[PATCH 0/7] board: rockchip: add FriendlyElec NanoPi R3S
The NanoPi R3S(as "R3S") is an open source platform with dual-Gbps Ethernet ports designed and developed by FriendlyElec for IoT applications.
Tianling Shen (7): arm64: dts: rockchip: Add FriendlyARM NanoPi R3S board arm64: dts: rockchip: fix model name for FriendlyElec NanoPi R3S arm64: dts: rockchip: replace deprecated snps,reset props for NanoPi R3S arm64: dts: rockchip: sort props in pmu_io_domains node for NanoPi R3S arm64: dts: rockchip: enable eMMC HS200 mode for NanoPi R3S arm64: dts: rockchip: reorder mmc aliases for NanoPi R3S board: rockchip: add FriendlyElec NanoPi R3S
arch/arm/dts/rk3566-nanopi-r3s-u-boot.dtsi | 8 + board/rockchip/evb_rk3568/MAINTAINERS | 7 + configs/nanopi-r3s-rk3566_defconfig | 74 +++ doc/board/rockchip/rockchip.rst | 1 + .../src/arm64/rockchip/rk3566-nanopi-r3s.dts | 554 ++++++++++++++++++ 5 files changed, 644 insertions(+) create mode 100644 arch/arm/dts/rk3566-nanopi-r3s-u-boot.dtsi create mode 100644 configs/nanopi-r3s-rk3566_defconfig create mode 100644 dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts
Specification: - Rockchip RK3566 - 2GB LPDDR4X RAM - optional 32GB eMMC module - SD card slot - 2x 1000 Base-T - 3x LEDs (POWER, LAN, WAN) - 2x Buttons (Reset, MaskROM) - 1x USB 3.0 Port - Type-C 5V 2A Power
Signed-off-by: Tianling Shen cnsztl@gmail.com Link: https://lore.kernel.org/r/20241020173946.225960-2-cnsztl@gmail.com Signed-off-by: Heiko Stuebner heiko@sntech.de
[ upstream commit: 50decd493c8394c52d04561fe4ede34df27a46ba ]
Signed-off-by: Tianling Shen cnsztl@gmail.com --- .../src/arm64/rockchip/rk3566-nanopi-r3s.dts | 554 ++++++++++++++++++ 1 file changed, 554 insertions(+) create mode 100644 dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts
diff --git a/dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts b/dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts new file mode 100644 index 0000000000..a7a55d68db --- /dev/null +++ b/dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts @@ -0,0 +1,554 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/* + * Copyright (c) 2020 Rockchip Electronics Co., Ltd. + * + * Copyright (c) 2024 FriendlyElec Computer Tech. Co., Ltd. + * (http://www.friendlyarm.com) + * + * Copyright (c) 2024 Tianling Shen cnsztl@gmail.com + */ + +/dts-v1/; +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/input/input.h> +#include <dt-bindings/leds/common.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include <dt-bindings/soc/rockchip,vop2.h> +#include "rk3566.dtsi" + +/ { + model = "FriendlyARM NanoPi R3S"; + compatible = "friendlyarm,nanopi-r3s", "rockchip,rk3566"; + + aliases { + ethernet0 = &gmac1; + mmc0 = &sdmmc0; + mmc1 = &sdhci; + }; + + chosen: chosen { + stdout-path = "serial2:1500000n8"; + }; + + gpio-keys { + compatible = "gpio-keys"; + pinctrl-names = "default"; + pinctrl-0 = <&reset_button_pin>; + + button-reset { + label = "reset"; + gpios = <&gpio0 RK_PC2 GPIO_ACTIVE_LOW>; + linux,code = <KEY_RESTART>; + debounce-interval = <50>; + }; + }; + + gpio-leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&power_led_pin>, <&lan_led_pin>, <&wan_led_pin>; + + power_led: led-0 { + color = <LED_COLOR_ID_RED>; + function = LED_FUNCTION_POWER; + gpios = <&gpio0 RK_PB7 GPIO_ACTIVE_HIGH>; + default-state = "on"; + }; + + lan_led: led-1 { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_LAN; + gpios = <&gpio3 RK_PC2 GPIO_ACTIVE_HIGH>; + }; + + wan_led: led-2 { + color = <LED_COLOR_ID_GREEN>; + function = LED_FUNCTION_WAN; + gpios = <&gpio3 RK_PC3 GPIO_ACTIVE_HIGH>; + }; + }; + + vcc3v3_sys: regulator-vcc3v3-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc5v0_sys: regulator-vcc5v0-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vdd_usbc>; + }; + + vcc5v0_usb: regulator-vcc5v0_usb { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&vcc5v0_usb_host_en>; + regulator-name = "vcc5v0_usb"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + vin-supply = <&vcc5v0_sys>; + }; + + vdd_usbc: regulator-vdd-usbc { + compatible = "regulator-fixed"; + regulator-name = "vdd_usbc"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; +}; + +&combphy1 { + status = "okay"; +}; + +&combphy2 { + status = "okay"; +}; + +&cpu0 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu1 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu2 { + cpu-supply = <&vdd_cpu>; +}; + +&cpu3 { + cpu-supply = <&vdd_cpu>; +}; + +&gmac1 { + assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1>; + assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>, <&cru CLK_MAC1_2TOP>; + assigned-clock-rates = <0>, <125000000>; + clock_in_out = "output"; + phy-mode = "rgmii-id"; + phy-handle = <&rgmii_phy1>; + pinctrl-names = "default"; + pinctrl-0 = <&gmac1m0_miim + &gmac1m0_tx_bus2_level3 + &gmac1m0_rx_bus2 + &gmac1m0_rgmii_clk_level2 + &gmac1m0_rgmii_bus_level3>; + snps,reset-gpio = <&gpio4 RK_PC2 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + /* Reset time is 20ms, 100ms for rtl8211f */ + snps,reset-delays-us = <0 20000 100000>; + status = "okay"; +}; + +&gpu { + mali-supply = <&vdd_gpu>; + status = "okay"; +}; + +&i2c0 { + status = "okay"; + + vdd_cpu: regulator@1c { + compatible = "tcs,tcs4525"; + reg = <0x1c>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1150000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + rk809: pmic@20 { + compatible = "rockchip,rk809"; + reg = <0x20>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <1>; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int>; + system-power-controller; + vcc1-supply = <&vcc3v3_sys>; + vcc2-supply = <&vcc3v3_sys>; + vcc3-supply = <&vcc3v3_sys>; + vcc4-supply = <&vcc3v3_sys>; + vcc5-supply = <&vcc3v3_sys>; + vcc6-supply = <&vcc3v3_sys>; + vcc7-supply = <&vcc3v3_sys>; + vcc8-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc3v3_sys>; + wakeup-source; + + regulators { + vdd_logic: DCDC_REG1 { + regulator-name = "vdd_logic"; + regulator-always-on; + regulator-boot-on; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_gpu: DCDC_REG2 { + regulator-name = "vdd_gpu"; + regulator-always-on; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-initial-mode = <0x2>; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vdd_npu: DCDC_REG4 { + regulator-name = "vdd_npu"; + regulator-initial-mode = <0x2>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_1v8: DCDC_REG5 { + regulator-name = "vcc_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda0v9_image: LDO_REG1 { + regulator-name = "vdda0v9_image"; + regulator-min-microvolt = <950000>; + regulator-max-microvolt = <950000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda_0v9: LDO_REG2 { + regulator-name = "vdda_0v9"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdda0v9_pmu: LDO_REG3 { + regulator-name = "vdda0v9_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <900000>; + regulator-max-microvolt = <900000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <900000>; + }; + }; + + vccio_acodec: LDO_REG4 { + regulator-name = "vccio_acodec"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vccio_sd: LDO_REG5 { + regulator-name = "vccio_sd"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_pmu: LDO_REG6 { + regulator-name = "vcc3v3_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcca_1v8: LDO_REG7 { + regulator-name = "vcca_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcca1v8_pmu: LDO_REG8 { + regulator-name = "vcca1v8_pmu"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcca1v8_image: LDO_REG9 { + regulator-name = "vcca1v8_image"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_3v3: SWITCH_REG1 { + regulator-name = "vcc_3v3"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_sd: SWITCH_REG2 { + regulator-name = "vcc3v3_sd"; + regulator-always-on; + regulator-boot-on; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + }; + }; +}; + +&i2c1 { + status = "okay"; + + hym8563: rtc@51 { + compatible = "haoyu,hym8563"; + reg = <0x51>; + #clock-cells = <0>; + clock-output-names = "hym8563"; + pinctrl-names = "default"; + pinctrl-0 = <&hym8563_int>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PD3 IRQ_TYPE_LEVEL_LOW>; + wakeup-source; + }; +}; + +&mdio1 { + rgmii_phy1: ethernet-phy@1 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <1>; + interrupt-parent = <&gpio4>; + interrupts = <RK_PC3 IRQ_TYPE_LEVEL_LOW>; + pinctrl-names = "default"; + pinctrl-0 = <ð_phy_reset_pin>; + }; +}; + +&pcie2x1 { + pinctrl-names = "default"; + pinctrl-0 = <&pcie_reset_h>; + reset-gpios = <&gpio4 RK_PC6 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + +&pinctrl { + gpio-leds { + lan_led_pin: lan-led-pin { + rockchip,pins = <3 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + power_led_pin: power-led-pin { + rockchip,pins = <0 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + wan_led_pin: wan-led-pin { + rockchip,pins = <3 RK_PC3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + gmac { + eth_phy_reset_pin: eth-phy-reset-pin { + rockchip,pins = <4 RK_PC2 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + pcie { + pcie_reset_h: pcie-reset-h { + rockchip,pins = <4 RK_PC6 RK_FUNC_GPIO &pcfg_pull_down>; + }; + }; + + pmic { + pmic_int: pmic-int { + rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + rockchip-key { + reset_button_pin: reset-button-pin { + rockchip,pins = <0 RK_PC2 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + rtc { + hym8563_int: hym8563-int { + rockchip,pins = <0 RK_PD3 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + usb { + vcc5v0_usb_host_en: vcc5v0-usb-host-en { + rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pmu_io_domains { + status = "okay"; + pmuio1-supply = <&vcc3v3_pmu>; + pmuio2-supply = <&vcc3v3_pmu>; + vccio1-supply = <&vccio_acodec>; + vccio2-supply = <&vcc_1v8>; + vccio3-supply = <&vccio_sd>; + vccio4-supply = <&vcc_3v3>; + vccio5-supply = <&vcc_1v8>; + vccio6-supply = <&vcc_3v3>; + vccio7-supply = <&vcc_3v3>; +}; + +&sdhci { + bus-width = <8>; + max-frequency = <200000000>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe>; + status = "okay"; +}; + +&sdmmc0 { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + disable-wp; + no-sdio; + no-mmc; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det>; + sd-uhs-sdr50; + vmmc-supply = <&vcc3v3_sd>; + vqmmc-supply = <&vccio_sd>; + status = "okay"; +}; + +&tsadc { + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&usb2phy0 { + status = "okay"; +}; + +&usb2phy0_host { + phy-supply = <&vcc5v0_usb>; + status = "okay"; +}; + +&usb2phy0_otg { + status = "okay"; +}; + +&usb_host0_xhci { + extcon = <&usb2phy0>; + status = "okay"; +}; + +&usb_host1_xhci { + status = "okay"; +}; + +&vop { + assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>; + assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>; + status = "okay"; +}; + +&vop_mmu { + status = "okay"; +};
Specification:
- Rockchip RK3566
- 2GB LPDDR4X RAM
- SD card slot
- 2x 1000 Base-T
- 1x USB 3.0 Port
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- Copyright (c) 2020 Rockchip Electronics Co., Ltd.
- Copyright (c) 2024 FriendlyElec Computer Tech. Co., Ltd.
- Copyright (c) 2024 Tianling Shen cnsztl@gmail.com
- model = "FriendlyARM NanoPi R3S";
- compatible = "friendlyarm,nanopi-r3s", "rockchip,rk3566";
- aliases {
ethernet0 = &gmac1;
mmc0 = &sdmmc0;
mmc1 = &sdhci;
- chosen: chosen {
- gpio-keys {
button-reset {
label = "reset";
- gpio-leds {
power_led: led-0 {
lan_led: led-1 {
wan_led: led-2 {
- vcc3v3_sys: regulator-vcc3v3-sys {
regulator-boot-on;
- vcc5v0_sys: regulator-vcc5v0-sys {
regulator-boot-on;
- vcc5v0_usb: regulator-vcc5v0_usb {
enable-active-high;
regulator-boot-on;
- vdd_usbc: regulator-vdd-usbc {
regulator-boot-on;
+&combphy1 {
- status = "okay";
+&combphy2 {
- status = "okay";
+&cpu0 {
- cpu-supply = <&vdd_cpu>;
+&cpu1 {
+&cpu2 {
+&cpu3 {
+&gmac1 {
- assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1>;
- assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>, <&cru CLK_MAC1_2TOP>;
- assigned-clock-rates = <0>, <125000000>;
- clock_in_out = "output";
- phy-mode = "rgmii-id";
- phy-handle = <&rgmii_phy1>;
- pinctrl-names = "default";
- pinctrl-0 = <&gmac1m0_miim
&gmac1m0_rx_bus2
- snps,reset-gpio = <&gpio4 RK_PC2 GPIO_ACTIVE_LOW>;
- snps,reset-active-low;
- /* Reset time is 20ms, 100ms for rtl8211f */
- snps,reset-delays-us = <0 20000 100000>;
- status = "okay";
+&gpu {
- mali-supply = <&vdd_gpu>;
- status = "okay";
+&i2c0 {
- status = "okay";
- vdd_cpu: regulator@1c {
reg = <0x1c>;
regulator-boot-on;
- rk809: pmic@20 {
reg = <0x20>;
#clock-cells = <1>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
+&i2c1 {
- status = "okay";
- hym8563: rtc@51 {
reg = <0x51>;
#clock-cells = <0>;
wakeup-source;
+&mdio1 {
- rgmii_phy1: ethernet-phy@1 {
reg = <1>;
+&pcie2x1 {
- pinctrl-0 = <&pcie_reset_h>;
- reset-gpios = <&gpio4 RK_PC6 GPIO_ACTIVE_HIGH>;
- status = "okay";
+&pinctrl {
- gpio-leds {
- gmac {
- pcie {
- pmic {
- rockchip-key {
- rtc {
- usb {
+&pmu_io_domains {
- status = "okay";
- pmuio1-supply = <&vcc3v3_pmu>;
- pmuio2-supply = <&vcc3v3_pmu>;
- vccio1-supply = <&vccio_acodec>;
- vccio2-supply = <&vcc_1v8>;
- vccio3-supply = <&vccio_sd>;
- vccio4-supply = <&vcc_3v3>;
- vccio5-supply = <&vcc_1v8>;
- vccio6-supply = <&vcc_3v3>;
- vccio7-supply = <&vcc_3v3>;
+&sdhci {
- bus-width = <8>;
- max-frequency = <200000000>;
- non-removable;
- pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe>;
- status = "okay";
+&sdmmc0 {
- bus-width = <4>;
- cap-mmc-highspeed;
- cap-sd-highspeed;
- disable-wp;
- no-sdio;
- no-mmc;
- pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det>;
- sd-uhs-sdr50;
- vmmc-supply = <&vcc3v3_sd>;
- vqmmc-supply = <&vccio_sd>;
- status = "okay";
+&tsadc {
- status = "okay";
+&uart2 {
- status = "okay";
+&usb2phy0 {
- status = "okay";
+&usb2phy0_host {
- phy-supply = <&vcc5v0_usb>;
- status = "okay";
+&usb2phy0_otg {
- status = "okay";
+&usb_host0_xhci {
- extcon = <&usb2phy0>;
- status = "okay";
+&usb_host1_xhci {
- status = "okay";
+&vop {
- assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>;
- assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>;
- status = "okay";
+&vop_mmu {
- status = "okay";
Use the marketing name for model name, this matches the dt-binding. Also update the website url in copyright.
Fixes: 50decd493c83 ("arm64: dts: rockchip: Add FriendlyARM NanoPi R3S board") Suggested-by: Jonas Karlman jonas@kwiboo.se Signed-off-by: Tianling Shen cnsztl@gmail.com Link: https://lore.kernel.org/r/20241022193537.1117919-2-cnsztl@gmail.com Signed-off-by: Heiko Stuebner heiko@sntech.de
[ upstream commit: b5bf84206a5c77528f9dd4cbca4e72caa063c102 ]
Signed-off-by: Tianling Shen cnsztl@gmail.com --- dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts b/dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts index a7a55d68db..6bc17f755b 100644 --- a/dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts +++ b/dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts @@ -3,7 +3,7 @@ * Copyright (c) 2020 Rockchip Electronics Co., Ltd. * * Copyright (c) 2024 FriendlyElec Computer Tech. Co., Ltd. - * (http://www.friendlyarm.com) + * (http://www.friendlyelec.com) * * Copyright (c) 2024 Tianling Shen cnsztl@gmail.com */ @@ -17,7 +17,7 @@ #include "rk3566.dtsi"
/ { - model = "FriendlyARM NanoPi R3S"; + model = "FriendlyElec NanoPi R3S"; compatible = "friendlyarm,nanopi-r3s", "rockchip,rk3566";
aliases {
Thanks, - Kever
- (http://www.friendlyelec.com)
aliases {
Replace deprecated snps,reset props and move them to the PHY node.
Fixes: 50decd493c83 ("arm64: dts: rockchip: Add FriendlyARM NanoPi R3S board") Suggested-by: Jonas Karlman jonas@kwiboo.se Signed-off-by: Tianling Shen cnsztl@gmail.com Link: https://lore.kernel.org/r/20241022193537.1117919-3-cnsztl@gmail.com Signed-off-by: Heiko Stuebner heiko@sntech.de
[ upstream commit: 82b2868937883b65732da498b26366d34db61510 ]
Signed-off-by: Tianling Shen cnsztl@gmail.com --- dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts | 7 +++---- 1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts b/dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts index 6bc17f755b..66a00cddda 100644 --- a/dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts +++ b/dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts @@ -149,10 +149,6 @@ &gmac1m0_rx_bus2 &gmac1m0_rgmii_clk_level2 &gmac1m0_rgmii_bus_level3>; - snps,reset-gpio = <&gpio4 RK_PC2 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - /* Reset time is 20ms, 100ms for rtl8211f */ - snps,reset-delays-us = <0 20000 100000>; status = "okay"; };
@@ -414,6 +410,9 @@ interrupts = <RK_PC3 IRQ_TYPE_LEVEL_LOW>; pinctrl-names = "default"; pinctrl-0 = <ð_phy_reset_pin>; + reset-assert-us = <20000>; + reset-deassert-us = <100000>; + reset-gpios = <&gpio4 RK_PC2 GPIO_ACTIVE_LOW>; }; };
Thanks, - Kever
}; };reset-gpios = <&gpio4 RK_PC2 GPIO_ACTIVE_LOW>;
The status prop is typically the last prop.
Fixes: 50decd493c83 ("arm64: dts: rockchip: Add FriendlyARM NanoPi R3S board") Suggested-by: Jonas Karlman jonas@kwiboo.se Signed-off-by: Tianling Shen cnsztl@gmail.com Link: https://lore.kernel.org/r/20241022193537.1117919-4-cnsztl@gmail.com Signed-off-by: Heiko Stuebner heiko@sntech.de
[ upstream commit: 17e150fdd983c7e59b9240e34a166285f3c3fb39 ]
Signed-off-by: Tianling Shen cnsztl@gmail.com --- dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts b/dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts index 66a00cddda..243574f8da 100644 --- a/dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts +++ b/dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts @@ -476,7 +476,6 @@ };
&pmu_io_domains { - status = "okay"; pmuio1-supply = <&vcc3v3_pmu>; pmuio2-supply = <&vcc3v3_pmu>; vccio1-supply = <&vccio_acodec>; @@ -486,6 +485,7 @@ vccio5-supply = <&vcc_1v8>; vccio6-supply = <&vcc_3v3>; vccio7-supply = <&vcc_3v3>; + status = "okay"; };
&sdhci {
Thanks, - Kever
&pmu_io_domains {
status = "okay"; };
&sdhci {
It is required to boot from eMMC without additional patch in u-boot.
Fixes: 50decd493c83 ("arm64: dts: rockchip: Add FriendlyARM NanoPi R3S board") Suggested-by: Jonas Karlman jonas@kwiboo.se Signed-off-by: Tianling Shen cnsztl@gmail.com Link: https://lore.kernel.org/r/20241022193537.1117919-5-cnsztl@gmail.com Signed-off-by: Heiko Stuebner heiko@sntech.de
[ upstream commit: 1b5365034410f1ca21adadadd492b99bdf4f2c55 ]
Signed-off-by: Tianling Shen cnsztl@gmail.com --- dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts | 1 + 1 file changed, 1 insertion(+)
diff --git a/dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts b/dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts index 243574f8da..03a2f90f62 100644 --- a/dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts +++ b/dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts @@ -491,6 +491,7 @@ &sdhci { bus-width = <8>; max-frequency = <200000000>; + mmc-hs200-1_8v; non-removable; pinctrl-names = "default"; pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe>;
Thanks, - Kever
- mmc-hs200-1_8v; non-removable; pinctrl-names = "default"; pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe>;
Typically any non-removable storage (emmc) is listed before removable storage (sd-card) options. Also U-Boot will try to override and use mmc0=sdhci and mmc1=sdmmc0 for all rk356x boards.
Fixes: 50decd493c83 ("arm64: dts: rockchip: Add FriendlyARM NanoPi R3S board") Suggested-by: Jonas Karlman jonas@kwiboo.se Signed-off-by: Tianling Shen cnsztl@gmail.com Link: https://lore.kernel.org/r/20241022193537.1117919-6-cnsztl@gmail.com Signed-off-by: Heiko Stuebner heiko@sntech.de
[ upstream commit: b7cd1115456d312f8c5e60c80fdc35fd35ea6eab ]
diff --git a/dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts b/dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts index 03a2f90f62..fb1f65c868 100644 --- a/dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts +++ b/dts/upstream/src/arm64/rockchip/rk3566-nanopi-r3s.dts @@ -22,8 +22,8 @@
aliases { ethernet0 = &gmac1; - mmc0 = &sdmmc0; - mmc1 = &sdhci; + mmc0 = &sdhci; + mmc1 = &sdmmc0; };
chosen: chosen {
Thanks, - Kever
mmc0 = &sdmmc0;
mmc1 = &sdhci;
mmc0 = &sdhci;
mmc1 = &sdmmc0;
chosen: chosen {
Signed-off-by: Tianling Shen cnsztl@gmail.com --- arch/arm/dts/rk3566-nanopi-r3s-u-boot.dtsi | 8 +++ board/rockchip/evb_rk3568/MAINTAINERS | 7 ++ configs/nanopi-r3s-rk3566_defconfig | 74 ++++++++++++++++++++++ doc/board/rockchip/rockchip.rst | 1 + 4 files changed, 90 insertions(+) create mode 100644 arch/arm/dts/rk3566-nanopi-r3s-u-boot.dtsi create mode 100644 configs/nanopi-r3s-rk3566_defconfig
diff --git a/arch/arm/dts/rk3566-nanopi-r3s-u-boot.dtsi b/arch/arm/dts/rk3566-nanopi-r3s-u-boot.dtsi new file mode 100644 index 0000000000..b66e5015d6 --- /dev/null +++ b/arch/arm/dts/rk3566-nanopi-r3s-u-boot.dtsi @@ -0,0 +1,8 @@ +// SPDX-License-Identifier: GPL-2.0-or-later + +#include "rk356x-u-boot.dtsi" + +&vcc5v0_usb { + /delete-property/ regulator-always-on; + /delete-property/ regulator-boot-on; +}; diff --git a/board/rockchip/evb_rk3568/MAINTAINERS b/board/rockchip/evb_rk3568/MAINTAINERS index 588134ecb2..b2780401a3 100644 --- a/board/rockchip/evb_rk3568/MAINTAINERS +++ b/board/rockchip/evb_rk3568/MAINTAINERS @@ -28,6 +28,13 @@ F: configs/lubancat-2-rk3568_defconfig F: arch/arm/dts/rk3568-lubancat-2.dts F: arch/arm/dts/rk3568-lubancat-2-u-boot.dtsi
+NANOPI-R3S +M: Tianling Shen cnsztl@gmail.com +R: Jonas Karlman jonas@kwiboo.se +S: Maintained +F: configs/nanopi-r3s-rk3566_defconfig +F: arch/arm/dts/rk3566-nanopi-r3s-u-boot.dtsi + NANOPI-R5C M: Tianling Shen cnsztl@gmail.com R: Jonas Karlman jonas@kwiboo.se diff --git a/configs/nanopi-r3s-rk3566_defconfig b/configs/nanopi-r3s-rk3566_defconfig new file mode 100644 index 0000000000..f21c703ca7 --- /dev/null +++ b/configs/nanopi-r3s-rk3566_defconfig @@ -0,0 +1,74 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3566-nanopi-r3s" +CONFIG_ROCKCHIP_RK3568=y +CONFIG_SPL_SERIAL=y +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_DEBUG_UART_BASE=0xFE660000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_PCI=y +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3566-nanopi-r3s.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_PHY_REALTEK=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y +CONFIG_RTL8169=y +CONFIG_NVME_PCI=y +CONFIG_PCIE_DW_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index 9bab86d234..02d7a4b124 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -99,6 +99,7 @@ List of mainline supported Rockchip boards:
* rk3566 - Anbernic RGxx3 (anbernic-rgxx3-rk3566) + - FriendlyElec NanoPi R3S (nanopi-r3s-rk3566) - Hardkernel ODROID-M1S (odroid-m1s-rk3566) - Pine64 PineTab2 (pinetab2-rk3566) - Pine64 Quartz64-A Board (quartz64-a-rk3566)
Specification:
- Rockchip RK3566
- 2GB LPDDR4X RAM
- SD card slot
- 2x 1000 Base-T
- 1x USB 3.0 Port
Thanks, - Kever
+&vcc5v0_usb {
- /delete-property/ regulator-always-on;
- /delete-property/ regulator-boot-on;
- NANOPI-R5C M: Tianling Shen cnsztl@gmail.com R: Jonas Karlman jonas@kwiboo.se
- rk3566
Hi Tianling.
You will need add below config for CONFIG_RTL8169:
CONFIG_SYS_HAS_NONCACHED_MEMORY=y
Or else we will get below error in CI:
aarch64: + nanopi-r3s-rk3566 +drivers/net/rtl8169.c:320:2: error: #warning cache-line size is larger than descriptor size [-Werror=cpp] + 320 | #warning cache-line size is larger than descriptor size + | ^~~~~~~ +cc1: all warnings being treated as errors +make[3]: *** [scripts/Makefile.build:257: drivers/net/rtl8169.o] Error 1 +make[2]: *** [scripts/Makefile.build:398: drivers/net] Error 2 +make[1]: *** [Makefile:1906: drivers] Error 2 +make: *** [Makefile:177: sub-make] Error 2
https://source.denx.de/u-boot/custodians/u-boot-rockchip/-/jobs/988639
Thanks,
- Kever
Specification:
- Rockchip RK3566
- 2GB LPDDR4X RAM
- SD card slot
- 2x 1000 Base-T
- 1x USB 3.0 Port
+&vcc5v0_usb {
- rk3566
Hi Kever,
在 2025/1/6 11:06, Kever Yang 写道:
Hi Tianling.
Thank you for fixing the issue and sorry for my mistake. I will be more careful next time.
Thanks, Tianling.
Thanks,
- Kever
Specification:
- Rockchip RK3566
- 2GB LPDDR4X RAM
- SD card slot
- 2x 1000 Base-T
- 1x USB 3.0 Port
diff --git a/arch/arm/dts/rk3566-nanopi-r3s-u-boot.dtsi b/arch/arm/ dts/rk3566-nanopi-r3s-u-boot.dtsi new file mode 100644 index 0000000000..b66e5015d6 --- /dev/null +++ b/arch/arm/dts/rk3566-nanopi-r3s-u-boot.dtsi @@ -0,0 +1,8 @@ +// SPDX-License-Identifier: GPL-2.0-or-later
+&vcc5v0_usb { + /delete-property/ regulator-always-on; + /delete-property/ regulator-boot-on; +}; diff --git a/board/rockchip/evb_rk3568/MAINTAINERS b/board/rockchip/ evb_rk3568/MAINTAINERS index 588134ecb2..b2780401a3 100644 --- a/board/rockchip/evb_rk3568/MAINTAINERS +++ b/board/rockchip/evb_rk3568/MAINTAINERS @@ -28,6 +28,13 @@ F: configs/lubancat-2-rk3568_defconfig F: arch/arm/dts/rk3568-lubancat-2.dts F: arch/arm/dts/rk3568-lubancat-2-u-boot.dtsi +NANOPI-R3S +M: Tianling Shen cnsztl@gmail.com +R: Jonas Karlman jonas@kwiboo.se +S: Maintained +F: configs/nanopi-r3s-rk3566_defconfig +F: arch/arm/dts/rk3566-nanopi-r3s-u-boot.dtsi
NANOPI-R5C M: Tianling Shen cnsztl@gmail.com R: Jonas Karlman jonas@kwiboo.se diff --git a/configs/nanopi-r3s-rk3566_defconfig b/configs/nanopi-r3s- rk3566_defconfig new file mode 100644 index 0000000000..f21c703ca7 --- /dev/null +++ b/configs/nanopi-r3s-rk3566_defconfig @@ -0,0 +1,74 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3566-nanopi-r3s" +CONFIG_ROCKCHIP_RK3568=y +CONFIG_SPL_SERIAL=y +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_DEBUG_UART_BASE=0xFE660000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_PCI=y +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3566-nanopi-r3s.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y +CONFIG_CMD_USB=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned- clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_LED=y +CONFIG_LED_GPIO=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_PHY_REALTEK=y +CONFIG_DWC_ETH_QOS=y +CONFIG_DWC_ETH_QOS_ROCKCHIP=y +CONFIG_RTL8169=y +CONFIG_NVME_PCI=y +CONFIG_PCIE_DW_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y +CONFIG_SPL_PINCTRL=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y +CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/ rockchip.rst index 9bab86d234..02d7a4b124 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -99,6 +99,7 @@ List of mainline supported Rockchip boards: * rk3566 - Anbernic RGxx3 (anbernic-rgxx3-rk3566) + - FriendlyElec NanoPi R3S (nanopi-r3s-rk3566) - Hardkernel ODROID-M1S (odroid-m1s-rk3566) - Pine64 PineTab2 (pinetab2-rk3566) - Pine64 Quartz64-A Board (quartz64-a-rk3566)
Hi Tianling,
Specification:
- Rockchip RK3566
- 2GB LPDDR4X RAM
- SD card slot
- 2x 1000 Base-T
- 1x USB 3.0 Port
+&vcc5v0_usb {
Please justify this change, this seems very odd.
I didn't see any PCIe connector for an NVMe on the R3S[1]? Did I miss something? The wiki seems to indicate there may be an NVME but that could be just a bad copy-pasting[2]?
[1] https://wiki.friendlyelec.com/wiki/index.php/NanoPi_R3S [2] https://wiki.friendlyelec.com/wiki/index.php/NanoPi_R3S#Expand_Docker_Storag...
Cheers, Quentin
Hi Quentin,
On 2025/1/14 22:48, Quentin Schulz wrote:
Hi Tianling,
Specification:
- Rockchip RK3566
- 2GB LPDDR4X RAM
- SD card slot
- 2x 1000 Base-T
- 1x USB 3.0 Port
This change is based on commit 5b155997d445 "rockchip: rk3568-nanopi-r5: Update defconfig for NanoPi R5C and R5S" and it's copy&paste.
And another commit a9e9445ea2bb "rockchip: rk3568-nanopi-r5: Enable PCIe on NanoPi R5C and R5S" removes the vpcie3v3-supply prop, not sure why.
Yes, I checked this board and it does not have NVMe slot. I will send a new patch to disable it.
Thanks, Tianling.
[1] https://wiki.friendlyelec.com/wiki/index.php/NanoPi_R3S [2] https://wiki.friendlyelec.com/wiki/index.php/ NanoPi_R3S#Expand_Docker_Storage
Cheers, Quentin
Hi Tianling,
How did you backport the above patches?
./tools/update-subtree.sh pick dts <commit>
is the tool to be used, it should have added a
(cherry picked from commit ...)
in the commit log.
Cheers, Quentin
Hi Quentin,
On 2025/1/14 22:39, Quentin Schulz wrote:
Hi Tianling,
Thank you for the tip! I did not know there's such a script and I just copy&paste the commit message from linux tree manually.
Thanks, Tianling.
in the commit log.
Cheers, Quentin
Hi Tianling,
On 1/14/25 3:49 PM, Tianling Shen wrote:
Hi Quentin,
Hi Tianling,
Mmmm, how did you apply the patch in your tree then? Trying to figure out how we can avoid this in the future.
I'm wondering if we shouldn't have tooling in place to detect when things aren't done the proper way (for maintainers I mean). We **really** want to have dts/upstream be upstream + some patches that were already merged in devicetree-rebasing tree. I don't know enough about subtree merges that Tom does when updating to a new tagged release to know if it's actually safe or if the possible mistake made when applying a commit by hand can persist without us noticing. I guess a mistake made in a manually applied patch would be caught by Tom during the merge from the next release with a merge conflict, but then that's pain for him to debug.
Cheers, Quentin
Hi Quentin,
On 2025/1/14 23:21, Quentin Schulz wrote:
Hi Tianling,
Hi Quentin,
Hi Tianling,
I fetched the patches[1] as-is from kernel and applied them by `git am -3` with path correction, then maually added the line "[ upstream commit: xxxxxx ]" to commit message.
1. https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/patch/?id...
I'm really sorry for that. All of those commits were already landed on devicetree-rebasing tree so hope everything would be fine.
Thanks, Tianling.
Cheers, Quentin
Hi Tianling,
On 1/14/25 5:14 PM, Tianling Shen wrote:
Hi Quentin,
Hi Tianling,
Hi Quentin,
Hi Tianling,
url=https%3A%2F%2Fgit.kernel.org%2Fpub%2Fscm%2Flinux%2Fkernel%2Fgit%2Ftorvalds%2Flinux.git%2Fpatch%2F%3Fid%3D50decd493c8394c52d04561fe4ede34df27a46ba&data=05%7C02%7Cquentin.schulz%40cherry.de%7C72d5c95645ef4197c18908dd34b69565%7C5e0e1b5221b54e7b83bb514ec460677e%7C0%7C0%7C638724680973346196%7CUnknown%7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ%3D%3D%7C0%7C%7C%7C&sdata=urDrXWTzIt2NF%2BUrBSO1FnSTxjBO5Q4nYHFU9i%2BRII0%3D&reserved=0
https://eur02.safelinks.protection.outlook.com/? url=https%3A%2F%2Fgit.kernel.org%2Fpub%2Fscm%2Flinux%2Fkernel%2Fgit%2Ftorvalds%2Flinux.git%2Fpatch%2F%3Fid%3Db5bf84206a5c77528f9dd4cbca4e72caa063c102&data=05%7C02%7Cquentin.schulz%40cherry.de%7C72d5c95645ef4197c18908dd34b69565%7C5e0e1b5221b54e7b83bb514ec460677e%7C0%7C0%7C638724680973368900%7CUnknown%7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ%3D%3D%7C0%7C%7C%7C&sdata=x4CksM87w51QxzlrqNqjKvpQOJ6KKmSFQ01hoWmiCyg%3D&reserved=0
https://eur02.safelinks.protection.outlook.com/? url=https%3A%2F%2Fgit.kernel.org%2Fpub%2Fscm%2Flinux%2Fkernel%2Fgit%2Ftorvalds%2Flinux.git%2Fpatch%2F%3Fid%3D82b2868937883b65732da498b26366d34db61510&data=05%7C02%7Cquentin.schulz%40cherry.de%7C72d5c95645ef4197c18908dd34b69565%7C5e0e1b5221b54e7b83bb514ec460677e%7C0%7C0%7C638724680973382545%7CUnknown%7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ%3D%3D%7C0%7C%7C%7C&sdata=qyjod1yP7k%2F7bhjfHdZqn3LqettTPI41duikY0NRveg%3D&reserved=0
https://eur02.safelinks.protection.outlook.com/? url=https%3A%2F%2Fgit.kernel.org%2Fpub%2Fscm%2Flinux%2Fkernel%2Fgit%2Ftorvalds%2Flinux.git%2Fpatch%2F%3Fid%3D17e150fdd983c7e59b9240e34a166285f3c3fb39&data=05%7C02%7Cquentin.schulz%40cherry.de%7C72d5c95645ef4197c18908dd34b69565%7C5e0e1b5221b54e7b83bb514ec460677e%7C0%7C0%7C638724680973396320%7CUnknown%7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ%3D%3D%7C0%7C%7C%7C&sdata=Zv7tjHe0VKKp%2FuIBFu5zrO%2BusEVjm%2F3lJ73jdaTmVuA%3D&reserved=0
https://eur02.safelinks.protection.outlook.com/? url=https%3A%2F%2Fgit.kernel.org%2Fpub%2Fscm%2Flinux%2Fkernel%2Fgit%2Ftorvalds%2Flinux.git%2Fpatch%2F%3Fid%3D1b5365034410f1ca21adadadd492b99bdf4f2c55&data=05%7C02%7Cquentin.schulz%40cherry.de%7C72d5c95645ef4197c18908dd34b69565%7C5e0e1b5221b54e7b83bb514ec460677e%7C0%7C0%7C638724680973413639%7CUnknown%7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ%3D%3D%7C0%7C%7C%7C&sdata=%2F3uw74TSfuoUpOFkfJPLWzKjoh331Y5RaPvEa4DrDs4%3D&reserved=0
https://eur02.safelinks.protection.outlook.com/? url=https%3A%2F%2Fgit.kernel.org%2Fpub%2Fscm%2Flinux%2Fkernel%2Fgit%2Ftorvalds%2Flinux.git%2Fpatch%2F%3Fid%3Db7cd1115456d312f8c5e60c80fdc35fd35ea6eab&data=05%7C02%7Cquentin.schulz%40cherry.de%7C72d5c95645ef4197c18908dd34b69565%7C5e0e1b5221b54e7b83bb514ec460677e%7C0%7C0%7C638724680973431321%7CUnknown%7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ%3D%3D%7C0%7C%7C%7C&sdata=pFych4CEp7BfolVm1KMGk828MIkCaMRNw8hCf7p2ldI%3D&reserved=0
Thanks for explaining!
Nothing to feel sorry for, we should have caught that before merging the patches, so the blame is rather on reviewers/maintainers :) If someone made the mistake once, it'll happen a second time. I'm glad it was caught now, so at least we're aware it's a possibility and we should either be more vigilant or write tooling for that.
For what it's worth, the documentation is here on how to cherry pick device tree changes: https://docs.u-boot.org/en/latest/develop/devicetree/control.html#resyncing-...
I'm not too sure if there's tooling we could write to check that the patches to dts/upstream, were done the proper way. I'm not sure anyone wants to touch the checkpatch Perl script and that would still not necessarily be run by the maintainer(s) when merging (don't know what's the process there). If merge requests are always coming from a GitLab tree, maybe there's something we could do from GitLab CI for any change made in dts/upstream/ subtree? (like remove the commit, reapply the patch on its parent with ./tools/update-subtree.sh pick dts pick <> and see if the commit log and content is the same?).
+Cc Tom for at least awareness, hope you don't mind.
Maybe I'm also making this a bigger problem than it is as I am no maintainer :)
Cheers, Quentin
Kever Yang
Quentin Schulz
Tianling Shen
