ipq40xx serial driver not working
Hello everyone, recently I'm trying to port the newest version of u boot to my ipq4019 development board, and I found that the current serial driver for Qualcomm ipq40xx socs at u-boot-2022.01/drivers/serial/serial_msm.c is not compatible to ipq40xx despite they share the same compatible string in the device tree: u-boot-2022.01/drivers/serial/serial_msm.c: static const struct udevice_id msm_serial_ids[] = { { .compatible = "qcom,msm-uartdm-v1.4" }, { } };
u-boot-2022.01/arch/arm/dts/qcom-ipq4019.dtsi: blsp1_uart1: serial@78af000 { compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; [...] }; I do have a confirmed working driver at hand, by comparing the code, I believe the reason behind this is the ipq40xx has a different register map than the current driver: Register map of my working diver at hand: struct ipq_serial_regs { unsigned int mr1; /* 0x00 - Operational Mode Register 1 */ unsigned int mr2; /* 0x04 - Operational Mode Register 2 */ unsigned int sr_csr; /* 0x08 - Status Register, Clock Selection Register */ unsigned char gap0[4]; /* 0x0C - gap */ unsigned int cr_misr; /* 0x10 - Command Register, Masked Interrupt Status Register */ unsigned int imr_isr; /* 0x14 - Interrupt Mask Register, Interrupt Status Register */ unsigned int ipr; /* 0x18 - Interrupt Programming Register */ unsigned int tfwr; /* 0x1C - Transmit FIFO Watermark Register */ unsigned int rfwr; /* 0x20 - Receive FIFO Watermark Register */ unsigned int hcr; /* 0x24 - Hunt Character Register */ unsigned char gap1[12]; /* 0x28 - gap */ unsigned int dmrx; /* 0x34 - RX transfer initialization */ unsigned int ncfrx_irda; /* 0x38 - Number of characters received since the end of last RX transfer, IRDA function Register */ unsigned int dmem; /* 0x3C - Data Mover Enable Register */ unsigned int ncftx; /* 0x40 - Number of characters for Transmission */ unsigned int badrr; /* 0x44 - RX FIFO Base Address */ unsigned char gap2[4]; /* 0x48 - gap */ unsigned int txfs; /* 0x4C - TX FIFO Status Register */ unsigned int rxfs; /* 0x50 - RX FIFO Status Register */ unsigned char gap3[28]; /* 0x54 - gap */ unsigned int rftf; /* 0x70 - UART Transmit and Receive FIFO Register */ };
Register definition bit at u-boot-2022.01/drivers/serial/serial_msm.c: #define UARTDM_MR1 0x00 #define UARTDM_MR2 0x04 #define UARTDM_DMRX 0x34 /* Max RX transfer length */ #define UARTDM_DMEN 0x3C /* DMA/data-packing mode */ #define UARTDM_NCF_TX 0x40 /* Number of chars to TX */ #define UARTDM_RXFS 0x50 /* RX channel status register */ #define UARTDM_ISR_TX_READY 0x80 /* TX FIFO empty */ #define UARTDM_CSR 0xA0 #define UARTDM_SR 0xA4 /* Status register */ #define UARTDM_CR 0xA8 /* Command register */ #define UARTDM_IMR 0xB0 /* Interrupt mask register */ #define UARTDM_ISR 0xB4 /* Interrupt status register */ #define UARTDM_TF 0x100 /* UART Transmit FIFO register */ #define UARTDM_RF 0x140 /* UART Receive FIFO register */
As you can see, for example: the working one's Transmit and Receive register definition is at an address of base + 0x70 while the current one's is at base + 0x100 and base + 0x140, so when the device is reading and sending things using current driver, they are doing it with wrong address and the serial won't work. I think this should be somehow fixed. Thanks.
On 3/19/22 09:22, Florence Riker wrote:
Hello everyone, recently I'm trying to port the newest version of u boot to my ipq4019 development board, and I found that the current serial driver for Qualcomm ipq40xx socs at u-boot-2022.01/drivers/serial/serial_msm.c is not compatible to ipq40xx despite they share the same compatible string in the device tree: [...] As you can see, for example: the working one's Transmit and Receive register definition is at an address of base + 0x70 while the current one's is at base + 0x100 and base + 0x140, so when the device is reading and sending things using current driver, they are doing it with wrong address and the serial won't work. I think this should be somehow fixed. Thanks.
I can confirm similar problem for newer qcom SoC sdm660, where I also had to use 0x70 for TF register, and 0x08 for SR register to make things work, so I don't think this is ipq40xx specific problem. Linux's serial-msm UARTDM driver is also using these values (different from what's in U-Boot driver).
It's hard to know the exact reason without full documentation for hw, but is it possible that there are two (or more) modes of operation and several register sets inside msm uartdm?
I'm also using u-boot as chain-loaded boot loader, so I'm using uart as it was configured by previous stage boot loader. Maybe which registers to use depends on how the controller was initially configured?
--- Regards, Alexey Minnekhanov
Alexey Minnekhanov
Florence Riker
