[U-Boot] Failure to compile sa1100 boards
Greetings,
Trying to make the hp jornada 700 flashboard u-boot friendly. Anyhow, the compilation goes well until the last step where it spits out an :
arm-linux-ld:/home/kristoffer/work/projects/u-boot.git/cpu/sa1100/u-boot.lds:42: parse error make: *** [u-boot] Fel 1 (= error 1)
This is currently the same for all sa1100 boards im trying. So is it my toolchain or a real fault?
My versions are u-boot (latest from git) gcc : 3.4.5 glibc : 2.3.5
Best wishes Kristoffer Ericson
error log: UNDEF_SYM=`arm-linux-objdump -x board/assabet/libassabet.a lib_generic/libgeneri c.a lib_generic/lzma/liblzma.a lib_generic/lzo/liblzo.a cpu/sa1100/libsa1100.a l ib_arm/libarm.a fs/cramfs/libcramfs.a fs/fat/libfat.a fs/fdos/libfdos.a fs/jffs2 /libjffs2.a fs/reiserfs/libreiserfs.a fs/ext2/libext2fs.a fs/yaffs2/libyaffs2.a fs/ubifs/libubifs.a net/libnet.a disk/libdisk.a drivers/bios_emulator/libatibios emu.a drivers/block/libblock.a drivers/dma/libdma.a drivers/fpga/libfpga.a drive rs/gpio/libgpio.a drivers/hwmon/libhwmon.a drivers/i2c/libi2c.a drivers/input/li binput.a drivers/misc/libmisc.a drivers/mmc/libmmc.a drivers/mtd/libmtd.a driver s/mtd/nand/libnand.a drivers/mtd/nand_legacy/libnand_legacy.a drivers/mtd/onenan d/libonenand.a drivers/mtd/ubi/libubi.a drivers/mtd/spi/libspi_flash.a drivers/n et/libnet.a drivers/net/phy/libphy.a drivers/net/sk98lin/libsk98lin.a drivers/pc i/libpci.a drivers/pcmcia/libpcmcia.a drivers/spi/libspi.a drivers/rtc/librtc.a drivers/serial/libserial.a drivers/twserial/libtws.a drivers/usb/gadget/libusb_g adget.a drivers/usb/host/libusb_host.a drivers/usb/musb/libusb_musb.a drivers/vi deo/libvideo.a drivers/watchdog/libwatchdog.a common/libcommon.a libfdt/libfdt.a api/libapi.a post/libpost.a | sed -n -e 's/.*(__u_boot_cmd_.*)/-u\1/p'|sort| uniq`; cd /home/kristoffer/work/projects/u-boot.git && arm-linux-ld -Bstatic -T /home/kristoffer/work/projects/u-boot.git/cpu/sa1100/u-boot.lds -Ttext 0xc1f000 00 $UNDEF_SYM cpu/sa1100/start.o --start-group lib_generic/libgeneric.a lib_gene ric/lzma/liblzma.a lib_generic/lzo/liblzo.a cpu/sa1100/libsa1100.a lib_arm/libar m.a fs/cramfs/libcramfs.a fs/fat/libfat.a fs/fdos/libfdos.a fs/jffs2/libjffs2.a fs/reiserfs/libreiserfs.a fs/ext2/libext2fs.a fs/yaffs2/libyaffs2.a fs/ubifs/lib ubifs.a net/libnet.a disk/libdisk.a drivers/bios_emulator/libatibiosemu.a driver s/block/libblock.a drivers/dma/libdma.a drivers/fpga/libfpga.a drivers/gpio/libg pio.a drivers/hwmon/libhwmon.a drivers/i2c/libi2c.a drivers/input/libinput.a dri vers/misc/libmisc.a drivers/mmc/libmmc.a drivers/mtd/libmtd.a drivers/mtd/nand/l ibnand.a drivers/mtd/nand_legacy/libnand_legacy.a drivers/mtd/onenand/libonenand .a drivers/mtd/ubi/libubi.a drivers/mtd/spi/libspi_flash.a drivers/net/libnet.a drivers/net/phy/libphy.a drivers/net/sk98lin/libsk98lin.a drivers/pci/libpci.a d rivers/pcmcia/libpcmcia.a drivers/spi/libspi.a drivers/rtc/librtc.a drivers/seri al/libserial.a drivers/twserial/libtws.a drivers/usb/gadget/libusb_gadget.a driv ers/usb/host/libusb_host.a drivers/usb/musb/libusb_musb.a drivers/video/libvideo .a drivers/watchdog/libwatchdog.a common/libcommon.a libfdt/libfdt.a api/libapi. a post/libpost.a board/assabet/libassabet.a --end-group -L /opt/crosstool/gcc-3. 4.5-glibc-2.3.5/arm-unknown-linux-gnu/lib/gcc/arm-unknown-linux-gnu/3.4.5 -lgcc -Map u-boot.map -o u-boot arm-linux-ld:/home/kristoffer/work/projects/u-boot.git/cpu/sa1100/u-boot.lds:42: parse error make: *** [u-boot] Fel 1 [kristoffer@boggieman u-boot.git]$
On 22:11 Wed 17 Jun , Kristoffer Ericson wrote:
Greetings,
it's quite old I'll recommand you to use a more recent toolchain gcc 4.3.x as example
Best Regards, J.
Jean-Christophe PLAGNIOL-VILLARD
Kristoffer Ericson
