[U-Boot] [PATCH] arm64: spin-table: add more information in Kconfig help
This feature seems to be sometimes misunderstood. The intention is
[1] Bring the slaves into U-Boot proper image, not SPL (unless you have a special reason).
[2] The operation must be done in a board (SoC) specific manner since how to wake the slaves from the Boot ROM is SoC specific.
[3] The slaves must enter U-Boot proper after U-Boot relocates itself because the "cpu-release-addr" property points to the relocated memory area.
[2] is already explained in the help. We can make [1] even clearer by mentioning "U-Boot proper" instead of "U-Boot". [3] is missing, so I am adding it to the list.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/cpu/armv8/Kconfig | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index 22dce88..7388eca 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -12,8 +12,11 @@ config ARMV8_SPIN_TABLE To use this feature, you must do: - Specify enable-method = "spin-table" in each CPU node in the Device Tree you are using to boot the kernel - - Let secondary CPUs in U-Boot (in a board specific manner) - before the master CPU jumps to the kernel + - Bring secondary CPUs into U-Boot proper (in a board specific + manner) before the master CPU jumps to the kernel, but *after* + relocation. Otherwise, the master CPU will see a different copy + of the spin code, then the secondary CPUs will spin in the + unprotected memory area.
U-Boot automatically does: - Set "cpu-release-addr" property of each CPU node
On Thu, Jan 19, 2017 at 2:07 PM, Masahiro Yamada yamada.masahiro@socionext.com wrote:
unprotected memory area. U-Boot automatically does: - Set "cpu-release-addr" property of each CPU node
-- 2.7.4
This patch is: Reviewed-by: Oded Gabbay oded.gabbay@gmail.com
Masahiro Yamada
Oded Gabbay
