[PATCH v2] mmc: sdhci-cadence: Add support for Cadence sdmmc v6
Cadence SDMMC v6 controller has a lot of changes on initialize compared to v4 controller. PHY is needed by v6 controller.
Signed-off-by: Kuan Lim Lee kuanlim.lee@starfivetech.com Co-developed-by: Alex Soo yuklin.soo@starfivetech.com Signed-off-by: Wei Liang Lim weiliang.lim@starfivetech.com --- Changes in v2 - Rename file sdhci-cadence6-phy.c to sdhci-cadence6.c - Remove CONFIG_MMC_SDHCI_CADENCE_V6 - Rewrite code of v6 configuration part - Add sdhci_cdns6_phy_init() function --- drivers/mmc/Makefile | 1 + drivers/mmc/sdhci-cadence.c | 63 ++------ drivers/mmc/sdhci-cadence.h | 69 ++++++++ drivers/mmc/sdhci-cadence6.c | 294 +++++++++++++++++++++++++++++++++++ 4 files changed, 376 insertions(+), 51 deletions(-) create mode 100644 drivers/mmc/sdhci-cadence.h create mode 100644 drivers/mmc/sdhci-cadence6.c
diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 2c65c4765a..136f06600a 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -61,6 +61,7 @@ obj-$(CONFIG_MMC_SDHCI_ATMEL) += atmel_sdhci.o obj-$(CONFIG_MMC_SDHCI_BCM2835) += bcm2835_sdhci.o obj-$(CONFIG_MMC_SDHCI_BCMSTB) += bcmstb_sdhci.o obj-$(CONFIG_MMC_SDHCI_CADENCE) += sdhci-cadence.o +obj-$(CONFIG_MMC_SDHCI_CADENCE) += sdhci-cadence6.o obj-$(CONFIG_MMC_SDHCI_AM654) += am654_sdhci.o obj-$(CONFIG_MMC_SDHCI_IPROC) += iproc_sdhci.o obj-$(CONFIG_MMC_SDHCI_KONA) += kona_sdhci.o diff --git a/drivers/mmc/sdhci-cadence.c b/drivers/mmc/sdhci-cadence.c index 327a05ad11..a5533af045 100644 --- a/drivers/mmc/sdhci-cadence.c +++ b/drivers/mmc/sdhci-cadence.c @@ -17,56 +17,7 @@ #include <linux/libfdt.h> #include <mmc.h> #include <sdhci.h> - -/* HRS - Host Register Set (specific to Cadence) */ -#define SDHCI_CDNS_HRS04 0x10 /* PHY access port */ -#define SDHCI_CDNS_HRS04_ACK BIT(26) -#define SDHCI_CDNS_HRS04_RD BIT(25) -#define SDHCI_CDNS_HRS04_WR BIT(24) -#define SDHCI_CDNS_HRS04_RDATA GENMASK(23, 16) -#define SDHCI_CDNS_HRS04_WDATA GENMASK(15, 8) -#define SDHCI_CDNS_HRS04_ADDR GENMASK(5, 0) - -#define SDHCI_CDNS_HRS06 0x18 /* eMMC control */ -#define SDHCI_CDNS_HRS06_TUNE_UP BIT(15) -#define SDHCI_CDNS_HRS06_TUNE GENMASK(13, 8) -#define SDHCI_CDNS_HRS06_MODE GENMASK(2, 0) -#define SDHCI_CDNS_HRS06_MODE_SD 0x0 -#define SDHCI_CDNS_HRS06_MODE_MMC_SDR 0x2 -#define SDHCI_CDNS_HRS06_MODE_MMC_DDR 0x3 -#define SDHCI_CDNS_HRS06_MODE_MMC_HS200 0x4 -#define SDHCI_CDNS_HRS06_MODE_MMC_HS400 0x5 -#define SDHCI_CDNS_HRS06_MODE_MMC_HS400ES 0x6 - -/* SRS - Slot Register Set (SDHCI-compatible) */ -#define SDHCI_CDNS_SRS_BASE 0x200 - -/* PHY */ -#define SDHCI_CDNS_PHY_DLY_SD_HS 0x00 -#define SDHCI_CDNS_PHY_DLY_SD_DEFAULT 0x01 -#define SDHCI_CDNS_PHY_DLY_UHS_SDR12 0x02 -#define SDHCI_CDNS_PHY_DLY_UHS_SDR25 0x03 -#define SDHCI_CDNS_PHY_DLY_UHS_SDR50 0x04 -#define SDHCI_CDNS_PHY_DLY_UHS_DDR50 0x05 -#define SDHCI_CDNS_PHY_DLY_EMMC_LEGACY 0x06 -#define SDHCI_CDNS_PHY_DLY_EMMC_SDR 0x07 -#define SDHCI_CDNS_PHY_DLY_EMMC_DDR 0x08 -#define SDHCI_CDNS_PHY_DLY_SDCLK 0x0b -#define SDHCI_CDNS_PHY_DLY_HSMMC 0x0c -#define SDHCI_CDNS_PHY_DLY_STROBE 0x0d - -/* - * The tuned val register is 6 bit-wide, but not the whole of the range is - * available. The range 0-42 seems to be available (then 43 wraps around to 0) - * but I am not quite sure if it is official. Use only 0 to 39 for safety. - */ -#define SDHCI_CDNS_MAX_TUNING_LOOP 40 - -struct sdhci_cdns_plat { - struct mmc_config cfg; - struct mmc mmc; - void __iomem *hrs_addr; -}; +#include "sdhci-cadence.h"
struct sdhci_cdns_phy_cfg { const char *property; @@ -163,6 +114,9 @@ static void sdhci_cdns_set_control_reg(struct sdhci_host *host) tmp &= ~SDHCI_CDNS_HRS06_MODE; tmp |= FIELD_PREP(SDHCI_CDNS_HRS06_MODE, mode); writel(tmp, plat->hrs_addr + SDHCI_CDNS_HRS06); + + if (device_is_compatible(mmc->dev, "cdns,sd6hc")) + sdhci_cdns6_phy_adj(mmc->dev, plat, mode); }
static const struct sdhci_ops sdhci_cdns_ops = { @@ -176,6 +130,9 @@ static int sdhci_cdns_set_tune_val(struct sdhci_cdns_plat *plat, u32 tmp; int i, ret;
+ if (device_is_compatible(plat->mmc.dev, "cdns,sd6hc")) + return sdhci_cdns6_set_tune_val(plat, val); + if (WARN_ON(!FIELD_FIT(SDHCI_CDNS_HRS06_TUNE, val))) return -EINVAL;
@@ -282,7 +239,10 @@ static int sdhci_cdns_probe(struct udevice *dev) if (ret) return ret;
- ret = sdhci_cdns_phy_init(plat, gd->fdt_blob, dev_of_offset(dev)); + if (device_is_compatible(dev, "cdns,sd6hc")) + ret = sdhci_cdns6_phy_init(dev, plat); + else + ret = sdhci_cdns_phy_init(plat, gd->fdt_blob, dev_of_offset(dev)); if (ret) return ret;
@@ -301,6 +261,7 @@ static int sdhci_cdns_probe(struct udevice *dev) static const struct udevice_id sdhci_cdns_match[] = { { .compatible = "socionext,uniphier-sd4hc" }, { .compatible = "cdns,sd4hc" }, + { .compatible = "cdns,sd6hc" }, { /* sentinel */ } };
diff --git a/drivers/mmc/sdhci-cadence.h b/drivers/mmc/sdhci-cadence.h new file mode 100644 index 0000000000..c20efd899a --- /dev/null +++ b/drivers/mmc/sdhci-cadence.h @@ -0,0 +1,69 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2016 Socionext Inc. + * Author: Masahiro Yamada yamada.masahiro@socionext.com + */ + +#ifndef SDHCI_CADENCE_H_ +#define SDHCI_CADENCE_H_ + +/* HRS - Host Register Set (specific to Cadence) */ +/* PHY access port */ +#define SDHCI_CDNS_HRS04 0x10 +/* Cadence V4 HRS04 Description*/ +#define SDHCI_CDNS_HRS04_ACK BIT(26) +#define SDHCI_CDNS_HRS04_RD BIT(25) +#define SDHCI_CDNS_HRS04_WR BIT(24) +#define SDHCI_CDNS_HRS04_RDATA GENMASK(23, 16) +#define SDHCI_CDNS_HRS04_WDATA GENMASK(15, 8) +#define SDHCI_CDNS_HRS04_ADDR GENMASK(5, 0) + +#define SDHCI_CDNS_HRS05 0x14 + +/* eMMC control */ +#define SDHCI_CDNS_HRS06 0x18 +#define SDHCI_CDNS_HRS06_TUNE_UP BIT(15) +#define SDHCI_CDNS_HRS06_TUNE GENMASK(13, 8) +#define SDHCI_CDNS_HRS06_MODE GENMASK(2, 0) +#define SDHCI_CDNS_HRS06_MODE_SD 0x0 +#define SDHCI_CDNS_HRS06_MODE_MMC_SDR 0x2 +#define SDHCI_CDNS_HRS06_MODE_MMC_DDR 0x3 +#define SDHCI_CDNS_HRS06_MODE_MMC_HS200 0x4 +#define SDHCI_CDNS_HRS06_MODE_MMC_HS400 0x5 +#define SDHCI_CDNS_HRS06_MODE_MMC_HS400ES 0x6 + +/* SRS - Slot Register Set (SDHCI-compatible) */ +#define SDHCI_CDNS_SRS_BASE 0x200 + +/* Cadence V4 PHY Setting*/ +#define SDHCI_CDNS_PHY_DLY_SD_HS 0x00 +#define SDHCI_CDNS_PHY_DLY_SD_DEFAULT 0x01 +#define SDHCI_CDNS_PHY_DLY_UHS_SDR12 0x02 +#define SDHCI_CDNS_PHY_DLY_UHS_SDR25 0x03 +#define SDHCI_CDNS_PHY_DLY_UHS_SDR50 0x04 +#define SDHCI_CDNS_PHY_DLY_UHS_DDR50 0x05 +#define SDHCI_CDNS_PHY_DLY_EMMC_LEGACY 0x06 +#define SDHCI_CDNS_PHY_DLY_EMMC_SDR 0x07 +#define SDHCI_CDNS_PHY_DLY_EMMC_DDR 0x08 +#define SDHCI_CDNS_PHY_DLY_SDCLK 0x0b +#define SDHCI_CDNS_PHY_DLY_HSMMC 0x0c +#define SDHCI_CDNS_PHY_DLY_STROBE 0x0d + +/* + * The tuned val register is 6 bit-wide, but not the whole of the range is + * available. The range 0-42 seems to be available (then 43 wraps around to 0) + * but I am not quite sure if it is official. Use only 0 to 39 for safety. + */ +#define SDHCI_CDNS_MAX_TUNING_LOOP 40 + +struct sdhci_cdns_plat { + struct mmc_config cfg; + struct mmc mmc; + void __iomem *hrs_addr; +}; + +int sdhci_cdns6_phy_adj(struct udevice *dev, struct sdhci_cdns_plat *plat, u32 mode); +int sdhci_cdns6_phy_init(struct udevice *dev, struct sdhci_cdns_plat *plat); +int sdhci_cdns6_set_tune_val(struct sdhci_cdns_plat *plat, unsigned int val); + +#endif diff --git a/drivers/mmc/sdhci-cadence6.c b/drivers/mmc/sdhci-cadence6.c new file mode 100644 index 0000000000..ea0857e655 --- /dev/null +++ b/drivers/mmc/sdhci-cadence6.c @@ -0,0 +1,294 @@ +// SPDX-License-Identifier: GPL-2.0-or-platform_driver +/* + * Copyright (C) 2023 Starfive. + * Author: Kuan Lim Lee kuanlim.lee@starfivetech.com + */ + +#include <common.h> +#include <dm.h> +#include <asm/global_data.h> +#include <dm/device_compat.h> +#include <linux/bitfield.h> +#include <linux/bitops.h> +#include <linux/bug.h> +#include <linux/io.h> +#include <linux/iopoll.h> +#include <linux/sizes.h> +#include <linux/libfdt.h> +#include <mmc.h> +#include <sdhci.h> +#include "sdhci-cadence.h" + +/* IO Delay Information */ +#define SDHCI_CDNS_HRS07 0X1C +#define SDHCI_CDNS_HRS07_RW_COMPENSATE GENMASK(20, 16) +#define SDHCI_CDNS_HRS07_IDELAY_VAL GENMASK(4, 0) + +/* PHY Control and Status */ +#define SDHCI_CDNS_HRS09 0x24 +#define SDHCI_CDNS_HRS09_RDDATA_EN BIT(16) +#define SDHCI_CDNS_HRS09_RDCMD_EN BIT(15) +#define SDHCI_CDNS_HRS09_EXTENDED_WR_MODE BIT(3) +#define SDHCI_CDNS_HRS09_EXTENDED_RD_MODE BIT(2) +#define SDHCI_CDNS_HRS09_PHY_INIT_COMPLETE BIT(1) +#define SDHCI_CDNS_HRS09_PHY_SW_RESET BIT(0) + +/* SDCLK adjustment */ +#define SDHCI_CDNS_HRS10 0x28 +#define SDHCI_CDNS_HRS10_HCSDCLKADJ GENMASK(19, 16) + +/* CMD/DAT output delay */ +#define SDHCI_CDNS_HRS16 0x40 + +/* PHY Special Function Registers */ +/* register to control the DQ related timing */ +#define PHY_DQ_TIMING_REG_ADDR 0x2000 + +/* register to control the DQS related timing */ +#define PHY_DQS_TIMING_REG_ADDR 0x2004 + +/* register to control the gate and loopback control related timing */ +#define PHY_GATE_LPBK_CTRL_REG_ADDR 0x2008 + +/* register to control the Master DLL logic */ +#define PHY_DLL_MASTER_CTRL_REG_ADDR 0x200C + +/* register to control the Slave DLL logic */ +#define PHY_DLL_SLAVE_CTRL_REG_ADDR 0x2010 +#define PHY_DLL_SLAVE_CTRL_REG_READ_DQS_CMD_DELAY GENMASK(31, 24) +#define PHY_DLL_SLAVE_CTRL_REG_READ_DQS_DELAY GENMASK(7, 0) + +#define SDHCI_CDNS6_PHY_CFG_NUM 4 +#define SDHCI_CDNS6_CTRL_CFG_NUM 4 + +struct sdhci_cdns6_phy_cfg { + const char *property; + u32 val; +}; + +struct sdhci_cdns6_ctrl_cfg { + const char *property; + u32 val; +}; + +static struct sdhci_cdns6_phy_cfg sd_ds_phy_cfgs[] = { + { "cdns,phy-dqs-timing-delay-sd-ds", 0x00380004, }, + { "cdns,phy-gate-lpbk_ctrl-delay-sd-ds", 0x01A00040, }, + { "cdns,phy-dll-slave-ctrl-sd-ds", 0x00000000, }, + { "cdns,phy-dq-timing-delay-sd-ds", 0x00000001, }, +}; + +static struct sdhci_cdns6_phy_cfg emmc_sdr_phy_cfgs[] = { + { "cdns,phy-dqs-timing-delay-semmc-sdr", 0x00380004, }, + { "cdns,phy-gate-lpbk_ctrl-delay-emmc-sdr", 0x01A00040, }, + { "cdns,phy-dll-slave-ctrl-emmc-sdr", 0x00000000, }, + { "cdns,phy-dq-timing-delay-emmc-sdr", 0x00000001, }, +}; + +static struct sdhci_cdns6_phy_cfg emmc_ddr_phy_cfgs[] = { + { "cdns,phy-dqs-timing-delay-emmc-ddr", 0x00380004, }, + { "cdns,phy-gate-lpbk_ctrl-delay-emmc-ddr", 0x01A00040, }, + { "cdns,phy-dll-slave-ctrl-emmc-ddr", 0x00000000, }, + { "cdns,phy-dq-timing-delay-emmc-ddr", 0x10000001, }, +}; + +static struct sdhci_cdns6_phy_cfg emmc_hs200_phy_cfgs[] = { + { "cdns,phy-dqs-timing-delay-emmc-hs200", 0x00380004, }, + { "cdns,phy-gate-lpbk_ctrl-delay-emmc-hs200", 0x01A00040, }, + { "cdns,phy-dll-slave-ctrl-emmc-hs200", 0x00DADA00, }, + { "cdns,phy-dq-timing-delay-emmc-hs200", 0x00000001, }, +}; + +static struct sdhci_cdns6_phy_cfg emmc_hs400_phy_cfgs[] = { + { "cdns,phy-dqs-timing-delay-emmc-hs400", 0x00280004, }, + { "cdns,phy-gate-lpbk_ctrl-delay-emmc-hs400", 0x01A00040, }, + { "cdns,phy-dll-slave-ctrl-emmc-hs400", 0x00DAD800, }, + { "cdns,phy-dq-timing-delay-emmc-hs400", 0x00000001, }, +}; + +static struct sdhci_cdns6_ctrl_cfg sd_ds_ctrl_cfgs[] = { + { "cdns,ctrl-hrs09-timing-delay-sd-ds", 0x0001800C, }, + { "cdns,ctrl-hrs10-lpbk_ctrl-delay-sd-ds", 0x00020000, }, + { "cdns,ctrl-hrs16-slave-ctrl-sd-ds", 0x00000000, }, + { "cdns,ctrl-hrs07-timing-delay-sd-ds", 0x00080000, }, +}; + +static struct sdhci_cdns6_ctrl_cfg emmc_sdr_ctrl_cfgs[] = { + { "cdns,ctrl-hrs09-timing-delay-emmc-sdr", 0x0001800C, }, + { "cdns,ctrl-hrs10-lpbk_ctrl-delay-emmc-sdr", 0x00030000, }, + { "cdns,ctrl-hrs16-slave-ctrl-emmc-sdr", 0x00000000, }, + { "cdns,ctrl-hrs07-timing-delay-emmc-sdr", 0x00080000, }, +}; + +static struct sdhci_cdns6_ctrl_cfg emmc_ddr_ctrl_cfgs[] = { + { "cdns,ctrl-hrs09-timing-delay-emmc-ddr", 0x0001800C, }, + { "cdns,ctrl-hrs10-lpbk_ctrl-delay-emmc-ddr", 0x00020000, }, + { "cdns,ctrl-hrs16-slave-ctrl-emmc-ddr", 0x11000001, }, + { "cdns,ctrl-hrs07-timing-delay-emmc-ddr", 0x00090001, }, +}; + +static struct sdhci_cdns6_ctrl_cfg emmc_hs200_ctrl_cfgs[] = { + { "cdns,ctrl-hrs09-timing-delay-emmc-hs200", 0x00018000, }, + { "cdns,ctrl-hrs10-lpbk_ctrl-delay-emmc-hs200", 0x00080000, }, + { "cdns,ctrl-hrs16-slave-ctrl-emmc-hs200", 0x00000000, }, + { "cdns,ctrl-hrs07-timing-delay-emmc-hs200", 0x00090000, }, +}; + +static struct sdhci_cdns6_ctrl_cfg emmc_hs400_ctrl_cfgs[] = { + { "cdns,ctrl-hrs09-timing-delay-emmc-hs400", 0x00018000, }, + { "cdns,ctrl-hrs10-lpbk_ctrl-delay-emmc-hs400", 0x00080000, }, + { "cdns,ctrl-hrs16-slave-ctrl-emmc-hs400", 0x11000000, }, + { "cdns,ctrl-hrs07-timing-delay-emmc-hs400", 0x00080000, }, +}; + +static u32 sdhci_cdns6_read_phy_reg(struct sdhci_cdns_plat *plat, u32 addr) +{ + writel(addr, plat->hrs_addr + SDHCI_CDNS_HRS04); + return readl(plat->hrs_addr + SDHCI_CDNS_HRS05); +} + +static void sdhci_cdns6_write_phy_reg(struct sdhci_cdns_plat *plat, u32 addr, u32 val) +{ + writel(addr, plat->hrs_addr + SDHCI_CDNS_HRS04); + writel(val, plat->hrs_addr + SDHCI_CDNS_HRS05); +} + +static int sdhci_cdns6_reset_phy_dll(struct sdhci_cdns_plat *plat, bool reset) +{ + void __iomem *reg = plat->hrs_addr + SDHCI_CDNS_HRS09; + u32 tmp; + int ret; + + tmp = readl(reg); + tmp &= ~SDHCI_CDNS_HRS09_PHY_SW_RESET; + + /* Switch On DLL Reset */ + if (reset) + tmp |= FIELD_PREP(SDHCI_CDNS_HRS09_PHY_SW_RESET, 0); + else + tmp |= FIELD_PREP(SDHCI_CDNS_HRS09_PHY_SW_RESET, 1); + + writel(tmp, reg); + + /* After reset, wait until HRS09.PHY_INIT_COMPLETE is set to 1 within 3000us*/ + if (!reset) { + ret = readl_poll_timeout(reg, tmp, (tmp & SDHCI_CDNS_HRS09_PHY_INIT_COMPLETE), + 3000); + } + + return ret; +} + +int sdhci_cdns6_phy_adj(struct udevice *dev, struct sdhci_cdns_plat *plat, u32 mode) +{ + DECLARE_GLOBAL_DATA_PTR; + struct sdhci_cdns6_phy_cfg *sdhci_cdns6_phy_cfgs; + struct sdhci_cdns6_ctrl_cfg *sdhci_cdns6_ctrl_cfgs; + const fdt32_t *prop; + u32 tmp; + int i, ret; + + switch (mode) { + case SDHCI_CDNS_HRS06_MODE_SD: + sdhci_cdns6_phy_cfgs = sd_ds_phy_cfgs; + sdhci_cdns6_ctrl_cfgs = sd_ds_ctrl_cfgs; + break; + + case SDHCI_CDNS_HRS06_MODE_MMC_SDR: + sdhci_cdns6_phy_cfgs = emmc_sdr_phy_cfgs; + sdhci_cdns6_ctrl_cfgs = emmc_sdr_ctrl_cfgs; + break; + + case SDHCI_CDNS_HRS06_MODE_MMC_DDR: + sdhci_cdns6_phy_cfgs = emmc_ddr_phy_cfgs; + sdhci_cdns6_ctrl_cfgs = emmc_ddr_ctrl_cfgs; + break; + + case SDHCI_CDNS_HRS06_MODE_MMC_HS200: + sdhci_cdns6_phy_cfgs = emmc_hs200_phy_cfgs; + sdhci_cdns6_ctrl_cfgs = emmc_hs200_ctrl_cfgs; + break; + + case SDHCI_CDNS_HRS06_MODE_MMC_HS400: + sdhci_cdns6_phy_cfgs = emmc_hs400_phy_cfgs; + sdhci_cdns6_ctrl_cfgs = emmc_hs400_ctrl_cfgs; + break; + default: + return -EINVAL; + } + + for (i = 0; i < SDHCI_CDNS6_PHY_CFG_NUM; i++) { + prop = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), + sdhci_cdns6_phy_cfgs[i].property, NULL); + if (prop) + sdhci_cdns6_phy_cfgs[i].val = *prop; + } + + for (i = 0; i < SDHCI_CDNS6_CTRL_CFG_NUM; i++) { + prop = fdt_getprop(gd->fdt_blob, dev_of_offset(dev), + sdhci_cdns6_ctrl_cfgs[i].property, NULL); + if (prop) + sdhci_cdns6_ctrl_cfgs[i].val = *prop; + } + + /* Switch On the DLL Reset */ + sdhci_cdns6_reset_phy_dll(plat, true); + + sdhci_cdns6_write_phy_reg(plat, PHY_DQS_TIMING_REG_ADDR, sdhci_cdns6_phy_cfgs[0].val); + sdhci_cdns6_write_phy_reg(plat, PHY_GATE_LPBK_CTRL_REG_ADDR, sdhci_cdns6_phy_cfgs[1].val); + sdhci_cdns6_write_phy_reg(plat, PHY_DLL_SLAVE_CTRL_REG_ADDR, sdhci_cdns6_phy_cfgs[2].val); + + /* Switch Off the DLL Reset */ + ret = sdhci_cdns6_reset_phy_dll(plat, false); + if (ret) { + printf("sdhci_cdns6_reset_phy is not completed\n"); + return ret; + } + + /* Set PHY DQ TIMING control register */ + sdhci_cdns6_write_phy_reg(plat, PHY_DQ_TIMING_REG_ADDR, sdhci_cdns6_phy_cfgs[3].val); + + /* Set HRS09 register */ + tmp = readl(plat->hrs_addr + SDHCI_CDNS_HRS09); + tmp &= ~(SDHCI_CDNS_HRS09_EXTENDED_WR_MODE | + SDHCI_CDNS_HRS09_EXTENDED_RD_MODE | + SDHCI_CDNS_HRS09_RDDATA_EN | + SDHCI_CDNS_HRS09_RDCMD_EN); + tmp |= sdhci_cdns6_ctrl_cfgs[0].val; + writel(tmp, plat->hrs_addr + SDHCI_CDNS_HRS09); + + /* Set HRS10 register */ + tmp = readl(plat->hrs_addr + SDHCI_CDNS_HRS10); + tmp &= ~SDHCI_CDNS_HRS10_HCSDCLKADJ; + tmp |= sdhci_cdns6_ctrl_cfgs[1].val; + writel(tmp, plat->hrs_addr + SDHCI_CDNS_HRS10); + + /* Set HRS16 register */ + writel(sdhci_cdns6_ctrl_cfgs[2].val, plat->hrs_addr + SDHCI_CDNS_HRS16); + + /* Set HRS07 register */ + writel(sdhci_cdns6_ctrl_cfgs[3].val, plat->hrs_addr + SDHCI_CDNS_HRS07); + + return 0; +} + +int sdhci_cdns6_phy_init(struct udevice *dev, struct sdhci_cdns_plat *plat) +{ + return sdhci_cdns6_phy_adj(dev, plat, SDHCI_CDNS_HRS06_MODE_SD); +} + +int sdhci_cdns6_set_tune_val(struct sdhci_cdns_plat *plat, unsigned int val) +{ + u32 tmp, tuneval; + + tuneval = (val * 256) / SDHCI_CDNS_MAX_TUNING_LOOP; + + tmp = sdhci_cdns6_read_phy_reg(plat, PHY_DLL_SLAVE_CTRL_REG_ADDR); + tmp &= ~(PHY_DLL_SLAVE_CTRL_REG_READ_DQS_CMD_DELAY | + PHY_DLL_SLAVE_CTRL_REG_READ_DQS_DELAY); + tmp |= FIELD_PREP(PHY_DLL_SLAVE_CTRL_REG_READ_DQS_CMD_DELAY, tuneval) | + FIELD_PREP(PHY_DLL_SLAVE_CTRL_REG_READ_DQS_DELAY, tuneval); + sdhci_cdns6_write_phy_reg(plat, PHY_DLL_SLAVE_CTRL_REG_ADDR, tmp); + + return 0; +}
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
Changes in v2
Signed-off-by: Kuan Lim Lee kuanlim.lee@starfivetech.com Co-developed-by: Alex Soo yuklin.soo@starfivetech.com Signed-off-by: Wei Liang Lim weiliang.lim@starfivetech.com Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Jaehoon Chung
Kuan Lim Lee
