[U-Boot] [PATCH] mx31pdk: Enable D and I caches
Enable D and I caches on mx31pdk.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- Stefano,
You explained that enabling cache may cause some drivers like FEC and MMC not to work properly. As mx31pdk does not have FEC or MMC driver I thought this should be OK.
Tested by booting Linux kernel via TFTP and mounting a NFS rootfs.
board/freescale/mx31pdk/mx31pdk.c | 8 ++++++++ 1 files changed, 8 insertions(+), 0 deletions(-)
diff --git a/board/freescale/mx31pdk/mx31pdk.c b/board/freescale/mx31pdk/mx31pdk.c index 9f8bc53..1d7b4f6 100644 --- a/board/freescale/mx31pdk/mx31pdk.c +++ b/board/freescale/mx31pdk/mx31pdk.c @@ -71,11 +71,19 @@ int board_early_init_f(void) return 0; }
+void enable_caches(void) +{ + icache_enable(); + dcache_enable(); +} + int board_init(void) { /* adress of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100;
+ enable_caches(); + return 0; }
Stefano,
Ok, understood.
Good. To be sure, do you have also tested NAND in u-boot ? I do not expect problems, but...
- icache_enable();
- dcache_enable();
- enable_caches();
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Hi Stefano,
Yes, I confirmed that NAND works with the caches enabled by doing the following tests:
1. Save environment variables in NAND 2. Reprogram U-boot in NAND using "run prg_uboot" script.
I would like to investigate the FEC issue when caches are enabled when I have a chance.
Would you have any pointers as to where to start investigating why the FEC driver is buggy when caches are enabled?
Thanks,
Fabio Estevam
Fabio,
2011/11/3 Fabio Estevam festevam@gmail.com:
Hi Stefano,
- Save environment variables in NAND
- Reprogram U-boot in NAND using "run prg_uboot" script.
you can search the tread: [U-Boot] i.MX51: FEC: Cache coherency problem?
Jason Liu
Thanks,
Fabio Estevam _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Stefano,
- icache_enable();
- dcache_enable();
- enable_caches();
Applied to u-boot-imx, thanks.
Fabio Estevam
Fabio Estevam
Jason Liu
Stefano Babic
