[PATCH] mtd: nand: raw: mt7621-nand: allow writing ecc region in raw mode
Allow writing ecc parity region in raw mode. This makes sure the nand write.raw command can write the flash data as-is.
Change-Id: Ibed3bdf13c9cf81e54041c5ac7a78192b97dcedc Signed-off-by: Weijie Gao weijie.gao@mediatek.com CR-Id: WCNCR00180092 --- drivers/mtd/nand/raw/mt7621_nand.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/nand/raw/mt7621_nand.c b/drivers/mtd/nand/raw/mt7621_nand.c index f6eddb84a9..341ef0bf2d 100644 --- a/drivers/mtd/nand/raw/mt7621_nand.c +++ b/drivers/mtd/nand/raw/mt7621_nand.c @@ -1003,9 +1003,9 @@ static int mt7621_nfc_write_page_raw(struct mtd_info *mtd, mt7621_nfc_write_data(nfc, oob_fdm_ptr(nand, i), NFI_FDM_SIZE);
- /* Write dummy ECC parity data */ - mt7621_nfc_write_data_empty(nfc, nfc->spare_per_sector - - NFI_FDM_SIZE); + /* Write ECC parity data */ + mt7621_nfc_write_data(nfc, oob_ecc_ptr(nfc, i), + nfc->spare_per_sector - NFI_FDM_SIZE); }
mt7621_nfc_wait_write_completion(nfc, nand);
Hi
I think this is for internal tracking
NFI_FDM_SIZE);
Please describe better what regression you are trying to fix in the commit message Reviewed-by: Michael Trimarchi michael@amarulasolutions.com
Michael
-- 2.34.1
On Wed, 2024-03-13 at 07:41 +0100, Michael Nazzareno Trimarchi wrote:
External email : Please do not click links or open attachments until you have verified the sender or the content. Hi
mtd_info *mtd,
spare_per_sector -
NFI_FDM_SIZE);
NFI_FDM_SIZE);
In fact this patch is not fixing any regression. It just provide the ability to read/write the whole NAND page with ECC disabled. Users/developers can the be able to debug NAND related issue or do anything they want.
Michael
-- 2.34.1
Weijie Gao
Weijie Gao (高惟杰)
