[U-Boot] [PATCH v2] arm, am33xx: update for siemens am335x based boards
updates for the siemens am335x based boards:
- draco: add delay for DDR3 configuration - change MTD partition layout and add a possibility to redefine MTD layout in board header. - move ubi support to common header file - draco: improve dtb naming - draco: set CONFIG_SYS_CBSIZE to 1024 - add generic env based led Leds can now be defined in Environment - add generic env based dfu button Which gpio is used for the dfu button can be defined through the Environment - set MACH_TYPE only if defined - draco: increase CPU freq to 300MHz - Add time command to siemens am33xx boards - DDR3: increase default tRFC - draco: enable pullup for DFU and ERST pin - change print format DDR3
Signed-off-by: Samuel Egli samuel.egli@siemens.com Acked-by: Heiko Schocher hs@denx.de Reviewed-by: Tom Rini trini@konsulko.com
Signed-off-by: Heiko Schocher hs@denx.de ---
Changes in v2: - add Reviewed-by from Tom Rini - add comment from Samuel Egli: increase delay in DDR3 init
board/siemens/common/board.c | 176 +++++++++++++++------ board/siemens/draco/board.c | 43 +++-- board/siemens/draco/board.h | 13 +- board/siemens/draco/mux.c | 4 +- include/configs/draco.h | 28 +++- include/configs/dxr2.h | 23 ++- include/configs/pxm2.h | 23 ++- include/configs/rut.h | 16 +- include/configs/siemens-am33x-common.h | 280 +++++++++++++++++++++++---------- 9 files changed, 428 insertions(+), 178 deletions(-)
diff --git a/board/siemens/common/board.c b/board/siemens/common/board.c index fb2de48..c127f6c 100644 --- a/board/siemens/common/board.c +++ b/board/siemens/common/board.c @@ -75,8 +75,9 @@ int board_init(void) i2c_set_bus_num(0); if (read_eeprom() < 0) puts("Could not get board ID.\n"); - +#ifdef CONFIG_MACH_TYPE gd->bd->bi_arch_number = CONFIG_MACH_TYPE; +#endif gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100;
#ifdef CONFIG_FACTORYSET @@ -102,21 +103,29 @@ const struct dpll_params *get_dpll_ddr_params(void) }
#ifndef CONFIG_SPL_BUILD + +#define MAX_NR_LEDS 10 +#define MAX_PIN_NUMBER 128 +#define STARTUP 0 + #if defined(BOARD_DFU_BUTTON_GPIO) -/* - * This command returns the status of the user button on - * Input - none - * Returns - 1 if button is held down - * 0 if button is not held down - */ -static int -do_userbutton(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +unsigned char get_button_state(char * const envname, unsigned char def) { int button = 0; int gpio; + char *ptr_env;
- gpio = BOARD_DFU_BUTTON_GPIO; - gpio_request(gpio, "DFU"); + /* If button is not found we take default */ + ptr_env = getenv(envname); + if (NULL == ptr_env) { + gpio = def; + } else { + gpio = (unsigned char)simple_strtoul(ptr_env, NULL, 0); + if (gpio > MAX_PIN_NUMBER) + gpio = def; + } + + gpio_request(gpio, ""); gpio_direction_input(gpio); if (gpio_get_value(gpio)) button = 1; @@ -127,53 +136,27 @@ do_userbutton(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
return button; } - -U_BOOT_CMD( - dfubutton, CONFIG_SYS_MAXARGS, 1, do_userbutton, - "Return the status of the DFU button", - "" -); -#endif -/* - * This command sets led - * Input - name of led - * value of led - * Returns - 1 if input does not match - * 0 if led was set +/** + * This command returns the status of the user button on + * Input - none + * Returns - 1 if button is held down + * 0 if button is not held down */ static int -do_setled(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +do_userbutton(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - int gpio = 0; - if (argc != 3) - goto exit; -#if defined(BOARD_STATUS_LED) - if (!strcmp(argv[1], "stat")) - gpio = BOARD_STATUS_LED; -#endif -#if defined(BOARD_DFU_BUTTON_LED) - if (!strcmp(argv[1], "dfu")) - gpio = BOARD_DFU_BUTTON_LED; -#endif - /* If argument does not mach exit */ - if (gpio == 0) - goto exit; - gpio_request(gpio, ""); - gpio_direction_output(gpio, 1); - if (!strcmp(argv[2], "1")) - gpio_set_value(gpio, 1); - else - gpio_set_value(gpio, 0); - return 0; -exit: - return 1; + int button = 0; + button = get_button_state("button_dfu0", BOARD_DFU_BUTTON_GPIO); + button |= get_button_state("button_dfu1", BOARD_DFU_BUTTON_GPIO); + return button; }
U_BOOT_CMD( - led, CONFIG_SYS_MAXARGS, 2, do_setled, - "Set led on or off", - "dfu val - set dfu led\nled stat val - set status led" + dfubutton, CONFIG_SYS_MAXARGS, 1, do_userbutton, + "Return the status of the DFU button", + "" ); +#endif
static int do_usertestwdt(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) @@ -189,4 +172,95 @@ U_BOOT_CMD( "Sends U-Boot into infinite loop", "" ); + +/** + * Get led gpios from env and set them. + * The led define in environment need to need to be of the form ledN=NN,S0,S1 + * where N is an unsigned integer from 0 to 9 and S0 and S1 is 0 or 1. S0 + * defines the startup state of the led, S1 the special state of the led when + * it enters e.g. dfu mode. + */ +void set_env_gpios(unsigned char state) +{ + char *ptr_env; + char str_tmp[5]; /* must contain "ledX"*/ + char num[1]; + unsigned char i, idx, pos1, pos2, ccount; + unsigned char gpio_n, gpio_s0, gpio_s1; + + for (i = 0; i < MAX_NR_LEDS; i++) { + strcpy(str_tmp, "led"); + sprintf(num, "%d", i); + strcat(str_tmp, num); + + /* If env var is not found we stop */ + ptr_env = getenv(str_tmp); + if (NULL == ptr_env) + break; + + /* Find sperators position */ + pos1 = 0; + pos2 = 0; + ccount = 0; + for (idx = 0; ptr_env[idx] != '\0'; idx++) { + if (ptr_env[idx] == ',') { + if (ccount++ < 1) + pos1 = idx; + else + pos2 = idx; + } + } + /* Bad led description skip this definition */ + if (pos2 <= pos1 || ccount > 2) + continue; + + /* Get pin number and request gpio */ + memset(str_tmp, 0, sizeof(str_tmp)); + strncpy(str_tmp, ptr_env, pos1*sizeof(char)); + gpio_n = (unsigned char)simple_strtoul(str_tmp, NULL, 0); + + /* Invalid gpio number skip definition */ + if (gpio_n > MAX_PIN_NUMBER) + continue; + + gpio_request(gpio_n, ""); + + if (state == STARTUP) { + /* get pin state 0 and set */ + memset(str_tmp, 0, sizeof(str_tmp)); + strncpy(str_tmp, ptr_env+pos1+1, + (pos2-pos1-1)*sizeof(char)); + gpio_s0 = (unsigned char)simple_strtoul(str_tmp, NULL, + 0); + + gpio_direction_output(gpio_n, gpio_s0); + + } else { + /* get pin state 1 and set */ + memset(str_tmp, 0, sizeof(str_tmp)); + strcpy(str_tmp, ptr_env+pos2+1); + gpio_s1 = (unsigned char)simple_strtoul(str_tmp, NULL, + 0); + gpio_direction_output(gpio_n, gpio_s1); + } + } /* loop through defined led in environment */ +} + +static int do_board_led(cmd_tbl_t *cmdtp, int flag, int argc, + char *const argv[]) +{ + if (argc != 2) + return CMD_RET_USAGE; + if ((unsigned char)simple_strtoul(argv[1], NULL, 0) == STARTUP) + set_env_gpios(0); + else + set_env_gpios(1); + return 0; +}; + +U_BOOT_CMD( + draco_led, CONFIG_SYS_MAXARGS, 2, do_board_led, + "Set LEDs defined in environment", + "<0|1>" +); #endif /* !CONFIG_SPL_BUILD */ diff --git a/board/siemens/draco/board.c b/board/siemens/draco/board.c index ede73ba..2697762 100644 --- a/board/siemens/draco/board.c +++ b/board/siemens/draco/board.c @@ -43,7 +43,7 @@ static struct draco_baseboard_id __attribute__((section(".data"))) settings; /* Default@303MHz-i0 */ const struct ddr3_data ddr3_default = { 0x33524444, 0x56312e35, 0x0080, 0x0000, 0x003A, 0x003F, 0x009F, - 0x0079, 0x0888A39B, 0x26247FDA, 0x501F821F, 0x00100206, 0x61A44A32, + 0x0079, 0x0888A39B, 0x26517FDA, 0x501F84EF, 0x00100206, 0x61A44A32, 0x0000093B, 0x0000014A, "default name @303MHz \0", "default marking \0", @@ -71,8 +71,8 @@ static void print_ddr3_timings(void) printf("clock:\t\t%d MHz\n", DDR_PLL_FREQ); printf("device:\t\t%s\n", settings.ddr3.manu_name); printf("marking:\t%s\n", settings.ddr3.manu_marking); - printf("timing parameters\n"); - printf("diff\teeprom\tdefault\n"); + printf("%-20s, %-8s, %-8s, %-4s\n", "timing parameters", "eeprom", + "default", "diff"); PRINTARGS(magic); PRINTARGS(version); PRINTARGS(ddr3_sratio); @@ -96,9 +96,12 @@ static void print_ddr3_timings(void)
static void print_chip_data(void) { + struct ctrl_dev *cdev = (struct ctrl_dev *)CTRL_DEVICE_BASE; + dpll_mpu_opp100.m = am335x_get_efuse_mpu_max_freq(cdev); printf("\nCPU BOARD\n"); printf("device: \t'%s'\n", settings.chip.sdevname); printf("hw version: \t'%s'\n", settings.chip.shwver); + printf("max freq: \t%d MHz\n", dpll_mpu_opp100.m); } #endif /* CONFIG_SPL_BUILD */
@@ -193,6 +196,11 @@ struct ctrl_ioregs draco_ddr3_ioregs = {
config_ddr(DDR_PLL_FREQ, &draco_ddr3_ioregs, &draco_ddr3_data, &draco_ddr3_cmd_ctrl_data, &draco_ddr3_emif_reg_data, 0); + + /* For Samsung 2Gbit RAM we need this delay otherwise config fails after + * soft reset. + */ + udelay(2000); }
static void spl_siemens_board_init(void) @@ -201,6 +209,26 @@ static void spl_siemens_board_init(void) } #endif /* if def CONFIG_SPL_BUILD */
+#ifdef CONFIG_BOARD_LATE_INIT +int board_late_init(void) +{ + omap_nand_switch_ecc(1, 8); +#ifdef CONFIG_FACTORYSET + /* Set ASN in environment*/ + if (factory_dat.asn[0] != 0) { + setenv("dtb_name", (char *)factory_dat.asn); + } else { + /* dtb suffix gets added in load script */ + setenv("dtb_name", "am335x-draco"); + } +#else + setenv("dtb_name", "am335x-draco"); +#endif + + return 0; +} +#endif + #if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_SPL_BUILD)) || \ (defined(CONFIG_SPL_ETH_SUPPORT) && defined(CONFIG_SPL_BUILD)) static void cpsw_control(int enabled) @@ -280,13 +308,4 @@ U_BOOT_CMD( #endif /* #if defined(CONFIG_DRIVER_TI_CPSW) */ #endif /* #if (defined(CONFIG_DRIVER_TI_CPSW) && !defined(CONFIG_SPL_BUILD)) */
-#ifdef CONFIG_BOARD_LATE_INIT -int board_late_init(void) -{ - omap_nand_switch_ecc(1, 8); - - return 0; -} -#endif - #include "../common/board.c" diff --git a/board/siemens/draco/board.h b/board/siemens/draco/board.h index ff8ab76..8856fd0 100644 --- a/board/siemens/draco/board.h +++ b/board/siemens/draco/board.h @@ -16,9 +16,13 @@ #ifndef _BOARD_H_ #define _BOARD_H_
-#define PARGS3(x) settings.ddr3.x-ddr3_default.x, \ - settings.ddr3.x, ddr3_default.x -#define PRINTARGS(y) printf("%x, %8x, %8x : "#y"\n", PARGS3(y)) +#define PARGS(x) #x , /* Parameter Name */ \ + settings.ddr3.x, /* EEPROM Value */ \ + ddr3_default.x, /* Default Value */ \ + settings.ddr3.x-ddr3_default.x /* Difference */ + +#define PRINTARGS(y) printf("%-20s, %8x, %8x, %4d\n", PARGS(y)) + #define MAGIC_CHIP 0x50494843
/* Automatic generated definition */ @@ -69,4 +73,7 @@ void enable_uart4_pin_mux(void); void enable_uart5_pin_mux(void); void enable_i2c0_pin_mux(void); void enable_board_pin_mux(void); + +/* Forwared declaration, defined in common board.c */ +void set_env_gpios(unsigned char state); #endif diff --git a/board/siemens/draco/mux.c b/board/siemens/draco/mux.c index eaa3c70..dbcc80b 100644 --- a/board/siemens/draco/mux.c +++ b/board/siemens/draco/mux.c @@ -60,7 +60,7 @@ static struct module_pin_mux nand_pin_mux[] = {
static struct module_pin_mux gpios_pin_mux[] = { /* DFU button GPIO0_27*/ - {OFFSET(gpmc_ad11), (MODE(7) | PULLUDEN | RXACTIVE)}, + {OFFSET(gpmc_ad11), (MODE(7) | PULLUDEN | PULLUP_EN | RXACTIVE)}, {OFFSET(gpmc_csn3), MODE(7) }, /* LED0 GPIO2_0 */ {OFFSET(emu0), MODE(7)}, /* LED1 GPIO3_7 */ /* Triacs in HW Rev 2 */ @@ -222,7 +222,7 @@ static struct module_pin_mux gpios_pin_mux[] = { {OFFSET(vrefp), MODE(7) | RXACTIVE | PULLUDDIS}, {OFFSET(vrefn), MODE(7) | RXACTIVE | PULLUDDIS}, /* nRST for SMSC LAN9303 switch - GPIO2_24 */ - {OFFSET(lcd_pclk), MODE(7) }, /* LAN9303 nRST */ + {OFFSET(lcd_pclk), MODE(7) | PULLUDEN | PULLUP_EN }, /* LAN9303 nRST */ {-1}, };
diff --git a/include/configs/draco.h b/include/configs/draco.h index a2438d8..acefd3e 100644 --- a/include/configs/draco.h +++ b/include/configs/draco.h @@ -19,18 +19,23 @@
#include "siemens-am33x-common.h"
-#define CONFIG_SYS_MPUCLK 275 +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_SYS_MPUCLK 300 #define DDR_PLL_FREQ 303 #undef CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC
-#define BOARD_DFU_BUTTON_GPIO 27 -#define BOARD_DFU_BUTTON_LED 64 /* red LED */ -#define BOARD_STATUS_LED 103 /* green LED */ +#define BOARD_DFU_BUTTON_GPIO 27 /* Use as default */ #define GPIO_LAN9303_NRST 88 /* GPIO2_24 = gpio88 */
+#define CONFIG_ENV_SETTINGS_BUTTONS_AND_LEDS \ + "button_dfu0=27\0" \ + "led0=103,1,0\0" \ + "led1=64,0,1\0" + #undef CONFIG_DOS_PARTITION #undef CONFIG_CMD_FAT
+#define CONFIG_BOARD_LATE_INIT
/* Physical Memory Map */ #define CONFIG_MAX_RAM_BANK_SIZE (1024 << 20) /* 1GB */ @@ -57,13 +62,25 @@ /* Watchdog */ #define CONFIG_OMAP_WATCHDOG
+/* Define own nand partitions */ +#define CONFIG_ENV_OFFSET_REDUND 0x2E0000 +#define CONFIG_ENV_SIZE_REDUND 0x2000 +#define CONFIG_ENV_RANGE (4 * CONFIG_SYS_ENV_SECT_SIZE) + + +#define MTDPARTS_DEFAULT MTDPARTS_DEFAULT_V2 + #ifndef CONFIG_SPL_BUILD
/* Default env settings */ #define CONFIG_EXTRA_ENV_SETTINGS \ + "hostname=draco\0" \ "nand_img_size=0x400000\0" \ "optargs=\0" \ - CONFIG_COMMON_ENV_SETTINGS + "preboot=draco_led 0\0" \ + CONFIG_ENV_SETTINGS_BUTTONS_AND_LEDS \ + CONFIG_ENV_SETTINGS_V2 \ + CONFIG_ENV_SETTINGS_NAND_V2
#ifndef CONFIG_RESTORE_FLASH /* set to negative value for no autoboot */ @@ -75,6 +92,7 @@ "reset; " \ "fi;" \ "run nand_boot;" \ +"run nand_boot_backup;" \ "reset;"
diff --git a/include/configs/dxr2.h b/include/configs/dxr2.h index 76e6cac..fa74070 100644 --- a/include/configs/dxr2.h +++ b/include/configs/dxr2.h @@ -19,7 +19,8 @@
@@ -28,9 +29,15 @@ #define BOARD_STATUS_LED 103 /* green LED */ #define GPIO_LAN9303_NRST 88 /* GPIO2_24 = gpio88 */
/* Physical Memory Map */ #define CONFIG_MAX_RAM_BANK_SIZE (1024 << 20) /* 1GB */ @@ -57,6 +64,14 @@ /* Watchdog */ #define CONFIG_OMAP_WATCHDOG
/* Default env settings */ @@ -64,7 +79,10 @@ "hostname=dxr2\0" \ "nand_img_size=0x400000\0" \ "optargs=\0" \ - CONFIG_COMMON_ENV_SETTINGS + "preboot=draco_led 0\0" \ + CONFIG_ENV_SETTINGS_BUTTONS_AND_LEDS \ + CONFIG_ENV_SETTINGS_V2 \ + CONFIG_ENV_SETTINGS_NAND_V2
#ifndef CONFIG_RESTORE_FLASH /* set to negative value for no autoboot */ @@ -76,6 +94,7 @@ "reset; " \ "fi;" \ "run nand_boot;" \ +"run nand_boot_backup;" \ "reset;"
diff --git a/include/configs/pxm2.h b/include/configs/pxm2.h index 946b2c8..d896bca 100644 --- a/include/configs/pxm2.h +++ b/include/configs/pxm2.h @@ -25,11 +25,14 @@ #define DDR_PLL_FREQ 266
#define BOARD_DFU_BUTTON_GPIO 59 -#define BOARD_DFU_BUTTON_LED 117 #define BOARD_LCD_POWER 111 #define BOARD_BACK_LIGHT 112 #define BOARD_TOUCH_POWER 57
+#define CONFIG_ENV_SETTINGS_BUTTONS_AND_LEDS \ + "button_dfu0=59\0" \ + "led0=117,0,1\0" \ + /* Physical Memory Map */ #define CONFIG_MAX_RAM_BANK_SIZE (512 << 20) /* 1GB */
@@ -48,29 +51,25 @@
#define CONFIG_FACTORYSET
-/* UBI Support */ -#ifndef CONFIG_SPL_BUILD -#define CONFIG_CMD_MTDPARTS -#define CONFIG_MTD_PARTITIONS -#define CONFIG_MTD_DEVICE -#define CONFIG_RBTREE -#define CONFIG_LZO -#define CONFIG_CMD_UBI -#define CONFIG_CMD_UBIFS -#endif
+/* Use common default */ +#define MTDPARTS_DEFAULT MTDPARTS_DEFAULT_V1 + /* Default env settings */ #define CONFIG_EXTRA_ENV_SETTINGS \ "hostname=pxm2\0" \ "nand_img_size=0x500000\0" \ "optargs=\0" \ + "preboot=draco_led 0\0" \ + CONFIG_ENV_SETTINGS_BUTTONS_AND_LEDS \ "splashpos=m,m\0" \ - CONFIG_COMMON_ENV_SETTINGS \ + CONFIG_ENV_SETTINGS_V1 \ + CONFIG_ENV_SETTINGS_NAND_V1 \ "mmc_dev=0\0" \ "mmc_root=/dev/mmcblk0p2 rw\0" \ "mmc_root_fs_type=ext4 rootwait\0" \ diff --git a/include/configs/rut.h b/include/configs/rut.h index 0067ea4..78264ba 100644 --- a/include/configs/rut.h +++ b/include/configs/rut.h @@ -45,29 +45,23 @@
/* Watchdog */ #define WATCHDOG_TRIGGER_GPIO 14
+/* Use common default */ +#define MTDPARTS_DEFAULT MTDPARTS_DEFAULT_V1 + /* Default env settings */ #define CONFIG_EXTRA_ENV_SETTINGS \ "hostname=rut\0" \ "nand_img_size=0x500000\0" \ "splashpos=m,m\0" \ "optargs=fixrtc --no-log consoleblank=0 \0" \ - CONFIG_COMMON_ENV_SETTINGS \ + CONFIG_ENV_SETTINGS_V1 \ + CONFIG_ENV_SETTINGS_NAND_V1 \ "mmc_dev=0\0" \ "mmc_root=/dev/mmcblk0p2 rw\0" \ "mmc_root_fs_type=ext4 rootwait\0" \ diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index b005c86..7b602b3 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -45,6 +45,7 @@ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_ECHO #define CONFIG_CMD_CACHE +#define CONFIG_CMD_TIME
#define CONFIG_SYS_GENERIC_BOARD
@@ -69,7 +70,7 @@ #define CONFIG_SYS_MAXARGS 32
/* Console I/O Buffer Size */ -#define CONFIG_SYS_CBSIZE 512 +#define CONFIG_SYS_CBSIZE 1024
/* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE \ @@ -309,22 +310,87 @@ /* NAND support */ #ifdef CONFIG_NAND #define CONFIG_CMD_NAND + +/* UBI Support */ +#ifndef CONFIG_SPL_BUILD #define CONFIG_CMD_MTDPARTS +#define CONFIG_MTD_PARTITIONS +#define CONFIG_MTD_DEVICE +#define CONFIG_RBTREE +#define CONFIG_LZO +#define CONFIG_CMD_UBI +#define CONFIG_CMD_UBIFS +#endif + +/* Commen environment */ +#define CONFIG_PREBOOT +#define COMMON_ENV_DFU_ARGS "dfu_args=run bootargs_defaults;" \ + "setenv bootargs ${bootargs};" \ + "mtdparts default;" \ + "draco_led 1;" \ + "dfu 0 nand 0;" \ + "draco_led 0;\0" \ + +#define COMMON_ENV_NAND_BOOT \ + "nand_boot=echo Booting from nand; " \ + "if test ${upgrade_available} -eq 1; then " \ + "if test ${bootcount} -gt ${bootlimit}; " \ + "then " \ + "setenv upgrade_available 0;" \ + "setenv ${partitionset_active} true;" \ + "if test -n ${A}; then " \ + "setenv partitionset_active B; " \ + "env delete A; " \ + "fi;" \ + "if test -n ${B}; then " \ + "setenv partitionset_active A; " \ + "env delete B; " \ + "fi;" \ + "saveenv; " \ + "fi;" \ + "fi;" \ + "echo set ${partitionset_active}...;" \ + "run nand_args; " + +#define COMMON_ENV_NAND_CMDS "flash_self=run nand_boot\0" \ + "flash_self_test=setenv testargs test; " \ + "run nand_boot\0" \ + "dfu_start=echo Preparing for dfu mode ...; " \ + "run dfu_args; \0" + +#define COMMON_ENV_SETTINGS \ + "verify=no \0" \ + "project_dir=targetdir\0" \ + "upgrade_available=0\0" \ + "altbootcmd=run bootcmd\0" \ + "bootlimit=3\0" \ + "partitionset_active=A\0" \ + "loadaddr=0x82000000\0" \ + "kloadaddr=0x81000000\0" \ + "script_addr=0x81900000\0" \ + "console=console=ttyMTD,mtdoops console=ttyO0,115200n8 panic=5\0" \ + "nfsopts=nolock rw\0" \ + "ip_method=none\0" \ + "bootenv=uEnv.txt\0" \ + "bootargs_defaults=setenv bootargs " \ + "console=${console} " \ + "${testargs} " \ + "${optargs}\0" \ + "siemens_help=echo; "\ + "echo Type 'run flash_self' to use kernel and root " \ + "filesystem on memory; echo Type 'run flash_self_test' to " \ + "use kernel and root filesystem on memory, boot in test " \ + "mode; echo Not ready yet: 'run flash_nfs' to use kernel " \ + "from memory and root filesystem over NFS; echo Type " \ + "'run net_nfs' to get Kernel over TFTP and mount root " \ + "filesystem over NFS; " \ + "echo Set partitionset_active variable to 'A' " \ + "or 'B' to select kernel and rootfs partition; " \ + "echo" \ + "\0"
-#define MTDIDS_NAME_STR "omap2-nand.0" -#define MTDIDS_DEFAULT "nand0=" MTDIDS_NAME_STR -#define MTDPARTS_DEFAULT "mtdparts=" MTDIDS_NAME_STR ":" \ - "128k(spl)," \ - "128k(spl.backup1)," \ - "128k(spl.backup2)," \ - "128k(spl.backup3)," \ - "1920k(u-boot)," \ - "128k(uboot.env)," \ - "5120k(kernel_a)," \ - "5120k(kernel_b)," \ - "8192k(mtdoops)," \ - "-(rootfs)" /* + * Variant 1 partition layout * chip-size = 256MiB *| name | size | address area | *------------------------------------------------------- @@ -340,8 +406,21 @@ *| rootfs | 235.500 MiB | 0x 1480000..0x fffffff | *------------------------------------------------------- */ +#define MTDIDS_NAME_STR "omap2-nand.0" +#define MTDIDS_DEFAULT "nand0=" MTDIDS_NAME_STR +#define MTDPARTS_DEFAULT_V1 "mtdparts=" MTDIDS_NAME_STR ":" \ + "128k(spl)," \ + "128k(spl.backup1)," \ + "128k(spl.backup2)," \ + "128k(spl.backup3)," \ + "1920k(u-boot)," \ + "128k(uboot.env)," \ + "5120k(kernel_a)," \ + "5120k(kernel_b)," \ + "8192k(mtdoops)," \ + "-(rootfs)"
-#define DFU_ALT_INFO_NAND \ +#define DFU_ALT_INFO_NAND_V1 \ "spl part 0 1;" \ "spl.backup1 part 0 2;" \ "spl.backup2 part 0 3;" \ @@ -352,17 +431,7 @@ "kernel_b part 0 8;" \ "rootfs partubi 0 10"
-#define CONFIG_COMMON_ENV_SETTINGS \ - "verify=no \0" \ - "project_dir=targetdir\0" \ - "upgrade_available=0\0" \ - "altbootcmd=run bootcmd\0" \ - "bootlimit=3\0" \ - "partitionset_active=A\0" \ - "loadaddr=0x82000000\0" \ - "kloadaddr=0x81000000\0" \ - "script_addr=0x81900000\0" \ - "console=console=ttyMTD,mtdoops console=ttyO0,115200n8 panic=5\0" \ +#define CONFIG_ENV_SETTINGS_NAND_V1 \ "nand_active_ubi_vol=rootfs_a\0" \ "nand_active_ubi_vol_A=rootfs_a\0" \ "nand_active_ubi_vol_B=rootfs_b\0" \ @@ -370,13 +439,6 @@ "nand_src_addr=0x280000\0" \ "nand_src_addr_A=0x280000\0" \ "nand_src_addr_B=0x780000\0" \ - "nfsopts=nolock rw mem=128M\0" \ - "ip_method=none\0" \ - "bootenv=uEnv.txt\0" \ - "bootargs_defaults=setenv bootargs " \ - "console=${console} " \ - "${testargs} " \ - "${optargs}\0" \ "nand_args=run bootargs_defaults;" \ "mtdparts default;" \ "setenv ${partitionset_active} true;" \ @@ -395,15 +457,15 @@ "rootfstype=${nand_root_fs_type} ip=${ip_method} " \ "console=ttyMTD,mtdoops console=ttyO0,115200n8 mtdoops.mtddev" \ "=mtdoops\0" \ - "dfu_args=run bootargs_defaults;" \ - "setenv bootargs ${bootargs} ;" \ - "mtdparts default; " \ - "led dfu 1;" \ - "led stat 0;" \ - "dfu 0 nand 0;" \ - "led dfu 0;" \ - "led stat 1;\0" \ - "dfu_alt_info=" DFU_ALT_INFO_NAND "\0" \ + COMMON_ENV_DFU_ARGS \ + "dfu_alt_info=" DFU_ALT_INFO_NAND_V1 "\0" \ + COMMON_ENV_NAND_BOOT \ + "nand read.i ${kloadaddr} ${nand_src_addr} " \ + "${nand_img_size}; bootm ${kloadaddr}\0" \ + COMMON_ENV_NAND_CMDS + +#define CONFIG_ENV_SETTINGS_V1 \ + COMMON_ENV_SETTINGS \ "net_args=run bootargs_defaults;" \ "mtdparts default;" \ "setenv bootfile ${project_dir}/kernel/uImage;" \ @@ -413,48 +475,103 @@ "nfsroot=${serverip}:${rootpath},${nfsopts} " \ "ip=${ipaddr}:${serverip}:" \ "${gatewayip}:${netmask}:${hostname}:eth0:off\0" \ - "nand_boot=echo Booting from nand; " \ - "if test ${upgrade_available} -eq 1; then " \ - "if test ${bootcount} -gt ${bootlimit}; " \ - "then " \ - "setenv upgrade_available 0;" \ - "setenv ${partitionset_active} true;" \ - "if test -n ${A}; then " \ - "setenv partitionset_active B; " \ - "env delete A; " \ - "fi;" \ - "if test -n ${B}; then " \ - "setenv partitionset_active A; " \ - "env delete B; " \ - "fi;" \ - "saveenv; " \ - "fi;" \ + "net_nfs=echo Booting from network ...; " \ + "run net_args; " \ + "tftpboot ${kloadaddr} ${serverip}:${bootfile}; " \ + "bootm ${kloadaddr}\0" + +/* + * Variant 2 partition layout + * chip-size = 256MiB + *| name | size | address area | + *------------------------------------------------------- + *| spl | 128.000 KiB | 0x 0..0x 1ffff | + *| spl.backup1 | 128.000 KiB | 0x 20000..0x 3ffff | + *| spl.backup2 | 128.000 KiB | 0x 40000..0x 5ffff | + *| spl.backup3 | 128.000 KiB | 0x 60000..0x 7ffff | + *| u-boot | 1.875 MiB | 0x 80000..0x 25ffff | + *| uboot.env0 | 512.000 KiB | 0x 260000..0x 2Dffff | + *| uboot.env1 | 512.000 KiB | 0x 2E0000..0x 35ffff | + *| rootfs | 148.000 MiB | 0x 360000..0x 975ffff | + *| mtdoops | 512.000 KiB | 0x 9760000..0x 98Dffff | + *|configuration | 104.125 MiB | 0x 97E0000..0x fffffff | + *------------------------------------------------------- + */ + +#define MTDPARTS_DEFAULT_V2 "mtdparts=" MTDIDS_NAME_STR ":" \ + "128k(spl)," \ + "128k(spl.backup1)," \ + "128k(spl.backup2)," \ + "128k(spl.backup3)," \ + "1920k(u-boot)," \ + "512k(u-boot.env0)," \ + "512k(u-boot.env1)," \ + "148m(rootfs)," \ + "512k(mtdoops)," \ + "-(configuration)" + +#define DFU_ALT_INFO_NAND_V2 \ + "spl part 0 1;" \ + "spl.backup1 part 0 2;" \ + "spl.backup2 part 0 3;" \ + "spl.backup3 part 0 4;" \ + "u-boot part 0 5;" \ + "u-boot.env0 part 0 6;" \ + "u-boot.env1 part 0 7;" \ + "rootfs partubi 0 8;" \ + "configuration partubi 0 10" + +#define CONFIG_ENV_SETTINGS_NAND_V2 \ + "nand_active_ubi_vol=rootfs_a\0" \ + "rootfs_name=rootfs\0" \ + "kernel_name=uImage\0"\ + "nand_root_fs_type=ubifs rootwait=1\0" \ + "nand_args=run bootargs_defaults;" \ + "mtdparts default;" \ + "setenv ${partitionset_active} true;" \ + "if test -n ${A}; then " \ + "setenv nand_active_ubi_vol ${rootfs_name}_a;" \ "fi;" \ - "echo set ${partitionset_active}...;" \ - "run nand_args; " \ - "nand read.i ${kloadaddr} ${nand_src_addr} " \ - "${nand_img_size}; bootm ${kloadaddr}\0" \ + "if test -n ${B}; then " \ + "setenv nand_active_ubi_vol ${rootfs_name}_b;" \ + "fi;" \ + "setenv nand_root ubi0:${nand_active_ubi_vol} rw " \ + "ubi.mtd=7,2048 ubi.mtd=9,2048;" \ + "setenv bootargs ${bootargs} " \ + "root=${nand_root} noinitrd ${mtdparts} " \ + "rootfstype=${nand_root_fs_type} ip=${ip_method} " \ + "console=ttyMTD,mtdoops console=ttyO0,115200n8 mtdoops.mtddev" \ + "=mtdoops\0" \ + COMMON_ENV_DFU_ARGS \ + "dfu_alt_info=" DFU_ALT_INFO_NAND_V2 "\0" \ + COMMON_ENV_NAND_BOOT \ + "ubi part rootfs 2048;" \ + "ubifsmount ubi0:${nand_active_ubi_vol};" \ + "ubifsload ${kloadaddr} boot/${kernel_name};" \ + "ubifsload ${loadaddr} boot/${dtb_name}.dtb;" \ + "bootm ${kloadaddr} - ${loadaddr}\0" \ + "nand_boot_backup=ubifsload ${loadaddr} boot/am335x-draco.dtb;" \ + "bootm ${kloadaddr} - ${loadaddr}\0" \ + COMMON_ENV_NAND_CMDS + +#define CONFIG_ENV_SETTINGS_V2 \ + COMMON_ENV_SETTINGS \ + "net_args=run bootargs_defaults;" \ + "mtdparts default;" \ + "setenv bootfile ${project_dir}/kernel/uImage;" \ + "setenv bootdtb ${project_dir}/kernel/dtb;" \ + "setenv rootpath /home/projects/${project_dir}/rootfs;" \ + "setenv bootargs ${bootargs} " \ + "root=/dev/nfs ${mtdparts} " \ + "nfsroot=${serverip}:${rootpath},${nfsopts} " \ + "ip=${ipaddr}:${serverip}:" \ + "${gatewayip}:${netmask}:${hostname}:eth0:off\0" \ "net_nfs=echo Booting from network ...; " \ "run net_args; " \ "tftpboot ${kloadaddr} ${serverip}:${bootfile}; " \ - "bootm ${kloadaddr}\0" \ - "flash_self=run nand_boot\0" \ - "flash_self_test=setenv testargs test; " \ - "run nand_boot\0" \ - "dfu_start=echo Preparing for dfu mode ...; " \ - "run dfu_args; \0" \ - "preboot=echo; "\ - "echo Type 'run flash_self' to use kernel and root " \ - "filesystem on memory; echo Type 'run flash_self_test' to " \ - "use kernel and root filesystem on memory, boot in test " \ - "mode; echo Not ready yet: 'run flash_nfs' to use kernel " \ - "from memory and root filesystem over NFS; echo Type " \ - "'run net_nfs' to get Kernel over TFTP and mount root " \ - "filesystem over NFS; " \ - "echo Set partitionset_active variable to 'A' " \ - "or 'B' to select kernel and rootfs partition; " \ - "echo" \ - "\0" + "tftpboot ${loadaddr} ${serverip}:${bootdtb}; " \ + "bootm ${kloadaddr} - ${loadaddr}\0" +
#define CONFIG_NAND_OMAP_GPMC #define CONFIG_NAND_OMAP_ELM @@ -473,6 +590,9 @@
#define CONFIG_OMAP_GPIO
+/* Gpio cmd support */ +#define CONFIG_CMD_GPIO + /* Watchdog */ #define CONFIG_HW_WATCHDOG
Heiko Schocher
