[U-Boot] [PATCH] fsl_esdhc: fix warning if CONFIG_DM_REGULATOR is not set
Warning appears when i.MX6 (icore) boards are built.
Signed-off-by: Stefano Babic sbabic@denx.de --- drivers/mmc/fsl_esdhc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mmc/fsl_esdhc.c b/drivers/mmc/fsl_esdhc.c index 3abd2d3..b98da69 100644 --- a/drivers/mmc/fsl_esdhc.c +++ b/drivers/mmc/fsl_esdhc.c @@ -968,7 +968,6 @@ static int fsl_esdhc_probe(struct udevice *dev) struct fsl_esdhc_priv *priv = dev_get_priv(dev); const void *fdt = gd->fdt_blob; int node = dev_of_offset(dev); - struct udevice *vqmmc_dev; fdt_addr_t addr; unsigned int val; int ret; @@ -1014,6 +1013,7 @@ static int fsl_esdhc_probe(struct udevice *dev) * If emmc I/O has a fixed voltage at 1.8V, this must be provided, * otherwise, emmc will work abnormally. */ + struct udevice *vqmmc_dev; ret = device_get_supply_regulator(dev, "vqmmc-supply", &vqmmc_dev); if (ret) { dev_dbg(dev, "no vqmmc-supply\n");
Hi Stefano.
ommit 9bb272e90acf7182311dc524df69b125eac92a53 Author: York Sun york.sun@nxp.com Date: Tue Aug 8 15:45:13 2017 -0700
driver: mmc: fsl_esdhc: Fix compiling warning
Commit 4483b7eb added variable vqmmc_dev but only uses it under CONFIG_DM_REGULATOR. Add the same macro to variable declaration to get rid of compiling warning.
Signed-off-by: York Sun york.sun@nxp.com
It seems that already fixed this issue.
Best Regards, Jaehoon Chung
- struct udevice *vqmmc_dev; ret = device_get_supply_regulator(dev, "vqmmc-supply", &vqmmc_dev); if (ret) { dev_dbg(dev, "no vqmmc-supply\n");
Jaehoon Chung
Stefano Babic
