[U-Boot] FPGA relocation/C environment
I am using U-Boot on a Coldfire to load FPGA code (Xilinx Spartan3 and Altera Cyclone2, currently) and am just trying to update my code base to current U-Boot for finally sending patches.
Now I recognized that commit 6385b28116f775da4771b768ba9bf93c3aaaf26e removed FPGA relocation, which of course breaks FPGA code for my Coldfire board.
What is the "proper relocation for PPC boards" that is mentioned by Peter in his commit log? I found this test patch by him: http://lists.denx.de/pipermail/u-boot/2009-September/060582.html which leads me to the assumption that for PPC, newer compilers do the right thing (TM) when given -mrelocatable, but - my m68k-elf-gcc (Sourcery G++ Lite 4.3-208) 4.3.3 (that was the newest one I could get my hands on that is able to compile U-Boot at all) does not know -mrelocatable - I do not understand how the compiler could know about the relocation for the FPGA (and possibly other) functions when the actual relocation is done during U-Boot run time?
Can anybody give some hints where I have to look at or where my misunderstanding occurs?
Thank you, Wolfgang
Dear Wolfgang Wegner,
This is an out-of-tree port, right? If your code had been in mainline, this would not have happened.
The compiler / linker create a Global Offset Table (GOT) which basicly is a list of offsets to the image, where address constants need to be updated to relocate the image to a new address. This is what the U-Boot relocation code does: add a (fixed) relocation offset (target address - source address) to all the locations listed in the GOT. The problem was, that certain types of addresses (statically initialized function pointers) did not get listed in the GOT. This is now fixed.
Dear Wolfgang Denk,
I know, as I mentioned in the first place, I am right now updating to get it integrated. (see below for the footnote)
Thank you for the clarification! I will see if I can find out in which state gcc and U-Boot for coldfire are in this respect.
Best regards, Wolfgang
[At the time of the original port, MCF532x/7x was not present in U-Boot; my own port had quite many conflicts (probably because of me being still very unfamiliar with U-Boot and its concepts) with the upcoming official port, which in turn had some severe problems at least with my setup. This and the fact that I needed some time to get at least a bit familiar with git led to me sticking with my old out-of-tree port. Now as the official MCF537x port is settled I am in the process of doing my homework...]
Just to avoid any misunderstandings, the GOT does not hold offsets, it holds absolute addresses. These addresses gets adjusted with an offset when you relocate.
Dear Joakim Tjernlund,
thank you, I already understood this.
As far as I can see there is already some GOT handling in cpu/mcf532x/start.S and the flags (-fPIC) in cpu/mcf532x/config.mk (and other coldfire ports, but MCF532x/MCF537x is what I am currently working on for testing), but somehow it does not work. However, it takes some time for me to understand the assembler code, especially the powerpc counterpart I am using as a reference.
There is a __got_start and __got_end in my u-boot.map, so I would think the linker does behave correctly - but I did not yet check if all the symbols (better: symbols' addresses) expected to be there are really present:
.reloc 0x00024600 0x1990 0x00024600 __got_start = . *(.got) .got 0x00024600 0x1990 cpu/mcf532x/cpu_init.o 0x00025f90 __got_end = . 0x00025f90 _GOT2_TABLE_ = . *(.got2) 0x00025f90 _FIXUP_TABLE_ = . *(.fixup) 0x00000000 __got2_entries = ((_FIXUP_TABLE_ - _GOT2_TABLE_) >> 0x2) 0x00000000 __fixup_entries = ((. - _FIXUP_TABLE_) >> 0x2)
(flash resides at 0x0, SDRAM at 0x4000000 and CONFIG_SYS_MONITOR_BASE is 0x40020000)
Regards, Wolfgang
wolfgang@leila.ping.de (Wolfgang Wegner) wrote on 29/10/2009 14:41:00:
It seems like you don't have any relocation data as both __got2_entries and __fixup_entries are zero. Something seems broken in general, perhaps your linker script is bust?
I took board/freescale/m5373evb/u-boot.lds without modifications first. After noticing that the PPC linker scripts do not have this entry (at this place), I removed "*(.fixup)" in the .text section, but this did not change anything. However, in my u-boot.map, I have some .data.rel entries which look as if they would belong into the .fixup section?! [...] .data.rel 0x00026eb4 0x30 lib_m68k/libm68k.a(board.o) 0x00026eb4 init_sequence .data.rel 0x00026ee4 0x4c common/libcommon.a(cmd_bootm.o) 0x00026ee4 boot_os .data.rel 0x00026f30 0x24 common/libcommon.a(cmd_mii.o) 0x00026f30 desc_and_len_tbl .data.rel 0x00026f54 0x88 board/astro/mcf5373l/libmcf5373l.a(fpga.o) 0x00026f88 xilinx_fns 0x00026fa8 xilinx_qspi_fns 0x00026f70 altera_fpga 0x00026f54 altera_fns 0x00026fc8 xilinx_fpga 0x00026fdc . = . 0x00026fdc __u_boot_cmd_start = . [...]
(From fpga.c: [...] Xilinx_Spartan3_Slave_Serial_fns xilinx_fns = { xilinx_pre_config_fn, xilinx_pgm_fn, xilinx_clk_fn, xilinx_init_fn, xilinx_done_fn, xilinx_wr_fn, 0, xilinx_fastwr_fn };
Xilinx_desc xilinx_fpga[CONFIG_FPGA_COUNT] = { {Xilinx_Spartan3, slave_serial, XILINX_XC3S4000_SIZE, #if FPGA_QSPI (void *) &xilinx_qspi_fns, #else (void *) &xilinx_fns, #endif 0} }; [...] )
I did not find a special entry for .data.rel (or .data.*) in the PPC u-boot.lds either, so maybe this is something the linker should do automatically?
Regards, Wolfgang
although I have to leave for now, just some questions to see if there is anything I understood correctly until now...
- in the PPC startup (assembly) files, the section .got2 is explicitely created using START_GOT etc. - .got2 contains some vital pointers (vectors) as well as data pointers like a pointer to .fixup and a pointer to itself (?!) - the ppc linker automatically puts .data.rel (and other relocatable sections?) into .fixup (which seems not the case with my m68k linker) - the ppc startup code uses some obfuscated assembly code ;-) to relocate both the global relocation table (.got) as well as the sections .got2 and .fixup (.got seems to be implicitly mentioned: "/* First our own GOT */ add r14, r14, r15 /* then the one used by the C code */ add r30, r30, r15" but I can not see where it is actually relocated...)
Is this correct so far? I am not sure because it seems more complicated than necessary to me (especially the algorithm to relocate .got2 and .fixup - or is this all about the possibility to do multiple relocations?), so maybe I still have a misunderstanding here. Furthermore, the special handling of r14 (-ffixed-r14 in config.mk) still puzzles me.
Thank you and best regards, Wolfgang
wolfgang@leila.ping.de (Wolfgang Wegner) wrote on 29/10/2009 16:44:55:
It adds a few entries to .got2 as the asm needs to access a few entries vis the GOT. If you look at the asm generated by gcc, it does the same for global data.
The first entry in got2 host a pointer to itself, this is needed by relocation later. .fixup entries is created by -mrelocatable and WD has mentioned what these are for.
As I recall that code is a leftover, at least the C version. Relocation happens directly after the in_ram: label. However, this is not you problem. You don't have any relocation entries so there is nothing to relocate. Your linker/linker script is broken.
The -ffixed-r14 is for IRQ procressing. The irq code needs to jump to transfer_to_handler via the GOT and needs r14 to hold a ptr to the GOT at all times. This can be avoided and I have a patch to get rid of ffixed-r14 but only for mpc83xx so I or someone else needs to do the other boards too before it can be committed.
Jocke
thank you all for all the comments so far.
It seems I have at least 2 problems: - my gcc (m68k-elf-gcc (Sourcery G++ Lite 4.3-208) 4.3.3) does not produce correctly relocatable code; no matter if I give -fPIC or not (-mrelocatable is not accepted at all), I do not get any entries in .got2 or .fixup, only .got However, there still may be anything wrong in my conclusion, because I can use this compiler to compile uClinux-dist-20071107 and get working applications (which, as far as I understand, have to be relocated at runtime, too, but I do not know if any of these use such features as statically initialized function pointers that I have in the U-Boot fpga code...). - the current coldfire startup code (at least for MCF532x/MCF537x) would not handle these sections even if they existed - however, this seems to be rather easily (i.e. maybe even I could do it) fixed, looking at the ppc examples.
I will first live with the problem (relocating the fpga struct pointers in my own board code, where it is filled anyways - for coldfire, gd->reloc_off is still present) and see if I can get hold of a better gcc version. I tried gcc-4.4.1, but was unable to compile one of U-Boot or uClinux, so switched back to this one which I found to compile (old and current) U-Boot, old uClinux _and_ support mcf5445x, which I am designing in now...
Thank you and sorry for my stupid questions.
Regards, Wolfgang
-mreloctable only applies to PPC CPUs - not version of gcc will give you .got2 and .fixup unless you are building for PPC
They are build and linked as pic or pie (position independent executable) This puts information in the elf binary that the dynamic loader/linker can user to modify the executable as it is loaded into memory to enable it to run at the target load address
You might want to look at the x86 example instead. I posted a patch a while ago (http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/68923)
Yes, this manual 'fixup' will work, but the long term goal is to remove this
Not stupid at all - Proper relocation can be very tricky to achieve. I spent a _long_ time getting it to work for x86, and in the end the solution is rather trivial - Have a search through the u-boot mailing list ;)
Regards, Wolfgang
Regards,
Graeme
wolfgang@leila.ping.de (Wolfgang Wegner) wrote on 29/10/2009 16:00:04:
linker script
is bust?
Compile one small file into asm (use -S to gcc) with and without -fPIC then compare where the relocation data goes. Normally they will be in .got2 but perhaps your compiler does something else?
Graeme Russ
Joakim Tjernlund
