[U-Boot] [PATCH] armv8/fsl-lsch2: fix sdhc clock frequency value
The eSDHC could select to use platform clock or peripheral clock to generate SD clock. The default selection is platform clock. So, fix the clock frequency value that's calculated for eSDHC.
Signed-off-by: Yangbo Lu yangbo.lu@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c index 6f6a588..453a93d 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fsl_lsch2_speed.c @@ -106,9 +106,13 @@ void get_sys_info(struct sys_info *sys_info) #define HWA_CGA_M2_CLK_SEL 0x00000007 #define HWA_CGA_M2_CLK_SHIFT 0 #ifdef CONFIG_FSL_ESDHC +#ifdef CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK rcw_tmp = in_be32(&gur->rcwsr[15]); rcw_tmp = (rcw_tmp & HWA_CGA_M2_CLK_SEL) >> HWA_CGA_M2_CLK_SHIFT; sys_info->freq_sdhc = freq_c_pll[1] / rcw_tmp; +#else + sys_info->freq_sdhc = sys_info->freq_systembus; +#endif #endif
#if defined(CONFIG_FSL_IFC)
- sys_info->freq_sdhc = sys_info->freq_systembus;
+#endif #endif
Yango,
The change looks OK. But you didn't define CONFIG_FSL_ESDHC_USE_PERIPHERAL_CLK anywhere. Do you have another patch using this macro? So far, this macro is only used for T1040QDS and T208xQDS.
York
-----Original Message----- From: york sun Sent: Tuesday, March 08, 2016 3:07 AM To: Yangbo Lu; u-boot@lists.denx.de Subject: Re: [PATCH] armv8/fsl-lsch2: fix sdhc clock frequency value
- sys_info->freq_sdhc = sys_info->freq_systembus; #endif
#endif
Yango,
York
[Lu Yangbo-B47093] Hi York. You are right. Although we don't use this macro presently, we will use it to support SD UHS mode in the future. Now we could treat it as a bug fix.
Thanks.
Applied to u-boot-fsl-qoriq, awaiting upstream.
Thanks.
York
Yangbo Lu
york sun
