[PATCH RFC 00/10] arm: dts: j7200/j721s2: Enable the ESM and PMIC ESM
This patch series is RFC. This is enabling ESM/PMIC_ESM modules needed for watchdog functionality.
Keerthy (10): arm64: dts: ti: k3-j721s2: Add ESM instances arm64: dts: ti: k3-j7200: Add MCU domain ESM instance arm: dts: k3-j721s2-r5-common-proc-board: Add ESM PMIC and dependent nodes arm64: dts: ti: k3-j721e: Add MCU domain ESM instance board: ti: j721e: Initialize MCU ESM board: ti: j721s2: Initialize the ESM & PMIC ESM configs: j721s2_evm_r5_defconfig: Enable ESM & PMIC ESM configs arm: dts: k3-j7200-r5-common-proc-board: Add PMIC ESM node configs: j7200_evm_r5_defconfig: Enable the ESM configs board: ti: j721e: Enable ESM initialization for J7200
arch/arm/dts/k3-j7200-mcu-wakeup.dtsi | 7 ++++ .../arm/dts/k3-j7200-r5-common-proc-board.dts | 14 +++++++ arch/arm/dts/k3-j721e-mcu-wakeup.dtsi | 7 ++++ arch/arm/dts/k3-j721s2-main.dtsi | 7 ++++ arch/arm/dts/k3-j721s2-mcu-wakeup.dtsi | 14 +++++++ .../dts/k3-j721s2-r5-common-proc-board.dts | 39 +++++++++++++++++++ board/ti/j721e/evm.c | 11 +++++- board/ti/j721s2/evm.c | 27 +++++++++++++ configs/j7200_evm_r5_defconfig | 2 + configs/j721s2_evm_r5_defconfig | 7 ++++ 10 files changed, 133 insertions(+), 2 deletions(-)
Patch adds the ESM instances for j721s2. It has 3 instances. One in the main domain and two in the mcu-wakeup domian.
Signed-off-by: Keerthy j-keerthy@ti.com --- arch/arm/dts/k3-j721s2-main.dtsi | 7 +++++++ arch/arm/dts/k3-j721s2-mcu-wakeup.dtsi | 14 ++++++++++++++ 2 files changed, 21 insertions(+)
diff --git a/arch/arm/dts/k3-j721s2-main.dtsi b/arch/arm/dts/k3-j721s2-main.dtsi index 976ba1e95a..859b5124ae 100644 --- a/arch/arm/dts/k3-j721s2-main.dtsi +++ b/arch/arm/dts/k3-j721s2-main.dtsi @@ -934,4 +934,11 @@ interrupt-names = "int0", "int1"; bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; }; + + main_esm: esm@700000 { + compatible = "ti,j721e-esm"; + reg = <0x00 0x700000 0x00 0x1000>; + ti,esm-pins = <688>, <689>; + bootph-pre-ram; + }; }; diff --git a/arch/arm/dts/k3-j721s2-mcu-wakeup.dtsi b/arch/arm/dts/k3-j721s2-mcu-wakeup.dtsi index 7521963719..f28cf7df50 100644 --- a/arch/arm/dts/k3-j721s2-mcu-wakeup.dtsi +++ b/arch/arm/dts/k3-j721s2-mcu-wakeup.dtsi @@ -299,4 +299,18 @@ ti,cpts-periodic-outputs = <2>; }; }; + + mcu_esm: esm@40800000 { + compatible = "ti,j721e-esm"; + reg = <0x00 0x40800000 0x00 0x1000>; + ti,esm-pins = <95>; + bootph-pre-ram; + }; + + wkup_esm: esm@42080000 { + compatible = "ti,j721e-esm"; + reg = <0x00 0x42080000 0x00 0x1000>; + ti,esm-pins = <63>; + bootph-pre-ram; + }; };
Patch adds the ESM instance for MCU domian of j7200.
Signed-off-by: Keerthy j-keerthy@ti.com --- arch/arm/dts/k3-j7200-mcu-wakeup.dtsi | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi b/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi index 1044ec6c4b..2b185fa350 100644 --- a/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi +++ b/arch/arm/dts/k3-j7200-mcu-wakeup.dtsi @@ -375,4 +375,11 @@ ti,loczrama = <1>; }; }; + + mcu_esm: esm@40800000 { + compatible = "ti,j721e-esm"; + reg = <0x00 0x40800000 0x00 0x1000>; + ti,esm-pins = <95>; + bootph-pre-ram; + }; };
PMIC ESM is part of tps6594x PMIC and connected to WKUP_I2C instance.
Signed-off-by: Keerthy j-keerthy@ti.com --- .../dts/k3-j721s2-r5-common-proc-board.dts | 39 +++++++++++++++++++ 1 file changed, 39 insertions(+)
diff --git a/arch/arm/dts/k3-j721s2-r5-common-proc-board.dts b/arch/arm/dts/k3-j721s2-r5-common-proc-board.dts index c74e8e58ae..629706aaf1 100644 --- a/arch/arm/dts/k3-j721s2-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j721s2-r5-common-proc-board.dts @@ -142,6 +142,14 @@ J721S2_WKUP_IOPAD(0x0b4, PIN_OUTPUT, 0) /* (D27) WKUP_UART0_TXD */ >; }; + + wkup_i2c0_pins_default: wkup-i2c0-pins-default { + bootph-pre-ram; + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x100, PIN_INPUT, 0) /* (H24) WKUP_I2C0_SCL */ + J721S2_WKUP_IOPAD(0x104, PIN_INPUT, 0) /* (H27) WKUP_I2C0_SDA */ + >; + }; };
&sms { @@ -197,4 +205,35 @@ ti,sci = <&dm_tifs>; };
+&wkup_i2c0 { + bootph-pre-ram; + pinctrl-names = "default"; + pinctrl-0 = <&wkup_i2c0_pins_default>; + clock-frequency = <400000>; + + tps659413: tps659413@48 { + compatible = "ti,tps659413"; + reg = <0x48>; + bootph-pre-ram; + + regulators: regulators { + bootph-pre-ram; + buck1234_reg: buck1234 { + /*VDD_CPU_AVS*/ + regulator-name = "buck1234"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <900000>; + regulator-always-on; + regulator-boot-on; + bootph-pre-ram; + }; + }; + + esm: esm { + compatible = "ti,tps659413-esm"; + bootph-pre-ram; + }; + }; +}; + #include "k3-j721s2-common-proc-board-u-boot.dtsi"
Patch adds the ESM instance for MCU domian of j721e.
Signed-off-by: Keerthy j-keerthy@ti.com --- arch/arm/dts/k3-j721e-mcu-wakeup.dtsi | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/dts/k3-j721e-mcu-wakeup.dtsi b/arch/arm/dts/k3-j721e-mcu-wakeup.dtsi index 22166c7942..66fdd6443f 100644 --- a/arch/arm/dts/k3-j721e-mcu-wakeup.dtsi +++ b/arch/arm/dts/k3-j721e-mcu-wakeup.dtsi @@ -408,4 +408,11 @@ ti,loczrama = <1>; }; }; + + mcu_esm: esm@40800000 { + compatible = "ti,j721e-esm"; + reg = <0x00 0x40800000 0x00 0x1000>; + ti,esm-pins = <95>; + bootph-pre-ram; + }; };
Initialize MCU ESM. This is needed to propagate MAIN domain events to the PMIC.
Signed-off-by: Keerthy j-keerthy@ti.com --- board/ti/j721e/evm.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index 38fe447d8f..42fa94b7a5 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -548,7 +548,12 @@ void spl_board_init(void) DM_DRIVER_GET(k3_esm), &dev); if (ret) printf("ESM init failed: %d\n", ret); + + ret = uclass_get_device_by_name(UCLASS_MISC, "esm@40800000", &dev); + if (ret) + printf("MISC init for esm@40800000 failed: %d\n", ret); } + #endif
#ifdef CONFIG_ESM_PMIC
Signed-off-by: Keerthy j-keerthy@ti.com --- board/ti/j721s2/evm.c | 27 +++++++++++++++++++++++++++ 1 file changed, 27 insertions(+)
diff --git a/board/ti/j721s2/evm.c b/board/ti/j721s2/evm.c index 7795300abc..effa52ff5a 100644 --- a/board/ti/j721s2/evm.c +++ b/board/ti/j721s2/evm.c @@ -319,4 +319,31 @@ int board_late_init(void)
void spl_board_init(void) { + struct udevice *dev; + int ret; + + if (IS_ENABLED(CONFIG_ESM_K3)) { + ret = uclass_get_device_by_name(UCLASS_MISC, "esm@700000", + &dev); + if (ret) + printf("MISC init for esm@700000 failed: %d\n", ret); + + ret = uclass_get_device_by_name(UCLASS_MISC, "esm@40800000", + &dev); + if (ret) + printf("MISC init for esm@40800000 failed: %d\n", ret); + + ret = uclass_get_device_by_name(UCLASS_MISC, "esm@42080000", + &dev); + if (ret) + printf("MISC init for esm@42080000 failed: %d\n", ret); + } + + if (IS_ENABLED(CONFIG_ESM_PMIC)) { + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_DRIVER_GET(pmic_esm), + &dev); + if (ret) + printf("ESM PMIC init failed: %d\n", ret); + } }
Signed-off-by: Keerthy j-keerthy@ti.com --- configs/j721s2_evm_r5_defconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/configs/j721s2_evm_r5_defconfig b/configs/j721s2_evm_r5_defconfig index 1e66ac23d0..b9ac56f34d 100644 --- a/configs/j721s2_evm_r5_defconfig +++ b/configs/j721s2_evm_r5_defconfig @@ -112,6 +112,8 @@ CONFIG_DM_MAILBOX=y CONFIG_K3_SEC_PROXY=y CONFIG_FS_LOADER=y CONFIG_SPL_FS_LOADER=y +CONFIG_ESM_K3=y +CONFIG_ESM_PMIC=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_SPL_MMC_HS400_SUPPORT=y CONFIG_MMC_SDHCI=y @@ -142,6 +144,11 @@ CONFIG_PINCTRL_SINGLE=y CONFIG_POWER_DOMAIN=y CONFIG_TI_POWER_DOMAIN=y CONFIG_K3_SYSTEM_CONTROLLER=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_TPS65941=y +CONFIG_DM_REGULATOR=y +CONFIG_SPL_DM_REGULATOR=y +CONFIG_DM_REGULATOR_TPS65941=y CONFIG_REMOTEPROC_TI_K3_ARM64=y CONFIG_RESET_TI_SCI=y CONFIG_DM_SERIAL=y
Enable the TPS659413 has the ESM PMIC.
Signed-off-by: Keerthy j-keerthy@ti.com --- arch/arm/dts/k3-j7200-r5-common-proc-board.dts | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts index e62f9218e8..4e5e4a08f8 100644 --- a/arch/arm/dts/k3-j7200-r5-common-proc-board.dts +++ b/arch/arm/dts/k3-j7200-r5-common-proc-board.dts @@ -271,6 +271,20 @@ }; };
+ tps659413: tps659413@48 { + compatible = "ti,tps659413"; + reg = <0x48>; + bootph-pre-ram; + + regulators_a: regulators { + bootph-pre-ram; + }; + + esm: esm { + compatible = "ti,tps659413-esm"; + bootph-pre-ram; + }; + }; };
&wkup_vtm0 {
Enable the ESM configs.
Signed-off-by: Keerthy j-keerthy@ti.com --- configs/j7200_evm_r5_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/j7200_evm_r5_defconfig b/configs/j7200_evm_r5_defconfig index c4dd33627b..7adc230fc1 100644 --- a/configs/j7200_evm_r5_defconfig +++ b/configs/j7200_evm_r5_defconfig @@ -101,6 +101,8 @@ CONFIG_DM_MAILBOX=y CONFIG_K3_SEC_PROXY=y CONFIG_FS_LOADER=y CONFIG_SPL_FS_LOADER=y +CONFIG_ESM_K3=y +CONFIG_ESM_PMIC=y CONFIG_K3_AVS0=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_SPL_MMC_HS400_SUPPORT=y
Signed-off-by: Keerthy j-keerthy@ti.com --- board/ti/j721e/evm.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index 42fa94b7a5..070b28326f 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -543,7 +543,8 @@ void spl_board_init(void) }
#ifdef CONFIG_ESM_K3 - if (board_ti_k3_is("J721EX-PM2-SOM")) { + if ((board_ti_k3_is("J721EX-PM2-SOM")) || + IS_ENABLED(CONFIG_TARGET_J7200_R5_EVM)) { ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(k3_esm), &dev); if (ret) @@ -557,7 +558,8 @@ void spl_board_init(void) #endif
#ifdef CONFIG_ESM_PMIC - if (board_ti_k3_is("J721EX-PM2-SOM")) { + if ((board_ti_k3_is("J721EX-PM2-SOM")) || + IS_ENABLED(CONFIG_TARGET_J7200_R5_EVM)) { ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(pmic_esm), &dev);
- if ((board_ti_k3_is("J721EX-PM2-SOM")) ||
Could we align on one kind of check, For J721E check is done against board-id, whereas for J7200 checking
for config option.
ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(pmic_esm), &dev);IS_ENABLED(CONFIG_TARGET_J7200_R5_EVM)) {
diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c index 42fa94b7a5..070b28326f 100644 --- a/board/ti/j721e/evm.c +++ b/board/ti/j721e/evm.c @@ -543,7 +543,8 @@ void spl_board_init(void) } #ifdef CONFIG_ESM_K3
We should look at figuring out how to split this file in two. One for "generic J721E systems" and one for "TI EVMs", as I've mentioned in other threads, so that it's easier for custom platforms to drop code they don' require.
Hi Tom,
Trying to bring back this series here.
Yes that does make sense. Would it be okay if we solve that problem separately in a different patch series? We can move along with this current series for now (after making the required change in CONFIG/board-id for v2) since ESM support is important for these platforms.
On Thu, Nov 16, 2023 at 11:43:50AM +0530, Neha Malcom Francis wrote:
Hi Tom,
Well, I think part of the answer to your question is (and this is a more general TI one too), what outstanding changes need to come in now to make existing platforms functional for v2024.01 ? My first thought is that this series would be taken to -next, if I took it now, which means there's time before it would be in master, and so if it really makes the re-org later easier, we could take it, but if not, can we re-org then do this? But if we need this to deal with regressions, OK, yes, we can take it like this now.
Hi Tom
Hi Tom,
Maybe focusing on the re-org after having in the changes would help give more perspective on how we can split? Not sure just a thought... in that case I prefer taking this in and having a working error signaling module in rather than delaying it if that's okay.
On Fri, Nov 17, 2023 at 02:00:43PM +0530, Neha Malcom Francis wrote:
Hi Tom
Hi Tom,
OK, please rebase on top of whatever other series are needed (and note so in the cover letter) and mark it as non-RFC, thanks.
Hi Tom,
Hi Tom
Hi Tom,
On 10/3/2023 1:40 PM, Keerthy wrote: > Enable ESM initialization for J7200 > > Signed-off-by: Keerthy j-keerthy@ti.com > --- > board/ti/j721e/evm.c | 6 ++++-- > 1 file changed, 4 insertions(+), 2 deletions(-) > > diff --git a/board/ti/j721e/evm.c b/board/ti/j721e/evm.c > index 42fa94b7a5..070b28326f 100644 > --- a/board/ti/j721e/evm.c > +++ b/board/ti/j721e/evm.c > @@ -543,7 +543,8 @@ void spl_board_init(void) > } > #ifdef CONFIG_ESM_K3 > - if (board_ti_k3_is("J721EX-PM2-SOM")) { > + if ((board_ti_k3_is("J721EX-PM2-SOM")) || > + IS_ENABLED(CONFIG_TARGET_J7200_R5_EVM)) {
Thanks! I'll rebase and send the next version.
Keerthy
Kumar, Udit
Neha Malcom Francis
