[U-Boot] [PULL] u-boot-sh/master
The following changes since commit 32fe36574ea5e6ea55313e16547b98a984af7767:
Merge git://git.denx.de/u-boot-arc (2018-02-15 14:07:04 -0500)
git://git.denx.de/u-boot-sh.git master
for you to fetch changes up to 5b6ae550a8d88ca8c7b5c39642fe767729422edb:
ARM: rmobile: Enable autocompletion on Gen2 (2018-02-16 16:43:11 +0100)
---------------------------------------------------------------- Marek Vasut (9): clk: rmobile: Assure SD-IF clock are configured correctly net: ravb: Initialize PHY in probe() once ARM: rmobile: Enable DTO support on Gen3 ARM: rmobile: Enable autocompletion on Gen3 serial: Replace CONFIG_ with CONFIG_IS_ENABLED ARM: dts: rmobile: Make scif0 available before reloc on Porter ARM: dts: rmobile: Make PFC and RST available before reloc ARM: rmobile: Convert Porter to SPL ARM: rmobile: Enable autocompletion on Gen2
arch/arm/dts/r8a7791-porter.dts | 1 + arch/arm/dts/r8a779x-u-boot.dtsi | 8 ++++++++ arch/arm/mach-rmobile/Kconfig.32 | 2 ++ board/renesas/porter/porter.c | 22 ++++++++++++++++++++++ configs/porter_defconfig | 20 +++++++++++++++++++- configs/r8a7795_salvator-x_defconfig | 1 + configs/r8a7795_ulcb_defconfig | 1 + configs/r8a7796_salvator-x_defconfig | 1 + configs/r8a7796_ulcb_defconfig | 1 + configs/r8a77970_eagle_defconfig | 1 + configs/r8a77995_draak_defconfig | 1 + drivers/clk/renesas/clk-rcar-gen3.c | 2 ++ drivers/net/ravb.c | 32 +++++++++++++++++++------------- drivers/serial/serial_sh.c | 4 ++-- include/configs/porter.h | 15 +++++++++------ include/configs/rcar-gen2-common.h | 2 +- include/configs/rcar-gen3-common.h | 1 + 17 files changed, 92 insertions(+), 23 deletions(-)
