[PATCH v3 1/3] iopoll: Add read_poll_timeout common API
Add read_poll_timeout common API similar to Linux iopoll.
readx_poll_timeout will trigger read_poll_timeout with proper op. This will help to extend the functionalities like sleep_us to poll timeout in future.
This change is referenced from Linux from below commit: commit <5f5323a14cad19323060a8cbf9d96f2280a462dd> ("iopoll: introduce read_poll_timeout macro")
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v3: - new patch
include/linux/iopoll.h | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/include/linux/iopoll.h b/include/linux/iopoll.h index ab0ae1969a..51966d83da 100644 --- a/include/linux/iopoll.h +++ b/include/linux/iopoll.h @@ -11,7 +11,7 @@ #include <time.h>
/** - * readx_poll_timeout - Periodically poll an address until a condition is met or a timeout occurs + * read_poll_timeout - Periodically poll an address until a condition is met or a timeout occurs * @op: accessor function (takes @addr as its only argument) * @addr: Address to poll * @val: Variable to read the value into @@ -24,7 +24,7 @@ * When available, you'll probably want to use one of the specialized * macros defined below rather than this macro directly. */ -#define readx_poll_timeout(op, addr, val, cond, timeout_us) \ +#define read_poll_timeout(op, addr, val, cond, timeout_us) \ ({ \ unsigned long timeout = timer_get_us() + timeout_us; \ for (;;) { \ @@ -39,6 +39,8 @@ (cond) ? 0 : -ETIMEDOUT; \ })
+#define readx_poll_timeout(op, addr, val, cond, timeout_us) \ + read_poll_timeout(op, addr, val, cond, timeout_us)
#define readb_poll_timeout(addr, val, cond, timeout_us) \ readx_poll_timeout(readb, addr, val, cond, timeout_us)
Some drivers and other bsp code not only poll the register with timeout but also required to delay on each transaction.
This patch add that requirement by adding sleep_us variable so-that read_poll_timeout now support delay as well.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v3: - add delay header
include/linux/iopoll.h | 8 ++++++-- 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/include/linux/iopoll.h b/include/linux/iopoll.h index 51966d83da..76d2f951c1 100644 --- a/include/linux/iopoll.h +++ b/include/linux/iopoll.h @@ -6,6 +6,7 @@ #ifndef _LINUX_IOPOLL_H #define _LINUX_IOPOLL_H
+#include <linux/delay.h> #include <linux/errno.h> #include <linux/io.h> #include <time.h> @@ -16,6 +17,7 @@ * @addr: Address to poll * @val: Variable to read the value into * @cond: Break condition (usually involving @val) + * @sleep_us: Maximum time to sleep in us * @timeout_us: Timeout in us, 0 means never timeout * * Returns 0 on success and -ETIMEDOUT upon a timeout. In either @@ -24,7 +26,7 @@ * When available, you'll probably want to use one of the specialized * macros defined below rather than this macro directly. */ -#define read_poll_timeout(op, addr, val, cond, timeout_us) \ +#define read_poll_timeout(op, addr, val, cond, sleep_us, timeout_us) \ ({ \ unsigned long timeout = timer_get_us() + timeout_us; \ for (;;) { \ @@ -35,12 +37,14 @@ (val) = op(addr); \ break; \ } \ + if (sleep_us) \ + udelay(sleep_us); \ } \ (cond) ? 0 : -ETIMEDOUT; \ })
#define readx_poll_timeout(op, addr, val, cond, timeout_us) \ - read_poll_timeout(op, addr, val, cond, timeout_us) + read_poll_timeout(op, addr, val, cond, false, timeout_us)
Add readl poll API with sleep and timeout support.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v3: - add readx_poll_sleep_timeout
include/linux/iopoll.h | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/include/linux/iopoll.h b/include/linux/iopoll.h index 76d2f951c1..30cdea0cdc 100644 --- a/include/linux/iopoll.h +++ b/include/linux/iopoll.h @@ -43,6 +43,12 @@ (cond) ? 0 : -ETIMEDOUT; \ })
+#define readx_poll_sleep_timeout(op, addr, val, cond, sleep_us, timeout_us) \ + read_poll_timeout(op, addr, val, cond, sleep_us, timeout_us) + +#define readl_poll_sleep_timeout(addr, val, cond, sleep_us, timeout_us) \ + readx_poll_sleep_timeout(readl, addr, val, cond, sleep_us, timeout_us) + #define readx_poll_timeout(op, addr, val, cond, timeout_us) \ read_poll_timeout(op, addr, val, cond, false, timeout_us)
Applied all to u-boot-spi/master
Jagan Teki
