[U-Boot] [PATCH v3] taurus: board updates
taurus changes: - rename at91_spl_board_init to spl_board_init fixes problems with recovery button and nand erase sector 0 - adapt CONFIG_SPL_MAX_SIZE and CONFIG_SPL_BSS_MAX_SIZE - add CONFIG_AT91_HW_WDT_TIMEOUT 15 - CONFIG_SF_DEFAULT_MODE SPI_MODE_3 not mode 0
Signed-off-by: Heiko Schocher hs@denx.de ---
Changes in v3: - use SZ_X defines for sizes
Changes in v2: - add comments from Andreas Biessmann: - rebase to 0d339cf9a969f0c249713d3697e735184f1bd955
board/siemens/taurus/taurus.c | 6 +++--- include/configs/taurus.h | 21 +++++++++++---------- 2 files changed, 14 insertions(+), 13 deletions(-)
diff --git a/board/siemens/taurus/taurus.c b/board/siemens/taurus/taurus.c index 781727e..edeb15b 100644 --- a/board/siemens/taurus/taurus.c +++ b/board/siemens/taurus/taurus.c @@ -99,7 +99,7 @@ static int at91_is_recovery(void) } #endif
-void at91_spl_board_init(void) +void spl_board_init(void) { taurus_nand_hw_init(); at91_spi0_hw_init(TAURUS_SPI_MASK); @@ -124,13 +124,13 @@ void at91_spl_board_init(void) if (at91_is_recovery() == 1) { struct spi_flash *flash;
- debug("Recovery button pressed\n"); + puts("Recovery button pressed\n"); nand_init(); spl_nand_erase_one(0, 0); flash = spi_flash_probe(CONFIG_SF_DEFAULT_BUS, 0, CONFIG_SF_DEFAULT_SPEED, - SPI_MODE_3); + CONFIG_SF_DEFAULT_MODE); if (!flash) { puts("no flash\n"); } else { diff --git a/include/configs/taurus.h b/include/configs/taurus.h index fb7c575..c1fed9a 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -81,14 +81,14 @@ */ #define CONFIG_NR_DRAM_BANKS 1 #define CONFIG_SYS_SDRAM_BASE ATMEL_BASE_CS1 -#define CONFIG_SYS_SDRAM_SIZE (128 * 1024 * 1024) +#define CONFIG_SYS_SDRAM_SIZE (128 * SZ_1M)
/* * Initial stack pointer: 4k - GENERATED_GBL_DATA_SIZE in internal SRAM, * leaving the correct space for initial global data structure above * that address while providing maximum stack area below. */ -# define CONFIG_SYS_INIT_SP_ADDR \ +#define CONFIG_SYS_INIT_SP_ADDR \ (ATMEL_BASE_SRAM1 + 0x1000 - GENERATED_GBL_DATA_SIZE)
/* NAND flash */ @@ -112,6 +112,7 @@ #define CONFIG_AT91_WANTS_COMMON_PHY
#define CONFIG_AT91SAM9_WATCHDOG +#define CONFIG_AT91_HW_WDT_TIMEOUT 15 #if !defined(CONFIG_SPL_BUILD) /* Enable the watchdog */ #define CONFIG_HW_WATCHDOG @@ -146,8 +147,8 @@ #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000
#define CONFIG_SF_DEFAULT_BUS 0 -#define CONFIG_SF_DEFAULT_SPEED 10000000 -#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 +#define CONFIG_SF_DEFAULT_SPEED 1000000 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_3 #endif
/* load address */ @@ -157,7 +158,7 @@ #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0x100000 #define CONFIG_ENV_OFFSET_REDUND 0x180000 -#define CONFIG_ENV_SIZE 0x20000 /* 1 sector = 128 kB */ +#define CONFIG_ENV_SIZE (SZ_128K) /* 1 sector = 128 kB */ #define CONFIG_BOOTCOMMAND "nand read 0x22000000 0x200000 0x300000; bootm"
#if defined(CONFIG_BOARD_TAURUS) @@ -241,7 +242,7 @@ * Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN \ - ROUND(3 * CONFIG_ENV_SIZE + 128*1024, 0x1000) + ROUND(3 * CONFIG_ENV_SIZE + SZ_128K, 0x1000)
/* Defines for SPL */ #define CONFIG_SPL_FRAMEWORK @@ -253,7 +254,7 @@ #define CONFIG_SYS_SPL_MALLOC_SIZE CONFIG_SYS_MALLOC_LEN
#define CONFIG_SPL_BSS_START_ADDR CONFIG_SPL_MAX_SIZE -#define CONFIG_SPL_BSS_MAX_SIZE (3 * 1024) +#define CONFIG_SPL_BSS_MAX_SIZE (3 * SZ_512)
#define CONFIG_SPL_LIBCOMMON_SUPPORT #define CONFIG_SPL_LIBGENERIC_SUPPORT @@ -275,9 +276,9 @@ #define CONFIG_SYS_NAND_U_BOOT_DST CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_NAND_5_ADDR_CYCLE
-#define CONFIG_SYS_NAND_SIZE (256*1024*1024) -#define CONFIG_SYS_NAND_PAGE_SIZE 2048 -#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) +#define CONFIG_SYS_NAND_SIZE (256 * SZ_1M) +#define CONFIG_SYS_NAND_PAGE_SIZE SZ_2K +#define CONFIG_SYS_NAND_BLOCK_SIZE (SZ_128K) #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ CONFIG_SYS_NAND_PAGE_SIZE) #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS
Dear Heiko Schocher,
Heiko Schocher hs@denx.de writes:
taurus changes:
Changes in v3:
Changes in v2:
applied to u-boot-atmel/master, thanks!
Best regards, Andreas Bießmann
Andreas Bießmann
Heiko Schocher
