[U-Boot] [PATCH 1/3] ARM: dts: dh-imx6: Refactor DT with som and board level defs for use with imx6 duallite
To use the device tree definitions imx6q-dhcom-som.dtsi for all imx6 derivatives rename it to imx6qdl-dhcom.dtsi. We omit the '-som', because it simplifies further mainlinening of already existing device trees. To reuse board level common stuff imx6qdl-dhcom-pdk2.dtsi is created and included by imx6q-dhcom-pdk2.dts.
Signed-off-by Ludwig Zenz lzenz@dh-electronics.com --- arch/arm/dts/imx6q-dhcom-pdk2.dts | 143 +-------------------- arch/arm/dts/imx6qdl-dhcom-pdk2.dtsi | 140 ++++++++++++++++++++ .../{imx6q-dhcom-som.dtsi => imx6qdl-dhcom.dtsi} | 1 - 3 files changed, 146 insertions(+), 138 deletions(-) create mode 100644 arch/arm/dts/imx6qdl-dhcom-pdk2.dtsi rename arch/arm/dts/{imx6q-dhcom-som.dtsi => imx6qdl-dhcom.dtsi} (99%)
diff --git a/arch/arm/dts/imx6q-dhcom-pdk2.dts b/arch/arm/dts/imx6q-dhcom-pdk2.dts index 9c61e3be2d..49ef3552bd 100644 --- a/arch/arm/dts/imx6q-dhcom-pdk2.dts +++ b/arch/arm/dts/imx6q-dhcom-pdk2.dts @@ -1,151 +1,20 @@ // SPDX-License-Identifier: (GPL-2.0+) /* - * Copyright (C) 2015 DH electronics GmbH - * Copyright (C) 2018 Marek Vasut marex@denx.de + * Copyright (C) 2019 DH electronics GmbH */
/dts-v1/;
-#include "imx6q-dhcom-som.dtsi" +#include "imx6q.dtsi" +#include "imx6qdl-dhcom.dtsi" +#include "imx6qdl-dhcom-pdk2.dtsi"
/ { - model = "Freescale i.MX6 Quad DHCOM Premium Developer Kit (2)"; - compatible = "dh,imx6q-dhcom-pdk2", "dh,imx6q-dhcom-som", "fsl,imx6q"; - - chosen { - stdout-path = &uart1; - }; - - clk_ext_audio_codec: clock-codec { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <24000000>; - }; - - sound { - compatible = "fsl,imx-audio-sgtl5000"; - model = "imx-sgtl5000"; - ssi-controller = <&ssi1>; - audio-codec = <&sgtl5000>; - audio-routing = - "MIC_IN", "Mic Jack", - "Mic Jack", "Mic Bias", - "LINE_IN", "Line In Jack", - "Headphone Jack", "HP_OUT"; - mux-int-port = <1>; - mux-ext-port = <3>; - }; -}; - -&audmux { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_audmux_ext>; - status = "okay"; -}; - -&hdmi { - ddc-i2c-bus = <&i2c2>; - status = "okay"; -}; - -&i2c2 { - sgtl5000: codec@a { - compatible = "fsl,sgtl5000"; - reg = <0x0a>; - #sound-dai-cells = <0>; - clocks = <&clk_ext_audio_codec>; - VDDA-supply = <®_3p3v>; - VDDIO-supply = <®_3p3v>; - }; -}; - -&iomuxc { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_hog_base &pinctrl_hog>; - - pinctrl_hog: hog-grp { - fsl,pins = < - MX6QDL_PAD_GPIO_2__GPIO1_IO02 0x400120b0 - MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x400120b0 - MX6QDL_PAD_GPIO_5__GPIO1_IO05 0x400120b0 - MX6QDL_PAD_CSI0_DAT17__GPIO6_IO03 0x400120b0 - MX6QDL_PAD_GPIO_19__GPIO4_IO05 0x120b0 - MX6QDL_PAD_DI0_PIN4__GPIO4_IO20 0x400120b0 - MX6QDL_PAD_EIM_D27__GPIO3_IO27 0x120b0 - MX6QDL_PAD_KEY_ROW0__GPIO4_IO07 0x120b0 - MX6QDL_PAD_KEY_COL1__GPIO4_IO08 0x400120b0 - MX6QDL_PAD_NANDF_CS1__GPIO6_IO14 0x400120b0 - MX6QDL_PAD_NANDF_CS2__GPIO6_IO15 0x400120b0 - MX6QDL_PAD_KEY_ROW1__GPIO4_IO09 0x400120b0 - MX6QDL_PAD_SD3_DAT5__GPIO7_IO00 0x400120b0 - MX6QDL_PAD_SD3_DAT4__GPIO7_IO01 0x400120b0 - MX6QDL_PAD_CSI0_VSYNC__GPIO5_IO21 0x400120b0 - MX6QDL_PAD_GPIO_18__GPIO7_IO13 0x400120b0 - MX6QDL_PAD_SD1_CMD__GPIO1_IO18 0x400120b0 - MX6QDL_PAD_SD1_DAT0__GPIO1_IO16 0x400120b0 - MX6QDL_PAD_SD1_DAT1__GPIO1_IO17 0x400120b0 - MX6QDL_PAD_SD1_DAT2__GPIO1_IO19 0x400120b0 - MX6QDL_PAD_SD1_CLK__GPIO1_IO20 0x400120b0 - MX6QDL_PAD_CSI0_PIXCLK__GPIO5_IO18 0x400120b0 - MX6QDL_PAD_CSI0_MCLK__GPIO5_IO19 0x400120b0 - MX6QDL_PAD_KEY_COL0__GPIO4_IO06 0x400120b0 - >; - }; - - pinctrl_audmux_ext: audmux-ext-grp { - fsl,pins = < - MX6QDL_PAD_CSI0_DAT7__AUD3_RXD 0x130b0 - MX6QDL_PAD_CSI0_DAT4__AUD3_TXC 0x130b0 - MX6QDL_PAD_CSI0_DAT5__AUD3_TXD 0x110b0 - MX6QDL_PAD_CSI0_DAT6__AUD3_TXFS 0x130b0 - >; - }; - - pinctrl_enet_1G: enet-1G-grp { - fsl,pins = < - MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x100b0 - MX6QDL_PAD_ENET_MDC__ENET_MDC 0x100b0 - MX6QDL_PAD_RGMII_TXC__RGMII_TXC 0x100b0 - MX6QDL_PAD_RGMII_TD0__RGMII_TD0 0x100b0 - MX6QDL_PAD_RGMII_TD1__RGMII_TD1 0x100b0 - MX6QDL_PAD_RGMII_TD2__RGMII_TD2 0x100b0 - MX6QDL_PAD_RGMII_TD3__RGMII_TD3 0x100b0 - MX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL 0x100b0 - MX6QDL_PAD_ENET_REF_CLK__ENET_TX_CLK 0x100b0 - MX6QDL_PAD_RGMII_RXC__RGMII_RXC 0x1b0b0 - MX6QDL_PAD_RGMII_RD0__RGMII_RD0 0x1b0b0 - MX6QDL_PAD_RGMII_RD1__RGMII_RD1 0x1b0b0 - MX6QDL_PAD_RGMII_RD2__RGMII_RD2 0x1b0b0 - MX6QDL_PAD_RGMII_RD3__RGMII_RD3 0x1b0b0 - MX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL 0x1b0b0 - MX6QDL_PAD_EIM_D29__GPIO3_IO29 0x000b0 - MX6QDL_PAD_GPIO_0__GPIO1_IO00 0x000b1 - MX6QDL_PAD_EIM_D26__GPIO3_IO26 0x000b1 - >; - }; - - pinctrl_pcie: pcie-grp { - fsl,pins = < - MX6QDL_PAD_CSI0_DATA_EN__GPIO5_IO20 0x1b0b1 - >; - }; -}; - -&pcie { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pcie>; - reset-gpio = <&gpio6 14 GPIO_ACTIVE_LOW>; - status = "okay"; -}; - -&ssi1 { - status = "okay"; + model = "Freescale i.MX6 Quad/Dual DHCOM Premium Developer Kit (2)"; + compatible = "dh,imx6q-dhcom-pdk2", "dh,imx6q-dhcom", "fsl,imx6q"; };
&sata { status = "okay"; };
-&usdhc3 { - status = "okay"; -}; diff --git a/arch/arm/dts/imx6qdl-dhcom-pdk2.dtsi b/arch/arm/dts/imx6qdl-dhcom-pdk2.dtsi new file mode 100644 index 0000000000..e08afcb297 --- /dev/null +++ b/arch/arm/dts/imx6qdl-dhcom-pdk2.dtsi @@ -0,0 +1,140 @@ +// SPDX-License-Identifier: (GPL-2.0+) +/* + * Copyright (C) 2015 DH electronics GmbH + * Copyright (C) 2018 Marek Vasut marex@denx.de + */ + +/ { + chosen { + stdout-path = &uart1; + }; + + clk_ext_audio_codec: clock-codec { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <24000000>; + }; + + sound { + compatible = "fsl,imx-audio-sgtl5000"; + model = "imx-sgtl5000"; + ssi-controller = <&ssi1>; + audio-codec = <&sgtl5000>; + audio-routing = + "MIC_IN", "Mic Jack", + "Mic Jack", "Mic Bias", + "LINE_IN", "Line In Jack", + "Headphone Jack", "HP_OUT"; + mux-int-port = <1>; + mux-ext-port = <3>; + }; +}; + +&audmux { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_audmux_ext>; + status = "okay"; +}; + +&hdmi { + ddc-i2c-bus = <&i2c2>; + status = "okay"; +}; + +&i2c2 { + sgtl5000: codec@a { + compatible = "fsl,sgtl5000"; + reg = <0x0a>; + #sound-dai-cells = <0>; + clocks = <&clk_ext_audio_codec>; + VDDA-supply = <®_3p3v>; + VDDIO-supply = <®_3p3v>; + }; +}; + +&iomuxc { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_hog_base &pinctrl_hog>; + + pinctrl_hog: hog-grp { + fsl,pins = < + MX6QDL_PAD_GPIO_2__GPIO1_IO02 0x400120b0 + MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x400120b0 + MX6QDL_PAD_GPIO_5__GPIO1_IO05 0x400120b0 + MX6QDL_PAD_CSI0_DAT17__GPIO6_IO03 0x400120b0 + MX6QDL_PAD_GPIO_19__GPIO4_IO05 0x120b0 + MX6QDL_PAD_DI0_PIN4__GPIO4_IO20 0x400120b0 + MX6QDL_PAD_EIM_D27__GPIO3_IO27 0x120b0 + MX6QDL_PAD_KEY_ROW0__GPIO4_IO07 0x120b0 + MX6QDL_PAD_KEY_COL1__GPIO4_IO08 0x400120b0 + MX6QDL_PAD_NANDF_CS1__GPIO6_IO14 0x400120b0 + MX6QDL_PAD_NANDF_CS2__GPIO6_IO15 0x400120b0 + MX6QDL_PAD_KEY_ROW1__GPIO4_IO09 0x400120b0 + MX6QDL_PAD_SD3_DAT5__GPIO7_IO00 0x400120b0 + MX6QDL_PAD_SD3_DAT4__GPIO7_IO01 0x400120b0 + MX6QDL_PAD_CSI0_VSYNC__GPIO5_IO21 0x400120b0 + MX6QDL_PAD_GPIO_18__GPIO7_IO13 0x400120b0 + MX6QDL_PAD_SD1_CMD__GPIO1_IO18 0x400120b0 + MX6QDL_PAD_SD1_DAT0__GPIO1_IO16 0x400120b0 + MX6QDL_PAD_SD1_DAT1__GPIO1_IO17 0x400120b0 + MX6QDL_PAD_SD1_DAT2__GPIO1_IO19 0x400120b0 + MX6QDL_PAD_SD1_CLK__GPIO1_IO20 0x400120b0 + MX6QDL_PAD_CSI0_PIXCLK__GPIO5_IO18 0x400120b0 + MX6QDL_PAD_CSI0_MCLK__GPIO5_IO19 0x400120b0 + MX6QDL_PAD_KEY_COL0__GPIO4_IO06 0x400120b0 + >; + }; + + pinctrl_audmux_ext: audmux-ext-grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT7__AUD3_RXD 0x130b0 + MX6QDL_PAD_CSI0_DAT4__AUD3_TXC 0x130b0 + MX6QDL_PAD_CSI0_DAT5__AUD3_TXD 0x110b0 + MX6QDL_PAD_CSI0_DAT6__AUD3_TXFS 0x130b0 + >; + }; + + pinctrl_enet_1G: enet-1G-grp { + fsl,pins = < + MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x100b0 + MX6QDL_PAD_ENET_MDC__ENET_MDC 0x100b0 + MX6QDL_PAD_RGMII_TXC__RGMII_TXC 0x100b0 + MX6QDL_PAD_RGMII_TD0__RGMII_TD0 0x100b0 + MX6QDL_PAD_RGMII_TD1__RGMII_TD1 0x100b0 + MX6QDL_PAD_RGMII_TD2__RGMII_TD2 0x100b0 + MX6QDL_PAD_RGMII_TD3__RGMII_TD3 0x100b0 + MX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL 0x100b0 + MX6QDL_PAD_ENET_REF_CLK__ENET_TX_CLK 0x100b0 + MX6QDL_PAD_RGMII_RXC__RGMII_RXC 0x1b0b0 + MX6QDL_PAD_RGMII_RD0__RGMII_RD0 0x1b0b0 + MX6QDL_PAD_RGMII_RD1__RGMII_RD1 0x1b0b0 + MX6QDL_PAD_RGMII_RD2__RGMII_RD2 0x1b0b0 + MX6QDL_PAD_RGMII_RD3__RGMII_RD3 0x1b0b0 + MX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL 0x1b0b0 + MX6QDL_PAD_EIM_D29__GPIO3_IO29 0x000b0 + MX6QDL_PAD_GPIO_0__GPIO1_IO00 0x000b1 + MX6QDL_PAD_EIM_D26__GPIO3_IO26 0x000b1 + >; + }; + + pinctrl_pcie: pcie-grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DATA_EN__GPIO5_IO20 0x1b0b1 + >; + }; +}; + +&pcie { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pcie>; + reset-gpio = <&gpio6 14 GPIO_ACTIVE_LOW>; + status = "okay"; +}; + +&ssi1 { + status = "okay"; +}; + +&usdhc3 { + status = "okay"; +}; diff --git a/arch/arm/dts/imx6q-dhcom-som.dtsi b/arch/arm/dts/imx6qdl-dhcom.dtsi similarity index 99% rename from arch/arm/dts/imx6q-dhcom-som.dtsi rename to arch/arm/dts/imx6qdl-dhcom.dtsi index 524cd287c6..5952c96086 100644 --- a/arch/arm/dts/imx6q-dhcom-som.dtsi +++ b/arch/arm/dts/imx6qdl-dhcom.dtsi @@ -4,7 +4,6 @@ * Copyright (C) 2018 Marek Vasut marex@denx.de */
-#include "imx6q.dtsi" #include <dt-bindings/pwm/pwm.h> #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/clock/imx6qdl-clock.h>
This device tree adds support for DHCOM iMX6 duallite and solo deriviates.
Signed-off-by: Ludwig Zenz lzenz@dh-electronics.com --- arch/arm/dts/Makefile | 5 +++-- arch/arm/dts/imx6dl-dhcom-pdk2.dts | 16 ++++++++++++++++ 2 files changed, 19 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/imx6dl-dhcom-pdk2.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 2271d78729..228f89eec1 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -548,10 +548,12 @@ dtb-$(CONFIG_TARGET_TBS2910) += \ imx6q-tbs2910.dtb
dtb-$(CONFIG_MX6QDL) += \ + imx6dl-dhcom-pdk2.dtb \ imx6dl-icore.dtb \ imx6dl-icore-mipi.dtb \ imx6dl-icore-rqs.dtb \ imx6dl-mamoj.dtb \ + imx6q-dhcom-pdk2.dtb \ imx6q-cm-fx6.dtb \ imx6q-icore.dtb \ imx6q-icore-mipi.dtb \ @@ -596,8 +598,7 @@ dtb-$(CONFIG_MX6ULL) += \
dtb-$(CONFIG_ARCH_MX6) += \ imx6-apalis.dtb \ - imx6-colibri.dtb \ - imx6q-dhcom-pdk2.dtb + imx6-colibri.dtb
dtb-$(CONFIG_MX7) += imx7d-sdb.dtb \ imx7d-sdb-qspi.dtb \ diff --git a/arch/arm/dts/imx6dl-dhcom-pdk2.dts b/arch/arm/dts/imx6dl-dhcom-pdk2.dts new file mode 100644 index 0000000000..02540f4884 --- /dev/null +++ b/arch/arm/dts/imx6dl-dhcom-pdk2.dts @@ -0,0 +1,16 @@ +// SPDX-License-Identifier: (GPL-2.0+) +/* + * Copyright (C) 2019 DH electronics GmbH + */ + +/dts-v1/; + +#include "imx6dl.dtsi" +#include "imx6qdl-dhcom.dtsi" +#include "imx6qdl-dhcom-pdk2.dtsi" + +/ { + model = "Freescale i.MX6 Duallite/Solo DHCOM Premium Developer Kit (2)"; + compatible = "dh,imx6dl-dhcom-pdk2", "dh,imx6dl-dhcom", "fsl,imx6dl"; +}; +
Configure fitImage for U-Boot with a device tree for imx6 quad/dual and duallite/solo. This enables to support the imx6 derivates quad/dual/duallite/solo with a single binary.
Signed-off-by: Ludwig Zenz lzenz@dh-electronics.com --- board/dhelectronics/dh_imx6/dh_imx6.c | 15 +++++++++++++++ configs/dh_imx6_defconfig | 7 +++++-- 2 files changed, 20 insertions(+), 2 deletions(-)
diff --git a/board/dhelectronics/dh_imx6/dh_imx6.c b/board/dhelectronics/dh_imx6/dh_imx6.c index e5ff91248a..cca8e832ec 100644 --- a/board/dhelectronics/dh_imx6/dh_imx6.c +++ b/board/dhelectronics/dh_imx6/dh_imx6.c @@ -355,3 +355,18 @@ int checkboard(void) puts("Board: DHCOM i.MX6\n"); return 0; } + +#ifdef CONFIG_MULTI_DTB_FIT +int board_fit_config_name_match(const char *name) +{ + if (is_mx6dq()) { + if (!strcmp(name, "imx6q-dhcom-pdk2")) + return 0; + } else if (is_mx6sdl()) { + if (!strcmp(name, "imx6dl-dhcom-pdk2")) + return 0; + } + + return -1; +} +#endif diff --git a/configs/dh_imx6_defconfig b/configs/dh_imx6_defconfig index 3f615b4634..4734ed76e5 100644 --- a/configs/dh_imx6_defconfig +++ b/configs/dh_imx6_defconfig @@ -10,14 +10,13 @@ CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SPL=y CONFIG_SYS_BOOTCOUNT_ADDR=0x00900000 -CONFIG_DM_GPIO=y -CONFIG_DM_MMC=y CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT=y +CONFIG_SPL_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 # CONFIG_USE_BOOTCOMMAND is not set @@ -43,9 +42,13 @@ CONFIG_CMD_TIME=y CONFIG_CMD_EXT4_WRITE=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6q-dhcom-pdk2" +CONFIG_OF_LIST="imx6q-dhcom-pdk2 imx6dl-dhcom-pdk2" +CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_DWC_AHSATA=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_DM_GPIO=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y
You forgot a changelog here:
V2: - foo changed - bar was adjusted ...
Also, $subject should state [PATCH v2 ...
- Copyright (C) 2015 DH electronics GmbH
- Copyright (C) 2018 Marek Vasut marex@denx.de
- Copyright (C) 2019 DH electronics GmbH
Please don't remove my copyright ? Also, extend the DH copyright (2015-2019)
/dts-v1/;
Shouldn't #include "imx6qdl-dhcom.dtsi" be in #include "imx6qdl-dhcom-pdk2.dtsi" instead ?
Ludwig Zenz
