[PATCH] imx: ahab: fix implicit declaration warning
Fix the following warning:
arch/arm/mach-imx/imx8/ahab.c:105:3: warning: implicit declaration of function ‘flush_dcache_range’ [-Wimplicit-function-declaration] flush_dcache_range(s, e); ^~~~~~~~~~~~~~~~~~
Include cpu_func.h header which declares the flush_dcache_range() function.
Signed-off-by: Oliver Graute oliver.graute@kococonnector.com Cc: Stefano Babic sbabic@denx.de Cc: uboot-imx uboot-imx@nxp.com --- arch/arm/mach-imx/imx8/ahab.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-imx/imx8/ahab.c b/arch/arm/mach-imx/imx8/ahab.c index 5dbe1d56e0..abd648a60c 100644 --- a/arch/arm/mach-imx/imx8/ahab.c +++ b/arch/arm/mach-imx/imx8/ahab.c @@ -14,6 +14,7 @@ #include <asm/arch/sys_proto.h> #include <asm/arch/image.h> #include <console.h> +#include <cpu_func.h>
DECLARE_GLOBAL_DATA_PTR;
arch/arm/mach-imx/imx8/ahab.c: In function ‘authenticate_os_container’: arch/arm/mach-imx/imx8/ahab.c:96:9: warning: format ‘%x’ expects argument of type ‘unsigned int’, but argument 9 has type ‘ulong {aka long unsigned int}’ [-Wformat=] debug("img %d, dst 0x%x, src 0x%x, size 0x%x\n",
Fix those by using "%lu" specified.
Signed-off-by: Oliver Graute oliver.graute@kococonnector.com Cc: Stefano Babic sbabic@denx.de Cc: uboot-imx uboot-imx@nxp.com --- arch/arm/mach-imx/imx8/ahab.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-imx/imx8/ahab.c b/arch/arm/mach-imx/imx8/ahab.c index abd648a60c..c77beb2b16 100644 --- a/arch/arm/mach-imx/imx8/ahab.c +++ b/arch/arm/mach-imx/imx8/ahab.c @@ -93,7 +93,7 @@ int authenticate_os_container(ulong addr) sizeof(struct container_hdr) + i * sizeof(struct boot_img_t));
- debug("img %d, dst 0x%x, src 0x%x, size 0x%x\n", + debug("img %d, dst 0x%x, src 0x%lux, size 0x%x\n", i, (uint32_t) img->dst, img->offset + addr, img->size);
memcpy((void *)img->dst, (const void *)(img->offset + addr),
arch/arm/mach-imx/imx8/ahab.c: In function ‘authenticate_os_container’: arch/arm/mach-imx/imx8/ahab.c:96:9: warning: format ‘%x’ expects argument of type ‘unsigned int’, but argument 9 has type ‘ulong {aka long unsigned int}’ [-Wformat=] debug("img %d, dst 0x%x, src 0x%x, size 0x%x\n", Fix those by using "%lu" specified. Signed-off-by: Oliver Graute oliver.graute@kococonnector.com Cc: Stefano Babic sbabic@denx.de Cc: uboot-imx uboot-imx@nxp.com
Best regards, Stefano Babic
arch/arm/mach-imx/imx8/ahab.c:110:63: warning: format ‘%x’ expects argument of type ‘unsigned int’, but argument 2 has type ‘u64 {aka long long unsigned int}’ [-Wformat=]
Fix those by using %llx
diff --git a/arch/arm/mach-imx/imx8/ahab.c b/arch/arm/mach-imx/imx8/ahab.c index c77beb2b16..4bb7c46921 100644 --- a/arch/arm/mach-imx/imx8/ahab.c +++ b/arch/arm/mach-imx/imx8/ahab.c @@ -107,7 +107,7 @@ int authenticate_os_container(ulong addr) /* Find the memreg and set permission for seco pt */ err = sc_rm_find_memreg(-1, &mr, s, e); if (err) { - printf("Error: can't find memreg for image load address 0x%x, error %d\n", img->dst, err); + printf("Error: can't find memreg for image load address 0x%llx, error %d\n", img->dst, err); ret = -ENOMEM; goto exit; }
arch/arm/mach-imx/imx8/ahab.c:110:63: warning: format ‘%x’ expects argument of type ‘unsigned int’, but argument 2 has type ‘u64 {aka long long unsigned int}’ [-Wformat=] Fix those by using %llx Signed-off-by: Oliver Graute oliver.graute@kococonnector.com Cc: Stefano Babic sbabic@denx.de Cc: uboot-imx uboot-imx@nxp.com
Fix the following warning: arch/arm/mach-imx/imx8/ahab.c:105:3: warning: implicit declaration of function ‘flush_dcache_range’ [-Wimplicit-function-declaration] flush_dcache_range(s, e); ^~~~~~~~~~~~~~~~~~ Include cpu_func.h header which declares the flush_dcache_range() function. Signed-off-by: Oliver Graute oliver.graute@kococonnector.com Cc: Stefano Babic sbabic@denx.de Cc: uboot-imx uboot-imx@nxp.com
Oliver Graute
sbabic@denx.de
