[PATCH 00/13] disentangling cyclic API from schedule()
These patches are part of a longer-term plan to properly deal with the HW_WATCHDOG vs WATCHDOG dichotomy, and getting rid of the legacy HW_WATCHDOG concept completely. As part of that, clean up which headers include other headers.
While schedule(), the artist formerly known as WATCHDOG_RESET(), is obviously called all over the tree, very few TUs make use of the cyclic API (cyclic_register etc.). And there's really no reason at all for global_data.h to include cyclic.h - except that some places implicitly rely on getting their declaration of schedule() through that include.
So this introduces a separate mostly trivial header that just serves to declare schedule(). Then we can get rid of things that include cyclic.h just to get that declaration.
A next, mostly mechanical step, could be to change almost all includes of watchdog.h (which most TUs that used to have a WATCHDOG_RESET() invocation has) to u-boot/schedule.h, because again, most of those TUs are not really concerned with implementing init_func_watchdog_init or need to call it. But that is for later.
CI seems happy: https://github.com/u-boot/u-boot/pull/673
Rasmus Villemoes (13): doc: cyclic: remove reference to WATCHDOG_RESET cyclic: introduce u-boot/schedule.h led: include cyclic.h in led_sw_blink.c m68k: asm/ptrace.h: include linux/types.h fs/cramfs: use schedule instead of cyclic_run as callback test: dm: wdt: replace cyclic_run() by schedule() cyclic: make cyclic_run static watchdog.h: change include of cyclic.h to u-boot/schedule.h lib/sha*: include u-boot/schedule.h instead of cyclic.h i2c: rzg2l: include u-boot/schedule.h ddr: altera: include u-boot/schedule.h boot: cedit: include u-boot/schedule.h global_data.h: remove unnecesary include of cyclic.h
arch/m68k/include/asm/ptrace.h | 2 ++ boot/cedit.c | 1 + common/cyclic.c | 3 ++- doc/develop/cyclic.rst | 10 +++++----- drivers/ddr/altera/sdram_n5x.c | 1 + drivers/ddr/altera/sdram_soc64.c | 1 + drivers/i2c/rz_riic.c | 1 + drivers/led/led_sw_blink.c | 1 + fs/cramfs/uncompress.c | 4 ++-- include/asm-generic/global_data.h | 1 - include/cyclic.h | 24 +----------------------- include/u-boot/schedule.h | 24 ++++++++++++++++++++++++ include/watchdog.h | 2 +- lib/sha1.c | 2 +- lib/sha256.c | 2 +- lib/sha512.c | 2 +- test/dm/wdt.c | 10 +++++----- 17 files changed, 50 insertions(+), 41 deletions(-) create mode 100644 include/u-boot/schedule.h
WATCHDOG_RESET is no more. Replace the reference by schedule().
While here, rearrange the sentence a bit so that "cyclic_run()" becomes the object and "the main function responsible for calling all registered cyclic functions" a parenthetical rather than the other way around, which at least to me makes it more readable.
Signed-off-by: Rasmus Villemoes ravi@prevas.dk --- doc/develop/cyclic.rst | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/doc/develop/cyclic.rst b/doc/develop/cyclic.rst index 893c269099a..6f1da6f0d9b 100644 --- a/doc/develop/cyclic.rst +++ b/doc/develop/cyclic.rst @@ -49,8 +49,8 @@ executed all 10ms. How is this cyclic functionality integrated / executed? --------------------------------------------------------
-The cyclic infrastructure integrates the main function responsible for -calling all registered cyclic functions cyclic_run() into the common -WATCHDOG_RESET macro. This guarantees that cyclic_run() is executed -very often, which is necessary for the cyclic functions to get scheduled -and executed at their configured periods. +The cyclic infrastructure integrates cyclic_run(), the main function +responsible for calling all registered cyclic functions, into the +common schedule() function. This guarantees that cyclic_run() is +executed very often, which is necessary for the cyclic functions to +get scheduled and executed at their configured periods.
2.46.2
Thanks, Stefan
Viele Grüße, Stefan Roese
I noticed an "unnecessary" include of <cyclic.h> in global_data.h, in the sense that nothing in cyclic.h is needed in order to define 'struct global_data'.
Well, it's not unnecessary, as it implicitly ensures that everybody gets a declaration of schedule(), and schedule() is (obviously) called all over the tree. Almost none of those places directly include <cyclic.h>, but for historical reasons, many do include <watchdog.h> (most schedule() instances are replacements of WATCHDOG_RESET()).
However, very few TUs actually need the declarations of the cyclic_register() and struct cyclic_info, and they also don't really need anything from the watchdog.h header.
So introduce a new header which just contains a declaration of schedule(), which can then be included from all the places that do call schedule(). I removed the direct reference to cyclic_run(), because we shouldn't have two public functions for doing roughly the same without being very explicit about when one should call one or the other.
Testing of later patches that explicitly include <schedule.h> when schedule() is used revealed a problem with host tool build on win32, which apparently picked up a host <schedule.h>. To avoid that problem, put the new header in include/u-boot/ and hence make the include statements say <u-boot/schedule.h>.
Signed-off-by: Rasmus Villemoes ravi@prevas.dk --- common/cyclic.c | 1 + include/cyclic.h | 12 +----------- include/u-boot/schedule.h | 24 ++++++++++++++++++++++++ 3 files changed, 26 insertions(+), 11 deletions(-) create mode 100644 include/u-boot/schedule.h
diff --git a/common/cyclic.c b/common/cyclic.c index ec38fad6775..38d815bec35 100644 --- a/common/cyclic.c +++ b/common/cyclic.c @@ -15,6 +15,7 @@ #include <linux/errno.h> #include <linux/list.h> #include <asm/global_data.h> +#include <u-boot/schedule.h>
DECLARE_GLOBAL_DATA_PTR;
diff --git a/include/cyclic.h b/include/cyclic.h index cd95b691d48..e8de616dcd5 100644 --- a/include/cyclic.h +++ b/include/cyclic.h @@ -13,6 +13,7 @@
#include <linux/list.h> #include <asm/types.h> +#include <u-boot/schedule.h> // to be removed later
/** * struct cyclic_info - Information about cyclic execution function @@ -94,13 +95,6 @@ struct hlist_head *cyclic_get_list(void); */ void cyclic_run(void);
-/** - * schedule() - Schedule all potentially waiting tasks - * - * Basically a wrapper for cyclic_run(), pontentially enhanced by some - * other parts, that need to get handled periodically. - */ -void schedule(void); #else
static inline void cyclic_register(struct cyclic_info *cyclic, cyclic_func_t func, @@ -116,10 +110,6 @@ static inline void cyclic_run(void) { }
-static inline void schedule(void) -{ -} - static inline int cyclic_unregister_all(void) { return 0; diff --git a/include/u-boot/schedule.h b/include/u-boot/schedule.h new file mode 100644 index 00000000000..4fd34c41229 --- /dev/null +++ b/include/u-boot/schedule.h @@ -0,0 +1,24 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ + +#ifndef _U_BOOT_SCHEDULE_H +#define _U_BOOT_SCHEDULE_H + +#if CONFIG_IS_ENABLED(CYCLIC) +/** + * schedule() - Schedule all potentially waiting tasks + * + * Run all pending tasks registered via the cyclic framework, and + * potentially perform other actions that need to be done + * periodically. + */ +void schedule(void); + +#else + +static inline void schedule(void) +{ +} + +#endif + +#endif
But could it just be include/schedule.h ?
Simon Glass sjg@chromium.org writes:
I think the last paragraph in the commit message should answer that:
So I tried that at first, and it worked fine for all my local builds, but the CI told me it couldn't. I can try to find the old github PR where I got the CI to tell me this (it's months ago I started doing this), but I don't know if the azure logs still exist.
Rasmus
Hi Rasmus,
Ah yes, thanks.
Thanks, Stefan
- struct cyclic_info - Information about cyclic execution function
- schedule() - Schedule all potentially waiting tasks
- Basically a wrapper for cyclic_run(), pontentially enhanced by some
- other parts, that need to get handled periodically.
- Run all pending tasks registered via the cyclic framework, and
- potentially perform other actions that need to be done
- periodically.
+#else
This makes use of the cyclic API but relies on implicitly getting the appropriate declarations through some nested include. Include the cyclic.h header directly.
Signed-off-by: Rasmus Villemoes ravi@prevas.dk --- drivers/led/led_sw_blink.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/led/led_sw_blink.c b/drivers/led/led_sw_blink.c index 9e36edbee47..6976b84544e 100644 --- a/drivers/led/led_sw_blink.c +++ b/drivers/led/led_sw_blink.c @@ -5,6 +5,7 @@ * Author: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu */
+#include <cyclic.h> #include <dm.h> #include <led.h> #include <time.h>
- Author: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu
#include <time.h>
2.46.2
Thanks, Stefan
Modifying a generic header like watchdog.h, removing not directly used #includes, can apparently break the build of m68k, because the asm/ptrace.h header relies on whoever includes it to already have included something that defines the type ulong.
Make the asm/ptrace.h header self-contained by including the proper header.
Signed-off-by: Rasmus Villemoes ravi@prevas.dk --- arch/m68k/include/asm/ptrace.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/m68k/include/asm/ptrace.h b/arch/m68k/include/asm/ptrace.h index d419824806c..5decf73a1d1 100644 --- a/arch/m68k/include/asm/ptrace.h +++ b/arch/m68k/include/asm/ptrace.h @@ -9,6 +9,8 @@ */ #ifndef __ASSEMBLY__
+#include <linux/types.h> + struct pt_regs { ulong d0; ulong d1;
Thanks, Stefan
- struct pt_regs { ulong d0; ulong d1;
Prior to commit 29caf9305b6f ("cyclic: Use schedule() instead of WATCHDOG_RESET()") we had
/* Currently only needed for fs/cramfs/uncompress.c */ static inline void watchdog_reset_func(void) { WATCHDOG_RESET(); }
and .outcb was set to that watchdog_reset_func(). Said commit changed that .outcb to cyclic_run instead of schedule, which would otherwise match all the other WATCHDOG_RESET replacements done. As the HW_WATCHDOG case is not handled by cyclic_run, this seems to be an oversight.
Signed-off-by: Rasmus Villemoes ravi@prevas.dk --- fs/cramfs/uncompress.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/fs/cramfs/uncompress.c b/fs/cramfs/uncompress.c index 2141edf22e4..97af8cb2b4f 100644 --- a/fs/cramfs/uncompress.c +++ b/fs/cramfs/uncompress.c @@ -21,9 +21,9 @@ */
#include <stdio.h> -#include <cyclic.h> #include <malloc.h> #include <watchdog.h> +#include <u-boot/schedule.h> #include <u-boot/zlib.h>
static z_stream stream; @@ -63,7 +63,7 @@ int cramfs_uncompress_init (void) stream.avail_in = 0;
#if defined(CONFIG_HW_WATCHDOG) || defined(CONFIG_WATCHDOG) - stream.outcb = (cb_func)cyclic_run; + stream.outcb = (cb_func)schedule; #else stream.outcb = Z_NULL; #endif /* CONFIG_HW_WATCHDOG */
2.46.2
Thanks, Stefan
- stream.outcb = (cb_func)schedule; #else stream.outcb = Z_NULL; #endif /* CONFIG_HW_WATCHDOG */
This is the last place outside of cyclic.c that references cyclic_run() directly. Replace by schedule(), so that cyclic_run() can be made private. This also better matches what I believe commit 29caf9305b6f ("cyclic: Use schedule() instead of WATCHDOG_RESET()") intended to do.
Signed-off-by: Rasmus Villemoes ravi@prevas.dk --- test/dm/wdt.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/test/dm/wdt.c b/test/dm/wdt.c index 1df2da23c6c..4d751b7e8cf 100644 --- a/test/dm/wdt.c +++ b/test/dm/wdt.c @@ -3,7 +3,6 @@ * Copyright 2017 Google, Inc */
-#include <cyclic.h> #include <dm.h> #include <time.h> #include <wdt.h> @@ -14,6 +13,7 @@ #include <test/test.h> #include <test/ut.h> #include <linux/delay.h> +#include <u-boot/schedule.h> #include <watchdog.h>
/* Test that watchdog driver functions are called */ @@ -131,7 +131,7 @@ static int dm_test_wdt_watchdog_reset(struct unit_test_state *uts) /* Neither device should be "started", so watchdog_reset() should be a no-op. */ reset_count = state->wdt.reset_count; val = sandbox_gpio_get_value(gpio, offset); - cyclic_run(); + schedule(); ut_asserteq(reset_count, state->wdt.reset_count); ut_asserteq(val, sandbox_gpio_get_value(gpio, offset));
@@ -141,19 +141,19 @@ static int dm_test_wdt_watchdog_reset(struct unit_test_state *uts)
/* Make sure both devices have just been pinged. */ timer_test_add_offset(100); - cyclic_run(); + schedule(); reset_count = state->wdt.reset_count; val = sandbox_gpio_get_value(gpio, offset);
/* The gpio watchdog should be pinged, the sandbox one not. */ timer_test_add_offset(30); - cyclic_run(); + schedule(); ut_asserteq(reset_count, state->wdt.reset_count); ut_asserteq(!val, sandbox_gpio_get_value(gpio, offset));
/* After another ~30ms, both devices should get pinged. */ timer_test_add_offset(30); - cyclic_run(); + schedule(); ut_asserteq(reset_count + 1, state->wdt.reset_count); ut_asserteq(val, sandbox_gpio_get_value(gpio, offset));
Thanks, Stefan
- Copyright 2017 Google, Inc
- cyclic_run();
- schedule(); ut_asserteq(reset_count, state->wdt.reset_count); ut_asserteq(val, sandbox_gpio_get_value(gpio, offset));
- cyclic_run();
- cyclic_run();
- cyclic_run();
- schedule(); ut_asserteq(reset_count + 1, state->wdt.reset_count); ut_asserteq(val, sandbox_gpio_get_value(gpio, offset));
The only caller left is schedule(); everybody outside cyclic.c now calls or references schedule().
Signed-off-by: Rasmus Villemoes ravi@prevas.dk --- common/cyclic.c | 2 +- include/cyclic.h | 12 ------------ 2 files changed, 1 insertion(+), 13 deletions(-)
diff --git a/common/cyclic.c b/common/cyclic.c index 38d815bec35..196797fd61e 100644 --- a/common/cyclic.c +++ b/common/cyclic.c @@ -45,7 +45,7 @@ void cyclic_unregister(struct cyclic_info *cyclic) hlist_del(&cyclic->list); }
-void cyclic_run(void) +static void cyclic_run(void) { struct cyclic_info *cyclic; struct hlist_node *tmp; diff --git a/include/cyclic.h b/include/cyclic.h index e8de616dcd5..c6c463d68e9 100644 --- a/include/cyclic.h +++ b/include/cyclic.h @@ -87,14 +87,6 @@ int cyclic_unregister_all(void); */ struct hlist_head *cyclic_get_list(void);
-/** - * cyclic_run() - Interate over all registered cyclic functions - * - * Interate over all registered cyclic functions and if the it's function - * needs to be executed, then call into these registered functions. - */ -void cyclic_run(void); - #else
static inline void cyclic_register(struct cyclic_info *cyclic, cyclic_func_t func, @@ -106,10 +98,6 @@ static inline void cyclic_unregister(struct cyclic_info *cyclic) { }
-static inline void cyclic_run(void) -{ -} - static inline int cyclic_unregister_all(void) { return 0;
Thanks, Stefan
- cyclic_run() - Interate over all registered cyclic functions
- Interate over all registered cyclic functions and if the it's function
- needs to be executed, then call into these registered functions.
#else
Nobody relies on getting the cyclic API declared by including the watchdog.h header, but for historical reasons, many TUs include watchdog.h to get a declaration of schedule(). Now that we have a dedicated header for just that, include that header instead of cyclic.h.
Eventually, all TUs that call schedule() should themselves include u-boot/schedule.h, but this is a step towards getting rid of unnecessary include statements in cyclic.h and global_data.h.
Signed-off-by: Rasmus Villemoes ravi@prevas.dk --- include/watchdog.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/watchdog.h b/include/watchdog.h index d1956fafca1..0149b44d077 100644 --- a/include/watchdog.h +++ b/include/watchdog.h @@ -10,7 +10,7 @@ #ifndef _WATCHDOG_H_ #define _WATCHDOG_H_
-#include <cyclic.h> +#include <u-boot/schedule.h> // to be removed later
/* * Reset the watchdog timer, always returns 0
Thanks, Stefan
- Reset the watchdog timer, always returns 0
These library routines obviously do not make use of the cyclic_register() etc. API, but do need to call schedule(). Include the proper header.
Eventually, their ifdef logic should be updated to avoid talking about CONFIG_WATCHDOG.
Signed-off-by: Rasmus Villemoes ravi@prevas.dk --- lib/sha1.c | 2 +- lib/sha256.c | 2 +- lib/sha512.c | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/lib/sha1.c b/lib/sha1.c index 7ef536f4b5d..233bd9145c6 100644 --- a/lib/sha1.c +++ b/lib/sha1.c @@ -17,7 +17,7 @@ #endif
#ifndef USE_HOSTCC -#include <cyclic.h> +#include <u-boot/schedule.h> #endif /* USE_HOSTCC */ #include <string.h> #include <u-boot/sha1.h> diff --git a/lib/sha256.c b/lib/sha256.c index 665ba6f152e..329802fd827 100644 --- a/lib/sha256.c +++ b/lib/sha256.c @@ -6,7 +6,7 @@ */
#ifndef USE_HOSTCC -#include <cyclic.h> +#include <u-boot/schedule.h> #endif /* USE_HOSTCC */ #include <string.h> #include <u-boot/sha256.h> diff --git a/lib/sha512.c b/lib/sha512.c index ffe2c5cd964..ea555ff33eb 100644 --- a/lib/sha512.c +++ b/lib/sha512.c @@ -11,7 +11,7 @@ */
#ifndef USE_HOSTCC -#include <cyclic.h> +#include <u-boot/schedule.h> #endif /* USE_HOSTCC */ #include <compiler.h> #include <u-boot/sha512.h>
Thanks, Stefan
This TU currently relies on getting a declaration of schedule() through some nested include. Include the proper header directly.
Signed-off-by: Rasmus Villemoes ravi@prevas.dk --- drivers/i2c/rz_riic.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/i2c/rz_riic.c b/drivers/i2c/rz_riic.c index 5f3f8d1b24b..f292c824362 100644 --- a/drivers/i2c/rz_riic.c +++ b/drivers/i2c/rz_riic.c @@ -14,6 +14,7 @@ #include <linux/bitops.h> #include <linux/delay.h> #include <reset.h> +#include <u-boot/schedule.h> #include <wait_bit.h>
#define RIIC_ICCR1 0x00
dodgy header-order here, although it predates this patch.
2.46.2
Thanks, Stefan
These TUs currently rely on getting a declaration of schedule() through some nested include. Include the proper header directly.
Signed-off-by: Rasmus Villemoes ravi@prevas.dk --- drivers/ddr/altera/sdram_n5x.c | 1 + drivers/ddr/altera/sdram_soc64.c | 1 + 2 files changed, 2 insertions(+)
diff --git a/drivers/ddr/altera/sdram_n5x.c b/drivers/ddr/altera/sdram_n5x.c index db09986f64b..d1fc93b6bdd 100644 --- a/drivers/ddr/altera/sdram_n5x.c +++ b/drivers/ddr/altera/sdram_n5x.c @@ -22,6 +22,7 @@ #include <asm/io.h> #include <linux/err.h> #include <linux/sizes.h> +#include <u-boot/schedule.h>
diff --git a/drivers/ddr/altera/sdram_soc64.c b/drivers/ddr/altera/sdram_soc64.c index 9e57c2ecfa4..10a8e64af3d 100644 --- a/drivers/ddr/altera/sdram_soc64.c +++ b/drivers/ddr/altera/sdram_soc64.c @@ -24,6 +24,7 @@ #include <asm/io.h> #include <dm/device_compat.h> #include <linux/sizes.h> +#include <u-boot/schedule.h>
#define PGTABLE_OFF 0x4000
-- 2.46.2
Thanks, Stefan
Signed-off-by: Rasmus Villemoes ravi@prevas.dk --- boot/cedit.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/boot/cedit.c b/boot/cedit.c index c29a2be14ce..ff0efda3a7b 100644 --- a/boot/cedit.c +++ b/boot/cedit.c @@ -20,6 +20,7 @@ #include <video.h> #include <linux/delay.h> #include "scene_internal.h" +#include <u-boot/schedule.h>
enum { CMOS_MAX_BITS = 2048,
enum { CMOS_MAX_BITS = 2048, -- 2.46.2
Thanks, Stefan
Nothing in cyclic.h is needed to define struct global_data, so do not include that header.
If any .c file relies on getting cyclic.h through asm/global_data.h, it needs to include it itself.
Signed-off-by: Rasmus Villemoes ravi@prevas.dk --- include/asm-generic/global_data.h | 1 - 1 file changed, 1 deletion(-)
diff --git a/include/asm-generic/global_data.h b/include/asm-generic/global_data.h index 27aa75e7036..1570ad8f0c0 100644 --- a/include/asm-generic/global_data.h +++ b/include/asm-generic/global_data.h @@ -20,7 +20,6 @@ */
#ifndef __ASSEMBLY__ -#include <cyclic.h> #include <event_internal.h> #include <fdtdec.h> #include <membuff.h>
Thanks, Stefan
Hi Rasmus,
Thanks for this work - really appreciated. I'm leaving for vacation pretty soon. Will take a closer look at these patches in roughly 2 weeks.
Thanks, Stefan
Applied to u-boot-watchdog/master
Thanks, Stefan
Rasmus Villemoes
Stefan Roese
