[PATCH] tools: relocate-rela: Fix BE symtab handling
The symtab contains data in target endianness, convert the data to native endianness before doing any operations and on them, and back to target endianness before updating the bin file.
Signed-off-by: Marek Vasut marek.vasut+renesas@mailbox.org --- Cc: Angelo Dureghello angelo@kernel-space.org Cc: Angelo Durgehello angelo.dureghello@timesys.com Cc: Bin Meng bmeng.cn@gmail.com Cc: Heinrich Schuchardt xypron.glpk@gmx.de Cc: Huan Wang alison.wang@nxp.com Cc: Marek Vasut marek.vasut+renesas@mailbox.org Cc: Michal Simek michal.simek@amd.com Cc: Ovidiu Panait ovpanait@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Zong Li zong.li@sifive.com --- tools/relocate-rela.c | 18 ++++++++++++++---- 1 file changed, 14 insertions(+), 4 deletions(-)
diff --git a/tools/relocate-rela.c b/tools/relocate-rela.c index f230ec5676c..e28e7fcc6f5 100644 --- a/tools/relocate-rela.c +++ b/tools/relocate-rela.c @@ -78,6 +78,14 @@ static uint32_t elf32_to_cpu(uint32_t data) return be32_to_cpu(data); }
+static uint32_t cpu_to_elf32(uint32_t data) +{ + if (ei_data == ELFDATA2LSB) + return cpu_to_le32(data); + + return cpu_to_be32(data); +} + static bool supported_rela(Elf64_Rela *rela) { uint64_t mask = 0xffffffffULL; /* would be different on 32-bit */ @@ -602,14 +610,16 @@ static int rela_elf32(char **argv, FILE *f) }
debug("Symbol description:\n"); - debug(" st_name:\t0x%x\n", symbols.st_name); - debug(" st_value:\t0x%x\n", symbols.st_value); - debug(" st_size:\t0x%x\n", symbols.st_size); + debug(" st_name:\t0x%x\n", elf32_to_cpu(symbols.st_name)); + debug(" st_value:\t0x%x\n", elf32_to_cpu(symbols.st_value)); + debug(" st_size:\t0x%x\n", elf32_to_cpu(symbols.st_size));
- value = swrela.r_addend + symbols.st_value; + value = swrela.r_addend + elf32_to_cpu(symbols.st_value);
debug("Value:\t0x%x\n", value);
+ value = cpu_to_elf32(value); + if (fseek(f, addr, SEEK_SET) < 0) { fprintf(stderr, "%s: %s: seek to %" PRIx32 " failed: %s\n",
- if (ei_data == ELFDATA2LSB)
- return cpu_to_be32(data);
- static bool supported_rela(Elf64_Rela *rela) { uint64_t mask = 0xffffffffULL; /* would be different on 32-bit */
value = swrela.r_addend + elf32_to_cpu(symbols.st_value); debug("Value:\t0x%x\n", value);
Tested-by: Michal Simek michal.simek@amd.com # microblaze, arm64
Thanks, Michal
Hi Marek,
thanks !
Reviewed-by: Angelo Dureghello angelo@kernel-space.org
applied to u-boot-coldfire
Thanks, angelo
Angelo Dureghello
Michal Simek
