Re: [PATCH] net: fec: Get rid of FEC_ENET_ENABLE_[TR]XC_DELAY
On 1/23/21 8:54 PM, sbabic@denx.de wrote:
The FEC_ENET_ENABLE_.XC_DELAY setting is only used by one system which supports OF control, correctly set the rgmii-id PHY mode in the DT and then determine whether or not to enable the FEC RXC/TXC internal delay based on the PHY mode.
Didn't this fail to build on mx25 ?
Hi Marek,
Yes, sorry, this is a false positive - patch has not been applied.
Regards, Stefano
On Sun, Jan 24, 2021 at 12:04 AM Stefano Babic sbabic@denx.de wrote:
Hi Marek,
Anyway, as there will be another solution that won't break mx25/mx35, I should retest the new patch version on apalis, so I'm calling off my review so far.
Regards, Stefano
Hi Marek,
The only change required to that patch is an extra ifdef DM_ETH, so for mx8 apalis nothing changed, since you have DM_ETH enabled.
Hi Marek,
Hi Marek,
Thanks for clarifying! So you have my review for apalis mx8.
Oleksandr Suvorov
Stefano Babic
