[U-Boot] [PATCH v2 0/5] ARM: DRA7: AM57xx: Enable SPL_DM
- Enable SPL_DM on all DRA7 and AM57xx based platforms. - SPL uses a generic dts on all platforms with same defconfig. - After this series SPL size is increased by ~8KB.
Verified MMC, eMMC boot on DRA74-evm, DRA72-evm. MMC boot on AM57xx-evm.
Changes since v1: - Instead of creating a new dts file for each platform, created a omap5 specific common dtsi that will be included automatically.
Lokesh Vutla (5): tools: omapimage: Fix size in header ARM: OMAP2+: define _image_binary_end to fix SPL_OF_CONTROL ARM: dts: OMAP5+: Add u-boot specific dtsi configs: am57xx_evm: Enable SPL_DM configs: dra7xx_evm: Enable SPL_DM
arch/arm/dts/omap5-u-boot.dtsi | 46 ++++++++++++++++++++++++++++++++++++++ arch/arm/mach-omap2/u-boot-spl.lds | 2 ++ configs/am57xx_evm_defconfig | 7 ++++-- configs/am57xx_hs_evm_defconfig | 5 ++++- configs/dra7xx_evm_defconfig | 5 ++++- configs/dra7xx_hs_evm_defconfig | 5 ++++- include/configs/am57xx_evm.h | 5 ----- include/configs/dra7xx_evm.h | 5 ----- include/configs/ti_omap5_common.h | 8 +------ tools/gpimage.c | 2 +- tools/omapimage.c | 2 +- 11 files changed, 68 insertions(+), 24 deletions(-) create mode 100644 arch/arm/dts/omap5-u-boot.dtsi
The size field in GP header that is expected by ROM is size of the image + size of the header. But omapimage generates a gp header only with size of the image as size field. Fix it
Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- tools/gpimage.c | 2 +- tools/omapimage.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/tools/gpimage.c b/tools/gpimage.c index 1adc55c5fc..3ae511d33e 100644 --- a/tools/gpimage.c +++ b/tools/gpimage.c @@ -54,7 +54,7 @@ static void gpimage_set_header(void *ptr, struct stat *sbuf, int ifd, { struct gp_header *gph = (struct gp_header *)ptr;
- gph_set_header(gph, sbuf->st_size - GPIMAGE_HDR_SIZE, params->addr, 1); + gph_set_header(gph, sbuf->st_size, params->addr, 1); }
/* diff --git a/tools/omapimage.c b/tools/omapimage.c index 7198b3330d..4fe62c5b31 100644 --- a/tools/omapimage.c +++ b/tools/omapimage.c @@ -143,7 +143,7 @@ static void omapimage_set_header(void *ptr, struct stat *sbuf, int ifd, toc++; memset(toc, 0xff, sizeof(*toc));
- gph_set_header(gph, sbuf->st_size - OMAP_FILE_HDR_SIZE, + gph_set_header(gph, sbuf->st_size - OMAP_CH_HDR_SIZE, params->addr, 0);
if (strncmp(params->imagename, "byteswap", 8) == 0) {
To make SPL_OF_CONTROL work on OMAP2+ SoCs, _image_binary_end must be defined in the linker script along with CONFIG_SPL_SEPARATE_BSS.
Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/mach-omap2/u-boot-spl.lds | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/mach-omap2/u-boot-spl.lds b/arch/arm/mach-omap2/u-boot-spl.lds index 8fec715ca5..e9da2a9dd1 100644 --- a/arch/arm/mach-omap2/u-boot-spl.lds +++ b/arch/arm/mach-omap2/u-boot-spl.lds @@ -46,6 +46,8 @@ SECTIONS *(.__end) }
+ _image_binary_end = .; + .bss : { . = ALIGN(4);
Add u-boot specific dtsi so that this will be included automatically while building dts.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/dts/omap5-u-boot.dtsi | 46 ++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 46 insertions(+) create mode 100644 arch/arm/dts/omap5-u-boot.dtsi
diff --git a/arch/arm/dts/omap5-u-boot.dtsi b/arch/arm/dts/omap5-u-boot.dtsi new file mode 100644 index 0000000000..cd37ec4fe8 --- /dev/null +++ b/arch/arm/dts/omap5-u-boot.dtsi @@ -0,0 +1,46 @@ +/* + * Copyright (C) 2017 Texas Instruments Incorporated - http://www.ti.com/ + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * Based on "dra7.dtsi" + */ + +/{ + ocp { + u-boot,dm-pre-reloc; + }; +}; + +&uart1 { + u-boot,dm-pre-reloc; +}; + +&uart3 { + u-boot,dm-pre-reloc; +}; + +&mmc1 { + u-boot,dm-pre-reloc; +}; + +&mmc2 { + u-boot,dm-pre-reloc; +}; + +&l4_wkup { + u-boot,dm-pre-reloc; +}; + +&scm_wkup { + u-boot,dm-pre-reloc; +}; + +&qspi { + u-boot,dm-pre-reloc; + + m25p80@0 { + u-boot,dm-pre-reloc; + }; +};
As I said earlier, I see a problem with this approach. We want this omap5-u-boot.dtsi only for SPL. But Makefile.lib tries to append this for each dtb in proper U-Boot as well. As we might not need any of these in U-Boot before relocation, the behavior is unexpected(sometimes U-boot does not comes up ). I would like to go ahead with V1 of this series, what do you say?
Thanks and regards, Lokesh
All of the other platforms are able to have pre-reloc on nodes without issue, can you describe what's going on a bit more? Simon, any ideas? Thanks!
So, when more nodes were added with pre-reloc, dm_scan_fdt() is failing with NOMEM. Then I realized that SYS_MALLOC_F_LEN is 0x400 which is very less. Increased the length to 0x2000 and everything working fine. Sorry for the noise :) Will be posting an updated series soon.
Enable SPL_DM on all AM57xx based platforms.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- configs/am57xx_evm_defconfig | 7 +++++-- configs/am57xx_hs_evm_defconfig | 5 ++++- include/configs/am57xx_evm.h | 5 ----- 3 files changed, 9 insertions(+), 8 deletions(-)
diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index e804b02c1e..50717ba65c 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -6,7 +6,7 @@ CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_ARMV7_LPAE=y CONFIG_SPL_STACK_R_ADDR=0x82000000 -CONFIG_DEFAULT_DEVICE_TREE="am57xx-beagle-x15" +CONFIG_DEFAULT_DEVICE_TREE="am572x-idk" CONFIG_FIT=y CONFIG_SPL_LOAD_FIT=y CONFIG_OF_BOARD_SETUP=y @@ -14,7 +14,9 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y +CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y @@ -52,8 +54,10 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am572x-idk am571x-idk" CONFIG_DM=y +CONFIG_SPL_DM=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y @@ -87,4 +91,3 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 -CONFIG_SPL_OF_LIBFDT=y diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index 7e84ccddf3..be84f06cee 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -19,7 +19,9 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y +CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_FASTBOOT=y @@ -55,7 +57,9 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y CONFIG_DM=y +CONFIG_SPL_DM=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y @@ -85,4 +89,3 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 -CONFIG_SPL_OF_LIBFDT=y diff --git a/include/configs/am57xx_evm.h b/include/configs/am57xx_evm.h index 3d8b996054..9883c9545a 100644 --- a/include/configs/am57xx_evm.h +++ b/include/configs/am57xx_evm.h @@ -121,11 +121,6 @@ #define CONFIG_SYS_SPI_ARGS_OFFS 0x140000 #define CONFIG_SYS_SPI_ARGS_SIZE 0x80000
-#ifdef CONFIG_SPL_BUILD -#undef CONFIG_DM_SPI -#undef CONFIG_DM_SPI_FLASH -#endif - /* SPI SPL */ #define CONFIG_TI_EDMA3 #define CONFIG_SPL_SPI_LOAD
Did you really want to change the default tree?
Yeah, I make this as default as it contains peripherals for all boot modes.
OK, thanks.
Enable SPL_DM on all DRA7 based platforms.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- configs/dra7xx_evm_defconfig | 5 ++++- configs/dra7xx_hs_evm_defconfig | 5 ++++- include/configs/dra7xx_evm.h | 5 ----- include/configs/ti_omap5_common.h | 8 +------- 4 files changed, 9 insertions(+), 14 deletions(-)
diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 26b26cc4cd..8a2b68c417 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -14,7 +14,9 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y +CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_SPL_OS_BOOT=y CONFIG_HUSH_PARSER=y @@ -52,8 +54,10 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIST="dra7-evm dra72-evm dra72-evm-revc dra71-evm" CONFIG_DM=y +CONFIG_SPL_DM=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y @@ -96,4 +100,3 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 -CONFIG_SPL_OF_LIBFDT=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 244940cd6c..12f2c3a786 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -20,7 +20,9 @@ CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SPL=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y +CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_DMA_SUPPORT=y CONFIG_HUSH_PARSER=y CONFIG_FASTBOOT=y @@ -57,8 +59,10 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIST="dra7-evm dra72-evm dra72-evm-revc dra71-evm" CONFIG_DM=y +CONFIG_SPL_DM=y # CONFIG_BLK is not set CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y @@ -101,4 +105,3 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Texas Instruments" CONFIG_G_DNL_VENDOR_NUM=0x0451 CONFIG_G_DNL_PRODUCT_NUM=0xd022 -CONFIG_SPL_OF_LIBFDT=y diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index bf8c041fb7..827d076e76 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -123,11 +123,6 @@ #define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #define CONFIG_QSPI_QUAD_SUPPORT
-#ifdef CONFIG_SPL_BUILD -#undef CONFIG_DM_SPI -#undef CONFIG_DM_SPI_FLASH -#endif - /* * Default to using SPI for environment, etc. * 0x000000 - 0x040000 : QSPI.SPL (256KiB) diff --git a/include/configs/ti_omap5_common.h b/include/configs/ti_omap5_common.h index 37d65653a5..8f65c2242f 100644 --- a/include/configs/ti_omap5_common.h +++ b/include/configs/ti_omap5_common.h @@ -45,7 +45,7 @@ * Hardware drivers */ #define CONFIG_SYS_NS16550_CLK 48000000 -#if defined(CONFIG_SPL_BUILD) || !defined(CONFIG_DM_SERIAL) +#if !defined(CONFIG_DM_SERIAL) #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE (-4) #endif @@ -163,14 +163,8 @@ #define CONFIG_SPL_NAND_AM33XX_BCH /* ELM support */ #endif
-/* - * Disable MMC DM for SPL build and can be re-enabled after adding - * DM support in SPL - */ #ifdef CONFIG_SPL_BUILD -#undef CONFIG_DM_MMC #undef CONFIG_TIMER -#undef CONFIG_DM_ETH #endif
#endif /* __CONFIG_TI_OMAP5_COMMON_H */
[snip]
- Hardware drivers
- Disable MMC DM for SPL build and can be re-enabled after adding
- DM support in SPL
Do you know why we need to disable timer?
[snip]
- Hardware drivers
- DM support in SPL
drivers/timer/ is not yet include in SPL and also we need to implement timer_early in SPL. I guess that is a different task. So till then I though of disabling it here.
[snip]
- Hardware drivers
- DM support in SPL
OK thanks.
Hi Tom,
Changes since v1:
Lokesh Vutla
