[PATCH v2 0/2] *** Add support for phyCORE-AM62x ***
As requested by Dhruva, this patch set comes now with a cover-letter :). This is a rebase on top of -next to address recent K3 updates.
It should be noted that the huge files are generated or copy pasted from TI's evm. So I do not think they need big attention in the review process.
- All yaml files are identical to TI's evm - k3-am62-phycore-som-ddr4-2gb.dtsi generated with TI's SysConfig DDR Tool - k3-am62-phycore-som.dtsi & k3-am625-phyboard-lyra-rdk.dts are 1:1 copies from Linux v6.7-rc3
v2: - Add cover-letter & mention Linux version I took the DTs from - Move board selection to mach-k3 - Add missing SPL_LDSCRIPT definition - Refactore binman file for templated FITs & drop key overrides - Drop SoC provided bootph params from dt files Note: Later we can drop more bootph params after we added them to Linux - Drop CONFIG_TI_SECURE_DEVICE as it is set as default for K3 - Drop cpsw3g custom DT property 'mac_efuse' and custom DT node cpsw-phy-sel as driver picks these from standard property/node (-u-boot.dtsi) - Add a53 cluster power to control from the rproc driver (a53 dt node)
v1: https://lists.denx.de/pipermail/u-boot/2023-October/535750.html
Wadim Egorov (2): board: phytec: am62x: Add PHYTEC phyCORE-AM62x SoM doc: board: phytec: Add phyCORE-AM62x
arch/arm/dts/Makefile | 4 +- .../arm/dts/k3-am62-phycore-som-ddr4-2gb.dtsi | 2190 +++++++++++++++++ arch/arm/dts/k3-am62-phycore-som.dtsi | 324 +++ .../k3-am625-phyboard-lyra-rdk-u-boot.dtsi | 166 ++ arch/arm/dts/k3-am625-phyboard-lyra-rdk.dts | 266 ++ arch/arm/dts/k3-am625-phycore-som-binman.dtsi | 380 +++ arch/arm/dts/k3-am625-r5-phycore-som-2gb.dts | 118 + arch/arm/mach-k3/am62x/Kconfig | 17 + board/phytec/phycore_am62x/Kconfig | 33 + board/phytec/phycore_am62x/MAINTAINERS | 15 + board/phytec/phycore_am62x/Makefile | 8 + board/phytec/phycore_am62x/board-cfg.yaml | 36 + board/phytec/phycore_am62x/phycore-am62x.c | 59 + board/phytec/phycore_am62x/phycore_am62x.env | 23 + board/phytec/phycore_am62x/pm-cfg.yaml | 12 + board/phytec/phycore_am62x/rm-cfg.yaml | 1088 ++++++++ board/phytec/phycore_am62x/sec-cfg.yaml | 379 +++ configs/phycore_am62x_a53_defconfig | 115 + configs/phycore_am62x_r5_defconfig | 130 + doc/board/phytec/index.rst | 1 + doc/board/phytec/phycore-am62x.rst | 125 + doc/board/ti/k3.rst | 1 + include/configs/phycore_am62x.h | 15 + 23 files changed, 5504 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/k3-am62-phycore-som-ddr4-2gb.dtsi create mode 100644 arch/arm/dts/k3-am62-phycore-som.dtsi create mode 100644 arch/arm/dts/k3-am625-phyboard-lyra-rdk-u-boot.dtsi create mode 100644 arch/arm/dts/k3-am625-phyboard-lyra-rdk.dts create mode 100644 arch/arm/dts/k3-am625-phycore-som-binman.dtsi create mode 100644 arch/arm/dts/k3-am625-r5-phycore-som-2gb.dts create mode 100644 board/phytec/phycore_am62x/Kconfig create mode 100644 board/phytec/phycore_am62x/MAINTAINERS create mode 100644 board/phytec/phycore_am62x/Makefile create mode 100644 board/phytec/phycore_am62x/board-cfg.yaml create mode 100644 board/phytec/phycore_am62x/phycore-am62x.c create mode 100644 board/phytec/phycore_am62x/phycore_am62x.env create mode 100644 board/phytec/phycore_am62x/pm-cfg.yaml create mode 100644 board/phytec/phycore_am62x/rm-cfg.yaml create mode 100644 board/phytec/phycore_am62x/sec-cfg.yaml create mode 100644 configs/phycore_am62x_a53_defconfig create mode 100644 configs/phycore_am62x_r5_defconfig create mode 100644 doc/board/phytec/phycore-am62x.rst create mode 100644 include/configs/phycore_am62x.h
Add basic support for PHYTEC phyCORE-AM62x SoM.
Supported features: - 2GB DDR4 RAM - eMMC Flash - OSPI NOR Flash - external uSD - Ethernet - debug UART
Product page SoM: https://www.phytec.com/product/phycore-am62x
Device trees were taken from Linux v6.7-rc3.
Signed-off-by: Wadim Egorov w.egorov@phytec.de --- v2: - Add cover-letter & mention Linux version I took the DTs from - Move board selection to mach-k3 - Add missing SPL_LDSCRIPT definition - Refactore binman file for templated FITs & drop key overrides - Drop SoC provided bootph params from dt files Note: Later we can drop more bootph params after we added them to Linux - Drop CONFIG_TI_SECURE_DEVICE as it is set as default for K3 - Drop cpsw3g custom DT property 'mac_efuse' and custom DT node cpsw-phy-sel as driver picks these from standard property/node (-u-boot.dtsi) - Add a53 cluster power to control from the rproc driver (a53 dt node)
--- arch/arm/dts/Makefile | 4 +- .../arm/dts/k3-am62-phycore-som-ddr4-2gb.dtsi | 2190 +++++++++++++++++ arch/arm/dts/k3-am62-phycore-som.dtsi | 324 +++ .../k3-am625-phyboard-lyra-rdk-u-boot.dtsi | 166 ++ arch/arm/dts/k3-am625-phyboard-lyra-rdk.dts | 266 ++ arch/arm/dts/k3-am625-phycore-som-binman.dtsi | 380 +++ arch/arm/dts/k3-am625-r5-phycore-som-2gb.dts | 119 + arch/arm/mach-k3/am62x/Kconfig | 17 + board/phytec/phycore_am62x/Kconfig | 33 + board/phytec/phycore_am62x/MAINTAINERS | 15 + board/phytec/phycore_am62x/Makefile | 8 + board/phytec/phycore_am62x/board-cfg.yaml | 36 + board/phytec/phycore_am62x/phycore-am62x.c | 59 + board/phytec/phycore_am62x/phycore_am62x.env | 23 + board/phytec/phycore_am62x/pm-cfg.yaml | 12 + board/phytec/phycore_am62x/rm-cfg.yaml | 1088 ++++++++ board/phytec/phycore_am62x/sec-cfg.yaml | 379 +++ configs/phycore_am62x_a53_defconfig | 115 + configs/phycore_am62x_r5_defconfig | 130 + include/configs/phycore_am62x.h | 15 + 20 files changed, 5378 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/k3-am62-phycore-som-ddr4-2gb.dtsi create mode 100644 arch/arm/dts/k3-am62-phycore-som.dtsi create mode 100644 arch/arm/dts/k3-am625-phyboard-lyra-rdk-u-boot.dtsi create mode 100644 arch/arm/dts/k3-am625-phyboard-lyra-rdk.dts create mode 100644 arch/arm/dts/k3-am625-phycore-som-binman.dtsi create mode 100644 arch/arm/dts/k3-am625-r5-phycore-som-2gb.dts create mode 100644 board/phytec/phycore_am62x/Kconfig create mode 100644 board/phytec/phycore_am62x/MAINTAINERS create mode 100644 board/phytec/phycore_am62x/Makefile create mode 100644 board/phytec/phycore_am62x/board-cfg.yaml create mode 100644 board/phytec/phycore_am62x/phycore-am62x.c create mode 100644 board/phytec/phycore_am62x/phycore_am62x.env create mode 100644 board/phytec/phycore_am62x/pm-cfg.yaml create mode 100644 board/phytec/phycore_am62x/rm-cfg.yaml create mode 100644 board/phytec/phycore_am62x/sec-cfg.yaml create mode 100644 configs/phycore_am62x_a53_defconfig create mode 100644 configs/phycore_am62x_r5_defconfig create mode 100644 include/configs/phycore_am62x.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index ea420db1b8..0496d281f7 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1418,7 +1418,9 @@ dtb-$(CONFIG_SOC_K3_AM625) += k3-am625-sk.dtb \ k3-am625-beagleplay.dtb \ k3-am625-r5-beagleplay.dtb \ k3-am625-verdin-wifi-dev.dtb \ - k3-am625-verdin-r5.dtb + k3-am625-verdin-r5.dtb \ + k3-am625-phyboard-lyra-rdk.dtb \ + k3-am625-r5-phycore-som-2gb.dtb
dtb-$(CONFIG_SOC_K3_AM62A7) += k3-am62a7-sk.dtb \ k3-am62a7-r5-sk.dtb diff --git a/arch/arm/dts/k3-am62-phycore-som-ddr4-2gb.dtsi b/arch/arm/dts/k3-am62-phycore-som-ddr4-2gb.dtsi new file mode 100644 index 0000000000..235cb99530 --- /dev/null +++ b/arch/arm/dts/k3-am62-phycore-som-ddr4-2gb.dtsi @@ -0,0 +1,2190 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * This file was generated with the + * AM62x SysConfig DDR Subsystem Register Configuration Tool v0.09.05 + * Fri Feb 03 2023 10:59:20 GMT+0100 (Mitteleuropäische Normalzeit) + * DDR Type: DDR4 + * Frequency = 800MHz (1600MTs) + * Density: 16Gb + * Number of Ranks: 1 +*/ + +#define DDRSS_PLL_FHS_CNT 6 +#define DDRSS_PLL_FREQUENCY_1 400000000 +#define DDRSS_PLL_FREQUENCY_2 400000000 + + +#define DDRSS_CTL_0_DATA 0x00000A00 +#define DDRSS_CTL_1_DATA 0x00000000 +#define DDRSS_CTL_2_DATA 0x00000000 +#define DDRSS_CTL_3_DATA 0x00000000 +#define DDRSS_CTL_4_DATA 0x00000000 +#define DDRSS_CTL_5_DATA 0x00000000 +#define DDRSS_CTL_6_DATA 0x00000000 +#define DDRSS_CTL_7_DATA 0x000890B8 +#define DDRSS_CTL_8_DATA 0x00000000 +#define DDRSS_CTL_9_DATA 0x00000000 +#define DDRSS_CTL_10_DATA 0x00000000 +#define DDRSS_CTL_11_DATA 0x000890B8 +#define DDRSS_CTL_12_DATA 0x00000000 +#define DDRSS_CTL_13_DATA 0x00000000 +#define DDRSS_CTL_14_DATA 0x00000000 +#define DDRSS_CTL_15_DATA 0x000890B8 +#define DDRSS_CTL_16_DATA 0x00000000 +#define DDRSS_CTL_17_DATA 0x00000000 +#define DDRSS_CTL_18_DATA 0x00000000 +#define DDRSS_CTL_19_DATA 0x01010100 +#define DDRSS_CTL_20_DATA 0x01000100 +#define DDRSS_CTL_21_DATA 0x01000110 +#define DDRSS_CTL_22_DATA 0x02010002 +#define DDRSS_CTL_23_DATA 0x00027100 +#define DDRSS_CTL_24_DATA 0x00061A80 +#define DDRSS_CTL_25_DATA 0x02550255 +#define DDRSS_CTL_26_DATA 0x00000255 +#define DDRSS_CTL_27_DATA 0x00000000 +#define DDRSS_CTL_28_DATA 0x00000000 +#define DDRSS_CTL_29_DATA 0x00000000 +#define DDRSS_CTL_30_DATA 0x00000000 +#define DDRSS_CTL_31_DATA 0x00000000 +#define DDRSS_CTL_32_DATA 0x00000000 +#define DDRSS_CTL_33_DATA 0x00000000 +#define DDRSS_CTL_34_DATA 0x00000000 +#define DDRSS_CTL_35_DATA 0x00000000 +#define DDRSS_CTL_36_DATA 0x00000000 +#define DDRSS_CTL_37_DATA 0x00000000 +#define DDRSS_CTL_38_DATA 0x0400091C +#define DDRSS_CTL_39_DATA 0x1C1C1C1C +#define DDRSS_CTL_40_DATA 0x0400091C +#define DDRSS_CTL_41_DATA 0x1C1C1C1C +#define DDRSS_CTL_42_DATA 0x0400091C +#define DDRSS_CTL_43_DATA 0x1C1C1C1C +#define DDRSS_CTL_44_DATA 0x05050404 +#define DDRSS_CTL_45_DATA 0x00002706 +#define DDRSS_CTL_46_DATA 0x0602001D +#define DDRSS_CTL_47_DATA 0x05001D0B +#define DDRSS_CTL_48_DATA 0x00270605 +#define DDRSS_CTL_49_DATA 0x0602001D +#define DDRSS_CTL_50_DATA 0x05001D0B +#define DDRSS_CTL_51_DATA 0x00270605 +#define DDRSS_CTL_52_DATA 0x0602001D +#define DDRSS_CTL_53_DATA 0x07001D0B +#define DDRSS_CTL_54_DATA 0x00180807 +#define DDRSS_CTL_55_DATA 0x04006DB0 +#define DDRSS_CTL_56_DATA 0x07070009 +#define DDRSS_CTL_57_DATA 0x00001808 +#define DDRSS_CTL_58_DATA 0x04006DB0 +#define DDRSS_CTL_59_DATA 0x07070009 +#define DDRSS_CTL_60_DATA 0x00001808 +#define DDRSS_CTL_61_DATA 0x04006DB0 +#define DDRSS_CTL_62_DATA 0x03000009 +#define DDRSS_CTL_63_DATA 0x0D0C0002 +#define DDRSS_CTL_64_DATA 0x0D0C0D0C +#define DDRSS_CTL_65_DATA 0x01010000 +#define DDRSS_CTL_66_DATA 0x03191919 +#define DDRSS_CTL_67_DATA 0x0B0B0B0B +#define DDRSS_CTL_68_DATA 0x00000B0B +#define DDRSS_CTL_69_DATA 0x00000101 +#define DDRSS_CTL_70_DATA 0x00000000 +#define DDRSS_CTL_71_DATA 0x01000000 +#define DDRSS_CTL_72_DATA 0x01180803 +#define DDRSS_CTL_73_DATA 0x00000C30 +#define DDRSS_CTL_74_DATA 0x00000118 +#define DDRSS_CTL_75_DATA 0x00000C30 +#define DDRSS_CTL_76_DATA 0x00000118 +#define DDRSS_CTL_77_DATA 0x00000C30 +#define DDRSS_CTL_78_DATA 0x00000005 +#define DDRSS_CTL_79_DATA 0x00000000 +#define DDRSS_CTL_80_DATA 0x00000000 +#define DDRSS_CTL_81_DATA 0x00000000 +#define DDRSS_CTL_82_DATA 0x00000000 +#define DDRSS_CTL_83_DATA 0x00000000 +#define DDRSS_CTL_84_DATA 0x00000000 +#define DDRSS_CTL_85_DATA 0x00000000 +#define DDRSS_CTL_86_DATA 0x00000000 +#define DDRSS_CTL_87_DATA 0x00090009 +#define DDRSS_CTL_88_DATA 0x00000009 +#define DDRSS_CTL_89_DATA 0x00000000 +#define DDRSS_CTL_90_DATA 0x00000000 +#define DDRSS_CTL_91_DATA 0x00000000 +#define DDRSS_CTL_92_DATA 0x00000000 +#define DDRSS_CTL_93_DATA 0x00000000 +#define DDRSS_CTL_94_DATA 0x00010001 +#define DDRSS_CTL_95_DATA 0x00025501 +#define DDRSS_CTL_96_DATA 0x02550120 +#define DDRSS_CTL_97_DATA 0x02550120 +#define DDRSS_CTL_98_DATA 0x01200120 +#define DDRSS_CTL_99_DATA 0x01200120 +#define DDRSS_CTL_100_DATA 0x00000000 +#define DDRSS_CTL_101_DATA 0x00000000 +#define DDRSS_CTL_102_DATA 0x00000000 +#define DDRSS_CTL_103_DATA 0x00000000 +#define DDRSS_CTL_104_DATA 0x00000000 +#define DDRSS_CTL_105_DATA 0x00000000 +#define DDRSS_CTL_106_DATA 0x03010000 +#define DDRSS_CTL_107_DATA 0x00010000 +#define DDRSS_CTL_108_DATA 0x00000000 +#define DDRSS_CTL_109_DATA 0x01000000 +#define DDRSS_CTL_110_DATA 0x80104002 +#define DDRSS_CTL_111_DATA 0x00040003 +#define DDRSS_CTL_112_DATA 0x00040005 +#define DDRSS_CTL_113_DATA 0x00030000 +#define DDRSS_CTL_114_DATA 0x00050004 +#define DDRSS_CTL_115_DATA 0x00000004 +#define DDRSS_CTL_116_DATA 0x00040003 +#define DDRSS_CTL_117_DATA 0x00040005 +#define DDRSS_CTL_118_DATA 0x00000000 +#define DDRSS_CTL_119_DATA 0x00030C00 +#define DDRSS_CTL_120_DATA 0x00030C00 +#define DDRSS_CTL_121_DATA 0x00030C00 +#define DDRSS_CTL_122_DATA 0x00030C00 +#define DDRSS_CTL_123_DATA 0x00030C00 +#define DDRSS_CTL_124_DATA 0x00000000 +#define DDRSS_CTL_125_DATA 0x00005550 +#define DDRSS_CTL_126_DATA 0x00030C00 +#define DDRSS_CTL_127_DATA 0x00030C00 +#define DDRSS_CTL_128_DATA 0x00030C00 +#define DDRSS_CTL_129_DATA 0x00030C00 +#define DDRSS_CTL_130_DATA 0x00030C00 +#define DDRSS_CTL_131_DATA 0x00000000 +#define DDRSS_CTL_132_DATA 0x00005550 +#define DDRSS_CTL_133_DATA 0x00030C00 +#define DDRSS_CTL_134_DATA 0x00030C00 +#define DDRSS_CTL_135_DATA 0x00030C00 +#define DDRSS_CTL_136_DATA 0x00030C00 +#define DDRSS_CTL_137_DATA 0x00030C00 +#define DDRSS_CTL_138_DATA 0x00000000 +#define DDRSS_CTL_139_DATA 0x00005550 +#define DDRSS_CTL_140_DATA 0x00000000 +#define DDRSS_CTL_141_DATA 0x00000000 +#define DDRSS_CTL_142_DATA 0x00000000 +#define DDRSS_CTL_143_DATA 0x00000000 +#define DDRSS_CTL_144_DATA 0x00000000 +#define DDRSS_CTL_145_DATA 0x00000000 +#define DDRSS_CTL_146_DATA 0x00000000 +#define DDRSS_CTL_147_DATA 0x00000000 +#define DDRSS_CTL_148_DATA 0x00000000 +#define DDRSS_CTL_149_DATA 0x00000000 +#define DDRSS_CTL_150_DATA 0x00000000 +#define DDRSS_CTL_151_DATA 0x00000000 +#define DDRSS_CTL_152_DATA 0x00000000 +#define DDRSS_CTL_153_DATA 0x00000000 +#define DDRSS_CTL_154_DATA 0x00000000 +#define DDRSS_CTL_155_DATA 0x00000000 +#define DDRSS_CTL_156_DATA 0x080C0000 +#define DDRSS_CTL_157_DATA 0x080C080C +#define DDRSS_CTL_158_DATA 0x08000000 +#define DDRSS_CTL_159_DATA 0x00000808 +#define DDRSS_CTL_160_DATA 0x000E0000 +#define DDRSS_CTL_161_DATA 0x00080808 +#define DDRSS_CTL_162_DATA 0x0E000000 +#define DDRSS_CTL_163_DATA 0x08080800 +#define DDRSS_CTL_164_DATA 0x00000000 +#define DDRSS_CTL_165_DATA 0x0000080E +#define DDRSS_CTL_166_DATA 0x00040003 +#define DDRSS_CTL_167_DATA 0x00000007 +#define DDRSS_CTL_168_DATA 0x00000000 +#define DDRSS_CTL_169_DATA 0x00000000 +#define DDRSS_CTL_170_DATA 0x00000000 +#define DDRSS_CTL_171_DATA 0x00000000 +#define DDRSS_CTL_172_DATA 0x00000000 +#define DDRSS_CTL_173_DATA 0x00000000 +#define DDRSS_CTL_174_DATA 0x01000000 +#define DDRSS_CTL_175_DATA 0x00000000 +#define DDRSS_CTL_176_DATA 0x00001500 +#define DDRSS_CTL_177_DATA 0x0000100E +#define DDRSS_CTL_178_DATA 0x00000000 +#define DDRSS_CTL_179_DATA 0x00000000 +#define DDRSS_CTL_180_DATA 0x00000001 +#define DDRSS_CTL_181_DATA 0x00000002 +#define DDRSS_CTL_182_DATA 0x00000C00 +#define DDRSS_CTL_183_DATA 0x00001000 +#define DDRSS_CTL_184_DATA 0x00000C00 +#define DDRSS_CTL_185_DATA 0x00001000 +#define DDRSS_CTL_186_DATA 0x00000C00 +#define DDRSS_CTL_187_DATA 0x00001000 +#define DDRSS_CTL_188_DATA 0x00000000 +#define DDRSS_CTL_189_DATA 0x00000000 +#define DDRSS_CTL_190_DATA 0x00000000 +#define DDRSS_CTL_191_DATA 0x00000000 +#define DDRSS_CTL_192_DATA 0x00000000 +#define DDRSS_CTL_193_DATA 0x00000000 +#define DDRSS_CTL_194_DATA 0x00000000 +#define DDRSS_CTL_195_DATA 0x00000000 +#define DDRSS_CTL_196_DATA 0x00000000 +#define DDRSS_CTL_197_DATA 0x00000000 +#define DDRSS_CTL_198_DATA 0x00000000 +#define DDRSS_CTL_199_DATA 0x00000000 +#define DDRSS_CTL_200_DATA 0x00000000 +#define DDRSS_CTL_201_DATA 0x00000000 +#define DDRSS_CTL_202_DATA 0x00000000 +#define DDRSS_CTL_203_DATA 0x00000000 +#define DDRSS_CTL_204_DATA 0x00042400 +#define DDRSS_CTL_205_DATA 0x00000301 +#define DDRSS_CTL_206_DATA 0x000000C0 +#define DDRSS_CTL_207_DATA 0x00000424 +#define DDRSS_CTL_208_DATA 0x00000301 +#define DDRSS_CTL_209_DATA 0x000000C0 +#define DDRSS_CTL_210_DATA 0x00000424 +#define DDRSS_CTL_211_DATA 0x00000301 +#define DDRSS_CTL_212_DATA 0x000000C0 +#define DDRSS_CTL_213_DATA 0x00000424 +#define DDRSS_CTL_214_DATA 0x00000301 +#define DDRSS_CTL_215_DATA 0x000000C0 +#define DDRSS_CTL_216_DATA 0x00000424 +#define DDRSS_CTL_217_DATA 0x00000301 +#define DDRSS_CTL_218_DATA 0x000000C0 +#define DDRSS_CTL_219_DATA 0x00000424 +#define DDRSS_CTL_220_DATA 0x00000301 +#define DDRSS_CTL_221_DATA 0x000000C0 +#define DDRSS_CTL_222_DATA 0x00000000 +#define DDRSS_CTL_223_DATA 0x00000000 +#define DDRSS_CTL_224_DATA 0x00000000 +#define DDRSS_CTL_225_DATA 0x00000000 +#define DDRSS_CTL_226_DATA 0x00000000 +#define DDRSS_CTL_227_DATA 0x00000000 +#define DDRSS_CTL_228_DATA 0x00000000 +#define DDRSS_CTL_229_DATA 0x00000000 +#define DDRSS_CTL_230_DATA 0x0000000C +#define DDRSS_CTL_231_DATA 0x0000000C +#define DDRSS_CTL_232_DATA 0x0000000C +#define DDRSS_CTL_233_DATA 0x0000000C +#define DDRSS_CTL_234_DATA 0x0000000C +#define DDRSS_CTL_235_DATA 0x0000000C +#define DDRSS_CTL_236_DATA 0x00001401 +#define DDRSS_CTL_237_DATA 0x00001401 +#define DDRSS_CTL_238_DATA 0x00001401 +#define DDRSS_CTL_239_DATA 0x00001401 +#define DDRSS_CTL_240_DATA 0x00001401 +#define DDRSS_CTL_241_DATA 0x00001401 +#define DDRSS_CTL_242_DATA 0x00000493 +#define DDRSS_CTL_243_DATA 0x00000493 +#define DDRSS_CTL_244_DATA 0x00000493 +#define DDRSS_CTL_245_DATA 0x00000493 +#define DDRSS_CTL_246_DATA 0x00000493 +#define DDRSS_CTL_247_DATA 0x00000493 +#define DDRSS_CTL_248_DATA 0x00000000 +#define DDRSS_CTL_249_DATA 0x00000000 +#define DDRSS_CTL_250_DATA 0x00000000 +#define DDRSS_CTL_251_DATA 0x00000000 +#define DDRSS_CTL_252_DATA 0x00000000 +#define DDRSS_CTL_253_DATA 0x00000000 +#define DDRSS_CTL_254_DATA 0x00000000 +#define DDRSS_CTL_255_DATA 0x00000000 +#define DDRSS_CTL_256_DATA 0x00000000 +#define DDRSS_CTL_257_DATA 0x00000000 +#define DDRSS_CTL_258_DATA 0x00000000 +#define DDRSS_CTL_259_DATA 0x00000000 +#define DDRSS_CTL_260_DATA 0x00000000 +#define DDRSS_CTL_261_DATA 0x00000000 +#define DDRSS_CTL_262_DATA 0x00000000 +#define DDRSS_CTL_263_DATA 0x00000000 +#define DDRSS_CTL_264_DATA 0x00000000 +#define DDRSS_CTL_265_DATA 0x00000000 +#define DDRSS_CTL_266_DATA 0x00000000 +#define DDRSS_CTL_267_DATA 0x00000000 +#define DDRSS_CTL_268_DATA 0x00000000 +#define DDRSS_CTL_269_DATA 0x00000000 +#define DDRSS_CTL_270_DATA 0x00000000 +#define DDRSS_CTL_271_DATA 0x00000000 +#define DDRSS_CTL_272_DATA 0x00000000 +#define DDRSS_CTL_273_DATA 0x00000000 +#define DDRSS_CTL_274_DATA 0x00000000 +#define DDRSS_CTL_275_DATA 0x00000000 +#define DDRSS_CTL_276_DATA 0x00000000 +#define DDRSS_CTL_277_DATA 0x00010000 +#define DDRSS_CTL_278_DATA 0x00000000 +#define DDRSS_CTL_279_DATA 0x00000000 +#define DDRSS_CTL_280_DATA 0x00000000 +#define DDRSS_CTL_281_DATA 0x00000101 +#define DDRSS_CTL_282_DATA 0x00000000 +#define DDRSS_CTL_283_DATA 0x00000000 +#define DDRSS_CTL_284_DATA 0x00000000 +#define DDRSS_CTL_285_DATA 0x00000000 +#define DDRSS_CTL_286_DATA 0x00000000 +#define DDRSS_CTL_287_DATA 0x00000000 +#define DDRSS_CTL_288_DATA 0x00000000 +#define DDRSS_CTL_289_DATA 0x00000000 +#define DDRSS_CTL_290_DATA 0x0C181511 +#define DDRSS_CTL_291_DATA 0x00000304 +#define DDRSS_CTL_292_DATA 0x00000000 +#define DDRSS_CTL_293_DATA 0x00000000 +#define DDRSS_CTL_294_DATA 0x00000000 +#define DDRSS_CTL_295_DATA 0x00000000 +#define DDRSS_CTL_296_DATA 0x00000000 +#define DDRSS_CTL_297_DATA 0x00000000 +#define DDRSS_CTL_298_DATA 0x00000000 +#define DDRSS_CTL_299_DATA 0x00000000 +#define DDRSS_CTL_300_DATA 0x00000000 +#define DDRSS_CTL_301_DATA 0x00000000 +#define DDRSS_CTL_302_DATA 0x00000000 +#define DDRSS_CTL_303_DATA 0x00000000 +#define DDRSS_CTL_304_DATA 0x00000000 +#define DDRSS_CTL_305_DATA 0x00040000 +#define DDRSS_CTL_306_DATA 0x00800200 +#define DDRSS_CTL_307_DATA 0x00000000 +#define DDRSS_CTL_308_DATA 0x02000400 +#define DDRSS_CTL_309_DATA 0x00000080 +#define DDRSS_CTL_310_DATA 0x00040000 +#define DDRSS_CTL_311_DATA 0x00800200 +#define DDRSS_CTL_312_DATA 0x00000000 +#define DDRSS_CTL_313_DATA 0x00000000 +#define DDRSS_CTL_314_DATA 0x00000000 +#define DDRSS_CTL_315_DATA 0x00000100 +#define DDRSS_CTL_316_DATA 0x01010000 +#define DDRSS_CTL_317_DATA 0x00000000 +#define DDRSS_CTL_318_DATA 0x3FFF0000 +#define DDRSS_CTL_319_DATA 0x000FFF00 +#define DDRSS_CTL_320_DATA 0xFFFFFFFF +#define DDRSS_CTL_321_DATA 0x00FFFF00 +#define DDRSS_CTL_322_DATA 0x0A000000 +#define DDRSS_CTL_323_DATA 0x0001FFFF +#define DDRSS_CTL_324_DATA 0x01010101 +#define DDRSS_CTL_325_DATA 0x01010101 +#define DDRSS_CTL_326_DATA 0x00000118 +#define DDRSS_CTL_327_DATA 0x00000C01 +#define DDRSS_CTL_328_DATA 0x00000000 +#define DDRSS_CTL_329_DATA 0x00000000 +#define DDRSS_CTL_330_DATA 0x00000000 +#define DDRSS_CTL_331_DATA 0x01000000 +#define DDRSS_CTL_332_DATA 0x00000100 +#define DDRSS_CTL_333_DATA 0x00010000 +#define DDRSS_CTL_334_DATA 0x00000000 +#define DDRSS_CTL_335_DATA 0x00000000 +#define DDRSS_CTL_336_DATA 0x00000000 +#define DDRSS_CTL_337_DATA 0x00000000 +#define DDRSS_CTL_338_DATA 0x00000000 +#define DDRSS_CTL_339_DATA 0x00000000 +#define DDRSS_CTL_340_DATA 0x00000000 +#define DDRSS_CTL_341_DATA 0x00000000 +#define DDRSS_CTL_342_DATA 0x00000000 +#define DDRSS_CTL_343_DATA 0x00000000 +#define DDRSS_CTL_344_DATA 0x00000000 +#define DDRSS_CTL_345_DATA 0x00000000 +#define DDRSS_CTL_346_DATA 0x00000000 +#define DDRSS_CTL_347_DATA 0x00000000 +#define DDRSS_CTL_348_DATA 0x00000000 +#define DDRSS_CTL_349_DATA 0x00000000 +#define DDRSS_CTL_350_DATA 0x00000000 +#define DDRSS_CTL_351_DATA 0x00000000 +#define DDRSS_CTL_352_DATA 0x00000000 +#define DDRSS_CTL_353_DATA 0x00000000 +#define DDRSS_CTL_354_DATA 0x00000000 +#define DDRSS_CTL_355_DATA 0x00000000 +#define DDRSS_CTL_356_DATA 0x00000000 +#define DDRSS_CTL_357_DATA 0x00000000 +#define DDRSS_CTL_358_DATA 0x00000000 +#define DDRSS_CTL_359_DATA 0x00000000 +#define DDRSS_CTL_360_DATA 0x00000000 +#define DDRSS_CTL_361_DATA 0x00000000 +#define DDRSS_CTL_362_DATA 0x00000000 +#define DDRSS_CTL_363_DATA 0x00000000 +#define DDRSS_CTL_364_DATA 0x00000000 +#define DDRSS_CTL_365_DATA 0x00000000 +#define DDRSS_CTL_366_DATA 0x00000000 +#define DDRSS_CTL_367_DATA 0x00000000 +#define DDRSS_CTL_368_DATA 0x00000000 +#define DDRSS_CTL_369_DATA 0x00000000 +#define DDRSS_CTL_370_DATA 0x0C000000 +#define DDRSS_CTL_371_DATA 0x060C0606 +#define DDRSS_CTL_372_DATA 0x06060C06 +#define DDRSS_CTL_373_DATA 0x00010101 +#define DDRSS_CTL_374_DATA 0x02000000 +#define DDRSS_CTL_375_DATA 0x05020101 +#define DDRSS_CTL_376_DATA 0x00000505 +#define DDRSS_CTL_377_DATA 0x02020200 +#define DDRSS_CTL_378_DATA 0x02020202 +#define DDRSS_CTL_379_DATA 0x02020202 +#define DDRSS_CTL_380_DATA 0x02020202 +#define DDRSS_CTL_381_DATA 0x00000000 +#define DDRSS_CTL_382_DATA 0x00000000 +#define DDRSS_CTL_383_DATA 0x04000100 +#define DDRSS_CTL_384_DATA 0x1E000004 +#define DDRSS_CTL_385_DATA 0x00001860 +#define DDRSS_CTL_386_DATA 0x00000200 +#define DDRSS_CTL_387_DATA 0x00000200 +#define DDRSS_CTL_388_DATA 0x00000200 +#define DDRSS_CTL_389_DATA 0x00000200 +#define DDRSS_CTL_390_DATA 0x00006DB0 +#define DDRSS_CTL_391_DATA 0x0000F3C0 +#define DDRSS_CTL_392_DATA 0x0C0D0302 +#define DDRSS_CTL_393_DATA 0x001E090A +#define DDRSS_CTL_394_DATA 0x00001860 +#define DDRSS_CTL_395_DATA 0x00000200 +#define DDRSS_CTL_396_DATA 0x00000200 +#define DDRSS_CTL_397_DATA 0x00000200 +#define DDRSS_CTL_398_DATA 0x00000200 +#define DDRSS_CTL_399_DATA 0x00006DB0 +#define DDRSS_CTL_400_DATA 0x0000F3C0 +#define DDRSS_CTL_401_DATA 0x0C0D0302 +#define DDRSS_CTL_402_DATA 0x001E090A +#define DDRSS_CTL_403_DATA 0x00001860 +#define DDRSS_CTL_404_DATA 0x00000200 +#define DDRSS_CTL_405_DATA 0x00000200 +#define DDRSS_CTL_406_DATA 0x00000200 +#define DDRSS_CTL_407_DATA 0x00000200 +#define DDRSS_CTL_408_DATA 0x00006DB0 +#define DDRSS_CTL_409_DATA 0x0000F3C0 +#define DDRSS_CTL_410_DATA 0x0C0D0302 +#define DDRSS_CTL_411_DATA 0x0000090A +#define DDRSS_CTL_412_DATA 0x00000000 +#define DDRSS_CTL_413_DATA 0x0302000A +#define DDRSS_CTL_414_DATA 0x01000500 +#define DDRSS_CTL_415_DATA 0x01010001 +#define DDRSS_CTL_416_DATA 0x00010001 +#define DDRSS_CTL_417_DATA 0x01010001 +#define DDRSS_CTL_418_DATA 0x02010000 +#define DDRSS_CTL_419_DATA 0x00000200 +#define DDRSS_CTL_420_DATA 0x02000201 +#define DDRSS_CTL_421_DATA 0x00000000 +#define DDRSS_CTL_422_DATA 0x00202020 +#define DDRSS_PI_0_DATA 0x00000A00 +#define DDRSS_PI_1_DATA 0x00000000 +#define DDRSS_PI_2_DATA 0x00000000 +#define DDRSS_PI_3_DATA 0x01000000 +#define DDRSS_PI_4_DATA 0x00000001 +#define DDRSS_PI_5_DATA 0x00010064 +#define DDRSS_PI_6_DATA 0x00000000 +#define DDRSS_PI_7_DATA 0x00000000 +#define DDRSS_PI_8_DATA 0x00000000 +#define DDRSS_PI_9_DATA 0x00000000 +#define DDRSS_PI_10_DATA 0x00000000 +#define DDRSS_PI_11_DATA 0x00000000 +#define DDRSS_PI_12_DATA 0x00000000 +#define DDRSS_PI_13_DATA 0x00010001 +#define DDRSS_PI_14_DATA 0x00000000 +#define DDRSS_PI_15_DATA 0x00010001 +#define DDRSS_PI_16_DATA 0x00000005 +#define DDRSS_PI_17_DATA 0x00000000 +#define DDRSS_PI_18_DATA 0x00000000 +#define DDRSS_PI_19_DATA 0x00000000 +#define DDRSS_PI_20_DATA 0x00000000 +#define DDRSS_PI_21_DATA 0x00000000 +#define DDRSS_PI_22_DATA 0x00000000 +#define DDRSS_PI_23_DATA 0x00000000 +#define DDRSS_PI_24_DATA 0x280D0001 +#define DDRSS_PI_25_DATA 0x00000000 +#define DDRSS_PI_26_DATA 0x00010000 +#define DDRSS_PI_27_DATA 0x00003200 +#define DDRSS_PI_28_DATA 0x00000000 +#define DDRSS_PI_29_DATA 0x00000000 +#define DDRSS_PI_30_DATA 0x00060602 +#define DDRSS_PI_31_DATA 0x00000000 +#define DDRSS_PI_32_DATA 0x00000000 +#define DDRSS_PI_33_DATA 0x00000000 +#define DDRSS_PI_34_DATA 0x00000001 +#define DDRSS_PI_35_DATA 0x00000055 +#define DDRSS_PI_36_DATA 0x000000AA +#define DDRSS_PI_37_DATA 0x000000AD +#define DDRSS_PI_38_DATA 0x00000052 +#define DDRSS_PI_39_DATA 0x0000006A +#define DDRSS_PI_40_DATA 0x00000095 +#define DDRSS_PI_41_DATA 0x00000095 +#define DDRSS_PI_42_DATA 0x000000AD +#define DDRSS_PI_43_DATA 0x00000000 +#define DDRSS_PI_44_DATA 0x00000000 +#define DDRSS_PI_45_DATA 0x00010100 +#define DDRSS_PI_46_DATA 0x00000014 +#define DDRSS_PI_47_DATA 0x000007D0 +#define DDRSS_PI_48_DATA 0x00000300 +#define DDRSS_PI_49_DATA 0x00000000 +#define DDRSS_PI_50_DATA 0x00000000 +#define DDRSS_PI_51_DATA 0x01000000 +#define DDRSS_PI_52_DATA 0x00010101 +#define DDRSS_PI_53_DATA 0x01000000 +#define DDRSS_PI_54_DATA 0x00000000 +#define DDRSS_PI_55_DATA 0x00010000 +#define DDRSS_PI_56_DATA 0x00000000 +#define DDRSS_PI_57_DATA 0x00000000 +#define DDRSS_PI_58_DATA 0x00000000 +#define DDRSS_PI_59_DATA 0x00000000 +#define DDRSS_PI_60_DATA 0x00001400 +#define DDRSS_PI_61_DATA 0x00000000 +#define DDRSS_PI_62_DATA 0x01000000 +#define DDRSS_PI_63_DATA 0x00000404 +#define DDRSS_PI_64_DATA 0x00000001 +#define DDRSS_PI_65_DATA 0x0001010E +#define DDRSS_PI_66_DATA 0x02040100 +#define DDRSS_PI_67_DATA 0x00010000 +#define DDRSS_PI_68_DATA 0x00000034 +#define DDRSS_PI_69_DATA 0x00000000 +#define DDRSS_PI_70_DATA 0x00000000 +#define DDRSS_PI_71_DATA 0x00000000 +#define DDRSS_PI_72_DATA 0x00000000 +#define DDRSS_PI_73_DATA 0x00000000 +#define DDRSS_PI_74_DATA 0x00000000 +#define DDRSS_PI_75_DATA 0x00000005 +#define DDRSS_PI_76_DATA 0x01000000 +#define DDRSS_PI_77_DATA 0x04000100 +#define DDRSS_PI_78_DATA 0x00020000 +#define DDRSS_PI_79_DATA 0x00010002 +#define DDRSS_PI_80_DATA 0x00000001 +#define DDRSS_PI_81_DATA 0x00020001 +#define DDRSS_PI_82_DATA 0x00020002 +#define DDRSS_PI_83_DATA 0x00000000 +#define DDRSS_PI_84_DATA 0x00000000 +#define DDRSS_PI_85_DATA 0x00000000 +#define DDRSS_PI_86_DATA 0x00000000 +#define DDRSS_PI_87_DATA 0x00000000 +#define DDRSS_PI_88_DATA 0x00000000 +#define DDRSS_PI_89_DATA 0x00000000 +#define DDRSS_PI_90_DATA 0x00000000 +#define DDRSS_PI_91_DATA 0x00000300 +#define DDRSS_PI_92_DATA 0x0A090B0C +#define DDRSS_PI_93_DATA 0x04060708 +#define DDRSS_PI_94_DATA 0x01000005 +#define DDRSS_PI_95_DATA 0x00000800 +#define DDRSS_PI_96_DATA 0x00000000 +#define DDRSS_PI_97_DATA 0x00010008 +#define DDRSS_PI_98_DATA 0x00000000 +#define DDRSS_PI_99_DATA 0x0000AA00 +#define DDRSS_PI_100_DATA 0x00000000 +#define DDRSS_PI_101_DATA 0x00010000 +#define DDRSS_PI_102_DATA 0x00000000 +#define DDRSS_PI_103_DATA 0x00000000 +#define DDRSS_PI_104_DATA 0x00000000 +#define DDRSS_PI_105_DATA 0x00000000 +#define DDRSS_PI_106_DATA 0x00000000 +#define DDRSS_PI_107_DATA 0x00000000 +#define DDRSS_PI_108_DATA 0x00000000 +#define DDRSS_PI_109_DATA 0x00000000 +#define DDRSS_PI_110_DATA 0x00000000 +#define DDRSS_PI_111_DATA 0x00000000 +#define DDRSS_PI_112_DATA 0x00000000 +#define DDRSS_PI_113_DATA 0x00000000 +#define DDRSS_PI_114_DATA 0x00000000 +#define DDRSS_PI_115_DATA 0x00000000 +#define DDRSS_PI_116_DATA 0x00000000 +#define DDRSS_PI_117_DATA 0x00000000 +#define DDRSS_PI_118_DATA 0x00000000 +#define DDRSS_PI_119_DATA 0x00000000 +#define DDRSS_PI_120_DATA 0x00000000 +#define DDRSS_PI_121_DATA 0x00000000 +#define DDRSS_PI_122_DATA 0x00000000 +#define DDRSS_PI_123_DATA 0x00000000 +#define DDRSS_PI_124_DATA 0x00000008 +#define DDRSS_PI_125_DATA 0x00000000 +#define DDRSS_PI_126_DATA 0x00000000 +#define DDRSS_PI_127_DATA 0x00000000 +#define DDRSS_PI_128_DATA 0x00000000 +#define DDRSS_PI_129_DATA 0x00000000 +#define DDRSS_PI_130_DATA 0x00000000 +#define DDRSS_PI_131_DATA 0x00000000 +#define DDRSS_PI_132_DATA 0x00000000 +#define DDRSS_PI_133_DATA 0x00010100 +#define DDRSS_PI_134_DATA 0x00000000 +#define DDRSS_PI_135_DATA 0x00000000 +#define DDRSS_PI_136_DATA 0x00027100 +#define DDRSS_PI_137_DATA 0x00061A80 +#define DDRSS_PI_138_DATA 0x00000100 +#define DDRSS_PI_139_DATA 0x00000000 +#define DDRSS_PI_140_DATA 0x00000000 +#define DDRSS_PI_141_DATA 0x00000000 +#define DDRSS_PI_142_DATA 0x00000000 +#define DDRSS_PI_143_DATA 0x00000000 +#define DDRSS_PI_144_DATA 0x01000000 +#define DDRSS_PI_145_DATA 0x00010003 +#define DDRSS_PI_146_DATA 0x02000101 +#define DDRSS_PI_147_DATA 0x01030001 +#define DDRSS_PI_148_DATA 0x00010400 +#define DDRSS_PI_149_DATA 0x06000105 +#define DDRSS_PI_150_DATA 0x01070001 +#define DDRSS_PI_151_DATA 0x00000000 +#define DDRSS_PI_152_DATA 0x00000000 +#define DDRSS_PI_153_DATA 0x00000000 +#define DDRSS_PI_154_DATA 0x00010000 +#define DDRSS_PI_155_DATA 0x00000000 +#define DDRSS_PI_156_DATA 0x00000000 +#define DDRSS_PI_157_DATA 0x00000000 +#define DDRSS_PI_158_DATA 0x00000000 +#define DDRSS_PI_159_DATA 0x00010000 +#define DDRSS_PI_160_DATA 0x00000004 +#define DDRSS_PI_161_DATA 0x00000000 +#define DDRSS_PI_162_DATA 0x00000000 +#define DDRSS_PI_163_DATA 0x00000000 +#define DDRSS_PI_164_DATA 0x00007800 +#define DDRSS_PI_165_DATA 0x00780078 +#define DDRSS_PI_166_DATA 0x00141414 +#define DDRSS_PI_167_DATA 0x0000003A +#define DDRSS_PI_168_DATA 0x0000003A +#define DDRSS_PI_169_DATA 0x0004003A +#define DDRSS_PI_170_DATA 0x04000400 +#define DDRSS_PI_171_DATA 0xC8040009 +#define DDRSS_PI_172_DATA 0x0400091C +#define DDRSS_PI_173_DATA 0x00091CC8 +#define DDRSS_PI_174_DATA 0x001CC804 +#define DDRSS_PI_175_DATA 0x00000118 +#define DDRSS_PI_176_DATA 0x00000C30 +#define DDRSS_PI_177_DATA 0x00000118 +#define DDRSS_PI_178_DATA 0x00000C30 +#define DDRSS_PI_179_DATA 0x00000118 +#define DDRSS_PI_180_DATA 0x04000C30 +#define DDRSS_PI_181_DATA 0x01010404 +#define DDRSS_PI_182_DATA 0x00001901 +#define DDRSS_PI_183_DATA 0x00190019 +#define DDRSS_PI_184_DATA 0x010C010C +#define DDRSS_PI_185_DATA 0x0000010C +#define DDRSS_PI_186_DATA 0x00000000 +#define DDRSS_PI_187_DATA 0x05000000 +#define DDRSS_PI_188_DATA 0x01010505 +#define DDRSS_PI_189_DATA 0x01010101 +#define DDRSS_PI_190_DATA 0x00181818 +#define DDRSS_PI_191_DATA 0x00000000 +#define DDRSS_PI_192_DATA 0x00000000 +#define DDRSS_PI_193_DATA 0x0D000000 +#define DDRSS_PI_194_DATA 0x0A0A0D0D +#define DDRSS_PI_195_DATA 0x0303030A +#define DDRSS_PI_196_DATA 0x00000000 +#define DDRSS_PI_197_DATA 0x00000000 +#define DDRSS_PI_198_DATA 0x00000000 +#define DDRSS_PI_199_DATA 0x00000000 +#define DDRSS_PI_200_DATA 0x00000000 +#define DDRSS_PI_201_DATA 0x00000000 +#define DDRSS_PI_202_DATA 0x00000000 +#define DDRSS_PI_203_DATA 0x00000000 +#define DDRSS_PI_204_DATA 0x00000000 +#define DDRSS_PI_205_DATA 0x00000000 +#define DDRSS_PI_206_DATA 0x00000000 +#define DDRSS_PI_207_DATA 0x00000000 +#define DDRSS_PI_208_DATA 0x00000000 +#define DDRSS_PI_209_DATA 0x0D090000 +#define DDRSS_PI_210_DATA 0x0D09000D +#define DDRSS_PI_211_DATA 0x0D09000D +#define DDRSS_PI_212_DATA 0x0000000D +#define DDRSS_PI_213_DATA 0x00000000 +#define DDRSS_PI_214_DATA 0x00000000 +#define DDRSS_PI_215_DATA 0x00000000 +#define DDRSS_PI_216_DATA 0x00000000 +#define DDRSS_PI_217_DATA 0x16000000 +#define DDRSS_PI_218_DATA 0x001600C8 +#define DDRSS_PI_219_DATA 0x001600C8 +#define DDRSS_PI_220_DATA 0x010100C8 +#define DDRSS_PI_221_DATA 0x00001B01 +#define DDRSS_PI_222_DATA 0x1F0F0053 +#define DDRSS_PI_223_DATA 0x05000001 +#define DDRSS_PI_224_DATA 0x001B0A0D +#define DDRSS_PI_225_DATA 0x1F0F0053 +#define DDRSS_PI_226_DATA 0x05000001 +#define DDRSS_PI_227_DATA 0x001B0A0D +#define DDRSS_PI_228_DATA 0x1F0F0053 +#define DDRSS_PI_229_DATA 0x05000001 +#define DDRSS_PI_230_DATA 0x00010A0D +#define DDRSS_PI_231_DATA 0x0C0B0700 +#define DDRSS_PI_232_DATA 0x000D0605 +#define DDRSS_PI_233_DATA 0x000062B8 +#define DDRSS_PI_234_DATA 0x0000001D +#define DDRSS_PI_235_DATA 0x180A0800 +#define DDRSS_PI_236_DATA 0x0B071C1C +#define DDRSS_PI_237_DATA 0x0D06050C +#define DDRSS_PI_238_DATA 0x000062B8 +#define DDRSS_PI_239_DATA 0x0000001D +#define DDRSS_PI_240_DATA 0x180A0800 +#define DDRSS_PI_241_DATA 0x0B071C1C +#define DDRSS_PI_242_DATA 0x0D06050C +#define DDRSS_PI_243_DATA 0x000062B8 +#define DDRSS_PI_244_DATA 0x0000001D +#define DDRSS_PI_245_DATA 0x180A0800 +#define DDRSS_PI_246_DATA 0x00001C1C +#define DDRSS_PI_247_DATA 0x00001860 +#define DDRSS_PI_248_DATA 0x0000F3C0 +#define DDRSS_PI_249_DATA 0x00001860 +#define DDRSS_PI_250_DATA 0x0000F3C0 +#define DDRSS_PI_251_DATA 0x00001860 +#define DDRSS_PI_252_DATA 0x0000F3C0 +#define DDRSS_PI_253_DATA 0x02550255 +#define DDRSS_PI_254_DATA 0x03030255 +#define DDRSS_PI_255_DATA 0x00025503 +#define DDRSS_PI_256_DATA 0x02550255 +#define DDRSS_PI_257_DATA 0x0C080C08 +#define DDRSS_PI_258_DATA 0x00000C08 +#define DDRSS_PI_259_DATA 0x000890B8 +#define DDRSS_PI_260_DATA 0x00000000 +#define DDRSS_PI_261_DATA 0x00000000 +#define DDRSS_PI_262_DATA 0x00000000 +#define DDRSS_PI_263_DATA 0x00000120 +#define DDRSS_PI_264_DATA 0x000890B8 +#define DDRSS_PI_265_DATA 0x00000000 +#define DDRSS_PI_266_DATA 0x00000000 +#define DDRSS_PI_267_DATA 0x00000000 +#define DDRSS_PI_268_DATA 0x00000120 +#define DDRSS_PI_269_DATA 0x000890B8 +#define DDRSS_PI_270_DATA 0x00000000 +#define DDRSS_PI_271_DATA 0x00000000 +#define DDRSS_PI_272_DATA 0x00000000 +#define DDRSS_PI_273_DATA 0x02000120 +#define DDRSS_PI_274_DATA 0x00000080 +#define DDRSS_PI_275_DATA 0x00020000 +#define DDRSS_PI_276_DATA 0x00000080 +#define DDRSS_PI_277_DATA 0x00020000 +#define DDRSS_PI_278_DATA 0x00000080 +#define DDRSS_PI_279_DATA 0x00000000 +#define DDRSS_PI_280_DATA 0x00000000 +#define DDRSS_PI_281_DATA 0x00040404 +#define DDRSS_PI_282_DATA 0x00000000 +#define DDRSS_PI_283_DATA 0x02010102 +#define DDRSS_PI_284_DATA 0x67676767 +#define DDRSS_PI_285_DATA 0x00000202 +#define DDRSS_PI_286_DATA 0x00000000 +#define DDRSS_PI_287_DATA 0x00000000 +#define DDRSS_PI_288_DATA 0x00000000 +#define DDRSS_PI_289_DATA 0x00000000 +#define DDRSS_PI_290_DATA 0x00000000 +#define DDRSS_PI_291_DATA 0x0D100F00 +#define DDRSS_PI_292_DATA 0x0003020E +#define DDRSS_PI_293_DATA 0x00000001 +#define DDRSS_PI_294_DATA 0x01000000 +#define DDRSS_PI_295_DATA 0x00020201 +#define DDRSS_PI_296_DATA 0x00000000 +#define DDRSS_PI_297_DATA 0x00000424 +#define DDRSS_PI_298_DATA 0x00000301 +#define DDRSS_PI_299_DATA 0x000000C0 +#define DDRSS_PI_300_DATA 0x00000000 +#define DDRSS_PI_301_DATA 0x0000000C +#define DDRSS_PI_302_DATA 0x00001401 +#define DDRSS_PI_303_DATA 0x00000493 +#define DDRSS_PI_304_DATA 0x00000000 +#define DDRSS_PI_305_DATA 0x00000424 +#define DDRSS_PI_306_DATA 0x00000301 +#define DDRSS_PI_307_DATA 0x000000C0 +#define DDRSS_PI_308_DATA 0x00000000 +#define DDRSS_PI_309_DATA 0x0000000C +#define DDRSS_PI_310_DATA 0x00001401 +#define DDRSS_PI_311_DATA 0x00000493 +#define DDRSS_PI_312_DATA 0x00000000 +#define DDRSS_PI_313_DATA 0x00000424 +#define DDRSS_PI_314_DATA 0x00000301 +#define DDRSS_PI_315_DATA 0x000000C0 +#define DDRSS_PI_316_DATA 0x00000000 +#define DDRSS_PI_317_DATA 0x0000000C +#define DDRSS_PI_318_DATA 0x00001401 +#define DDRSS_PI_319_DATA 0x00000493 +#define DDRSS_PI_320_DATA 0x00000000 +#define DDRSS_PI_321_DATA 0x00000424 +#define DDRSS_PI_322_DATA 0x00000301 +#define DDRSS_PI_323_DATA 0x000000C0 +#define DDRSS_PI_324_DATA 0x00000000 +#define DDRSS_PI_325_DATA 0x0000000C +#define DDRSS_PI_326_DATA 0x00001401 +#define DDRSS_PI_327_DATA 0x00000493 +#define DDRSS_PI_328_DATA 0x00000000 +#define DDRSS_PI_329_DATA 0x00000424 +#define DDRSS_PI_330_DATA 0x00000301 +#define DDRSS_PI_331_DATA 0x000000C0 +#define DDRSS_PI_332_DATA 0x00000000 +#define DDRSS_PI_333_DATA 0x0000000C +#define DDRSS_PI_334_DATA 0x00001401 +#define DDRSS_PI_335_DATA 0x00000493 +#define DDRSS_PI_336_DATA 0x00000000 +#define DDRSS_PI_337_DATA 0x00000424 +#define DDRSS_PI_338_DATA 0x00000301 +#define DDRSS_PI_339_DATA 0x000000C0 +#define DDRSS_PI_340_DATA 0x00000000 +#define DDRSS_PI_341_DATA 0x0000000C +#define DDRSS_PI_342_DATA 0x00001401 +#define DDRSS_PI_343_DATA 0x00000493 +#define DDRSS_PI_344_DATA 0x00000000 +#define DDRSS_PHY_0_DATA 0x04C00000 +#define DDRSS_PHY_1_DATA 0x00000000 +#define DDRSS_PHY_2_DATA 0x00000200 +#define DDRSS_PHY_3_DATA 0x00000000 +#define DDRSS_PHY_4_DATA 0x00000000 +#define DDRSS_PHY_5_DATA 0x00000000 +#define DDRSS_PHY_6_DATA 0x00000000 +#define DDRSS_PHY_7_DATA 0x00000000 +#define DDRSS_PHY_8_DATA 0x00000001 +#define DDRSS_PHY_9_DATA 0x00000000 +#define DDRSS_PHY_10_DATA 0x00000000 +#define DDRSS_PHY_11_DATA 0x010101FF +#define DDRSS_PHY_12_DATA 0x00010000 +#define DDRSS_PHY_13_DATA 0x00C00004 +#define DDRSS_PHY_14_DATA 0x00CC0008 +#define DDRSS_PHY_15_DATA 0x00660201 +#define DDRSS_PHY_16_DATA 0x00000000 +#define DDRSS_PHY_17_DATA 0x00000000 +#define DDRSS_PHY_18_DATA 0x00000000 +#define DDRSS_PHY_19_DATA 0x0000AAAA +#define DDRSS_PHY_20_DATA 0x00005555 +#define DDRSS_PHY_21_DATA 0x0000B5B5 +#define DDRSS_PHY_22_DATA 0x00004A4A +#define DDRSS_PHY_23_DATA 0x00005656 +#define DDRSS_PHY_24_DATA 0x0000A9A9 +#define DDRSS_PHY_25_DATA 0x0000B7B7 +#define DDRSS_PHY_26_DATA 0x00004848 +#define DDRSS_PHY_27_DATA 0x00000000 +#define DDRSS_PHY_28_DATA 0x00000000 +#define DDRSS_PHY_29_DATA 0x08000000 +#define DDRSS_PHY_30_DATA 0x0F000008 +#define DDRSS_PHY_31_DATA 0x00000F0F +#define DDRSS_PHY_32_DATA 0x00E4E400 +#define DDRSS_PHY_33_DATA 0x00070820 +#define DDRSS_PHY_34_DATA 0x000C0020 +#define DDRSS_PHY_35_DATA 0x00062000 +#define DDRSS_PHY_36_DATA 0x00000000 +#define DDRSS_PHY_37_DATA 0x55555555 +#define DDRSS_PHY_38_DATA 0xAAAAAAAA +#define DDRSS_PHY_39_DATA 0x55555555 +#define DDRSS_PHY_40_DATA 0xAAAAAAAA +#define DDRSS_PHY_41_DATA 0x00005555 +#define DDRSS_PHY_42_DATA 0x01000100 +#define DDRSS_PHY_43_DATA 0x00800180 +#define DDRSS_PHY_44_DATA 0x00000000 +#define DDRSS_PHY_45_DATA 0x00000000 +#define DDRSS_PHY_46_DATA 0x00000000 +#define DDRSS_PHY_47_DATA 0x00000000 +#define DDRSS_PHY_48_DATA 0x00000000 +#define DDRSS_PHY_49_DATA 0x00000000 +#define DDRSS_PHY_50_DATA 0x00000000 +#define DDRSS_PHY_51_DATA 0x00000000 +#define DDRSS_PHY_52_DATA 0x00000000 +#define DDRSS_PHY_53_DATA 0x00000000 +#define DDRSS_PHY_54_DATA 0x00000000 +#define DDRSS_PHY_55_DATA 0x00000000 +#define DDRSS_PHY_56_DATA 0x00000000 +#define DDRSS_PHY_57_DATA 0x00000000 +#define DDRSS_PHY_58_DATA 0x00000000 +#define DDRSS_PHY_59_DATA 0x00000000 +#define DDRSS_PHY_60_DATA 0x00000000 +#define DDRSS_PHY_61_DATA 0x00000000 +#define DDRSS_PHY_62_DATA 0x00000000 +#define DDRSS_PHY_63_DATA 0x00000000 +#define DDRSS_PHY_64_DATA 0x00000000 +#define DDRSS_PHY_65_DATA 0x00000004 +#define DDRSS_PHY_66_DATA 0x00000000 +#define DDRSS_PHY_67_DATA 0x00000000 +#define DDRSS_PHY_68_DATA 0x00000000 +#define DDRSS_PHY_69_DATA 0x00000000 +#define DDRSS_PHY_70_DATA 0x00000000 +#define DDRSS_PHY_71_DATA 0x00000000 +#define DDRSS_PHY_72_DATA 0x041F07FF +#define DDRSS_PHY_73_DATA 0x00000000 +#define DDRSS_PHY_74_DATA 0x01CCB001 +#define DDRSS_PHY_75_DATA 0x2000CCB0 +#define DDRSS_PHY_76_DATA 0x20000140 +#define DDRSS_PHY_77_DATA 0x07FF0200 +#define DDRSS_PHY_78_DATA 0x0000DD01 +#define DDRSS_PHY_79_DATA 0x10100303 +#define DDRSS_PHY_80_DATA 0x10101010 +#define DDRSS_PHY_81_DATA 0x10101010 +#define DDRSS_PHY_82_DATA 0x00021010 +#define DDRSS_PHY_83_DATA 0x00100010 +#define DDRSS_PHY_84_DATA 0x00100010 +#define DDRSS_PHY_85_DATA 0x00100010 +#define DDRSS_PHY_86_DATA 0x00100010 +#define DDRSS_PHY_87_DATA 0x02020010 +#define DDRSS_PHY_88_DATA 0x51515041 +#define DDRSS_PHY_89_DATA 0x31804000 +#define DDRSS_PHY_90_DATA 0x04BF0340 +#define DDRSS_PHY_91_DATA 0x01008080 +#define DDRSS_PHY_92_DATA 0x04050001 +#define DDRSS_PHY_93_DATA 0x00000504 +#define DDRSS_PHY_94_DATA 0x42100010 +#define DDRSS_PHY_95_DATA 0x010C053E +#define DDRSS_PHY_96_DATA 0x000F0C14 +#define DDRSS_PHY_97_DATA 0x01000140 +#define DDRSS_PHY_98_DATA 0x007A0120 +#define DDRSS_PHY_99_DATA 0x00000C00 +#define DDRSS_PHY_100_DATA 0x000001CC +#define DDRSS_PHY_101_DATA 0x20100200 +#define DDRSS_PHY_102_DATA 0x00000005 +#define DDRSS_PHY_103_DATA 0x76543210 +#define DDRSS_PHY_104_DATA 0x00000008 +#define DDRSS_PHY_105_DATA 0x02800280 +#define DDRSS_PHY_106_DATA 0x02800280 +#define DDRSS_PHY_107_DATA 0x02800280 +#define DDRSS_PHY_108_DATA 0x02800280 +#define DDRSS_PHY_109_DATA 0x00000280 +#define DDRSS_PHY_110_DATA 0x00008000 +#define DDRSS_PHY_111_DATA 0x00800080 +#define DDRSS_PHY_112_DATA 0x00800080 +#define DDRSS_PHY_113_DATA 0x00800080 +#define DDRSS_PHY_114_DATA 0x00800080 +#define DDRSS_PHY_115_DATA 0x00800080 +#define DDRSS_PHY_116_DATA 0x00800080 +#define DDRSS_PHY_117_DATA 0x00800080 +#define DDRSS_PHY_118_DATA 0x00800080 +#define DDRSS_PHY_119_DATA 0x01000080 +#define DDRSS_PHY_120_DATA 0x01000000 +#define DDRSS_PHY_121_DATA 0x00000000 +#define DDRSS_PHY_122_DATA 0x00000000 +#define DDRSS_PHY_123_DATA 0x00080200 +#define DDRSS_PHY_124_DATA 0x00000000 +#define DDRSS_PHY_125_DATA 0x00000000 +#define DDRSS_PHY_126_DATA 0x00000000 +#define DDRSS_PHY_127_DATA 0x00000000 +#define DDRSS_PHY_128_DATA 0x00000000 +#define DDRSS_PHY_129_DATA 0x00000000 +#define DDRSS_PHY_130_DATA 0x00000000 +#define DDRSS_PHY_131_DATA 0x00000000 +#define DDRSS_PHY_132_DATA 0x00000000 +#define DDRSS_PHY_133_DATA 0x00000000 +#define DDRSS_PHY_134_DATA 0x00000000 +#define DDRSS_PHY_135_DATA 0x00000000 +#define DDRSS_PHY_136_DATA 0x00000000 +#define DDRSS_PHY_137_DATA 0x00000000 +#define DDRSS_PHY_138_DATA 0x00000000 +#define DDRSS_PHY_139_DATA 0x00000000 +#define DDRSS_PHY_140_DATA 0x00000000 +#define DDRSS_PHY_141_DATA 0x00000000 +#define DDRSS_PHY_142_DATA 0x00000000 +#define DDRSS_PHY_143_DATA 0x00000000 +#define DDRSS_PHY_144_DATA 0x00000000 +#define DDRSS_PHY_145_DATA 0x00000000 +#define DDRSS_PHY_146_DATA 0x00000000 +#define DDRSS_PHY_147_DATA 0x00000000 +#define DDRSS_PHY_148_DATA 0x00000000 +#define DDRSS_PHY_149_DATA 0x00000000 +#define DDRSS_PHY_150_DATA 0x00000000 +#define DDRSS_PHY_151_DATA 0x00000000 +#define DDRSS_PHY_152_DATA 0x00000000 +#define DDRSS_PHY_153_DATA 0x00000000 +#define DDRSS_PHY_154_DATA 0x00000000 +#define DDRSS_PHY_155_DATA 0x00000000 +#define DDRSS_PHY_156_DATA 0x00000000 +#define DDRSS_PHY_157_DATA 0x00000000 +#define DDRSS_PHY_158_DATA 0x00000000 +#define DDRSS_PHY_159_DATA 0x00000000 +#define DDRSS_PHY_160_DATA 0x00000000 +#define DDRSS_PHY_161_DATA 0x00000000 +#define DDRSS_PHY_162_DATA 0x00000000 +#define DDRSS_PHY_163_DATA 0x00000000 +#define DDRSS_PHY_164_DATA 0x00000000 +#define DDRSS_PHY_165_DATA 0x00000000 +#define DDRSS_PHY_166_DATA 0x00000000 +#define DDRSS_PHY_167_DATA 0x00000000 +#define DDRSS_PHY_168_DATA 0x00000000 +#define DDRSS_PHY_169_DATA 0x00000000 +#define DDRSS_PHY_170_DATA 0x00000000 +#define DDRSS_PHY_171_DATA 0x00000000 +#define DDRSS_PHY_172_DATA 0x00000000 +#define DDRSS_PHY_173_DATA 0x00000000 +#define DDRSS_PHY_174_DATA 0x00000000 +#define DDRSS_PHY_175_DATA 0x00000000 +#define DDRSS_PHY_176_DATA 0x00000000 +#define DDRSS_PHY_177_DATA 0x00000000 +#define DDRSS_PHY_178_DATA 0x00000000 +#define DDRSS_PHY_179_DATA 0x00000000 +#define DDRSS_PHY_180_DATA 0x00000000 +#define DDRSS_PHY_181_DATA 0x00000000 +#define DDRSS_PHY_182_DATA 0x00000000 +#define DDRSS_PHY_183_DATA 0x00000000 +#define DDRSS_PHY_184_DATA 0x00000000 +#define DDRSS_PHY_185_DATA 0x00000000 +#define DDRSS_PHY_186_DATA 0x00000000 +#define DDRSS_PHY_187_DATA 0x00000000 +#define DDRSS_PHY_188_DATA 0x00000000 +#define DDRSS_PHY_189_DATA 0x00000000 +#define DDRSS_PHY_190_DATA 0x00000000 +#define DDRSS_PHY_191_DATA 0x00000000 +#define DDRSS_PHY_192_DATA 0x00000000 +#define DDRSS_PHY_193_DATA 0x00000000 +#define DDRSS_PHY_194_DATA 0x00000000 +#define DDRSS_PHY_195_DATA 0x00000000 +#define DDRSS_PHY_196_DATA 0x00000000 +#define DDRSS_PHY_197_DATA 0x00000000 +#define DDRSS_PHY_198_DATA 0x00000000 +#define DDRSS_PHY_199_DATA 0x00000000 +#define DDRSS_PHY_200_DATA 0x00000000 +#define DDRSS_PHY_201_DATA 0x00000000 +#define DDRSS_PHY_202_DATA 0x00000000 +#define DDRSS_PHY_203_DATA 0x00000000 +#define DDRSS_PHY_204_DATA 0x00000000 +#define DDRSS_PHY_205_DATA 0x00000000 +#define DDRSS_PHY_206_DATA 0x00000000 +#define DDRSS_PHY_207_DATA 0x00000000 +#define DDRSS_PHY_208_DATA 0x00000000 +#define DDRSS_PHY_209_DATA 0x00000000 +#define DDRSS_PHY_210_DATA 0x00000000 +#define DDRSS_PHY_211_DATA 0x00000000 +#define DDRSS_PHY_212_DATA 0x00000000 +#define DDRSS_PHY_213_DATA 0x00000000 +#define DDRSS_PHY_214_DATA 0x00000000 +#define DDRSS_PHY_215_DATA 0x00000000 +#define DDRSS_PHY_216_DATA 0x00000000 +#define DDRSS_PHY_217_DATA 0x00000000 +#define DDRSS_PHY_218_DATA 0x00000000 +#define DDRSS_PHY_219_DATA 0x00000000 +#define DDRSS_PHY_220_DATA 0x00000000 +#define DDRSS_PHY_221_DATA 0x00000000 +#define DDRSS_PHY_222_DATA 0x00000000 +#define DDRSS_PHY_223_DATA 0x00000000 +#define DDRSS_PHY_224_DATA 0x00000000 +#define DDRSS_PHY_225_DATA 0x00000000 +#define DDRSS_PHY_226_DATA 0x00000000 +#define DDRSS_PHY_227_DATA 0x00000000 +#define DDRSS_PHY_228_DATA 0x00000000 +#define DDRSS_PHY_229_DATA 0x00000000 +#define DDRSS_PHY_230_DATA 0x00000000 +#define DDRSS_PHY_231_DATA 0x00000000 +#define DDRSS_PHY_232_DATA 0x00000000 +#define DDRSS_PHY_233_DATA 0x00000000 +#define DDRSS_PHY_234_DATA 0x00000000 +#define DDRSS_PHY_235_DATA 0x00000000 +#define DDRSS_PHY_236_DATA 0x00000000 +#define DDRSS_PHY_237_DATA 0x00000000 +#define DDRSS_PHY_238_DATA 0x00000000 +#define DDRSS_PHY_239_DATA 0x00000000 +#define DDRSS_PHY_240_DATA 0x00000000 +#define DDRSS_PHY_241_DATA 0x00000000 +#define DDRSS_PHY_242_DATA 0x00000000 +#define DDRSS_PHY_243_DATA 0x00000000 +#define DDRSS_PHY_244_DATA 0x00000000 +#define DDRSS_PHY_245_DATA 0x00000000 +#define DDRSS_PHY_246_DATA 0x00000000 +#define DDRSS_PHY_247_DATA 0x00000000 +#define DDRSS_PHY_248_DATA 0x00000000 +#define DDRSS_PHY_249_DATA 0x00000000 +#define DDRSS_PHY_250_DATA 0x00000000 +#define DDRSS_PHY_251_DATA 0x00000000 +#define DDRSS_PHY_252_DATA 0x00000000 +#define DDRSS_PHY_253_DATA 0x00000000 +#define DDRSS_PHY_254_DATA 0x00000000 +#define DDRSS_PHY_255_DATA 0x00000000 +#define DDRSS_PHY_256_DATA 0x04C00000 +#define DDRSS_PHY_257_DATA 0x00000000 +#define DDRSS_PHY_258_DATA 0x00000200 +#define DDRSS_PHY_259_DATA 0x00000000 +#define DDRSS_PHY_260_DATA 0x00000000 +#define DDRSS_PHY_261_DATA 0x00000000 +#define DDRSS_PHY_262_DATA 0x00000000 +#define DDRSS_PHY_263_DATA 0x00000000 +#define DDRSS_PHY_264_DATA 0x00000001 +#define DDRSS_PHY_265_DATA 0x00000000 +#define DDRSS_PHY_266_DATA 0x00000000 +#define DDRSS_PHY_267_DATA 0x010101FF +#define DDRSS_PHY_268_DATA 0x00010000 +#define DDRSS_PHY_269_DATA 0x00C00004 +#define DDRSS_PHY_270_DATA 0x00CC0008 +#define DDRSS_PHY_271_DATA 0x00660201 +#define DDRSS_PHY_272_DATA 0x00000000 +#define DDRSS_PHY_273_DATA 0x00000000 +#define DDRSS_PHY_274_DATA 0x00000000 +#define DDRSS_PHY_275_DATA 0x0000AAAA +#define DDRSS_PHY_276_DATA 0x00005555 +#define DDRSS_PHY_277_DATA 0x0000B5B5 +#define DDRSS_PHY_278_DATA 0x00004A4A +#define DDRSS_PHY_279_DATA 0x00005656 +#define DDRSS_PHY_280_DATA 0x0000A9A9 +#define DDRSS_PHY_281_DATA 0x0000B7B7 +#define DDRSS_PHY_282_DATA 0x00004848 +#define DDRSS_PHY_283_DATA 0x00000000 +#define DDRSS_PHY_284_DATA 0x00000000 +#define DDRSS_PHY_285_DATA 0x08000000 +#define DDRSS_PHY_286_DATA 0x0F000008 +#define DDRSS_PHY_287_DATA 0x00000F0F +#define DDRSS_PHY_288_DATA 0x00E4E400 +#define DDRSS_PHY_289_DATA 0x00070820 +#define DDRSS_PHY_290_DATA 0x000C0020 +#define DDRSS_PHY_291_DATA 0x00062000 +#define DDRSS_PHY_292_DATA 0x00000000 +#define DDRSS_PHY_293_DATA 0x55555555 +#define DDRSS_PHY_294_DATA 0xAAAAAAAA +#define DDRSS_PHY_295_DATA 0x55555555 +#define DDRSS_PHY_296_DATA 0xAAAAAAAA +#define DDRSS_PHY_297_DATA 0x00005555 +#define DDRSS_PHY_298_DATA 0x01000100 +#define DDRSS_PHY_299_DATA 0x00800180 +#define DDRSS_PHY_300_DATA 0x00000000 +#define DDRSS_PHY_301_DATA 0x00000000 +#define DDRSS_PHY_302_DATA 0x00000000 +#define DDRSS_PHY_303_DATA 0x00000000 +#define DDRSS_PHY_304_DATA 0x00000000 +#define DDRSS_PHY_305_DATA 0x00000000 +#define DDRSS_PHY_306_DATA 0x00000000 +#define DDRSS_PHY_307_DATA 0x00000000 +#define DDRSS_PHY_308_DATA 0x00000000 +#define DDRSS_PHY_309_DATA 0x00000000 +#define DDRSS_PHY_310_DATA 0x00000000 +#define DDRSS_PHY_311_DATA 0x00000000 +#define DDRSS_PHY_312_DATA 0x00000000 +#define DDRSS_PHY_313_DATA 0x00000000 +#define DDRSS_PHY_314_DATA 0x00000000 +#define DDRSS_PHY_315_DATA 0x00000000 +#define DDRSS_PHY_316_DATA 0x00000000 +#define DDRSS_PHY_317_DATA 0x00000000 +#define DDRSS_PHY_318_DATA 0x00000000 +#define DDRSS_PHY_319_DATA 0x00000000 +#define DDRSS_PHY_320_DATA 0x00000000 +#define DDRSS_PHY_321_DATA 0x00000004 +#define DDRSS_PHY_322_DATA 0x00000000 +#define DDRSS_PHY_323_DATA 0x00000000 +#define DDRSS_PHY_324_DATA 0x00000000 +#define DDRSS_PHY_325_DATA 0x00000000 +#define DDRSS_PHY_326_DATA 0x00000000 +#define DDRSS_PHY_327_DATA 0x00000000 +#define DDRSS_PHY_328_DATA 0x041F07FF +#define DDRSS_PHY_329_DATA 0x00000000 +#define DDRSS_PHY_330_DATA 0x01CCB001 +#define DDRSS_PHY_331_DATA 0x2000CCB0 +#define DDRSS_PHY_332_DATA 0x20000140 +#define DDRSS_PHY_333_DATA 0x07FF0200 +#define DDRSS_PHY_334_DATA 0x0000DD01 +#define DDRSS_PHY_335_DATA 0x10100303 +#define DDRSS_PHY_336_DATA 0x10101010 +#define DDRSS_PHY_337_DATA 0x10101010 +#define DDRSS_PHY_338_DATA 0x00021010 +#define DDRSS_PHY_339_DATA 0x00100010 +#define DDRSS_PHY_340_DATA 0x00100010 +#define DDRSS_PHY_341_DATA 0x00100010 +#define DDRSS_PHY_342_DATA 0x00100010 +#define DDRSS_PHY_343_DATA 0x02020010 +#define DDRSS_PHY_344_DATA 0x51515041 +#define DDRSS_PHY_345_DATA 0x31804000 +#define DDRSS_PHY_346_DATA 0x04BF0340 +#define DDRSS_PHY_347_DATA 0x01008080 +#define DDRSS_PHY_348_DATA 0x04050001 +#define DDRSS_PHY_349_DATA 0x00000504 +#define DDRSS_PHY_350_DATA 0x42100010 +#define DDRSS_PHY_351_DATA 0x010C053E +#define DDRSS_PHY_352_DATA 0x000F0C14 +#define DDRSS_PHY_353_DATA 0x01000140 +#define DDRSS_PHY_354_DATA 0x007A0120 +#define DDRSS_PHY_355_DATA 0x00000C00 +#define DDRSS_PHY_356_DATA 0x000001CC +#define DDRSS_PHY_357_DATA 0x20100200 +#define DDRSS_PHY_358_DATA 0x00000005 +#define DDRSS_PHY_359_DATA 0x76543210 +#define DDRSS_PHY_360_DATA 0x00000008 +#define DDRSS_PHY_361_DATA 0x02800280 +#define DDRSS_PHY_362_DATA 0x02800280 +#define DDRSS_PHY_363_DATA 0x02800280 +#define DDRSS_PHY_364_DATA 0x02800280 +#define DDRSS_PHY_365_DATA 0x00000280 +#define DDRSS_PHY_366_DATA 0x00008000 +#define DDRSS_PHY_367_DATA 0x00800080 +#define DDRSS_PHY_368_DATA 0x00800080 +#define DDRSS_PHY_369_DATA 0x00800080 +#define DDRSS_PHY_370_DATA 0x00800080 +#define DDRSS_PHY_371_DATA 0x00800080 +#define DDRSS_PHY_372_DATA 0x00800080 +#define DDRSS_PHY_373_DATA 0x00800080 +#define DDRSS_PHY_374_DATA 0x00800080 +#define DDRSS_PHY_375_DATA 0x01000080 +#define DDRSS_PHY_376_DATA 0x01000000 +#define DDRSS_PHY_377_DATA 0x00000000 +#define DDRSS_PHY_378_DATA 0x00000000 +#define DDRSS_PHY_379_DATA 0x00080200 +#define DDRSS_PHY_380_DATA 0x00000000 +#define DDRSS_PHY_381_DATA 0x00000000 +#define DDRSS_PHY_382_DATA 0x00000000 +#define DDRSS_PHY_383_DATA 0x00000000 +#define DDRSS_PHY_384_DATA 0x00000000 +#define DDRSS_PHY_385_DATA 0x00000000 +#define DDRSS_PHY_386_DATA 0x00000000 +#define DDRSS_PHY_387_DATA 0x00000000 +#define DDRSS_PHY_388_DATA 0x00000000 +#define DDRSS_PHY_389_DATA 0x00000000 +#define DDRSS_PHY_390_DATA 0x00000000 +#define DDRSS_PHY_391_DATA 0x00000000 +#define DDRSS_PHY_392_DATA 0x00000000 +#define DDRSS_PHY_393_DATA 0x00000000 +#define DDRSS_PHY_394_DATA 0x00000000 +#define DDRSS_PHY_395_DATA 0x00000000 +#define DDRSS_PHY_396_DATA 0x00000000 +#define DDRSS_PHY_397_DATA 0x00000000 +#define DDRSS_PHY_398_DATA 0x00000000 +#define DDRSS_PHY_399_DATA 0x00000000 +#define DDRSS_PHY_400_DATA 0x00000000 +#define DDRSS_PHY_401_DATA 0x00000000 +#define DDRSS_PHY_402_DATA 0x00000000 +#define DDRSS_PHY_403_DATA 0x00000000 +#define DDRSS_PHY_404_DATA 0x00000000 +#define DDRSS_PHY_405_DATA 0x00000000 +#define DDRSS_PHY_406_DATA 0x00000000 +#define DDRSS_PHY_407_DATA 0x00000000 +#define DDRSS_PHY_408_DATA 0x00000000 +#define DDRSS_PHY_409_DATA 0x00000000 +#define DDRSS_PHY_410_DATA 0x00000000 +#define DDRSS_PHY_411_DATA 0x00000000 +#define DDRSS_PHY_412_DATA 0x00000000 +#define DDRSS_PHY_413_DATA 0x00000000 +#define DDRSS_PHY_414_DATA 0x00000000 +#define DDRSS_PHY_415_DATA 0x00000000 +#define DDRSS_PHY_416_DATA 0x00000000 +#define DDRSS_PHY_417_DATA 0x00000000 +#define DDRSS_PHY_418_DATA 0x00000000 +#define DDRSS_PHY_419_DATA 0x00000000 +#define DDRSS_PHY_420_DATA 0x00000000 +#define DDRSS_PHY_421_DATA 0x00000000 +#define DDRSS_PHY_422_DATA 0x00000000 +#define DDRSS_PHY_423_DATA 0x00000000 +#define DDRSS_PHY_424_DATA 0x00000000 +#define DDRSS_PHY_425_DATA 0x00000000 +#define DDRSS_PHY_426_DATA 0x00000000 +#define DDRSS_PHY_427_DATA 0x00000000 +#define DDRSS_PHY_428_DATA 0x00000000 +#define DDRSS_PHY_429_DATA 0x00000000 +#define DDRSS_PHY_430_DATA 0x00000000 +#define DDRSS_PHY_431_DATA 0x00000000 +#define DDRSS_PHY_432_DATA 0x00000000 +#define DDRSS_PHY_433_DATA 0x00000000 +#define DDRSS_PHY_434_DATA 0x00000000 +#define DDRSS_PHY_435_DATA 0x00000000 +#define DDRSS_PHY_436_DATA 0x00000000 +#define DDRSS_PHY_437_DATA 0x00000000 +#define DDRSS_PHY_438_DATA 0x00000000 +#define DDRSS_PHY_439_DATA 0x00000000 +#define DDRSS_PHY_440_DATA 0x00000000 +#define DDRSS_PHY_441_DATA 0x00000000 +#define DDRSS_PHY_442_DATA 0x00000000 +#define DDRSS_PHY_443_DATA 0x00000000 +#define DDRSS_PHY_444_DATA 0x00000000 +#define DDRSS_PHY_445_DATA 0x00000000 +#define DDRSS_PHY_446_DATA 0x00000000 +#define DDRSS_PHY_447_DATA 0x00000000 +#define DDRSS_PHY_448_DATA 0x00000000 +#define DDRSS_PHY_449_DATA 0x00000000 +#define DDRSS_PHY_450_DATA 0x00000000 +#define DDRSS_PHY_451_DATA 0x00000000 +#define DDRSS_PHY_452_DATA 0x00000000 +#define DDRSS_PHY_453_DATA 0x00000000 +#define DDRSS_PHY_454_DATA 0x00000000 +#define DDRSS_PHY_455_DATA 0x00000000 +#define DDRSS_PHY_456_DATA 0x00000000 +#define DDRSS_PHY_457_DATA 0x00000000 +#define DDRSS_PHY_458_DATA 0x00000000 +#define DDRSS_PHY_459_DATA 0x00000000 +#define DDRSS_PHY_460_DATA 0x00000000 +#define DDRSS_PHY_461_DATA 0x00000000 +#define DDRSS_PHY_462_DATA 0x00000000 +#define DDRSS_PHY_463_DATA 0x00000000 +#define DDRSS_PHY_464_DATA 0x00000000 +#define DDRSS_PHY_465_DATA 0x00000000 +#define DDRSS_PHY_466_DATA 0x00000000 +#define DDRSS_PHY_467_DATA 0x00000000 +#define DDRSS_PHY_468_DATA 0x00000000 +#define DDRSS_PHY_469_DATA 0x00000000 +#define DDRSS_PHY_470_DATA 0x00000000 +#define DDRSS_PHY_471_DATA 0x00000000 +#define DDRSS_PHY_472_DATA 0x00000000 +#define DDRSS_PHY_473_DATA 0x00000000 +#define DDRSS_PHY_474_DATA 0x00000000 +#define DDRSS_PHY_475_DATA 0x00000000 +#define DDRSS_PHY_476_DATA 0x00000000 +#define DDRSS_PHY_477_DATA 0x00000000 +#define DDRSS_PHY_478_DATA 0x00000000 +#define DDRSS_PHY_479_DATA 0x00000000 +#define DDRSS_PHY_480_DATA 0x00000000 +#define DDRSS_PHY_481_DATA 0x00000000 +#define DDRSS_PHY_482_DATA 0x00000000 +#define DDRSS_PHY_483_DATA 0x00000000 +#define DDRSS_PHY_484_DATA 0x00000000 +#define DDRSS_PHY_485_DATA 0x00000000 +#define DDRSS_PHY_486_DATA 0x00000000 +#define DDRSS_PHY_487_DATA 0x00000000 +#define DDRSS_PHY_488_DATA 0x00000000 +#define DDRSS_PHY_489_DATA 0x00000000 +#define DDRSS_PHY_490_DATA 0x00000000 +#define DDRSS_PHY_491_DATA 0x00000000 +#define DDRSS_PHY_492_DATA 0x00000000 +#define DDRSS_PHY_493_DATA 0x00000000 +#define DDRSS_PHY_494_DATA 0x00000000 +#define DDRSS_PHY_495_DATA 0x00000000 +#define DDRSS_PHY_496_DATA 0x00000000 +#define DDRSS_PHY_497_DATA 0x00000000 +#define DDRSS_PHY_498_DATA 0x00000000 +#define DDRSS_PHY_499_DATA 0x00000000 +#define DDRSS_PHY_500_DATA 0x00000000 +#define DDRSS_PHY_501_DATA 0x00000000 +#define DDRSS_PHY_502_DATA 0x00000000 +#define DDRSS_PHY_503_DATA 0x00000000 +#define DDRSS_PHY_504_DATA 0x00000000 +#define DDRSS_PHY_505_DATA 0x00000000 +#define DDRSS_PHY_506_DATA 0x00000000 +#define DDRSS_PHY_507_DATA 0x00000000 +#define DDRSS_PHY_508_DATA 0x00000000 +#define DDRSS_PHY_509_DATA 0x00000000 +#define DDRSS_PHY_510_DATA 0x00000000 +#define DDRSS_PHY_511_DATA 0x00000000 +#define DDRSS_PHY_512_DATA 0x00000100 +#define DDRSS_PHY_513_DATA 0x00000000 +#define DDRSS_PHY_514_DATA 0x00000000 +#define DDRSS_PHY_515_DATA 0x00000000 +#define DDRSS_PHY_516_DATA 0x00000000 +#define DDRSS_PHY_517_DATA 0x00000100 +#define DDRSS_PHY_518_DATA 0x00000000 +#define DDRSS_PHY_519_DATA 0x00000000 +#define DDRSS_PHY_520_DATA 0x00000000 +#define DDRSS_PHY_521_DATA 0x00000000 +#define DDRSS_PHY_522_DATA 0x00000000 +#define DDRSS_PHY_523_DATA 0x00000000 +#define DDRSS_PHY_524_DATA 0x00000000 +#define DDRSS_PHY_525_DATA 0x00DCBA98 +#define DDRSS_PHY_526_DATA 0x00000000 +#define DDRSS_PHY_527_DATA 0x00000000 +#define DDRSS_PHY_528_DATA 0x00000000 +#define DDRSS_PHY_529_DATA 0x00000000 +#define DDRSS_PHY_530_DATA 0x00000000 +#define DDRSS_PHY_531_DATA 0x00000000 +#define DDRSS_PHY_532_DATA 0x00000000 +#define DDRSS_PHY_533_DATA 0x00000000 +#define DDRSS_PHY_534_DATA 0x00000000 +#define DDRSS_PHY_535_DATA 0x00000000 +#define DDRSS_PHY_536_DATA 0x00000000 +#define DDRSS_PHY_537_DATA 0x00000000 +#define DDRSS_PHY_538_DATA 0x00000000 +#define DDRSS_PHY_539_DATA 0x00000000 +#define DDRSS_PHY_540_DATA 0x0A418820 +#define DDRSS_PHY_541_DATA 0x103F0000 +#define DDRSS_PHY_542_DATA 0x000F0100 +#define DDRSS_PHY_543_DATA 0x0000000F +#define DDRSS_PHY_544_DATA 0x020002CC +#define DDRSS_PHY_545_DATA 0x00030000 +#define DDRSS_PHY_546_DATA 0x00000300 +#define DDRSS_PHY_547_DATA 0x00000300 +#define DDRSS_PHY_548_DATA 0x00000300 +#define DDRSS_PHY_549_DATA 0x00000300 +#define DDRSS_PHY_550_DATA 0x00000300 +#define DDRSS_PHY_551_DATA 0x42080010 +#define DDRSS_PHY_552_DATA 0x0000003E +#define DDRSS_PHY_553_DATA 0x00000000 +#define DDRSS_PHY_554_DATA 0x00000000 +#define DDRSS_PHY_555_DATA 0x00000000 +#define DDRSS_PHY_556_DATA 0x00000000 +#define DDRSS_PHY_557_DATA 0x00000000 +#define DDRSS_PHY_558_DATA 0x00000000 +#define DDRSS_PHY_559_DATA 0x00000000 +#define DDRSS_PHY_560_DATA 0x00000000 +#define DDRSS_PHY_561_DATA 0x00000000 +#define DDRSS_PHY_562_DATA 0x00000000 +#define DDRSS_PHY_563_DATA 0x00000000 +#define DDRSS_PHY_564_DATA 0x00000000 +#define DDRSS_PHY_565_DATA 0x00000000 +#define DDRSS_PHY_566_DATA 0x00000000 +#define DDRSS_PHY_567_DATA 0x00000000 +#define DDRSS_PHY_568_DATA 0x00000000 +#define DDRSS_PHY_569_DATA 0x00000000 +#define DDRSS_PHY_570_DATA 0x00000000 +#define DDRSS_PHY_571_DATA 0x00000000 +#define DDRSS_PHY_572_DATA 0x00000000 +#define DDRSS_PHY_573_DATA 0x00000000 +#define DDRSS_PHY_574_DATA 0x00000000 +#define DDRSS_PHY_575_DATA 0x00000000 +#define DDRSS_PHY_576_DATA 0x00000000 +#define DDRSS_PHY_577_DATA 0x00000000 +#define DDRSS_PHY_578_DATA 0x00000000 +#define DDRSS_PHY_579_DATA 0x00000000 +#define DDRSS_PHY_580_DATA 0x00000000 +#define DDRSS_PHY_581_DATA 0x00000000 +#define DDRSS_PHY_582_DATA 0x00000000 +#define DDRSS_PHY_583_DATA 0x00000000 +#define DDRSS_PHY_584_DATA 0x00000000 +#define DDRSS_PHY_585_DATA 0x00000000 +#define DDRSS_PHY_586_DATA 0x00000000 +#define DDRSS_PHY_587_DATA 0x00000000 +#define DDRSS_PHY_588_DATA 0x00000000 +#define DDRSS_PHY_589_DATA 0x00000000 +#define DDRSS_PHY_590_DATA 0x00000000 +#define DDRSS_PHY_591_DATA 0x00000000 +#define DDRSS_PHY_592_DATA 0x00000000 +#define DDRSS_PHY_593_DATA 0x00000000 +#define DDRSS_PHY_594_DATA 0x00000000 +#define DDRSS_PHY_595_DATA 0x00000000 +#define DDRSS_PHY_596_DATA 0x00000000 +#define DDRSS_PHY_597_DATA 0x00000000 +#define DDRSS_PHY_598_DATA 0x00000000 +#define DDRSS_PHY_599_DATA 0x00000000 +#define DDRSS_PHY_600_DATA 0x00000000 +#define DDRSS_PHY_601_DATA 0x00000000 +#define DDRSS_PHY_602_DATA 0x00000000 +#define DDRSS_PHY_603_DATA 0x00000000 +#define DDRSS_PHY_604_DATA 0x00000000 +#define DDRSS_PHY_605_DATA 0x00000000 +#define DDRSS_PHY_606_DATA 0x00000000 +#define DDRSS_PHY_607_DATA 0x00000000 +#define DDRSS_PHY_608_DATA 0x00000000 +#define DDRSS_PHY_609_DATA 0x00000000 +#define DDRSS_PHY_610_DATA 0x00000000 +#define DDRSS_PHY_611_DATA 0x00000000 +#define DDRSS_PHY_612_DATA 0x00000000 +#define DDRSS_PHY_613_DATA 0x00000000 +#define DDRSS_PHY_614_DATA 0x00000000 +#define DDRSS_PHY_615_DATA 0x00000000 +#define DDRSS_PHY_616_DATA 0x00000000 +#define DDRSS_PHY_617_DATA 0x00000000 +#define DDRSS_PHY_618_DATA 0x00000000 +#define DDRSS_PHY_619_DATA 0x00000000 +#define DDRSS_PHY_620_DATA 0x00000000 +#define DDRSS_PHY_621_DATA 0x00000000 +#define DDRSS_PHY_622_DATA 0x00000000 +#define DDRSS_PHY_623_DATA 0x00000000 +#define DDRSS_PHY_624_DATA 0x00000000 +#define DDRSS_PHY_625_DATA 0x00000000 +#define DDRSS_PHY_626_DATA 0x00000000 +#define DDRSS_PHY_627_DATA 0x00000000 +#define DDRSS_PHY_628_DATA 0x00000000 +#define DDRSS_PHY_629_DATA 0x00000000 +#define DDRSS_PHY_630_DATA 0x00000000 +#define DDRSS_PHY_631_DATA 0x00000000 +#define DDRSS_PHY_632_DATA 0x00000000 +#define DDRSS_PHY_633_DATA 0x00000000 +#define DDRSS_PHY_634_DATA 0x00000000 +#define DDRSS_PHY_635_DATA 0x00000000 +#define DDRSS_PHY_636_DATA 0x00000000 +#define DDRSS_PHY_637_DATA 0x00000000 +#define DDRSS_PHY_638_DATA 0x00000000 +#define DDRSS_PHY_639_DATA 0x00000000 +#define DDRSS_PHY_640_DATA 0x00000000 +#define DDRSS_PHY_641_DATA 0x00000000 +#define DDRSS_PHY_642_DATA 0x00000000 +#define DDRSS_PHY_643_DATA 0x00000000 +#define DDRSS_PHY_644_DATA 0x00000000 +#define DDRSS_PHY_645_DATA 0x00000000 +#define DDRSS_PHY_646_DATA 0x00000000 +#define DDRSS_PHY_647_DATA 0x00000000 +#define DDRSS_PHY_648_DATA 0x00000000 +#define DDRSS_PHY_649_DATA 0x00000000 +#define DDRSS_PHY_650_DATA 0x00000000 +#define DDRSS_PHY_651_DATA 0x00000000 +#define DDRSS_PHY_652_DATA 0x00000000 +#define DDRSS_PHY_653_DATA 0x00000000 +#define DDRSS_PHY_654_DATA 0x00000000 +#define DDRSS_PHY_655_DATA 0x00000000 +#define DDRSS_PHY_656_DATA 0x00000000 +#define DDRSS_PHY_657_DATA 0x00000000 +#define DDRSS_PHY_658_DATA 0x00000000 +#define DDRSS_PHY_659_DATA 0x00000000 +#define DDRSS_PHY_660_DATA 0x00000000 +#define DDRSS_PHY_661_DATA 0x00000000 +#define DDRSS_PHY_662_DATA 0x00000000 +#define DDRSS_PHY_663_DATA 0x00000000 +#define DDRSS_PHY_664_DATA 0x00000000 +#define DDRSS_PHY_665_DATA 0x00000000 +#define DDRSS_PHY_666_DATA 0x00000000 +#define DDRSS_PHY_667_DATA 0x00000000 +#define DDRSS_PHY_668_DATA 0x00000000 +#define DDRSS_PHY_669_DATA 0x00000000 +#define DDRSS_PHY_670_DATA 0x00000000 +#define DDRSS_PHY_671_DATA 0x00000000 +#define DDRSS_PHY_672_DATA 0x00000000 +#define DDRSS_PHY_673_DATA 0x00000000 +#define DDRSS_PHY_674_DATA 0x00000000 +#define DDRSS_PHY_675_DATA 0x00000000 +#define DDRSS_PHY_676_DATA 0x00000000 +#define DDRSS_PHY_677_DATA 0x00000000 +#define DDRSS_PHY_678_DATA 0x00000000 +#define DDRSS_PHY_679_DATA 0x00000000 +#define DDRSS_PHY_680_DATA 0x00000000 +#define DDRSS_PHY_681_DATA 0x00000000 +#define DDRSS_PHY_682_DATA 0x00000000 +#define DDRSS_PHY_683_DATA 0x00000000 +#define DDRSS_PHY_684_DATA 0x00000000 +#define DDRSS_PHY_685_DATA 0x00000000 +#define DDRSS_PHY_686_DATA 0x00000000 +#define DDRSS_PHY_687_DATA 0x00000000 +#define DDRSS_PHY_688_DATA 0x00000000 +#define DDRSS_PHY_689_DATA 0x00000000 +#define DDRSS_PHY_690_DATA 0x00000000 +#define DDRSS_PHY_691_DATA 0x00000000 +#define DDRSS_PHY_692_DATA 0x00000000 +#define DDRSS_PHY_693_DATA 0x00000000 +#define DDRSS_PHY_694_DATA 0x00000000 +#define DDRSS_PHY_695_DATA 0x00000000 +#define DDRSS_PHY_696_DATA 0x00000000 +#define DDRSS_PHY_697_DATA 0x00000000 +#define DDRSS_PHY_698_DATA 0x00000000 +#define DDRSS_PHY_699_DATA 0x00000000 +#define DDRSS_PHY_700_DATA 0x00000000 +#define DDRSS_PHY_701_DATA 0x00000000 +#define DDRSS_PHY_702_DATA 0x00000000 +#define DDRSS_PHY_703_DATA 0x00000000 +#define DDRSS_PHY_704_DATA 0x00000000 +#define DDRSS_PHY_705_DATA 0x00000000 +#define DDRSS_PHY_706_DATA 0x00000000 +#define DDRSS_PHY_707_DATA 0x00000000 +#define DDRSS_PHY_708_DATA 0x00000000 +#define DDRSS_PHY_709_DATA 0x00000000 +#define DDRSS_PHY_710_DATA 0x00000000 +#define DDRSS_PHY_711_DATA 0x00000000 +#define DDRSS_PHY_712_DATA 0x00000000 +#define DDRSS_PHY_713_DATA 0x00000000 +#define DDRSS_PHY_714_DATA 0x00000000 +#define DDRSS_PHY_715_DATA 0x00000000 +#define DDRSS_PHY_716_DATA 0x00000000 +#define DDRSS_PHY_717_DATA 0x00000000 +#define DDRSS_PHY_718_DATA 0x00000000 +#define DDRSS_PHY_719_DATA 0x00000000 +#define DDRSS_PHY_720_DATA 0x00000000 +#define DDRSS_PHY_721_DATA 0x00000000 +#define DDRSS_PHY_722_DATA 0x00000000 +#define DDRSS_PHY_723_DATA 0x00000000 +#define DDRSS_PHY_724_DATA 0x00000000 +#define DDRSS_PHY_725_DATA 0x00000000 +#define DDRSS_PHY_726_DATA 0x00000000 +#define DDRSS_PHY_727_DATA 0x00000000 +#define DDRSS_PHY_728_DATA 0x00000000 +#define DDRSS_PHY_729_DATA 0x00000000 +#define DDRSS_PHY_730_DATA 0x00000000 +#define DDRSS_PHY_731_DATA 0x00000000 +#define DDRSS_PHY_732_DATA 0x00000000 +#define DDRSS_PHY_733_DATA 0x00000000 +#define DDRSS_PHY_734_DATA 0x00000000 +#define DDRSS_PHY_735_DATA 0x00000000 +#define DDRSS_PHY_736_DATA 0x00000000 +#define DDRSS_PHY_737_DATA 0x00000000 +#define DDRSS_PHY_738_DATA 0x00000000 +#define DDRSS_PHY_739_DATA 0x00000000 +#define DDRSS_PHY_740_DATA 0x00000000 +#define DDRSS_PHY_741_DATA 0x00000000 +#define DDRSS_PHY_742_DATA 0x00000000 +#define DDRSS_PHY_743_DATA 0x00000000 +#define DDRSS_PHY_744_DATA 0x00000000 +#define DDRSS_PHY_745_DATA 0x00000000 +#define DDRSS_PHY_746_DATA 0x00000000 +#define DDRSS_PHY_747_DATA 0x00000000 +#define DDRSS_PHY_748_DATA 0x00000000 +#define DDRSS_PHY_749_DATA 0x00000000 +#define DDRSS_PHY_750_DATA 0x00000000 +#define DDRSS_PHY_751_DATA 0x00000000 +#define DDRSS_PHY_752_DATA 0x00000000 +#define DDRSS_PHY_753_DATA 0x00000000 +#define DDRSS_PHY_754_DATA 0x00000000 +#define DDRSS_PHY_755_DATA 0x00000000 +#define DDRSS_PHY_756_DATA 0x00000000 +#define DDRSS_PHY_757_DATA 0x00000000 +#define DDRSS_PHY_758_DATA 0x00000000 +#define DDRSS_PHY_759_DATA 0x00000000 +#define DDRSS_PHY_760_DATA 0x00000000 +#define DDRSS_PHY_761_DATA 0x00000000 +#define DDRSS_PHY_762_DATA 0x00000000 +#define DDRSS_PHY_763_DATA 0x00000000 +#define DDRSS_PHY_764_DATA 0x00000000 +#define DDRSS_PHY_765_DATA 0x00000000 +#define DDRSS_PHY_766_DATA 0x00000000 +#define DDRSS_PHY_767_DATA 0x00000000 +#define DDRSS_PHY_768_DATA 0x00000100 +#define DDRSS_PHY_769_DATA 0x00000000 +#define DDRSS_PHY_770_DATA 0x00000000 +#define DDRSS_PHY_771_DATA 0x00000000 +#define DDRSS_PHY_772_DATA 0x00000000 +#define DDRSS_PHY_773_DATA 0x00000100 +#define DDRSS_PHY_774_DATA 0x00000000 +#define DDRSS_PHY_775_DATA 0x00000000 +#define DDRSS_PHY_776_DATA 0x00000000 +#define DDRSS_PHY_777_DATA 0x00000000 +#define DDRSS_PHY_778_DATA 0x00000000 +#define DDRSS_PHY_779_DATA 0x00000000 +#define DDRSS_PHY_780_DATA 0x00000000 +#define DDRSS_PHY_781_DATA 0x00DCBA98 +#define DDRSS_PHY_782_DATA 0x00000000 +#define DDRSS_PHY_783_DATA 0x00000000 +#define DDRSS_PHY_784_DATA 0x00000000 +#define DDRSS_PHY_785_DATA 0x00000000 +#define DDRSS_PHY_786_DATA 0x00000000 +#define DDRSS_PHY_787_DATA 0x00000000 +#define DDRSS_PHY_788_DATA 0x00000000 +#define DDRSS_PHY_789_DATA 0x00000000 +#define DDRSS_PHY_790_DATA 0x00000000 +#define DDRSS_PHY_791_DATA 0x00000000 +#define DDRSS_PHY_792_DATA 0x00000000 +#define DDRSS_PHY_793_DATA 0x00000000 +#define DDRSS_PHY_794_DATA 0x00000000 +#define DDRSS_PHY_795_DATA 0x00000000 +#define DDRSS_PHY_796_DATA 0x16A4A0E6 +#define DDRSS_PHY_797_DATA 0x103F0000 +#define DDRSS_PHY_798_DATA 0x000F0000 +#define DDRSS_PHY_799_DATA 0x0000000F +#define DDRSS_PHY_800_DATA 0x020002CC +#define DDRSS_PHY_801_DATA 0x00030000 +#define DDRSS_PHY_802_DATA 0x00000300 +#define DDRSS_PHY_803_DATA 0x00000300 +#define DDRSS_PHY_804_DATA 0x00000300 +#define DDRSS_PHY_805_DATA 0x00000300 +#define DDRSS_PHY_806_DATA 0x00000300 +#define DDRSS_PHY_807_DATA 0x42080010 +#define DDRSS_PHY_808_DATA 0x0000003E +#define DDRSS_PHY_809_DATA 0x00000000 +#define DDRSS_PHY_810_DATA 0x00000000 +#define DDRSS_PHY_811_DATA 0x00000000 +#define DDRSS_PHY_812_DATA 0x00000000 +#define DDRSS_PHY_813_DATA 0x00000000 +#define DDRSS_PHY_814_DATA 0x00000000 +#define DDRSS_PHY_815_DATA 0x00000000 +#define DDRSS_PHY_816_DATA 0x00000000 +#define DDRSS_PHY_817_DATA 0x00000000 +#define DDRSS_PHY_818_DATA 0x00000000 +#define DDRSS_PHY_819_DATA 0x00000000 +#define DDRSS_PHY_820_DATA 0x00000000 +#define DDRSS_PHY_821_DATA 0x00000000 +#define DDRSS_PHY_822_DATA 0x00000000 +#define DDRSS_PHY_823_DATA 0x00000000 +#define DDRSS_PHY_824_DATA 0x00000000 +#define DDRSS_PHY_825_DATA 0x00000000 +#define DDRSS_PHY_826_DATA 0x00000000 +#define DDRSS_PHY_827_DATA 0x00000000 +#define DDRSS_PHY_828_DATA 0x00000000 +#define DDRSS_PHY_829_DATA 0x00000000 +#define DDRSS_PHY_830_DATA 0x00000000 +#define DDRSS_PHY_831_DATA 0x00000000 +#define DDRSS_PHY_832_DATA 0x00000000 +#define DDRSS_PHY_833_DATA 0x00000000 +#define DDRSS_PHY_834_DATA 0x00000000 +#define DDRSS_PHY_835_DATA 0x00000000 +#define DDRSS_PHY_836_DATA 0x00000000 +#define DDRSS_PHY_837_DATA 0x00000000 +#define DDRSS_PHY_838_DATA 0x00000000 +#define DDRSS_PHY_839_DATA 0x00000000 +#define DDRSS_PHY_840_DATA 0x00000000 +#define DDRSS_PHY_841_DATA 0x00000000 +#define DDRSS_PHY_842_DATA 0x00000000 +#define DDRSS_PHY_843_DATA 0x00000000 +#define DDRSS_PHY_844_DATA 0x00000000 +#define DDRSS_PHY_845_DATA 0x00000000 +#define DDRSS_PHY_846_DATA 0x00000000 +#define DDRSS_PHY_847_DATA 0x00000000 +#define DDRSS_PHY_848_DATA 0x00000000 +#define DDRSS_PHY_849_DATA 0x00000000 +#define DDRSS_PHY_850_DATA 0x00000000 +#define DDRSS_PHY_851_DATA 0x00000000 +#define DDRSS_PHY_852_DATA 0x00000000 +#define DDRSS_PHY_853_DATA 0x00000000 +#define DDRSS_PHY_854_DATA 0x00000000 +#define DDRSS_PHY_855_DATA 0x00000000 +#define DDRSS_PHY_856_DATA 0x00000000 +#define DDRSS_PHY_857_DATA 0x00000000 +#define DDRSS_PHY_858_DATA 0x00000000 +#define DDRSS_PHY_859_DATA 0x00000000 +#define DDRSS_PHY_860_DATA 0x00000000 +#define DDRSS_PHY_861_DATA 0x00000000 +#define DDRSS_PHY_862_DATA 0x00000000 +#define DDRSS_PHY_863_DATA 0x00000000 +#define DDRSS_PHY_864_DATA 0x00000000 +#define DDRSS_PHY_865_DATA 0x00000000 +#define DDRSS_PHY_866_DATA 0x00000000 +#define DDRSS_PHY_867_DATA 0x00000000 +#define DDRSS_PHY_868_DATA 0x00000000 +#define DDRSS_PHY_869_DATA 0x00000000 +#define DDRSS_PHY_870_DATA 0x00000000 +#define DDRSS_PHY_871_DATA 0x00000000 +#define DDRSS_PHY_872_DATA 0x00000000 +#define DDRSS_PHY_873_DATA 0x00000000 +#define DDRSS_PHY_874_DATA 0x00000000 +#define DDRSS_PHY_875_DATA 0x00000000 +#define DDRSS_PHY_876_DATA 0x00000000 +#define DDRSS_PHY_877_DATA 0x00000000 +#define DDRSS_PHY_878_DATA 0x00000000 +#define DDRSS_PHY_879_DATA 0x00000000 +#define DDRSS_PHY_880_DATA 0x00000000 +#define DDRSS_PHY_881_DATA 0x00000000 +#define DDRSS_PHY_882_DATA 0x00000000 +#define DDRSS_PHY_883_DATA 0x00000000 +#define DDRSS_PHY_884_DATA 0x00000000 +#define DDRSS_PHY_885_DATA 0x00000000 +#define DDRSS_PHY_886_DATA 0x00000000 +#define DDRSS_PHY_887_DATA 0x00000000 +#define DDRSS_PHY_888_DATA 0x00000000 +#define DDRSS_PHY_889_DATA 0x00000000 +#define DDRSS_PHY_890_DATA 0x00000000 +#define DDRSS_PHY_891_DATA 0x00000000 +#define DDRSS_PHY_892_DATA 0x00000000 +#define DDRSS_PHY_893_DATA 0x00000000 +#define DDRSS_PHY_894_DATA 0x00000000 +#define DDRSS_PHY_895_DATA 0x00000000 +#define DDRSS_PHY_896_DATA 0x00000000 +#define DDRSS_PHY_897_DATA 0x00000000 +#define DDRSS_PHY_898_DATA 0x00000000 +#define DDRSS_PHY_899_DATA 0x00000000 +#define DDRSS_PHY_900_DATA 0x00000000 +#define DDRSS_PHY_901_DATA 0x00000000 +#define DDRSS_PHY_902_DATA 0x00000000 +#define DDRSS_PHY_903_DATA 0x00000000 +#define DDRSS_PHY_904_DATA 0x00000000 +#define DDRSS_PHY_905_DATA 0x00000000 +#define DDRSS_PHY_906_DATA 0x00000000 +#define DDRSS_PHY_907_DATA 0x00000000 +#define DDRSS_PHY_908_DATA 0x00000000 +#define DDRSS_PHY_909_DATA 0x00000000 +#define DDRSS_PHY_910_DATA 0x00000000 +#define DDRSS_PHY_911_DATA 0x00000000 +#define DDRSS_PHY_912_DATA 0x00000000 +#define DDRSS_PHY_913_DATA 0x00000000 +#define DDRSS_PHY_914_DATA 0x00000000 +#define DDRSS_PHY_915_DATA 0x00000000 +#define DDRSS_PHY_916_DATA 0x00000000 +#define DDRSS_PHY_917_DATA 0x00000000 +#define DDRSS_PHY_918_DATA 0x00000000 +#define DDRSS_PHY_919_DATA 0x00000000 +#define DDRSS_PHY_920_DATA 0x00000000 +#define DDRSS_PHY_921_DATA 0x00000000 +#define DDRSS_PHY_922_DATA 0x00000000 +#define DDRSS_PHY_923_DATA 0x00000000 +#define DDRSS_PHY_924_DATA 0x00000000 +#define DDRSS_PHY_925_DATA 0x00000000 +#define DDRSS_PHY_926_DATA 0x00000000 +#define DDRSS_PHY_927_DATA 0x00000000 +#define DDRSS_PHY_928_DATA 0x00000000 +#define DDRSS_PHY_929_DATA 0x00000000 +#define DDRSS_PHY_930_DATA 0x00000000 +#define DDRSS_PHY_931_DATA 0x00000000 +#define DDRSS_PHY_932_DATA 0x00000000 +#define DDRSS_PHY_933_DATA 0x00000000 +#define DDRSS_PHY_934_DATA 0x00000000 +#define DDRSS_PHY_935_DATA 0x00000000 +#define DDRSS_PHY_936_DATA 0x00000000 +#define DDRSS_PHY_937_DATA 0x00000000 +#define DDRSS_PHY_938_DATA 0x00000000 +#define DDRSS_PHY_939_DATA 0x00000000 +#define DDRSS_PHY_940_DATA 0x00000000 +#define DDRSS_PHY_941_DATA 0x00000000 +#define DDRSS_PHY_942_DATA 0x00000000 +#define DDRSS_PHY_943_DATA 0x00000000 +#define DDRSS_PHY_944_DATA 0x00000000 +#define DDRSS_PHY_945_DATA 0x00000000 +#define DDRSS_PHY_946_DATA 0x00000000 +#define DDRSS_PHY_947_DATA 0x00000000 +#define DDRSS_PHY_948_DATA 0x00000000 +#define DDRSS_PHY_949_DATA 0x00000000 +#define DDRSS_PHY_950_DATA 0x00000000 +#define DDRSS_PHY_951_DATA 0x00000000 +#define DDRSS_PHY_952_DATA 0x00000000 +#define DDRSS_PHY_953_DATA 0x00000000 +#define DDRSS_PHY_954_DATA 0x00000000 +#define DDRSS_PHY_955_DATA 0x00000000 +#define DDRSS_PHY_956_DATA 0x00000000 +#define DDRSS_PHY_957_DATA 0x00000000 +#define DDRSS_PHY_958_DATA 0x00000000 +#define DDRSS_PHY_959_DATA 0x00000000 +#define DDRSS_PHY_960_DATA 0x00000000 +#define DDRSS_PHY_961_DATA 0x00000000 +#define DDRSS_PHY_962_DATA 0x00000000 +#define DDRSS_PHY_963_DATA 0x00000000 +#define DDRSS_PHY_964_DATA 0x00000000 +#define DDRSS_PHY_965_DATA 0x00000000 +#define DDRSS_PHY_966_DATA 0x00000000 +#define DDRSS_PHY_967_DATA 0x00000000 +#define DDRSS_PHY_968_DATA 0x00000000 +#define DDRSS_PHY_969_DATA 0x00000000 +#define DDRSS_PHY_970_DATA 0x00000000 +#define DDRSS_PHY_971_DATA 0x00000000 +#define DDRSS_PHY_972_DATA 0x00000000 +#define DDRSS_PHY_973_DATA 0x00000000 +#define DDRSS_PHY_974_DATA 0x00000000 +#define DDRSS_PHY_975_DATA 0x00000000 +#define DDRSS_PHY_976_DATA 0x00000000 +#define DDRSS_PHY_977_DATA 0x00000000 +#define DDRSS_PHY_978_DATA 0x00000000 +#define DDRSS_PHY_979_DATA 0x00000000 +#define DDRSS_PHY_980_DATA 0x00000000 +#define DDRSS_PHY_981_DATA 0x00000000 +#define DDRSS_PHY_982_DATA 0x00000000 +#define DDRSS_PHY_983_DATA 0x00000000 +#define DDRSS_PHY_984_DATA 0x00000000 +#define DDRSS_PHY_985_DATA 0x00000000 +#define DDRSS_PHY_986_DATA 0x00000000 +#define DDRSS_PHY_987_DATA 0x00000000 +#define DDRSS_PHY_988_DATA 0x00000000 +#define DDRSS_PHY_989_DATA 0x00000000 +#define DDRSS_PHY_990_DATA 0x00000000 +#define DDRSS_PHY_991_DATA 0x00000000 +#define DDRSS_PHY_992_DATA 0x00000000 +#define DDRSS_PHY_993_DATA 0x00000000 +#define DDRSS_PHY_994_DATA 0x00000000 +#define DDRSS_PHY_995_DATA 0x00000000 +#define DDRSS_PHY_996_DATA 0x00000000 +#define DDRSS_PHY_997_DATA 0x00000000 +#define DDRSS_PHY_998_DATA 0x00000000 +#define DDRSS_PHY_999_DATA 0x00000000 +#define DDRSS_PHY_1000_DATA 0x00000000 +#define DDRSS_PHY_1001_DATA 0x00000000 +#define DDRSS_PHY_1002_DATA 0x00000000 +#define DDRSS_PHY_1003_DATA 0x00000000 +#define DDRSS_PHY_1004_DATA 0x00000000 +#define DDRSS_PHY_1005_DATA 0x00000000 +#define DDRSS_PHY_1006_DATA 0x00000000 +#define DDRSS_PHY_1007_DATA 0x00000000 +#define DDRSS_PHY_1008_DATA 0x00000000 +#define DDRSS_PHY_1009_DATA 0x00000000 +#define DDRSS_PHY_1010_DATA 0x00000000 +#define DDRSS_PHY_1011_DATA 0x00000000 +#define DDRSS_PHY_1012_DATA 0x00000000 +#define DDRSS_PHY_1013_DATA 0x00000000 +#define DDRSS_PHY_1014_DATA 0x00000000 +#define DDRSS_PHY_1015_DATA 0x00000000 +#define DDRSS_PHY_1016_DATA 0x00000000 +#define DDRSS_PHY_1017_DATA 0x00000000 +#define DDRSS_PHY_1018_DATA 0x00000000 +#define DDRSS_PHY_1019_DATA 0x00000000 +#define DDRSS_PHY_1020_DATA 0x00000000 +#define DDRSS_PHY_1021_DATA 0x00000000 +#define DDRSS_PHY_1022_DATA 0x00000000 +#define DDRSS_PHY_1023_DATA 0x00000000 +#define DDRSS_PHY_1024_DATA 0x00000100 +#define DDRSS_PHY_1025_DATA 0x00000000 +#define DDRSS_PHY_1026_DATA 0x00000000 +#define DDRSS_PHY_1027_DATA 0x00000000 +#define DDRSS_PHY_1028_DATA 0x00000000 +#define DDRSS_PHY_1029_DATA 0x00000100 +#define DDRSS_PHY_1030_DATA 0x00000000 +#define DDRSS_PHY_1031_DATA 0x00000000 +#define DDRSS_PHY_1032_DATA 0x00000000 +#define DDRSS_PHY_1033_DATA 0x00000000 +#define DDRSS_PHY_1034_DATA 0x00000000 +#define DDRSS_PHY_1035_DATA 0x00000000 +#define DDRSS_PHY_1036_DATA 0x00000000 +#define DDRSS_PHY_1037_DATA 0x00DCBA98 +#define DDRSS_PHY_1038_DATA 0x00000000 +#define DDRSS_PHY_1039_DATA 0x00000000 +#define DDRSS_PHY_1040_DATA 0x00000000 +#define DDRSS_PHY_1041_DATA 0x00000000 +#define DDRSS_PHY_1042_DATA 0x00000000 +#define DDRSS_PHY_1043_DATA 0x00000000 +#define DDRSS_PHY_1044_DATA 0x00000000 +#define DDRSS_PHY_1045_DATA 0x00000000 +#define DDRSS_PHY_1046_DATA 0x00000000 +#define DDRSS_PHY_1047_DATA 0x00000000 +#define DDRSS_PHY_1048_DATA 0x00000000 +#define DDRSS_PHY_1049_DATA 0x00000000 +#define DDRSS_PHY_1050_DATA 0x00000000 +#define DDRSS_PHY_1051_DATA 0x00000000 +#define DDRSS_PHY_1052_DATA 0x2307B9AC +#define DDRSS_PHY_1053_DATA 0x10030000 +#define DDRSS_PHY_1054_DATA 0x000F0000 +#define DDRSS_PHY_1055_DATA 0x0000000F +#define DDRSS_PHY_1056_DATA 0x020002CC +#define DDRSS_PHY_1057_DATA 0x00030000 +#define DDRSS_PHY_1058_DATA 0x00000300 +#define DDRSS_PHY_1059_DATA 0x00000300 +#define DDRSS_PHY_1060_DATA 0x00000300 +#define DDRSS_PHY_1061_DATA 0x00000300 +#define DDRSS_PHY_1062_DATA 0x00000300 +#define DDRSS_PHY_1063_DATA 0x42080010 +#define DDRSS_PHY_1064_DATA 0x0000003E +#define DDRSS_PHY_1065_DATA 0x00000000 +#define DDRSS_PHY_1066_DATA 0x00000000 +#define DDRSS_PHY_1067_DATA 0x00000000 +#define DDRSS_PHY_1068_DATA 0x00000000 +#define DDRSS_PHY_1069_DATA 0x00000000 +#define DDRSS_PHY_1070_DATA 0x00000000 +#define DDRSS_PHY_1071_DATA 0x00000000 +#define DDRSS_PHY_1072_DATA 0x00000000 +#define DDRSS_PHY_1073_DATA 0x00000000 +#define DDRSS_PHY_1074_DATA 0x00000000 +#define DDRSS_PHY_1075_DATA 0x00000000 +#define DDRSS_PHY_1076_DATA 0x00000000 +#define DDRSS_PHY_1077_DATA 0x00000000 +#define DDRSS_PHY_1078_DATA 0x00000000 +#define DDRSS_PHY_1079_DATA 0x00000000 +#define DDRSS_PHY_1080_DATA 0x00000000 +#define DDRSS_PHY_1081_DATA 0x00000000 +#define DDRSS_PHY_1082_DATA 0x00000000 +#define DDRSS_PHY_1083_DATA 0x00000000 +#define DDRSS_PHY_1084_DATA 0x00000000 +#define DDRSS_PHY_1085_DATA 0x00000000 +#define DDRSS_PHY_1086_DATA 0x00000000 +#define DDRSS_PHY_1087_DATA 0x00000000 +#define DDRSS_PHY_1088_DATA 0x00000000 +#define DDRSS_PHY_1089_DATA 0x00000000 +#define DDRSS_PHY_1090_DATA 0x00000000 +#define DDRSS_PHY_1091_DATA 0x00000000 +#define DDRSS_PHY_1092_DATA 0x00000000 +#define DDRSS_PHY_1093_DATA 0x00000000 +#define DDRSS_PHY_1094_DATA 0x00000000 +#define DDRSS_PHY_1095_DATA 0x00000000 +#define DDRSS_PHY_1096_DATA 0x00000000 +#define DDRSS_PHY_1097_DATA 0x00000000 +#define DDRSS_PHY_1098_DATA 0x00000000 +#define DDRSS_PHY_1099_DATA 0x00000000 +#define DDRSS_PHY_1100_DATA 0x00000000 +#define DDRSS_PHY_1101_DATA 0x00000000 +#define DDRSS_PHY_1102_DATA 0x00000000 +#define DDRSS_PHY_1103_DATA 0x00000000 +#define DDRSS_PHY_1104_DATA 0x00000000 +#define DDRSS_PHY_1105_DATA 0x00000000 +#define DDRSS_PHY_1106_DATA 0x00000000 +#define DDRSS_PHY_1107_DATA 0x00000000 +#define DDRSS_PHY_1108_DATA 0x00000000 +#define DDRSS_PHY_1109_DATA 0x00000000 +#define DDRSS_PHY_1110_DATA 0x00000000 +#define DDRSS_PHY_1111_DATA 0x00000000 +#define DDRSS_PHY_1112_DATA 0x00000000 +#define DDRSS_PHY_1113_DATA 0x00000000 +#define DDRSS_PHY_1114_DATA 0x00000000 +#define DDRSS_PHY_1115_DATA 0x00000000 +#define DDRSS_PHY_1116_DATA 0x00000000 +#define DDRSS_PHY_1117_DATA 0x00000000 +#define DDRSS_PHY_1118_DATA 0x00000000 +#define DDRSS_PHY_1119_DATA 0x00000000 +#define DDRSS_PHY_1120_DATA 0x00000000 +#define DDRSS_PHY_1121_DATA 0x00000000 +#define DDRSS_PHY_1122_DATA 0x00000000 +#define DDRSS_PHY_1123_DATA 0x00000000 +#define DDRSS_PHY_1124_DATA 0x00000000 +#define DDRSS_PHY_1125_DATA 0x00000000 +#define DDRSS_PHY_1126_DATA 0x00000000 +#define DDRSS_PHY_1127_DATA 0x00000000 +#define DDRSS_PHY_1128_DATA 0x00000000 +#define DDRSS_PHY_1129_DATA 0x00000000 +#define DDRSS_PHY_1130_DATA 0x00000000 +#define DDRSS_PHY_1131_DATA 0x00000000 +#define DDRSS_PHY_1132_DATA 0x00000000 +#define DDRSS_PHY_1133_DATA 0x00000000 +#define DDRSS_PHY_1134_DATA 0x00000000 +#define DDRSS_PHY_1135_DATA 0x00000000 +#define DDRSS_PHY_1136_DATA 0x00000000 +#define DDRSS_PHY_1137_DATA 0x00000000 +#define DDRSS_PHY_1138_DATA 0x00000000 +#define DDRSS_PHY_1139_DATA 0x00000000 +#define DDRSS_PHY_1140_DATA 0x00000000 +#define DDRSS_PHY_1141_DATA 0x00000000 +#define DDRSS_PHY_1142_DATA 0x00000000 +#define DDRSS_PHY_1143_DATA 0x00000000 +#define DDRSS_PHY_1144_DATA 0x00000000 +#define DDRSS_PHY_1145_DATA 0x00000000 +#define DDRSS_PHY_1146_DATA 0x00000000 +#define DDRSS_PHY_1147_DATA 0x00000000 +#define DDRSS_PHY_1148_DATA 0x00000000 +#define DDRSS_PHY_1149_DATA 0x00000000 +#define DDRSS_PHY_1150_DATA 0x00000000 +#define DDRSS_PHY_1151_DATA 0x00000000 +#define DDRSS_PHY_1152_DATA 0x00000000 +#define DDRSS_PHY_1153_DATA 0x00000000 +#define DDRSS_PHY_1154_DATA 0x00000000 +#define DDRSS_PHY_1155_DATA 0x00000000 +#define DDRSS_PHY_1156_DATA 0x00000000 +#define DDRSS_PHY_1157_DATA 0x00000000 +#define DDRSS_PHY_1158_DATA 0x00000000 +#define DDRSS_PHY_1159_DATA 0x00000000 +#define DDRSS_PHY_1160_DATA 0x00000000 +#define DDRSS_PHY_1161_DATA 0x00000000 +#define DDRSS_PHY_1162_DATA 0x00000000 +#define DDRSS_PHY_1163_DATA 0x00000000 +#define DDRSS_PHY_1164_DATA 0x00000000 +#define DDRSS_PHY_1165_DATA 0x00000000 +#define DDRSS_PHY_1166_DATA 0x00000000 +#define DDRSS_PHY_1167_DATA 0x00000000 +#define DDRSS_PHY_1168_DATA 0x00000000 +#define DDRSS_PHY_1169_DATA 0x00000000 +#define DDRSS_PHY_1170_DATA 0x00000000 +#define DDRSS_PHY_1171_DATA 0x00000000 +#define DDRSS_PHY_1172_DATA 0x00000000 +#define DDRSS_PHY_1173_DATA 0x00000000 +#define DDRSS_PHY_1174_DATA 0x00000000 +#define DDRSS_PHY_1175_DATA 0x00000000 +#define DDRSS_PHY_1176_DATA 0x00000000 +#define DDRSS_PHY_1177_DATA 0x00000000 +#define DDRSS_PHY_1178_DATA 0x00000000 +#define DDRSS_PHY_1179_DATA 0x00000000 +#define DDRSS_PHY_1180_DATA 0x00000000 +#define DDRSS_PHY_1181_DATA 0x00000000 +#define DDRSS_PHY_1182_DATA 0x00000000 +#define DDRSS_PHY_1183_DATA 0x00000000 +#define DDRSS_PHY_1184_DATA 0x00000000 +#define DDRSS_PHY_1185_DATA 0x00000000 +#define DDRSS_PHY_1186_DATA 0x00000000 +#define DDRSS_PHY_1187_DATA 0x00000000 +#define DDRSS_PHY_1188_DATA 0x00000000 +#define DDRSS_PHY_1189_DATA 0x00000000 +#define DDRSS_PHY_1190_DATA 0x00000000 +#define DDRSS_PHY_1191_DATA 0x00000000 +#define DDRSS_PHY_1192_DATA 0x00000000 +#define DDRSS_PHY_1193_DATA 0x00000000 +#define DDRSS_PHY_1194_DATA 0x00000000 +#define DDRSS_PHY_1195_DATA 0x00000000 +#define DDRSS_PHY_1196_DATA 0x00000000 +#define DDRSS_PHY_1197_DATA 0x00000000 +#define DDRSS_PHY_1198_DATA 0x00000000 +#define DDRSS_PHY_1199_DATA 0x00000000 +#define DDRSS_PHY_1200_DATA 0x00000000 +#define DDRSS_PHY_1201_DATA 0x00000000 +#define DDRSS_PHY_1202_DATA 0x00000000 +#define DDRSS_PHY_1203_DATA 0x00000000 +#define DDRSS_PHY_1204_DATA 0x00000000 +#define DDRSS_PHY_1205_DATA 0x00000000 +#define DDRSS_PHY_1206_DATA 0x00000000 +#define DDRSS_PHY_1207_DATA 0x00000000 +#define DDRSS_PHY_1208_DATA 0x00000000 +#define DDRSS_PHY_1209_DATA 0x00000000 +#define DDRSS_PHY_1210_DATA 0x00000000 +#define DDRSS_PHY_1211_DATA 0x00000000 +#define DDRSS_PHY_1212_DATA 0x00000000 +#define DDRSS_PHY_1213_DATA 0x00000000 +#define DDRSS_PHY_1214_DATA 0x00000000 +#define DDRSS_PHY_1215_DATA 0x00000000 +#define DDRSS_PHY_1216_DATA 0x00000000 +#define DDRSS_PHY_1217_DATA 0x00000000 +#define DDRSS_PHY_1218_DATA 0x00000000 +#define DDRSS_PHY_1219_DATA 0x00000000 +#define DDRSS_PHY_1220_DATA 0x00000000 +#define DDRSS_PHY_1221_DATA 0x00000000 +#define DDRSS_PHY_1222_DATA 0x00000000 +#define DDRSS_PHY_1223_DATA 0x00000000 +#define DDRSS_PHY_1224_DATA 0x00000000 +#define DDRSS_PHY_1225_DATA 0x00000000 +#define DDRSS_PHY_1226_DATA 0x00000000 +#define DDRSS_PHY_1227_DATA 0x00000000 +#define DDRSS_PHY_1228_DATA 0x00000000 +#define DDRSS_PHY_1229_DATA 0x00000000 +#define DDRSS_PHY_1230_DATA 0x00000000 +#define DDRSS_PHY_1231_DATA 0x00000000 +#define DDRSS_PHY_1232_DATA 0x00000000 +#define DDRSS_PHY_1233_DATA 0x00000000 +#define DDRSS_PHY_1234_DATA 0x00000000 +#define DDRSS_PHY_1235_DATA 0x00000000 +#define DDRSS_PHY_1236_DATA 0x00000000 +#define DDRSS_PHY_1237_DATA 0x00000000 +#define DDRSS_PHY_1238_DATA 0x00000000 +#define DDRSS_PHY_1239_DATA 0x00000000 +#define DDRSS_PHY_1240_DATA 0x00000000 +#define DDRSS_PHY_1241_DATA 0x00000000 +#define DDRSS_PHY_1242_DATA 0x00000000 +#define DDRSS_PHY_1243_DATA 0x00000000 +#define DDRSS_PHY_1244_DATA 0x00000000 +#define DDRSS_PHY_1245_DATA 0x00000000 +#define DDRSS_PHY_1246_DATA 0x00000000 +#define DDRSS_PHY_1247_DATA 0x00000000 +#define DDRSS_PHY_1248_DATA 0x00000000 +#define DDRSS_PHY_1249_DATA 0x00000000 +#define DDRSS_PHY_1250_DATA 0x00000000 +#define DDRSS_PHY_1251_DATA 0x00000000 +#define DDRSS_PHY_1252_DATA 0x00000000 +#define DDRSS_PHY_1253_DATA 0x00000000 +#define DDRSS_PHY_1254_DATA 0x00000000 +#define DDRSS_PHY_1255_DATA 0x00000000 +#define DDRSS_PHY_1256_DATA 0x00000000 +#define DDRSS_PHY_1257_DATA 0x00000000 +#define DDRSS_PHY_1258_DATA 0x00000000 +#define DDRSS_PHY_1259_DATA 0x00000000 +#define DDRSS_PHY_1260_DATA 0x00000000 +#define DDRSS_PHY_1261_DATA 0x00000000 +#define DDRSS_PHY_1262_DATA 0x00000000 +#define DDRSS_PHY_1263_DATA 0x00000000 +#define DDRSS_PHY_1264_DATA 0x00000000 +#define DDRSS_PHY_1265_DATA 0x00000000 +#define DDRSS_PHY_1266_DATA 0x00000000 +#define DDRSS_PHY_1267_DATA 0x00000000 +#define DDRSS_PHY_1268_DATA 0x00000000 +#define DDRSS_PHY_1269_DATA 0x00000000 +#define DDRSS_PHY_1270_DATA 0x00000000 +#define DDRSS_PHY_1271_DATA 0x00000000 +#define DDRSS_PHY_1272_DATA 0x00000000 +#define DDRSS_PHY_1273_DATA 0x00000000 +#define DDRSS_PHY_1274_DATA 0x00000000 +#define DDRSS_PHY_1275_DATA 0x00000000 +#define DDRSS_PHY_1276_DATA 0x00000000 +#define DDRSS_PHY_1277_DATA 0x00000000 +#define DDRSS_PHY_1278_DATA 0x00000000 +#define DDRSS_PHY_1279_DATA 0x00000000 +#define DDRSS_PHY_1280_DATA 0x00000000 +#define DDRSS_PHY_1281_DATA 0x00000100 +#define DDRSS_PHY_1282_DATA 0x00000000 +#define DDRSS_PHY_1283_DATA 0x00000000 +#define DDRSS_PHY_1284_DATA 0x00000000 +#define DDRSS_PHY_1285_DATA 0x00000000 +#define DDRSS_PHY_1286_DATA 0x00050000 +#define DDRSS_PHY_1287_DATA 0x04000100 +#define DDRSS_PHY_1288_DATA 0x00000055 +#define DDRSS_PHY_1289_DATA 0x00000000 +#define DDRSS_PHY_1290_DATA 0x00000000 +#define DDRSS_PHY_1291_DATA 0x00000000 +#define DDRSS_PHY_1292_DATA 0x00000000 +#define DDRSS_PHY_1293_DATA 0x01002000 +#define DDRSS_PHY_1294_DATA 0x00004001 +#define DDRSS_PHY_1295_DATA 0x00020028 +#define DDRSS_PHY_1296_DATA 0x00010100 +#define DDRSS_PHY_1297_DATA 0x00000001 +#define DDRSS_PHY_1298_DATA 0x00000000 +#define DDRSS_PHY_1299_DATA 0x0F0F0E06 +#define DDRSS_PHY_1300_DATA 0x00010101 +#define DDRSS_PHY_1301_DATA 0x010F0004 +#define DDRSS_PHY_1302_DATA 0x00000000 +#define DDRSS_PHY_1303_DATA 0x00000000 +#define DDRSS_PHY_1304_DATA 0x00000064 +#define DDRSS_PHY_1305_DATA 0x00000000 +#define DDRSS_PHY_1306_DATA 0x00000000 +#define DDRSS_PHY_1307_DATA 0x01020103 +#define DDRSS_PHY_1308_DATA 0x0F020102 +#define DDRSS_PHY_1309_DATA 0x03030303 +#define DDRSS_PHY_1310_DATA 0x03030303 +#define DDRSS_PHY_1311_DATA 0x00040000 +#define DDRSS_PHY_1312_DATA 0x00005201 +#define DDRSS_PHY_1313_DATA 0x00000000 +#define DDRSS_PHY_1314_DATA 0x00000000 +#define DDRSS_PHY_1315_DATA 0x00000000 +#define DDRSS_PHY_1316_DATA 0x00000000 +#define DDRSS_PHY_1317_DATA 0x00000000 +#define DDRSS_PHY_1318_DATA 0x00000000 +#define DDRSS_PHY_1319_DATA 0x07070001 +#define DDRSS_PHY_1320_DATA 0x00005400 +#define DDRSS_PHY_1321_DATA 0x000040A2 +#define DDRSS_PHY_1322_DATA 0x00024410 +#define DDRSS_PHY_1323_DATA 0x00004410 +#define DDRSS_PHY_1324_DATA 0x00004410 +#define DDRSS_PHY_1325_DATA 0x00004410 +#define DDRSS_PHY_1326_DATA 0x00004410 +#define DDRSS_PHY_1327_DATA 0x00004410 +#define DDRSS_PHY_1328_DATA 0x00004410 +#define DDRSS_PHY_1329_DATA 0x00004410 +#define DDRSS_PHY_1330_DATA 0x00004410 +#define DDRSS_PHY_1331_DATA 0x00004410 +#define DDRSS_PHY_1332_DATA 0x00000000 +#define DDRSS_PHY_1333_DATA 0x00000046 +#define DDRSS_PHY_1334_DATA 0x00000400 +#define DDRSS_PHY_1335_DATA 0x00000008 +#define DDRSS_PHY_1336_DATA 0x00000000 +#define DDRSS_PHY_1337_DATA 0x00000000 +#define DDRSS_PHY_1338_DATA 0x00000000 +#define DDRSS_PHY_1339_DATA 0x00000000 +#define DDRSS_PHY_1340_DATA 0x00000000 +#define DDRSS_PHY_1341_DATA 0x03000000 +#define DDRSS_PHY_1342_DATA 0x00000000 +#define DDRSS_PHY_1343_DATA 0x00000000 +#define DDRSS_PHY_1344_DATA 0x00000000 +#define DDRSS_PHY_1345_DATA 0x04102006 +#define DDRSS_PHY_1346_DATA 0x00041020 +#define DDRSS_PHY_1347_DATA 0x01C98C98 +#define DDRSS_PHY_1348_DATA 0x3F400000 +#define DDRSS_PHY_1349_DATA 0x3F3F1F3F +#define DDRSS_PHY_1350_DATA 0x0000001F +#define DDRSS_PHY_1351_DATA 0x00000000 +#define DDRSS_PHY_1352_DATA 0x00000000 +#define DDRSS_PHY_1353_DATA 0x00000000 +#define DDRSS_PHY_1354_DATA 0x00000001 +#define DDRSS_PHY_1355_DATA 0x00000000 +#define DDRSS_PHY_1356_DATA 0x00000000 +#define DDRSS_PHY_1357_DATA 0x00000000 +#define DDRSS_PHY_1358_DATA 0x00000000 +#define DDRSS_PHY_1359_DATA 0x76543210 +#define DDRSS_PHY_1360_DATA 0x00000098 +#define DDRSS_PHY_1361_DATA 0x00000000 +#define DDRSS_PHY_1362_DATA 0x00000000 +#define DDRSS_PHY_1363_DATA 0x00000000 +#define DDRSS_PHY_1364_DATA 0x00040700 +#define DDRSS_PHY_1365_DATA 0x00000000 +#define DDRSS_PHY_1366_DATA 0x00000000 +#define DDRSS_PHY_1367_DATA 0x00000000 +#define DDRSS_PHY_1368_DATA 0x00000002 +#define DDRSS_PHY_1369_DATA 0x00000100 +#define DDRSS_PHY_1370_DATA 0x00000000 +#define DDRSS_PHY_1371_DATA 0x00000FC3 +#define DDRSS_PHY_1372_DATA 0x00020002 +#define DDRSS_PHY_1373_DATA 0x00000000 +#define DDRSS_PHY_1374_DATA 0x00001142 +#define DDRSS_PHY_1375_DATA 0x03020400 +#define DDRSS_PHY_1376_DATA 0x00000080 +#define DDRSS_PHY_1377_DATA 0x03900390 +#define DDRSS_PHY_1378_DATA 0x03900390 +#define DDRSS_PHY_1379_DATA 0x03900390 +#define DDRSS_PHY_1380_DATA 0x03900390 +#define DDRSS_PHY_1381_DATA 0x03900390 +#define DDRSS_PHY_1382_DATA 0x03900390 +#define DDRSS_PHY_1383_DATA 0x00000300 +#define DDRSS_PHY_1384_DATA 0x00000300 +#define DDRSS_PHY_1385_DATA 0x00000300 +#define DDRSS_PHY_1386_DATA 0x00000300 +#define DDRSS_PHY_1387_DATA 0x31823FC7 +#define DDRSS_PHY_1388_DATA 0x00000000 +#define DDRSS_PHY_1389_DATA 0x0C000D3F +#define DDRSS_PHY_1390_DATA 0x30000D3F +#define DDRSS_PHY_1391_DATA 0x300D3F11 +#define DDRSS_PHY_1392_DATA 0x01990000 +#define DDRSS_PHY_1393_DATA 0x000D3FCC +#define DDRSS_PHY_1394_DATA 0x00000C11 +#define DDRSS_PHY_1395_DATA 0x300D3F11 +#define DDRSS_PHY_1396_DATA 0x01990000 +#define DDRSS_PHY_1397_DATA 0x300C3F11 +#define DDRSS_PHY_1398_DATA 0x01990000 +#define DDRSS_PHY_1399_DATA 0x300C3F11 +#define DDRSS_PHY_1400_DATA 0x01990000 +#define DDRSS_PHY_1401_DATA 0x300D3F11 +#define DDRSS_PHY_1402_DATA 0x01990000 +#define DDRSS_PHY_1403_DATA 0x300D3F11 +#define DDRSS_PHY_1404_DATA 0x01990000 +#define DDRSS_PHY_1405_DATA 0x20040004 diff --git a/arch/arm/dts/k3-am62-phycore-som.dtsi b/arch/arm/dts/k3-am62-phycore-som.dtsi new file mode 100644 index 0000000000..aa43e7407e --- /dev/null +++ b/arch/arm/dts/k3-am62-phycore-som.dtsi @@ -0,0 +1,324 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 - 2023 PHYTEC Messtechnik GmbH + * Author: Wadim Egorov w.egorov@phytec.de + * + * Product homepage: + * https://www.phytec.com/product/phycore-am62x + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/net/ti-dp83867.h> + +/ { + model = "PHYTEC phyCORE-AM62x"; + compatible = "phytec,am62-phycore-som", "ti,am625"; + + aliases { + ethernet0 = &cpsw_port1; + gpio0 = &main_gpio0; + gpio1 = &main_gpio1; + i2c0 = &main_i2c0; + mmc0 = &sdhci0; + rtc0 = &i2c_som_rtc; + rtc1 = &wkup_rtc0; + spi0 = &ospi0; + }; + + memory@80000000 { + device_type = "memory"; + reg = <0x00000000 0x80000000 0x00000000 0x80000000>; + }; + + reserved_memory: reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + ramoops@9ca00000 { + compatible = "ramoops"; + reg = <0x00 0x9ca00000 0x00 0x00100000>; + record-size = <0x8000>; + console-size = <0x8000>; + ftrace-size = <0x00>; + pmsg-size = <0x8000>; + }; + + secure_tfa_ddr: tfa@9e780000 { + reg = <0x00 0x9e780000 0x00 0x80000>; + alignment = <0x1000>; + no-map; + }; + + secure_ddr: optee@9e800000 { + reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */ + alignment = <0x1000>; + no-map; + }; + + wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9db00000 { + compatible = "shared-dma-pool"; + reg = <0x00 0x9db00000 0x00 0x00c00000>; + no-map; + }; + }; + + vcc_5v0_som: regulator-vcc-5v0-som { + compatible = "regulator-fixed"; + regulator-name = "VCC_5V0_SOM"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; + + vdd_1v8: regulator-vdd-1v8 { + compatible = "regulator-fixed"; + regulator-name = "VDD_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_5v0_som>; + regulator-always-on; + regulator-boot-on; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&leds_pins_default>; + + led-0 { + color = <LED_COLOR_ID_GREEN>; + gpios = <&main_gpio0 13 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + function = LED_FUNCTION_HEARTBEAT; + }; + }; +}; + +&main_pmx0 { + leds_pins_default: leds-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x034, PIN_OUTPUT, 7) /* (H21) OSPI0_CSN2.GPIO0_13 */ + >; + }; + + main_i2c0_pins_default: main-i2c0-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x1e0, PIN_INPUT_PULLUP, 0) /* (B16) I2C0_SCL */ + AM62X_IOPAD(0x1e4, PIN_INPUT_PULLUP, 0) /* (A16) I2C0_SDA */ + >; + }; + + main_mdio1_pins_default: main-mdio1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x160, PIN_OUTPUT, 0) /* (AD24) MDIO0_MDC */ + AM62X_IOPAD(0x15c, PIN_INPUT, 0) /* (AB22) MDIO0_MDIO */ + >; + }; + + main_mmc0_pins_default: main-mmc0-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x220, PIN_INPUT_PULLUP, 0) /* (Y3) MMC0_CMD */ + AM62X_IOPAD(0x218, PIN_INPUT_PULLDOWN, 0) /* (AB1) MMC0_CLK */ + AM62X_IOPAD(0x214, PIN_INPUT_PULLUP, 0) /* (AA2) MMC0_DAT0 */ + AM62X_IOPAD(0x210, PIN_INPUT_PULLUP, 0) /* (AA1) MMC0_DAT1 */ + AM62X_IOPAD(0x20c, PIN_INPUT_PULLUP, 0) /* (AA3) MMC0_DAT2 */ + AM62X_IOPAD(0x208, PIN_INPUT_PULLUP, 0) /* (Y4) MMC0_DAT3 */ + AM62X_IOPAD(0x204, PIN_INPUT_PULLUP, 0) /* (AB2) MMC0_DAT4 */ + AM62X_IOPAD(0x200, PIN_INPUT_PULLUP, 0) /* (AC1) MMC0_DAT5 */ + AM62X_IOPAD(0x1fc, PIN_INPUT_PULLUP, 0) /* (AD2) MMC0_DAT6 */ + AM62X_IOPAD(0x1f8, PIN_INPUT_PULLUP, 0) /* (AC2) MMC0_DAT7 */ + >; + }; + + main_rgmii1_pins_default: main-rgmii1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x14c, PIN_INPUT, 0) /* (AB17) RGMII1_RD0 */ + AM62X_IOPAD(0x150, PIN_INPUT, 0) /* (AC17) RGMII1_RD1 */ + AM62X_IOPAD(0x154, PIN_INPUT, 0) /* (AB16) RGMII1_RD2 */ + AM62X_IOPAD(0x158, PIN_INPUT, 0) /* (AA15) RGMII1_RD3 */ + AM62X_IOPAD(0x148, PIN_INPUT, 0) /* (AD17) RGMII1_RXC */ + AM62X_IOPAD(0x144, PIN_INPUT, 0) /* (AE17) RGMII1_RX_CTL */ + AM62X_IOPAD(0x134, PIN_OUTPUT, 0) /* (AE20) RGMII1_TD0 */ + AM62X_IOPAD(0x138, PIN_OUTPUT, 0) /* (AD20) RGMII1_TD1 */ + AM62X_IOPAD(0x13c, PIN_OUTPUT, 0) /* (AE18) RGMII1_TD2 */ + AM62X_IOPAD(0x140, PIN_OUTPUT, 0) /* (AD18) RGMII1_TD3 */ + AM62X_IOPAD(0x130, PIN_OUTPUT, 0) /* (AE19) RGMII1_TXC */ + AM62X_IOPAD(0x12c, PIN_OUTPUT, 0) /* (AD19) RGMII1_TX_CTL */ + >; + }; + + ospi0_pins_default: ospi0-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x000, PIN_OUTPUT, 0) /* (H24) OSPI0_CLK */ + AM62X_IOPAD(0x02c, PIN_OUTPUT, 0) /* (F23) OSPI0_CSn0 */ + AM62X_IOPAD(0x00c, PIN_INPUT, 0) /* (E25) OSPI0_D0 */ + AM62X_IOPAD(0x010, PIN_INPUT, 0) /* (G24) OSPI0_D1 */ + AM62X_IOPAD(0x014, PIN_INPUT, 0) /* (F25) OSPI0_D2 */ + AM62X_IOPAD(0x018, PIN_INPUT, 0) /* (F24) OSPI0_D3 */ + AM62X_IOPAD(0x01c, PIN_INPUT, 0) /* (J23) OSPI0_D4 */ + AM62X_IOPAD(0x020, PIN_INPUT, 0) /* (J25) OSPI0_D5 */ + AM62X_IOPAD(0x024, PIN_INPUT, 0) /* (H25) OSPI0_D6 */ + AM62X_IOPAD(0x028, PIN_INPUT, 0) /* (J22) OSPI0_D7 */ + AM62X_IOPAD(0x008, PIN_INPUT, 0) /* (J24) OSPI0_DQS */ + >; + }; + + pmic_irq_pins_default: pmic-irq-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x01f4, PIN_INPUT, 0) /* (D16) EXTINTn */ + >; + }; +}; + +&cpsw3g { + pinctrl-names = "default"; + pinctrl-0 = <&main_rgmii1_pins_default>; +}; + +&cpsw_port1 { + phy-mode = "rgmii-rxid"; + phy-handle = <&cpsw3g_phy1>; +}; + +&cpsw3g_mdio { + pinctrl-names = "default"; + pinctrl-0 = <&main_mdio1_pins_default>; + status = "okay"; + + cpsw3g_phy1: ethernet-phy@1 { + compatible = "ethernet-phy-id2000.a231", "ethernet-phy-ieee802.3-c22"; + reg = <1>; + ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; + ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; + }; +}; + +&main_i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&main_i2c0_pins_default>; + clock-frequency = <400000>; + status = "okay"; + + pmic@30 { + compatible = "ti,tps65219"; + reg = <0x30>; + buck1-supply = <&vcc_5v0_som>; + buck2-supply = <&vcc_5v0_som>; + buck3-supply = <&vcc_5v0_som>; + ldo1-supply = <&vdd_3v3>; + ldo2-supply = <&vdd_1v8>; + ldo3-supply = <&vcc_5v0_som>; + ldo4-supply = <&vcc_5v0_som>; + + pinctrl-names = "default"; + pinctrl-0 = <&pmic_irq_pins_default>; + interrupt-parent = <&gic500>; + interrupts = <GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>; + interrupt-controller; + #interrupt-cells = <1>; + + ti,power-button; + system-power-controller; + + regulators { + vdd_core: buck1 { + regulator-name = "VDD_CORE"; + regulator-min-microvolt = <750000>; + regulator-max-microvolt = <750000>; + regulator-boot-on; + regulator-always-on; + }; + + vdd_3v3: buck2 { + regulator-name = "VDD_3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + vdd_ddr4: buck3 { + regulator-name = "VDD_DDR4"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-boot-on; + regulator-always-on; + }; + + vddshv5_sdio: ldo1 { + regulator-name = "VDDSHV5_SDIO"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-allow-bypass; + regulator-boot-on; + regulator-always-on; + }; + + vddr_core: ldo2 { + regulator-name = "VDDR_CORE"; + regulator-min-microvolt = <850000>; + regulator-max-microvolt = <850000>; + regulator-boot-on; + regulator-always-on; + }; + + vdda_1v8: ldo3 { + regulator-name = "VDDA_1V8"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + vdd_2v5: ldo4 { + regulator-name = "VDD_2V5"; + regulator-min-microvolt = <2500000>; + regulator-max-microvolt = <2500000>; + regulator-boot-on; + regulator-always-on; + }; + }; + }; + + eeprom@50 { + compatible = "atmel,24c32"; + pagesize = <32>; + reg = <0x50>; + }; + + i2c_som_rtc: rtc@52 { + compatible = "microcrystal,rv3028"; + reg = <0x52>; + }; +}; + +&ospi0 { + pinctrl-names = "default"; + pinctrl-0 = <&ospi0_pins_default>; + status = "okay"; + + serial_flash: flash@0 { + compatible = "jedec,spi-nor"; + reg = <0x0>; + spi-tx-bus-width = <8>; + spi-rx-bus-width = <8>; + spi-max-frequency = <25000000>; + cdns,tshsl-ns = <60>; + cdns,tsd2d-ns = <60>; + cdns,tchsh-ns = <60>; + cdns,tslch-ns = <60>; + cdns,read-delay = <0>; + }; +}; + +&sdhci0 { + pinctrl-names = "default"; + pinctrl-0 = <&main_mmc0_pins_default>; + ti,driver-strength-ohm = <50>; + disable-wp; + non-removable; + status = "okay"; +}; diff --git a/arch/arm/dts/k3-am625-phyboard-lyra-rdk-u-boot.dtsi b/arch/arm/dts/k3-am625-phyboard-lyra-rdk-u-boot.dtsi new file mode 100644 index 0000000000..f6138f3058 --- /dev/null +++ b/arch/arm/dts/k3-am625-phyboard-lyra-rdk-u-boot.dtsi @@ -0,0 +1,166 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * phyCORE-AM62x dts file for SPLs + * Copyright (C) 2022 - 2023 Phytec Messtechnik GmbH + * Author: Wadim Egorov w.egorov@phytec.de + * + * Product homepage: + * https://www.phytec.com/product/phyboard-am62x + */ + +#include "k3-am625-phycore-som-binman.dtsi" + +/ { + chosen { + stdout-path = "serial2:115200n8"; + tick-timer = &main_timer0; + }; + + aliases { + mmc0 = &sdhci0; + mmc1 = &sdhci1; + }; + + memory@80000000 { + bootph-all; + }; +}; + +&cpsw3g { + bootph-all; +}; + +&cpsw_port1 { + bootph-all; +}; + +&cpsw_port2 { + status = "disabled"; +}; + +&cpsw3g_phy1 { + bootph-all; +}; + +&dmsc { + k3_sysreset: sysreset-controller { + compatible = "ti,sci-sysreset"; + bootph-all; + }; +}; + +&fss { + bootph-all; +}; + +&main_bcdma { + bootph-all; + reg = <0x00 0x485c0100 0x00 0x100>, + <0x00 0x4c000000 0x00 0x20000>, + <0x00 0x4a820000 0x00 0x20000>, + <0x00 0x4aa40000 0x00 0x20000>, + <0x00 0x4bc00000 0x00 0x100000>, + <0x00 0x48600000 0x00 0x8000>, + <0x00 0x484a4000 0x00 0x2000>, + <0x00 0x484c2000 0x00 0x2000>; + reg-names = "gcfg", "bchanrt", "rchanrt", "tchanrt", + "ringrt" , "cfg", "tchan", "rchan"; +}; + +&main_gpio0 { + bootph-all; +}; + +&main_mdio1_pins_default { + bootph-all; +}; + +&main_i2c0 { + bootph-all; +}; + +&main_i2c0_pins_default { + bootph-all; +}; + +&main_mmc0_pins_default { + bootph-all; +}; + +&main_mmc1_pins_default { + bootph-all; +}; + +&main_pktdma { + bootph-all; + reg = <0x00 0x485c0000 0x00 0x100>, + <0x00 0x4a800000 0x00 0x20000>, + <0x00 0x4aa00000 0x00 0x20000>, + <0x00 0x4b800000 0x00 0x200000>, + <0x00 0x485e0000 0x00 0x10000>, + <0x00 0x484a0000 0x00 0x2000>, + <0x00 0x484c0000 0x00 0x2000>, + <0x00 0x48430000 0x00 0x1000>; + reg-names = "gcfg", "rchanrt", "tchanrt", "ringrt", + "cfg", "tchan", "rchan", "rflow"; +}; + +&main_rgmii1_pins_default { + bootph-all; +}; + +&main_timer0 { + clock-frequency = <25000000>; +}; + +&main_uart0 { + bootph-all; +}; + +&main_uart0_pins_default { + bootph-all; +}; + +&main_uart1 { + bootph-all; +}; + +&main_uart1_pins_default { + bootph-all; +}; + +&ospi0 { + bootph-all; + + flash@0 { + bootph-all; + }; +}; + +&ospi0_pins_default { + bootph-all; +}; + +&sdhci0 { + bootph-all; +}; + +&sdhci1 { + bootph-all; +}; + +&vcc_3v3_mmc { + bootph-all; +}; + +&vcc_5v0_som { + bootph-all; +}; + +&vddshv5_sdio { + bootph-all; +}; + +&wkup_uart0 { + bootph-all; +}; diff --git a/arch/arm/dts/k3-am625-phyboard-lyra-rdk.dts b/arch/arm/dts/k3-am625-phyboard-lyra-rdk.dts new file mode 100644 index 0000000000..a438baf542 --- /dev/null +++ b/arch/arm/dts/k3-am625-phyboard-lyra-rdk.dts @@ -0,0 +1,266 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 - 2023 PHYTEC Messtechnik GmbH + * Author: Wadim Egorov w.egorov@phytec.de + * + * Product homepage: + * https://www.phytec.com/product/phyboard-am62x + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/net/ti-dp83867.h> +#include "k3-am625.dtsi" +#include "k3-am62-phycore-som.dtsi" + +/ { + compatible = "phytec,am625-phyboard-lyra-rdk", + "phytec,am62-phycore-som", "ti,am625"; + model = "PHYTEC phyBOARD-Lyra AM625"; + + aliases { + serial2 = &main_uart0; + serial3 = &main_uart1; + mmc1 = &sdhci1; + usb0 = &usb0; + usb1 = &usb1; + ethernet1 = &cpsw_port2; + }; + + can_tc1: can-phy0 { + compatible = "ti,tcan1042"; + #phy-cells = <0>; + max-bitrate = <5000000>; + standby-gpios = <&gpio_exp 1 GPIO_ACTIVE_HIGH>; + }; + + keys { + compatible = "gpio-keys"; + autorepeat; + pinctrl-names = "default"; + pinctrl-0 = <&gpio_keys_pins_default>; + + key-home { + label = "home"; + linux,code = <KEY_HOME>; + gpios = <&main_gpio1 23 GPIO_ACTIVE_HIGH>; + }; + + key-menu { + label = "menu"; + linux,code = <KEY_MENU>; + gpios = <&gpio_exp 4 GPIO_ACTIVE_HIGH>; + }; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&leds_pins_default>, <&user_leds_pins_default>; + + led-1 { + gpios = <&main_gpio0 32 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc0"; + }; + + led-2 { + gpios = <&gpio_exp 2 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc1"; + }; + }; + + vcc_3v3_mmc: regulator-vcc-3v3-mmc { + compatible = "regulator-fixed"; + regulator-name = "VCC_3V3_MMC"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + regulator-boot-on; + }; +}; + +&main_pmx0 { + gpio_keys_pins_default: gpio-keys-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x1d4, PIN_INPUT, 7) /* (B15) UART0_RTSn.GPIO1_23 */ + >; + }; + + gpio_exp_int_pins_default: gpio-exp-int-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x244, PIN_INPUT, 7) /* (C17) MMC1_SDWP.GPIO1_49 */ + >; + }; + + main_i2c1_pins_default: main-i2c1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x1e8, PIN_INPUT_PULLUP, 0) /* (B17) I2C1_SCL */ + AM62X_IOPAD(0x1ec, PIN_INPUT_PULLUP, 0) /* (A17) I2C1_SDA */ + >; + }; + + main_mcan0_pins_default: main-mcan0-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x1dc, PIN_INPUT, 0) /* (E15) MCAN0_RX */ + AM62X_IOPAD(0x1d8, PIN_OUTPUT, 0) /* (C15) MCAN0_TX */ + >; + }; + + main_mmc1_pins_default: main-mmc1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x23c, PIN_INPUT_PULLUP, 0) /* (A21) MMC1_CMD */ + AM62X_IOPAD(0x234, PIN_INPUT_PULLDOWN, 0) /* (B22) MMC1_CLK */ + AM62X_IOPAD(0x230, PIN_INPUT_PULLUP, 0) /* (A22) MMC1_DAT0 */ + AM62X_IOPAD(0x22c, PIN_INPUT_PULLUP, 0) /* (B21) MMC1_DAT1 */ + AM62X_IOPAD(0x228, PIN_INPUT_PULLUP, 0) /* (C21) MMC1_DAT2 */ + AM62X_IOPAD(0x224, PIN_INPUT_PULLUP, 0) /* (D22) MMC1_DAT3 */ + AM62X_IOPAD(0x240, PIN_INPUT_PULLUP, 0) /* (D17) MMC1_SDCD */ + >; + }; + + main_rgmii2_pins_default: main-rgmii2-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x184, PIN_INPUT, 0) /* (AE23) RGMII2_RD0 */ + AM62X_IOPAD(0x188, PIN_INPUT, 0) /* (AB20) RGMII2_RD1 */ + AM62X_IOPAD(0x18c, PIN_INPUT, 0) /* (AC21) RGMII2_RD2 */ + AM62X_IOPAD(0x190, PIN_INPUT, 0) /* (AE22) RGMII2_RD3 */ + AM62X_IOPAD(0x180, PIN_INPUT, 0) /* (AD23) RGMII2_RXC */ + AM62X_IOPAD(0x17c, PIN_INPUT, 0) /* (AD22) RGMII2_RX_CTL */ + AM62X_IOPAD(0x16c, PIN_OUTPUT, 0) /* (Y18) RGMII2_TD0 */ + AM62X_IOPAD(0x170, PIN_OUTPUT, 0) /* (AA18) RGMII2_TD1 */ + AM62X_IOPAD(0x174, PIN_OUTPUT, 0) /* (AD21) RGMII2_TD2 */ + AM62X_IOPAD(0x178, PIN_OUTPUT, 0) /* (AC20) RGMII2_TD3 */ + AM62X_IOPAD(0x168, PIN_OUTPUT, 0) /* (AE21) RGMII2_TXC */ + AM62X_IOPAD(0x164, PIN_OUTPUT, 0) /* (AA19) RGMII2_TX_CTL */ + >; + }; + + main_uart0_pins_default: main-uart0-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x1c8, PIN_INPUT, 0) /* (D14) UART0_RXD */ + AM62X_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (E14) UART0_TXD */ + >; + }; + + main_uart1_pins_default: main-uart1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x194, PIN_INPUT, 2) /* (B19) MCASP0_AXR3.UART1_CTSn */ + AM62X_IOPAD(0x198, PIN_OUTPUT, 2) /* (A19) MCASP0_AXR2.UART1_RTSn */ + AM62X_IOPAD(0x1ac, PIN_INPUT, 2) /* (E19) MCASP0_AFSR.UART1_RXD */ + AM62X_IOPAD(0x1b0, PIN_OUTPUT, 2) /* (A20) MCASP0_ACLKR.UART1_TXD */ + >; + }; + + main_usb1_pins_default: main-usb1-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x258, PIN_OUTPUT, 0) /* (F18) USB1_DRVVBUS */ + >; + }; + + user_leds_pins_default: user-leds-default-pins { + pinctrl-single,pins = < + AM62X_IOPAD(0x084, PIN_OUTPUT, 7) /* (L23) GPMC0_ADVn_ALE.GPIO0_32 */ + >; + }; +}; + +&cpsw3g { + pinctrl-names = "default"; + pinctrl-0 = <&main_rgmii1_pins_default>, <&main_rgmii2_pins_default>; +}; + +&cpsw_port2 { + phy-mode = "rgmii-rxid"; + phy-handle = <&cpsw3g_phy3>; +}; + +&cpsw3g_mdio { + cpsw3g_phy3: ethernet-phy@3 { + compatible = "ethernet-phy-id2000.a231", "ethernet-phy-ieee802.3-c22"; + reg = <3>; + ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; + ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; + }; +}; + +&main_i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&main_i2c1_pins_default>; + clock-frequency = <400000>; + status = "okay"; + + gpio_exp: gpio-expander@21 { + pinctrl-names = "default"; + pinctrl-0 = <&gpio_exp_int_pins_default>; + compatible = "nxp,pcf8574"; + reg = <0x21>; + interrupt-parent = <&main_gpio1>; + interrupts = <49 0>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + gpio-line-names = "GPIO0_HDMI_RST", "GPIO1_CAN0_nEN", + "GPIO2_LED2", "GPIO3_LVDS_GPIO", + "GPIO4_BUT2", "GPIO5_LVDS_BKLT_EN", + "GPIO6_ETH1_USER_RESET", "GPIO7_AUDIO_USER_RESET"; + }; + + eeprom@51 { + compatible = "atmel,24c02"; + pagesize = <16>; + reg = <0x51>; + }; +}; + +&main_mcan0 { + pinctrl-names = "default"; + pinctrl-0 = <&main_mcan0_pins_default>; + phys = <&can_tc1>; + status = "okay"; +}; + +&main_uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&main_uart0_pins_default>; + status = "okay"; +}; + +&main_uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&main_uart1_pins_default>; + /* Main UART1 may be used by TIFS firmware */ + status = "okay"; +}; + +&sdhci1 { + vmmc-supply = <&vcc_3v3_mmc>; + vqmmc-supply = <&vddshv5_sdio>; + pinctrl-names = "default"; + pinctrl-0 = <&main_mmc1_pins_default>; + ti,driver-strength-ohm = <50>; + disable-wp; + no-1-8-v; + status = "okay"; +}; + +&usbss0 { + ti,vbus-divider; + status = "okay"; +}; + +&usbss1 { + ti,vbus-divider; + status = "okay"; +}; + +&usb0 { + dr_mode = "peripheral"; +}; + +&usb1 { + dr_mode = "host"; + pinctrl-names = "default"; + pinctrl-0 = <&main_usb1_pins_default>; +}; diff --git a/arch/arm/dts/k3-am625-phycore-som-binman.dtsi b/arch/arm/dts/k3-am625-phycore-som-binman.dtsi new file mode 100644 index 0000000000..e6d5de2aca --- /dev/null +++ b/arch/arm/dts/k3-am625-phycore-som-binman.dtsi @@ -0,0 +1,380 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Based on k3-am625-sk-binman.dtsi + * + * Copyright (C) 2022 - 2023 PHYTEC Messtechnik GmbH + * Author: Wadim Egorov w.egorov@phytec.de + */ + +#include "k3-binman.dtsi" + +#ifndef CONFIG_ARM64 +/* Override path to schema files */ +&bcfg_yaml { + schema = "../../ti/common/schema.yaml"; +}; + +&pcfg_yaml { + schema = "../../ti/common/schema.yaml"; +}; + +&rcfg_yaml { + schema = "../../ti/common/schema.yaml"; +}; + +&scfg_yaml { + schema = "../../ti/common/schema.yaml"; +}; + +/* combined-tifs-cfg */ + +&bcfg_yaml_tifs { + schema = "../../ti/common/schema.yaml"; +}; + +&pcfg_yaml_tifs { + schema = "../../ti/common/schema.yaml"; +}; + +&rcfg_yaml_tifs { + schema = "../../ti/common/schema.yaml"; +}; + +&scfg_yaml_tifs { + schema = "../../ti/common/schema.yaml"; +}; + +/* combined-dm-cfg */ + +&pcfg_yaml_dm { + schema = "../../ti/common/schema.yaml"; +}; + +&rcfg_yaml_dm { + schema = "../../ti/common/schema.yaml"; +}; + +/* combined-sysfw-cfg */ + +&bcfg_yaml_sysfw { + schema = "../../ti/common/schema.yaml"; +}; + +&pcfg_yaml_sysfw { + schema = "../../ti/common/schema.yaml"; +}; + +&rcfg_yaml_sysfw { + schema = "../../ti/common/schema.yaml"; +}; + +&scfg_yaml_sysfw { + schema = "../../ti/common/schema.yaml"; +}; + +#endif /* CONFIG_ARM64 */ + +#ifdef CONFIG_TARGET_PHYCORE_AM62X_R5 +&binman { + tiboot3-am62x-hs-phycore-som.bin { + filename = "tiboot3-am62x-hs-phycore-som.bin"; + ti-secure-rom { + content = <&u_boot_spl>, <&ti_fs_enc>, <&combined_tifs_cfg>, + <&combined_dm_cfg>, <&sysfw_inner_cert>; + combined; + dm-data; + sysfw-inner-cert; + keyfile = "custMpk.pem"; + sw-rev = <1>; + content-sbl = <&u_boot_spl>; + content-sysfw = <&ti_fs_enc>; + content-sysfw-data = <&combined_tifs_cfg>; + content-sysfw-inner-cert = <&sysfw_inner_cert>; + content-dm-data = <&combined_dm_cfg>; + load = <0x43c00000>; + load-sysfw = <0x40000>; + load-sysfw-data = <0x67000>; + load-dm-data = <0x43c3a800>; + }; + u_boot_spl: u-boot-spl { + no-expanded; + }; + ti_fs_enc: ti-fs-enc.bin { + filename = "ti-sysfw/ti-fs-firmware-am62x-hs-enc.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg: combined-tifs-cfg.bin { + filename = "combined-tifs-cfg.bin"; + type = "blob-ext"; + }; + sysfw_inner_cert: sysfw-inner-cert { + filename = "ti-sysfw/ti-fs-firmware-am62x-hs-cert.bin"; + type = "blob-ext"; + optional; + }; + combined_dm_cfg: combined-dm-cfg.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + }; +}; + +&binman { + tiboot3-am62x-hs-fs-phycore-som.bin { + filename = "tiboot3-am62x-hs-fs-phycore-som.bin"; + symlink = "tiboot3.bin"; + ti-secure-rom { + content = <&u_boot_spl_fs>, <&ti_fs_enc_fs>, <&combined_tifs_cfg_fs>, + <&combined_dm_cfg_fs>, <&sysfw_inner_cert_fs>; + combined; + dm-data; + sysfw-inner-cert; + keyfile = "custMpk.pem"; + sw-rev = <1>; + content-sbl = <&u_boot_spl_fs>; + content-sysfw = <&ti_fs_enc_fs>; + content-sysfw-data = <&combined_tifs_cfg_fs>; + content-sysfw-inner-cert = <&sysfw_inner_cert_fs>; + content-dm-data = <&combined_dm_cfg_fs>; + load = <0x43c00000>; + load-sysfw = <0x40000>; + load-sysfw-data = <0x67000>; + load-dm-data = <0x43c3a800>; + }; + u_boot_spl_fs: u-boot-spl { + no-expanded; + }; + ti_fs_enc_fs: ti-fs-enc.bin { + filename = "ti-sysfw/ti-fs-firmware-am62x-hs-fs-enc.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg_fs: combined-tifs-cfg.bin { + filename = "combined-tifs-cfg.bin"; + type = "blob-ext"; + }; + sysfw_inner_cert_fs: sysfw-inner-cert { + filename = "ti-sysfw/ti-fs-firmware-am62x-hs-fs-cert.bin"; + type = "blob-ext"; + optional; + }; + combined_dm_cfg_fs: combined-dm-cfg.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + }; +}; + +&binman { + tiboot3-am62x-gp-phycore-som.bin { + filename = "tiboot3-am62x-gp-phycore-som.bin"; + ti-secure-rom { + content = <&u_boot_spl_unsigned>, <&ti_fs_gp>, + <&combined_tifs_cfg_gp>, <&combined_dm_cfg_gp>; + combined; + dm-data; + content-sbl = <&u_boot_spl_unsigned>; + load = <0x43c00000>; + content-sysfw = <&ti_fs_gp>; + load-sysfw = <0x40000>; + content-sysfw-data = <&combined_tifs_cfg_gp>; + load-sysfw-data = <0x67000>; + content-dm-data = <&combined_dm_cfg_gp>; + load-dm-data = <0x43c3a800>; + sw-rev = <1>; + keyfile = "ti-degenerate-key.pem"; + }; + u_boot_spl_unsigned: u-boot-spl { + no-expanded; + }; + ti_fs_gp: ti-fs-gp.bin { + filename = "ti-sysfw/ti-fs-firmware-am62x-gp.bin"; + type = "blob-ext"; + optional; + }; + combined_tifs_cfg_gp: combined-tifs-cfg-gp.bin { + filename = "combined-tifs-cfg.bin"; + type = "blob-ext"; + }; + combined_dm_cfg_gp: combined-dm-cfg-gp.bin { + filename = "combined-dm-cfg.bin"; + type = "blob-ext"; + }; + }; +}; +#endif /* CONFIG_TARGET_PHYCORE_AM62X_R5 */ + +#ifdef CONFIG_TARGET_PHYCORE_AM62X_A53 +#define SPL_AM625_PHYBOARD_LYRA_DTB "spl/dts/k3-am625-phyboard-lyra-rdk.dtb" +#define AM625_PHYBOARD_LYRA_DTB "u-boot.dtb" + +&binman { + ti-dm { + filename = "ti-dm.bin"; + blob-ext { + filename = "ti-dm/am62xx/ipc_echo_testb_mcu1_0_release_strip.xer5f"; + }; + }; + ti-spl { + insert-template = <&ti_spl_template>; + + fit { + + images { + dm { + ti-secure { + content = <&dm>; + keyfile = "custMpk.pem"; + }; + dm: blob-ext { + filename = "ti-dm.bin"; + }; + }; + + fdt-0 { + description = "k3-am625-phyboard-lyra-rdk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&spl_am625_phyboard_lyra_dtb>; + keyfile = "custMpk.pem"; + }; + spl_am625_phyboard_lyra_dtb: blob-ext { + filename = SPL_AM625_PHYBOARD_LYRA_DTB; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am625-phyboard-lyra-rdk"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; + +&binman { + u-boot { + insert-template = <&u_boot_template>; + + fit { + images { + uboot { + description = "U-Boot for phyCORE-AM62x"; + }; + + fdt-0 { + description = "k3-am625-phyboard-lyra-rdk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + ti-secure { + content = <&am625_phyboard_lyra_dtb>; + keyfile = "custMpk.pem"; + }; + am625_phyboard_lyra_dtb: blob-ext { + filename = AM625_PHYBOARD_LYRA_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am625-phyboard-lyra-rdk"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; + +&binman { + ti-spl_unsigned { + insert-template = <&ti_spl_unsigned_template>; + + fit { + images { + dm { + blob-ext { + filename = "ti-dm.bin"; + }; + }; + + fdt-0 { + description = "k3-am625-phyboard-lyra-rdk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + spl_am625_phyboard_lyra_dtb_unsigned: blob { + filename = SPL_AM625_PHYBOARD_LYRA_DTB; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am625-phyboard-lyra-rdk"; + firmware = "atf"; + loadables = "tee", "dm", "spl"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; + +&binman { + u-boot_unsigned { + insert-template = <&u_boot_unsigned_template>; + + fit { + images { + uboot { + description = "U-Boot for phyCORE-AM62x"; + }; + + fdt-0 { + description = "k3-am625-phyboard-lyra-rdk"; + type = "flat_dt"; + arch = "arm"; + compression = "none"; + am625_phyboard_lyra_dtb_unsigned: blob { + filename = AM625_PHYBOARD_LYRA_DTB; + }; + hash { + algo = "crc32"; + }; + }; + }; + + configurations { + default = "conf-0"; + + conf-0 { + description = "k3-am625-phyboard-lyra-rdk"; + firmware = "uboot"; + loadables = "uboot"; + fdt = "fdt-0"; + }; + }; + }; + }; +}; +#endif /* CONFIG_TARGET_PHYCORE_AM62X_A53 */ diff --git a/arch/arm/dts/k3-am625-r5-phycore-som-2gb.dts b/arch/arm/dts/k3-am625-r5-phycore-som-2gb.dts new file mode 100644 index 0000000000..70154409b1 --- /dev/null +++ b/arch/arm/dts/k3-am625-r5-phycore-som-2gb.dts @@ -0,0 +1,119 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * phyCORE-AM62x dts file for R5 SPL with 2GB RAM + * Copyright (C) 2022 - 2023 Phytec Messtechnik GmbH + * Author: Wadim Egorov w.egorov@phytec.de + */ + +#include "k3-am625-phyboard-lyra-rdk.dts" +#include "k3-am62-phycore-som-ddr4-2gb.dtsi" +#include "k3-am62-ddr.dtsi" + +#include "k3-am625-phyboard-lyra-rdk-u-boot.dtsi" + +/ { + aliases { + remoteproc0 = &sysctrler; + remoteproc1 = &a53_0; + serial0 = &wkup_uart0; + serial3 = &main_uart1; + }; + + a53_0: a53@0 { + compatible = "ti,am654-rproc"; + reg = <0x00 0x00a90000 0x00 0x10>; + power-domains = <&k3_pds 61 TI_SCI_PD_EXCLUSIVE>, + <&k3_pds 135 TI_SCI_PD_EXCLUSIVE>, + <&k3_pds 166 TI_SCI_PD_EXCLUSIVE>; + resets = <&k3_reset 135 0>; + clocks = <&k3_clks 61 0>; + assigned-clocks = <&k3_clks 61 0>, <&k3_clks 135 0>; + assigned-clock-parents = <&k3_clks 61 2>; + assigned-clock-rates = <200000000>, <1200000000>; + ti,sci = <&dmsc>; + ti,sci-proc-id = <32>; + ti,sci-host-id = <10>; + bootph-pre-ram; + }; + + dm_tifs: dm-tifs { + compatible = "ti,j721e-dm-sci"; + ti,host-id = <36>; + ti,secure-host; + mbox-names = "rx", "tx"; + mboxes= <&secure_proxy_main 22>, + <&secure_proxy_main 23>; + bootph-pre-ram; + }; + + memory@80000000 { + device_type = "memory"; + /* 2G RAM */ + reg = <0x00000000 0x80000000 0x00000000 0x80000000>; + bootph-pre-ram; + }; +}; + +&secure_proxy_sa3 { + /* We require this for boot handshake */ + status = "okay"; +}; + +&cbass_main { + sysctrler: sysctrler { + compatible = "ti,am654-system-controller"; + mboxes= <&secure_proxy_main 1>, <&secure_proxy_main 0>, <&secure_proxy_sa3 0>; + mbox-names = "tx", "rx", "boot_notify"; + bootph-pre-ram; + }; +}; + +&dmsc { + mboxes= <&secure_proxy_main 0>, + <&secure_proxy_main 1>, + <&secure_proxy_main 0>; + mbox-names = "rx", "tx", "notify"; + ti,host-id = <35>; + ti,secure-host; +}; + +&main_bcdma { + ti,sci = <&dm_tifs>; +}; + +&main_pktdma { + ti,sci = <&dm_tifs>; +}; + +/* Main UART1 is used for TIFS firmware logs */ +&main_uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&main_uart1_pins_default>; + status = "okay"; + bootph-pre-ram; +}; + +&mcu_pmx0 { + wkup_uart0_pins_default: wkup-uart0-pins-default { + pinctrl-single,pins = < + AM62X_MCU_IOPAD(0x02c, PIN_INPUT, 0) /* (C6) WKUP_UART0_CTSn */ + AM62X_MCU_IOPAD(0x030, PIN_OUTPUT, 0) /* (A4) WKUP_UART0_RTSn */ + AM62X_MCU_IOPAD(0x024, PIN_INPUT, 0) /* (B4) WKUP_UART0_RXD */ + AM62X_MCU_IOPAD(0x028, PIN_OUTPUT, 0) /* (C5) WKUP_UART0_TXD */ + >; + bootph-pre-ram; + }; +}; + +&ospi0 { + reg = <0x00 0x0fc40000 0x00 0x100>, + <0x00 0x60000000 0x00 0x08000000>; +}; + +/* WKUP UART0 is used for DM firmware logs */ +&wkup_uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&wkup_uart0_pins_default>; + status = "okay"; + bootph-pre-ram; +}; diff --git a/arch/arm/mach-k3/am62x/Kconfig b/arch/arm/mach-k3/am62x/Kconfig index 8091d72078..935d596c87 100644 --- a/arch/arm/mach-k3/am62x/Kconfig +++ b/arch/arm/mach-k3/am62x/Kconfig @@ -25,6 +25,22 @@ config TARGET_AM625_R5_EVM select BINMAN imply SYS_K3_SPL_ATF
+config TARGET_PHYCORE_AM62X_A53 + bool "PHYTEC phyCORE-AM62x running on A53" + select ARM64 + select BINMAN + +config TARGET_PHYCORE_AM62X_R5 + bool "PHYTEC phyCORE-AM62x running on R5" + select CPU_V7R + select SYS_THUMB_BUILD + select K3_LOAD_SYSFW + select RAM + select SPL_RAM + select K3_DDRSS + select BINMAN + imply SYS_K3_SPL_ATF + config TARGET_VERDIN_AM62_A53 bool "Toradex Verdin AM62 running on A53" select ARM64 @@ -44,6 +60,7 @@ config TARGET_VERDIN_AM62_R5 endchoice
source "board/beagle/beagleplay/Kconfig" +source "board/phytec/phycore_am62x/Kconfig" source "board/ti/am62x/Kconfig" source "board/toradex/verdin-am62/Kconfig"
diff --git a/board/phytec/phycore_am62x/Kconfig b/board/phytec/phycore_am62x/Kconfig new file mode 100644 index 0000000000..b64c345138 --- /dev/null +++ b/board/phytec/phycore_am62x/Kconfig @@ -0,0 +1,33 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2022 - 2023 PHYTEC Messtechnik GmbH +# Author: Wadim Egorov w.egorov@phytec.de + +if TARGET_PHYCORE_AM62X_A53 + +config SYS_BOARD + default "phycore_am62x" + +config SYS_VENDOR + default "phytec" + +config SYS_CONFIG_NAME + default "phycore_am62x" + +endif + +if TARGET_PHYCORE_AM62X_R5 + +config SYS_BOARD + default "phycore_am62x" + +config SYS_VENDOR + default "phytec" + +config SYS_CONFIG_NAME + default "phycore_am62x" + +config SPL_LDSCRIPT + default "arch/arm/mach-omap2/u-boot-spl.lds" + +endif diff --git a/board/phytec/phycore_am62x/MAINTAINERS b/board/phytec/phycore_am62x/MAINTAINERS new file mode 100644 index 0000000000..884e9c6776 --- /dev/null +++ b/board/phytec/phycore_am62x/MAINTAINERS @@ -0,0 +1,15 @@ +phyCORE-AM62x +M: Wadim Egorov w.egorov@phytec.de +W: https://www.phytec.com/product/phycore-am62x +S: Maintained +F: arch/arm/dts/k3-am62-phycore-som-ddr4-2gb.dtsi +F: arch/arm/dts/k3-am62-phycore-som.dtsi +F: arch/arm/dts/k3-am625-phyboard-lyra-rdk-u-boot.dtsi +F: arch/arm/dts/k3-am625-phyboard-lyra-rdk.dts +F: arch/arm/dts/k3-am625-phycore-som-binman.dtsi +F: arch/arm/dts/k3-am625-r5-phycore-som-2gb.dts +F: board/phytec/phycore_am62x/ +F: configs/phycore_am62x_a53_defconfig +F: configs/phycore_am62x_r5_defconfig +F: include/configs/phycore_am62x.h +F: doc/board/phytec/phycore-am62x.rst diff --git a/board/phytec/phycore_am62x/Makefile b/board/phytec/phycore_am62x/Makefile new file mode 100644 index 0000000000..76a663f7f2 --- /dev/null +++ b/board/phytec/phycore_am62x/Makefile @@ -0,0 +1,8 @@ +# +# Copyright (C) 2022 - 2023 PHYTEC Messtechnik GmbH +# Author: Wadim Egorov w.egorov@phytec.de +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += phycore-am62x.o diff --git a/board/phytec/phycore_am62x/board-cfg.yaml b/board/phytec/phycore_am62x/board-cfg.yaml new file mode 100644 index 0000000000..36cfb550ad --- /dev/null +++ b/board/phytec/phycore_am62x/board-cfg.yaml @@ -0,0 +1,36 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022-2023 Texas Instruments Incorporated - https://www.ti.com/ +# +# Board configuration for AM62 +# + +--- + +board-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + control: + subhdr: + magic: 0xC1D3 + size: 7 + main_isolation_enable : 0x5A + main_isolation_hostid : 0x2 + secproxy: + subhdr: + magic: 0x1207 + size: 7 + scaling_factor : 0x1 + scaling_profile : 0x1 + disable_main_nav_secure_proxy : 0 + msmc: + subhdr: + magic: 0xA5C3 + size: 5 + msmc_cache_size : 0x0 + debug_cfg: + subhdr: + magic: 0x020C + size: 8 + trace_dst_enables : 0x00 + trace_src_enables : 0x00 diff --git a/board/phytec/phycore_am62x/phycore-am62x.c b/board/phytec/phycore_am62x/phycore-am62x.c new file mode 100644 index 0000000000..91a24018c4 --- /dev/null +++ b/board/phytec/phycore_am62x/phycore-am62x.c @@ -0,0 +1,59 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 - 2023 PHYTEC Messtechnik GmbH + * Author: Wadim Egorov w.egorov@phytec.de + */ + +#include <asm/io.h> +#include <env.h> +#include <env_internal.h> +#include <spl.h> +#include <fdt_support.h> +#include <asm/arch/hardware.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ + return 0; +} + +int dram_init(void) +{ + return fdtdec_setup_mem_size_base(); +} + +int dram_init_banksize(void) +{ + return fdtdec_setup_memory_banksize(); +} + +#define CTRLMMR_USB0_PHY_CTRL 0x43004008 +#define CTRLMMR_USB1_PHY_CTRL 0x43004018 +#define CORE_VOLTAGE 0x80000000 + +#ifdef CONFIG_SPL_BOARD_INIT +void spl_board_init(void) +{ + u32 val; + + /* Set USB0 PHY core voltage to 0.85V */ + val = readl(CTRLMMR_USB0_PHY_CTRL); + val &= ~(CORE_VOLTAGE); + writel(val, CTRLMMR_USB0_PHY_CTRL); + + /* Set USB1 PHY core voltage to 0.85V */ + val = readl(CTRLMMR_USB1_PHY_CTRL); + val &= ~(CORE_VOLTAGE); + writel(val, CTRLMMR_USB1_PHY_CTRL); + + /* We have 32k crystal, so lets enable it */ + val = readl(MCU_CTRL_LFXOSC_CTRL); + val &= ~(MCU_CTRL_LFXOSC_32K_DISABLE_VAL); + writel(val, MCU_CTRL_LFXOSC_CTRL); + /* Add any TRIM needed for the crystal here.. */ + /* Make sure to mux up to take the SoC 32k from the crystal */ + writel(MCU_CTRL_DEVICE_CLKOUT_LFOSC_SELECT_VAL, + MCU_CTRL_DEVICE_CLKOUT_32K_CTRL); +} +#endif diff --git a/board/phytec/phycore_am62x/phycore_am62x.env b/board/phytec/phycore_am62x/phycore_am62x.env new file mode 100644 index 0000000000..ada3a9233b --- /dev/null +++ b/board/phytec/phycore_am62x/phycore_am62x.env @@ -0,0 +1,23 @@ +fdtaddr=0x88000000 +loadaddr=0x82000000 +scriptaddr=0x80000000 +fdt_addr_r=0x88000000 +kernel_addr_r=0x82000000 +ramdisk_addr_r=0x88080000 +fdtoverlay_addr_r=0x89000000 + +fdtfile=CONFIG_DEFAULT_FDT_FILE +mmcdev=1 +mmcroot=2 +mmcpart=1 +console=ttyS2,115200n8 +mmcargs=setenv bootargs console=${console} earlycon=ns16550a,mmio32,0x02800000 + root=/dev/mmcblk${mmcdev}p${mmcroot} rootwait rw +loadimage=load mmc ${mmcdev}:${mmcpart} ${loadaddr} Image +loadfdt=load mmc ${mmcdev}:${mmcpart} ${fdtaddr} ${fdtfile} +mmcboot=run mmcargs; + mmc dev ${mmcdev}; + mmc rescan; + run loadimage; + run loadfdt; + booti ${loadaddr} - ${fdtaddr} diff --git a/board/phytec/phycore_am62x/pm-cfg.yaml b/board/phytec/phycore_am62x/pm-cfg.yaml new file mode 100644 index 0000000000..5d04cf82ef --- /dev/null +++ b/board/phytec/phycore_am62x/pm-cfg.yaml @@ -0,0 +1,12 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022-2023 Texas Instruments Incorporated - https://www.ti.com/ +# +# Power management configuration for AM62 +# + +--- + +pm-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 diff --git a/board/phytec/phycore_am62x/rm-cfg.yaml b/board/phytec/phycore_am62x/rm-cfg.yaml new file mode 100644 index 0000000000..c28707be8e --- /dev/null +++ b/board/phytec/phycore_am62x/rm-cfg.yaml @@ -0,0 +1,1088 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022-2023 Texas Instruments Incorporated - https://www.ti.com/ +# +# Resource management configuration for AM62 +# + +--- + +rm-cfg: + rm_boardcfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + host_cfg: + subhdr: + magic: 0x4C41 + size : 356 + host_cfg_entries: + - #1 + host_id: 12 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #2 + host_id: 30 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #3 + host_id: 36 + allowed_atype : 0x2A + allowed_qos : 0xAAAA + allowed_orderid : 0xAAAAAAAA + allowed_priority : 0xAAAA + allowed_sched_priority : 0xAA + - #4 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #5 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #6 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #7 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #8 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #9 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #10 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #11 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #12 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #13 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #14 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #15 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #16 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #17 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #18 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #19 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #20 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #21 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #22 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #23 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #24 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #25 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #26 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #27 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #28 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #29 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #30 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #31 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + - #32 + host_id: 0 + allowed_atype : 0 + allowed_qos : 0 + allowed_orderid : 0 + allowed_priority : 0 + allowed_sched_priority : 0 + resasg: + subhdr: + magic: 0x7B25 + size : 8 + resasg_entries_size: 960 + reserved : 0 + resasg_entries: + - + start_resource: 0 + num_resource: 16 + type: 64 + host_id: 12 + reserved: 0 + + - + start_resource: 16 + num_resource: 4 + type: 64 + host_id: 35 + reserved: 0 + + - + start_resource: 16 + num_resource: 4 + type: 64 + host_id: 36 + reserved: 0 + + - + start_resource: 20 + num_resource: 22 + type: 64 + host_id: 30 + reserved: 0 + + - + start_resource: 0 + num_resource: 16 + type: 192 + host_id: 12 + reserved: 0 + + - + start_resource: 34 + num_resource: 2 + type: 192 + host_id: 30 + reserved: 0 + + - + start_resource: 0 + num_resource: 4 + type: 320 + host_id: 12 + reserved: 0 + + - + start_resource: 4 + num_resource: 4 + type: 320 + host_id: 30 + reserved: 0 + + - + start_resource: 0 + num_resource: 26 + type: 384 + host_id: 128 + reserved: 0 + + - + start_resource: 50176 + num_resource: 164 + type: 1666 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 1667 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 18 + type: 1677 + host_id: 12 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1677 + host_id: 35 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1677 + host_id: 36 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 1677 + host_id: 30 + reserved: 0 + + - + start_resource: 26 + num_resource: 6 + type: 1677 + host_id: 128 + reserved: 0 + + - + start_resource: 54 + num_resource: 18 + type: 1678 + host_id: 12 + reserved: 0 + + - + start_resource: 72 + num_resource: 6 + type: 1678 + host_id: 35 + reserved: 0 + + - + start_resource: 72 + num_resource: 6 + type: 1678 + host_id: 36 + reserved: 0 + + - + start_resource: 78 + num_resource: 2 + type: 1678 + host_id: 30 + reserved: 0 + + - + start_resource: 80 + num_resource: 2 + type: 1678 + host_id: 128 + reserved: 0 + + - + start_resource: 32 + num_resource: 12 + type: 1679 + host_id: 12 + reserved: 0 + + - + start_resource: 44 + num_resource: 6 + type: 1679 + host_id: 35 + reserved: 0 + + - + start_resource: 44 + num_resource: 6 + type: 1679 + host_id: 36 + reserved: 0 + + - + start_resource: 50 + num_resource: 2 + type: 1679 + host_id: 30 + reserved: 0 + + - + start_resource: 52 + num_resource: 2 + type: 1679 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 18 + type: 1696 + host_id: 12 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1696 + host_id: 35 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1696 + host_id: 36 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 1696 + host_id: 30 + reserved: 0 + + - + start_resource: 26 + num_resource: 6 + type: 1696 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 18 + type: 1697 + host_id: 12 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1697 + host_id: 35 + reserved: 0 + + - + start_resource: 18 + num_resource: 6 + type: 1697 + host_id: 36 + reserved: 0 + + - + start_resource: 24 + num_resource: 2 + type: 1697 + host_id: 30 + reserved: 0 + + - + start_resource: 26 + num_resource: 2 + type: 1697 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 12 + type: 1698 + host_id: 12 + reserved: 0 + + - + start_resource: 12 + num_resource: 6 + type: 1698 + host_id: 35 + reserved: 0 + + - + start_resource: 12 + num_resource: 6 + type: 1698 + host_id: 36 + reserved: 0 + + - + start_resource: 18 + num_resource: 2 + type: 1698 + host_id: 30 + reserved: 0 + + - + start_resource: 20 + num_resource: 2 + type: 1698 + host_id: 128 + reserved: 0 + + - + start_resource: 5 + num_resource: 35 + type: 1802 + host_id: 12 + reserved: 0 + + - + start_resource: 44 + num_resource: 36 + type: 1802 + host_id: 35 + reserved: 0 + + - + start_resource: 44 + num_resource: 36 + type: 1802 + host_id: 36 + reserved: 0 + + - + start_resource: 168 + num_resource: 8 + type: 1802 + host_id: 30 + reserved: 0 + + - + start_resource: 13 + num_resource: 512 + type: 1805 + host_id: 12 + reserved: 0 + + - + start_resource: 525 + num_resource: 256 + type: 1805 + host_id: 35 + reserved: 0 + + - + start_resource: 525 + num_resource: 256 + type: 1805 + host_id: 36 + reserved: 0 + + - + start_resource: 781 + num_resource: 128 + type: 1805 + host_id: 30 + reserved: 0 + + - + start_resource: 909 + num_resource: 627 + type: 1805 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1024 + type: 1807 + host_id: 128 + reserved: 0 + + - + start_resource: 4096 + num_resource: 29 + type: 1808 + host_id: 128 + reserved: 0 + + - + start_resource: 4608 + num_resource: 99 + type: 1809 + host_id: 128 + reserved: 0 + + - + start_resource: 5120 + num_resource: 24 + type: 1810 + host_id: 128 + reserved: 0 + + - + start_resource: 5632 + num_resource: 51 + type: 1811 + host_id: 128 + reserved: 0 + + - + start_resource: 6144 + num_resource: 51 + type: 1812 + host_id: 128 + reserved: 0 + + - + start_resource: 6656 + num_resource: 51 + type: 1813 + host_id: 128 + reserved: 0 + + - + start_resource: 8192 + num_resource: 32 + type: 1814 + host_id: 128 + reserved: 0 + + - + start_resource: 8704 + num_resource: 32 + type: 1815 + host_id: 128 + reserved: 0 + + - + start_resource: 9216 + num_resource: 32 + type: 1816 + host_id: 128 + reserved: 0 + + - + start_resource: 9728 + num_resource: 22 + type: 1817 + host_id: 128 + reserved: 0 + + - + start_resource: 10240 + num_resource: 22 + type: 1818 + host_id: 128 + reserved: 0 + + - + start_resource: 10752 + num_resource: 22 + type: 1819 + host_id: 128 + reserved: 0 + + - + start_resource: 11264 + num_resource: 28 + type: 1820 + host_id: 128 + reserved: 0 + + - + start_resource: 11776 + num_resource: 28 + type: 1821 + host_id: 128 + reserved: 0 + + - + start_resource: 12288 + num_resource: 28 + type: 1822 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 1923 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 1936 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1936 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1936 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 1936 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 1936 + host_id: 128 + reserved: 0 + + - + start_resource: 19 + num_resource: 64 + type: 1937 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 64 + type: 1937 + host_id: 36 + reserved: 0 + + - + start_resource: 83 + num_resource: 8 + type: 1938 + host_id: 12 + reserved: 0 + + - + start_resource: 91 + num_resource: 8 + type: 1939 + host_id: 12 + reserved: 0 + + - + start_resource: 99 + num_resource: 10 + type: 1942 + host_id: 12 + reserved: 0 + + - + start_resource: 109 + num_resource: 3 + type: 1942 + host_id: 35 + reserved: 0 + + - + start_resource: 109 + num_resource: 3 + type: 1942 + host_id: 36 + reserved: 0 + + - + start_resource: 112 + num_resource: 3 + type: 1942 + host_id: 30 + reserved: 0 + + - + start_resource: 115 + num_resource: 3 + type: 1942 + host_id: 128 + reserved: 0 + + - + start_resource: 118 + num_resource: 16 + type: 1943 + host_id: 12 + reserved: 0 + + - + start_resource: 118 + num_resource: 16 + type: 1943 + host_id: 36 + reserved: 0 + + - + start_resource: 134 + num_resource: 8 + type: 1944 + host_id: 12 + reserved: 0 + + - + start_resource: 134 + num_resource: 8 + type: 1945 + host_id: 12 + reserved: 0 + + - + start_resource: 142 + num_resource: 8 + type: 1946 + host_id: 12 + reserved: 0 + + - + start_resource: 142 + num_resource: 8 + type: 1947 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 1955 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1955 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1955 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 1955 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 1955 + host_id: 128 + reserved: 0 + + - + start_resource: 19 + num_resource: 8 + type: 1956 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 8 + type: 1956 + host_id: 36 + reserved: 0 + + - + start_resource: 27 + num_resource: 1 + type: 1957 + host_id: 12 + reserved: 0 + + - + start_resource: 28 + num_resource: 1 + type: 1958 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 1961 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1961 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1961 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 1961 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 1961 + host_id: 128 + reserved: 0 + + - + start_resource: 0 + num_resource: 10 + type: 1962 + host_id: 12 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1962 + host_id: 35 + reserved: 0 + + - + start_resource: 10 + num_resource: 3 + type: 1962 + host_id: 36 + reserved: 0 + + - + start_resource: 13 + num_resource: 3 + type: 1962 + host_id: 30 + reserved: 0 + + - + start_resource: 16 + num_resource: 3 + type: 1962 + host_id: 128 + reserved: 0 + + - + start_resource: 19 + num_resource: 1 + type: 1963 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 1 + type: 1963 + host_id: 36 + reserved: 0 + + - + start_resource: 19 + num_resource: 16 + type: 1964 + host_id: 12 + reserved: 0 + + - + start_resource: 19 + num_resource: 16 + type: 1964 + host_id: 36 + reserved: 0 + + - + start_resource: 20 + num_resource: 1 + type: 1965 + host_id: 12 + reserved: 0 + + - + start_resource: 35 + num_resource: 8 + type: 1966 + host_id: 12 + reserved: 0 + + - + start_resource: 21 + num_resource: 1 + type: 1967 + host_id: 12 + reserved: 0 + + - + start_resource: 35 + num_resource: 8 + type: 1968 + host_id: 12 + reserved: 0 + + - + start_resource: 22 + num_resource: 1 + type: 1969 + host_id: 12 + reserved: 0 + + - + start_resource: 43 + num_resource: 8 + type: 1970 + host_id: 12 + reserved: 0 + + - + start_resource: 23 + num_resource: 1 + type: 1971 + host_id: 12 + reserved: 0 + + - + start_resource: 43 + num_resource: 8 + type: 1972 + host_id: 12 + reserved: 0 + + - + start_resource: 0 + num_resource: 1 + type: 2112 + host_id: 128 + reserved: 0 + + - + start_resource: 2 + num_resource: 2 + type: 2122 + host_id: 12 + reserved: 0 diff --git a/board/phytec/phycore_am62x/sec-cfg.yaml b/board/phytec/phycore_am62x/sec-cfg.yaml new file mode 100644 index 0000000000..07081ce06c --- /dev/null +++ b/board/phytec/phycore_am62x/sec-cfg.yaml @@ -0,0 +1,379 @@ +# SPDX-License-Identifier: GPL-2.0+ +# Copyright (C) 2022-2023 Texas Instruments Incorporated - https://www.ti.com/ +# +# Security management configuration for AM62 +# + +--- + +sec-cfg: + rev: + boardcfg_abi_maj : 0x0 + boardcfg_abi_min : 0x1 + processor_acl_list: + subhdr: + magic: 0xF1EA + size: 164 + proc_acl_entries: + - #1 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #2 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #3 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #4 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #5 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #6 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #7 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #8 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #9 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #10 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #11 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #12 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #13 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #14 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #15 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #16 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #17 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #18 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #19 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #20 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #21 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #22 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #23 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #24 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #25 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #26 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #27 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #28 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #29 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #30 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #31 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + - #32 + processor_id: 0 + proc_access_master: 0 + proc_access_secondary: [0, 0, 0] + host_hierarchy: + subhdr: + magic: 0x8D27 + size: 68 + host_hierarchy_entries: + - #1 + host_id: 0 + supervisor_host_id: 0 + - #2 + host_id: 0 + supervisor_host_id: 0 + - #3 + host_id: 0 + supervisor_host_id: 0 + - #4 + host_id: 0 + supervisor_host_id: 0 + - #5 + host_id: 0 + supervisor_host_id: 0 + - #6 + host_id: 0 + supervisor_host_id: 0 + - #7 + host_id: 0 + supervisor_host_id: 0 + - #8 + host_id: 0 + supervisor_host_id: 0 + - #9 + host_id: 0 + supervisor_host_id: 0 + - #10 + host_id: 0 + supervisor_host_id: 0 + - #11 + host_id: 0 + supervisor_host_id: 0 + - #12 + host_id: 0 + supervisor_host_id: 0 + - #13 + host_id: 0 + supervisor_host_id: 0 + - #14 + host_id: 0 + supervisor_host_id: 0 + - #15 + host_id: 0 + supervisor_host_id: 0 + - #16 + host_id: 0 + supervisor_host_id: 0 + - #17 + host_id: 0 + supervisor_host_id: 0 + - #18 + host_id: 0 + supervisor_host_id: 0 + - #19 + host_id: 0 + supervisor_host_id: 0 + - #20 + host_id: 0 + supervisor_host_id: 0 + - #21 + host_id: 0 + supervisor_host_id: 0 + - #22 + host_id: 0 + supervisor_host_id: 0 + - #23 + host_id: 0 + supervisor_host_id: 0 + - #24 + host_id: 0 + supervisor_host_id: 0 + - #25 + host_id: 0 + supervisor_host_id: 0 + - #26 + host_id: 0 + supervisor_host_id: 0 + - #27 + host_id: 0 + supervisor_host_id: 0 + - #28 + host_id: 0 + supervisor_host_id: 0 + - #29 + host_id: 0 + supervisor_host_id: 0 + - #30 + host_id: 0 + supervisor_host_id: 0 + - #31 + host_id: 0 + supervisor_host_id: 0 + - #32 + host_id: 0 + supervisor_host_id: 0 + otp_config: + subhdr: + magic: 0x4081 + size: 69 + write_host_id : 0 + otp_entry: + - #1 + host_id: 0 + host_perms: 0 + - #2 + host_id: 0 + host_perms: 0 + - #3 + host_id: 0 + host_perms: 0 + - #4 + host_id: 0 + host_perms: 0 + - #5 + host_id: 0 + host_perms: 0 + - #6 + host_id: 0 + host_perms: 0 + - #7 + host_id: 0 + host_perms: 0 + - #8 + host_id: 0 + host_perms: 0 + - #9 + host_id: 0 + host_perms: 0 + - #10 + host_id: 0 + host_perms: 0 + - #11 + host_id: 0 + host_perms: 0 + - #12 + host_id: 0 + host_perms: 0 + - #13 + host_id: 0 + host_perms: 0 + - #14 + host_id: 0 + host_perms: 0 + - #15 + host_id: 0 + host_perms: 0 + - #16 + host_id: 0 + host_perms: 0 + - #17 + host_id: 0 + host_perms: 0 + - #18 + host_id: 0 + host_perms: 0 + - #19 + host_id: 0 + host_perms: 0 + - #20 + host_id: 0 + host_perms: 0 + - #21 + host_id: 0 + host_perms: 0 + - #22 + host_id: 0 + host_perms: 0 + - #23 + host_id: 0 + host_perms: 0 + - #24 + host_id: 0 + host_perms: 0 + - #25 + host_id: 0 + host_perms: 0 + - #26 + host_id: 0 + host_perms: 0 + - #27 + host_id: 0 + host_perms: 0 + - #28 + host_id: 0 + host_perms: 0 + - #29 + host_id: 0 + host_perms: 0 + - #30 + host_id: 0 + host_perms: 0 + - #31 + host_id: 0 + host_perms: 0 + - #32 + host_id: 0 + host_perms: 0 + dkek_config: + subhdr: + magic: 0x5170 + size: 12 + allowed_hosts: [128, 0, 0, 0] + allow_dkek_export_tisci : 0x5A + rsvd: [0, 0, 0] + sa2ul_cfg: + subhdr: + magic: 0x23BE + size : 0 + auth_resource_owner: 0 + enable_saul_psil_global_config_writes: 0x5A + rsvd: [0, 0] + sec_dbg_config: + subhdr: + magic: 0x42AF + size: 16 + allow_jtag_unlock : 0x5A + allow_wildcard_unlock : 0x5A + allowed_debug_level_rsvd: 0 + rsvd: 0 + min_cert_rev : 0x0 + jtag_unlock_hosts: [0, 0, 0, 0] + sec_handover_cfg: + subhdr: + magic: 0x608F + size: 10 + handover_msg_sender : 0 + handover_to_host_id : 0 + rsvd: [0, 0, 0, 0] diff --git a/configs/phycore_am62x_a53_defconfig b/configs/phycore_am62x_a53_defconfig new file mode 100644 index 0000000000..fb5c3f9fb9 --- /dev/null +++ b/configs/phycore_am62x_a53_defconfig @@ -0,0 +1,115 @@ +CONFIG_ARM=y +CONFIG_ARCH_K3=y +CONFIG_SYS_MALLOC_F_LEN=0x8000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_SOC_K3_AM625=y +CONFIG_K3_ATF_LOAD_ADDR=0x9e780000 +CONFIG_TARGET_PHYCORE_AM62X_A53=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80b80000 +CONFIG_SF_DEFAULT_SPEED=25000000 +CONFIG_ENV_SIZE=0x2000 +CONFIG_ENV_OFFSET=0xFFFFD000 +CONFIG_SPL_DM_SPI=y +CONFIG_DEFAULT_DEVICE_TREE="k3-am625-phyboard-lyra-rdk" +CONFIG_SPL_TEXT_BASE=0x80080000 +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_DM_RESET=y +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_STACK_R_ADDR=0x82000000 +CONFIG_SPL_SIZE_LIMIT=0x40000 +CONFIG_SPL_SIZE_LIMIT_PROVIDE_STACK=0x800 +CONFIG_SPL_FS_FAT=y +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y +# CONFIG_PSCI_RESET is not set +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 +CONFIG_BOOTSTD_FULL=y +CONFIG_BOOTSTD_DEFAULTS=y +CONFIG_SYS_BOOTM_LEN=0x800000 +CONFIG_BOOTCOMMAND="run mmcboot; bootflow scan -lb" +CONFIG_DEFAULT_FDT_FILE="oftree" +CONFIG_SPL_MAX_SIZE=0x58000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x80c80000 +CONFIG_SPL_BSS_MAX_SIZE=0x80000 +CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_STACK_R=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 +CONFIG_SPL_ENV_SUPPORT=y +CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" +CONFIG_SPL_DM_MAILBOX=y +CONFIG_SPL_DM_SPI_FLASH=y +CONFIG_SPL_POWER_DOMAIN=y +# CONFIG_SPL_SPI_FLASH_TINY is not set +CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x280000 +CONFIG_SPL_YMODEM_SUPPORT=y +CONFIG_CMD_MMC=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_MULTI_DTB_FIT=y +CONFIG_SPL_MULTI_DTB_FIT=y +CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_MMC_ENV_DEV=1 +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_OF_TRANSLATE=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_CLK_TI_SCI=y +CONFIG_DMA_CHANNELS=y +CONFIG_TI_K3_NAVSS_UDMA=y +CONFIG_TI_SCI_PROTOCOL=y +CONFIG_DM_MAILBOX=y +CONFIG_K3_SEC_PROXY=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ADMA=y +CONFIG_SPL_MMC_SDHCI_ADMA=y +CONFIG_MMC_SDHCI_AM654=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +# CONFIG_SPI_FLASH_SMART_HWCAPS is not set +CONFIG_SPI_FLASH_SOFT_RESET=y +CONFIG_SPI_FLASH_SOFT_RESET_ON_BOOT=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_S28HX_T=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_MT35XU=y +CONFIG_PHY_TI_DP83867=y +CONFIG_PHY_FIXED=y +CONFIG_TI_AM65_CPSW_NUSS=y +CONFIG_PHY=y +CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y +CONFIG_PINCTRL_SINGLE=y +CONFIG_POWER_DOMAIN=y +CONFIG_TI_SCI_POWER_DOMAIN=y +CONFIG_K3_SYSTEM_CONTROLLER=y +CONFIG_REMOTEPROC_TI_K3_ARM64=y +CONFIG_RESET_TI_SCI=y +CONFIG_DM_SERIAL=y +CONFIG_SOC_DEVICE=y +CONFIG_SOC_DEVICE_TI_K3=y +CONFIG_SOC_TI=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_CADENCE_QSPI=y +CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y +CONFIG_SYSRESET_TI_SCI=y +CONFIG_FS_FAT_MAX_CLUSTSIZE=16384 diff --git a/configs/phycore_am62x_r5_defconfig b/configs/phycore_am62x_r5_defconfig new file mode 100644 index 0000000000..f655d1bfde --- /dev/null +++ b/configs/phycore_am62x_r5_defconfig @@ -0,0 +1,130 @@ +CONFIG_ARM=y +CONFIG_ARCH_K3=y +CONFIG_SYS_MALLOC_LEN=0x08000000 +CONFIG_SYS_MALLOC_F_LEN=0x9000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_SOC_K3_AM625=y +CONFIG_TARGET_PHYCORE_AM62X_R5=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x43c3a7f0 +CONFIG_SF_DEFAULT_SPEED=25000000 +CONFIG_SF_DEFAULT_MODE=0 +CONFIG_ENV_SIZE=0x20000 +CONFIG_DM_GPIO=y +CONFIG_SPL_DM_SPI=y +CONFIG_DEFAULT_DEVICE_TREE="k3-am625-r5-phycore-som-2gb" +CONFIG_SPL_TEXT_BASE=0x43c00000 +CONFIG_DM_RESET=y +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_SPL_STACK_R_ADDR=0x82000000 +CONFIG_SPL_SYS_MALLOC_F_LEN=0x7000 +CONFIG_SPL_SIZE_LIMIT=0x3A7F0 +CONFIG_SPL_SIZE_LIMIT_PROVIDE_STACK=0x3500 +CONFIG_SPL_FS_FAT=y +CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_SPL_LOAD_FIT_ADDRESS=0x80080000 +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_SIZE_LIMIT_SUBTRACT_GD=y +CONFIG_SPL_SIZE_LIMIT_SUBTRACT_MALLOC=y +CONFIG_SPL_MAX_SIZE=0x3B000 +CONFIG_SPL_PAD_TO=0x0 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x43c3b000 +CONFIG_SPL_BSS_MAX_SIZE=0x3000 +CONFIG_SPL_SYS_REPORT_STACK_F_USAGE=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x200000 +CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_SYS_MALLOC=y +CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y +CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x84000000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x1000000 +CONFIG_SPL_EARLY_BSS=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 +CONFIG_SPL_DM_MAILBOX=y +CONFIG_SPL_DM_SPI_FLASH=y +CONFIG_SPL_DM_RESET=y +CONFIG_SPL_POWER_DOMAIN=y +CONFIG_SPL_RAM_SUPPORT=y +CONFIG_SPL_RAM_DEVICE=y +CONFIG_SPL_REMOTEPROC=y +# CONFIG_SPL_SPI_FLASH_TINY is not set +CONFIG_SPL_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x80000 +CONFIG_SPL_YMODEM_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_ASKENV=y +CONFIG_CMD_DFU=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_REMOTEPROC=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_CMD_FAT=y +CONFIG_OF_CONTROL=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_SPL_MULTI_DTB_FIT=y +CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_SPL_DM=y +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_REGMAP=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_OF_TRANSLATE=y +CONFIG_CLK=y +CONFIG_SPL_CLK=y +CONFIG_SPL_CLK_CCF=y +CONFIG_SPL_CLK_K3_PLL=y +CONFIG_SPL_CLK_K3=y +CONFIG_TI_SCI_PROTOCOL=y +CONFIG_DA8XX_GPIO=y +CONFIG_DM_MAILBOX=y +CONFIG_K3_SEC_PROXY=y +CONFIG_SPL_MISC=y +CONFIG_ESM_K3=y +CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ADMA=y +CONFIG_SPL_MMC_SDHCI_ADMA=y +CONFIG_MMC_SDHCI_AM654=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +# CONFIG_SPI_FLASH_SMART_HWCAPS is not set +CONFIG_SPI_FLASH_SOFT_RESET=y +CONFIG_SPI_FLASH_SOFT_RESET_ON_BOOT=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_MT35XU=y +CONFIG_PINCTRL=y +# CONFIG_PINCTRL_GENERIC is not set +CONFIG_SPL_PINCTRL=y +# CONFIG_SPL_PINCTRL_GENERIC is not set +CONFIG_PINCTRL_SINGLE=y +CONFIG_POWER_DOMAIN=y +CONFIG_TI_POWER_DOMAIN=y +CONFIG_K3_SYSTEM_CONTROLLER=y +CONFIG_REMOTEPROC_TI_K3_ARM64=y +CONFIG_RESET_TI_SCI=y +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_DM_SERIAL=y +CONFIG_SOC_DEVICE=y +CONFIG_SOC_DEVICE_TI_K3=y +CONFIG_SOC_TI=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_CADENCE_QSPI=y +CONFIG_TIMER=y +CONFIG_SPL_TIMER=y +CONFIG_OMAP_TIMER=y +CONFIG_LIB_RATIONAL=y +CONFIG_SPL_LIB_RATIONAL=y diff --git a/include/configs/phycore_am62x.h b/include/configs/phycore_am62x.h new file mode 100644 index 0000000000..10b78b6f53 --- /dev/null +++ b/include/configs/phycore_am62x.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Configuration header file for PHYTEC phyCORE-AM62x + * + * Copyright (C) 2023 PHYTEC Messtechnik GmbH + * Author: Wadim Egorov w.egorov@phytec.de + */ + +#ifndef __PHYCORE_AM62X_H +#define __PHYCORE_AM62X_H + +/* DDR Configuration */ +#define CFG_SYS_SDRAM_BASE 0x80000000 + +#endif /* __PHYCORE_AM62X_H */
On Nov 30, 2023 at 12:56:06 +0100, Wadim Egorov wrote:
Add basic support for PHYTEC phyCORE-AM62x SoM.
Supported features:
- 2GB DDR4 RAM
- eMMC Flash
- OSPI NOR Flash
- external uSD
- Ethernet
- debug UART
Product page SoM: https://www.phytec.com/product/phycore-am62x
Device trees were taken from Linux v6.7-rc3.
Thanks for providing the Linux tag, since DT changes are in sync with kernel,
Reviewed-by: Dhruva Gole d-gole@ti.com
Signed-off-by: Wadim Egorov w.egorov@phytec.de
v2:
- Add cover-letter & mention Linux version I took the DTs from
- Move board selection to mach-k3
- Add missing SPL_LDSCRIPT definition
- Refactore binman file for templated FITs & drop key overrides
- Drop SoC provided bootph params from dt files Note: Later we can drop more bootph params after we added them to Linux
- Drop CONFIG_TI_SECURE_DEVICE as it is set as default for K3
- Drop cpsw3g custom DT property 'mac_efuse' and custom DT node cpsw-phy-sel as driver picks these from standard property/node (-u-boot.dtsi)
- Add a53 cluster power to control from the rproc driver (a53 dt node)
arch/arm/dts/Makefile | 4 +- .../arm/dts/k3-am62-phycore-som-ddr4-2gb.dtsi | 2190 +++++++++++++++++ arch/arm/dts/k3-am62-phycore-som.dtsi | 324 +++ .../k3-am625-phyboard-lyra-rdk-u-boot.dtsi | 166 ++ arch/arm/dts/k3-am625-phyboard-lyra-rdk.dts | 266 ++ arch/arm/dts/k3-am625-phycore-som-binman.dtsi | 380 +++ arch/arm/dts/k3-am625-r5-phycore-som-2gb.dts | 119 + arch/arm/mach-k3/am62x/Kconfig | 17 + board/phytec/phycore_am62x/Kconfig | 33 + board/phytec/phycore_am62x/MAINTAINERS | 15 + board/phytec/phycore_am62x/Makefile | 8 + board/phytec/phycore_am62x/board-cfg.yaml | 36 + board/phytec/phycore_am62x/phycore-am62x.c | 59 + board/phytec/phycore_am62x/phycore_am62x.env | 23 + board/phytec/phycore_am62x/pm-cfg.yaml | 12 + board/phytec/phycore_am62x/rm-cfg.yaml | 1088 ++++++++ board/phytec/phycore_am62x/sec-cfg.yaml | 379 +++ configs/phycore_am62x_a53_defconfig | 115 + configs/phycore_am62x_r5_defconfig | 130 + include/configs/phycore_am62x.h | 15 + 20 files changed, 5378 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/k3-am62-phycore-som-ddr4-2gb.dtsi create mode 100644 arch/arm/dts/k3-am62-phycore-som.dtsi create mode 100644 arch/arm/dts/k3-am625-phyboard-lyra-rdk-u-boot.dtsi create mode 100644 arch/arm/dts/k3-am625-phyboard-lyra-rdk.dts create mode 100644 arch/arm/dts/k3-am625-phycore-som-binman.dtsi create mode 100644 arch/arm/dts/k3-am625-r5-phycore-som-2gb.dts create mode 100644 board/phytec/phycore_am62x/Kconfig create mode 100644 board/phytec/phycore_am62x/MAINTAINERS create mode 100644 board/phytec/phycore_am62x/Makefile create mode 100644 board/phytec/phycore_am62x/board-cfg.yaml create mode 100644 board/phytec/phycore_am62x/phycore-am62x.c create mode 100644 board/phytec/phycore_am62x/phycore_am62x.env create mode 100644 board/phytec/phycore_am62x/pm-cfg.yaml create mode 100644 board/phytec/phycore_am62x/rm-cfg.yaml create mode 100644 board/phytec/phycore_am62x/sec-cfg.yaml create mode 100644 configs/phycore_am62x_a53_defconfig create mode 100644 configs/phycore_am62x_r5_defconfig create mode 100644 include/configs/phycore_am62x.h
Add documentation for PHYTEC phyCORE-AM62x SoM.
Signed-off-by: Wadim Egorov w.egorov@phytec.de --- v2: Rebased on top of -next
--- doc/board/phytec/index.rst | 1 + doc/board/phytec/phycore-am62x.rst | 125 +++++++++++++++++++++++++++++ doc/board/ti/k3.rst | 1 + 3 files changed, 127 insertions(+) create mode 100644 doc/board/phytec/phycore-am62x.rst
diff --git a/doc/board/phytec/index.rst b/doc/board/phytec/index.rst index a5b442045e..b914cc3fbd 100644 --- a/doc/board/phytec/index.rst +++ b/doc/board/phytec/index.rst @@ -6,5 +6,6 @@ PHYTEC .. toctree:: :maxdepth: 2
+ phycore-am62x phycore-imx8mm phycore-imx8mp diff --git a/doc/board/phytec/phycore-am62x.rst b/doc/board/phytec/phycore-am62x.rst new file mode 100644 index 0000000000..46312a73bc --- /dev/null +++ b/doc/board/phytec/phycore-am62x.rst @@ -0,0 +1,125 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. sectionauthor:: Wadim Egorov w.egorov@phytec.de + +phyCORE-AM62x +============= + +The `phyCORE-AM62x https://www.phytec.com/product/phycore-am62x`_ is a +SoM (System on Module) featuring TI's AM62x SoC. It can be used in combination +with different carrier boards. This module can come with different sizes and +models for DDR, eMMC, SPI NOR Flash and various SoCs from the AM62x family. + +A development Kit, called `phyBOARD-Lyra https://www.phytec.com/product/phyboard-am62x`_ +is used as a carrier board reference design around the AM62x SoM. + +Quickstart +---------- + +* Download sources and TI firmware blobs +* Build Trusted Firmware-A +* Build OP-TEE +* Build U-Boot for the R5 +* Build U-Boot for the A53 +* Create bootable uSD Card +* Boot + +Sources +------- + +.. include:: ../ti/k3.rst + :start-after: .. k3_rst_include_start_boot_sources + :end-before: .. k3_rst_include_end_boot_sources + +Build procedure +--------------- + +Setup the environment variables: + +.. include:: ../ti/k3.rst + :start-after: .. k3_rst_include_start_common_env_vars_desc + :end-before: .. k3_rst_include_end_common_env_vars_desc + +.. include:: ../ti/k3.rst + :start-after: .. k3_rst_include_start_board_env_vars_desc + :end-before: .. k3_rst_include_end_board_env_vars_desc + +Set the variables corresponding to this platform: + +.. include:: ../ti/k3.rst + :start-after: .. k3_rst_include_start_common_env_vars_defn + :end-before: .. k3_rst_include_end_common_env_vars_defn +.. code-block:: bash + + $ export UBOOT_CFG_CORTEXR=phycore_am62x_r5_defconfig + $ export UBOOT_CFG_CORTEXA=phycore_am62x_a53_defconfig + $ export TFA_BOARD=lite + $ # we don't use any extra TFA parameters + $ unset TFA_EXTRA_ARGS + $ export OPTEE_PLATFORM=k3-am62x + $ export OPTEE_EXTRA_ARGS="CFG_WITH_SOFTWARE_PRNG=y" + +.. include:: ../ti/am62x_sk.rst + :start-after: .. am62x_evm_rst_include_start_build_steps + :end-before: .. am62x_evm_rst_include_end_build_steps + +uSD Card creation +----------------- + +Use fdisk to partition the uSD card. The layout should look similar to: + +.. code-block:: bash + + $ sudo fdisk -l /dev/mmcblk0 + Disk /dev/mmcblk0: 7.56 GiB, 8120172544 bytes, 15859712 sectors + Units: sectors of 1 * 512 = 512 bytes + Sector size (logical/physical): 512 bytes / 512 bytes + I/O size (minimum/optimal): 512 bytes / 512 bytes + Disklabel type: dos + Disk identifier: 0x6583d9a3 + + Device Boot Start End Sectors Size Id Type + /dev/mmcblk0p1 * 2048 264191 262144 128M c W95 FAT32 (LBA) + /dev/mmcblk0p2 264192 1934953 1670762 815.8M 83 Linux + + +Once partitioned, the boot partition has to be formatted with a FAT filesystem. +Assuming the uSD card is `/dev/mmcblk0`: + +.. code-block:: bash + + $ mkfs.vfat /dev/mmcblk0p1 + +To boot from an uSD on a GP device simply copy the following artifacts to the +FAT partition: + +* tiboot3-am62x-gp-phycore-som.bin from R5 build as tiboot3.bin +* tispl.bin_unsigned from Cortex-A build as tispl.bin +* u-boot.img_unsigned from Cortex-A build as u-boot.img + +Boot +---- + +Put the uSD card in the slot on the board and apply power. Check the serial +console for output. + +Flash to SPI NOR +---------------- + +Below commands can be used to flash the SPI NOR flash; assuming +tiboot3.bin, tispl.bin and u-boot.img are stored on the uSD card. + +.. code-block:: bash + + sf probe + fatload mmc 1 ${loadaddr} tiboot3.bin + sf update $loadaddr 0x0 $filesize + fatload mmc 1 ${loadaddr} tispl.bin + sf update $loadaddr 0x80000 $filesize + fatload mmc 1 ${loadaddr} u-boot.img + sf update $loadaddr 0x280000 $filesize + +Further Information +------------------- + +Please see :doc:`../ti/am62x_sk` chapter for further AM62 SoC related documentation +and https://docs.phytec.com/phycore-am62x for vendor documentation. diff --git a/doc/board/ti/k3.rst b/doc/board/ti/k3.rst index a127215ce5..435c72a428 100644 --- a/doc/board/ti/k3.rst +++ b/doc/board/ti/k3.rst @@ -33,6 +33,7 @@ K3 Based SoCs am62ax_sk am62x_sk ../beagle/am62x_beagleplay + ../phytec/phycore-am62x ../toradex/verdin-am62 am64x_evm am65x_evm
Please CC Tom Rini trini@konsulko.com on the series.
- phycore-am62x phycore-imx8mm phycore-imx8mp
+Sources +-------
- :start-after: .. k3_rst_include_start_boot_sources
- :end-before: .. k3_rst_include_end_boot_sources
- :start-after: .. k3_rst_include_start_common_env_vars_desc
- :end-before: .. k3_rst_include_end_common_env_vars_desc
- :start-after: .. k3_rst_include_start_board_env_vars_desc
- :end-before: .. k3_rst_include_end_board_env_vars_desc
- :start-after: .. k3_rst_include_start_common_env_vars_defn
- :end-before: .. k3_rst_include_end_common_env_vars_defn
- $ export UBOOT_CFG_CORTEXR=phycore_am62x_r5_defconfig
- $ export UBOOT_CFG_CORTEXA=phycore_am62x_a53_defconfig
- $ export TFA_BOARD=lite
- $ # we don't use any extra TFA parameters
- $ unset TFA_EXTRA_ARGS
- $ export OPTEE_PLATFORM=k3-am62x
- $ export OPTEE_EXTRA_ARGS="CFG_WITH_SOFTWARE_PRNG=y"
Does this need to be the case? If it's just copied from AM62x then I think I need to fix that documentation, not sure if we necessarily need SW_RNG and thus disable HW_RNG upstream.
The context here was we were enabling SW_RNG a while back due to a crash after suspend resume on AM62x, however that issue no longer seems to cause any lock ups/ crash.
- :start-after: .. am62x_evm_rst_include_start_build_steps
- :end-before: .. am62x_evm_rst_include_end_build_steps
- $ sudo fdisk -l /dev/mmcblk0
- Disk /dev/mmcblk0: 7.56 GiB, 8120172544 bytes, 15859712 sectors
- Units: sectors of 1 * 512 = 512 bytes
- Sector size (logical/physical): 512 bytes / 512 bytes
- I/O size (minimum/optimal): 512 bytes / 512 bytes
- Disklabel type: dos
- Disk identifier: 0x6583d9a3
- Device Boot Start End Sectors Size Id Type
- /dev/mmcblk0p1 * 2048 264191 262144 128M c W95 FAT32 (LBA)
- /dev/mmcblk0p2 264192 1934953 1670762 815.8M 83 Linux
- $ mkfs.vfat /dev/mmcblk0p1
nit: "a" micro SD card not an
Are most of the SoM's GP devices? Otherwise thinking if we should make the documentation for HSFS as a default and GP as an exception?
Or else just say copy tiboot3.bin as is on the SD card for HSFS devices and for GP.... (as you have done below)
+FAT partition:
+Boot +----
- sf probe
- fatload mmc 1 ${loadaddr} tiboot3.bin
- sf update $loadaddr 0x0 $filesize
- fatload mmc 1 ${loadaddr} tispl.bin
- sf update $loadaddr 0x80000 $filesize
- fatload mmc 1 ${loadaddr} u-boot.img
- sf update $loadaddr 0x280000 $filesize
Want to add some documentation on Boot Modes? Something like [0]?
- ../phytec/phycore-am62x ../toradex/verdin-am62 am64x_evm
Rest looks good, so with the above suggestions,
[0] https://docs.u-boot.org/en/v2023.07.02/board/ti/am62x_sk.html
Hi Dhruva,
Am 01.12.23 um 11:10 schrieb Dhruva Gole:
+Sources +-------
Yep, copy&paste. I'll remove it.
Currently, most devices around are GPs. But this will change. So making HSFS as default makes sense.
+FAT partition:
+Boot +----
- sf probe
Good idea.
For both patches or only for the docs part?
Regards, Wadim
Dhruva Gole
Wadim Egorov
