[U-Boot] [PATCH] cmd: ximg: Invert check for fit image compression
The imgextract command runs a number of checks of the specified fit. Where it checks for a load address for compressed images the logic in the expression is inverted as fit_image_check_comp returns 1 on success and not 0. --- cmd/ximg.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/ximg.c b/cmd/ximg.c index 6880c747f5..8572a67a00 100644 --- a/cmd/ximg.c +++ b/cmd/ximg.c @@ -143,7 +143,7 @@ do_imgextract(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) return 1; }
- if (fit_image_check_comp(fit_hdr, noffset, IH_COMP_NONE) + if (!fit_image_check_comp(fit_hdr, noffset, IH_COMP_NONE) && (argc < 4)) { printf("Must specify load address for %s command " "with compressed image\n",
Stefan Theil
