[PATCH] arm:suniv:complete the serial port configuration of Suniv
111
Signed-off-by: lhdjply lhdjply@126.com --- arch/arm/mach-sunxi/board.c | 4 ++-- include/sunxi_gpio.h | 6 ++++++ 2 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index f4dbb2a740..b91c9629e4 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -151,8 +151,8 @@ static int gpio_init(void) sunxi_gpio_set_cfgpin(SUNXI_GPE(3), 6); sunxi_gpio_set_pull(SUNXI_GPE(3), SUNXI_GPIO_PULL_UP); #elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_MACH_SUNIV) - sunxi_gpio_set_cfgpin(SUNXI_GPA(2), SUNIV_GPE_UART0); - sunxi_gpio_set_cfgpin(SUNXI_GPA(3), SUNIV_GPE_UART0); + sunxi_gpio_set_cfgpin(SUNXI_GPA(2), SUNIV_GPA_UART1); + sunxi_gpio_set_cfgpin(SUNXI_GPA(3), SUNIV_GPA_UART1); sunxi_gpio_set_pull(SUNXI_GPA(3), SUNXI_GPIO_PULL_UP); #elif CONFIG_CONS_INDEX == 2 && defined(CONFIG_MACH_SUN5I) sunxi_gpio_set_cfgpin(SUNXI_GPG(3), SUN5I_GPG_UART1); diff --git a/include/sunxi_gpio.h b/include/sunxi_gpio.h index db3742c039..51258e3dd9 100644 --- a/include/sunxi_gpio.h +++ b/include/sunxi_gpio.h @@ -108,6 +108,8 @@ enum sunxi_gpio_number { #define SUN8I_H3_GPA_UART0 2 #define SUN8I_H3_GPA_UART2 2
+#define SUNIV_GPA_UART1 5 + #define SUN4I_GPB_PWM 2 #define SUN4I_GPB_TWI0 2 #define SUN4I_GPB_TWI1 2 @@ -130,12 +132,16 @@ enum sunxi_gpio_number {
#define SUNXI_GPD_LCD0 2 #define SUNXI_GPD_LVDS0 3 +#define SUNIV_GPD_UART1 3 +#define SUNIV_GPD_UART2 3
#define SUNIV_GPE_UART0 5 +#define SUNIV_GPE_UART2 3
#define SUNXI_GPF_SDC0 2 #define SUNXI_GPF_UART0 4 #define SUN8I_GPF_UART0 3 +#define SUNIV_GPF_UART0 3
#define SUN4I_GPG_SDC1 4 #define SUN5I_GPG_SDC1 2
On Wed, 13 Mar 2024 13:33:23 +0800 lhdjply@126.com wrote:
111
There should be a proper commit message here, explaining *why* this patch is needed. So what does this patch or which problem does it solve?
Please note that I consider those "SUNxx_GPy_UARTz" symbols nonsense, since they do not carry real information. I thought about replacing all those pinmux defines with something like SUNXI_PINMUX_x, defined to x, so say: "#define SUNXI_PINMUX_5 5". Does that sound better to you?
Cheers, Andre
- sunxi_gpio_set_cfgpin(SUNXI_GPA(2), SUNIV_GPA_UART1);
- sunxi_gpio_set_cfgpin(SUNXI_GPA(3), SUNIV_GPA_UART1); sunxi_gpio_set_pull(SUNXI_GPA(3), SUNXI_GPIO_PULL_UP);
Andre Przywara
lhdjply@126.com
