[U-Boot] [PATCH 1/3] mx27: generic.c: Fix Codyng Style
Fix warning reported by checkpatch.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/arm926ejs/mx27/generic.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx27/generic.c b/arch/arm/cpu/arm926ejs/mx27/generic.c index 222a8e9..33640ce 100644 --- a/arch/arm/cpu/arm926ejs/mx27/generic.c +++ b/arch/arm/cpu/arm926ejs/mx27/generic.c @@ -153,7 +153,7 @@ ulong imx_get_perclk4(void) }
#if defined(CONFIG_DISPLAY_CPUINFO) -int print_cpuinfo (void) +int print_cpuinfo(void) { char buf[32];
Fix warnings reported by checkpatch.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/arm926ejs/mx27/timer.c | 14 +++++++------- 1 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx27/timer.c b/arch/arm/cpu/arm926ejs/mx27/timer.c index df76d16..5af9359 100644 --- a/arch/arm/cpu/arm926ejs/mx27/timer.c +++ b/arch/arm/cpu/arm926ejs/mx27/timer.c @@ -45,8 +45,8 @@
DECLARE_GLOBAL_DATA_PTR;
-#define timestamp gd->tbl -#define lastinc gd->lastinc +#define timestamp (gd->tbl) +#define lastinc (gd->lastinc)
/* * "time" is measured in 1 / CONFIG_SYS_HZ seconds, @@ -124,7 +124,7 @@ int timer_init(void) return 0; }
-unsigned long long get_ticks (void) +unsigned long long get_ticks(void) { struct gpt_regs *regs = (struct gpt_regs *)IMX_TIM1_BASE; ulong now = readl(®s->gpt_tcn); /* current tick value */ @@ -143,7 +143,7 @@ unsigned long long get_ticks (void) return timestamp; }
-ulong get_timer_masked (void) +ulong get_timer_masked(void) { /* * get_ticks() returns a long long (64 bit), it wraps in @@ -154,13 +154,13 @@ ulong get_timer_masked (void) return tick_to_time(get_ticks()); }
-ulong get_timer (ulong base) +ulong get_timer(ulong base) { - return get_timer_masked () - base; + return get_timer_masked() - base; }
/* delay x useconds AND preserve advance timstamp value */ -void __udelay (unsigned long usec) +void __udelay(unsigned long usec) { unsigned long long tmp; ulong tmo;
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/arm926ejs/mx27/reset.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mx27/reset.c b/arch/arm/cpu/arm926ejs/mx27/reset.c index 6c54eaf..cc0a33e 100644 --- a/arch/arm/cpu/arm926ejs/mx27/reset.c +++ b/arch/arm/cpu/arm926ejs/mx27/reset.c @@ -39,7 +39,7 @@ /* * Reset the cpu by setting up the watchdog timer and let it time out */ -void reset_cpu (ulong ignored) +void reset_cpu(ulong ignored) { struct wdog_regs *regs = (struct wdog_regs *)IMX_WDT_BASE; /* Disable watchdog and set Time-Out field to 0 */
Fabio Estevam
