI_TRANSFER_MODE); */ - mixctrl = readl(®s->mixctrl); - mixctrl = MIX_CTRL_DTDSEL_READ | (mixctrl & ~MIX_CTRL_SDHCI_MASK); - writel(mixctrl, ®s->mixctrl); - - writel(IRQSTATEN_BRR, ®s->irqstaten); - writel(IRQSTATEN_BRR, ®s->irqsigen); - - /* - * Issue opcode repeatedly till Execute Tuning is set to 0 or the number - * of loops reaches 40 times. - */ - for (i = 0; i < MAX_TUNING_LOOP; i++) { - u32 ctrl; - - if (opcode == MMC_CMD_SEND_TUNING_BLOCK_HS200) { - if (mmc->bus_width == 8) - writel(0x7080, ®s->blkattr); - else if (mmc->bus_width == 4) - writel(0x7040, ®s->blkattr); - } else { - writel(0x7040, ®s->blkattr); - } - - /* sdhci_writew(host, SDHCI_TRNS_READ, SDHCI_TRANSFER_MODE) */ - val = readl(®s->mixctrl); - val = MIX_CTRL_DTDSEL_READ | (val & ~MIX_CTRL_SDHCI_MASK); - writel(val, ®s->mixctrl); - - /* We are using STD tuning, no need to check return value */ - mmc_send_tuning(mmc, opcode, NULL); - - ctrl = readl(®s->autoc12err); - if ((!(ctrl & MIX_CTRL_EXE_TUNE)) && - (ctrl & MIX_CTRL_SMPCLK_SEL)) { - /* - * need to wait some time, make sure sd/mmc fininsh - * send out tuning data, otherwise, the sd/mmc can't - * response to any command when the card still out - * put the tuning data. - */ - mdelay(1); - ret = 0; - break; - } - - /* Add 1ms delay for SD and eMMC */ - mdelay(1); - } - - writel(irqstaten, ®s->irqstaten); - writel(irqsigen, ®s->irqsigen); - - esdhc_stop_tuning(mmc); - - return ret; -} -#endif - static int esdhc_set_ios_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) { struct fsl_esdhc *regs = priv->esdhc_regs; - int ret __maybe_unused;
#ifdef CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK /* Select to use peripheral clock */ esdhc_clock_control(priv, false); - esdhc_setbits32(®s->scr, ESDHCCTL_PCS); + esdhc_setbits32(®s->esdhcctl, ESDHCCTL_PCS); esdhc_clock_control(priv, true); #endif /* Set the clock speed */ if (priv->clock != mmc->clock) set_sysctl(priv, mmc, mmc->clock);
-#ifdef MMC_SUPPORTS_TUNING - if (mmc->clk_disable) { -#ifdef CONFIG_FSL_USDHC - esdhc_clrbits32(®s->vendorspec, VENDORSPEC_CKEN); -#else - esdhc_clrbits32(®s->sysctl, SYSCTL_CKEN); -#endif - } else { -#ifdef CONFIG_FSL_USDHC - esdhc_setbits32(®s->vendorspec, VENDORSPEC_PEREN | - VENDORSPEC_CKEN); -#else - esdhc_setbits32(®s->sysctl, SYSCTL_PEREN | SYSCTL_CKEN); -#endif - } - - if (priv->mode != mmc->selected_mode) { - ret = esdhc_set_timing(mmc); - if (ret) { - printf("esdhc_set_timing error %d\n", ret); - return ret; - } - } - - if (priv->signal_voltage != mmc->signal_voltage) { - ret = esdhc_set_voltage(mmc); - if (ret) { - printf("esdhc_set_voltage error %d\n", ret); - return ret; - } - } -#endif - /* Set the bus width */ esdhc_clrbits32(®s->proctl, PROCTL_DTW_4 | PROCTL_DTW_8);
@@ -1024,34 +607,10 @@ static int esdhc_init_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) return -ETIMEDOUT; }
-#if defined(CONFIG_FSL_USDHC) - /* RSTA doesn't reset MMC_BOOT register, so manually reset it */ - esdhc_write32(®s->mmcboot, 0x0); - /* Reset MIX_CTRL and CLK_TUNE_CTRL_STATUS regs to 0 */ - esdhc_write32(®s->mixctrl, 0x0); - esdhc_write32(®s->clktunectrlstatus, 0x0); - - /* Put VEND_SPEC to default value */ - if (priv->vs18_enable) - esdhc_write32(®s->vendorspec, (VENDORSPEC_INIT | - ESDHC_VENDORSPEC_VSELECT)); - else - esdhc_write32(®s->vendorspec, VENDORSPEC_INIT); - - /* Disable DLL_CTRL delay line */ - esdhc_write32(®s->dllctrl, 0x0); -#endif - -#ifndef ARCH_MXC /* Enable cache snooping */ - esdhc_write32(®s->scr, 0x00000040); -#endif + esdhc_write32(®s->esdhcctl, 0x00000040);
-#ifndef CONFIG_FSL_USDHC esdhc_setbits32(®s->sysctl, SYSCTL_HCKEN | SYSCTL_IPGEN); -#else - esdhc_setbits32(®s->vendorspec, VENDORSPEC_HCKEN | VENDORSPEC_IPGEN); -#endif
/* Set the initial clock speed */ mmc_set_clock(mmc, 400000, MMC_CLK_ENABLE); @@ -1059,12 +618,8 @@ static int esdhc_init_common(struct fsl_esdhc_priv *priv, struct mmc *mmc) /* Disable the BRR and BWR bits in IRQSTAT */ esdhc_clrbits32(®s->irqstaten, IRQSTATEN_BRR | IRQSTATEN_BWR);
-#ifdef CONFIG_MCF5441x - esdhc_write32(®s->proctl, PROCTL_INIT | PROCTL_D3CD); -#else /* Put the PROCTL reg back to the default */ esdhc_write32(®s->proctl, PROCTL_INIT); -#endif
/* Set timout to the maximum value */ esdhc_clrsetbits32(®s->sysctl, SYSCTL_TIMEOUT_MASK, 14 << 16); @@ -1085,10 +640,6 @@ static int esdhc_getcd_common(struct fsl_esdhc_priv *priv) #if CONFIG_IS_ENABLED(DM_MMC) if (priv->non_removable) return 1; -#ifdef CONFIG_DM_GPIO - if (dm_gpio_is_valid(&priv->cd_gpio)) - return dm_gpio_get_value(&priv->cd_gpio); -#endif #endif
while (!(esdhc_read32(®s->prsstat) & PRSSTAT_CINS) && --timeout) @@ -1172,25 +723,8 @@ static int fsl_esdhc_init(struct fsl_esdhc_priv *priv, if (ret) return ret;
-#ifdef CONFIG_MCF5441x - /* ColdFire, using SDHC_DATA[3] for card detection */ - esdhc_write32(®s->proctl, PROCTL_INIT | PROCTL_D3CD); -#endif - -#ifndef CONFIG_FSL_USDHC - esdhc_setbits32(®s->sysctl, SYSCTL_PEREN | SYSCTL_HCKEN - | SYSCTL_IPGEN | SYSCTL_CKEN); - /* Clearing tuning bits in case ROM has set it already */ - esdhc_write32(®s->mixctrl, 0); - esdhc_write32(®s->autoc12err, 0); - esdhc_write32(®s->clktunectrlstatus, 0); -#else - esdhc_setbits32(®s->vendorspec, VENDORSPEC_PEREN | - VENDORSPEC_HCKEN | VENDORSPEC_IPGEN | VENDORSPEC_CKEN); -#endif - - if (priv->vs18_enable) - esdhc_setbits32(®s->vendorspec, ESDHC_VENDORSPEC_VSELECT); + esdhc_setbits32(®s->sysctl, SYSCTL_PEREN | SYSCTL_HCKEN | + SYSCTL_IPGEN | SYSCTL_CKEN);
writel(SDHCI_IRQ_EN_BITS, ®s->irqstaten); cfg = &plat->cfg; @@ -1201,15 +735,6 @@ static int fsl_esdhc_init(struct fsl_esdhc_priv *priv, voltage_caps = 0; caps = esdhc_read32(®s->hostcapblt);
-#ifdef CONFIG_MCF5441x - /* - * MCF5441x RM declares in more points that sdhc clock speed must - * never exceed 25 Mhz. From this, the HS bit needs to be disabled - * from host capabilities. - */ - caps &= ~ESDHC_HOSTCAPBLT_HSS; -#endif - #ifdef CONFIG_SYS_FSL_ERRATUM_ESDHC135 caps = caps & ~(ESDHC_HOSTCAPBLT_SRS | ESDHC_HOSTCAPBLT_VS18 | ESDHC_HOSTCAPBLT_VS30); @@ -1266,27 +791,11 @@ static int fsl_esdhc_init(struct fsl_esdhc_priv *priv, cfg->host_caps &= ~MMC_MODE_8BIT; #endif
- cfg->host_caps |= priv->caps; - cfg->f_min = 400000; cfg->f_max = min(priv->sdhc_clk, (u32)200000000);
cfg->b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT;
- writel(0, ®s->dllctrl); - if (priv->flags & ESDHC_FLAG_USDHC) { - if (priv->flags & ESDHC_FLAG_STD_TUNING) { - u32 val = readl(®s->tuning_ctrl); - - val |= ESDHC_STD_TUNING_EN; - val &= ~ESDHC_TUNING_START_TAP_MASK; - val |= priv->tuning_start_tap; - val &= ~ESDHC_TUNING_STEP_MASK; - val |= (priv->tuning_step) << ESDHC_TUNING_STEP_SHIFT; - writel(val, ®s->tuning_ctrl); - } - } - return 0; }
@@ -1301,7 +810,6 @@ static int fsl_esdhc_cfg_to_priv(struct fsl_esdhc_cfg *cfg, priv->bus_width = cfg->max_bus_width; priv->sdhc_clk = cfg->sdhc_clk; priv->wp_enable = cfg->wp_enable; - priv->vs18_enable = cfg->vs18_enable;
return 0; }; @@ -1438,22 +946,11 @@ void fdt_fixup_esdhc(void *blob, bd_t *bd) #ifndef CONFIG_PPC #include <asm/arch/clock.h> #endif -__weak void init_clk_usdhc(u32 index) -{ -} - static int fsl_esdhc_probe(struct udevice *dev) { struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); struct fsl_esdhc_plat *plat = dev_get_platdata(dev); struct fsl_esdhc_priv *priv = dev_get_priv(dev); - const void *fdt = gd->fdt_blob; - int node = dev_of_offset(dev); - struct esdhc_soc_data *data = - (struct esdhc_soc_data *)dev_get_driver_data(dev); -#if CONFIG_IS_ENABLED(DM_REGULATOR) - struct udevice *vqmmc_dev; -#endif fdt_addr_t addr; unsigned int val; struct mmc *mmc; @@ -1468,11 +965,6 @@ static int fsl_esdhc_probe(struct udevice *dev) priv->esdhc_regs = (struct fsl_esdhc *)addr; #endif priv->dev = dev; - priv->mode = -1; - if (data) { - priv->flags = data->flags; - priv->caps = data->caps; - }
val = dev_read_u32_default(dev, "bus-width", -1); if (val == 8) @@ -1482,81 +974,13 @@ static int fsl_esdhc_probe(struct udevice *dev) else priv->bus_width = 1;
- val = fdtdec_get_int(fdt, node, "fsl,tuning-step", 1); - priv->tuning_step = val; - val = fdtdec_get_int(fdt, node, "fsl,tuning-start-tap", - ESDHC_TUNING_START_TAP_DEFAULT); - priv->tuning_start_tap = val; - val = fdtdec_get_int(fdt, node, "fsl,strobe-dll-delay-target", - ESDHC_STROBE_DLL_CTRL_SLV_DLY_TARGET_DEFAULT); - priv->strobe_dll_delay_target = val; - if (dev_read_bool(dev, "non-removable")) { priv->non_removable = 1; } else { priv->non_removable = 0; -#ifdef CONFIG_DM_GPIO - gpio_request_by_name(dev, "cd-gpios", 0, &priv->cd_gpio, - GPIOD_IS_IN); -#endif }
- if (dev_read_prop(dev, "fsl,wp-controller", NULL)) { - priv->wp_enable = 1; - } else { - priv->wp_enable = 0; -#ifdef CONFIG_DM_GPIO - gpio_request_by_name(dev, "wp-gpios", 0, &priv->wp_gpio, - GPIOD_IS_IN); -#endif - } - - priv->vs18_enable = 0; - -#if CONFIG_IS_ENABLED(DM_REGULATOR) - /* - * If emmc I/O has a fixed voltage at 1.8V, this must be provided, - * otherwise, emmc will work abnormally. - */ - ret = device_get_supply_regulator(dev, "vqmmc-supply", &vqmmc_dev); - if (ret) { - dev_dbg(dev, "no vqmmc-supply\n"); - } else { - ret = regulator_set_enable(vqmmc_dev, true); - if (ret) { - dev_err(dev, "fail to enable vqmmc-supply\n"); - return ret; - } - - if (regulator_get_value(vqmmc_dev) == 1800000) - priv->vs18_enable = 1; - } -#endif - - if (fdt_get_property(fdt, node, "no-1-8-v", NULL)) - priv->caps &= ~(UHS_CAPS | MMC_MODE_HS200 | MMC_MODE_HS400); - - /* - * TODO: - * Because lack of clk driver, if SDHC clk is not enabled, - * need to enable it first before this driver is invoked. - * - * we use MXC_ESDHC_CLK to get clk freq. - * If one would like to make this function work, - * the aliases should be provided in dts as this: - * - * aliases { - * mmc0 = &usdhc1; - * mmc1 = &usdhc2; - * mmc2 = &usdhc3; - * mmc3 = &usdhc4; - * }; - * Then if your board only supports mmc2 and mmc3, but we can - * correctly get the seq as 2 and 3, then let mxc_get_clock - * work as expected. - */ - - init_clk_usdhc(dev->seq); + priv->wp_enable = 1;
if (IS_ENABLED(CONFIG_CLK)) { /* Assigned clock already set clock */ @@ -1627,28 +1051,10 @@ static const struct dm_mmc_ops fsl_esdhc_ops = { .get_cd = fsl_esdhc_get_cd, .send_cmd = fsl_esdhc_send_cmd, .set_ios = fsl_esdhc_set_ios, -#ifdef MMC_SUPPORTS_TUNING - .execute_tuning = fsl_esdhc_execute_tuning, -#endif }; #endif
-static struct esdhc_soc_data usdhc_imx7d_data = { - .flags = ESDHC_FLAG_USDHC | ESDHC_FLAG_STD_TUNING - | ESDHC_FLAG_HAVE_CAP1 | ESDHC_FLAG_HS200 - | ESDHC_FLAG_HS400, - .caps = UHS_CAPS | MMC_MODE_HS200 | MMC_MODE_DDR_52MHz | - MMC_MODE_HS_52MHz | MMC_MODE_HS, -}; - static const struct udevice_id fsl_esdhc_ids[] = { - { .compatible = "fsl,imx53-esdhc", }, - { .compatible = "fsl,imx6ul-usdhc", }, - { .compatible = "fsl,imx6sx-usdhc", }, - { .compatible = "fsl,imx6sl-usdhc", }, - { .compatible = "fsl,imx6q-usdhc", }, - { .compatible = "fsl,imx7d-usdhc", .data = (ulong)&usdhc_imx7d_data,}, - { .compatible = "fsl,imx7ulp-usdhc", }, { .compatible = "fsl,esdhc", }, { /* sentinel */ } }; diff --git a/include/fsl_esdhc.h b/include/fsl_esdhc.h index 8dbd524..7d7e946 100644 --- a/include/fsl_esdhc.h +++ b/include/fsl_esdhc.h @@ -9,7 +9,6 @@ #ifndef __FSL_ESDHC_H__ #define __FSL_ESDHC_H__
-#include <linux/bitops.h> #include <linux/errno.h> #include <asm/byteorder.h>
@@ -25,22 +24,14 @@ #define SYSCTL_INITA 0x08000000 #define SYSCTL_TIMEOUT_MASK 0x000f0000 #define SYSCTL_CLOCK_MASK 0x0000fff0 -#if !defined(CONFIG_FSL_USDHC) #define SYSCTL_CKEN 0x00000008 #define SYSCTL_PEREN 0x00000004 #define SYSCTL_HCKEN 0x00000002 #define SYSCTL_IPGEN 0x00000001 -#endif #define SYSCTL_RSTA 0x01000000 #define SYSCTL_RSTC 0x02000000 #define SYSCTL_RSTD 0x04000000
-#define VENDORSPEC_CKEN 0x00004000 -#define VENDORSPEC_PEREN 0x00002000 -#define VENDORSPEC_HCKEN 0x00001000 -#define VENDORSPEC_IPGEN 0x00000800 -#define VENDORSPEC_INIT 0x20007809 - #define IRQSTAT 0x0002e030 #define IRQSTAT_DMAE (0x10000000) #define IRQSTAT_AC12E (0x01000000) @@ -172,54 +163,6 @@ #define ESDHC_HOSTCAPBLT_DMAS 0x00400000 #define ESDHC_HOSTCAPBLT_HSS 0x00200000
-#define ESDHC_VENDORSPEC_VSELECT 0x00000002 /* Use 1.8V */ - -/* Imported from Linux Kernel drivers/mmc/host/sdhci-esdhc-imx.c */ -#define MIX_CTRL_DDREN BIT(3) -#define MIX_CTRL_DTDSEL_READ BIT(4) -#define MIX_CTRL_AC23EN BIT(7) -#define MIX_CTRL_EXE_TUNE BIT(22) -#define MIX_CTRL_SMPCLK_SEL BIT(23) -#define MIX_CTRL_AUTO_TUNE_EN BIT(24) -#define MIX_CTRL_FBCLK_SEL BIT(25) -#define MIX_CTRL_HS400_EN BIT(26) -#define MIX_CTRL_HS400_ES BIT(27) -/* Bits 3 and 6 are not SDHCI standard definitions */ -#define MIX_CTRL_SDHCI_MASK 0xb7 -/* Tuning bits */ -#define MIX_CTRL_TUNING_MASK 0x03c00000 - -/* strobe dll register */ -#define ESDHC_STROBE_DLL_CTRL 0x70 -#define ESDHC_STROBE_DLL_CTRL_ENABLE BIT(0) -#define ESDHC_STROBE_DLL_CTRL_RESET BIT(1) -#define ESDHC_STROBE_DLL_CTRL_SLV_DLY_TARGET_DEFAULT 0x7 -#define ESDHC_STROBE_DLL_CTRL_SLV_DLY_TARGET_SHIFT 3 - -#define ESDHC_STROBE_DLL_STATUS 0x74 -#define ESDHC_STROBE_DLL_STS_REF_LOCK BIT(1) -#define ESDHC_STROBE_DLL_STS_SLV_LOCK 0x1 -#define ESDHC_STROBE_DLL_CLK_FREQ 100000000 - -#define ESDHC_STD_TUNING_EN BIT(24) -/* NOTE: the minimum valid tuning start tap for mx6sl is 1 */ -#define ESDHC_TUNING_START_TAP_DEFAULT 0x1 -#define ESDHC_TUNING_START_TAP_MASK 0xff -#define ESDHC_TUNING_STEP_MASK 0x00070000 -#define ESDHC_TUNING_STEP_SHIFT 16 - -#define ESDHC_FLAG_MULTIBLK_NO_INT BIT(1) -#define ESDHC_FLAG_ENGCM07207 BIT(2) -#define ESDHC_FLAG_USDHC BIT(3) -#define ESDHC_FLAG_MAN_TUNING BIT(4) -#define ESDHC_FLAG_STD_TUNING BIT(5) -#define ESDHC_FLAG_HAVE_CAP1 BIT(6) -#define ESDHC_FLAG_ERR004536 BIT(7) -#define ESDHC_FLAG_HS200 BIT(8) -#define ESDHC_FLAG_HS400 BIT(9) -#define ESDHC_FLAG_ERR010450 BIT(10) -#define ESDHC_FLAG_HS400_ES BIT(11) - struct fsl_esdhc_cfg { phys_addr_t esdhc_base; u32 sdhc_clk;
Dropped useless code for i.MX eSDHC driver.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com Tested-by: Steffen Dirkwinkel s.dirkwinkel@beckhoff.com Reviewed-by: Peng Fan peng.fan@nxp.com --- Changes for v2: - Added this patch. Changes for v3: - None. Changes for v4: - Dropped PPC code introduced recently. Changes for v5: - Kept MCF5441x code. --- drivers/mmc/fsl_esdhc_imx.c | 65 +++------------------------------------------ include/fsl_esdhc_imx.h | 4 --- 2 files changed, 4 insertions(+), 65 deletions(-)
diff --git a/drivers/mmc/fsl_esdhc_imx.c b/drivers/mmc/fsl_esdhc_imx.c index 1474e2c..2c0ad18 100644 --- a/drivers/mmc/fsl_esdhc_imx.c +++ b/drivers/mmc/fsl_esdhc_imx.c @@ -261,8 +261,7 @@ static int esdhc_setup_data(struct fsl_esdhc_priv *priv, struct mmc *mmc, { int timeout; struct fsl_esdhc *regs = priv->esdhc_regs; -#if defined(CONFIG_FSL_LAYERSCAPE) || defined(CONFIG_S32V234) || \ - defined(CONFIG_IMX8) || defined(CONFIG_IMX8M) +#if defined(CONFIG_S32V234) || defined(CONFIG_IMX8) || defined(CONFIG_IMX8M) dma_addr_t addr; #endif uint wml_value; @@ -275,8 +274,7 @@ static int esdhc_setup_data(struct fsl_esdhc_priv *priv, struct mmc *mmc,
esdhc_clrsetbits32(®s->wml, WML_RD_WML_MASK, wml_value); #ifndef CONFIG_SYS_FSL_ESDHC_USE_PIO -#if defined(CONFIG_FSL_LAYERSCAPE) || defined(CONFIG_S32V234) || \ - defined(CONFIG_IMX8) || defined(CONFIG_IMX8M) +#if defined(CONFIG_S32V234) || defined(CONFIG_IMX8) || defined(CONFIG_IMX8M) addr = virt_to_phys((void *)(data->dest)); if (upper_32_bits(addr)) printf("Error found for upper 32 bits\n"); @@ -312,8 +310,7 @@ static int esdhc_setup_data(struct fsl_esdhc_priv *priv, struct mmc *mmc, esdhc_clrsetbits32(®s->wml, WML_WR_WML_MASK, wml_value << 16); #ifndef CONFIG_SYS_FSL_ESDHC_USE_PIO -#if defined(CONFIG_FSL_LAYERSCAPE) || defined(CONFIG_S32V234) || \ - defined(CONFIG_IMX8) || defined(CONFIG_IMX8M) +#if defined(CONFIG_S32V234) || defined(CONFIG_IMX8) || defined(CONFIG_IMX8M) addr = virt_to_phys((void *)(data->src)); if (upper_32_bits(addr)) printf("Error found for upper 32 bits\n"); @@ -378,8 +375,7 @@ static void check_and_invalidate_dcache_range unsigned end = 0; unsigned size = roundup(ARCH_DMA_MINALIGN, data->blocks*data->blocksize); -#if defined(CONFIG_FSL_LAYERSCAPE) || defined(CONFIG_S32V234) || \ - defined(CONFIG_IMX8) || defined(CONFIG_IMX8M) +#if defined(CONFIG_S32V234) || defined(CONFIG_IMX8) || defined(CONFIG_IMX8M) dma_addr_t addr;
addr = virt_to_phys((void *)(data->dest)); @@ -1364,45 +1360,6 @@ int fsl_esdhc_mmc_init(bd_t *bis) } #endif
-#ifdef CONFIG_FSL_ESDHC_ADAPTER_IDENT -void mmc_adapter_card_type_ident(void) -{ - u8 card_id; - u8 value; - - card_id = QIXIS_READ(present) & QIXIS_SDID_MASK; - gd->arch.sdhc_adapter = card_id; - - switch (card_id) { - case QIXIS_ESDHC_ADAPTER_TYPE_EMMC45: - value = QIXIS_READ(brdcfg[5]); - value |= (QIXIS_DAT4 | QIXIS_DAT5_6_7); - QIXIS_WRITE(brdcfg[5], value); - break; - case QIXIS_ESDHC_ADAPTER_TYPE_SDMMC_LEGACY: - value = QIXIS_READ(pwr_ctl[1]); - value |= QIXIS_EVDD_BY_SDHC_VS; - QIXIS_WRITE(pwr_ctl[1], value); - break; - case QIXIS_ESDHC_ADAPTER_TYPE_EMMC44: - value = QIXIS_READ(brdcfg[5]); - value |= (QIXIS_SDCLKIN | QIXIS_SDCLKOUT); - QIXIS_WRITE(brdcfg[5], value); - break; - case QIXIS_ESDHC_ADAPTER_TYPE_RSV: - break; - case QIXIS_ESDHC_ADAPTER_TYPE_MMC: - break; - case QIXIS_ESDHC_ADAPTER_TYPE_SD: - break; - case QIXIS_ESDHC_NO_ADAPTER: - break; - default: - break; - } -} -#endif - #ifdef CONFIG_OF_LIBFDT __weak int esdhc_status_fixup(void *blob, const char *compat) { @@ -1430,17 +1387,11 @@ void fdt_fixup_esdhc(void *blob, bd_t *bd) do_fixup_by_compat_u32(blob, compat, "clock-frequency", gd->arch.sdhc_clk, 1); #endif -#ifdef CONFIG_FSL_ESDHC_ADAPTER_IDENT - do_fixup_by_compat_u32(blob, compat, "adapter-type", - (u32)(gd->arch.sdhc_adapter), 1); -#endif } #endif
#if CONFIG_IS_ENABLED(DM_MMC) -#ifndef CONFIG_PPC #include <asm/arch/clock.h> -#endif __weak void init_clk_usdhc(u32 index) { } @@ -1465,11 +1416,7 @@ static int fsl_esdhc_probe(struct udevice *dev) addr = dev_read_addr(dev); if (addr == FDT_ADDR_T_NONE) return -EINVAL; -#ifdef CONFIG_PPC - priv->esdhc_regs = (struct fsl_esdhc *)lower_32_bits(addr); -#else priv->esdhc_regs = (struct fsl_esdhc *)addr; -#endif priv->dev = dev; priv->mode = -1; if (data) { @@ -1576,11 +1523,7 @@ static int fsl_esdhc_probe(struct udevice *dev)
priv->sdhc_clk = clk_get_rate(&priv->per_clk); } else { -#ifndef CONFIG_PPC priv->sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK + dev->seq); -#else - priv->sdhc_clk = gd->arch.sdhc_clk; -#endif if (priv->sdhc_clk <= 0) { dev_err(dev, "Unable to get clk for %s\n", dev->name); return -EINVAL; diff --git a/include/fsl_esdhc_imx.h b/include/fsl_esdhc_imx.h index 67fd289..33c6d52 100644 --- a/include/fsl_esdhc_imx.h +++ b/include/fsl_esdhc_imx.h @@ -19,10 +19,6 @@ /* needed for the mmc_cfg definition */ #include <mmc.h>
-#ifdef CONFIG_FSL_ESDHC_ADAPTER_IDENT -#include "../board/freescale/common/qixis.h" -#endif - /* FSL eSDHC-specific constants */ #define SYSCTL 0x0002e02c #define SYSCTL_INITA 0x08000000
Yangbo Lu
