[U-Boot] ca9x4_ct_vxp build failure
Dear Matt Waddel,
ca9x4_ct_vxp does not build with ELDK4.2 . Can you please come up with a patch?
Thanks in advance!
Copyright (C) 2007 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Configuring for ca9x4_ct_vxp board... cmd_pxe.c: In function 'do_pxe_get': cmd_pxe.c:334: warning: dereferencing type-punned pointer will break strict- aliasing rules cmd_pxe.c: In function 'get_relfile_envaddr': cmd_pxe.c:374: warning: dereferencing type-punned pointer will break strict- aliasing rules common/libcommon.o: In function `cread_line': /opt/work/jenkins/jobs/U- Boot/workspace/workspace/compiler/eldk4.2/device/arm___ca9x4_ct_vxp/common/main.c:717: undefined reference to `get_ticks' /opt/work/jenkins/jobs/U- Boot/workspace/workspace/compiler/eldk4.2/device/arm___ca9x4_ct_vxp/common/main.c:717: undefined reference to `get_tbclk' /opt/work/jenkins/jobs/U- Boot/workspace/workspace/compiler/eldk4.2/device/arm___ca9x4_ct_vxp/common/main.c:720: undefined reference to `get_ticks' arm-linux-ld: BFD (GNU Binutils) 2.17.90.20070806 assertion fail /opt/eldk/build/arm-2008-11-24/work/usr/src/denx/BUILD/crosstool-0.43/build/gcc-4.2.2- glibc-20070515T2025-eldk/arm-linux-gnueabi/binutils-2.17.90/bfd/elf32-arm.c:8886 arm-linux-ld: BFD (GNU Binutils) 2.17.90.20070806 assertion fail /opt/eldk/build/arm-2008-11-24/work/usr/src/denx/BUILD/crosstool-0.43/build/gcc-4.2.2- glibc-20070515T2025-eldk/arm-linux-gnueabi/binutils-2.17.90/bfd/elf32-arm.c:8886 arm-linux-ld: BFD (GNU Binutils) 2.17.90.20070806 assertion fail /opt/eldk/build/arm-2008-11-24/work/usr/src/denx/BUILD/crosstool-0.43/build/gcc-4.2.2- glibc-20070515T2025-eldk/arm-linux-gnueabi/binutils-2.17.90/bfd/elf32-arm.c:9117 /bin/sh: line 1: 21550 Segmentation fault (core dumped) arm-linux-ld -pie - T u-boot.lds -Bstatic -Ttext 0x60800000 $UNDEF_SYM arch/arm/cpu/armv7/start.o -- start-group api/libapi.o arch/arm/cpu/armv7/libarmv7.o arch/arm/lib/libarm.o common/libcommon.o disk/libdisk.o drivers/bios_emulator/libatibiosemu.o drivers/block/libblock.o drivers/dma/libdma.o drivers/fpga/libfpga.o drivers/gpio/libgpio.o drivers/hwmon/libhwmon.o drivers/i2c/libi2c.o drivers/input/libinput.o drivers/misc/libmisc.o drivers/mmc/libmmc.o drivers/mtd/libmtd.o drivers/mtd/nand/libnand.o drivers/mtd/onenand/libonenand.o drivers/mtd/spi/libspi_flash.o drivers/mtd/ubi/libubi.o drivers/net/libnet.o drivers/net/phy/libphy.o drivers/pci/libpci.o drivers/pcmcia/libpcmcia.o drivers/power/libpower.o drivers/rtc/librtc.o drivers/serial/libserial.o drivers/spi/libspi.o drivers/twserial/libtws.o drivers/usb/eth/libusb_eth.o drivers/usb/gadget/libusb_gadget.o drivers/usb/host/libusb_host.o drivers/usb/musb/libusb_musb.o drivers/usb/phy/libusb_phy.o drivers/usb/ulpi/libusb_ulpi.o drivers/video/libvideo.o drivers/watchdog/libwatchdog.o fs/cramfs/libcramfs.o fs/ext2/libext2fs.o fs/fat/libfat.o fs/fdos/libfdos.o fs/jffs2/libjffs2.o fs/reiserfs/libreiserfs.o fs/ubifs/libubifs.o fs/yaffs2/libyaffs2.o lib/libfdt/libfdt.o lib/libgeneric.o lib/lzma/liblzma.o lib/lzo/liblzo.o lib/zlib/libz.o net/libnet.o post/libpost.o board/armltd/vexpress/libvexpress.o --end-group /opt/work/jenkins/jobs/U- Boot/workspace/workspace/compiler/eldk4.2/device/arm___ca9x4_ct_vxp/arch/arm/lib/eabi_compat.o -L /opt/eldk-4.2-2008-11-24/usr/bin/../lib/gcc/arm-linux-gnueabi/4.2.2/soft- float -lgcc -Map u-boot.map -o u-boot make: *** [u-boot] Error 139 arm-linux-size: ./u-boot: File format not recognized
--------------------- SUMMARY ---------------------------- Boards compiled: 1 Boards with warnings or errors: 1 ( ca9x4_ct_vxp ) ----------------------------------------------------------
Best regards, Marek Vasut
Added get_ticks() and get_tbclk() routines
Signed-off-by: Matt Waddel matt.waddel@linaro.org --- board/armltd/vexpress/ca9x4_ct_vxp.c | 10 ++++++++++ 1 files changed, 10 insertions(+), 0 deletions(-)
diff --git a/board/armltd/vexpress/ca9x4_ct_vxp.c b/board/armltd/vexpress/ca9x4_ct_vxp.c index da6f14d..22e5af1 100644 --- a/board/armltd/vexpress/ca9x4_ct_vxp.c +++ b/board/armltd/vexpress/ca9x4_ct_vxp.c @@ -226,3 +226,13 @@ void lowlevel_init(void) ulong get_board_rev(void){ return readl((u32 *)SYS_ID); } + +unsigned long long get_ticks(void) +{ + return get_timer(0); +} + +ulong get_tbclk(void) +{ + return (ulong)CONFIG_SYS_HZ; +}
Hi Matt waddel,
I have posted the fix before: http://patchwork.ozlabs.org/patch/142477/
Liming Wang
- return get_timer(0);
- return (ulong)CONFIG_SYS_HZ;
1.7.5.4
walimis
