[PATCH v1 0/1] sunxi: h3: Add initial ZeroPi support
This commit add support to FriendlyARM ZeroPi board.
Board Schematic: http://wiki.friendlyarm.com/wiki/images/7/71/ZeroPi_20190731_Schematic.pdf
- v1 . fix trailing whitespace
Yu-Tung Chang (1): sunxi: h3: Add initial ZeroPi support
arch/arm/dts/Makefile | 3 +- arch/arm/dts/sun8i-h3-zeropi.dts | 48 ++++++++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 6 ++++ configs/zeropi_defconfig | 13 +++++++++ 4 files changed, 69 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/sun8i-h3-zeropi.dts create mode 100644 configs/zeropi_defconfig
ZeroPi is a new board of high performance with low cost designed by FriendlyElec., using the Allwinner H3 SOC.
ZeroPi features - Allwinner H3, Quad-core Cortex-A7@1.2GHz - 256MB/512MB DDR3 RAM - microsd slot - 10/100/1000Mbps Ethernet - Debug Serial Port - DC 5V/2A power-supply
Signed-off-by: Yu-Tung Chang mtwget@gmail.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/sun8i-h3-zeropi.dts | 48 ++++++++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 6 ++++ configs/zeropi_defconfig | 13 +++++++++ 4 files changed, 69 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/sun8i-h3-zeropi.dts create mode 100644 configs/zeropi_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 096068261d..7c8e253350 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -607,7 +607,8 @@ dtb-$(CONFIG_MACH_SUN8I_H3) += \ sun8i-h3-orangepi-plus.dtb \ sun8i-h3-orangepi-plus2e.dtb \ sun8i-h3-orangepi-zero-plus2.dtb \ - sun8i-h3-rervision-dvk.dtb + sun8i-h3-rervision-dvk.dtb \ + sun8i-h3-zeropi.dtb dtb-$(CONFIG_MACH_SUN8I_R40) += \ sun8i-r40-bananapi-m2-ultra.dtb \ sun8i-v40-bananapi-m2-berry.dtb diff --git a/arch/arm/dts/sun8i-h3-zeropi.dts b/arch/arm/dts/sun8i-h3-zeropi.dts new file mode 100644 index 0000000000..e36381f11b --- /dev/null +++ b/arch/arm/dts/sun8i-h3-zeropi.dts @@ -0,0 +1,48 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (C) 2021 Yu-Tung Chang mtwget@gmail.com + */ + +#include "sun8i-h3-nanopi.dtsi" + +/ { + model = "FriendlyARM ZeroPi"; + compatible = "friendlyarm,zeropi", "allwinner,sun8i-h3"; + + aliases { + ethernet0 = &emac; + }; + + reg_gmac_3v3: gmac-3v3 { + compatible = "regulator-fixed"; + regulator-name = "gmac-3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + startup-delay-us = <100000>; + enable-active-high; + gpio = <&pio 3 6 GPIO_ACTIVE_HIGH>; /* PD6 */ + }; +}; + +&external_mdio { + ext_rgmii_phy: ethernet-phy@7 { + compatible = "ethernet-phy-ieee802.3-c22"; + reg = <7>; + }; +}; + +&emac { + pinctrl-names = "default"; + pinctrl-0 = <&emac_rgmii_pins>; + phy-supply = <®_gmac_3v3>; + phy-handle = <&ext_rgmii_phy>; + phy-mode = "rgmii-id"; + + allwinner,leds-active-low; + status = "okay"; +}; + +&usb_otg { + status = "okay"; + dr_mode = "host"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 76eba2ad20..4fc26077b2 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -529,3 +529,9 @@ YONES TOPTECH BS1078 V2 BOARD M: Peter Korsgaard peter@korsgaard.com S: Maintained F: configs/Yones_Toptech_BS1078_V2_defconfig + +ZEROPI BOARD +M: Yu-Tung Chang mtwget@gmail.com +S: Maintained +F: configs/zeropi_defconfig +F: arch/arm/dts/sun8i-h3-zeropi.dts diff --git a/configs/zeropi_defconfig b/configs/zeropi_defconfig new file mode 100644 index 0000000000..f921b09892 --- /dev/null +++ b/configs/zeropi_defconfig @@ -0,0 +1,13 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_SPL=y +CONFIG_MACH_SUN8I_H3=y +CONFIG_DRAM_CLK=408 +CONFIG_MACPWR="PD6" +# CONFIG_VIDEO_DE2 is not set +CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-zeropi" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_CONSOLE_MUX=y +CONFIG_SUN8I_EMAC=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OHCI_HCD=y
ZeroPi features
- microsd slot
- Debug Serial Port
Looks alright, thanks for sending this. One nit below.
- sun8i-h3-rervision-dvk.dtb \
- sun8i-h3-zeropi.dtb
While I like those SPDX lines more, the Linux kernel copy still(?) uses the more explicit license header. And we aim to stay as close as possible to the kernel DTs, that includes comments as well.
So if you resend a v2 which just copies the kernel .dts, I will queue it for the next merge window.
Cheers, Andre
P.S. For the first version of a single patch "series", just use "[PATCH]" in the subject. There is never a "v1", and also little reason for a "1/1". If you have some comments that would typically go into a cover letter, put them behind the "---" in the top of the email.
- Copyright (C) 2021 Yu-Tung Chang mtwget@gmail.com
- model = "FriendlyARM ZeroPi";
- compatible = "friendlyarm,zeropi", "allwinner,sun8i-h3";
- aliases {
ethernet0 = &emac;
- reg_gmac_3v3: gmac-3v3 {
enable-active-high;
+&external_mdio {
- ext_rgmii_phy: ethernet-phy@7 {
reg = <7>;
+&emac {
- pinctrl-names = "default";
- pinctrl-0 = <&emac_rgmii_pins>;
- phy-supply = <®_gmac_3v3>;
- phy-handle = <&ext_rgmii_phy>;
- phy-mode = "rgmii-id";
- allwinner,leds-active-low;
- status = "okay";
+&usb_otg {
- status = "okay";
- dr_mode = "host";
Andre Przywara
Yu-Tung Chang
