[RFC PATCH v3 0/5] imx8m: move env_get_location for imx8mn and imx8mp at board level
This series move env_get_location from soc to board level. As suggested by Michael michael@amarulasolutions.com make no sense to define an unique way for multiple board. One board can boot from emmc and having env on spi flash etc.. Anyways, this function is kept in imx8mn_evk, imx8mp_evk, phycore-imx8mp and imx8mn_beacon boards instead of being completely dropped.
Tommaso Merciai (5): imx8m: drop env_get_location for imx8mn and imx8mp imx: imx8mn_evk: override env_get_location imx: imx8mp_evk: override env_get_location beacon: imx8mn: override env_get_location in imx8mn_beacon.c phytec: phycore_imx8mp: override env_get_location in phycore-imx8mp.c
arch/arm/mach-imx/imx8m/soc.c | 39 -------------------- board/beacon/imx8mn/imx8mn_beacon.c | 35 +++++++++++++++++- board/freescale/imx8mn_evk/imx8mn_evk.c | 35 ++++++++++++++++++ board/freescale/imx8mp_evk/imx8mp_evk.c | 34 +++++++++++++++++ board/phytec/phycore_imx8mp/phycore-imx8mp.c | 33 +++++++++++++++++ 5 files changed, 136 insertions(+), 40 deletions(-)
This function defined for two architecture is not really generic and can generate problem when people add a new board.
Signed-off-by: Tommaso Merciai tomm.merciai@gmail.com --- arch/arm/mach-imx/imx8m/soc.c | 39 ----------------------------------- 1 file changed, 39 deletions(-)
diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index 863508776d..f0030a557a 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -1313,45 +1313,6 @@ void do_error(struct pt_regs *pt_regs, unsigned int esr) #endif
#if defined(CONFIG_IMX8MN) || defined(CONFIG_IMX8MP) -enum env_location env_get_location(enum env_operation op, int prio) -{ - enum boot_device dev = get_boot_device(); - enum env_location env_loc = ENVL_UNKNOWN; - - if (prio) - return env_loc; - - switch (dev) { -#ifdef CONFIG_ENV_IS_IN_SPI_FLASH - case QSPI_BOOT: - env_loc = ENVL_SPI_FLASH; - break; -#endif -#ifdef CONFIG_ENV_IS_IN_NAND - case NAND_BOOT: - env_loc = ENVL_NAND; - break; -#endif -#ifdef CONFIG_ENV_IS_IN_MMC - case SD1_BOOT: - case SD2_BOOT: - case SD3_BOOT: - case MMC1_BOOT: - case MMC2_BOOT: - case MMC3_BOOT: - env_loc = ENVL_MMC; - break; -#endif - default: -#if defined(CONFIG_ENV_IS_NOWHERE) - env_loc = ENVL_NOWHERE; -#endif - break; - } - - return env_loc; -} - #ifndef ENV_IS_EMBEDDED long long env_get_offset(long long defautl_offset) {
Hello Tommaso,
Am Samstag, dem 25.12.2021 um 21:25 +0100 schrieb Tommaso Merciai:
diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach- imx/imx8m/soc.c index 863508776d..f0030a557a 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -1313,45 +1313,6 @@ void do_error(struct pt_regs *pt_regs, unsigned int esr) #endif
- if (prio)
return env_loc;
- switch (dev) {
- case QSPI_BOOT:
break;
- case NAND_BOOT:
break;
- case SD1_BOOT:
- case SD2_BOOT:
- case SD3_BOOT:
- case MMC1_BOOT:
- case MMC2_BOOT:
- case MMC3_BOOT:
env_loc = ENVL_MMC;
break;
-#endif
- default:
-#endif
break;
- return env_loc;
would it not make sense to move also env_get_offset() to board level?
Regards, Teresa
Hi Teresa
On Tue, Jan 4, 2022 at 12:04 PM Teresa Remmet T.Remmet@phytec.de wrote:
Hello Tommaso,
if (prio)
return env_loc;
switch (dev) {
case QSPI_BOOT:
break;
case NAND_BOOT:
break;
case SD1_BOOT:
case SD2_BOOT:
case SD3_BOOT:
case MMC1_BOOT:
case MMC2_BOOT:
case MMC3_BOOT:
env_loc = ENVL_MMC;
break;
-#endif
default:
-#endif
break;
return env_loc;
Drop it in another patch. This is not reference in uboot
Michael
Regards, Teresa
-- PHYTEC Messtechnik GmbH | Robert-Koch-Str. 39 | 55129 Mainz, Germany
Geschäftsführer: Dipl.-Ing. Michael Mitezki, Dipl.-Ing. Bodo Huber | Handelsregister Mainz HRB 4656 | Finanzamt Mainz | St.Nr. 266500608, DE 149059855
Hello Michael,
Am Dienstag, dem 04.01.2022 um 12:06 +0100 schrieb Michael Nazzareno Trimarchi:
Hi Teresa
Hello Tommaso,
if (prio)
return env_loc;
switch (dev) {
case QSPI_BOOT:
break;
case NAND_BOOT:
break;
case SD1_BOOT:
case SD2_BOOT:
case SD3_BOOT:
case MMC1_BOOT:
case MMC2_BOOT:
case MMC3_BOOT:
env_loc = ENVL_MMC;
break;
-#endif
default:
-#endif
break;
return env_loc;
Ah thanks!
Teresa
Michael
Regards, Teresa
On Tue, Jan 04, 2022 at 11:04:10AM +0000, Teresa Remmet wrote:
Hello Tommaso,
- if (prio)
return env_loc;
- switch (dev) {
- case QSPI_BOOT:
break;
- case NAND_BOOT:
break;
- case SD1_BOOT:
- case SD2_BOOT:
- case SD3_BOOT:
- case MMC1_BOOT:
- case MMC2_BOOT:
- case MMC3_BOOT:
env_loc = ENVL_MMC;
break;
-#endif
- default:
-#endif
break;
- return env_loc;
Hi Teresa, I think is better to put this function at board level. In this way others boards that use i.MX8MN/i.MX8MM SOC can customize env_get_location function. For example: maybe one user want store U-Boot env on a device other than the boot device.
Tommaso
Regards, Teresa
Hello Tommaso,
Am Samstag, dem 08.01.2022 um 20:08 +0100 schrieb Tommaso Merciai:
Hello Tommaso,
- if (prio)
return env_loc;
- switch (dev) {
- case QSPI_BOOT:
break;
- case NAND_BOOT:
break;
- case SD1_BOOT:
- case SD2_BOOT:
- case SD3_BOOT:
- case MMC1_BOOT:
- case MMC2_BOOT:
- case MMC3_BOOT:
env_loc = ENVL_MMC;
break;
-#endif
- default:
-#endif
break;
- return env_loc;
Michael send a patch to remove the function. Which I missed. See: https://lore.kernel.org/u-boot/20211117143456.34441-1-michael@amarulasolutio...
So everything is fine then.
Thanks, Teresa
Tommaso
Regards, Teresa
On Tue, Jan 11, 2022 at 09:35:54AM +0000, Teresa Remmet wrote:
Hello Tommaso,
Hello Tommaso,
- if (prio)
return env_loc;
- switch (dev) {
- case QSPI_BOOT:
break;
- case NAND_BOOT:
break;
- case SD1_BOOT:
- case SD2_BOOT:
- case SD3_BOOT:
- case MMC1_BOOT:
- case MMC2_BOOT:
- case MMC3_BOOT:
env_loc = ENVL_MMC;
break;
-#endif
- default:
-#endif
break;
- return env_loc;
Thanks, Teresa
Hi Teresa, Perfect.
Thanks, Tommaso
Tommaso
Regards, Teresa
Override env_get_location function at board level, previously dropped down from soc.c
References: - commit 37d3e3bb95d7532e2503f115dd6c6762fd3b0262
Signed-off-by: Tommaso Merciai tomm.merciai@gmail.com --- Changes since v1: - Fix code indentation using checkpatch as suggested by MBehún
board/freescale/imx8mn_evk/imx8mn_evk.c | 35 +++++++++++++++++++++++++ 1 file changed, 35 insertions(+)
diff --git a/board/freescale/imx8mn_evk/imx8mn_evk.c b/board/freescale/imx8mn_evk/imx8mn_evk.c index 9a0a0488bf..ec1ab202a6 100644 --- a/board/freescale/imx8mn_evk/imx8mn_evk.c +++ b/board/freescale/imx8mn_evk/imx8mn_evk.c @@ -5,11 +5,46 @@
#include <common.h> #include <env.h> +#include <env_internal.h> #include <init.h> +#include <asm/arch/sys_proto.h> +#include <asm/mach-imx/boot_mode.h> #include <asm/global_data.h>
DECLARE_GLOBAL_DATA_PTR;
+enum env_location env_get_location(enum env_operation op, int prio) +{ + enum boot_device dev = get_boot_device(); + enum env_location env_loc = ENVL_UNKNOWN; + + if (prio) + return env_loc; + + if (IS_ENABLED(CONFIG_ENV_IS_IN_SPI_FLASH) && dev == QSPI_BOOT) { + env_loc = ENVL_SPI_FLASH; + } else if (IS_ENABLED(CONFIG_ENV_IS_IN_NAND) && dev == NAND_BOOT) { + env_loc = ENVL_NAND; + } else if (IS_ENABLED(CONFIG_ENV_IS_IN_MMC)) { + switch (dev) { + case SD1_BOOT: + case SD2_BOOT: + case SD3_BOOT: + case MMC1_BOOT: + case MMC2_BOOT: + case MMC3_BOOT: + env_loc = ENVL_MMC; + break; + default: + break; + } + } else if (IS_ENABLED(CONFIG_ENV_IS_NOWHERE)) { + env_loc = ENVL_MMC; + } + + return env_loc; +} + int board_init(void) { return 0;
board/freescale/imx8mp_evk/imx8mp_evk.c | 34 +++++++++++++++++++++++++ 1 file changed, 34 insertions(+)
diff --git a/board/freescale/imx8mp_evk/imx8mp_evk.c b/board/freescale/imx8mp_evk/imx8mp_evk.c index 62096c24fb..8548f606d2 100644 --- a/board/freescale/imx8mp_evk/imx8mp_evk.c +++ b/board/freescale/imx8mp_evk/imx8mp_evk.c @@ -5,6 +5,7 @@
#include <common.h> #include <env.h> +#include <env_internal.h> #include <errno.h> #include <init.h> #include <miiphy.h> @@ -17,6 +18,7 @@ #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> #include <asm/mach-imx/gpio.h> +#include <asm/mach-imx/boot_mode.h>
@@ -32,6 +34,38 @@ static iomux_v3_cfg_t const wdog_pads[] = { MX8MP_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), };
+enum env_location env_get_location(enum env_operation op, int prio) +{ + enum boot_device dev = get_boot_device(); + enum env_location env_loc = ENVL_UNKNOWN; + + if (prio) + return env_loc; + + if (IS_ENABLED(CONFIG_ENV_IS_IN_SPI_FLASH) && dev == QSPI_BOOT) { + env_loc = ENVL_SPI_FLASH; + } else if (IS_ENABLED(CONFIG_ENV_IS_IN_NAND) && dev == NAND_BOOT) { + env_loc = ENVL_NAND; + } else if (IS_ENABLED(CONFIG_ENV_IS_IN_MMC)) { + switch (dev) { + case SD1_BOOT: + case SD2_BOOT: + case SD3_BOOT: + case MMC1_BOOT: + case MMC2_BOOT: + case MMC3_BOOT: + env_loc = ENVL_MMC; + break; + default: + break; + } + } else if (IS_ENABLED(CONFIG_ENV_IS_NOWHERE)) { + env_loc = ENVL_MMC; + } + + return env_loc; +} + int board_early_init_f(void) { struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR;
Override env_get_location function at board level, previously dropped down from arch/arm/mach-imx/imx8m/soc.c
Signed-off-by: Tommaso Merciai tomm.merciai@gmail.com --- board/beacon/imx8mn/imx8mn_beacon.c | 35 ++++++++++++++++++++++++++++- 1 file changed, 34 insertions(+), 1 deletion(-)
diff --git a/board/beacon/imx8mn/imx8mn_beacon.c b/board/beacon/imx8mn/imx8mn_beacon.c index 7fe252b262..05ab5613ee 100644 --- a/board/beacon/imx8mn/imx8mn_beacon.c +++ b/board/beacon/imx8mn/imx8mn_beacon.c @@ -6,14 +6,47 @@ #include <common.h> #include <miiphy.h> #include <netdev.h> - +#include <env_internal.h> #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> +#include <asm/mach-imx/boot_mode.h> #include <asm/global_data.h> #include <asm/io.h>
+enum env_location env_get_location(enum env_operation op, int prio) +{ + enum boot_device dev = get_boot_device(); + enum env_location env_loc = ENVL_UNKNOWN; + + if (prio) + return env_loc; + + if (IS_ENABLED(CONFIG_ENV_IS_IN_SPI_FLASH) && dev == QSPI_BOOT) { + env_loc = ENVL_SPI_FLASH; + } else if (IS_ENABLED(CONFIG_ENV_IS_IN_NAND) && dev == NAND_BOOT) { + env_loc = ENVL_NAND; + } else if (IS_ENABLED(CONFIG_ENV_IS_IN_MMC)) { + switch (dev) { + case SD1_BOOT: + case SD2_BOOT: + case SD3_BOOT: + case MMC1_BOOT: + case MMC2_BOOT: + case MMC3_BOOT: + env_loc = ENVL_MMC; + break; + default: + break; + } + } else if (IS_ENABLED(CONFIG_ENV_IS_NOWHERE)) { + env_loc = ENVL_MMC; + } + + return env_loc; +} + #if IS_ENABLED(CONFIG_FEC_MXC) static int setup_fec(void) {
On Sat, Dec 25, 2021 at 8:26 PM Tommaso Merciai tomm.merciai@gmail.com wrote:
References:
I am traveling, so I can't test this. However, I question why not make the function __weak and leave it where it was, so we don't have to copy this code from board to board. For those who need something that differs from this, they can write their own function which will replace the standard version.
adam
if (prio)
return env_loc;
switch (dev) {
case SD1_BOOT:
case SD2_BOOT:
case SD3_BOOT:
case MMC1_BOOT:
case MMC2_BOOT:
case MMC3_BOOT:
env_loc = ENVL_MMC;
break;
default:
break;
env_loc = ENVL_MMC;
return env_loc;
#if IS_ENABLED(CONFIG_FEC_MXC) static int setup_fec(void) { -- 2.25.1
References:
adam
Hi Adam, Thanks for your reply. env_get_location function is already declared (__weak) in:
- env/env.c
Override 2 times the same function, is that correct?
I think can be a good solution too, declare it as __weak in soc.c and override it at board level.
Some References: - https://developer.arm.com/documentation/dui0491/i/Compiler-specific-Features...
Let me know.
Thanks, Tommaso
if (prio)
return env_loc;
switch (dev) {
case SD1_BOOT:
case SD2_BOOT:
case SD3_BOOT:
case MMC1_BOOT:
case MMC2_BOOT:
case MMC3_BOOT:
env_loc = ENVL_MMC;
break;
default:
break;
env_loc = ENVL_MMC;
return env_loc;
On Sun, Dec 26, 2021 at 11:17 AM Tommaso Merciai tomm.merciai@gmail.com wrote:
References:
the
adam
- env/env.c
I didn't know it was already _weak. I am not sure it can be done in two places. i'm traveling, so i dont have the source code to review it.
Some References:
Let me know.
Thanks, Tommaso
if (prio)
return env_loc;
QSPI_BOOT) {
NAND_BOOT) {
switch (dev) {
case SD1_BOOT:
case SD2_BOOT:
case SD3_BOOT:
case MMC1_BOOT:
case MMC2_BOOT:
case MMC3_BOOT:
env_loc = ENVL_MMC;
break;
default:
break;
env_loc = ENVL_MMC;
return env_loc;
References:
the
adam
- env/env.c
No problem. Take your time.
Thanks, Tommaso
Some References:
Let me know.
Thanks, Tommaso
if (prio)
return env_loc;
QSPI_BOOT) {
NAND_BOOT) {
switch (dev) {
case SD1_BOOT:
case SD2_BOOT:
case SD3_BOOT:
case MMC1_BOOT:
case MMC2_BOOT:
case MMC3_BOOT:
env_loc = ENVL_MMC;
break;
default:
break;
env_loc = ENVL_MMC;
return env_loc;
On Sat, Dec 25, 2021 at 2:26 PM Tommaso Merciai tomm.merciai@gmail.com wrote:
References:
I am going to re-do the patch for the beacon board, because I talked it over with my colleagues, and we'd like to force the environment to one location or another and not base it on whether or not it was the boot device.
I guess my questions is what's the status of the remaining patch series, and how do I integrate my desired changes into it? I can send you what I want for my board if you're going to resubmit the series. I wonder if a sub-function could be called where the existing env_get_location() is renamed to something else, but declared as weak can called from env_get_location. Anyone who wants a their own function can write their own so we don't have two functions with the same name declared as weak.
What are your thoughts on that?
adam
if (prio)
return env_loc;
switch (dev) {
case SD1_BOOT:
case SD2_BOOT:
case SD3_BOOT:
case MMC1_BOOT:
case MMC2_BOOT:
case MMC3_BOOT:
env_loc = ENVL_MMC;
break;
default:
break;
env_loc = ENVL_MMC;
return env_loc;
References:
Hi Adam,
It's ok for me. Send me your changes. Thanks.
Right. In this way every boards that use imx8mp/imx8mn can override this function according to their own needs.
Tommaso
adam
if (prio)
return env_loc;
switch (dev) {
case SD1_BOOT:
case SD2_BOOT:
case SD3_BOOT:
case MMC1_BOOT:
case MMC2_BOOT:
case MMC3_BOOT:
env_loc = ENVL_MMC;
break;
default:
break;
env_loc = ENVL_MMC;
return env_loc;
On Wed, Jan 26, 2022 at 2:58 PM Tommaso Merciai tomm.merciai@gmail.com wrote:
References:
Hi Adam,
After trying some different options, I wonder if we can just delete env_get_location() completely from arch/arm/mach-imx/imx8m/soc.c.
For my board, it does exactly what I want when I delete that function since the default from env.c is sufficient. I think it's probably safest to use your original approach to move them to individual board files with the idea that some people may not need it at all. When placed into their board files, they can choose what they want for themselves.
I would suggest sending a patch without the RFC and place the function into the various imx8mn and imx8mp boards, but know that you can skip the beacon board. I would also suggest that you add a note that people should test this to see if it's really what they want or if they can live without the code and fall back on the default.
adam
Tommaso
adam
if (prio)
return env_loc;
switch (dev) {
case SD1_BOOT:
case SD2_BOOT:
case SD3_BOOT:
case MMC1_BOOT:
case MMC2_BOOT:
case MMC3_BOOT:
env_loc = ENVL_MMC;
break;
default:
break;
env_loc = ENVL_MMC;
return env_loc;
Hi
References:
Hi Adam,
Totally agree. I sent patches to remove in the beginning. That function must be removed
Michael
adam
Tommaso
adam
if (prio)
return env_loc;
switch (dev) {
case SD1_BOOT:
case SD2_BOOT:
case SD3_BOOT:
case MMC1_BOOT:
case MMC2_BOOT:
case MMC3_BOOT:
env_loc = ENVL_MMC;
break;
default:
break;
env_loc = ENVL_MMC;
return env_loc;
References:
Hi Adam,
Hi Adam,
Ack.
Ok, I'll send v4 of the series (without RFC label) in these days.
Thanks, Tommaso
adam
Tommaso
adam
if (prio)
return env_loc;
switch (dev) {
case SD1_BOOT:
case SD2_BOOT:
case SD3_BOOT:
case MMC1_BOOT:
case MMC2_BOOT:
case MMC3_BOOT:
env_loc = ENVL_MMC;
break;
default:
break;
env_loc = ENVL_MMC;
return env_loc;
Signed-off-by: Tommaso Merciai tomm.merciai@gmail.com --- board/phytec/phycore_imx8mp/phycore-imx8mp.c | 33 ++++++++++++++++++++ 1 file changed, 33 insertions(+)
diff --git a/board/phytec/phycore_imx8mp/phycore-imx8mp.c b/board/phytec/phycore_imx8mp/phycore-imx8mp.c index a8f0821437..05926eefa3 100644 --- a/board/phytec/phycore_imx8mp/phycore-imx8mp.c +++ b/board/phytec/phycore_imx8mp/phycore-imx8mp.c @@ -11,9 +11,42 @@ #include <asm/mach-imx/boot_mode.h> #include <env.h> #include <miiphy.h> +#include <env_internal.h>
+enum env_location env_get_location(enum env_operation op, int prio) +{ + enum boot_device dev = get_boot_device(); + enum env_location env_loc = ENVL_UNKNOWN; + + if (prio) + return env_loc; + + if (IS_ENABLED(CONFIG_ENV_IS_IN_SPI_FLASH) && dev == QSPI_BOOT) { + env_loc = ENVL_SPI_FLASH; + } else if (IS_ENABLED(CONFIG_ENV_IS_IN_NAND) && dev == NAND_BOOT) { + env_loc = ENVL_NAND; + } else if (IS_ENABLED(CONFIG_ENV_IS_IN_MMC)) { + switch (dev) { + case SD1_BOOT: + case SD2_BOOT: + case SD3_BOOT: + case MMC1_BOOT: + case MMC2_BOOT: + case MMC3_BOOT: + env_loc = ENVL_MMC; + break; + default: + break; + } + } else if (IS_ENABLED(CONFIG_ENV_IS_NOWHERE)) { + env_loc = ENVL_MMC; + } + + return env_loc; +} + static int setup_fec(void) { struct iomuxc_gpr_base_regs *gpr =
Hello Tommaso,
thank you for working on this.
References:
- if (prio)
return env_loc;
- if (IS_ENABLED(CONFIG_ENV_IS_IN_SPI_FLASH) && dev == QSPI_BOOT)
- } else if (IS_ENABLED(CONFIG_ENV_IS_IN_NAND) && dev ==
NAND_BOOT) {
For phyCORE-i.MX8MP board code you could just remove the NAND part. As there is no NAND flash available on the hardware.
Thanks, Teresa
- } else if (IS_ENABLED(CONFIG_ENV_IS_IN_MMC)) {
switch (dev) {
case SD1_BOOT:
case SD2_BOOT:
case SD3_BOOT:
case MMC1_BOOT:
case MMC2_BOOT:
case MMC3_BOOT:
env_loc = ENVL_MMC;
break;
default:
break;
- } else if (IS_ENABLED(CONFIG_ENV_IS_NOWHERE)) {
env_loc = ENVL_MMC;
- return env_loc;
Adam Ford
Teresa Remmet
Tommaso Merciai
