[U-Boot-Users] Intel Flash CFI initialisation failure
Dear All,
I am having the problem with Intel Flash TE28F640 J3C120 on my avnet evaluation board (xilinx based with Virtex-4). I have compiled successfully u-boot-1.2.0 and it run well without FLASH support. Eventually I want to store u-boot in Flash but when I compile u-boot with Flash support the u-boot fails during Flash initialization.
My Flash memory is: type: TE28F640 J3C120 (http://www.datasheets.org.uk/datasheet.php?article=3266188) vendor: Intel spec: NOR FLASH 64 Blocks 64 Mbits x8/x16
To support Flash memory I have configured u-boot with the following settings:
#define CFG_FLASH_BASE 0xFF800000 #define CFG_MAX_FLASH_BANKS 1 #define CFG_MAX_FLASH_SECT 64 #define CFG_FLASH_CFI 1 #define CFG_FLASH_CFI_DRIVER 1
The u-boot was compiled successfully but when I booted it I have got the error messages when it came to the Flash initialization:
U-Boot 1.2.0 (Sep 6 2007 - 17:56:34)
### No HW ID - assuming ML403 DRAM: 32 MB Top of RAM usable for U-Boot at: 02000000 Reserving 138k for U-Boot at: 01fdd000 Reserving 129k for malloc() at: 01fbcc00 Reserving 120 Bytes for Board Info at: 01fbcb88 Reserving 48 Bytes for Global Data at: 01fbcb58 Stack Pointer at: 01fbcb38 New Stack Pointer is: 01fbcb38 Now running in RAM - U-Boot at: 01fdd000 FLASH: flash detect cfi fwc addr ff800000 cmd 0 0 8bit x 8 bit fwc addr ff800055 cmd 98 98 8bit x 8 bit is= cmd 51(Q) addr ff800010 is= 0 51 fwc addr ff800555 cmd 98 98 8bit x 8 bit is= cmd 51(Q) addr ff800010 is= 0 51 fwc addr ff800000 cmd 0 0000 16bit x 8 bit fwc addr ff8000aa cmd 98 9898 16bit x 8 bit is= cmd 51(Q) addr ff800020 is= 0051 5151 fwc addr ff800aaa cmd 98 9898 16bit x 8 bit is= cmd 51(Q) addr ff800020 is= 0051 5151 fwc addr ff800000 cmd 0 0000 16bit x 16 bit fwc addr ff8000aa cmd 98 0098 16bit x 16 bit is= cmd 51(Q) addr ff800020 is= 0051 0051 is= cmd 52(R) addr ff800022 is= 0052 0052 is= cmd 59(Y) addr ff800024 is= 0059 0059 ushort addr is at ff800050 info->portwidth = 2 addr[0] = 0x0 addr[1] = 0x2 addr[2] = 0x0 addr[3] = 0x0 retval = 0x2 device interface is 2 found port 2 chip 2 port 16 bits chip 16 bits ushort addr is at ff800026 info->portwidth = 2 addr[0] = 0x0 addr[1] = 0x1 addr[2] = 0x0 addr[3] = 0x0 retval = 0x1 fwc addr ff800000 cmd ff 00ff 16bit x 16 bit fwc addr ff800000 cmd 90 0090 16bit x 16 bit fwc addr ff800000 cmd ff 00ff 16bit x 16 bit fwc addr ff8000aa cmd 98 0098 16bit x 16 bit ushort addr is at ff80002a info->portwidth = 2 addr[0] = 0x0 addr[1] = 0x31 addr[2] = 0x0 addr[3] = 0x0 retval = 0x31 ff800020 : 00 51 00 52 00 59 00 01 00 00 00 31 00 00 00 00 .Q.R.Y.....1.... ff800030 : 00 00 00 00 00 00 00 27 00 36 00 00 00 00 00 08 .......'.6...... ff800040 : 00 08 00 0b 00 00 00 02 00 02 00 03 00 00 00 17 ................ ff800050 : 00 02 00 00 00 05 00 00 00 01 00 3f 00 00 00 00 ...........?.... ff800060 : 00 02 00 50 00 52 00 49 00 31 00 31 00 ce 00 00 ...P.R.I.1.1.... ff800070 : 00 00 00 00 00 01 00 01 00 00 00 33 00 00 00 01 ...........3.... ff800080 : 00 80 00 00 00 03 00 03 00 03 00 00 00 00 00 00 ................ ff800090 : ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................ manufacturer is 1 manufacturer id is 0x89 device id is 0x17 device id2 is 0x0 cfi version is 0x3131 size_ratio 1 port 16 bits chip 16 bits found 1 erase regions long addr is at ff80005a info->portwidth = 2 addr[0] = 0x0 addr[1] = 0x3f addr[2] = 0x0 addr[3] = 0x0 addr[4] = 0x0 addr[5] = 0x0 addr[6] = 0x0 addr[7] = 0x2 erase_region_count = 64 erase_region_size = 131072 Bus Fault @ 0x01fe4424, fixup 0x00000000 Machine check in kernel mode. Caused by (from msr): regs 01fbc978 Data parity signal NIP: 01FE4424 XER: 20000000 LR: 01FE43D8 REGS: 01fbc978 TRAP: 0200 DAR: 00000000MSR: 00021000 EE: 0 PR: 0 FP: 0 ME: 1 IR/DR: 00
GPR00: 00000000 01FBCA68 C01FC950 01FFF8D0 00000001 01FBCA70 00000001 00000006 GPR08: 00000000 FFC00004 01FBCA73 00000003 01FBC860 30000000 02001600 00000000 GPR16: 00020000 00000001 0000002D 00000000 00000020 00000040 0000002D FFC20000 GPR24: 01FFF950 00000001 00000020 00000004 01FFF8D0 01FBCB58 02001A94 FFC00000 Call backtrace: machine check NIP: FFFFFFFC XER: 00000000 LR: 01FED864 REGS: 01fbc868 TRAP: 0700 DAR: 00000001MSR: 00000000 EE: 0 PR: 0 FP: 0 ME: 0 IR/DR: 00
Does anybody have an idea what could be wrong?
Best Regards
Mirek
============================================================================= Miroslaw Dach (Miroslaw.Dach@psi.ch) - SLS/Controls Group PSI - Paul Scherrer Institut CH-5232 Villigen =============================================================================
In message Pine.LNX.4.44.0709071639130.13688-100000@slslc02.psi.ch you wrote:
Why are you posting the same stuff twice here? Please don't do that,
Hi Wolfgang,
I have sent the same post twice since first time when I have tried to send it via: www.nabble.com it was not accepted by the lists.sourceforge.net. I have verified it on the lists.sourceforge.net web page and it indeed was not there so I have tried to send it directly.
Best Regards
Mirek
Dear All,
After some tests I have found out few things which caused the problem with my Flash:
1. The erase_region_size variable gets twice bigger number (ie. 131072 instead of 65536) than it should:
File: ./drivers/cfi_flash.c function: flash_get_size(ulong base, int banknum)
erase_region_size = (tmp & 0xffff) ? ((tmp & 0xffff) * 256) : 128;
When I reduced the erase_region_size by 2 the u-boot initialization went to the successful end. Next What I did I have tried to read, write and erase memory/sectors. The Read/erase function worked fine but when writing to the memory I have got a time out:
---------------- u-boot output -------------------------------- => flinfo
Bank # 1: CFI conformant FLASH (16 x 16) Size: 8 MB in 64 Sectors Intel Extended command set, Manufacturer ID: 0x89, Device ID: 0x17 Erase timeout: 16384 ms, write timeout: 2 ms Buffer write timeout: 2 ms, buffer size: 32 bytes
=> cp.w 0x400000 FF860000 0x49 Copy to Flash... fwc addr ff860000 cmd 50 0050 16bit x 16 bit fwc addr ff860000 cmd e8 00e8 16bit x 16 bit flash_is_busy: 0 fwc addr ff860000 cmd f 000f 16bit x 16 bit fwc addr ff860000 cmd d0 00d0 16bit x 16 bit flash_is_busy: 1 long addr is at ff860000 info->portwidth = 2 addr[0] = 0x0 addr[1] = 0x80 addr[2] = 0x0 addr[3] = 0x80 addr[4] = 0x0 addr[5] = 0x80 addr[6] = 0x0 addr[7] = 0x80 Flash buffer write timeout at address ff860000 data 80808080 fwc addr ff860000 cmd ff 00ff 16bit x 16 bit fwc addr ff860000 cmd ff 00ff 16bit x 16 bit Timeout writing to Flash
I thought that maybe it is set wrongly the processor speed so I have set in the include/configs/ml403.h #define CONFIG_SYS_CLK_FREQ 100000000
since my PPC405 works with the frequency 100 MHZ but unfortunately it did not help so I have modified in the:
File: ./drivers/cfi_flash.c function: flash_status_check( )
tout *= 10;
The factor 10 was obtained after some experiments. The time passage when booting u-boot is roughly speaking fine since the count down from 10 - 0 sec. reflect this what I measure with normal watch so the timeout problem refers to something else?
3. My third observation is that when I refer to the wrong memory location (ie. md 0x2000000 which is beyond RAM or Flash) than u-boot crashes and I get:
=> md 0x2000000 02000000:Bus Fault @ 0x01fe84b0, fixup 0x00000000 Machine check in kernel mode. Caused by (from msr): regs 01fbc620 Data parity signal NIP: 01FE84B0 XER: 20000000 LR: 01FE8480 REGS: 01fbc620 TRAP: 0200 DAR: 00000004 MSR: 00029000 EE: 1 PR: 0 FP: 0 ME: 1 IR/DR: 00
GPR00: 01FE8480 01FBC710 C01FC950 00000000 00000000 00000010 00000001 00000007 GPR08: 00000001 40600004 00000000 01FBC4D6 01FBC4D8 30000000 02000F00 017DD000
Is it somehow possible to restrict in u-boot memory regions which are valid for RAM and Flash and reject other regions.
Best Regards
Mirek
Hi All,
Unfortunately I did not solve completely the problem which I had with the Flash memory. It seems to be that in u-boot there is a problem with 16 bits long data access.
My memory has the size of 64 Mbits. In my configuration it should be accessed in x16 bits mode so it means that under each memory location there are 16 bits. In u-boot it seems to be that all is seen in bytes and under one memory location there is seen only one byte instead of two.
Is it somehow possible to change that by some define statements?
Best Regards
Mirek
Miroslaw Dach wrote:
Hi All,
Best Regards
Mirek
Trying to understand, are you saying your hardware has the CFI flash hooked up 16 bits wide on 32 bit boundaries (every 32 bit word has 16 bits of garbage and 16 bits of CFI flash data)?
Thanks, gvb
Hi Jerry,
I use Intel Flash CFI compliant and it has two modes of operation x8/x16. The hardware is configured to operate in x16 mode so it means that under each address there are 16 bits. In u-boot it seems to be only 8 bits visible/visible.
Best Regards
Mirek
Hi Mirek,
Perhaps the board has LA[n:31] connected to the address bus of the Flash rather than the correct LA[n:30] signals.
If so, its a hardware error, and there is not much you can do. Even if the chip has a BYTE# pin you can change modes with, a 16-bit Flash usually has a DQ15/A-1 pin that LA[31] would then connect to.
Just a thought ...
Cheers, Dave
David Hawkins
Jerry Van Baren
Miroslaw Dach
