[PATCH 1/1] timer: dw-apb: fix compiler warnings
readl() and writel() expect void *. Do not pass an integer value.
Remove unused include include asm/arch/timer.h.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- The driver is needed for the timers of the Kendryte K210 (compatible "snps,dw-apb-timer"). --- drivers/timer/dw-apb-timer.c | 7 +++---- 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/drivers/timer/dw-apb-timer.c b/drivers/timer/dw-apb-timer.c index 35271b20c8..c8be4417fd 100644 --- a/drivers/timer/dw-apb-timer.c +++ b/drivers/timer/dw-apb-timer.c @@ -14,7 +14,6 @@ #include <dm/device_compat.h>
#include <asm/io.h> -#include <asm/arch/timer.h>
#define DW_APB_LOAD_VAL 0x0 #define DW_APB_CURR_VAL 0x4 @@ -34,7 +33,7 @@ static int dw_apb_timer_get_count(struct udevice *dev, u64 *count) * requires the count to be incrementing. Invert the * result. */ - *count = timer_conv_64(~readl(priv->regs + DW_APB_CURR_VAL)); + *count = timer_conv_64(~readl((void *)(priv->regs + DW_APB_CURR_VAL)));
return 0; } @@ -61,8 +60,8 @@ static int dw_apb_timer_probe(struct udevice *dev) clk_free(&clk);
/* init timer */ - writel(0xffffffff, priv->regs + DW_APB_LOAD_VAL); - writel(0xffffffff, priv->regs + DW_APB_CURR_VAL); + writel(0xffffffff, (void *)(priv->regs + DW_APB_LOAD_VAL)); + writel(0xffffffff, (void *)(priv->regs + DW_APB_CURR_VAL)); setbits_le32(priv->regs + DW_APB_CTRL, 0x3);
return 0; -- 2.27.0
On Wed, Jul 29, 2020 at 1:02 AM Heinrich Schuchardt xypron.glpk@gmx.de wrote:
two include ?
*count = timer_conv_64(~readl((void *)(priv->regs + DW_APB_CURR_VAL))); return 0;
/* init timer */
Reviewed-by: Bin Meng bin.meng@windriver.com
Bin Meng
