[PATCH v1] usb: kbd: destroy device after console is stopped
In case of IOMUX enabled it assumes that console devices in the list are available to get them stopped properly via ->stop() callback. However, the USB keyboard driver violates this assumption and tries to play tricks so the device get destroyed while being listed as an active console.
Swap the order of device deregistration and IOMUX update to avoid the use-after-free.
Fixes: 3cbcb2892809 ("usb: Fix usb_kbd_deregister when console-muxing is used") Fixes: 8a8348703081 ("dm: usb: Add a remove() method for USB keyboards") Reported-by: Nicolas Saenz Julienne nsaenzjulienne@suse.de Signed-off-by: Andy Shevchenko andriy.shevchenko@linux.intel.com --- v2: Nicolas, can you test this one instead of yours? common/usb_kbd.c | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/common/usb_kbd.c b/common/usb_kbd.c index b316807844b1..e09d9f7794c8 100644 --- a/common/usb_kbd.c +++ b/common/usb_kbd.c @@ -617,12 +617,12 @@ int usb_kbd_deregister(int force) if (dev) { usb_kbd_dev = (struct usb_device *)dev->priv; data = usb_kbd_dev->privptr; - if (stdio_deregister_dev(dev, force) != 0) - return 1; #if CONFIG_IS_ENABLED(CONSOLE_MUX) if (iomux_doenv(stdin, env_get("stdin")) != 0) return 1; #endif + if (stdio_deregister_dev(dev, force) != 0) + return 1; #ifdef CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE destroy_int_queue(usb_kbd_dev, data->intq); #endif @@ -660,16 +660,16 @@ static int usb_kbd_remove(struct udevice *dev) goto err; } data = udev->privptr; - if (stdio_deregister_dev(sdev, true)) { - ret = -EPERM; - goto err; - } #if CONFIG_IS_ENABLED(CONSOLE_MUX) if (iomux_doenv(stdin, env_get("stdin"))) { ret = -ENOLINK; goto err; } #endif + if (stdio_deregister_dev(sdev, true)) { + ret = -EPERM; + goto err; + } #ifdef CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE destroy_int_queue(udev, data->intq); #endif
Hi Andy,
Sadly this doesn't seem to work, and breaks a bunch of other tests in the process. You can try it yourself by running: './test/py/test.py --bd sandbox --build'
Regards, Nicolas
return 1;
return 1;
ret = -EPERM;
goto err;
ret = -EPERM;
goto err;
On Thu, Jan 28, 2021 at 06:19:56PM +0100, Nicolas Saenz Julienne wrote:
Hi Andy,
Thanks for trying.
Unfortunately I have unrelated bug somewhere: Traceback (most recent call last): File "/home/andy/prj/u-boot/./test/py/test.py", line 20, in <module> sys.exit(load_entry_point('pytest', 'console_scripts', 'pytest')(args)) TypeError: console_main() takes 0 positional arguments but 1 was given
Hi Andy,
Thanks for trying.
Seems test cases are broken in U-Boot. I'm not sure how you were able to run them.
Hi Andy,
Thanks for trying.
This is I guess what Heinrich was posting a patch for earlier today. The supported way to run the tests (so that they're the same for everyone) is to use "pip" and "pip install -r test/py/requirements.txt".
Hi Andy,
Thanks for trying.
My Gosh! It is full of package == version, which is simply awful. Can it be more flexible?
I hate this Python hell.
Hi Andy,
Thanks for trying.
It's intentional to follow the best practices of using python packages as best I can tell. CI doesn't mean so much if it's not repeatable and non-versioned packages mean that you can't be sure that running a test 6 months from now gives you what you get today on the same code base.
I agree on CI point, I disagree on end user's point of view. I have a distribution that has provided all required packages. Moreover, I have another (locally installed) packages that may require something else. The Py virtual environment maybe a way to solve this, but it's like an exploitation of the hi-tech laboratory to chop a firewood.
And as I told, it's not your fault, it's "best practices of using Py packages".
Hi Andy,
Thanks for trying.
Tom, any insights? Seems your patch changed the way how test.py works and something wrong happened meanwhile.
Hi Andy,
Now I'm able to run test cases. I see some of them failing even without my patch, but few definitely related. Can you give a list of failed ones on your side? I can compare that we are on the same page here.
Hi Andy,
Running this here on sandbox I get: FAILED test/py/tests/test_ut.py::test_ut[ut_dm_bootcount] - OSError: [Errno 5] Input/output ... FAILED test/py/tests/test_ut.py::test_ut[ut_dm_usb_flash] - OSError: [Errno 5] Input/output ... FAILED test/py/tests/test_ut.py::test_ut[ut_dm_usb_multi] - OSError: [Errno 5] Input/output ... FAILED test/py/tests/test_ut.py::test_ut[ut_dm_video_ansi] - OSError: [Errno 5] Input/output...
and those 4 are segfaults of sandbox.
Right, I have got the same. Thanks.
Actually it's a can of worms I have opened. I already see a mess with the console assignment between devices. I will check later how possibly to fix this (to some extent), today is almost midnight here...
Btw this is the wrong test case name printed. The real one which crashed is blk_usb (previous one to above mentioned). And it's failing only when you run either blk_usb or acpi_basic before (I haven't checked other permutations). Consider this as a bug report against tests.
Andy, Tony, Sorry for my late reply, but I got a bad cold.
Hi Andy,
This is what I'm seeing too.
Regards, Nicolas
I hope you are doing well.
Unfortunately I haven't heard from you lately, so I have decided to send out whatever I have as a patch series. You are Cc'ed on the last patch (it has prerequisites, so better to apply entire series for easy going).
That said, I have dropped the 'iomux' branch from my public tree.
Hi Andy,
Andy Shevchenko
Andy Shevchenko
