[U-Boot] ARM Pull Request
Hi Wolfgang,
The OMAP3 patch has been dropped
Please Pull The following changes since commit 88685b5f62274167ad2ba8a58e108d89ff71955b: Wolfgang Denk (1): VCMA9: fix compile errors
git://git.denx.de/u-boot-arm.git master
Jean-Christophe PLAGNIOL-VILLARD (18): s3c4510b: move specific code to soc directory s3c44b0: move i2c driver to drivers/i2c s3c44b0: move rtc driver to drivers/rtc s3c44b0: move serial driver to drivers/serial s3c44b0: extract cache from cpu.c sa1100: move serial driver to drivers/serial netarm: move serial driver to drivers/serial imx31: move serial driver to drivers/serial s3c64xx: move usb driver to drivers/usb ks8695: move serial driver to drivers/serial lpc2292: move serial driver to drivers/serial arm720t/clps7111: move serial driver to drivers/serial imx: move serial driver to drivers/serial davinci: move nand driver to drivers/mtd/nand davinci: move i2c driver to drivers/i2c s3c24x0: move serial driver to drivers/serial s3c24x0: move i2c driver to drivers/i2c s3c2410: move nand driver to drivers/mtd/nand
Ladislav Michl (7): Remove nowhere used symbol CONFIG_SYS_CLKS_IN_HZ NetStar: update crcit utility NetStar: use generic flash driver NetStar: add RTC support OMAP: reindent timer code OMAP: rename timer divisor OMAP: use {read,write}l to access timer registers
Makefile | 2 +- board/netstar/Makefile | 2 +- board/netstar/crcit.c | 14 +- board/netstar/flash.c | 343 ---------------- board/netstar/netstar.c | 20 + cpu/arm1136/mx31/Makefile | 2 +- cpu/arm1136/omap24xx/interrupts.c | 2 +- cpu/arm1176/s3c64xx/Makefile | 1 - cpu/arm720t/Makefile | 2 +- cpu/arm720t/cpu.c | 62 --- cpu/arm720t/s3c4510b/Makefile | 46 ++ cpu/arm720t/s3c4510b/cache.c | 86 ++++ cpu/arm720t/serial.c | 202 --------- cpu/arm920t/imx/Makefile | 2 +- cpu/arm920t/ks8695/Makefile | 2 +- cpu/arm920t/s3c24x0/Makefile | 3 +- cpu/arm925t/interrupts.c | 40 +- cpu/arm926ejs/davinci/Makefile | 2 +- cpu/arm926ejs/omap/timer.c | 2 +- cpu/arm_cortexa8/omap3/interrupts.c | 2 +- cpu/s3c44b0/Makefile | 2 +- cpu/s3c44b0/cache.c | 91 ++++ cpu/s3c44b0/cpu.c | 430 -------------------- cpu/sa1100/Makefile | 2 +- drivers/i2c/Makefile | 3 + .../davinci/i2c.c => drivers/i2c/davinci_i2c.c | 5 - .../s3c24x0/i2c.c => drivers/i2c/s3c24x0_i2c.c | 5 - drivers/i2c/s3c44b0_i2c.c | 315 ++++++++++++++ drivers/mtd/nand/Makefile | 2 + .../nand.c => drivers/mtd/nand/davinci_nand.c | 9 - .../nand.c => drivers/mtd/nand/s3c2410_nand.c | 8 - drivers/rtc/Makefile | 1 + drivers/rtc/s3c44b0_rtc.c | 102 +++++ drivers/serial/Makefile | 9 + .../serial.c => drivers/serial/serial_clps7111.c | 97 ++--- .../imx/serial.c => drivers/serial/serial_imx.c | 6 - .../serial.c => drivers/serial/serial_ks8695.c | 0 drivers/serial/serial_lpc2292.c | 105 +++++ .../mx31/serial.c => drivers/serial/serial_mx31.c | 6 - {cpu/arm720t => drivers/serial}/serial_netarm.c | 5 - .../serial.c => drivers/serial/serial_s3c24x0.c | 4 - .../serial.c => drivers/serial/serial_s3c44b0.c | 0 .../serial.c => drivers/serial/serial_sa1100.c | 0 drivers/usb/Makefile | 1 + .../s3c64xx/usb.c => drivers/usb/s3c64xx_usb.c | 0 include/asm-arm/arch-arm720t/hardware.h | 4 +- .../s3c4510b.h => arch-s3c4510b/hardware.h} | 0 include/configs/ADNPESC1.h | 1 - include/configs/B2.h | 6 +- include/configs/DK1C20.h | 1 - include/configs/DK1S10.h | 1 - include/configs/EXBITGEN.h | 2 - include/configs/SMN42.h | 3 +- include/configs/SX1.h | 8 +- include/configs/VCMA9.h | 4 +- include/configs/W7OLMC.h | 2 - include/configs/W7OLMG.h | 2 - include/configs/actux1.h | 2 - include/configs/actux2.h | 2 - include/configs/actux3.h | 2 - include/configs/actux4.h | 2 - include/configs/apollon.h | 7 +- include/configs/armadillo.h | 3 +- include/configs/assabet.h | 3 +- include/configs/cerf250.h | 2 - include/configs/cm4008.h | 3 +- include/configs/cm41xx.h | 3 +- include/configs/cradle.h | 2 - include/configs/csb226.h | 2 - include/configs/csb272.h | 1 - include/configs/csb472.h | 1 - include/configs/davinci_dvevm.h | 1 + include/configs/davinci_schmoogie.h | 1 + include/configs/davinci_sffsdr.h | 1 + include/configs/davinci_sonata.h | 1 + include/configs/delta.h | 2 - include/configs/dnp1110.h | 3 +- include/configs/eNET.h | 2 - include/configs/ep7312.h | 3 +- include/configs/evb4510.h | 2 - include/configs/gcplus.h | 3 +- include/configs/hymod.h | 2 - include/configs/impa7.h | 3 +- include/configs/innokom.h | 2 - include/configs/integratorap.h | 1 - include/configs/integratorcp.h | 1 - include/configs/ixdp425.h | 2 - include/configs/ixdpg425.h | 1 - include/configs/lart.h | 3 +- include/configs/logodl.h | 2 - include/configs/lpc2292sodimm.h | 3 +- include/configs/lpd7a400.h | 2 - include/configs/lpd7a404.h | 2 - include/configs/lubbock.h | 2 - include/configs/modnet50.h | 3 +- include/configs/mx1ads.h | 2 +- include/configs/mx1fs2.h | 5 +- include/configs/netstar.h | 35 +- include/configs/nmdk8815.h | 1 - include/configs/ns9750dev.h | 2 - include/configs/omap1510inn.h | 8 +- include/configs/omap1610h2.h | 6 +- include/configs/omap1610inn.h | 6 +- include/configs/omap2420h4.h | 12 +- include/configs/omap3_beagle.h | 8 +- include/configs/omap3_evm.h | 9 +- include/configs/omap3_overo.h | 9 +- include/configs/omap3_pandora.h | 9 +- include/configs/omap3_zoom1.h | 8 +- include/configs/omap5912osk.h | 6 +- include/configs/omap730p2.h | 9 +- include/configs/pdnb3.h | 1 - include/configs/pleb2.h | 2 - include/configs/pxa255_idp.h | 2 - include/configs/sbc2410x.h | 4 +- include/configs/sc520_cdp.h | 2 - include/configs/sc520_spunk.h | 2 - include/configs/scb9328.h | 3 +- include/configs/shannon.h | 3 +- include/configs/smdk2400.h | 3 +- include/configs/smdk2410.h | 3 +- include/configs/smdk6400.h | 1 + include/configs/trab.h | 3 +- include/configs/trizepsiv.h | 2 - include/configs/versatile.h | 1 - include/configs/voiceblue.h | 8 +- include/configs/wepep250.h | 2 - include/configs/xaeniax.h | 2 - include/configs/xm250.h | 2 - include/configs/xsengine.h | 1 - include/configs/zylonite.h | 2 - 131 files changed, 936 insertions(+), 1410 deletions(-) delete mode 100644 board/netstar/flash.c create mode 100644 cpu/arm720t/s3c4510b/Makefile create mode 100644 cpu/arm720t/s3c4510b/cache.c delete mode 100644 cpu/arm720t/serial.c create mode 100644 cpu/s3c44b0/cache.c rename cpu/arm926ejs/davinci/i2c.c => drivers/i2c/davinci_i2c.c (98%) rename cpu/arm920t/s3c24x0/i2c.c => drivers/i2c/s3c24x0_i2c.c (99%) create mode 100644 drivers/i2c/s3c44b0_i2c.c rename cpu/arm926ejs/davinci/nand.c => drivers/mtd/nand/davinci_nand.c (98%) rename cpu/arm920t/s3c24x0/nand.c => drivers/mtd/nand/s3c2410_nand.c (96%) create mode 100644 drivers/rtc/s3c44b0_rtc.c copy cpu/sa1100/serial.c => drivers/serial/serial_clps7111.c (56%) rename cpu/arm920t/imx/serial.c => drivers/serial/serial_imx.c (97%) rename cpu/arm920t/ks8695/serial.c => drivers/serial/serial_ks8695.c (100%) create mode 100644 drivers/serial/serial_lpc2292.c rename cpu/arm1136/mx31/serial.c => drivers/serial/serial_mx31.c (99%) rename {cpu/arm720t => drivers/serial}/serial_netarm.c (99%) rename cpu/arm920t/s3c24x0/serial.c => drivers/serial/serial_s3c24x0.c (97%) rename cpu/s3c44b0/serial.c => drivers/serial/serial_s3c44b0.c (100%) rename cpu/sa1100/serial.c => drivers/serial/serial_sa1100.c (100%) rename cpu/arm1176/s3c64xx/usb.c => drivers/usb/s3c64xx_usb.c (100%) rename include/asm-arm/{arch-arm720t/s3c4510b.h => arch-s3c4510b/hardware.h} (100%)
Best Regards, J.
Dear Jean-Christophe PLAGNIOL-VILLARD,
In message 20090330164713.GD23828@game.jcrosoft.org you wrote:
Hi Wolfgang,
Applied, thanks.
