[PATCH] Makefile: imx: Do not call arch/arm/mach-imx flash.bin generation if BINMAN enabled
Skip running arch/arm/mach-imx flash.bin generation in case BINMAN is enabled, otherwise the target in arch/arm/mach-imx/Makefile regenerates the flash.bin again and produces corrupted result.
Signed-off-by: Marek Vasut marex@denx.de Cc: Peng Fan peng.fan@oss.nxp.com Cc: Simon Glass sjg@chromium.org --- Makefile | 1 - 1 file changed, 1 deletion(-)
diff --git a/Makefile b/Makefile index ae9bfab91ac..c04caaebc8e 100644 --- a/Makefile +++ b/Makefile @@ -1517,7 +1517,6 @@ else ifeq ($(CONFIG_BINMAN),y) flash.bin: spl/u-boot-spl.bin $(INPUTS-y) FORCE $(call if_changed,binman) - $(Q)$(MAKE) $(build)=arch/arm/mach-imx $@ else flash.bin: spl/u-boot-spl.bin u-boot.itb FORCE $(Q)$(MAKE) $(build)=arch/arm/mach-imx $@
Skip running arch/arm/mach-imx flash.bin generation in case BINMAN is enabled, otherwise the target in arch/arm/mach-imx/Makefile regenerates the flash.bin again and produces corrupted result. Signed-off-by: Marek Vasut marex@denx.de Cc: Peng Fan peng.fan@oss.nxp.com Cc: Simon Glass sjg@chromium.org Reviewed-by: Simon Glass sjg@chromium.org
Best regards, Stefano Babic
sbabic@denx.de
