[U-Boot] [PATCH 1/1] efi_loader: SPDX-License-Identifier for efi_api.h
Add the missing SPDX-License-Identifier based on Linux kernel commit b24413180f56 ("License cleanup: add SPDX GPL-2.0 license identifier to files with no license").
Correct formatting errors.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- include/efi_api.h | 28 ++++++++++------------------ 1 file changed, 10 insertions(+), 18 deletions(-)
diff --git a/include/efi_api.h b/include/efi_api.h index 26e88f494c..f1c4e59f3a 100644 --- a/include/efi_api.h +++ b/include/efi_api.h @@ -1,3 +1,4 @@ +/* SPDX-License-Identifier: GPL-2.0 */ /* * Extensible Firmware Interface * Based on 'Extensible Firmware Interface Specification' version 0.9, @@ -295,8 +296,7 @@ struct efi_runtime_services { EFI_GUID(0xeb9d2d31, 0x2d88, 0x11d3, \ 0x9a, 0x16, 0x00, 0x90, 0x27, 0x3f, 0xc1, 0x4d)
-struct efi_configuration_table -{ +struct efi_configuration_table { efi_guid_t guid; void *table; }; @@ -351,7 +351,7 @@ struct efi_loaded_image {
#define DEVICE_PATH_GUID \ EFI_GUID(0x09576e91, 0x6d3f, 0x11d2, \ - 0x8e, 0x39, 0x00, 0xa0, 0xc9, 0x69, 0x72, 0x3b ) + 0x8e, 0x39, 0x00, 0xa0, 0xc9, 0x69, 0x72, 0x3b)
#define DEVICE_PATH_TYPE_END 0x7f # define DEVICE_PATH_SUB_TYPE_INSTANCE_END 0x01 @@ -476,8 +476,7 @@ struct efi_device_path_file_path { EFI_GUID(0x964e5b21, 0x6459, 0x11d2, \ 0x8e, 0x39, 0x00, 0xa0, 0xc9, 0x69, 0x72, 0x3b)
-struct efi_block_io_media -{ +struct efi_block_io_media { u32 media_id; char removable_media; char media_present; @@ -522,7 +521,6 @@ struct simple_text_output_mode { bool cursor_visible; };
- #define EFI_SIMPLE_TEXT_OUTPUT_PROTOCOL_GUID \ EFI_GUID(0x387477c2, 0x69c7, 0x11d2, \ 0x8e, 0x39, 0x0, 0xa0, 0xc9, 0x69, 0x72, 0x3b) @@ -611,8 +609,7 @@ struct efi_simple_text_input_protocol { EFI_GUID(0x8b843e20, 0x8132, 0x4852, \ 0x90, 0xcc, 0x55, 0x1a, 0x4e, 0x4a, 0x7f, 0x1c)
-struct efi_device_path_to_text_protocol -{ +struct efi_device_path_to_text_protocol { uint16_t *(EFIAPI *convert_device_node_to_text)( struct efi_device_path *device_node, bool display_only, @@ -660,8 +657,7 @@ struct efi_device_path_utilities_protocol { #define EFI_GOT_BGRA8 1 #define EFI_GOT_BITMASK 2
-struct efi_gop_mode_info -{ +struct efi_gop_mode_info { u32 version; u32 width; u32 height; @@ -670,8 +666,7 @@ struct efi_gop_mode_info u32 pixels_per_scanline; };
-struct efi_gop_mode -{ +struct efi_gop_mode { u32 max_mode; u32 mode; struct efi_gop_mode_info *info; @@ -692,8 +687,7 @@ struct efi_gop_pixel { #define EFI_BLT_BUFFER_TO_VIDEO 2 #define EFI_BLT_VIDEO_TO_VIDEO 3
-struct efi_gop -{ +struct efi_gop { efi_status_t (EFIAPI *query_mode)(struct efi_gop *this, u32 mode_number, efi_uintn_t *size_of_info, struct efi_gop_mode_info **info); @@ -763,8 +757,7 @@ struct efi_simple_network_mode { /* revision of the simple network protocol */ #define EFI_SIMPLE_NETWORK_PROTOCOL_REVISION 0x00010000
-struct efi_simple_network -{ +struct efi_simple_network { u64 revision; efi_status_t (EFIAPI *start)(struct efi_simple_network *this); efi_status_t (EFIAPI *stop)(struct efi_simple_network *this); @@ -809,8 +802,7 @@ struct efi_pxe_packet { u8 packet[1472]; };
-struct efi_pxe_mode -{ +struct efi_pxe_mode { u8 started; u8 ipv6_available; u8 ipv6_supported;
