[U-Boot] [PATCH] MIPS: board.c: remove manual relocation of env_name_spec
Remove the manual relocation of env_name_spec. This has been missed in the previous patch series for introducing dynamic relocation on MIPS.
Signed-off-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com --- arch/mips/lib/board.c | 8 -------- 1 file changed, 8 deletions(-)
diff --git a/arch/mips/lib/board.c b/arch/mips/lib/board.c index 7a656f6..6c65d97 100644 --- a/arch/mips/lib/board.c +++ b/arch/mips/lib/board.c @@ -267,9 +267,6 @@ void board_init_r(gd_t *id, ulong dest_addr) #ifndef CONFIG_SYS_NO_FLASH ulong size; #endif -#ifndef CONFIG_ENV_IS_NOWHERE - extern char *env_name_spec; -#endif bd_t *bd;
gd = id; @@ -283,11 +280,6 @@ void board_init_r(gd_t *id, ulong dest_addr)
serial_initialize();
- /* there are some other pointer constants we must deal with */ -#ifndef CONFIG_ENV_IS_NOWHERE - env_name_spec += gd->reloc_off; -#endif - bd = gd->bd;
/* The Malloc area is immediately below the monitor copy in DRAM */
Daniel Schwierzeck
